path: root/drivers/char/Makefile
2007-07-31Merge git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdogLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog: (28 commits) [WATCHDOG] Fix pcwd_init_module crash [WATCHDOG] ICH9 support for iTCO_wdt [WATCHDOG] 631xESB/632xESB support for iTCO_wdt - add all LPC bridges [WATCHDOG] 631xESB/632xESB support for iTCO_wdt [WATCHDOG] omap_wdt.c - default error for IOCTL is -ENOTTY [WATCHDOG] Return value of nonseekable_open [WATCHDOG] mv64x60_wdt: Rework the timeout register manipulation [WATCHDOG] mv64x60_wdt: disable watchdog timer when driver is probed [WATCHDOG] mv64x60_wdt: Support the WDIOF_MAGICCLOSE feature [WATCHDOG] mv64x60_wdt: Add a module parameter to change nowayout setting [WATCHDOG] mv64x60_wdt: Add WDIOC_SETOPTIONS ioctl support [WATCHDOG] mv64x60_wdt: Support for WDIOC_SETTIMEOUT ioctl [WATCHDOG] mv64x60_wdt: Fix WDIOC_GETTIMEOUT return value [WATCHDOG] mv64x60_wdt: Check return value of nonseekable_open [WATCHDOG] mv64x60_wdt: Add arch/powerpc platform support [WATCHDOG] mv64x60_wdt: Get register address from platform data [WATCHDOG] mv64x60_wdt: set up platform_device in platform code [WATCHDOG] ensure mouse and keyboard ignored in w83627hf_wdt [WATCHDOG] s3c2410_wdt: fixup after arch include moves [WATCHDOG] git-watchdog-typo ...
2007-07-29[WATCHDOG] Fix pcwd_init_module crashWim Van Sebroeck
Fix for the problem detected by Ingo Molnar: enabling CONFIG_PCWATCHDOG=y crashes bzImage bootup. The reason for this can be found in drivers/makefile We first do: obj-y += char/ and later we do: obj-y += base/ block/ misc/ mfd/ net/ media/ So if we put a platform or isa or usb bus driver in char/watchdog (which is called from the Makefile in drivers/char/Makefile) then we didn't have the different device drivers initialized yet (they are in drivers/base and drivers/usb and ...) This fix makes sure that we compile the watchdog drivers after drivers/base, drivers/misc, drivers/pci and drivers/usb. We also do the compile after hwmon because in the future the watchdog temperature support will use the hwmon system. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2007-07-24[SPARC32]: Deal with rtc/sun_mostek_rtc conflict.Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-21ps3: FLASH ROM Storage DriverGeert Uytterhoeven
Add a FLASH ROM Storage Driver for the PS3: - Implemented as a misc character device driver - Uses a fixed 256 KiB buffer allocated from boot memory as the hypervisor requires the writing of aligned 256 KiB blocks Cc: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19lguest: the console driverRusty Russell
A simple console driver for lguest. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-18xen: use the hvc console infrastructure for Xen consoleJeremy Fitzhardinge
Implement a Xen back-end for hvc console. * * * Add early printk support via hvc console, enable using "earlyprintk=xen" on the kernel command line. From: Gerd Hoffmann <kraxel@suse.de> Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Olof Johansson <olof@lixom.net>
2007-07-16Audit: add TTY input auditingMiloslav Trmac
Add TTY input auditing, used to audit system administrator's actions. This is required by various security standards such as DCID 6/3 and PCI to provide non-repudiation of administrator's actions and to allow a review of past actions if the administrator seems to overstep their duties or if the system becomes misconfigured for unknown reasons. These requirements do not make it necessary to audit TTY output as well. Compared to an user-space keylogger, this approach records TTY input using the audit subsystem, correlated with other audit events, and it is completely transparent to the user-space application (e.g. the console ioctls still work). TTY input auditing works on a higher level than auditing all system calls within the session, which would produce an overwhelming amount of mostly useless audit events. Add an "audit_tty" attribute, inherited across fork (). Data read from TTYs by process with the attribute is sent to the audit subsystem by the kernel. The audit netlink interface is extended to allow modifying the audit_tty attribute, and to allow sending explanatory audit events from user-space (for example, a shell might send an event containing the final command, after the interactive command-line editing and history expansion is performed, which might be difficult to decipher from the TTY input alone). Because the "audit_tty" attribute is inherited across fork (), it would be set e.g. for sshd restarted within an audited session. To prevent this, the audit_tty attribute is cleared when a process with no open TTY file descriptors (e.g. after daemon startup) opens a TTY. See https://www.redhat.com/archives/linux-audit/2007-June/msg00000.html for a more detailed rationale document for an older version of this patch. [akpm@linux-foundation.org: build fix] Signed-off-by: Miloslav Trmac <mitr@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Paul Fulghum <paulkf@microgate.com> Cc: Casey Schaufler <casey@schaufler-ca.com> Cc: Steve Grubb <sgrubb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07rename TANBAC TB0219 configYoichi Yuasa
Rename config for TANBAC TB0219 GPIO support to something more appropriate. Fixes this: drivers/char/Kconfig:906:warning: type of 'TANBAC_TB0219' redefined from 'boolean' to 'tristate' drivers/char/Kconfig:907:warning: choice values currently only support a single prompt Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-09[APM] Add shared version of APM emulationRalf Baechle
Currently ARM and MIPS both have nearly identical copies of the APM emulation code in their arch code. Add yet another copy of it to drivers char and make it selectable through SYS_SUPPORTS_APM_EMULATION. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-07[POWERPC] Celleb: hypervisor console driverIshizaki Kou
This patch adds hypervisor console driver for Celleb platform. Signed-off-by: Kou Ishizaki <kou.ishizaki@toshiba.co.jp> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-12-08[PATCH] mxser: make an experimental cloneJiri Slaby
Clone a new driver for moxa smartio devices by copying mxser.c to mxser_new.c and mxser.h to mxser_new.h. No other changes are made. This is for purposes of updating the driver to the latest vendor version. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-03Remove long-unmaintained ftape driver subsystem.Jeff Garzik
It's bitrotten, long unmaintained, long hidden under BROKEN_ON_SMP, etc. As scheduled in feature-removal-schedule.txt, and ack'd several times on lkml. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-10-03[MIPS] Remove IT8172-based platforms, ITE 8172G and Globespan IVR support.Yoichi Yuasa
As per feature-removal-schedule.txt. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-09-29[PATCH] Remove old drivers/char/s3c2410_rtc.cBen Dooks
This can now be removed, since there is now a drivers/rtc/rtc-s3c.c driver. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] mspec driverJes Sorensen
Implement the special memory driver (mspec) based on the do_no_pfn approach. The driver is currently used only on SN2 hardware with special fetchop support but could be beneficial on other architectures using the uncached mode. Signed-off-by: Jes Sorensen <jes@sgi.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-13[POWERPC] iseries: A new iSeries consoleStephen Rothwell
This driver uses the hvc_console.c infrastructure that is used by the pSeries virtual and RTAS consoles. This will allow us to make viocons.c obsolete and is another step along the way to a combined kernel (as viocons could not coexist with CONFIG_VT). Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au>
2006-07-07[POWERPC] Add support for briq front panelBenjamin Herrenschmidt
This adds the driver for the Briq front panel. This is a cleaned up version of a driver that has been floating around for some time now, initially written by Karsten Jeppesen <karsten@jeppesens.com> and cleaned up by jk and myself. Signed-off-by: Jeremy Kerr <jk@ozlabs.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-06-27[PATCH] chardev: GPIO for SCx200 & PC-8736x: add proper Kconfig, Makefile ↵Jim Cromie
entries Replace the temp makefile hacks with proper CONFIG entries, which are also added to Kconfig. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] chardev: GPIO for SCx200 & PC-8736x: add new pc8736x_gpio moduleJim Cromie
Add the brand new pc8736x_gpio driver. This is mostly based upon scx200_gpio.c, but the platform_dev is treated separately, since its fairly big too. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] chardev: GPIO for SCx200 & PC-8736x: add empty common-moduleJim Cromie
Add the nsc_gpio common-support module as an empty shell. Next patch starts the migration of the common gpio support routines. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] Add new generic HW RNG coreMichael Buesch
Signed-off-by: Michael Buesch <mb@bu3sch.de> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] Remove old HW RNG supportMichael Buesch
This patch series replaces the old non-generic Hardware Random Number Generator support by a fully generic RNG API. This makes it possible to register additional RNGs from modules. With this patch series applied, Laptops with a bcm43xx chip (PowerBook) have a HW RNG available now. Additionally two new RNG drivers are added for the "ixp4xx" and "omap" devices. (Written by Deepak Saxena). This patch series includes the old patches by Deepak Saxena. The old x86-rng driver has beed split. The userspace RNG daemon can later be updated to select the RNG through /sys/class/misc/hw_random/ for convenience. For now it is sufficient to use cat and echo -n on the sysfs attributes. Signed-off-by: Michael Buesch <mb@bu3sch.de> Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-10[PATCH] powerpc: console_initcall ordering issuesMilton Miller
From: Milton Miller <miltonm@bga.com> The add_preferred_console call in rtas_console.c was not causing the console to be selected. It turns out that the add_preferred_console was being called after the hvc_console driver was registered. It only works when it is called before the console driver is registered. Reorder hvc_console.o after the hvc_console drivers to allow the selection during console_initcall processing. Signed-off-by: Milton Miller <miltonm@bga.com> Signed-off-by: Anton Blanchard <anton@samba.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] RTC subsystem: VR41XX driverYoichi Yuasa
This patch updates VR4100 series RTC driver. * This driver supports new RTC subsystem. * Simple set time/read time test worked fine. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] powerpc: add hvc backend for rtasArnd Bergmann
Current Cell hardware is using the console through a set of rtas calls. This driver is needed to get console output on those boards. Signed-off-by: Arnd Bergmann <abergman@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-28[PATCH] powerpc: hvc_console updatesRyan S. Arnold
These are some updates from both Ryan and Arnd for the hvc_console driver: The main point is to enable the inclusion of a console driver for rtas, which is currrently needed for the cell platform. Also shuffle around some data-type declarations and moves some functions out of include/asm-ppc64/hvconsole.h and into a new drivers/char/hvc_console.h file. Signed-off-by: "Ryan S. Arnold" <rsa@us.ibm.com> Signed-off-by: Arnd Bergmann <abergman@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-24tabify drivers/char/MakefileJim Cromie
this trivial patch tabifies drivers/char/Makefile for readability. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-01-19Move ip2.c and ip2main.c to drivers/char/ip2/ where the other filesAdrian Bunk
used by this driver reside. Renamed ip2.c to ip2base.c to allow ip2.o to be built from multiple objects. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Michael H. Warfield <mhw@WittsEnd.com>
2006-01-10[PATCH] i386: GPIO driver for AMD CS5535/CS5536Ben Gardner
A simple driver for the CS5535 and CS5536 that allows a user-space program to manipulate GPIO pins. The CS5535/CS5536 chips are Geode processor companion devices. Signed-off-by: Ben Gardner <bgardner@wabtec.com> Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] new driver synclink_gtPaul Fulghum
New character device driver for the SyncLink GT and SyncLink AC families of synchronous and asynchronous serial adapters Signed-off-by: Paul Fulghum <paulkf@microgate.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] Telecom Clock Driver for MPCBL0010 ATCA computer bladeMark Gross
Signed-off-by: Mark Gross <mgross@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] hvc_console: Separate hvc_console and vio code 2Milton Miller
Remove all the vio device driver code from hvc_console.c This will allow us to separate hvsi, hvc, and allow hvc_console to be used without the ppc64 vio layer. Signed-off-by: Milton Miller <miltonm@bga.com> Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] mips: add vr41xx gpio supportYoichi Yuasa
Add vr41xx gpio support. Signed-off-by: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-25[IA64] Altix system controller event handlingGreg Howard
The following is an update of the patch I sent yesterday (3/9/05) incorporating suggestions from Christoph Hellwig and Andreas Schwab. It allows Altix and Altix-like systems to handle environmental events generated by the system controllers, and should apply on top of Jack Steiner's patch of 3/1/05 ("New chipset support for SN platform") and Mark Goodwin's patch of 3/8/05 ("Altix SN topology support for new chipsets and pci topology"). Signed-off-by: Greg Howard <ghoward@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-04-25[IA64-SGI] Bus driver for the CX port of SGI's TIO chip.Bruce Losure
This patch is to provide CX port infrastructure for SGI TIO-based h/w. Also a 'core services' driver for SGI FPGA-based h/w. Signed-off-by: Bruce Losure <blosure@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
