path: root/drivers/char/watchdog/indydog.c
2007-01-27[WATCHDOG] show default value for nowayout in module parameterWim Van Sebroeck
change default=CONFIG_WATCHDOG_NOWAYOUT in the module parameter for nowayout by it's real value (0 or 1) by using: __MODULE_STRING(WATCHDOG_NOWAYOUT) Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2006-10-02[WATCHDOG] use ENOTTY instead of ENOIOCTLCMD in ioctl()Samuel Tardieu
Return ENOTTY instead of ENOIOCTLCMD in user-visible ioctl() results The watchdog drivers used to return ENOIOCTLCMD for bad ioctl() commands. ENOIOCTLCMD should not be visible by the user, so use ENOTTY instead. Signed-off-by: Samuel Tardieu <sam@rfc1149.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org>
2006-07-03[PATCH] make more file_operation structs staticArjan van de Ven
Mark the static struct file_operations in drivers/char as const. Making them const prevents accidental bugs, and moves them to the .rodata section so that they no longer do any false sharing; in addition with the proper debug option they are then protected against corruption.. [akpm@osdl.org: build fix] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] consolidate CONFIG_WATCHDOG_NOWAYOUT handlingAndrey Panin
Attached patch removes #ifdef CONFIG_WATCHDOG_NOWAYOUT mess duplicated in almost every watchdog driver and replaces it with common define in linux/watchdog.h. Signed-off-by: Andrey Panin <pazke@donpac.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
