This patch adds firmware dump support for marvell
bluetooth chipset. Currently only SD8897 is supported.
This is implemented based on dev_coredump, a new mechnism
introduced in kernel 3.18rc3
Firmware dump can be trigger by
echo 1 > /sys/kernel/debug/bluetooth/hci*/config/fw_dump
and when the dump operation is completed, data can be read by
cat /sys/class/devcoredump/devcd*/data
We have prepared following script to divide fw memory
dump data into multiple files based on memory type.
[root]# cat btmrvl_split_dump_data.sh
#!/bin/bash
# usage: ./btmrvl_split_dump_data.sh dump_data
fw_dump_data=$1
mem_type="ITCM DTCM SQRAM APU CIU ICU MAC EXT7 EXT8 EXT9 EXT10 EXT11 EXT12 EXT13 EXTLAST"
for name in ${mem_type[@]}
do
sed -n "/Start dump $name/,/End dump/p" $fw_dump_data > tmp.$name.log
if [ ! -s tmp.$name.log ]
then
rm -rf tmp.$name.log
else
# Remove the describle info "Start dump" and "End dump"
sed '1d' tmp.$name.log | sed '$d' > /data/$name.log
if [ -s /data/$name.log ]
then
echo "generate /data/$name.log"
else
sed '1d' tmp.$name.log | sed '$d' > /var/$name.log
echo "generate /var/$name.log"
fi
fi
done
Signed-off-by: Xinming Hu <huxm@marvell.com>
Signed-off-by: Cathy Luo <cluo@marvell.com>
Signed-off-by: Avinash Patil <patila@marvell.com>
Reviewed-by: Johannes Berg <johannes@sipsolutions.net>
Reviewed-by: Marcel Holtmann <marcel@holtmann.org>
Signed-off-by: Amitkumar Karwar <akarwar@marvell.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
BT_INFO/BT_DBG etc. already takes care of adding a newline
An extra newline character inside message is removed in this
patch.
This patch adds driver support for marvell SD8887 chip.
Signed-off-by: Kevin Gan <ganhy@marvell.com>
Register offsets are different for SD8897 and newer chip SD8887.
We can not have common btmrvl_sdio_card_reg map for them.
We should suspend hci device and purge remaining data in tx queue
before enabling host sleep in firmware. If any data is sent to
firmware after host sleep is activated, firmware may end up
sending a TX_DONE interrupt to driver. If this interrupt gets
delivered to host while the SDIO host controller is suspending,
it may crash the system.
Conversely, in resume handler, we should resume hci device after
host sleep is de-activated.
Signed-off-by: Chin-Ran Lo <crlo@marvell.com>
Signed-off-by: Bing Zhao <bzhao@marvell.com>
A vendor specific command is sent to firmware during
initialization to enable this feature. This command is for
SD8897 only.
For SD8897, CMD52 write_to_clear may have missing interrupts
under certain corner case condition. Use CMD53 read-to-clear
to fix the problem.
This patch improves readability and makes future changes easier.
Some ARM versions of Chromebook need to download a new calibration
data from host driver to firmware. They do have EEPROM but still
need a piece of new calibration data in test mode.
The cal-data is platform dependent. It's simpler and more feasible
to use device tree based cal-data instead of configuration file
based cal-data.
This patch remove configuration file based cal-data downloading
and replace it using cal-data from device tree.
When CONFIG_OF is not selected, or the specific property is not
present in the device tree, the calibration downloading will not
happen.
Cc: Mike Frysinger <vapier@chromium.org>
Cc: Amitkumar Karwar <akarwar@marvell.com>
Signed-off-by: Hyuckjoo Lee <hyuckjoo.lee@samsung.com>
To avoid casting skb->dev into hdev, just let the drivers provide
the hdev directly when calling hci_recv_frame() function.
This patch also fixes up all drivers to provide the hdev.
Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
A text file containing calibration data in hex format can
be provided at following path:
/lib/firmware/mrvl/sd8797_caldata.conf
The data will be downloaded to firmware during initialization.
Reviewed-by: Mike Frysinger <vapier@chromium.org>
Move initialization code to hdev's setup handler.
There are two places where DIV_ROUND_UP may be used. It makes code a bit
clearer.
Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
Fix to return -ENOMEM in the skb alloc error handling case
instead of 0, as done elsewhere in this function.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
The register offsets have been changed in SD8897 and newer chips.
Define a new btmrvl_sdio_card_reg map for SD88xx.
Signed-off-by: Frank Huang <frankh@marvell.com>
FW does the synchronization of the different modules during init.
It will report different modules, that it is ready at different times.
The fw download 'winner' will be reported fw ready first. Without this
patch, btmrvl was already continuing before the FW told it too. Probably
on behalf of the 'winner' which then never sees FW ready and times out.
Signed-off-by: Andreas Fenkart <andreas.fenkart@streamunlimited.com>
If not winner, driver must release the sdio host lock, so the fw
download can progress. While holding the lock fw download is stalled
and the following error is produced:
[ 235.746015] Bluetooth: FW failed to be active in time!
[ 235.752799] Bluetooth: Downloading firmware failed!
There is no need to init ret to zero in btmrvl_sdio_download_fw().
The firmware images are shared with libertas_sdio WiFi chip and used to be
in libertas/ subtree in linux-firmware. As btmrvl_sdio used to look into
the linux-firmware root, it ended up being unsuccessful. Since the
firmware files are not specific to the libertas hardware, they're being
moved into mrvl/ now.
Signed-off-by: Lubomir Rintel <lkundrak@v3.sk>
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Use standard print specifier and remove print_hex_dump_bytes call.
Makes output more sensible:
[18809.401218] 00000000: 0b 00 00 fe 5b fc 01 f2 00 00 00 ....[......
would be changed to
[18809.401218] Bluetooth: hex: 0b 00 00 fe 5b fc 01 f2 00 00 00
Signed-off-by: Andrei Emeltchenko <andrei.emeltchenko@intel.com>
Add extra check to avoid skb buffer overflow. Fixes crash below:
[ 101.030427] ------------[ cut here ]------------
[ 101.030459] kernel BUG at net/core/skbuff.c:127!
[ 101.030486] invalid opcode: 0000 [#1] SMP
[ 101.030806] Pid: 2010, comm: btmrvl_main_ser Not tainted 3.5.0+ #80 Laptop
[ 101.030859] EIP: 0060:[<c14f2ba9>] EFLAGS: 00010282 CPU: 0
[ 101.030894] EIP is at skb_put+0x99/0xa0
[ 101.030919] EAX: 00000080 EBX: f129380b ECX: ef923540 EDX: 00000001
[ 101.030956] ESI: f00a4000 EDI: 00001003 EBP: ed4a5efc ESP: ed4a5ecc
[ 101.030992] DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068
[ 101.031024] CR0: 8005003b CR2: 08fca014 CR3: 30960000 CR4: 000407f0
[ 101.031062] DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000
[ 101.031100] DR6: ffff0ff0 DR7: 00000400
[ 101.031125] Process btmrvl_main_ser (pid: 2010, ti=ed4a4000 task=ef923540 task.ti=ed4a4000)
[ 101.031174] Stack:
[ 101.031188] c18126f8 c1651938 f853f8d2 00001003 00001003 f1292800 f1292808 f129380b
[ 101.031250] f1292940 f00a4000 eddb1280 efc0f9c0 ed4a5f44 f853f8d2 00000040 00000000
[ 101.031312] ef923540 c15ee096 ef923540 eddb12d4 00000004 f00a4000 00000040 00000000
[ 101.031376] Call Trace:
[ 101.031396] [<f853f8d2>] ? btmrvl_sdio_process_int_status+0x272/0x3d0 [btmrvl_sdio]
[ 101.031444] [<f853f8d2>] btmrvl_sdio_process_int_status+0x272/0x3d0 [btmrvl_sdio]
[ 101.031488] [<c15ee096>] ? _raw_spin_unlock_irqrestore+0x36/0x70
[ 101.031526] [<f85a46e4>] btmrvl_service_main_thread+0x244/0x300 [btmrvl]
[ 101.031568] [<f853fb50>] ? btmrvl_sdio_poll_card_status.isra.6.constprop.7+0x90/0x90 [btmrvl_sdio]
[ 101.031619] [<c107eda0>] ? try_to_wake_up+0x270/0x270
[ 101.031648] [<f85a44a0>] ? btmrvl_process_event+0x3b0/0x3b0 [btmrvl]
[ 101.031686] [<c106d19d>] kthread+0x7d/0x90
[ 101.031713] [<c106d120>] ? flush_kthread_work+0x150/0x150
[ 101.031745] [<c15f5a82>] kernel_thread_helper+0x6/0x10
[ 101.032008] EIP: [<c14f2ba9>] skb_put+0x99/0xa0 SS:ESP 0068:ed4a5ecc
[ 101.056125] ---[ end trace a0bd01d1a9a796c8 ]---
The kernel.h macro DIV_ROUND_UP performs the computation
(((n) + (d) - 1) / (d))
Make code readable by correcting name from buf_block_len to num_blocks
since it represent number of blocks; NOT a length of a block buffer.
Remove pointless conditional before kfree_skb().
devm_kzalloc() eliminates the need to free memory explicitly
thereby saving some cleanup code.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Patch shortens locals scope and adds missing braces. This is a diff
between v1 which was applied and v2 of patch "Bluetooth: btmrvl: Do
not send vendor events to bluetooth stack".
git://git.kernel.org/pub/scm/linux/kernel/git/bluetooth/bluetooth
Vendor-specific events shall be processed in driver and not sent
to bluetooth stack where they screw up HCI command countings.
SD8787 SDIO function 3 (device ID 0x911B) is for Bluetooth AMP.
Host sleep is activated using already configured host sleep
parameters in suspend handler and it is cancelled in resume
handler.
Signed-off-by: Gustavo Padovan <gustavo@padovan.org>
Currently debugfs commands "hscfgcmd" and "gpiogap" are provided
for host sleep configuration. But if user doesn't configure host
sleep parameters using these commands, host sleep activation is
failed during suspend (support for suspend and resume handlers is
added in next patch).
Default host sleep configuration is done during driver initialisation
in this patch.
release_firmware() deals gracefullt with NULL pointers so there's no
reason to test for one prior to calling the function.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
The SD8797 firmware image is shared with mwifiex driver.
Whoever gets loaded first will be responsible for firmware
downloading.
Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
It should be 'btmrvl_sdio_sd8688', of course.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
The SD8787 firmware image is shared with mwifiex driver.
downloading.
Signed-off-by: Tristan Xu <xurf@marvell.com>
Use kzalloc rather than the combination of kmalloc and memset.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
expression x,size,flags;
statement S;
-x = kmalloc(size,flags);
+x = kzalloc(size,flags);
if (x == NULL) S
-memset(x, 0, size);
// </smpl>
Acked-by: Gustavo F. Padovan <padovan@profusion.mobi>
When driver is sending a command or data and the firmware is also
sending a sleep event, sometimes it is observed that driver will
continue to send the command/data to firmware right after processing
sleep event. Once sleep event is processed driver is not supposed to
send anything because firmware is in sleep state after that. Previously
interrupt processing was done in SDIO interrupt callback handler.
Now it is done in btmrvl driver main thread to solve the
cross-sending properly.
Clone checking of ret to simplify the code.
This patch silences a compiler warning:
drivers/bluetooth/btmrvl_sdio.c: In function ‘btmrvl_sdio_verify_fw_download’:
drivers/bluetooth/btmrvl_sdio.c:80: warning: ‘fws1’ may be used uninitialized in this function
drivers/bluetooth/btmrvl_sdio.c:80: note: ‘fws1’ was declared here
Signed-off-by: Kulikov Vasiliy <segooon@gmail.com>
Reviewed-by: Dan Carpenter <error27@gmail.com>
Move btmrvl hdev registration code out of btmrvl_add_card().
New function btmrvl_register_hdev() is added.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Trivial patch which adds the __init/__exit macros to the module_init/
module_exit functions of btmrvl_sdio.c driver.
Signed-off-by: Peter Huewe <peterhuewe@gmx.de>
Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits)
tree-wide: fix misspelling of "definition" in comments
reiserfs: fix misspelling of "journaled"
doc: Fix a typo in slub.txt.
inotify: remove superfluous return code check
hdlc: spelling fix in find_pvc() comment
doc: fix regulator docs cut-and-pasteism
mtd: Fix comment in Kconfig
doc: Fix IRQ chip docs
tree-wide: fix assorted typos all over the place
drivers/ata/libata-sff.c: comment spelling fixes
fix typos/grammos in Documentation/edac.txt
sysctl: add missing comments
fs/debugfs/inode.c: fix comment typos
sgivwfb: Make use of ARRAY_SIZE.
sky2: fix sky2_link_down copy/paste comment error
tree-wide: fix typos "couter" -> "counter"
tree-wide: fix typos "offest" -> "offset"
fix kerneldoc for set_irq_msi()
spidev: fix double "of of" in comment
comment typo fix: sybsystem -> subsystem
That is "success", "unknown", "through", "performance", "[re|un]mapping"
, "access", "default", "reasonable", "[con]currently", "temperature"
, "channel", "[un]used", "application", "example","hierarchy", "therefore"
, "[over|under]flow", "contiguous", "threshold", "enough" and others.
Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com>
The auto sleep mode for btmrvl driver is not enabled by default.
This patch enables auto sleep mode when card is probed.
Check that the result of kmalloc is not NULL before dereferencing it.
The patch also replaces kmalloc + memset by kzalloc.
The semantic match that finds this problem is as follows:
// <smpl>
expression *x;
identifier f;
constant char *C;
x = \(kmalloc\|kcalloc\|kzalloc\)(...);
... when != x == NULL
when != x != NULL
when != (x || ...)
kfree(x)
f(...,C,...,x,...)
*f(...,x,...)
*x->f
// </smpl>
The driver uses "u32" for alignment check and calculation which
works only on 32-bit system. It will crash the 64-bit system.
Replace "u32" with "unsigned long" to fix this issue.
