path: root/drivers/char/generic_serial.c
2008-04-30drivers/char: replace remaining __FUNCTION__ occurrencesHarvey Harrison
2008-04-30char: switch gs, cyclades and esp to return int for put_charAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Cc: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30tty/serial: lay the foundations for the next set of reworksAlan Cox
- Stop drivers calling their own flush method indirectly, it obfuscates code and it will change soon anyway - A few more lock_kernel paths temporarily needed in some driver internal waiting code - Remove private put_char method that does a write call for one char - we have that anyway - Most but not yet all of the termios copy under lock fixing (some has other dependencies to follow) - Note a few locking bugs in drivers found in the process - Kill remaining [ab]users of TIOCG/SSOFTCAR in the driver, these must go to fix the termios locking Signed-off-by: Alan Cox <alan@redhat.com> Cc: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-18drivers: Remove unnecessary inclusions of asm/semaphore.hMatthew Wilcox
None of these files use any of the functionality promised by asm/semaphore.h. It's possible that they rely on it dragging in some unrelated header file, but I can't build all these files, so we'll have fix any build failures as they come up. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2007-07-16genericserial: remove bogus optimisation check and dead code pathsAlan Cox
We've been using the 'new locking' for a long time now so it seems pointless keeping the old one around. Remove it and undo the macros it uses back into real code for readability. Remove the bogus 'no termios change' checks. Signed-off-by: Alan Cox <alan@redhat.com> Cc: Morten Helgesen <morten@sourcepoet.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-27[PATCH] generic_serial: fix decoding of baud rateDaniel Drake
Commit d720bc4b8fc5d6d179ef094908d4fbb5e436ffad partially removed a private implementation of baud speed decoding. However it doesn't seem to be complete: after the speed is decoded, it is still being used as an index to a local speed table (array overrun, no doubt). This was found by Graham Murray who noticed it caused a 2.6.19 regression with the SX driver: https://bugs.gentoo.org/170554 Signed-off-by: Daniel Drake <dsd@gentoo.org> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Russell King <rmk@arm.linux.org.uk> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Char: tty_wakeup cleanupJiri Slaby
tty_wakeup cleanup - remove wake_up_interruptible(&tty->write_wait) surrounding tty_wakup(tty); - substitute tty->ldisc.write_wakeup(tty) + wake_up() by tty_wakeup(tty); Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] tty: switch to ktermiosAlan Cox
This is the grungy swap all the occurrences in the right places patch that goes with the updates. At this point we have the same functionality as before (except that sgttyb() returns speeds not zero) and are ready to begin turning new stuff on providing nobody reports lots of bugs If you are a tty driver author converting an out of tree driver the only impact should be termios->ktermios name changes for the speed/property setting functions from your upper layers. If you are implementing your own TCGETS function before then your driver was broken already and its about to get a whole lot more painful for you so please fix it 8) Also fill in c_ispeed/ospeed on init for most devices, although the current code will do this for you anyway but I'd like eventually to lose that extra paranoia [akpm@osdl.org: bluetooth fix] [mp3@de.ibm.com: sclp fix] [mp3@de.ibm.com: warning fix for tty3270] [hugh@veritas.com: fix tty_ioctl powerpc build] [jdike@addtoit.com: uml: fix ->set_termios declaration] Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Martin Peschke <mp3@de.ibm.com> Acked-by: Peter Oberparleiter <oberpar@de.ibm.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] char: kill unneeded memsetsJiri Slaby
char, another tmp_buf cleanup No need to allocate one page as a side buffer. It's no more used. Clean this (de)allocs of this useless memory pages in char subtree. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] generic_serial: remove private decoding of baud rate bitsAlan Cox
The driver has no business doing this work itself any more and hasn't for some years. When the new speed stuff goes in this will break entirely so fix it up ready. Also remove a #if 0 around a comment.... Signed-off-by: Alan Cox <alan@redhat.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] sem2mutex: serial ->port_write_mutexIngo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] remove unused tmp_buf_sem'sAdrian Bunk
tmp_buf_sem sems to be a common name for something completely unused... Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> ("usb portion") Signed-off-by: Linus Torvalds <torvalds@osdl.org>
