path: root/drivers/block
2008-01-24Kobject: convert drivers/* from kobject_unregister() to kobject_put()Greg Kroah-Hartman
There is no need for kobject_unregister() anymore, thanks to Kay's kobject cleanup changes, so replace all instances of it with kobject_put(). Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24Driver core: convert block from raw kobjects to core devicesKay Sievers
This moves the block devices to /sys/class/block. It will create a flat list of all block devices, with the disks and partitions in one directory. For compatibility /sys/block is created and contains symlinks to the disks. /sys/class/block |-- sda -> ../../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda |-- sda1 -> ../../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda/sda1 |-- sda10 -> ../../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda/sda10 |-- sda5 -> ../../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda/sda5 |-- sda6 -> ../../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda/sda6 |-- sda7 -> ../../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda/sda7 |-- sda8 -> ../../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda/sda8 |-- sda9 -> ../../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda/sda9 `-- sr0 -> ../../devices/pci0000:00/0000:00:1f.2/host1/target1:0:0/1:0:0:0/block/sr0 /sys/block/ |-- sda -> ../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda `-- sr0 -> ../devices/pci0000:00/0000:00:1f.2/host1/target1:0:0/1:0:0:0/block/sr0 Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24Kobject: change drivers/block/pktcdvd.c to use kobject_init_and_addGreg Kroah-Hartman
Stop using kobject_register, as this way we can control the sending of the uevent properly, after everything is properly initialized. Cc: Jens Axboe <axboe@kernel.dk> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24pktcdvd: Convert from class_device to device for block/pktcdvdTony Jones
struct class_device is going away, this converts the code to use struct device instead. Signed-off-by: Tony Jones <tonyj@suse.de> Cc: Peter Osterlund <petero2@telia.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24paride: Convert from class_device to device for block/parideTony Jones
struct class_device is going away, this converts the code to use struct device instead. Signed-off-by: Tony Jones <tonyj@suse.de> Cc: Tim Waugh <tim@cyberelk.net> Cc: Jens Axboe <axboe@kernel.dk> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24aoechr: Convert from class_device to deviceTony Jones
Signed-off-by: Tony Jones <tonyj@suse.de> Cc: Jens Axboe <axboe@kernel.dk> Cc: Sam Hopkins <sah@coraid.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-14cciss: section mismatchRandy Dunlap
Mark cciss_pci_init() as __devinit, to fix section mismatch warning. WARNING: vmlinux.o(.text+0x601fc9): Section mismatch: reference to .init.text: (between 'cciss_pci_init' and 'cciss_getgeometry') Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: <mike.miller@hp.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-11loop: fix bad bio_alloc() nr_iovec requestJens Axboe
Don't allocate room for an iovec when it is not needed. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-12-18Cleanup umem driver: fix most checkpatch warnings, conform to kernelRandy Dunlap
coding style. linux-2.6.24-rc5-git3> checkpatch.pl-next patches/block-umem-ckpatch.patch total: 0 errors, 5 warnings, 530 lines checked All of these are line-length warnings. Only change in generated object file is due to not initializing a static global variable to 0. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-12-17pktcdvd: add kobject_put when kobject register failsDave Young
In kobject_register, the kobject reference is get in kobject_init, and then kobject_add. If kobject_add fail, it will only cleanup the reference got by itself. Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Reviewed-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Greg KH <greg@kroah.com> Cc: Peter Osterlund <petero2@telia.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-10Fix NULL dereference in umem.cNeil Brown
Fix NULL dereference in umem.c Signed-off-by: Neil Brown <neilb@suse.de> Tested-by: Dave Chinner <dgc@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-10aoe: properly initialise the request_queue's backing_dev_infoAndrew Morton
AOE forgot to initialise its queue's backing_dev_info, so kernels crash. (http://bugzilla.kernel.org/show_bug.cgi?id=9482) Fix that and consoldate aoeblk_gdalloc()'s error handling. Thanks be to Jon for reporting and testing. Cc: "Ed L. Cashin" <ecashin@coraid.com> Cc: <stable@kernel.org> Cc: "Jon Nelson" <jnelson@jamponi.net> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-19virtio: fix module/device unloadingRusty Russell
The virtio code never hooked through the ->remove callback. Although noone supports device removal at the moment, this code is already needed for module unloading. This of course also revealed bugs in virtio_blk, virtio_net and lguest unloading paths. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2007-11-14rd: fix data corruption on memory pressureChristian Borntraeger
We have seen ramdisk based install systems, where some pages of mapped libraries and programs were suddendly zeroed under memory pressure. This should not happen, as the ramdisk avoids freeing its pages by keeping them dirty all the time. It turns out that there is a case, where the VM makes a ramdisk page clean, without telling the ramdisk driver. On memory pressure shrink_zone runs and it starts to run shrink_active_list. There is a check for buffer_heads_over_limit, and if true, pagevec_strip is called. pagevec_strip calls try_to_release_page. If the mapping has no releasepage callback, try_to_free_buffers is called. try_to_free_buffers has now a special logic for some file systems to make a dirty page clean, if all buffers are clean. Thats what happened in our test case. The simplest solution is to provide a noop-releasepage callback for the ramdisk driver. This avoids try_to_free_buffers for ramdisk pages. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Acked-by: Nick Piggin <npiggin@suse.de> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-14paride: pf driver fixesOndrej Zary
The pf driver for parallel port floppy drives seems to be broken. At least with Imation SuperDisk with EPAT chip, the driver calls pi_connect() and pi_disconnect after each transferred sector. At least with EPAT, this operation is very expensive - causes drive recalibration. Thus, transferring even a single byte (dd if=/dev/pf0 of=/dev/null bs=1 count=1) takes 20 seconds, making the driver useless. The pf_next_buf() function seems to be broken as it returns 1 always (except when pf_run is non-zero), causing the loop in do_pf_read_drq (and do_pf_write_drq) to be executed only once. The following patch fixes this problem. It also fixes swapped descriptions in pf_lock() function and removes DBMSG macro, which seems useless. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-12[NET]: Add the helper kernel_sock_shutdown()Trond Myklebust
...and fix a couple of bugs in the NBD, CIFS and OCFS2 socket handlers. Looking at the sock->op->shutdown() handlers, it looks as if all of them take a SHUT_RD/SHUT_WR/SHUT_RDWR argument instead of the RCV_SHUTDOWN/SEND_SHUTDOWN arguments. Add a helper, and then define the SHUT_* enum to ensure that kernel users of shutdown() don't get confused. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Mark Fasheh <mark.fasheh@oracle.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-08pktcdvd: fix BUG caused by sysfs module reference semantics changeTejun Heo
pkt_setup_dev() expects module reference to be held on invocation. This used to be true for sysfs callbacks but not anymore. Test and grab module reference around pkt_setup_dev() in class_pktcdvd_store_add(). Signed-off-by: Tejun Heo <htejun@gmail.com> Acked-by: Peter Osterlund <petero2@telia.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-11-05paride: fix 'and' typo in drivers/block/paride/pt.cRoel Kluin
Fix 'and' typo (PT_WRITE_OK is defined 2) Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-29cciss: update copyright noticesMike Miller
This patch updates the copyright information for the cciss driver. It includes extending the year to 2007 (how timely) and some minor corrections deemed necessary by HP legal and the Open Source Review Board. Please consider this patch for inclusion. Signed-off-by: Mike Miller <mike.miller@hp.com> -------------------------------------------------------------------------------- Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-25ub: add sg_init_table for sense and read capacity commandsFUJITA Tomonori
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-24SG: audit of drivers that use blk_rq_map_sg()Jens Axboe
They need to properly init the sg table, or blk_rq_map_sg() will complain if CONFIG_DEBUG_SG is set. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-24SG: Change sg_set_page() to take length and offset argumentJens Axboe
Most drivers need to set length and offset as well, so may as well fold those three lines into one. Add sg_assign_page() for those two locations that only needed to set the page, where the offset/length is set outside of the function context. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-24More SG build fixesDavid Miller
Signed-off-by: Jens Axboe <axboe@carl.home.kernel.dk>
2007-10-23[PATCH] Fix breakage after SG cleanupsRalf Baechle
Commits 58b053e4ce9d2fc3023645c1b96e537c72aa8d9a ("Update arch/ to use sg helpers") 45711f1af6eff1a6d010703b4862e0d2b9afd056 ("[SG] Update drivers to use sg helpers") fa05f1286be25a8ce915c5dd492aea61126b3f33 ("Update net/ to use sg helpers") converted many files to use the scatter gather helpers without ensuring that the necessary headerfile <linux/scatterlist> is included. This happened to work for ia64, powerpc, sparc64 and x86 because they happened to drag in that file via their <asm/dma-mapping.h>. On most of the others this probably broke. Instead of increasing the header file spider web I choose to include <linux/scatterlist.h> directly into the affectes files. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-23Remove old lguest bus and drivers.Rusty Russell
This gets rid of the lguest bus, drivers and DMA mechanism, to make way for a generic virtio mechanism. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2007-10-23Block driver using virtio.Rusty Russell
The block driver uses scatter-gather lists with sg[0] being the request information (struct virtio_blk_outhdr) with the type, sector and inbuf id. The next N sg entries are the bio itself, then the last sg is the status byte. Whether the N entries are in or out depends on whether it's a read or a write. We accept the normal (SCSI) ioctls: they get handed through to the other side which can then handle it or reply that it's unsupported. It's not clear that this actually works in general, since I don't know if blk_pc_request() requests have an accurate rq_data_dir(). Although we try to reply -ENOTTY on unsupported commands, ioctl(fd, CDROMEJECT) returns success to userspace. This needs a separate patch. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <jens.axboe@oracle.com>
2007-10-22[SG] Update drivers to use sg helpersJens Axboe
2007-10-20remove unused return within void return functionDenis Cheng
Signed-off-by: Denis Cheng <crquan@gmail.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-20remove duplicate MMAPPER Kconfig optionAdrian Bunk
This option is already in arch/um/Kconfig.char Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Jeff Dike <jdike@addtoit.com>
2007-10-19Convert files to UTF-8 and some cleanupsJan Engelhardt
* Convert files to UTF-8. * Also correct some people's names (one example is Eißfeldt, which was found in a source file. Given that the author used an ß at all in a source file indicates that the real name has in fact a 'ß' and not an 'ss', which is commonly used as a substitute for 'ß' when limited to 7bit.) * Correct town names (Goettingen -> Göttingen) * Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313) Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19Fix misspellings of "system", "controller", "interrupt" and "necessary".Robert P. J. Day
Fix the various misspellings of "system", controller", "interrupt" and "[un]necessary". Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19fix typos in drivers/block/KconfigPatrick Ringl
2007-10-19Use helpers to obtain task pid in printksPavel Emelyanov
The task_struct->pid member is going to be deprecated, so start using the helpers (task_pid_nr/task_pid_vnr/task_pid_nr_ns) in the kernel. The first thing to start with is the pid, printed to dmesg - in this case we may safely use task_pid_nr(). Besides, printks produce more (much more) than a half of all the explicit pid usage. [akpm@linux-foundation.org: git-drm went and changed lots of stuff] Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Dave Airlie <airlied@linux.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18Add missing newlines to some uses of dev_<level> messagesJoe Perches
Found these while looking at printk uses. Add missing newlines to dev_<level> uses Add missing KERN_<level> prefixes to multiline dev_<level>s Fixed a wierd->weird spelling typo Added a newline to a printk Signed-off-by: Joe Perches <joe@perches.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Mark M. Hoffman <mhoffman@lightlink.com> Cc: Roland Dreier <rolandd@cisco.com> Cc: Tilman Schmidt <tilman@imap.cc> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Stephen Hemminger <shemminger@linux-foundation.org> Cc: Greg KH <greg@kroah.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Cc: James Smart <James.Smart@Emulex.Com> Cc: Andrew Vasquez <andrew.vasquez@qlogic.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Merge branch 'for-linus' of git://git.kernel.dk/data/git/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/data/git/linux-2.6-block: [SCSI] Remove full sg table memset() [SCSI] ide-scsi: remove usage of sg_last() Fix loop terminating conditions in fill_sg(). [BLOCK] Clear sg entry before filling in blk_rq_map_sg() IA64: iommu uses sg_next with an invalid sg element cciss: disable DMA refetch on Smart Array P600 swiotlb: fix map_sg failure handling SPARC64: fix iommu sg chaining [SCSI] ide-scsi: use scsi_sg_count() instead of ->use_sg
2007-10-17floppy: remove register keyword use from floppy driverJesper Juhl
The floppy drive is slow. These days I see absolutely no good reason why the floppy driver should try to gain a tiny bit of speed by telling gcc to optimize access to some variables via the register keyword. Better to just leave gcc free to do whatever optimizations it deduces to be sane and not hamper it by telling it that some variables in the floppy driver are special and need to be fast (they don't). Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17floppy: remove dead/commented out code from floppy driverJesper Juhl
A good initial step for a cleanup seems to me to be getting rid of old dead code. This stuff is either commented out or inside '#if 0' so it is not currently in use at all, let's just get rid of it once and for all. That's a few lines less to deal with. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17floppy: do a very minimal style cleanup of the floppy driverJesper Juhl
Yes, some of this will likely be replaced in later patches, but I do not see anyone else coming out of the woodwork with any patches for this driver, so I'll ignore comments about churn. I want to get this driver cleaned up, and if I'm going to do so I want to start with this basic style cleanup to reduce the reading pain a bit. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Remove final traces of long-deprecated "ramdisk" kernel parmRobert P. J. Day
Since the "ramdisk" kernel parameter has been officially deprecated since at least 2.6.18, might as well finally get rid of it. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17drivers/block/cciss.c: fix check-after-useAdrian Bunk
The Coverity checker spotted that we have already oops'ed if "disk" was NULL. Since "disk" being NULL seems impossible at this point this patch removes the NULL check. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Mike Miller <mike.miller@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17cciss: fix error reporting for SG_IOSteve Cameron
This fixes a problem with the way cciss was filling out the "errors" field of the request structure upon completion of requests. Previously, it just put a 1 or a 0 in there and used the negation of this as the uptodate parameter to one of the functions in the block layer, being a block device. For the SG_IO ioctl, this was not sufficient, and we noticed that, for example, sg_turs from sg3_utils did not correctly detect problems due to cciss having set rq->errors incorrectly. Signed-off-by: Stephen M. Cameron <steve.cameron@hp.com> Acked-by: Mike Miller <mike.miller@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17NBD: allow hung network I/O to be cancelledPaul Clements
Allow NBD I/O to be cancelled when a network outage occurs. Previously, I/O would just hang, and if enough I/O was hung in nbd, the system (at least user-level) would completely hang until a TCP timeout (default, 15 minutes) occurred. The patch introduces a new ioctl NBD_SET_TIMEOUT that allows a transmit timeout value (in seconds) to be specified. Any network send that exceeds the timeout will be cancelled and the nbd connection will be shut down. I've tested with various timeout values and 6 seconds seems to be a good choice for the timeout. If the NBD_SET_TIMEOUT ioctl is not called, you get the old (I/O hang) behavior. Signed-off-by: Paul Clements <paul.clements@steeleye.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17NBD: set uninitialized devices to size 0Paul Clements
This fixes errors with utilities (such as LVM's vgscan) that try to scan all devices. Previously this would generate read errors when uninitialized nbd devices were scanned: # vgscan Reading all physical volumes. This may take a while... /dev/nbd0: read failed after 0 of 1024 at 0: Input/output error /dev/nbd0: read failed after 0 of 1024 at 509804544: Input/output error /dev/nbd0: read failed after 0 of 2048 at 0: Input/output error /dev/nbd1: read failed after 0 of 1024 at 509804544: Input/output error /dev/nbd1: read failed after 0 of 2048 at 0: Input/output error From now on, uninitialized nbd devices will have size zero, which prevents these errors. Signed-off-by: Paul Clements <paul.clements@steeleye.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17floppy: tolerate DMA channel unavailabilityJan Beulich
The floppy driver is already written to be able to operate in virtual DMA mode. Thus it can easily be adjusted to tolerate failure from fd_request_dma() as long as virtual DMA mode is not disallowed. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17aoe: remove unecessary wrapper functionEd L. Cashin
We can just use skb_mac_header now, and we don't need a wrapper function to perform the cast. Instead of requiring the reader to check aoe.h to look up what an aoe_hdr function does, I'd rather do without it. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Remove unneeded lock_kernel() in driver/block/loop.cDiego Woitasen
Signed-off-by: Diego Woitasen <diego@woitasen.com.ar> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17nbd: change a parameter's type to remove a memcpy callDenis Cheng
This memcpy looks so strange, in fact it's merely a pointer dereference, so I change the parameter's type to refer it more directly, this could make the memcpy not needed anymore. In the function nbd_read_stat where nbd_find_request is only once called, the parameter served should be transformed accordingly. Signed-off-by: Denis Cheng <crquan@gmail.com> Cc: Paul Clements <paul.clements@steeleye.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17nbd: use list_for_each_entry_safe to make it more consolidated and readableDenis Cheng
Thus the traverse of the loop may delete nodes, use the safe version. Signed-off-by: Denis Cheng <crquan@gmail.com> Cc: Paul Clements <paul.clements@steeleye.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17mm: bdi init hooksPeter Zijlstra
provide BDI constructor/destructor hooks [akpm@linux-foundation.org: compile fix] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17cciss: disable DMA refetch on Smart Array P600Mike Miller (OS Dev)
This patch disables DMA refetch in the PCI bridge. We have disabled DMA prefetch for quite some time. Testing with XEN revealed another ASIC bug. If dom0 resides on a P600 the board can can an MCA bi accessing invalid memory addresses. Apparently, we need to disable both prefetch and refetch. My understanding is a refetch operation should not occur but it is a valid thing to do if prefetched data is no longer available for whatever reason. Please consider this patch for inclusion. Signed-off-by: Mike Miller <mike.miller@hp.com> Signed-off-by: Alex Chiang <achiang@hp.com> -------------------------------------------------------------------------------- Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
