This is a driver for the on-chip watchdog device found on some
MIPS RM9000 processors.
Signed-off-by: Thomas Koeller <thomas.koeller@baslerweb.com>
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
Add vendor specific support to the intel TCO timer based watchdog
devices. At this moment we only have additional support for some
SuperMicro Inc. motherboards.
Signed-off-by: Robert Seretny <lkpatches@paypc.com>
New watchdog driver for the NS pc87413-wdt Watchdog Timer.
Signed-off-by: Sven Anders <anders@anduras.de>
Signed-off-by: Marcus Junker <junker@anduras.de>
The iTCO_wdt.c driver has been tested enough. So we can
remove the experimental classification.
The new Atmel AT91SAM9261 and AT91SAM9260 processors use a different
internal watchdog peripheral. This watchdog driver is therefore
AT91RM9200-specific.
This patch renames at91_wdt.c to at91rm9200_wdt.c, and changes the name
of the configuration option.
Signed-off-by: Andrew Victor <andrew@sanpeople.com>
Update Kconfig for the w83697hf/hg watchdog driver.
Signed-off-by: Samuel Tardieu <sam@rfc1149.net>
fixed some more trailing spaces.
* fix typo's according to spellings checker
* Fix some leading and trailing spaces
New watchdog driver for the Winbond W83697HF chipset.
New watchdog driver for the Winbond SMsC37B787 chipset.
Hardware driver for the intel TCO timer based watchdog devices.
These drivers are included in the Intel 82801 I/O Controller
Hub family (from ICH0 up to ICH7) and in the Intel 6300ESB
controller hub.
This driver will replace the i8xx_tco.c driver.
Add watchdog support for Philips PNX4008 ARM board inlined.
Signed-off-by: Vitaly Wool <vitalywool@gmail.com>
Add Texas Instruments (TI) OMAP1/2 (http://www.ti.com/omap) based
processors, like OMAP1610/1710/242x.
[akpm@osdl.org: cleanups]
Cc: <gdavis@mvista.com>
Cc: "Komal Shah" <komal_shah802003@yahoo.com>
In some applications people have expressed a need for an mmap() method,
so we implement a simple stub for this that maps back a page with the
counter in it.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Three typos in drivers/char/watchdog/Kconfig...
Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com>
Watchdog driver for the Atmel AT91RM9200 processor.
Add a driver for the on-chip watchdog on the cirrus ep93xx series of ARM
CPUs.
Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org>
Cc: Wim Van Sebroeck <wim@iguana.be>
Signed-off-by: Alessandro Zummo <a.zummo@towertech.it>
Add support for the PowerPC MPC83xx watchdog. The MPC83xx has a simple
watchdog that once enabled it can not be stopped, has some simple timeout
range selection, and the ability to either reset the processor or take a
machine check.
Signed-off-by: Dave Updegraff <dave@cray.org>
This is a 2.6 patch that adds support for the watchdog timer built into the
EPX-C3 single board computer manufactured by Winsystems, Inc.
Driver details:
This is for x86 only. This watchdog is pretty basic and simple. It is
only configurable via jumpers on the SBC, and it only has either a 1.5s or
200s interval. The watchdog can either be auto-configured to start as soon
as the machine powers up (bad idea for the 1.5s interval!) or it can be
enabled and disabled by writing to io port 0x1ee. Petting the watchdog
involves writing any value to io port 0x1ef.
The only unfortunate thing about this watchdog (and it is not at all
uncommmon in watchdogs that linux supports) is that it is not a PCI or
ISA-PNP device and as such it isn't at all probeable. Either the watchdog
exists as 2 bytes at 0x1ee, or it doesn't. Thus, using this driver on a
machine that doesn't have that watchdog can potentially hang/crash the
system, etc. So only use this driver if you in fact are on a Winsystems
EPX-C3 SBC.
Anyway this driver fits into the already-existing watchdog framework quite
nicely and I already tested it on my EPX-C3 and it works like a charm.
Signed-off-by: Calin A. Culianu <calin@ajvar.org>
Sanitize some s390 Kconfig options. We have ARCH_S390, ARCH_S390X,
ARCH_S390_31, 64BIT, S390_SUPPORT and COMPAT. Replace these 6 options by
S390, 64BIT and COMPAT.
Add platform independent parts of the ARM MPCore watchdog driver.
In a project for my company I've needed to use the watchdog device in a
PCM-5335 SBC from AAEON. The watchdog timer is from a Winbond's SuperIO
chip, the W83977F.
I've made this driver based on two others already on the kernel tree,
the w83877f_wdt and the wdt977.
Signed-off-by: Jose Goncalves <jose.goncalves@inov.pt>
New SBC8360 watchdog driver patch
This patch adds driver for IBM Automatic Server Restart watchdog hardware
found in some IBM eServer xSeries machines. This driver is based on the ugly
driver provided by IBM. Driver was tested on IBM eServer 226.
Signed-off-by: Andrey Panin <pazke@donpac.ru>
I wrote earlier to the list[1] asking for a driver for the watchdog
included in the 6300ESB chipset. I got a 2.4 driver via private email
from Ross Biro which I've changed into what I hope resembles a 2.6
driver (which was done by looking a lot at the watchdog drivers
already in the 2.6 tree).
I've attached the result, and I'm hoping to get some feedback on the
coding as a first step. I can't actually test it on the hardware
right now as I won't have physical access until April. So my own tests
have been limited to "compiles-without-warnings" and
"can-be-insmodded-in-other-machine-without-oops".
[1] http://marc.theaimsgroup.com/?l=linux-kernel&m=110711079825794&w=2
[2] http://marc.theaimsgroup.com/?l=linux-kernel&m=110711973917746&w=2
Signed-off-by: David Hardeman <david@2gen.com>
Add mv64x60 (Marvell Discovery) watchdog support.
Signed-off-by: James Chapman <jchapman@katalix.com>
Clean the Kconfig+Makefile according to a sorted list
of the drivers of each architecture (and sub-architecture).
Renamed global variables used to convey if the watchdog is enabled and
periodicity of the timer and moved the declarations into a header for these
variables
Signed-off-by: Matt McClintock <msm@freescale.com>
Signed-off-by: Kumar Gala <kumar.gala@freescale.com>
PowerPC 40x and Book-E processors support a watchdog timer at the processor
core level. The timer has implementation dependent timeout frequencies
that can be configured by software.
One the first Watchdog timeout we get a critical exception. It is left to
board specific code to determine what should happen at this point. If
nothing is done and another timeout period expires the processor may
attempt to reset the machine.
Command line parameters:
wdt=0 : disable watchdog (default)
wdt=1 : enable watchdog
wdt_period=N : N sets the value of the Watchdog Timer Period.
The Watchdog Timer Period meaning is implementation specific. Check
User Manual for the processor for more details.
This patch is based off of work done by Takeharu Kato.
Add a watchdog using the RTAS OS surveillance service. This is
provided as a simpler alternative to rtasd. The added value
is that it works with standard watchdog client programs and
can therefore also do user space monitoring.
On BPA, rtasd is not really useful because the hardware does
not have much to report with event-scan.
The driver should also work on other platforms that support
the OS surveillance rtas calls.
Signed-off-by: Arnd Bergmann <arndb@de.ibm.com>
infrastructure for it.
Let it rip!
