[ Upstream commit 4528668ca331f7ce5999b7746657b46db5b3b785 ]
The of_find_compatible_node() function returns a node pointer with
refcount incremented, We should use of_node_put() on it when done
Add the missing of_node_put() to release the refcount.
Fixes: 2121aa3e2312 ("mips: cdmm: Add mti,mips-cdmm dtb node support")
Signed-off-by: Miaoqian Lin <linmq006@gmail.com>
Acked-by: Serge Semin <fancer.lancer@gmail.com>
Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
kfree(dev) has been called inside put_device so anther
kfree would cause a use-after-free bug/
Fixes: 8286ae03308c ("MIPS: Add CDMM bus support")
Signed-off-by: Qinglang Miao <miaoqinglang@huawei.com>
Since having and mapping the CDMM block is platform specific, then
instead of just returning a zero-address, lets make the default CDMM
base address search method (mips_cdmm_phys_base()) to do something
useful. For instance to find the address in a dedicated dtb-node in
order to support of-based platforms by default.
Signed-off-by: Serge Semin <Sergey.Semin@baikalelectronics.ru>
Install the callbacks via the state machine and let the core invoke
the callbacks on the already online CPUs.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: rt@linutronix.de
Link: http://lkml.kernel.org/r/20160818125731.27256-14-bigeasy@linutronix.de
Since commit 3b9d6da67e11 ("cpu/hotplug: Fix rollback during error-out
in __cpu_disable()") it is ensured that callbacks of CPU_ONLINE and
CPU_DOWN_PREPARE are processed on the hotplugged CPU. Due to this
work_on_cpu() calls are no longer required.
Replace work_on_cpu() with a direct call of mips_cdmm_bus_up() or
mips_cdmm_bus_down(). Description of those functions are adapted.
Signed-off-by: Anna-Maria Gleixner <anna-maria@linutronix.de>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/13197/
Weak header file declarations are error-prone because they make every
definition weak, and the linker chooses one based on link order (see
10629d711ed7 ("PCI: Remove __weak annotation from pcibios_get_phb_of_node
decl")).
mips_cdmm_phys_base() is defined only in arch/mips/mti-malta/malta-memory.c
so there's no problem with multiple definitions. But it works better to
have a weak default implementation and allow a strong function to override
it. Then we don't have to test whether a definition is present, and if
there are ever multiple strong definitions, we get a link error instead of
calling a random definition.
Add a weak mips_cdmm_phys_base() definition and remove the weak annotation
from the declaration in arch/mips/include/asm/cdmm.h.
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Reviewed-by: James Hogan <james.hogan@imgtec.com>
Cc: Andrew Bresticker <abrestic@chromium.org>
Patchwork: https://patchwork.linux-mips.org/patch/10688/
The MIPS Common Device Memory Map (CDMM) is internal to the core and has
native endianness. There is therefore no need to byte swap the accesses
on big endian targets, so convert the CDMM bus driver to use
__raw_readl() rather than readl().
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/9904/
Add MIPS Common Device Memory Map (CDMM) support in the form of a bus in
the standard Linux device model. Each device attached via CDMM is
discoverable via an 8-bit type identifier and may contain a number of
blocks of memory mapped registers in the CDMM region. IRQs are expected
to be handled separately.
Due to the per-cpu (per-VPE for MT cores) nature of the CDMM devices,
all the driver callbacks take place from workqueues which are run on the
right CPU for the device in question, so that the driver doesn't need to
be as concerned about which CPU it is running on. Callbacks also exist
for when CPUs are taken offline, so that any per-CPU resources used by
the driver can be disabled so they don't get forcefully migrated. CDMM
devices are created as children of the CPU device they are attached to.
Any existing CDMM configuration by the bootloader will be inherited,
however platforms wishing to enable CDMM should implement the weak
mips_cdmm_phys_base() function (see asm/cdmm.h) so that the bus driver
knows where it should put the CDMM region in the physical address space
if the bootloader hasn't already enabled it.
A mips_cdmm_early_probe() function is also provided to allow early boot
or particularly low level code to set up the CDMM region and probe for a
specific device type, for example early console or KGDB IO drivers for
the EJTAG Fast Debug Channel (FDC) CDMM device.
Patchwork: https://patchwork.linux-mips.org/patch/9599/
