btmrvl_add_card() function calls kthread_run that might return error
(e.g. if current thread is killed). If one tries to use the error
value as a pointer then invalid memory access oops happens.
Check kthread_run() return value, if it is an error then release resources
correctly.
TEST=boot computer with BT modules enabled. I see the error message that
BT device initialization failed. Now kernel does not crash. Hint: to enable
BT run 'rmmod btmrvl_sdio; modprobe btmrvl_sdio'
Signed-off-by: Anatol Pomozov <anatol.pomozov@gmail.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
.set_bdaddr handler is implemented for public address configuration.
A reboot restores the bdaddr to its original address.
Signed-off-by: Amitkumar Karwar <akarwar@marvell.com>
Signed-off-by: Bing Zhao <bzhao@marvell.com>
After BT_CMD_HOST_SLEEP_ENABLE command finishes, driver should
wait until getting BT_EVENT_HOST_SLEEP_ENABLE event to complete
suspend procedure.
Without this patch the suspend handler would return success
earlier. By the time when the BT_EVENT_HOST_SLEEP_ENABLE event
comes in the controller driver could have already turned off the
bus clock. This causes kernel crash or system reboot eventually.
Cc: <stable@vger.kernel.org> # 3.13+
Signed-off-by: Chin-Ran Lo <crlo@marvell.com>
Signed-off-by: Jeff CF Chen <jeffc@marvell.com>
A vendor specific command is sent to firmware during
initialization to enable this feature. This command is for
SD8897 only.
Change subcmd parameter from int to u8 to match its use:
btmrvl_send_sync_cmd(priv, BT_CMD_MODULE_CFG_REQ, &subcmd, 1);
Signed-off-by: Petri Gynther <pgynther@google.com>
Reviewed-by: Bing Zhao <bzhao@marvell.com>
Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
For SD8897, CMD52 write_to_clear may have missing interrupts
under certain corner case condition. Use CMD53 read-to-clear
to fix the problem.
If vendor specific HCI commands are received from application,
we should send corresponding events to stack.
These events should be consumed in driver, only if they are for
the internal HCI commands generated by driver.
This patch fixes the vendor command 0x3f stuck problem with
above mentioned change. For example,
hcitool cmd 3f 22 fe 06 22 21 20 43 50 00
The device tree property can define the cal-data in proper order.
There is no need to swap the bytes in driver.
Also remove the redundant cal-data memory copy after removing the
byte swapping.
Cc: Mike Frysinger <vapier@chromium.org>
Cc: Amitkumar Karwar <akarwar@marvell.com>
Signed-off-by: Hyuckjoo Lee <hyuckjoo.lee@samsung.com>
Some ARM versions of Chromebook need to download a new calibration
data from host driver to firmware. They do have EEPROM but still
need a piece of new calibration data in test mode.
The cal-data is platform dependent. It's simpler and more feasible
to use device tree based cal-data instead of configuration file
based cal-data.
This patch remove configuration file based cal-data downloading
and replace it using cal-data from device tree.
When CONFIG_OF is not selected, or the specific property is not
present in the device tree, the calibration downloading will not
happen.
Replace ogf/ocf and its packing with 16-bit opcodes.
The hdev parameter of btmrvl_send_frame() is always valid. If it were
not valid, then it would have crashed earlier in the call chain.
Instead of masking hdev inside the skb->dev parameter, hand it
directly to the driver as a parameter to hdev->send. This makes
the driver interface more clear and simpler.
This patch fixes all drivers to accept and handle the new parameter
of hdev->send callback. Special care has been taken for bpa10x
and btusb drivers that require having skb->dev set to hdev for
the URB transmit complete handlers.
The btmrvl_ioctl() function is not used and thus remove it.
A text file containing calibration data in hex format can
be provided at following path:
/lib/firmware/mrvl/sd8797_caldata.conf
The data will be downloaded to firmware during initialization.
Reviewed-by: Mike Frysinger <vapier@chromium.org>
Move initialization code to hdev's setup handler.
Replace this proprietary structure with the standard one
(struct hci_command_hdr).
Command preparation code is used multiple times. This patch
separate out this common code and create btmrvl_send_sync_cmd()
function.
There is currently a race condition in the btmrvl_remove_card() which
is causing hangs on suspend for OLPC. When the race occurs,
kthread_stop() never returns.
The problem is that btmrvl_service_main_thread() calls kthread_should_stop()
and then does a fair number of things before restarting the loop and
sleeping.
If the thread gets stopped after kthread_should_stop() is checked, but
before the sleep happens, the thread will go to sleep and won't necessarily
be woken up.
Move the kthread_should_stop() check into a race-free place.
Signed-off-by: Daniel Drake <dsd@laptop.org>
Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
Patch shortens locals scope and adds missing braces. This is a diff
between v1 which was applied and v2 of patch "Bluetooth: btmrvl: Do
not send vendor events to bluetooth stack".
Signed-off-by: Andrei Emeltchenko <andrei.emeltchenko@intel.com>
Vendor-specific events shall be processed in driver and not sent
to bluetooth stack where they screw up HCI command countings.
Host sleep is activated using already configured host sleep
parameters in suspend handler and it is cancelled in resume
handler.
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Signed-off-by: Gustavo Padovan <gustavo@padovan.org>
Currently debugfs commands "hscfgcmd" and "gpiogap" are provided
for host sleep configuration. But if user doesn't configure host
sleep parameters using these commands, host sleep activation is
failed during suspend (support for suspend and resume handlers is
added in next patch).
Default host sleep configuration is done during driver initialisation
in this patch.
The linux device model provides dev_set/get_drvdata so we can use this
to save private driver data.
This also removes several unnecessary casts.
Signed-off-by: David Herrmann <dh.herrmann@googlemail.com>
After unregistering an hci_dev object a bluetooth driver does not have
any callbacks in the hci_dev structure left over. Therefore, there is no
need to keep a reference to the module.
Previously, we needed this to protect the hci-destruct callback.
However, this callback is no longer available so we do not need this
owner field, anymore. Drivers now call hci_unregister_dev() and they
are done with the object.
The callback is optional and we provide an empty callback so remove it
entirely.
Some drivers set PF_NOFREEZE in their kthread functions which is
completely unnecessary and racy - some part of freezer code doesn't
consider cases where PF_NOFREEZE is set asynchronous to freezer
operations.
In general, there's no reason to allow setting PF_NOFREEZE explicitly.
Remove them and change the documentation to note that setting
PF_NOFREEZE directly isn't allowed.
-v2: Dropped change to twl4030-irq.c as it no longer uses PF_NOFREEZE.
Acked-by: "Gustavo F. Padovan" <padovan@profusion.mobi>
Acked-by: Samuel Ortiz <sameo@linux.intel.com>
Cc: Marcel Holtmann <marcel@holtmann.org>
Cc: wwang <wei_wang@realsil.com.cn>
HCI transport drivers may not know what type of radio an AMP device has
so only say whether they're BR/EDR or AMP devices.
Signed-off-by: David Vrabel <david.vrabel@csr.com>
Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
When driver is sending a command or data and the firmware is also
sending a sleep event, sometimes it is observed that driver will
continue to send the command/data to firmware right after processing
sleep event. Once sleep event is processed driver is not supposed to
send anything because firmware is in sleep state after that. Previously
interrupt processing was done in SDIO interrupt callback handler.
Now it is done in btmrvl driver main thread to solve the
cross-sending properly.
Get the device type from MODULE_BRINGUP_REQ command response.
Move btmrvl hdev registration code out of btmrvl_add_card().
New function btmrvl_register_hdev() is added.
The MODULE_BRINGUP_REQ command response returns success with
either 0x00 or 0x0c.
This is mostly cleanup. There is only one caller and it just checks for
non-zero return values. Still "ret" should be int because we want to return
-EINVAL on errors.
The hdev->type is misnamed and should be actually hdev->bus instead. So
convert it now.
The auto sleep mode for btmrvl driver is not enabled by default.
This patch enables auto sleep mode when card is probed.
The Marvell Bluetooth driver is full of Enter/Leave debug statements and
all of them are really pointless and only clutter the code. Seems to be
some left-overs when they ported the driver from Windows. For the Linux
driver lets remove these.
After fixing the driver to use skb_put properly for their HCI commands
only a few compiler warnings are left. Add proper casting for them.
The Marvell driver has some weird quirks on how to construct proper SKBs
with Bluetooth HCI commands. Fix it to use skb_put properly and also
use hci_opcode_pack instead of self-crafted macro.
Make the module description entries for the core and also the Marvell
SDIO driver match common practive inside the Bluetooth subsystem.
The Marvell core Bluetooth driver has various weird casting and unneeded
braces in its code that makes it hard to read. Remove all of these to
make the code a little bit simpler.
/debug/btmrvl/config/
/debug/btmrvl/status/
See Documentation/btmrvl.txt for details.
This patch incorporates a lot of comments given by
Nicolas Pitre <nico@marvell.com>. Many thanks to Nicolas Pitre.
Signed-off-by: Rahul Tank <rahult@marvell.com>
This driver provides basic definitions and library functions to
support Marvell Bluetooth enabled devices, such as 88W8688 WLAN/BT
combo chip.
