path: root/drivers/block/rsxx
2014-11-24block/rsxx: use generic io stats accounting functions to simplify io stat ↵Gu Zheng
accounting Use generic io stats accounting help functions (generic_{start,end}_io_acct) to simplify io stat accounting. Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-10-18Merge branch 'for-3.18/drivers' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block layer driver update from Jens Axboe: "This is the block driver pull request for 3.18. Not a lot in there this round, and nothing earth shattering. - A round of drbd fixes from the linbit team, and an improvement in asender performance. - Removal of deprecated (and unused) IRQF_DISABLED flag in rsxx and hd from Michael Opdenacker. - Disable entropy collection from flash devices by default, from Mike Snitzer. - A small collection of xen blkfront/back fixes from Roger Pau Monné and Vitaly Kuznetsov" * 'for-3.18/drivers' of git://git.kernel.dk/linux-block: block: disable entropy contributions for nonrot devices xen, blkfront: factor out flush-related checks from do_blkif_request() xen-blkback: fix leak on grant map error path xen/blkback: unmap all persistent grants when frontend gets disconnected rsxx: Remove deprecated IRQF_DISABLED block: hd: remove deprecated IRQF_DISABLED drbd: use RB_DECLARE_CALLBACKS() to define augment callbacks drbd: compute the end before rb_insert_augmented() drbd: Add missing newline in resync progress display in /proc/drbd drbd: reduce lock contention in drbd_worker drbd: Improve asender performance drbd: Get rid of the WORK_PENDING macro drbd: Get rid of the __no_warn and __cond_lock macros drbd: Avoid inconsistent locking warning drbd: Remove superfluous newline from "resync_extents" debugfs entry. drbd: Use consistent names for all the bi_end_io callbacks drbd: Use better variable names
2014-10-09rsxx debugfs inanityAl Viro
check with the author of that horror... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-10-04block: disable entropy contributions for nonrot devicesMike Snitzer
Clear QUEUE_FLAG_ADD_RANDOM in all block drivers that set QUEUE_FLAG_NONROT. Historically, all block devices have automatically made entropy contributions. But as previously stated in commit e2e1a148 ("block: add sysfs knob for turning off disk entropy contributions"): - On SSD disks, the completion times aren't as random as they are for rotational drives. So it's questionable whether they should contribute to the random pool in the first place. - Calling add_disk_randomness() has a lot of overhead. There are more reliable sources for randomness than non-rotational block devices. From a security perspective it is better to err on the side of caution than to allow entropy contributions from unreliable "random" sources. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-10-01rsxx: Remove deprecated IRQF_DISABLEDMichael Opdenacker
This removes the use of the IRQF_DISABLED flag from drivers/block/rsxx/core.c It's a NOOP since 2.6.35 and it will be removed one day. Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com> Acked-by Philip Kelleher <pjk1939@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-08-12PCI: Remove DEFINE_PCI_DEVICE_TABLE macro useBenoit Taine
We should prefer `struct pci_device_id` over `DEFINE_PCI_DEVICE_TABLE` to meet kernel coding style guidelines. This issue was reported by checkpatch. A simplified version of the semantic patch that makes this change is as follows (http://coccinelle.lip6.fr/): // <smpl> @@ identifier i; declarer name DEFINE_PCI_DEVICE_TABLE; initializer z; @@ - DEFINE_PCI_DEVICE_TABLE(i) + const struct pci_device_id i[] = z; // </smpl> [bhelgaas: add semantic patch] Signed-off-by: Benoit Taine <benoit.taine@lip6.fr> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-11-23block: Convert bio_for_each_segment() to bvec_iterKent Overstreet
More prep work for immutable biovecs - with immutable bvecs drivers won't be able to use the biovec directly, they'll need to use helpers that take into account bio->bi_iter.bi_bvec_done. This updates callers for the new usage without changing the implementation yet. Signed-off-by: Kent Overstreet <kmo@daterainc.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "Ed L. Cashin" <ecashin@coraid.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Lars Ellenberg <drbd-dev@lists.linbit.com> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Paul Clements <Paul.Clements@steeleye.com> Cc: Jim Paris <jim@jtan.com> Cc: Geoff Levand <geoff@infradead.org> Cc: Yehuda Sadeh <yehuda@inktank.com> Cc: Sage Weil <sage@inktank.com> Cc: Alex Elder <elder@inktank.com> Cc: ceph-devel@vger.kernel.org Cc: Joshua Morris <josh.h.morris@us.ibm.com> Cc: Philip Kelleher <pjk1939@linux.vnet.ibm.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Neil Brown <neilb@suse.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: linux390@de.ibm.com Cc: Nagalakshmi Nandigama <Nagalakshmi.Nandigama@lsi.com> Cc: Sreekanth Reddy <Sreekanth.Reddy@lsi.com> Cc: support@lsi.com Cc: "James E.J. Bottomley" <JBottomley@parallels.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com> Cc: Tejun Heo <tj@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Guo Chao <yan@linux.vnet.ibm.com> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Matthew Wilcox <matthew.r.wilcox@intel.com> Cc: Keith Busch <keith.busch@intel.com> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: Quoc-Son Anh <quoc-sonx.anh@intel.com> Cc: Sebastian Ott <sebott@linux.vnet.ibm.com> Cc: Nitin Gupta <ngupta@vflare.org> Cc: Minchan Kim <minchan@kernel.org> Cc: Jerome Marchand <jmarchan@redhat.com> Cc: Seth Jennings <sjenning@linux.vnet.ibm.com> Cc: "Martin K. Petersen" <martin.petersen@oracle.com> Cc: Mike Snitzer <snitzer@redhat.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: "Darrick J. Wong" <darrick.wong@oracle.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Jan Kara <jack@suse.cz> Cc: linux-m68k@lists.linux-m68k.org Cc: linuxppc-dev@lists.ozlabs.org Cc: drbd-user@lists.linbit.com Cc: nbd-general@lists.sourceforge.net Cc: cbe-oss-dev@lists.ozlabs.org Cc: xen-devel@lists.xensource.com Cc: virtualization@lists.linux-foundation.org Cc: linux-raid@vger.kernel.org Cc: linux-s390@vger.kernel.org Cc: DL-MPTFusionLinux@lsi.com Cc: linux-scsi@vger.kernel.org Cc: devel@driverdev.osuosl.org Cc: linux-fsdevel@vger.kernel.org Cc: cluster-devel@redhat.com Cc: linux-mm@kvack.org Acked-by: Geoff Levand <geoff@infradead.org>
2013-11-23block: Abstract out bvec iteratorKent Overstreet
Immutable biovecs are going to require an explicit iterator. To implement immutable bvecs, a later patch is going to add a bi_bvec_done member to this struct; for now, this patch effectively just renames things. Signed-off-by: Kent Overstreet <kmo@daterainc.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "Ed L. Cashin" <ecashin@coraid.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Lars Ellenberg <drbd-dev@lists.linbit.com> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Matthew Wilcox <willy@linux.intel.com> Cc: Geoff Levand <geoff@infradead.org> Cc: Yehuda Sadeh <yehuda@inktank.com> Cc: Sage Weil <sage@inktank.com> Cc: Alex Elder <elder@inktank.com> Cc: ceph-devel@vger.kernel.org Cc: Joshua Morris <josh.h.morris@us.ibm.com> Cc: Philip Kelleher <pjk1939@linux.vnet.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Neil Brown <neilb@suse.de> Cc: Alasdair Kergon <agk@redhat.com> Cc: Mike Snitzer <snitzer@redhat.com> Cc: dm-devel@redhat.com Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: linux390@de.ibm.com Cc: Boaz Harrosh <bharrosh@panasas.com> Cc: Benny Halevy <bhalevy@tonian.com> Cc: "James E.J. Bottomley" <JBottomley@parallels.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: "Nicholas A. Bellinger" <nab@linux-iscsi.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Chris Mason <chris.mason@fusionio.com> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Andreas Dilger <adilger.kernel@dilger.ca> Cc: Jaegeuk Kim <jaegeuk.kim@samsung.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Dave Kleikamp <shaggy@kernel.org> Cc: Joern Engel <joern@logfs.org> Cc: Prasad Joshi <prasadjoshi.linux@gmail.com> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: KONISHI Ryusuke <konishi.ryusuke@lab.ntt.co.jp> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Ben Myers <bpm@sgi.com> Cc: xfs@oss.sgi.com Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Len Brown <len.brown@intel.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com> Cc: Ben Hutchings <ben@decadent.org.uk> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Guo Chao <yan@linux.vnet.ibm.com> Cc: Tejun Heo <tj@kernel.org> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Cc: "Roger Pau Monné" <roger.pau@citrix.com> Cc: Jan Beulich <jbeulich@suse.com> Cc: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Cc: Ian Campbell <Ian.Campbell@citrix.com> Cc: Sebastian Ott <sebott@linux.vnet.ibm.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Jiang Liu <jiang.liu@huawei.com> Cc: Nitin Gupta <ngupta@vflare.org> Cc: Jerome Marchand <jmarchand@redhat.com> Cc: Joe Perches <joe@perches.com> Cc: Peng Tao <tao.peng@emc.com> Cc: Andy Adamson <andros@netapp.com> Cc: fanchaoting <fanchaoting@cn.fujitsu.com> Cc: Jie Liu <jeff.liu@oracle.com> Cc: Sunil Mushran <sunil.mushran@gmail.com> Cc: "Martin K. Petersen" <martin.petersen@oracle.com> Cc: Namjae Jeon <namjae.jeon@samsung.com> Cc: Pankaj Kumar <pankaj.km@samsung.com> Cc: Dan Magenheimer <dan.magenheimer@oracle.com> Cc: Mel Gorman <mgorman@suse.de>6
2013-11-08rsxx: Fix possible kernel panic with invalid config.Philip J Kelleher
This patch fixes a possible Kernel Panic on driver load if the configuration on the card is messed up or not yet set. The driver could possible give a 32 bit unsigned all Fs to the kernel as the device's block size. Now we only write the block size to the kernel if the configuration from the card is valid. Also, driver version is being updated. Signed-off-by: Philip J Kelleher <pjk1939@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-11-08rsxx: Disallow discards from being unmapped.Philip J Kelleher
This patch fixes a bug in which discards were always calling pci_unmap_page. Discards should never call the pci_unmap_page function call because they are never mapped. This caused a race condition on PowerPC systems when issuing discards, writes, and reads all at the same time. The pci_map_page function would eventually map logical address 0 for a read or write. Discards are always assigned a DMA address of 0 because they are never mapped. So if pci_map_page mapped address 0 for a DMA and a discard was "unmapped" then the address would be freed and would cause an EEH event to occur when Hardware accesses the address. This was injected/uncovered in commit: b347f9cf0bc8d42ee95ba1d3837fd93045ab336b The pci_dma_mapping_error function declares -1 a DMA_ERROR not 0 like initially thought So before we would never unmap discards because they were considered NULL. This patch should fall on top of commit id: fc1967bb08a6184ed44ef990e1dd4389901b809c Also, the driver version is being up dated. Signed-off-by: Philip J Kelleher <pjk1939@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-11-08rsxx: Kernel Panic caused by mapping DiscardsPhilip J Kelleher
This fixes a kernel panic injected by commit id 8d26750143341831bc312f61c5ed141eeb75b8d0 where discards are getting mapped through the pci_map_page function call. The driver will now start verifying that a dma is not a discard before issuing a the pci_map_page function call. Also, we are updating the driver version. Signed-off-by: Philip J Kelleher <pjk1939@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-11-08rsxx: Moving pci_map_page to prevent overflow.Philip J Kelleher
The pci_map_page function has been moved into our issued workqueue to prevent an us running out of mappable addresses on non-HWWD PCIe x8 slots. The maximum amount that can possible be mapped at one time now is: 255 dmas X 4 dma channels X 4096 Bytes. Signed-off-by: Philip J Kelleher <pjk1939@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-11-08rsxx: Handling failed pci_map_page on PowerPC and double free.Philip J Kelleher
The rsxx driver was not checking the correct value during a pci_map_page failure. Fixing this also uncovered a double free if the bio was returned before it was broken up into indiviadual 4k dmas, that is also fixed here. Signed-off-by: Philip J Kelleher <pjk1939@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-06-19rsxx: Adding in debugfs entries.Philip J Kelleher
Adding debugfs entries to help with debugging and testing and testing code. pci_regs: This entry will spit out all of the data stored on the BAR. stats: This entry will display all of the driver stats for each DMA channel. cram: This will allow read/write ability to the CRAM address space on our adapter's CPU. Signed-off-by: Philip J Kelleher <pjk1939@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-06-19rsxx: Fixes incorrect stats calculation.Philip J Kelleher
Fixing incorrect stats calculation during read retries. Signed-off-by: Philip J Kelleher <pjk1939@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-06-19rsxx: Adding EEH check inside cregs timeout.Philip J Kelleher
Unfortunaly, our CPU register path does not do any kind of EEH error checking. So to fix this issue, an ioread32 was added to the CPU register timeout code. This way, the driver can check to see if the timeout was caused by an EEH error or not. This is a dummy read. Signed-off-by: Philip J Kelleher <pjk1939@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-06-19rsxx: Adapter address space sanity check.Philip J Kelleher
Adding a sanity check to guarentee that DMAs outside of the device's address space will be errored out right away. Signed-off-by: Philip J Kelleher <pjk1939@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-06-19rsxx: Fixes DLPAR add kernel panic if partition still mounted.Philip J Kelleher
A kernel panic would occur on a DLPAR add if there was a partition still mounted during the DLPAR remove. This bug fix will allow the user to unmount the partition and bring the driver back into a good state after the DLPAR add. Signed-off-by: Philip J Kelleher <pjk1939@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-06-19rsxx: Changing the adapter name to the official name.Philip J Kelleher
Changing the adapter name from FlashSystem-80 to the official name: Flash Adapter 900GB Full Height. Signed-off-by: Philip J Kelleher <pjk1939@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-06-19rsxx: Adding in sync_start module paramenter.Philip J Kelleher
Before, the partition table would have to be reread because our card was attached before it transistioned out of it's 'starting' state. This change will cause the driver to wait to attach the device until the adapter is ready. Signed-off-by: Philip J Kelleher <pjk1939@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-06-19rsxx: Allow block size to be determined by configuration.Philip J Kelleher
Previously, the block size was determined by whether or not our Hardware could handle 512 byte accesses. Now, all of our Hardware can handle 512 and 4096 block sizes. This fix allows it to be user configurable. Signed-off-by: Philip J Kelleher <pjk1939@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-06-19rsxx: Fixes soft-lockup issues during DMAs.Philip J Kelleher
The workqueue mechanism has been reworked to prevent soft lockup issues from occuring by adding in mutex sychronization. Signed-off-by: Philip J Kelleher <pjk1939@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-06-19rsxx: Restructured DMA cancel scheme.Philip J Kelleher
Before, DMAs would never be cancelled if there was a data stall or an EEH Permenant failure which would cause an unrecoverable I/O hang. The DMA cancellation mechanism has been modified to fix these issues and allows DMAs to be cancelled during the above mentioned events. Signed-off-by: Philip J Kelleher <pjk1939@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-06-19rsxx: Individual workqueues for interruptible events.Philip J Kelleher
Giving all interrupt based events their own workqueue to complete tasks on. This fixes a bug that would cause creg commands to timeout if too many are issued at once. Signed-off-by: Philip J Kelleher <pjk1939@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-03-26rsxx: remove unused variablePhilip J Kelleher
2013-03-26rsxx: enable error return of rsxx_eeh_save_issued_dmas()Philip J Kelleher
Commit d8d595df introduced a bug where we did not check for a NULL return from kmalloc(). Make rsxx_eeh_save_issued_dmas() return an error for that case, and make the callers handle that. Signed-off-by: Philip J Kelleher <pjk1939@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-03-25block: removes dynamic allocation on stackPhilip J Kelleher
This patch removes dynamic allocation on the stack error. Signed-off-by: Philip J Kelleher <pjk1939@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-03-16rsxx: fix missing unlock on error return in rsxx_eeh_remap_dmas()Jens Axboe
Spotted by Fenguan Wu's super build robot. Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-03-16Adding in EEH support to the IBM FlashSystem 70/80 device driverPhilip J Kelleher
Changes in v2 include: o Fixed spelling of guarantee. o Fixed potential memory leak if slot reset fails out. o Changed list_for_each_entry_safe with list_for_each_entry. Signed-off-by: Philip J Kelleher <pjk1939@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-03-11block: IBM RamSan 70/80 error message bug fix.Philip J Kelleher
This patch includes a simple change to the rsxx_pci_remove function that caused error messages because traffic was halted too early. Signed-off-by: Philip J Kelleher <pjk1939@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-03-11block: IBM RamSan 70/80 branding changes.Philip J Kelleher
This patch includes changing the hardware branding name from IBM RamSan to IBM FlashSystem. v2 Changes include: o Removing the unnecessary IBM Vendor ID #define v1 Changes include: o Changed all references of RamSan to FlashSystem. o Changed the vendor/device IDs for the product. o Changed driver version number. o Updated the MAINTAINERS file. o Various other little things. Signed-off-by: Philip J Kelleher <pjk1939@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-03-11block: IBM RamSan 70/80 fixes inconsistent locking.Philip J Kelleher
This patch includes changes to the cregs locking scheme. Before, inconsistant locking would occur because of misuse of spin_lock, spin_lock_bh, and counter parts. Signed-off-by: Philip J Kelleher <pjk1939@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-03-11block: IBM RamSan 70/80 trivial changes.Philip J Kelleher
This patch includes trivial changes that were recommended by different members of the Linux Community. Changes include: o Removing the redundant wmb(). o Formatting o Various other little things. Signed-off-by: Philip J Kelleher <pjk1939@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-02-18block: IBM RamSan 70/80 driver fixesPhilip J Kelleher
This patch includes the following driver fixes for the IBM RamSan 70/80 driver: o Changed the creg_ctrl lock from a mutex to a spinlock. o Added a count check for ioctl calls. o Removed unnecessary casting of void pointers. o Made every function static that needed to be. o Added comments to explain things more thoroughly. Signed-off-by: Philip J Kelleher <pjk1939@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-02-07rsxx: add slab.h include to dma.cJens Axboe
kbuild test robot says: tree: git://git.kernel.dk/linux-block.git for-3.9/drivers head: 1262e24a59a052f9a98383e47e7c903712490d5c commit: 8722ff8cdbfac9c1b20e67bb067b455c48cb8e93 [6/8] block: IBM RamSan 70/80 device driver config: make ARCH=alpha allyesconfig All error/warnings: drivers/block/rsxx/dma.c: In function 'rsxx_complete_dma': >> drivers/block/rsxx/dma.c:251:2: error: implicit declaration of function 'kmem_cache_free' [-Werror=implicit-function-declaration] drivers/block/rsxx/dma.c: In function 'rsxx_queue_discard': >> drivers/block/rsxx/dma.c:567:2: error: implicit declaration of function 'kmem_cache_alloc' [-Werror=implicit-function-declaration] >> drivers/block/rsxx/dma.c:567:6: warning: assignment makes pointer from integer without a cast [enabled by default] drivers/block/rsxx/dma.c: In function 'rsxx_queue_dma': >> drivers/block/rsxx/dma.c:601:6: warning: assignment makes pointer from integer without a cast [enabled by default] drivers/block/rsxx/dma.c: In function 'rsxx_dma_init': >> drivers/block/rsxx/dma.c:985:2: error: implicit declaration of function 'KMEM_CACHE' [-Werror=implicit-function-declaration] >> drivers/block/rsxx/dma.c:985:29: error: 'rsxx_dma' undeclared (first use in this function) drivers/block/rsxx/dma.c:985:29: note: each undeclared identifier is reported only once for each function it appears in >> drivers/block/rsxx/dma.c:985:39: error: 'SLAB_HWCACHE_ALIGN' undeclared (first use in this function) drivers/block/rsxx/dma.c: In function 'rsxx_dma_cleanup': >> drivers/block/rsxx/dma.c:995:2: error: implicit declaration of function 'kmem_cache_destroy' [-Werror=implicit-function-declaration] cc1: some warnings being treated as errors Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-02-06block: remove new __devinit/exit annotations on ramsam driverStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-02-05block: IBM RamSan 70/80 device driverjosh.h.morris@us.ibm.com
This patch includes the device driver for the IBM RamSan family of PCI SSD flash storage cards. This driver will include support for the RamSan 70 and 80. The driver presents a block device for device I/O. Signed-off-by: Philip J Kelleher <pjk1939@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
