path: root/drivers/cdrom/aztcd.c
2007-07-10Remove legacy CDROM driversJens Axboe
They are all broken beyond repair. Given that nobody has complained about them (most haven't worked in 2.6 AT ALL), remove them from the tree. A new mitsumi driver that actually works is in progress, it'll get added when completed. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-10[PATCH] fix request->cmd == INT casesBoaz Harrosh
- I have unearthed very old bugs in stale drivers that still used request->cmd as a READ|WRITE int - This patch is maybe a proof that these drivers have not been used for a long time. Should they be removed completely? Drivers that currently do not work for sure: drivers/acorn/block/fd1772.c | 2 +- drivers/acorn/block/mfmhd.c | 8 ++++---- drivers/cdrom/aztcd.c | 2 +- drivers/cdrom/cm206.c | 2 +- drivers/cdrom/gscd.c | 2 +- drivers/cdrom/mcdx.c | 2 +- drivers/cdrom/optcd.c | 2 +- drivers/cdrom/sjcd.c | 2 +- Drivers with cosmetic fixes only: b/drivers/block/amiflop.c b/drivers/block/nbd.c b/drivers/ide/legacy/hd.c Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-06-26[PATCH] devfs: Remove the gendisk devfs_name field as it's no longer neededGreg Kroah-Hartman
And remove the now unneeded number field. Also fixes all drivers that set these fields. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-11[PATCH] Overrun in cdrom/aztcd.cEric Sesterhenn
This fixes coverity bug id #473. After the for loop i==16 if we didn't find a cdrom. So we should check for i==16 first before checking the array element. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Cc: Jens Axboe <axboe@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] timer initialization cleanup: DEFINE_TIMERIngo Molnar
Clean up timer initialization by introducing DEFINE_TIMER a'la DEFINE_SPINLOCK. Build and boot-tested on x86. A similar patch has been been in the -RT tree for some time. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
