path: root/drivers/bluetooth/hci_usb.c
2008-04-19hci_usb: remove code obfuscationPavel Machek
_urb_free is an alias for kfree... making code longer & harder to read. Remove it. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-19hci_usb: do not initialize static variables to 0Pavel Machek
hci_usb: do not initialize static variables to 0. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (47 commits) [SCTP]: Fix local_addr deletions during list traversals. net: fix build with CONFIG_NET=n [TCP]: Prevent sending past receiver window with TSO (at last skb) rt2x00: Add new D-Link USB ID rt2x00: never disable multicast because it disables broadcast too libertas: fix the 'compare command with itself' properly drivers/net/Kconfig: fix whitespace for GELIC_WIRELESS entry [NETFILTER]: nf_queue: don't return error when unregistering a non-existant handler [NETFILTER]: nfnetlink_queue: fix EPERM when binding/unbinding and instance 0 exists [NETFILTER]: nfnetlink_log: fix EPERM when binding/unbinding and instance 0 exists [NETFILTER]: nf_conntrack: replace horrible hack with ksize() [NETFILTER]: nf_conntrack: add \n to "expectation table full" message [NETFILTER]: xt_time: fix failure to match on Sundays [NETFILTER]: nfnetlink_log: fix computation of netlink skb size [NETFILTER]: nfnetlink_queue: fix computation of allocated size for netlink skb. [NETFILTER]: nfnetlink: fix ifdef in nfnetlink_compat.h [NET]: include <linux/types.h> into linux/ethtool.h for __u* typedef [NET]: Make /proc/net a symlink on /proc/self/net (v3) RxRPC: fix rxrpc_recvmsg()'s returning of msg_name net/enc28j60: oops fix ...
2008-03-07bluetooth: Add another Broadcom deviceKarsten Keil
This adds another Broadcom BCM2045 based device to the blacklist, with these settings the micro dongle works on my system. Signed-off-by: Karsten Keil <kkeil@suse.de> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-05bluetooth: CONWISE Technology based adapters with buggy SCO support ↵SDiZ
(bugzilla #9027) From: SDiZ <sdiz@sdiz.net> Fix the CONWISE Technology based adapters with buggy SCO support issue (bugzilla #9027) Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-05bluetooth: blacklist another Broadcom BCM2035 deviceAndy Shevchenko
This device is recognized as bluetooth, but still not works. Signed-off-by: Andy Shevchenko <andy@smile.org.ua> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-09-09[Bluetooth] Add missing stat.byte_rx counter modificationMarcel Holtmann
With the support for hci_recv_fragment() the call to increase the stat.byte_rx counter got accidentally removed. This patch fixes it. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2007-07-11[Bluetooth] Use hci_recv_fragment() within HCI USB driverMarcel Holtmann
This patch modifies the HCI USB driver to use the new helper function for reassembling HCI data packets and events. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2007-05-24[Bluetooth] Always send HCI_Reset for Broadcom devicesMarcel Holtmann
In case of Broadcom based Bluetooth devices, it is safe to always send HCI_Reset as first command. This gives the advantage that all HID Proxy versions will automatically work and don't need any additional quirks anymore. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2007-05-05[Bluetooth] Correct SCO buffer for another Broadcom based dongleMarcel Holtmann
The SCO buffer size values for Bluetooth chips from Broadcom are wrong and the USB Bluetooth driver has to set a quirk to correct these SCO buffer size values. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2007-05-05[Bluetooth] Add support for Targus ACB10US USB dongleMarcel Holtmann
This patch adds the vendor and product id of the Targus ACB10US dongle and sets a flag to send HCI_Reset as the first command. Signed-off-by: Marcel Holtmann <marcel@holtmann.org
2007-01-09[Bluetooth] Correct SCO buffer for Broadcom based Dell laptopsMarcel Holtmann
The SCO buffer size values on Dell laptops with a Bluetooth chip from Broadcom are wrong. The USB Bluetooth driver has to set a quirk to correct the SCO buffer size values. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2007-01-09[Bluetooth] Correct SCO buffer for Broadcom based HP laptopsMarcel Holtmann
The SCO buffer size values on HP laptops with a Bluetooth chip from Broadcom are wrong. The USB Bluetooth driver has to set a quirk to correct the SCO buffer size values. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2007-01-09[Bluetooth] Correct SCO buffer size for another ThinkPad laptopMarcel Holtmann
The ThinkPad R60E uses a Broadcom based Bluetooth chip and even this version needs the quirk to correct the SCO buffer size values. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-12-20[PATCH] bluetooth: add support for another Kensington dongleOlivier Galibert
Add the stupid sco fixup quirk to yet another Broadcom/Kensington device. Cc: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-20[Bluetooth] Add support for newer ANYCOM USB donglesMarcel Holtmann
This patch adds the vendor and product id of the ANYCOM Bluetooth USB-200 and USB-250 dongles and sets a flag to send HCI_Reset as the first command. Signed-off-by: Marcel Holtmann <marcel@holtmann.org
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-28[Bluetooth] Add support for Canyon CN-BTU1 dongleMarcel Holtmann
This patch adds the vendor and product id of the Canycon CN-BTU1 dongle and sets a flag to send HCI_Reset as the first command. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-07-24[Bluetooth] Enable SCO support for Broadcom HID proxy dongleMarcel Holtmann
The Broadcom dongles with HID proxy support actually support SCO over HCI if the SCO buffer size values are corrected. So instead of disabling the SCO support, mark this dongle with the quirk for the Bluetooth core to correct the wrong buffer size values. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-07-24[Bluetooth] Add quirk for another broken RTX Telecom based dongleMarcel Holtmann
This patch disables the ISOC transfers for another broken RTX Telecom based USB dongle. Starting the USB ISOC transfers only ends in a burst of error messages for invalid SCO packets on connection handle 0. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-07-24[Bluetooth] Correct SCO buffer size for Belkin devicesMarcel Holtmann
The Belkin F8T012 and F8T013 devices are both based on a Bluetooth chip from Broadcom and their SCO buffer size values are wrong. The Bluetooth core should correct these values. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-07-24[Bluetooth] Correct SCO buffer size for another Broadcom chipMarcel Holtmann
The SCO buffer size values on IBM/Lenovo ThinkPad laptops with a Bluetooth chip from Broadcom are wrong. The USB Bluetooth driver has to set a quirk to correct the SCO buffer size values. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-07-03[Bluetooth] Correct SCO buffer size on requestMarcel Holtmann
This patch introduces a quirk that allows the drivers to tell the host to correct the SCO buffer size values. Signed-off-by: Olivier Galibert <galibert@pobox.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-07-03[Bluetooth] Add suspend/resume support to the HCI USB driverMarcel Holtmann
This patch implements the suspend/resume methods for the HCI USB driver by killing all outstanding URBs on suspend, and re-issuing them on resume. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-07-03[Bluetooth] Use raw mode for the Frontline sniffer deviceMarcel Holtmann
The Frontline sniffer device looks like a normal H:2 Bluetooth device, but it is not and so mark it as raw mode device. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-01-04[PATCH] USB: remove .owner field from struct usb_driverGreg Kroah-Hartman
It is no longer needed, so let's remove it, saving a bit of memory. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-08[Bluetooth]: Add another ignore parameter to the HCI USB driverMarcel Holtmann
This patchs adds the module parameter ignore_dga to the HCI USB driver which makes it possible to prevent this driver from being loaded by some buggy Digianswer devices. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-07[PATCH] bluetooth: kmalloc + memset -> kzalloc conversionDeepak Saxena
Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Cc: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-13[Bluetooth] Add ignore parameters to the HCI USB driverMarcel Holtmann
This patch adds the module parameters ignore_csr and ignore_sniffer to the HCI USB driver. This allows an easier use of CSR ROM chips that need an additional initialization routine and the Frontline sniffers. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2005-08-29[Bluetooth]: Move packet type into the SKB control bufferMarcel Holtmann
This patch moves the usage of packet type into the SKB control buffer. After this patch it is now possible to shrink the sk_buff structure and redefine its pkt_type. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[Bluetooth]: Fix sparse warnings (__nocast type)Victor Fusco
This patch fixes the sparse warnings "implicit cast to nocast type" for the priority or gfp_mask parameters of the memory allocations. Signed-off-by: Victor Fusco <victor@cetuc.puc-rio.br> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-06[Bluetooth] Remove unused functions and cleanup symbol exportsMarcel Holtmann
This patch removes the unused bt_dump() function and it also removes its BT_DMP macro. It also unexports the hci_dev_get(), hci_send_cmd() and hci_si_event() functions. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2005-08-06[Bluetooth] Kill redundant NULL checks before kfree()Marcel Holtmann
There's no need to check for NULL before calling kfree() on a pointer. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2005-08-06[Bluetooth] Send HCI_Reset for Kensington dongleMarcel Holtmann
The Kensington Bluetooth USB adapter is based on a Broadcom chip with the HID proxy support. To initialize these kind of devices correctly it is necessary to send HCI_Reset as the first command. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
