path: root/drivers/cdrom
2014-06-11Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block layer fixes from Jens Axboe: "Final small batch of fixes to be included before -rc1. Some general cleanups in here as well, but some of the blk-mq fixes we need for the NVMe conversion and/or scsi-mq. The pull request contains: - Support for not merging across a specified "chunk size", if set by the driver. Some NVMe devices perform poorly for IO that crosses such a chunk, so we need to support it generically as part of request merging avoid having to do complicated split logic. From me. - Bump max tag depth to 10Ki tags. Some scsi devices have a huge shared tag space. Before we failed with EINVAL if a too large tag depth was specified, now we truncate it and pass back the actual value. From me. - Various blk-mq rq init fixes from me and others. - A fix for enter on a dying queue for blk-mq from Keith. This is needed to prevent oopsing on hot device removal. - Fixup for blk-mq timer addition from Ming Lei. - Small round of performance fixes for mtip32xx from Sam Bradshaw. - Minor stack leak fix from Rickard Strandqvist. - Two __init annotations from Fabian Frederick" * 'for-linus' of git://git.kernel.dk/linux-block: block: add __init to blkcg_policy_register block: add __init to elv_register block: ensure that bio_add_page() always accepts a page for an empty bio blk-mq: add timer in blk_mq_start_request blk-mq: always initialize request->start_time block: blk-exec.c: Cleaning up local variable address returnd mtip32xx: minor performance enhancements blk-mq: ->timeout should be cleared in blk_mq_rq_ctx_init() blk-mq: don't allow queue entering for a dying queue blk-mq: bump max tag depth to 10K tags block: add blk_rq_set_block_pc() block: add notion of a chunk size for request merging
2014-06-06cdrom: convert use of typedef ctl_table to struct ctl_tableJoe Perches
This typedef is unnecessary and should just be removed. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-06block: add blk_rq_set_block_pc()Jens Axboe
With the optimizations around not clearing the full request at alloc time, we are leaving some of the needed init for REQ_TYPE_BLOCK_PC up to the user allocating the request. Add a blk_rq_set_block_pc() that sets the command type to REQ_TYPE_BLOCK_PC, and properly initializes the members associated with this type of request. Update callers to use this function instead of manipulating rq->cmd_type directly. Includes fixes from Christoph Hellwig <hch@lst.de> for my half-assed attempt. Signed-off-by: Jens Axboe <axboe@fb.com>
2014-05-05cdrom: Remove unnecessary prototype for cdrom_get_disc_infoJoe Perches
Move the function to the proper spot instead. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-05-05cdrom: Remove unnecessary prototype for cdrom_mrw_exitJoe Perches
Move the function to appropriate locations instead. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-05-05cdrom: Remove cdrom_count_tracks prototypeJoe Perches
Move function to proper location instead. Fix whitespace and embedded if too. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-05-05cdrom: Remove cdrom_get_next_writeable prototypeJoe Perches
Move the function to the right spot instead. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-05-05cdrom: Remove cdrom_get_last_written prototypeJoe Perches
Move the function instead. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-05-05cdrom: Move mmc_ioctls above cdrom_ioctl to remove unnecessary prototypeJoe Perches
Neaten the spacing too. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-05-05cdrom: Remove unnecessary sanitize_format prototypeJoe Perches
It's defined below without being called. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-05-05cdrom: Remove unnecessary check_for_audio_disc prototypeJoe Perches
The actual static is defined below it but not used until later. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-05-05cdrom: Remove prototype for open_for_dataJoe Perches
Move static function to the appropriate place to remove the now unnecessary prototype. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-05-05cdrom: Remove obfuscating IOCTL_IN and IOCTL_OUT macrosJoe Perches
Macros with hidden control flow aren't nice. Just use copy_to/from_user directly instead. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-05-05cdrom: Remove unused CHECKAUDIO macroJoe Perches
It's unused, make it disappear. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-05-05cdrom: convert cdinfo to cd_dbgJoe Perches
It's a debugging message, mark it so. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-04-16gdrom: missed conversion from req->bufferJens Axboe
The friendly Intel kbuild test robot reported: drivers/cdrom/gdrom.c: In function 'gdrom_readdisk_dma': drivers/cdrom/gdrom.c:605:3: error: 'struct request' has no member named 'buffer' Convert that from req->buffer to bio_data(rq->bio). Apparently my grep missed this one, and I don't build for Sega Dreamcast enough. Signed-off-by: Jens Axboe <axboe@fb.com>
2014-01-30Merge branch 'for-3.14/drivers' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block IO driver changes from Jens Axboe: - bcache update from Kent Overstreet. - two bcache fixes from Nicholas Swenson. - cciss pci init error fix from Andrew. - underflow fix in the parallel IDE pg_write code from Dan Carpenter. I'm sure the 1 (or 0) users of that are now happy. - two PCI related fixes for sx8 from Jingoo Han. - floppy init fix for first block read from Jiri Kosina. - pktcdvd error return miss fix from Julia Lawall. - removal of IRQF_SHARED from the SEGA Dreamcast CD-ROM code from Michael Opdenacker. - comment typo fix for the loop driver from Olaf Hering. - potential oops fix for null_blk from Raghavendra K T. - two fixes from Sam Bradshaw (Micron) for the mtip32xx driver, fixing an OOM problem and a problem with handling security locked conditions * 'for-3.14/drivers' of git://git.kernel.dk/linux-block: (47 commits) mg_disk: Spelling s/finised/finished/ null_blk: Null pointer deference problem in alloc_page_buffers mtip32xx: Correctly handle security locked condition mtip32xx: Make SGL container per-command to eliminate high order dma allocation drivers/block/loop.c: fix comment typo in loop_config_discard drivers/block/cciss.c:cciss_init_one(): use proper errnos drivers/block/paride/pg.c: underflow bug in pg_write() drivers/block/sx8.c: remove unnecessary pci_set_drvdata() drivers/block/sx8.c: use module_pci_driver() floppy: bail out in open() if drive is not responding to block0 read bcache: Fix auxiliary search trees for key size > cacheline size bcache: Don't return -EINTR when insert finished bcache: Improve bucket_prio() calculation bcache: Add bch_bkey_equal_header() bcache: update bch_bkey_try_merge bcache: Move insert_fixup() to btree_keys_ops bcache: Convert sorting to btree_keys bcache: Convert debug code to btree_keys bcache: Convert btree_iter to struct btree_keys bcache: Refactor bset_tree sysfs stats ...
2013-12-03drivers/cdrom/gdrom.c: remove deprecated IRQF_DISABLEDMichael Opdenacker
Remove the IRQF_DISABLED flag from drivers/cdrom/gdrom.c. It's a NOOP since 2.6.35 and it will be removed one day. Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-12-03vio: remove dangly makefile bitsAlan
The drivers are long gone but some config escaped the prune Signed-off-by: Alan Cox <gnomes@lxorguk.ukuu.org.uk> Resolves-bug: https://bugzilla.kernel.org/show_bug.cgi?id=57221 Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-07-03drivers/cdrom/cdrom.c: use kzalloc() for failing hardwareJonathan Salwan
In drivers/cdrom/cdrom.c mmc_ioctl_cdrom_read_data() allocates a memory area with kmalloc in line 2885. 2885 cgc->buffer = kmalloc(blocksize, GFP_KERNEL); 2886 if (cgc->buffer == NULL) 2887 return -ENOMEM; In line 2908 we can find the copy_to_user function: 2908 if (!ret && copy_to_user(arg, cgc->buffer, blocksize)) The cgc->buffer is never cleaned and initialized before this function. If ret = 0 with the previous basic block, it's possible to display some memory bytes in kernel space from userspace. When we read a block from the disk it normally fills the ->buffer but if the drive is malfunctioning there is a chance that it would only be partially filled. The result is an leak information to userspace. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03drivers/cdrom/gdrom.c: fix device number leakLibo Chen
Without this patch, gdrom_major will leak when gd.cd_info alloc fails. Signed-off-by: Libo Chen <libo.chen@huawei.com> Cc: Jens Axboe <axboe@kernel.dk> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-07block_device_operations->release() should return voidAl Viro
The value passed is 0 in all but "it can never happen" cases (and those only in a couple of drivers) *and* it would've been lost on the way out anyway, even if something tried to pass something meaningful. Just don't bother. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-01-03Drivers: misc: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-20workqueue: deprecate flush[_delayed]_work_sync()Tejun Heo
flush[_delayed]_work_sync() are now spurious. Mark them deprecated and convert all users to flush[_delayed]_work(). If you're cc'd and wondering what's going on: Now all workqueues are non-reentrant and the regular flushes guarantee that the work item is not pending or running on any CPU on return, so there's no reason to use the sync flushes at all and they're going away. This patch doesn't make any functional difference. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Ian Campbell <ian.campbell@citrix.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Mattia Dongili <malattia@linux.it> Cc: Kent Yoder <key@linux.vnet.ibm.com> Cc: David Airlie <airlied@linux.ie> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Karsten Keil <isdn@linux-pingi.de> Cc: Bryan Wu <bryan.wu@canonical.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Alasdair Kergon <agk@redhat.com> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: David Woodhouse <dwmw2@infradead.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: linux-wireless@vger.kernel.org Cc: Anton Vorontsov <cbou@mail.ru> Cc: Sangbeom Kim <sbkim73@samsung.com> Cc: "James E.J. Bottomley" <James.Bottomley@HansenPartnership.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Takashi Iwai <tiwai@suse.de> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Petr Vandrovec <petr@vandrovec.name> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Avi Kivity <avi@redhat.com>
2012-03-16powerpc: Remove some of the legacy iSeries specific device driversStephen Rothwell
These drivers are specific to the PowerPC legacy iSeries platform and their Kconfig is specified in arch/powerpc. Legacy iSeries is being removed, so these drivers can no longer be selected. Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-02-08cdrom: move shared static to cdrom_device_infoPaolo Bonzini
The keeplocked variable in the cdrom driver is shared across multiple drives, but set in per-device ioctls. Move it to the per-device struct, avoiding that the setting on one drive affects the driver's behavior when closing another. [ Impact: limit udev's confusion to one drive when a CD burning program unlocks the CD door at the end of burning. ] Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-02-06cdrom: use copy_to_user() without the underscoresDan Carpenter
"nframes" comes from the user and "nframes * CD_FRAMESIZE_RAW" can wrap on 32 bit systems. That would have been ok if we used the same wrapped value for the copy, but we use a shifted value. We should just use the checked version of copy_to_user() because it's not going to make a difference to the speed. Cc: stable@vger.kernel.com Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-01-14block: add and use scsi_blk_cmd_ioctlPaolo Bonzini
Introduce a wrapper around scsi_cmd_ioctl that takes a block device. The function will then be enhanced to detect partition block devices and, in that case, subject the ioctls to whitelisting. Cc: linux-scsi@vger.kernel.org Cc: Jens Axboe <axboe@kernel.dk> Cc: James Bottomley <JBottomley@parallels.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-13module_param: make bool parameters really bool (drivers & misc)Rusty Russell
module_param(bool) used to counter-intuitively take an int. In fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy trick. It's time to remove the int/unsigned int option. For this version it'll simply give a warning, but it'll break next kernel version. Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-01-03fs: move code out of buffer.cAl Viro
Move invalidate_bdev, block_sync_page into fs/block_dev.c. Export kill_bdev as well, so brd doesn't have to open code it. Reduce buffer_head.h requirement accordingly. Removed a rather large comment from invalidate_bdev, as it looked a bit obsolete to bother moving. The small comment replacing it says enough. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-08-02drivers/cdrom/cdrom.c: relax check on dvd manufacturer valueAndrew Morton
The report has an ISO which has a very long manufacturer ID. It seems that Linux is wrong, not the ISO maker. Relax the check for the length of this field: emit a warning and truncate the incoming data to 2048 bytes rather than rejecting the entire thing. dvd_manufact.value isn't null-terminated. I'm not even sure if it's a string. The kernel doesn't apepar to use it anyway. Addresses https://bugzilla.kernel.org/show_bug.cgi?id=39062 Reported-by: <ale.goujon@gmail.com> Tested-by: <ale.goujon@gmail.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-06-02block: fix mismerge of the DISK_EVENT_MEDIA_CHANGE removalLinus Torvalds
Jens' back-merge commit 698567f3fa79 ("Merge commit 'v2.6.39' into for-2.6.40/core") was incorrectly done, and re-introduced the DISK_EVENT_MEDIA_CHANGE lines that had been removed earlier in commits - 9fd097b14918 ("block: unexport DISK_EVENT_MEDIA_CHANGE for legacy/fringe drivers") - 7eec77a1816a ("ide: unexport DISK_EVENT_MEDIA_CHANGE for ide-gd and ide-cd") because of conflicts with the "g->flags" updates near-by by commit d4dc210f69bc ("block: don't block events on excl write for non-optical devices") As a result, we re-introduced the hanging behavior due to infinite disk media change reports. Tssk, tssk, people! Don't do back-merges at all, and *definitely* don't do them to hide merge conflicts from me - especially as I'm likely better at merging them than you are, since I do so many merges. Reported-by: Steven Rostedt <rostedt@goodmis.org> Cc: Jens Axboe <jaxboe@fusionio.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-20Merge commit 'v2.6.39' into for-2.6.40/coreJens Axboe
Since for-2.6.40/core was forked off the 2.6.39 devel tree, we've had churn in the core area that makes it difficult to handle patches for eg cfq or blk-throttle. Instead of requiring that they be based in older versions with bugs that have been fixed later in the rc cycle, merge in 2.6.39 final. Also fixes up conflicts in the below files. Conflicts: drivers/block/paride/pcd.c drivers/cdrom/viocd.c drivers/ide/ide-cd.c Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-04-29cdrom: always check_disk_change() on openTejun Heo
cdrom_open() called check_disk_change() after the rest of open path succeeded which leads to the following bizarre behavior. * After media change, if the device opened without O_NONBLOCK, open_for_data() naturally fails with -ENOMEDIA and check_disk_change() is never called. The media is known to be gone and the open failure makes it obvious to the userland but device invalidation never happens. * But if the device is opened with O_NONBLOCK, all the checks are bypassed and cdrom_open() doesn't notice that the media is not there and check_disk_change() is called and invalidation happens. There's nothing to be gained by avoiding calling check_disk_change() on open failure. Common cases end up calling check_disk_change() anyway. All we get is inconsistent behavior. Fix it by moving check_disk_change() invocation to the top of cdrom_open() so that it always gets called regardless of how the rest of open proceeds. Stable: 2.6.38 Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Amit Shah <amit.shah@redhat.com> Tested-by: Amit Shah <amit.shah@redhat.com> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-04-21block: unexport DISK_EVENT_MEDIA_CHANGE for legacy/fringe driversTejun Heo
In-kernel disk event polling doesn't matter for legacy/fringe drivers and may lead to infinite event loop if ->check_events() implementation generates events on level condition instead of edge. Now that block layer supports suppressing exporting unlisted events, simply leaving disk->events cleared allows these drivers to keep the internal revalidation behavior intact while avoiding weird interactions with userland event handler. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-04-21block: don't block events on excl write for non-optical devicesTejun Heo
Disk event code automatically blocks events on excl write. This is primarily to avoid issuing polling commands while burning is in progress. This behavior doesn't fit other types of devices with removeable media where polling commands don't have adverse side effects and door locking usually doesn't exist. This patch introduces new genhd flag which controls the auto-blocking behavior and uses it to enable auto-blocking only on optical devices. Note for stable: 2.6.38 and later only Cc: stable@kernel.org Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-04-21cdrom: always check_disk_change() on openTejun Heo
cdrom_open() called check_disk_change() after the rest of open path succeeded which leads to the following bizarre behavior. * After media change, if the device opened without O_NONBLOCK, open_for_data() naturally fails with -ENOMEDIA and check_disk_change() is never called. The media is known to be gone and the open failure makes it obvious to the userland but device invalidation never happens. * But if the device is opened with O_NONBLOCK, all the checks are bypassed and cdrom_open() doesn't notice that the media is not there and check_disk_change() is called and invalidation happens. There's nothing to be gained by avoiding calling check_disk_change() on open failure. Common cases end up calling check_disk_change() anyway. All we get is inconsistent behavior. Fix it by moving check_disk_change() invocation to the top of cdrom_open() so that it always gets called regardless of how the rest of open proceeds. Note for stable: 2.6.38 and later only Cc: stable@kernel.org Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Amit Shah <amit.shah@redhat.com> Tested-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-09gdrom,viocd: Convert to bdops->check_events()Tejun Heo
Convert gdrom and viocd from ->media_changed() to ->check_events(). It's unclear how the conditions are cleared and it's possible that it may generate spurious events when polled. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jens Axboe <axboe@kernel.dk> Cc: Kay Sievers <kay.sievers@vrfy.org>
2011-02-09cdrom: support devices that have check_events but not media_changedSimon Arlott
Commit 93aae17af1172c40c6f74b7294e93a90c3cfaa5d ("sr: implement sr_check_events()") replaced the media_changed op with the check_events op in drivers/scsi/sr.c All users that check for the CDC_MEDIA_CHANGED capbility try both the check_events op and the media_changed op, but register_cdrom() was requiring media_changed. This patch fixes the capability checking. The cdrom_select_disc ioctl is also using the two operations, so they should be required for CDC_SELECT_DISC too. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Cc: Tejun Heo <tj@kernel.org> Cc: Kay Sievers <kay.sievers@vrfy.org> Tested-by: Chris Clayton <chris2553@googlemail.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-01-13Merge branch 'for-2.6.38/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.38/core' of git://git.kernel.dk/linux-2.6-block: (43 commits) block: ensure that completion error gets properly traced blktrace: add missing probe argument to block_bio_complete block cfq: don't use atomic_t for cfq_group block cfq: don't use atomic_t for cfq_queue block: trace event block fix unassigned field block: add internal hd part table references block: fix accounting bug on cross partition merges kref: add kref_test_and_get bio-integrity: mark kintegrityd_wq highpri and CPU intensive block: make kblockd_workqueue smarter Revert "sd: implement sd_check_events()" block: Clean up exit_io_context() source code. Fix compile warnings due to missing removal of a 'ret' variable fs/block: type signature of major_to_index(int) to major_to_index(unsigned) block: convert !IS_ERR(p) && p to !IS_ERR_NOR_NULL(p) cfq-iosched: don't check cfqg in choose_service_tree() fs/splice: Pull buf->ops->confirm() from splice_from_pipe actors cdrom: export cdrom_check_events() sd: implement sd_check_events() sr: implement sr_check_events() ...
2010-12-24gdrom: don't use flush_scheduled_work()Tejun Heo
flush_scheduled_work() is deprecated and scheduled to be removed. Directly flush work on removal instead. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jens Axboe <axboe@kernel.dk>
2010-12-16cdrom: export cdrom_check_events()Jens Axboe
It's used by sr, so we need to export it. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-12-16cdrom: add ->check_events() supportTejun Heo
In principle, cdrom just needs to pass through ->check_events() but CDROM_MEDIA_CHANGED ioctl makes things a bit more complex. Just as with ->media_changed() support, cdrom code needs to buffer the events and serve them to ioctl and vfs as requested. As the code has to deal with both ->check_events() and ->media_changed(), and vfs and ioctl event buffering, this patch adds check_events caching on top of the existing cdi->mc_flags buffering. It may be a good idea to deprecate CDROM_MEDIA_CHANGED ioctl and remove all this mess. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-27cdrom: gdrom: ctrl_in/outX to __raw_read/writeX conversion.Paul Mundt
The ctrl_xxx routines are deprecated, switch over to the __raw_xxx versions. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-10-05block: autoconvert trivial BKL users to private mutexArnd Bergmann
The block device drivers have all gained new lock_kernel calls from a recent pushdown, and some of the drivers were already using the BKL before. This turns the BKL into a set of per-driver mutexes. Still need to check whether this is safe to do. file=$1 name=$2 if grep -q lock_kernel ${file} ; then if grep -q 'include.*linux.mutex.h' ${file} ; then sed -i '/include.*<linux\/smp_lock.h>/d' ${file} else sed -i 's/include.*<linux\/smp_lock.h>.*$/include <linux\/mutex.h>/g' ${file} fi sed -i ${file} \ -e "/^#include.*linux.mutex.h/,$ { 1,/^\(static\|int\|long\)/ { /^\(static\|int\|long\)/istatic DEFINE_MUTEX(${name}_mutex); } }" \ -e "s/\(un\)*lock_kernel\>[ ]*()/mutex_\1lock(\&${name}_mutex)/g" \ -e '/[ ]*cycle_kernel_lock();/d' else sed -i -e '/include.*\<smp_lock.h\>/d' ${file} \ -e '/cycle_kernel_lock()/d' fi Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2010-08-07block: push down BKL into .open and .releaseArnd Bergmann
The open and release block_device_operations are currently called with the BKL held. In order to change that, we must first make sure that all drivers that currently rely on this have no regressions. This blindly pushes the BKL into all .open and .release operations for all block drivers to prepare for the next step. The drivers can subsequently replace the BKL with their own locks or remove it completely when it can be shown that it is not needed. The functions blkdev_get and blkdev_put are the only remaining users of the big kernel lock in the block layer, besides a few uses in the ioctl code, none of which need to serialize with blkdev_{get,put}. Most of these two functions is also under the protection of bdev->bd_mutex, including the actual calls to ->open and ->release, and the common code does not access any global data structures that need the BKL. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: push down BKL into .locked_ioctlArnd Bergmann
As a preparation for the removal of the big kernel lock in the block layer, this removes the BKL from the common ioctl handling code, moving it into every single driver still using it. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07drivers/cdrom: use pr_<level>Joe Perches
- add pr_fmt. - convert printks to pr_<level> - add if (0) and printf argument checking to cdinfo - coalesce consecutive printks to single pr_ - fix a typo "back ground" to "background" - convert printks without level to pr_info - remove VIOCD_ prefixes and use pr_fmt/pr_<level> - add a missing newline to an OS/400 message Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Folded in tab indentation fix from Andrew. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: remove wrappers for request type/flagsChristoph Hellwig
Remove all the trivial wrappers for the cmd_type and cmd_flags fields in struct requests. This allows much easier grepping for different request types instead of unwinding through macros. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
