path: root/drivers/block/loop.c
2006-03-26[PATCH] loop: potential kernel hang waiting for kthreadHerbert Poetzl
Check that kernel_thread() succeeded, so we don't wait for something which cannot happen. Signed-off-by: Herbert Poetzl <herbert@13thfloor.at> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] sem2mutex: drivers/block/loop.cIngo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Jens Axboe <axboe@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-18[PATCH] regularize blk_cleanup_queue() useAl Viro
2006-01-14[PATCH] Unlinline a bunch of other functionsArjan van de Ven
Remove the "inline" keyword from a bunch of big functions in the kernel with the goal of shrinking it by 30kb to 40kb Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] mutex subsystem, semaphore to completion: drivers/block/loop.cIngo Molnar
convert the block loop device from semaphores to completions. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2006-01-09[PATCH] mutex subsystem, semaphore to mutex: VFS, ->i_semJes Sorensen
This patch converts the inode semaphore to a mutex. I have tested it on XFS and compiled as much as one can consider on an ia64. Anyway your luck with it might be different. Modified-by: Ingo Molnar <mingo@elte.hu> (finished the conversion) Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2006-01-03[PATCH] add AOP_TRUNCATED_PAGE, prepend AOP_ to WRITEPAGE_ACTIVATEZach Brown
readpage(), prepare_write(), and commit_write() callers are updated to understand the special return code AOP_TRUNCATED_PAGE in the style of writepage() and WRITEPAGE_ACTIVATE. AOP_TRUNCATED_PAGE tells the caller that the callee has unlocked the page and that the operation should be tried again with a new page. OCFS2 uses this to detect and work around a lock inversion in its aop methods. There should be no change in behaviour for methods that don't return AOP_TRUNCATED_PAGE. WRITEPAGE_ACTIVATE is also prepended with AOP_ for consistency and they are made enums so that kerneldoc can be used to document their semantics. Signed-off-by: Zach Brown <zach.brown@oracle.com>
2005-10-28[PATCH] gfp_t: remaining bits of drivers/*Al Viro
2005-06-23[PATCH] optimise loop driver a bitNick Piggin
Looks like locking can be optimised quite a lot. Increase lock widths slightly so lo_lock is taken fewer times per request. Also it was quite trivial to cover lo_pending with that lock, and remove the atomic requirement. This also makes memory ordering explicitly correct, which is nice (not that I particularly saw any mem ordering bugs). Test was reading 4 250MB files in parallel on ext2-on-tmpfs filesystem (1K block size, 4K page size). System is 2 socket Xeon with HT (4 thread). intel:/home/npiggin# umount /dev/loop0 ; mount /dev/loop0 /mnt/loop ; /usr/bin/time ./mtloop.sh Before: 0.24user 5.51system 0:02.84elapsed 202%CPU (0avgtext+0avgdata 0maxresident)k 0.19user 5.52system 0:02.88elapsed 198%CPU (0avgtext+0avgdata 0maxresident)k 0.19user 5.57system 0:02.89elapsed 198%CPU (0avgtext+0avgdata 0maxresident)k 0.22user 5.51system 0:02.90elapsed 197%CPU (0avgtext+0avgdata 0maxresident)k 0.19user 5.44system 0:02.91elapsed 193%CPU (0avgtext+0avgdata 0maxresident)k After: 0.07user 2.34system 0:01.68elapsed 143%CPU (0avgtext+0avgdata 0maxresident)k 0.06user 2.37system 0:01.68elapsed 144%CPU (0avgtext+0avgdata 0maxresident)k 0.06user 2.39system 0:01.68elapsed 145%CPU (0avgtext+0avgdata 0maxresident)k 0.06user 2.36system 0:01.68elapsed 144%CPU (0avgtext+0avgdata 0maxresident)k 0.06user 2.42system 0:01.68elapsed 147%CPU (0avgtext+0avgdata 0maxresident)k Signed-off-by: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
