path: root/drivers/cdrom
2008-02-06drivers/cdrom/cdrom.c: simplify logic in cdrom_release()Borislav Petkov
Simplify logic in cdrom_release() without semantic change. Signed-off-by: Borislav Petkov <bbpetkov@yahoo.de> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01ide-cd: move lba_to_msf() and msf_to_lba() to <linux/cdrom.h>Bartlomiej Zolnierkiewicz
* Move lba_to_msf() and msf_to_lba() to <linux/cdrom.h> (use 'u8' type instead of 'byte' while at it). * Remove msf_to_lba() copy from drivers/cdrom/cdrom.c. Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (197 commits) sh: add spi header and r2d platform data V3 sh: update r7780rp interrupt code sh: remove consistent alloc stuff from the machine vector sh: use declared coherent memory for dreamcast pci ethernet adapter sh: declared coherent memory support V2 sh: Add support for SDK7780 board. sh: constify function pointer tables sh: Kill off -traditional for linker script. cdrom: Add support for Sega Dreamcast GD-ROM. sh: Kill off hs7751rvoip reference from arch/sh/Kconfig. sh: Drop r7780rp_defconfig, use r7780mp_defconfig as kbuild default. sh: Kill off dead HS771RVoIP board support. sh: r7785rp: Fix up DECLARE_INTC_DESC() arg mismatch. sh: r7785rp: Hook up the rest of the HL7785 FPGA IRQ vectors. sh: r2d - enable sm501 usb host function sh: remove voyagergx sh: r2d - add lcd planel timings to sm501 platform data sh: Add OHCI and UDC platform devices for SH7720. sh: intc - remove default interrupt priority tables sh: Correct pte size mismatch for X2 TLB. ...
2008-01-28blk_end_request: changing viocd (take 4)Kiyoshi Ueda
This patch converts viocd to use blk_end_request interfaces. Related 'uptodate' arguments are converted to 'error'. As a result, the interface of internal function, viocd_end_request(), is changed. Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-28cdrom: Add support for Sega Dreamcast GD-ROM.Adrian McMenamin
This patch adds support for the GD-Rom drive, SEGA's proprietary implementation of an IDE CD Rom for the SEGA Dreamcast. This driver implements Sega's Packet Interface (SPI) - at least partially. It will also read disks in SEGA's propreitary GD format. Unlike previous drivers (which were never in mainline) this uses DMA and not PIO to read disks. It is a new driver, not a refactoring of old drivers. Signed-off by: Adrian McMenamin <adrian@mcmen.demon.co.uk> Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-10-24SG: audit of drivers that use blk_rq_map_sg()Jens Axboe
They need to properly init the sg table, or blk_rq_map_sg() will complain if CONFIG_DEBUG_SG is set. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-19Use helpers to obtain task pid in printksPavel Emelyanov
The task_struct->pid member is going to be deprecated, so start using the helpers (task_pid_nr/task_pid_vnr/task_pid_nr_ns) in the kernel. The first thing to start with is the pid, printed to dmesg - in this case we may safely use task_pid_nr(). Besides, printks produce more (much more) than a half of all the explicit pid usage. [akpm@linux-foundation.org: git-drm went and changed lots of stuff] Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Dave Airlie <airlied@linux.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18sysctl: remove broken cdrom binary sysctlsEric W. Biederman
The binary interface for the cdrom sysctls can't possilby work. So remove the binary sysctls and update the test for finding out which sysctl table entry we are dealy with to use the procname and not the ctl_name (which I am removing). Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Alexey Dobriyan <adobriyan@sw.ru> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-11[POWERPC] iSeries: Move detection of virtual cdromsStephen Rothwell
Now we will only have entries in the device tree for the actual existing devices (including their OS/400 properties). This way viocd.c gets all the information about the devices from the device tree. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-10-11[POWERPC] Remove iSeries_vio_devStephen Rothwell
It was only being used to carry around dma_iommu_ops and vio_iommu_table which we can use directly instead. This also means that vio_bus_device doesn't need to refer to them either. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-10-11[POWERPC] iSeries: Simplify viocd initialisationStephen Rothwell
We don't need to keep a lump of dma coherent memory around for the life of the module. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-09-26cdrom_open() forgets to unlock on -EROFS failure exitsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-24[BLOCK] Get rid of request_queue_t typedefJens Axboe
Some of the code has been gradually transitioned to using the proper struct request_queue, but there's lots left. So do a full sweet of the kernel and get rid of this typedef and replace its uses with the proper type. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-16bsg: add a request_queue argument to scsi_cmd_ioctl()FUJITA Tomonori
bsg uses scsi_cmd_ioctl() for some SCSI/sg ioctl commands. scsi_cmd_ioctl() gets a request queue from a gendisk arguement. This prevents bsg being bound to SCSI devices that don't have a gendisk (like OSD). This adds a request_queue argument to scsi_cmd_ioctl(). The SCSI/sg ioctl commands doesn't use a gendisk so it's safe for any SCSI devices to use scsi_cmd_ioctl(). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-10Remove legacy CDROM driversJens Axboe
They are all broken beyond repair. Given that nobody has complained about them (most haven't worked in 2.6 AT ALL), remove them from the tree. A new mitsumi driver that actually works is in progress, it'll get added when completed. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-10[PATCH] fix request->cmd == INT casesBoaz Harrosh
- I have unearthed very old bugs in stale drivers that still used request->cmd as a READ|WRITE int - This patch is maybe a proof that these drivers have not been used for a long time. Should they be removed completely? Drivers that currently do not work for sure: drivers/acorn/block/fd1772.c | 2 +- drivers/acorn/block/mfmhd.c | 8 ++++---- drivers/cdrom/aztcd.c | 2 +- drivers/cdrom/cm206.c | 2 +- drivers/cdrom/gscd.c | 2 +- drivers/cdrom/mcdx.c | 2 +- drivers/cdrom/optcd.c | 2 +- drivers/cdrom/sjcd.c | 2 +- Drivers with cosmetic fixes only: b/drivers/block/amiflop.c b/drivers/block/nbd.c b/drivers/ide/legacy/hd.c Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-10[PATCH] cdrom_sysctl_info fixDave Young
Fix the cdrom_sysctl_info possible buffer overwrite bug. Also fix the locking of accessing topCdromPtr pointer. Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-06-08potential parse error in ifdef part 3Yoann Padioleau
Fix various bits of obviously-busted code which we're not happening to compile, due to ifdefs. Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Cc: Andi Kleen <ak@suse.de> Cc: Paul Mackerras <paulus@samba.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07mm: remove destroy_dirty_buffers from invalidate_bdev()Peter Zijlstra
Remove the destroy_dirty_buffers argument from invalidate_bdev(), it hasn't been used in 6 years (so akpm says). find * -name \*.[ch] | xargs grep -l invalidate_bdev | while read file; do quilt add $file; sed -ie 's/invalidate_bdev(\([^,]*\),[^)]*)/invalidate_bdev(\1)/g' $file; done Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-05[PATCH] Fix soft lockup with iSeries viocd driverTony Breeds
Fix soft lockup with iSeries viocd driver, caused by eventually calling end_that_request_first() with nr_bytes 0. Some versions of hald do an SG_IO ioctl on the viocd device which becomes a request with hard_nr_sectors and hard_cur_sectors set to zero. Passing zero as the number of sectors to end_request() (which calls end_that_request_first()) causes an infinite loop when the bio is being freed. This patch makes sure that the zero is never passed. It only requires some number larger the the request size the terminate the loop. The lockup is triggered by hald, interrogating the device. Signed-off-by: Tony Breeds <tony@bakeyournoodle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: remove insert_at_head from register_sysctlEric W. Biederman
The semantic effect of insert_at_head is that it would allow new registered sysctl entries to override existing sysctl entries of the same name. Which is pain for caching and the proc interface never implemented. I have done an audit and discovered that none of the current users of register_sysctl care as (excpet for directories) they do not register duplicate sysctl entries. So this patch simply removes the support for overriding existing entries in the sys_sysctl interface since no one uses it or cares and it makes future enhancments harder. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: David Howells <dhowells@redhat.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Andi Kleen <ak@muc.de> Cc: Jens Axboe <axboe@kernel.dk> Cc: Corey Minyard <minyard@acm.org> Cc: Neil Brown <neilb@suse.de> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Jan Kara <jack@ucw.cz> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: David Chinner <dgc@sgi.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: cdrom: don't set de->ownerEric W. Biederman
There is no need for open files in /proc/sys/XXX to hold a reference count on the module that provides the file to prevent module unload races. While there is code active in the module p->used in the sysctl_table_header is incremented, preventing the sysctl from being unregisted. Once the sysctl is unregistered it cannot be found. Open files are also not a problem as they revalidate the sysctl information and bump p->used before accessing module code. So setting de->owner is unnecessary, makes for a bad example and gets in my way of removing ctl_table->de. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Jens Axboe <jens.axboe@oracle.com> Acked-by: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: cdrom: remove unnecessary insert_at_head flagEric W. Biederman
With unique binary sysctl numbers setting insert_at_head to override other sysctl entries is pointless. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct file_operations const 3Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-03[PATCH] cdrom: set default timeout to 7 secondsJens Axboe
It's a known fact that Windows times out commands after 7 seconds, so drives generally try and respond if they can before that happens. We default to 5 seconds, which sometimes is a bit too short. Jeremy Higdon reported here: http://lkml.org/lkml/2007/1/1/145 that his drive takes longer than 5 seconds for a "read track information" command, later confirming that it is about 6.7 seconds. So just do the sane thing and change the default command timeout to 7 seconds to avoid other surprises. Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-21Merge branch 'for-linus' of git://brick.kernel.dk/data/git/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://brick.kernel.dk/data/git/linux-2.6-block: [PATCH] block: document io scheduler allow_merge_fn hook [PATCH] cfq-iosched: don't allow sync merges across queues [PATCH] Fixup blk_rq_unmap_user() API [PATCH] __blk_rq_unmap_user() fails to return error [PATCH] __blk_rq_map_user() doesn't need to grab the queue_lock [PATCH] Remove queue merging hooks [PATCH] ->nr_sectors and ->hard_nr_sectors are not used for BLOCK_PC requests [PATCH] cciss: fix XFER_READ/XFER_WRITE in do_cciss_request [PATCH] cciss: set default raid level when reading geometry fails
2006-12-20[POWERPC] iSeries: fix viocd initStephen Rothwell
Only initialise viocd on legacy iSeries. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-12-19[PATCH] Fixup blk_rq_unmap_user() APIJens Axboe
The blk_rq_unmap_user() API is not very nice. It expects the caller to know that rq->bio has to be reset to the original bio, and it will silently do nothing if that is not done. Instead make it explicit that we need to pass in the first bio, by expecting a bio argument. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-12-13[PATCH] getting rid of all casts of k[cmz]alloc() callsRobert P. J. Day
Run this: #!/bin/sh for f in $(grep -Erl "\([^\)]*\) *k[cmz]alloc" *) ; do echo "De-casting $f..." perl -pi -e "s/ ?= ?\([^\)]*\) *(k[cmz]alloc) *\(/ = \1\(/" $f done And then go through and reinstate those cases where code is casting pointers to non-pointers. And then drop a few hunks which conflicted with outstanding work. Cc: Russell King <rmk@arm.linux.org.uk>, Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Greg KH <greg@kroah.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Karsten Keil <kkeil@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Ian Kent <raven@themaw.net> Cc: Steven French <sfrench@us.ibm.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] drivers/cdrom/*: trivial vsnprintf() conversionAlexey Dobriyan
Fixing sbpcd.c baroque error printing in process. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Jens Axboe <axboe@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-01[PATCH] block: support larger block pc requestsMike Christie
This patch modifies blk_rq_map/unmap_user() and the cdrom and scsi_ioctl.c users so that it supports requests larger than bio by chaining them together. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-10-10[PATCH] cdrom: add endianness annotationsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-06Various drivers' irq handlers: kill dead code, needless castsJeff Garzik
- Eliminate casts to/from void* - Eliminate checks for conditions that never occur. These typically fall into two classes: 1) Checking for 'dev_id == NULL', then it is never called with NULL as an argument. 2) Checking for invalid irq number, when the only caller (the system) guarantees the irq handler is called with the proper 'irq' number argument. Signed-off-by: Jeff Garzik <jeff@garzik.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-10-03fix file specification in commentsUwe Zeisberger
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-30[PATCH] BLOCK: Make it possible to disable the block layer [try #6]David Howells
Make it possible to disable the block layer. Not all embedded devices require it, some can make do with just JFFS2, NFS, ramfs, etc - none of which require the block layer to be present. This patch does the following: (*) Introduces CONFIG_BLOCK to disable the block layer, buffering and blockdev support. (*) Adds dependencies on CONFIG_BLOCK to any configuration item that controls an item that uses the block layer. This includes: (*) Block I/O tracing. (*) Disk partition code. (*) All filesystems that are block based, eg: Ext3, ReiserFS, ISOFS. (*) The SCSI layer. As far as I can tell, even SCSI chardevs use the block layer to do scheduling. Some drivers that use SCSI facilities - such as USB storage - end up disabled indirectly from this. (*) Various block-based device drivers, such as IDE and the old CDROM drivers. (*) MTD blockdev handling and FTL. (*) JFFS - which uses set_bdev_super(), something it could avoid doing by taking a leaf out of JFFS2's book. (*) Makes most of the contents of linux/blkdev.h, linux/buffer_head.h and linux/elevator.h contingent on CONFIG_BLOCK being set. sector_div() is, however, still used in places, and so is still available. (*) Also made contingent are the contents of linux/mpage.h, linux/genhd.h and parts of linux/fs.h. (*) Makes a number of files in fs/ contingent on CONFIG_BLOCK. (*) Makes mm/bounce.c (bounce buffering) contingent on CONFIG_BLOCK. (*) set_page_dirty() doesn't call __set_page_dirty_buffers() if CONFIG_BLOCK is not enabled. (*) fs/no-block.c is created to hold out-of-line stubs and things that are required when CONFIG_BLOCK is not set: (*) Default blockdev file operations (to give error ENODEV on opening). (*) Makes some /proc changes: (*) /proc/devices does not list any blockdevs. (*) /proc/diskstats and /proc/partitions are contingent on CONFIG_BLOCK. (*) Makes some compat ioctl handling contingent on CONFIG_BLOCK. (*) If CONFIG_BLOCK is not defined, makes sys_quotactl() return -ENODEV if given command other than Q_SYNC or if a special device is specified. (*) In init/do_mounts.c, no reference is made to the blockdev routines if CONFIG_BLOCK is not defined. This does not prohibit NFS roots or JFFS2. (*) The bdflush, ioprio_set and ioprio_get syscalls can now be absent (return error ENOSYS by way of cond_syscall if so). (*) The seclvl_bd_claim() and seclvl_bd_release() security calls do nothing if CONFIG_BLOCK is not set, since they can't then happen. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-30[PATCH] Split struct request ->flags into two partsJens Axboe
Right now ->flags is a bit of a mess: some are request types, and others are just modifiers. Clean this up by splitting it into ->cmd_type and ->cmd_flags. This allows introduction of generic Linux block message types, useful for sending generic Linux commands to block devices. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-08-27[PATCH] cdrom/gdsc: fix printk format warningRandy Dunlap
Fix printk format warning: drivers/cdrom/gscd.c:269: warning: format ‘%lu’ expects type ‘long unsigned int’, but argument 2 has type ‘unsigned int’ Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Cc: Jens Axboe <axboe@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] cdrom: fix bad cgc.buflen assignmentJens Axboe
The code really means to mask off the high bits, not assign 0xff. Signed-off-by: Jens Axboe <axboe@suse.de> Cc: Marcus Meissner <meissner@suse.de> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] irq-flags: misc drivers: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: Remove obsolete #include <linux/config.h> remove obsolete swsusp_encrypt arch/arm26/Kconfig typos Documentation/IPMI typos Kconfig: Typos in net/sched/Kconfig v9fs: do not include linux/version.h Documentation/DocBook/mtdnand.tmpl: typo fixes typo fixes: specfic -> specific typo fixes in Documentation/networking/pktgen.txt typo fixes: occuring -> occurring typo fixes: infomation -> information typo fixes: disadvantadge -> disadvantage typo fixes: aquire -> acquire typo fixes: mecanism -> mechanism typo fixes: bandwith -> bandwidth fix a typo in the RTC_CLASS help text smb is no longer maintained Manually merged trivial conflict in arch/um/kernel/vmlinux.lds.S
2006-06-30[PATCH] drivers/cdrom/cm206.c: cleanupsAdrian Bunk
- make __cm206_init() __init (required since it calls the __init cm206_init()) - make the needlessly global bcdbin() static - remove a comment with an obsolete compile command Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Jens Axboe <axboe@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] devfs: Last little devfs cleanups throughout the kernel tree.Greg Kroah-Hartman
Just removes a few unused #defines and fixes some comments due to devfs now being gone. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[PATCH] devfs: Remove the gendisk devfs_name field as it's no longer neededGreg Kroah-Hartman
And remove the now unneeded number field. Also fixes all drivers that set these fields. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[PATCH] devfs: Remove the devfs_fs_kernel.h file from the treeGreg Kroah-Hartman
Also fixes up all files that #include it. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[PATCH] devfs: Remove devfs_remove() function from the kernel treeGreg Kroah-Hartman
Removes the devfs_remove() function and all callers of it. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[PATCH] devfs: Remove devfs_mk_dir() function from the kernel treeGreg Kroah-Hartman
Removes the devfs_mk_dir() function and all callers of it. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-25[PATCH] cdrom/mcdx: section fixesRandy Dunlap
Priority: not critical. Make __mcdx_init() __init and static. Saves a little memory. Fix section mismatch warning and make the function static while there: WARNING: drivers/cdrom/mcdx.o - Section mismatch: reference to .init.text: from .text between 'init_module' (at offset 0x8be) and 'mcdx_transfer' Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Cc: Jens Axboe <axboe@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
