some drivers still todo.
Signed-off-by: Dave Airlie <airlied@linux.ie>
This moves a bunch of typedefs into a !defined __KERNEL__ to keep userspace
API compatiblity, it changes all internal usages to structs/enum/unions.
Bugzilla Bug #9457
Add refcounting of user waiters to the DRM hardware lock, so that we can use
DRM_LOCK_CONT flag more conservatively.
Also add a kernel waiter refcount that if nonzero transfers the lock for the
kernel context when it is released. This is useful when waiting for idle and can be used for very simple fence object driver implementations for the new memory manager
DRM core.
This patch pull in a lot of changes from CVS to the main core DRM,
and updates the radeon driver to 1.21.0 that supports r300 texrect
and radeon card type ioctl.
A fix for a locking bug which is triggered when a client tries to lock with
flag DMA_QUIESCENT (typically the X server), but gets interrupted by a signal.
The locking IOCTL should then return an error, but if DMA_QUIESCENT succeeds
it returns 0, and the client falsely thinks it has the lock. In addition
The client waits for DMA_QUISCENT and possibly DMA_READY without having the lock.
I've been threatening this for a while, so no point hanging around.
This lindents the DRM code which was always really bad in tabbing department.
I've also fixed some misnamed files in comments and removed some trailing
whitespace.
This patch contains the following cleanups:
- make needlessly global functions static
- remove the following unused global functions:
- drm_fops.c: drm_read
- i915_dma.c: i915_do_cleanup_pageflip
infrastructure for it.
Let it rip!
