path: root/drivers/bus/mvebu-mbus.c
2014-06-02Merge tag 'soc-for-3.16' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc into next Pull part one of ARM SoC updates from Olof Johansson: "A quite large set of SoC updates this cycle. In no particular order: - Multi-cluster power management for Samsung Exynos, adding support for big.LITTLE CPU switching on EXYNOS5 - SMP support for Marvell Armada 375 and 38x - SMP rework on Allwinner A31 - Xilinx Zynq support for SOC_BUS, big endian - Marvell orion5x platform cleanup, modernizing the implementation and moving to DT. - _Finally_ moving Samsung Exynos over to support MULTIPLATFORM, so that their platform can be enabled in the same kernel binary as most of the other v7 platforms in the tree. \o/ The work isn't quite complete, there's some driver fixes still needed, but the basics now work. New SoC support added: - Freescale i.MX6SX - LSI Axxia AXM55xx SoCs - Samsung EXYNOS 3250, 5260, 5410, 5420 and 5800 - STi STIH407 plus a large set of various smaller updates for different platforms. I'm probably missing some important one here" * tag 'soc-for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (281 commits) ARM: exynos: don't run exynos4 l2x0 setup on other platforms ARM: exynos: Fix "allmodconfig" build errors in mcpm and hotplug ARM: EXYNOS: mcpm rename the power_down_finish ARM: EXYNOS: Enable mcpm for dual-cluster exynos5800 SoC ARM: EXYNOS: Enable multi-platform build support ARM: EXYNOS: Consolidate Kconfig entries ARM: EXYNOS: Add support for EXYNOS5410 SoC ARM: EXYNOS: Support secondary CPU boot of Exynos3250 ARM: EXYNOS: Add Exynos3250 SoC ID ARM: EXYNOS: Add 5800 SoC support ARM: EXYNOS: initial board support for exynos5260 SoC clk: exynos5410: register clocks using common clock framework ARM: debug: qcom: add UART addresses to Kconfig help for APQ8084 ARM: sunxi: allow building without reset controller Documentation: devicetree: arm: sort enable-method entries ARM: rockchip: convert smp bringup to CPU_METHOD_OF_DECLARE clk: exynos5250: Add missing sysmmu clocks for DISP and ISP blocks ARM: dts: axxia: Add reset controller power: reset: Add Axxia system reset driver ARM: axxia: Adding defconfig for AXM55xx ...
2014-04-24bus: mvebu: pass the coherency availability information at init timeThomas Petazzoni
Until now, the mvebu-mbus was guessing by itself whether hardware I/O coherency was available or not by poking into the Device Tree to see if the coherency fabric Device Tree node was present or not. However, on some upcoming SoCs, the presence or absence of the coherency fabric DT node isn't sufficient: in CONFIG_SMP, the coherency can be enabled, but not in !CONFIG_SMP. In order to clean this up, the mvebu_mbus_dt_init() function is extended to get a boolean argument telling whether coherency is enabled or not. Therefore, the logic to decide whether coherency is available or not now belongs to the core SoC code instead of the mvebu-mbus driver itself, which is much better. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Link: https://lkml.kernel.org/r/1397483228-25625-4-git-send-email-thomas.petazzoni@free-electrons.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-04-24bus: mvebu-mbus: allow several windows with the same target/attributeThomas Petazzoni
Having multiple windows with the same target and attribute is actually legal, and can be useful for PCIe windows, when PCIe BARs have a size that isn't a power of two, and we therefore need to create several MBus windows to cover the PCIe BAR for a given PCIe interface. Fixes: fddddb52a6c4 ('bus: introduce an Marvell EBU MBus driver') Cc: <stable@vger.kernel.org> # v3.10+ Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Link: https://lkml.kernel.org/r/1397823593-1932-7-git-send-email-thomas.petazzoni@free-electrons.com Tested-by: Neil Greatorex <neil@fatboyfat.co.uk> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-04-24bus: mvebu-mbus: Avoid setting an undefined window sizeJason Gunthorpe
The mbus hardware requires a power of two size, and size aligned base. Currently, if a non-power of two is passed in to the low level routines they configure the register in a way that results in undefined behaviour. Call WARN and return EINVAL instead. Also, update the debugfs routines to show a message if there is an invalid register setting. All together this makes the recent problems with silent failure of PCI very obvious, noisy and debuggable. Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Link: https://lkml.kernel.org/r/1397823593-1932-6-git-send-email-thomas.petazzoni@free-electrons.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-04-05Merge tag 'drivers-3.15' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver changes from Arnd Bergmann: "These changes are mostly for ARM specific device drivers that either don't have an upstream maintainer, or that had the maintainer ask us to pick up the changes to avoid conflicts. A large chunk of this are clock drivers (bcm281xx, exynos, versatile, shmobile), aside from that, reset controllers for STi as well as a large rework of the Marvell Orion/EBU watchdog driver are notable" * tag 'drivers-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (99 commits) Revert "dts: socfpga: Add DTS entry for adding the stmmac glue layer for stmmac." Revert "net: stmmac: Add SOCFPGA glue driver" ARM: shmobile: r8a7791: Fix SCIFA3-5 clocks ARM: STi: Add reset controller support to mach-sti Kconfig drivers: reset: stih416: add softreset controller drivers: reset: stih415: add softreset controller drivers: reset: Reset controller driver for STiH416 drivers: reset: Reset controller driver for STiH415 drivers: reset: STi SoC system configuration reset controller support dts: socfpga: Add sysmgr node so the gmac can use to reference dts: socfpga: Add support for SD/MMC on the SOCFPGA platform reset: Add optional resets and stubs ARM: shmobile: r7s72100: fix bus clock calculation Power: Reset: Generalize qnap-poweroff to work on Synology devices. dts: socfpga: Update clock entry to support multiple parents ARM: socfpga: Update socfpga_defconfig dts: socfpga: Add DTS entry for adding the stmmac glue layer for stmmac. net: stmmac: Add SOCFPGA glue driver watchdog: orion_wdt: Use %pa to print 'phys_addr_t' drivers: cci: Export CCI PMU revision ...
2014-02-18bus: mvebu-mbus: Fix incorrect size for PCI aperture resourcesJason Gunthorpe
reg[0] is the DT base, reg[1] is the DT length in bytes, struct resource.end is the inclusive end address, so a -1 is required. Tested on kirkwood. Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Jason Cooper <jason@lakedaemon.net> Acked-by: Arnd Bergmann <arnd@arndb.de>
2014-02-11bus: mvebu-mbus: make use of of_find_matching_node_and_matchJosh Cartwright
Instead of the of_find_matching_node()/of_match_node() pair, which requires two iterations through the match table, make use of of_find_matching_node_and_match(), which only iterates through the table once. Signed-off-by: Josh Cartwright <joshc@codeaurora.org> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-11-24bus: mvebu-mbus: Remove deprecated commentEzequiel Garcia
Remove a comment about the lack of a devicetree binding: this driver's binding is already implemented and in use. Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-11-24bus: mvebu-mbus: potential forever loop in mvebu_mbus_init()Dan Carpenter
"of_id->compatible" is an array and not a pointer so it can never be NULL. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-10-01bus: mvebu-mbus: Fix optional pcie-mem/io-aperture propertiesJason Gunthorpe
If the property was not specified then the returned resource had a resource_size(..) == 1, rather than 0. The PCI-E driver checks for 0 so it blindly continues on with a corrupted resource. The regression was introduced into v3.12 by: 11be654 PCI: mvebu: Adapt to the new device tree layout Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-09-18bus: mvebu: add missing of_node_put() to fix reference leakJisheng Zhang
Add of_node_put to properly decrement the refcount when we are done using a given node. Signed-off-by: Jisheng Zhang <jszhang@marvell.com> Reviewed-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net> Conflicts: drivers/bus/mvebu-mbus.c
2013-08-06bus: mvebu-mbus: Factorize Armada 370/XP data structuresThomas Petazzoni
These structures were only different in the mapping tables. Now that those tables have been removed, it doesn't make any sense to keep different structures. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Tested-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-08-06bus: mvebu-mbus: Update main descriptionThomas Petazzoni
After replacing the MBus name-based by the new ID-based API let's fix the general description of the driver at the beginning of the file. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Tested-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-08-06bus: mvebu-mbus: Remove name -> target, attribute mapping tablesThomas Petazzoni
This tables were used together with the name-based MBus window creation API. Since that's has been removed, we can also remove the tables. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Tested-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-08-06bus: mvebu-mbus: Remove the no longer used name-based APIThomas Petazzoni
Now that every user of the deprecated name-based API has been converted to using the ID-based API, let's remove the former one. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Tested-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-08-06bus: mvebu-mbus: Add new API for the PCIe memory and IO apertureEzequiel Garcia
We add two optional properties to the MBus DT binding, to encode the PCIe memory and IO aperture. This allows such information to be retrieved by -for instance- the pci driver to allocate the MBus decoding windows. Correspondingly, and in order to retrieve this information, we add two new APIs. Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Tested-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-08-06bus: mvebu-mbus: Add static window allocation to the DT bindingEzequiel Garcia
This patch adds static window allocation to the device tree binding. Each first-child of the mbus-compatible node, with a suitable 'ranges' property, declaring an address translation, will trigger an address decoding window allocation. Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Tested-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-08-06bus: mvebu-mbus: Introduce device tree bindingEzequiel Garcia
This patch adds the most fundamental device-tree initialization. We only introduce what's required to be able to probe the mvebu-mbus driver from the DT. Follow-up patches will extend the device tree binding, allowing to describe static address decoding windows. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Tested-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-08-06bus: mvebu-mbus: Factor out initialization detailsEzequiel Garcia
We introduce a common initialization function mvebu_mbus_common_init() that will be used by both legacy and device-tree initialization code. This patch is an intermediate step, which will allow to introduce the DT binding for this driver in a less intrusive way. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Tested-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-08-06bus: mvebu-mbus: Add new API for window creationThomas Petazzoni
We add an API to create MBus address decoding windows from the target ID and attribute. This function will be used later and deprecate the current name based scheme. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Tested-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-06-08bus: mvebu-mbus: Use pr_fmtEzequiel Garcia
In order to clean message printing, we replace pr_info with pr_fmt. This is purely cosmetic change, with the sole purpose of making the code a bit more readable. Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Acked-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-04-11bus: mvebu: fix mistake in PCIe window target attribute for KirkwoodThomas Petazzoni
The target and attributes for the PCIe address decoding windows were not correct on Kirkwood for the second PCIe interface. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-03-30bus: mvebu-mbus: Restore checking for coherency fabric hardwareNeil Greatorex
The new mvebu-mbus driver was not checking the device tree for coherency fabric hardware and hence was not setting the hw_io_coherency flag in mbus_state. This prevented the mvsdio driver from operating correctly. This patch restores the check. Signed-off-by: Neil Greatorex <neil@fatboyfat.co.uk> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-03-28bus: introduce an Marvell EBU MBus driverThomas Petazzoni
The Marvell EBU SoCs have a configurable physical address space layout: the physical ranges of memory used to address PCI(e) interfaces, NOR flashes, SRAM and various other types of memory are configurable by software, through a mechanism of so-called 'address decoding windows'. This new driver mvebu-mbus consolidates the existing code to address the configuration of these memory ranges, which is spread into mach-mvebu, mach-orion5x, mach-mv78xx0, mach-dove and mach-kirkwood. Following patches convert each Marvell EBU SoC family to use this driver, therefore removing the old code that was configuring the address decoding windows. It is worth mentioning that the MVEBU_MBUS Kconfig option is intentionally added as a blind option. The new driver implements and exports the mv_mbus_dram_info() function, which is used by various Marvell drivers throughout the tree to get access to window configuration parameters that they require. This function is also implemented in arch/arm/plat-orion/addr-map.c, which ultimately gets removed at the end of this patch series. So, in order to preserve bisectability, we want to ensure that *either* this new driver, *or* the legacy code in plat-orion/addr-map.c gets compiled in. By making MVEBU_MBUS a blind option, we are sure that only a platform that does 'select MVEBU_MBUS' will get this new driver compiled in. Therefore, throughout the next patches that convert the Marvell sub-architectures one after the other to this new driver, we add the 'select MVEBU_MBUS' and also ensure to remove plat-orion/addr-map.c from the build for this specific sub-architecture. This ensures that bisectability is preserved. Ealier versions of this driver had a DT binding, but since those were not yet agreed upon, they were removed. The driver still uses of_device_id to find the SoC specific details according to the string passed to mvebu_mbus_init(). The plan is to re-introduce a proper DT binding as a followup set of patches. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
