path: root/drivers/block
2008-12-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: lguest: struct device - replace bus_id with dev_name() lguest: move the initial guest page table creation code to the host kvm-s390: implement config_changed for virtio on s390 virtio_console: support console resizing virtio: add PCI device release() function virtio_blk: fix type warning virtio: block: dynamic maximum segments virtio: set max_segment_size and max_sectors to infinite. virtio: avoid implicit use of Linux page size in balloon interface virtio: hand virtio ring alignment as argument to vring_new_virtqueue virtio: use KVM_S390_VIRTIO_RING_ALIGN instead of relying on pagesize virtio: use LGUEST_VRING_ALIGN instead of relying on pagesize virtio: Don't use PAGE_SIZE for vring alignment in virtio_pci. virtio: rename 'pagesize' arg to vring_init/vring_size virtio: Don't use PAGE_SIZE in virtio_pci.c virtio: struct device - replace bus_id with dev_name(), dev_set_name() virtio-pci queue allocation not page-aligned
2008-12-30virtio_blk: fix type warningRandy Dunlap
Fix parameter type warning: linux-next-20081126/drivers/block/virtio_blk.c:307: warning: large integer implicitly truncated to unsigned type Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-12-30virtio: block: dynamic maximum segmentsRusty Russell
Enhance the driver to handle whatever maximum segment number the host tells us to handle. Do to this, we need to allocate the scatterlist dynamically. We set max_phys_segments and max_hw_segments to the same value (1 if the host doesn't tell us, since that's safest and all known hosts do tell us). Note that kmalloc'ing the structure for large sg_elems might be problematic: the fix for this is sg_table, but that requires more work. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-12-30virtio: set max_segment_size and max_sectors to infinite.Rusty Russell
Setting max_segment_size allows more than 64k per sg element, unless the host specified a limit. Setting max_sectors indicates that our max_hw_segments is the only limit. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-12-29cciss: simplify parameters to deregister_disk functionStephen M. Cameron
Simplify parameters to deregister_disk function. Signed-off-by: Stephen M. Cameron <scameron@beardog.cca.cpqcorp.net> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-12-29loop: Do not call loop_unplug for not configured loop device.Milan Broz
In loop_unplug() function is expected that mapping is set and lo->lo_backing_file is not NULL. Unfortunately loop_set_fd() set the request queue unplug function, but loop_clr_fd() doesn't clear that. Loop device allows open of non-configured loop in some situations. If the unplug on request queue is called, loop module oopses because of missing lo_backing_file. Simple reproducer: losetup /dev/loop0 /xxx losetup -d /dev/loop0 dmsetup create x --table "0 1 linear /dev/loop0 0" EIP is at loop_unplug+0x1d/0x3b ... Call Trace: blk_unplug+0x57/0x5e dm_table_unplug_all+0x34/0x77 [dm_mod] destroy_inode+0x27/0x38 generic_delete_inode+0xd5/0xd9 iput+0x4b/0x4e dm_resume+0xca/0xfe [dm_mod] dev_suspend+0x143/0x165 [dm_mod] dm_ctl_ioctl+0x18e/0x1cf [dm_mod] dev_suspend+0x0/0x165 [dm_mod] dm_ctl_ioctl+0x0/0x1cf [dm_mod] vfs_ioctl+0x22/0x69 do_vfs_ioctl+0x39d/0x3c7 trace_hardirqs_on+0xb/0xd remove_vma+0x50/0x56 do_munmap+0x21c/0x237 sys_ioctl+0x2c/0x45 sysenter_do_call+0x12/0x31 Several reports here http://www.kerneloops.org/search.php?search=loop_unplug Fix it by simply clear unplug function together with removing of backing file. Signed-off-by: Milan Broz <mbroz@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-12-29loop: Flush possible running bios when loop device is released.Milan Broz
When there are still queued bios and reference count drops to zero, loop device must flush all queued bios. Otherwise it can lead to situation that caller closes the device, but some bios are still running and endio() function call later OOpses when uses unallocated mempool. This happens for example when running dm-crypt over loop, here is typical oops backtrace: Oops: 0000 [#1] PREEMPT SMP EIP is at mempool_free+0x12/0x6b ... crypt_dec_pending+0x50/0x54 [dm_crypt] crypt_endio+0x9f/0xa7 [dm_crypt] crypt_endio+0x0/0xa7 [dm_crypt] bio_endio+0x2b/0x2e loop_thread+0x37a/0x3b1 do_lo_send_aops+0x0/0x165 autoremove_wake_function+0x0/0x33 loop_thread+0x0/0x3b1 kthread+0x3b/0x61 kthread+0x0/0x61 kernel_thread_helper+0x7/0x10 (But crash is reproducible with different dm targets running over loop device too.) Patch fixes it by flushing the bios in release call, reusing the flush mechanism for switching backing store. Signed-off-by: Milan Broz <mbroz@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-12-29nbd: tell the block layer that it is not a rotational deviceJens Axboe
Then we can get rid of that manual elevator type fiddling. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-12-29block: get rid of elevator_t typedefJens Axboe
Just use struct elevator_queue everywhere instead. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-12-29cciss: switch to using hlist for command list managementJens Axboe
This both cleans up the code and also helps detect the spurious case of a command attempted being removed from a queue it doesn't belong to. Acked-by: Mike Miller <mike.miller@hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-12-29xen-blkfront: set queue paravirt flagFernando Luis Vázquez Cao
Xen's blkfront sets noop as the default I/O scheduler at initialization time to avoid elevator overheads such as idling, but with the advent of basic disk profiling capabilities this is not necessary anymore. We should just tell the block layer that we are a paravirt front-end driver and the elevator will automatically make the necessary adjustments. Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-12-29virtio_blk: set queue paravirt flagFernando Luis Vázquez Cao
As a paravirt front-end driver, virtio_blk is not a rotational device so we want do avoid idling in AS/CFQ. Tell the block layer about this. Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-12-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1429 commits) net: Allow dependancies of FDDI & Tokenring to be modular. igb: Fix build warning when DCA is disabled. net: Fix warning fallout from recent NAPI interface changes. gro: Fix potential use after free sfc: If AN is enabled, always read speed/duplex from the AN advertising bits sfc: When disabling the NIC, close the device rather than unregistering it sfc: SFT9001: Add cable diagnostics sfc: Add support for multiple PHY self-tests sfc: Merge top-level functions for self-tests sfc: Clean up PHY mode management in loopback self-test sfc: Fix unreliable link detection in some loopback modes sfc: Generate unique names for per-NIC workqueues 802.3ad: use standard ethhdr instead of ad_header 802.3ad: generalize out mac address initializer 802.3ad: initialize ports LACPDU from const initializer 802.3ad: remove typedef around ad_system 802.3ad: turn ports is_individual into a bool 802.3ad: turn ports is_enabled into a bool 802.3ad: make ntt bool ixgbe: Fix set_ringparam in ixgbe to use the same memory pools. ... Fixed trivial IPv4/6 address printing conflicts in fs/cifs/connect.c due to the conversion to %pI (in this networking merge) and the addition of doing IPv6 addresses (from the earlier merge of CIFS).
2008-12-25Merge branch 'next' into for-linusJames Morris
2008-12-19cciss: fix problem that deleting multiple logical drives could cause a panicStephen M. Cameron
Fix problem that deleting multiple logical drives could cause a panic. It fixes a panic which can be easily reproduced in the following way: Just create several "arrays," each with multiple logical drives via hpacucli, then delete the first array, and it will blow up in deregister_disk(), in the call to get_host() when it tries to dig the hba pointer out of a NULL queue pointer. The problem has been present since my code to make rebuild_lun_table behave better went in. Signed-off-by: Stephen M. Cameron <scameron@beardog.cca.cpqcorp.net> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-12-15Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/e1000e/ich8lan.c
2008-12-10pktcdvd: remove broken dev_t export of class devicesKay Sievers
The pktcdvd created class devices only export some sysfs files, but have no char dev_t registered in the driver. At class device creation time they copy the dev_t value of the block device to the char device, wich will register a new char device in the driver core and userspace, with a conflicting dev_t value. In many cases the class devices dev_t just points to a random USB device. This fixes the sysfs "duplicate entry" errors. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Acked-by: Peter Osterlund <petero2@telia.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-04[PATCH] fix bogus argument of blkdev_put() in pktcdvdAl Viro
final close of ->bdev should match the initial open, i.e. get FMODE_READ | FMODE_NDELAY; FMODE_READ|FMODE_WRITE has been a braino. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-12-04Merge branch 'master' into nextJames Morris
Conflicts: fs/nfsd/nfs4recover.c Manually fixed above to use new creds API functions, e.g. nfs4_save_creds(). Signed-off-by: James Morris <jmorris@namei.org>
2008-12-02Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/ixgbe/ixgbe_main.c drivers/net/smc91x.c
2008-11-30Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: powerpc: Fix system calls on Cell entered with XER.SO=1 powerpc/cell: Fix GDB watchpoints, again powerpc/mpic: Don't reset affinity for secondary MPIC on boot powerpc/cell/axon-msi: Retry on missing interrupt powerpc: Fix boot freeze on machine with empty memory node powerpc: Fix IRQ assignment for some PCIe devices powerpc/spufs: Fix spinning in spufs_ps_fault on signal powerpc/mpc832x_rdb: fix swapped ethernet ids powerpc: Use generic PHY driver for Marvell 88E1111 PHY on GE Fanuc SBC610 powerpc/85xx: L2 cache size wrong in 8572DS dts powerpc/virtex: Update defconfigs powerpc/52xx: update defconfigs xsysace: Fix driver to use resource_size_t instead of unsigned long powerpc/virtex: fix various format/casting printk mismatches powerpc/mpc5200: fix bestcomm Kconfig dependencies powerpc/44x: Fix 460EX/460GT machine check handling powerpc/40x: Limit allocable DRAM during early mapping
2008-11-25aoe: remove private mac address format functionHarvey Harrison
Add %pm to omit the colons when printing a mac address. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-24Merge branch 'merge' of git://git.secretlab.ca/git/linux-2.6-mpc52xx into mergePaul Mackerras
2008-11-19cciss: fix DEBUG printk formatsRandy Dunlap
Fix printk format warnings when CCISS_DEBUG is defined. drivers/block/cciss.c:2856: warning: format '%d' expects type 'int', but argument 2 has type 'long unsigned int' drivers/block/cciss.c:3205: warning: format '%x' expects type 'unsigned int', but argument 2 has type 'long unsigned int' drivers/block/cciss.c:3236: warning: format '%x' expects type 'unsigned int', but argument 2 has type '__u64' drivers/block/cciss.c:3246: warning: format '%x' expects type 'unsigned int', but argument 2 has type '__u64' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Mike Miller <mike.miller@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-18Release old elevator on change elevatorZhaolei
We should release old elevator when change to use a new one. Signed-off-by: Zhao Lei <zhaolei@cn.fujitsu.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-11-18Merge branch 'master' into nextJames Morris
Conflicts: fs/cifs/misc.c Merge to resolve above, per the patch below. Signed-off-by: James Morris <jmorris@namei.org> diff --cc fs/cifs/misc.c index ec36410,addd1dc..0000000 --- a/fs/cifs/misc.c +++ b/fs/cifs/misc.c @@@ -347,13 -338,13 +338,13 @@@ header_assemble(struct smb_hdr *buffer /* BB Add support for establishing new tCon and SMB Session */ /* with userid/password pairs found on the smb session */ /* for other target tcp/ip addresses BB */ - if (current->fsuid != treeCon->ses->linux_uid) { + if (current_fsuid() != treeCon->ses->linux_uid) { cFYI(1, ("Multiuser mode and UID " "did not match tcon uid")); - read_lock(&GlobalSMBSeslock); - list_for_each(temp_item, &GlobalSMBSessionList) { - ses = list_entry(temp_item, struct cifsSesInfo, cifsSessionList); + read_lock(&cifs_tcp_ses_lock); + list_for_each(temp_item, &treeCon->ses->server->smb_ses_list) { + ses = list_entry(temp_item, struct cifsSesInfo, smb_ses_list); - if (ses->linux_uid == current->fsuid) { + if (ses->linux_uid == current_fsuid()) { if (ses->server == treeCon->ses->server) { cFYI(1, ("found matching uid substitute right smb_uid")); buffer->Uid = ses->Suid;
2008-11-15Merge branch 'doc-subdirs' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rdunlap/linux-docs * 'doc-subdirs' of git://git.kernel.org/pub/scm/linux/kernel/git/rdunlap/linux-docs: Create/use more directory structure in the Documentation/ tree.
2008-11-14Create/use more directory structure in the Documentation/ tree.Randy Dunlap
Create Documentation/blockdev/ sub-directory and populate it. Populate the Documentation/serial/ sub-directory. Move MSI-HOWTO.txt to Documentation/PCI/. Move ioctl-number.txt to Documentation/ioctl/. Update all relevant 00-INDEX files. Update all relevant Kconfig files and source files. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com>
2008-11-14xsysace: Fix driver to use resource_size_t instead of unsigned longYuri Tikhonov
This patch is a bug fix to the SystemACE driver to use resource_size_t for physical address instead of unsigned long. This makes the driver work correctly on 32 bit systems with 64-bit resources (e.g. PowerPC 440). Signed-off-by: Yuri Tikhonov <yur@emcraft.com> Signed-off-by: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2008-11-14powerpc/virtex: fix various format/casting printk mismatchesGrant Likely
Various printk format string in code used by the Xilinx Virtex platform are not 32-bit/64-bit safe. Add correct casting to fix the bugs. Reported-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2008-11-14Merge branch 'master' into nextJames Morris
Conflicts: security/keys/internal.h security/keys/process_keys.c security/keys/request_key.c Fixed conflicts above by using the non 'tsk' versions. Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Wrap task credential accesses in the block loopback driverDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-13ub: stub pre_reset and post_reset to fix oopsPete Zaitcev
Due to recent changes to usb_reset_device, the following hang occurs: events/0 D 0000000000000000 0 6 2 ffff880037477cc0 0000000000000046 ffff880037477c50 ffffffff80237434 ffffffff80574c80 00000001000a015c 0000000000000286 ffff8800374757d0 ffff88002a31c860 ffff880037475a00 0000000036779140 ffff880037475a00 Call Trace: [<ffffffff80237434>] try_to_del_timer_sync+0x52/0x5b [<ffffffff8026f86c>] dma_pool_free+0x1a7/0x1ec [<ffffffffa02a928a>] ub_disconnect+0x8e/0x1ad [ub] [<ffffffff802407c9>] autoremove_wake_function+0x0/0x2e [<ffffffff80378959>] usb_unbind_interface+0x5c/0xb7 [<ffffffff8036ab70>] __device_release_driver+0x95/0xbd [<ffffffff8036ac70>] device_release_driver+0x21/0x2d [<ffffffff803789f8>] usb_driver_release_interface+0x44/0x83 [<ffffffff80378ab9>] usb_forced_unbind_intf+0x17/0x1d [<ffffffff80371ba4>] usb_reset_device+0x7d/0x114 [<ffffffffa02aaffd>] ub_reset_task+0x0/0x293 [ub] [<ffffffffa02ab1c1>] ub_reset_task+0x1c4/0x293 [ub] [<ffffffff8033dd1e>] flush_to_ldisc+0x0/0x1cd [<ffffffffa02aaffd>] ub_reset_task+0x0/0x293 [ub] [<ffffffff8023d302>] run_workqueue+0x87/0x114 [<ffffffff8023d467>] worker_thread+0xd8/0xe7 [<ffffffff802407c9>] autoremove_wake_function+0x0/0x2e [<ffffffff8023d38f>] worker_thread+0x0/0xe7 [<ffffffff802404c1>] kthread+0x47/0x73 [<ffffffff8022c8dd>] schedule_tail+0x27/0x60 [<ffffffff8020c249>] child_rip+0xa/0x11 [<ffffffff8024047a>] kthread+0x0/0x73 [<ffffffff8020c23f>] child_rip+0x0/0x11 This is because usb_reset_device now unbinds, and that calls disconnect, which in case of ub waits until the reset completes... which deadlocks. Worse, this deadlocks keventd and this takes whole box down. I'm going to fix this properly later, but let's unbreak the driver quickly for non-composite devices at least. Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Cc: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-06cciss: fix regression firmware not displayed in procfsMike Miller
This regression was introduced by commit 6ae5ce8e8d4de666f31286808d2285aa6a50fa40 ("cciss: remove redundant code"). This patch fixes a regression where the controller firmware version is not displayed in procfs. The previous patch would be called anytime something changed. This will get called only once for each controller. Signed-off-by: Mike Miller <mike.miller@hp.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: <stable@kernel.org> [2.6.27.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-06cciss: fix sysfs broken symlink regressionMike Miller
Regression introduced by commit 6ae5ce8e8d4de666f31286808d2285aa6a50fa40 ("cciss: remove redundant code"). This patch fixes a broken symlink in sysfs that was introduced by the above commit. We broke it in 2.6.27-rc on or about 20080804. Some installers are broken if this symlink does not exist and they may not detect the logical drives configured on the controller. It does not require being backported into 2.6.26.x or earlier kernels. Signed-off-by: Mike Miller <mike.miller@hp.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: <stable@kernel.org> [2.6.27.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-06cpqarry: fix return value of cpqarray_init()Andrey Borzenkov
As reported by Dick Gevers on Compaq ProLiant: Oct 13 18:06:51 dvgcpl kernel: Compaq SMART2 Driver (v 2.6.0) Oct 13 18:06:51 dvgcpl kernel: sys_init_module: 'cpqarray'->init suspiciously returned 1, it should follow 0/-E convention Oct 13 18:06:51 dvgcpl kernel: sys_init_module: loading module anyway... Oct 13 18:06:51 dvgcpl kernel: Pid: 315, comm: modprobe Not tainted 2.6.27-desktop-0.rc8.2mnb #1 Oct 13 18:06:51 dvgcpl kernel: [<c0380612>] ? printk+0x18/0x1e Oct 13 18:06:51 dvgcpl kernel: [<c0158f85>] sys_init_module+0x155/0x1c0 Oct 13 18:06:51 dvgcpl kernel: [<c0103f06>] syscall_call+0x7/0xb Oct 13 18:06:51 dvgcpl kernel: ======================= Make it return 0 on success and -ENODEV if no array was found. Reported-by: Dick Gevers <dvgevers@xs4all.nl> Signed-off-by: Andrey Borzenkov <arvidjaar@mail.ru> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-06cciss: new hardware supportMike Miller
Add support for 2 new SAS/SATA controllers. Signed-off-by: Mike Miller <mike.miller@hp.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-30fs: remove prepare_write/commit_writeNick Piggin
Nothing uses prepare_write or commit_write. Remove them from the tree completely. [akpm@linux-foundation.org: schedule simple_prepare_write() for unexporting] Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-21[PATCH] sanitize blkdev_get() and friendsAl Viro
* get rid of fake struct file/struct dentry in __blkdev_get() * merge __blkdev_get() and do_open() * get rid of flags argument of blkdev_get() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-21[PATCH] pass fmode_t to blkdev_put()Al Viro
2008-10-21[PATCH] kill the unused bsize on the send side of /dev/loopAl Viro
2008-10-21[PATCH] switch z2ramAl Viro
2008-10-21[PATCH] switch xyspaceAl Viro
2008-10-21[PATCH] switch xenAl Viro
2008-10-21[PATCH] switch xdAl Viro
2008-10-21[PATCH] switch virtio_blkAl Viro
2008-10-21[PATCH] switch viodasdAl Viro
2008-10-21[PATCH] switch ubAl Viro
2008-10-21[PATCH] switch swim3Al Viro
2008-10-21[PATCH] switch pktdvdcdAl Viro
