Move it into sysrq.c, along with the rest of the sysrq implementation.
It is written in the Documentation/sysrq.txt that oom-killer is enabled
when we set "64" in /proc/sys/kernel/sysrq:
<Documentation/sysrq.txt>
Here is the list of possible values in /proc/sys/kernel/sysrq:
64 - enable signalling of processes (term, kill, oom-kill)
but enable_mask is not set in sysrq_moom_op.
Signed-off-by: Naohiro Ooiwa <nooiwa@miraclelinux.com>
drivers/char/sysrq.c: In function 'sysrq_showregs_othercpus':
drivers/char/sysrq.c:218: error: too many arguments to function 'smp_call_function'
When a cpu really is stuck in the kernel, it can be often
impossible to figure out which cpu is stuck where. The
worst case is when the stuck cpu has interrupts disabled.
Therefore, implement a global cpu state capture that uses
SMP message interrupts which are not disabled by the
normal IRQ enable/disable APIs of the kernel.
As long as we can get a sysrq 'y' to the kernel, we can
get a dump. Even if the console interrupt cpu is wedged,
we can trigger it from userspace using /proc/sysrq-trigger
The output is made compact so that this facility is more
useful on high cpu count systems, which is where this
facility will likely find itself the most useful :)
SysRQ-P is not always useful on SMP systems, since it usually ends up showing
the backtrace of a CPU that is doing just fine, instead of the backtrace of
the CPU that is having problems.
This patch adds SysRQ show-all-cpus(L), which shows the backtrace of every
active CPU in the system. It skips idle CPUs because some SMP systems are
just too large and we already know what the backtrace of the idle task looks
like.
Signed-off-by: Rik van Riel <riel@redhat.com>
Randy Dunlap <randy.dunlap@oracle.com>
Cc: <lwoodman@redhat.com>
Introduce a node_zonelist() helper function. It is used to lookup the
appropriate zonelist given a node and a GFP mask. The patch on its own is a
cleanup but it helps clarify parts of the two-zonelist-per-node patchset. If
necessary, it can be merged with the next patch in this set without problems.
Reviewed-by: Christoph Lameter <clameter@sgi.com>
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com>
Cc: Christoph Lameter <clameter@sgi.com>
Cc: Hugh Dickins <hugh@veritas.com>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
is_init() is an ambiguous name for the pid==1 check. Split it into
is_global_init() and is_container_init().
A cgroup init has it's tsk->pid == 1.
A global init also has it's tsk->pid == 1 and it's active pid namespace
is the init_pid_ns. But rather than check the active pid namespace,
compare the task structure with 'init_pid_ns.child_reaper', which is
initialized during boot to the /sbin/init process and never changes.
Changelog:
2.6.22-rc4-mm2-pidns1:
- Use 'init_pid_ns.child_reaper' to determine if a given task is the
global init (/sbin/init) process. This would improve performance
and remove dependence on the task_pid().
2.6.21-mm2-pidns2:
- [Sukadev Bhattiprolu] Changed is_container_init() calls in {powerpc,
ppc,avr32}/traps.c for the _exception() call to is_global_init().
This way, we kill only the cgroup if the cgroup's init has a
bug rather than force a kernel panic.
[akpm@linux-foundation.org: fix comment]
[sukadev@us.ibm.com: Use is_global_init() in arch/m32r/mm/fault.c]
[bunk@stusta.de: kernel/pid.c: remove unused exports]
[sukadev@us.ibm.com: Fix capability.c to work with threaded init]
Signed-off-by: Serge E. Hallyn <serue@us.ibm.com>
Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com>
Acked-by: Pavel Emelianov <xemul@openvz.org>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Cedric Le Goater <clg@fr.ibm.com>
Cc: Dave Hansen <haveblue@us.ibm.com>
Cc: Herbert Poetzel <herbert@13thfloor.at>
Cc: Kirill Korotaev <dev@sw.ru>
As of now, the kernel defaults to non-unicode and XLATE for the keyboard.
We've been changing this in Fedora, but that requires patching the defaults
in the kernel.
The attached introduces CONFIG_VT_UNICODE, which sets the console in
unicode mode by default on boot, including both the virtual terminal and
the keyboard driver.
Signed-off-by: Bill Nottingham <notting@redhat.com>
Cc: Samuel Thibault <samuel.thibault@ens-lyon.org>
Cc: Dmitry Torokhov <dtor@mail.ru>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Move the OOM killer's extern function prototypes to include/linux/oom.h and
include it where necessary.
[clg@fr.ibm.com: build fix]
Cc: Andrea Arcangeli <andrea@suse.de>
Acked-by: Christoph Lameter <clameter@sgi.com>
Signed-off-by: David Rientjes <rientjes@google.com>
Signed-off-by: Cedric Le Goater <clg@fr.ibm.com>
Remove includes of <linux/smp_lock.h> where it is not used/needed.
Suggested by Al Viro.
Builds cleanly on x86_64, i386, alpha, ia64, powerpc, sparc,
sparc64, and arm (all 59 defconfigs).
Add SysRq-Q to print pending timers and other timer info.
Cc: john stultz <johnstul@us.ibm.com>
Cc: Roman Zippel <zippel@linux-m68k.org>
Somewhere in the rewrite of the work queues my cleanup of SAK handling
got broken. Maybe I didn't retest it properly or possibly the API
was changing so fast I missed something. Regardless currently
triggering a SAK now generates an ugly BUG_ON and kills the kernel.
Thanks to Alexey Dobriyan <adobriyan@openvz.org> for spotting this.
This modifies the use of SAK_work to initialize it when the data
structure it resides in is initialized, and to simply call
schedule_work when we need to generate a SAK. I update both
data structures that have a SAK_work member for consistency.
All of the old PREPARE_WORK calls that are now gone.
If we call schedule_work again before it has processed it
has generated the first SAK it will simply ignore the duplicate
schedule_work request.
This does several things.
- It moves looking up of the current foreground console into process
context where we can safely take the semaphore that protects this
operation.
- It uses the new flavor of work queue processing.
- This generates a factor of do_SAK, __do_SAK that runs immediately.
- This calls __do_SAK with the console semaphore held ensuring nothing
else happens to the console while we process the SAK operation.
- With the console SAK processing moved into process context this
patch removes the xchg operations that I used to attempt to attomically
update struct pid, because of the strange locking used in the SAK processing.
With SAK using the normal console semaphore nothing special is needed.
Cc: Oleg Nesterov <oleg@tv-sign.ru>
Change SysRq showBlockedTasks from sysrq-X to sysrq-W and show that in the
Help message.
It was previously done via X, but X is already used for Xmon on ppc & powerpc
platforms and this collision needs to be avoided.
All callers of register_sysrq_key() are now marked in the sysrq op/key table.
I didn't mark 'h' as Help because Help is just printed for any unknown key,
such as '?'.
Added some omitted sysrq key entries in the sysrq.txt file.
Most distributions enable sysrq support but set it to 0 by default. Add a
sysrq_always_enabled boot option to always-enable sysrq keys. Useful for
debugging - without having to modify the disribution's config files (which
might not be possible if the kernel is on a live CD, etc.).
Also, while at it, clean up the sysrq interfaces.
[bunk@stusta.de: make sysrq_always_enabled_setup() static]
Add SysRq-X support: show blocked (TASK_UNINTERRUPTIBLE) tasks only.
Useful for debugging IO stalls.
Pass the work_struct pointer to the work function rather than context data.
The work function can use container_of() to work out the data.
For the cases where the container of the work_struct may go away the moment the
pending bit is cleared, it is made possible to defer the release of the
structure by deferring the clearing of the pending bit.
To make this work, an extra flag is introduced into the management side of the
work_struct. This governs auto-release of the structure upon execution.
Ordinarily, the work queue executor would release the work_struct for further
scheduling or deallocation by clearing the pending bit prior to jumping to the
work function. This means that, unless the driver makes some guarantee itself
that the work_struct won't go away, the work function may not access anything
else in the work_struct or its container lest they be deallocated.. This is a
problem if the auxiliary data is taken away (as done by the last patch).
However, if the pending bit is *not* cleared before jumping to the work
function, then the work function *may* access the work_struct and its container
with no problems. But then the work function must itself release the
work_struct by calling work_release().
In most cases, automatic release is fine, so this is the default. Special
initiators exist for the non-auto-release case (ending in _NAR).
Signed-Off-By: David Howells <dhowells@redhat.com>
drivers/char/sysrq.c: In function `sysrq_handle_crashdump':
drivers/char/sysrq.c:98: warning: implicit declaration of function `get_irq_regs'
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
SysRq : Emergency Sync
Emergency Sync complete
SysRq : Emergency Remount R/O
Emergency Remount complete
SysRq : Resetting
BUG: warning at kernel/lockdep.c:1816/trace_hardirqs_on() (Not tainted)
Call Trace:
[<ffffffff8026d56d>] show_trace+0xae/0x319
[<ffffffff8026d7ed>] dump_stack+0x15/0x17
[<ffffffff802a68d1>] trace_hardirqs_on+0xbc/0x13d
[<ffffffff803a8eec>] sysrq_handle_reboot+0x9/0x11
[<ffffffff803a8f8d>] __handle_sysrq+0x99/0x130
[<ffffffff803a903b>] handle_sysrq+0x17/0x19
[<ffffffff803a36ee>] kbd_event+0x32e/0x57d
[<ffffffff80401e35>] input_event+0x42d/0x45b
[<ffffffff804063eb>] atkbd_interrupt+0x44d/0x53d
[<ffffffff803fe5c5>] serio_interrupt+0x49/0x86
[<ffffffff803ff2a4>] i8042_interrupt+0x202/0x21a
[<ffffffff80210cf0>] handle_IRQ_event+0x2c/0x64
[<ffffffff802bfd8b>] __do_IRQ+0xaf/0x114
[<ffffffff8026ea24>] do_IRQ+0xf8/0x107
[<ffffffff8025f886>] ret_from_intr+0x0/0xf
DWARF2 unwinder stuck at ret_from_intr+0x0/0xf
Leftover inexact backtrace:
<IRQ> <EOI> [<ffffffff80258e36>] mwait_idle+0x3f/0x54
[<ffffffff8024a33a>] cpu_idle+0xa2/0xc5
[<ffffffff8026c34e>] rest_init+0x2b/0x2d
[<ffffffff809708bc>] start_kernel+0x24a/0x24c
[<ffffffff8097028b>] _sinittext+0x28b/0x292
Since we're shutting down anyway, don't bother being smart,
just turn the thing off.
Cc: Arjan van de Ven <arjan@linux.intel.com>
This is an updated version of Eric Biederman's is_init() patch.
(http://lkml.org/lkml/2006/2/6/280). It applies cleanly to 2.6.18-rc3 and
replaces a few more instances of ->pid == 1 with is_init().
Further, is_init() checks pid and thus removes dependency on Eric's other
patches for now.
Eric's original description:
There are a lot of places in the kernel where we test for init
because we give it special properties. Most significantly init
must not die. This results in code all over the kernel test
->pid == 1.
Introduce is_init to capture this case.
With multiple pid spaces for all of the cases affected we are
looking for only the first process on the system, not some other
process that has pid == 1.
Cc: Serge Hallyn <serue@us.ibm.com>
Cc: <lxc-devel@lists.sourceforge.net>
Acked-by: Paul Mackerras <paulus@samba.org>
Print all lock-classes on SysRq-D.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Generic lock debugging:
- generalized lock debugging framework. For example, a bug in one lock
subsystem turns off debugging in all lock subsystems.
- got rid of the caller address passing (__IP__/__IP_DECL__/etc.) from
the mutex/rtmutex debugging code: it caused way too much prototype
hackery, and lockdep will give the same information anyway.
- ability to do silent tests
- check lock freeing in vfree too.
- more finegrained debugging options, to allow distributions to
turn off more expensive debugging features.
There's no separate 'held mutexes' list anymore - but there's a 'held locks'
stack within lockdep, which unifies deadlock detection across all lock
classes. (this is independent of the lockdep validation stuff - lockdep first
checks whether we are holding a lock already)
Here are the current debugging options:
CONFIG_DEBUG_MUTEXES=y
CONFIG_DEBUG_LOCK_ALLOC=y
which do:
config DEBUG_MUTEXES
bool "Mutex debugging, basic checks"
config DEBUG_LOCK_ALLOC
bool "Detect incorrect freeing of live mutexes"
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
sysrq.c is fairly revolting. Fix.
Some allocations are restricted to a limited set of nodes (due to memory
policies or cpuset constraints). If the page allocator is not able to find
enough memory then that does not mean that overall system memory is low.
In particular going postal and more or less randomly shooting at processes
is not likely going to help the situation but may just lead to suicide (the
whole system coming down).
It is better to signal to the process that no memory exists given the
constraints that the process (or the configuration of the process) has
placed on the allocation behavior. The process may be killed but then the
sysadmin or developer can investigate the situation. The solution is
similar to what we do when running out of hugepages.
This patch adds a check before we kill processes. At that point
performance considerations do not matter much so we just scan the zonelist
and reconstruct a list of nodes. If the list of nodes does not contain all
online nodes then this is a constrained allocation and we should kill the
current process.
Signed-off-by: Christoph Lameter <clameter@sgi.com>
Cc: Andi Kleen <ak@muc.de>
more mutex debugging: check for held locks during memory freeing,
task exit, enable sysrq printouts, etc.
Signed-off-by: Arjan van de Ven <arjan@infradead.org>
This patch makes two needlessly global functions static.
sysrq calls into the reboot path from an interrupt handler
we can either push the code do into process context and
call kernel_restart and get a clean reboot or we can simply
reboot the machine, and increase our chances of actually
rebooting. emergency_reboot() seems like the closest match
to what we have previously done, and what we want.
Dump the current allocation order when OOM killing.
Makes kexec_crashdump() take a pt_regs * as an argument. This allows to
get exact register state at the point of the crash. If we come from direct
panic assertion NULL will be passed and the current registers saved before
crashdump.
This hooks into two places:
die(): check the conditions under which we will panic when calling
do_exit and go there directly with the pt_regs that caused the fatal
fault.
die_nmi(): If we receive an NMI lockup while in the kernel use the
pt_regs and go directly to crash_kexec(). We're probably nested up badly
at this point so this might be the only chance to escape with proper
information.
Signed-off-by: Alexander Nyberg <alexn@telia.com>
Add a sysrq-trigger mechanism for kexec based crashdumps. Alt-Sysrq-c
triggers a kexec based crashdump.
Signed-off-by: Hariprasad Nellitheertha <hari@in.ibm.com>
infrastructure for it.
Let it rip!
