Joe Perches points out [1] that this pattern isn't currently safe.
This driver doesn't really need the zeroing semantic anyway;
by restructuring the code slightly we can initialize all the
fields of the structure up front instead.
[1] https://lkml.kernel.org/r/1469729491.3998.58.camel@perches.com
Signed-off-by: Chris Metcalf <cmetcalf@mellanox.com>
struct kiocb now is a generic I/O container, so move it to fs.h.
Also do a #include diet for aio.h while we're at it.
Add a real platform bus device as a parent for
the srom class devices, to prevent non-platform
devices hanging from the bus root.
Signed-off-by: Pawel Moll <pawel.moll@arm.com>
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
Cc: David Airlie <airlied@linux.ie>
Cc: Matt Mackall <mpm@selenic.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Kukjin Kim <kgene.kim@samsung.com>
Cc: Corey Minyard <minyard@acm.org>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: Peter Huewe <peterhuewe@gmx.de>
Cc: Ashley Lai <ashley@ashleylai.com>
Cc: Marcel Selhorst <tpmdd@selhorst.net>
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull PTR_RET() removal patches from Rusty Russell:
"PTR_RET() is a weird name, and led to some confusing usage. We ended
up with PTR_ERR_OR_ZERO(), and replacing or fixing all the usages.
This has been sitting in linux-next for a whole cycle"
[ There are still some PTR_RET users scattered about, with some of them
possibly being new, but most of them existing in Rusty's tree too. We
have that
#define PTR_RET(p) PTR_ERR_OR_ZERO(p)
thing in <linux/err.h>, so they continue to work for now - Linus ]
* tag 'PTR_RET-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
GFS2: Replace PTR_RET with PTR_ERR_OR_ZERO
Btrfs: volume: Replace PTR_RET with PTR_ERR_OR_ZERO
drm/cma: Replace PTR_RET with PTR_ERR_OR_ZERO
sh_veu: Replace PTR_RET with PTR_ERR_OR_ZERO
dma-buf: Replace PTR_RET with PTR_ERR_OR_ZERO
drivers/rtc: Replace PTR_RET with PTR_ERR_OR_ZERO
mm/oom_kill: remove weird use of ERR_PTR()/PTR_ERR().
staging/zcache: don't use PTR_RET().
remoteproc: don't use PTR_RET().
pinctrl: don't use PTR_RET().
acpi: Replace weird use of PTR_RET.
s390: Replace weird use of PTR_RET.
PTR_RET is now PTR_ERR_OR_ZERO(): Replace most.
This fixes the build error:
drivers/char/tile-srom.c:307:2: warning: missing braces around initializer [-Wmissing-braces]
and the resulting fallout for the missing '*' character, sorry, my
fault...
Reported-by: kbuild test robot <fengguang.wu@intel.com>
The dev_attrs field of struct class is going away soon, dev_groups
should be used instead. This converts the tile srom_class code to use
the correct field.
Sweep of the simple cases.
Cc: netdev@vger.kernel.org
Cc: linuxppc-dev@lists.ozlabs.org
Cc: Julia Lawall <julia.lawall@lip6.fr>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Used PTR_RET function instead of IS_ERR and PTR_ERR.
Patch found using coccinelle.
Signed-off-by: Alexandru Gheorghiu <gheorghiuandru@gmail.com>
both callers of device_get_devnode() are only interested in lower 16bits
and nobody tries to return anything wider than 16bit anyway.
The first version of this patch proposed an arch/tile/drivers/ directory,
but the consensus was that this was probably a poor choice for a place to
group Tilera-specific drivers, and that in any case grouping by platform
was discouraged, and grouping by function was preferred.
This version of the patch addresses various issues raised in the
community, primarily the absence of sysfs integration. The sysfs
integration now handles passing information on sector size, page size,
and total partition size to userspace as well. In addition, we now
use a single "struct cdev" to manage all the partition minor devices,
and dynamically discover the correct number of partitions from the
hypervisor rather than using a module_param with a default value.
This driver has no particular "peer" drivers it can be grouped with.
It is sort of like an MTD driver for SPI ROM, but it doesn't group well
with the other MTD devices since it relies on hypervisor virtualization
to handle many of the irritating aspects of flash ROM management: sector
awareness, background read for sub-sector writes, bit examination to
determine whether a sector erase needs to be issued, etc. It is in fact
more like an EEPROM driver, but the hypervisor virtualization does require
a "flush" command if you wish to commit a sector write prior to writing
to a different sector, and this is sufficiently different from generic
I2C/SPI EEPROMs that as a result it doesn't group well with them either.
The simple character device is already in use by a range of Tilera
SPI ROM management tools, as well as by customers. In addition, using
the simple character device actually simplifies the userspace tools,
since they don't need to manage sector erase, background read, etc.
This both simplifies the code (since we can uniformly manage plain files
and the SPI ROM) as well as makes the user code portable to non-Linux
platforms that don't offer the same MTD ioctls.
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
