path: root/drivers/block
2006-10-03[PATCH] pr_debug: umem: repair nonexistant bh pr_debug referenceZach Brown
umem: repair nonexistant bh pr_debug reference Signed-off-by: Zach Brown <zach.brown@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] completions: lockdep annotate on stack completionsPeter Zijlstra
All on stack DECLARE_COMPLETIONs should be replaced by: DECLARE_COMPLETION_ONSTACK Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] cciss: remove unneeded spaces in output for attached volumesMetathronius Galabant
It removes the awkwards spaces after the "=" when displaying the geometry of the attached volumes. Before: cciss: using DAC cycles blocks= 286734240 block_size= 512 heads= 255, sectors= 32, cylinders= 35139 After: cciss: using DAC cycles blocks=286734240 block_size=512 heads=255, sectors=32, cylinders=35139 Signed-off-by: Metathronius Galabant <m.galabant@gmail.com> Acked-by: Mike Miller <mike.miller@hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] cciss: support for >2TB logical volumesMike Miller (OS Dev)
Add support for logical volumes >2TB. All SAS/SATA controllers support large volumes. Signed-off-by: Mike Miller <mike.miller@hp.com> Cc: Jens Axboe <axboe@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Generic booleanRichard Knutsson
This patch defines: * a generic boolean-type, named 'bool' * aliases to 0 and 1, named 'false' and 'true' Removing colliding definitions of 'bool', 'false' and 'true'. Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-30[PATCH] BLOCK: Make it possible to disable the block layer [try #6]David Howells
Make it possible to disable the block layer. Not all embedded devices require it, some can make do with just JFFS2, NFS, ramfs, etc - none of which require the block layer to be present. This patch does the following: (*) Introduces CONFIG_BLOCK to disable the block layer, buffering and blockdev support. (*) Adds dependencies on CONFIG_BLOCK to any configuration item that controls an item that uses the block layer. This includes: (*) Block I/O tracing. (*) Disk partition code. (*) All filesystems that are block based, eg: Ext3, ReiserFS, ISOFS. (*) The SCSI layer. As far as I can tell, even SCSI chardevs use the block layer to do scheduling. Some drivers that use SCSI facilities - such as USB storage - end up disabled indirectly from this. (*) Various block-based device drivers, such as IDE and the old CDROM drivers. (*) MTD blockdev handling and FTL. (*) JFFS - which uses set_bdev_super(), something it could avoid doing by taking a leaf out of JFFS2's book. (*) Makes most of the contents of linux/blkdev.h, linux/buffer_head.h and linux/elevator.h contingent on CONFIG_BLOCK being set. sector_div() is, however, still used in places, and so is still available. (*) Also made contingent are the contents of linux/mpage.h, linux/genhd.h and parts of linux/fs.h. (*) Makes a number of files in fs/ contingent on CONFIG_BLOCK. (*) Makes mm/bounce.c (bounce buffering) contingent on CONFIG_BLOCK. (*) set_page_dirty() doesn't call __set_page_dirty_buffers() if CONFIG_BLOCK is not enabled. (*) fs/no-block.c is created to hold out-of-line stubs and things that are required when CONFIG_BLOCK is not set: (*) Default blockdev file operations (to give error ENODEV on opening). (*) Makes some /proc changes: (*) /proc/devices does not list any blockdevs. (*) /proc/diskstats and /proc/partitions are contingent on CONFIG_BLOCK. (*) Makes some compat ioctl handling contingent on CONFIG_BLOCK. (*) If CONFIG_BLOCK is not defined, makes sys_quotactl() return -ENODEV if given command other than Q_SYNC or if a special device is specified. (*) In init/do_mounts.c, no reference is made to the blockdev routines if CONFIG_BLOCK is not defined. This does not prohibit NFS roots or JFFS2. (*) The bdflush, ioprio_set and ioprio_get syscalls can now be absent (return error ENOSYS by way of cond_syscall if so). (*) The seclvl_bd_claim() and seclvl_bd_release() security calls do nothing if CONFIG_BLOCK is not set, since they can't then happen. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-30[PATCH] BLOCK: Move the loop device ioctl compat stuff to the loop driver ↵David Howells
[try #6] Move the loop device ioctl compat stuff from fs/compat_ioctl.c to the loop driver so that the loop header file doesn't need to be included. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-30[PATCH] Kill various deprecated/unused block layer defines/functionsJens Axboe
Signed-off-by: Jens Axboe <axboe@suse.de>
2006-09-30[PATCH] Remove ->rq_status from struct requestJens Axboe
After Christophs SCSI change, the only usage left is RQ_ACTIVE and RQ_INACTIVE. The block layer sets RQ_INACTIVE right before freeing the request, so any check for RQ_INACTIVE in a driver is a bug and indicates use-after-free. So kill/clean the remaining users, straight forward. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-09-30[PATCH] Remove ->waiting member from struct requestJens Axboe
As the comments indicates in blkdev.h, we can fold it into ->end_io_data usage as that is really what ->waiting is. Fixup the users of blk_end_sync_rq(). Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-30[PATCH] Split struct request ->flags into two partsJens Axboe
Right now ->flags is a bit of a mess: some are request types, and others are just modifiers. Clean this up by splitting it into ->cmd_type and ->cmd_flags. This allows introduction of generic Linux block message types, useful for sending generic Linux commands to block devices. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-09-29[PATCH] loop: forward-port resource leak checks from SolarSerge E. Hallyn
Forward port of the patch by Solar and ported by Julio. Compiles, boots, and passes my looptorturetest.sh. Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Julio Auto <mindvortex@gmail.com> Cc: Solar Designer <solar@openwall.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] kthread: convert loop.c to kthreadSerge E. Hallyn
Convert loop.c from the deprecated kernel_thread to kthread. This patch simplifies the code quite a bit and passes similar testing to the previous submission on both emulated x86 and s390. Changes since last submission: switched to using a rather simple loop based on wait_event_interruptible. Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27USB: UB: Let cdrecord to see a device with media absentPete Zaitcev
The command "cdrecord dev=/dev/uba x.iso" prints nasty garbage if a blank is not in the drive. This happens because drivers have to set req->errors separately from just returning zero uptodate with end_that_request_first, end_that_request_last. These functions only set error in BIO, but sg_io() ignores it. Since we're on it, let cdrecord access a device when ->changed is set. It's useful if someone wants to know device capabilities without burning anything. Signed-Off-By: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-23Merge mulgrave-w:git/scsi-misc-2.6James Bottomley
Conflicts: drivers/scsi/iscsi_tcp.c drivers/scsi/iscsi_tcp.h Pretty horrible merge between crypto hash consolidation and crypto_digest_...->crypto_hash_... conversion Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-09-21[BLOCK] cryptoloop: Use block ciphers where applicableHerbert Xu
This patch converts cryptoloop to use the new block cipher type where applicable. As a result the ECB-specific and CBC-specific transfer functions have been merged. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-09-13[PATCH] cciss: version update, new hwMike Miller
Add support for new hardware and bumps the version to 3.6.10. It seems there were several changes introduced including soft_irq. I decided to bump the major number to reflect these changes. Since we're still supporting older vendor kernels I need some way differentiate between kernel versions <=2.6.10 and newer kernels >=2.6.16. Signed-off-by: Mike Miller <mike.miller@hp.com> Cc: Jens Axboe <axboe@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-01[PATCH] exit early in floppy_init when no floppy existsOlaf Hering
modprobe -v floppy on a Apple G5 writes incorrect stuff to dmesg: Floppy drive(s): fd0 is 2.88M The reason is that the legacy io check happens very late, when part of the floppy stuff is already initialized. check_legacy_ioport() returns either -ENODEV right away, or it walks the device-tree looking for a floppy node. Signed-off-by: Olaf Hering <olaf@aepfle.de> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-27Merge ../linux-2.6James Bottomley
2006-08-06[SCSI] Improve inquiry printingMatthew Wilcox
- Replace scsi_device_types array API with scsi_device_type function API. Gets rid of a lot of common code, as well as being easier to use. - Add the new device types in SPC4 r05a, and rename some of the older ones. - Reformat the printing of inquiry data; now fits on one line and includes PQ. I think I've addressed all the feedback from the previous versions. My current test box prints: scsi 2:0:1:0: Direct access HP 18.2G ATLAS10K3_18_SCA HP05 PQ: 0 ANSI: 2 Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-08-04[SCSI] DAC960: PCI id table fixupBrian King
The PCI ID table in the DAC960 driver conflicts with some devices that use the ipr driver. All ipr adapters that use this chip have an IBM subvendor ID and all DAC960 adapters that use this chip have a Mylex subvendor id. Signed-off-by: Brian King <brking@us.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-07-31[PATCH] nbd: Abort request on data reception failureMichal Feix
When reading from nbd device, we need to receive all the data after receiving reply packet from the server - otherwise such request will never be ended. If socket is closed right after accepting reply control packet and in the middle of waiting for read data, nbd_read_stat() returns NULL and nbd_end_request() is not called. This patch fixes it. Signed-off-by: Michal Feix <michal@feix.cz> Acked-by: Paul Clements <paul.clements@steeleye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] nbd: Check magic before doing anything elseMichal Feix
We should check magic sequence in reply packet before trying to find request with it's request handle. This also solves the problem with "Unexpected reply" message beeing logged, when packet with invalid magic is received. Signed-off-by: Michal Feix <michal@feix.cz> Acked-by: Paul Clements <paul.clements@steeleye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] lockdep: annotate pktcdvd natural device hierarchyArjan van de Ven
The pkt_*_dev functions operate on not-this-blockdevice, and that is sufficiently checked at setup time. As a result there is a natural hierarchy, which needs nesting annotations Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Peter Osterlund <petero2@telia.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-25[PATCH] cciss: fix stall with softirq handling and CFQJens Axboe
We need to postpone the queue startup until after the softirq handler has actually finished some requests, otherwise we could be racing with cciss_softirq_done() and not actually restart the queue handling. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-07-14[PATCH] drivers/block/cpqarray.c: remove an unused variableAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Mike Miller <mike.miller@hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] ramdisk blocksize Kconfig entryNathan Scott
Make the ramdisk blocksize configurable at kernel compilation time rather than only at boot or module load time, like a couple of the other ramdisk options. I found this handy awhile back but thought little of it, until recently asked by a few of the testing folks here to be able to do the same thing for their automated test setups. The Kconfig comment is largely lifted from comments in rd.c, and hopefully this will increase the chances of making folks aware that the default value often isn't a great choice here (for increasing values of PAGE_SIZE, even moreso). Signed-off-by: Nathan Scott <nathans@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] aoe: cleanup i_rdev usageEric Sesterhenn
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpcLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: powerpc: add defconfig for Freescale MPC8349E-mITX board powerpc: Add base support for the Freescale MPC8349E-mITX eval board Documentation: correct values in MPC8548E SEC example node [POWERPC] Actually copy over i8259.c to arch/ppc/syslib this time [POWERPC] Add new interrupt mapping core and change platforms to use it [POWERPC] Copy i8259 code back to arch/ppc [POWERPC] New device-tree interrupt parsing code [POWERPC] Use the genirq framework [PATCH] genirq: Allow fasteoi handler to retrigger disabled interrupts [POWERPC] Update the SWIM3 (powermac) floppy driver [POWERPC] Fix error handling in detecting legacy serial ports [POWERPC] Fix booting on Momentum "Apache" board (a Maple derivative) [POWERPC] Fix various offb and BootX-related issues [POWERPC] Add a default config for 32-bit CHRP machines [POWERPC] fix implicit declaration on cell. [POWERPC] change get_property to return void *
2006-07-03[PATCH] lockdep: floppy.c irq release fixIngo Molnar
The lock validator triggered a number of bugs in the floppy driver, all related to the floppy driver allocating and freeing irq and dma resources from interrupt context. The initial solution was to use schedule_work() to push this into process context, but this caused further problems: for example the current floppy driver in -mm2 is totally broken and all floppy commands time out with an error. (as reported by Barry K. Nathan) This patch tries another solution: simply get rid of all that dynamic IRQ and DMA allocation/freeing. I doubt it made much sense back in the heydays of floppies (if two devices raced for DMA or IRQ resources then we didnt handle those cases too gracefully anyway), and today it makes near zero sense. So the new code does the simplest and most straightforward thing: allocate IRQ and DMA resources at module init time, and free them at module removal time. Dont try to release while the driver is operational. This, besides making the floppy driver functional again has an added bonus, floppy IRQ stats are finally persistent and visible in /proc/interrupts: 6: 63 XT-PIC-level floppy Besides normal floppy IO i have also tested IO error handling, motor-off timeouts, etc. - and everything seems to be working fine. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[POWERPC] Update the SWIM3 (powermac) floppy driverBenjamin Herrenschmidt
Port the PowerMac floppy driver (swim3) to use the macio device infrastructure. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-07-02[PATCH] irq-flags: drivers/block Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jens Axboe <axboe@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-01[PATCH] drivers/block/nbd.c compile fixIngo van Lil
The Network Block Device driver doesn't compile if NDEBUG is defined. Signed-off-by: Ingo van Lil <inguin@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/devfs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/devfs-2.6: (22 commits) [PATCH] devfs: Remove it from the feature_removal.txt file [PATCH] devfs: Last little devfs cleanups throughout the kernel tree. [PATCH] devfs: Rename TTY_DRIVER_NO_DEVFS to TTY_DRIVER_DYNAMIC_DEV [PATCH] devfs: Remove the tty_driver devfs_name field as it's no longer needed [PATCH] devfs: Remove the line_driver devfs_name field as it's no longer needed [PATCH] devfs: Remove the videodevice devfs_name field as it's no longer needed [PATCH] devfs: Remove the gendisk devfs_name field as it's no longer needed [PATCH] devfs: Remove the miscdevice devfs_name field as it's no longer needed [PATCH] devfs: Remove the devfs_fs_kernel.h file from the tree [PATCH] devfs: Remove devfs_remove() function from the kernel tree [PATCH] devfs: Remove devfs_mk_cdev() function from the kernel tree [PATCH] devfs: Remove devfs_mk_bdev() function from the kernel tree [PATCH] devfs: Remove devfs_mk_symlink() function from the kernel tree [PATCH] devfs: Remove devfs_mk_dir() function from the kernel tree [PATCH] devfs: Remove devfs_*_tape() functions from the kernel tree [PATCH] devfs: Remove devfs support from the sound subsystem [PATCH] devfs: Remove devfs support from the ide subsystem. [PATCH] devfs: Remove devfs support from the serial subsystem [PATCH] devfs: Remove devfs from the init code [PATCH] devfs: Remove devfs from the partition code ...
2006-06-29Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6: [PATCH] i386: export memory more than 4G through /proc/iomem [PATCH] 64bit Resource: finally enable 64bit resource sizes [PATCH] 64bit Resource: convert a few remaining drivers to use resource_size_t where needed [PATCH] 64bit resource: change pnp core to use resource_size_t [PATCH] 64bit resource: change pci core and arch code to use resource_size_t [PATCH] 64bit resource: change resource core to use resource_size_t [PATCH] 64bit resource: introduce resource_size_t for the start and end of struct resource [PATCH] 64bit resource: fix up printks for resources in misc drivers [PATCH] 64bit resource: fix up printks for resources in arch and core code [PATCH] 64bit resource: fix up printks for resources in pcmcia drivers [PATCH] 64bit resource: fix up printks for resources in video drivers [PATCH] 64bit resource: fix up printks for resources in ide drivers [PATCH] 64bit resource: fix up printks for resources in mtd drivers [PATCH] 64bit resource: fix up printks for resources in pci core and hotplug drivers [PATCH] 64bit resource: fix up printks for resources in networks drivers [PATCH] 64bit resource: fix up printks for resources in sound drivers [PATCH] 64bit resource: C99 changes for struct resource declarations Fixed up trivial conflict in drivers/ide/pci/cmd64x.c (the printk that was changed by the 64-bit resources had been deleted in the meantime ;)
2006-06-29[PATCH] Deref in drivers/block/paride/pf.cEric Sesterhenn
Another possible dereference detected by coverity (id #759). pf_probe() might call pf_identify() which might call get_capacity() which dereferences pf->disk Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-28[PATCH] mark address_space_operations constChristoph Hellwig
Same as with already do with the file operations: keep them in .rodata and prevents people from doing runtime patching. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] 64bit resource: fix up printks for resources in misc driversGreg Kroah-Hartman
This is needed if we wish to change the size of the resource structures. Based on an original patch from Vivek Goyal <vgoyal@in.ibm.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[PATCH] devfs: Last little devfs cleanups throughout the kernel tree.Greg Kroah-Hartman
Just removes a few unused #defines and fixes some comments due to devfs now being gone. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[PATCH] devfs: Remove the gendisk devfs_name field as it's no longer neededGreg Kroah-Hartman
And remove the now unneeded number field. Also fixes all drivers that set these fields. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[PATCH] devfs: Remove the miscdevice devfs_name field as it's no longer neededGreg Kroah-Hartman
Also fixes all drivers that set this field. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[PATCH] devfs: Remove the devfs_fs_kernel.h file from the treeGreg Kroah-Hartman
Also fixes up all files that #include it. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[PATCH] devfs: Remove devfs_remove() function from the kernel treeGreg Kroah-Hartman
Removes the devfs_remove() function and all callers of it. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[PATCH] devfs: Remove devfs_mk_cdev() function from the kernel treeGreg Kroah-Hartman
Removes the devfs_mk_cdev() function and all callers of it. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[PATCH] devfs: Remove devfs_mk_bdev() function from the kernel treeGreg Kroah-Hartman
Removes the devfs_mk_bdev() function and all callers of it. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[PATCH] devfs: Remove devfs_mk_dir() function from the kernel treeGreg Kroah-Hartman
Removes the devfs_mk_dir() function and all callers of it. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26Revert "[PATCH] kthread: update loop.c to use kthread"Linus Torvalds
This reverts commit c7b2eff059fcc2d1b7085ee3d84b79fd657a537b. Hugh Dickins explains: "It seems too little tested: "losetup -d /dev/loop0" fails with EINVAL because nothing sets lo_thread; but even when you patch loop_thread() to set lo->lo_thread = current, it can't survive more than a few dozen iterations of the loop below (with a tmpfs mounted on /tst): j=0 cp /dev/zero /tst while : do let j=j+1 echo "Doing pass $j" losetup /dev/loop0 /tst/zero mkfs -t ext2 -b 1024 /dev/loop0 >/dev/null 2>&1 mount -t ext2 /dev/loop0 /mnt umount /mnt losetup -d /dev/loop0 done it collapses with failed ioctl then BUG_ON(!bio). I think the original lo_done completion was more subtle and safe than the kthread conversion has allowed for." Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] CCISS: tidy up product table indentationBjorn Helgaas
Make each one fit on a line so it's easier to read. I re-ordered COMPAQ_CISSC/0x4091, which was out of order. I double-checked these, but it would be good if you'd also check them to make sure I didn't miss any. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Jeff Garzik <jeff@garzik.org> Acked-by: Mike Miller <mike.miller@hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
