path: root/drivers/block/aoe/aoeblk.c
2009-09-22const: make block_device_operations constAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-14Merge branch 'for-2.6.32' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.32' of git://git.kernel.dk/linux-2.6-block: (29 commits) block: use blkdev_issue_discard in blk_ioctl_discard Make DISCARD_BARRIER and DISCARD_NOBARRIER writes instead of reads block: don't assume device has a request list backing in nr_requests store block: Optimal I/O limit wrapper cfq: choose a new next_req when a request is dispatched Seperate read and write statistics of in_flight requests aoe: end barrier bios with EOPNOTSUPP block: trace bio queueing trial only when it occurs block: enable rq CPU completion affinity by default cfq: fix the log message after dispatched a request block: use printk_once cciss: memory leak in cciss_init_one() splice: update mtime and atime on files block: make blk_iopoll_prep_sched() follow normal 0/1 return convention cfq-iosched: get rid of must_alloc flag block: use interrupts disabled version of raise_softirq_irqoff() block: fix comment in blk-iopoll.c block: adjust default budget for blk-iopoll block: fix long lines in block/blk-iopoll.c block: add blk-iopoll, a NAPI like approach for block devices ...
2009-09-14aoe: end barrier bios with EOPNOTSUPPEd Cashin
BugLink: http://bugzilla.kernel.org/show_bug.cgi?id=13942 Bruno Premont noticed that aoe throws a BUG during umount of an XFS in 2.6.31: [ 5259.349897] aoe: bi_io_vec is NULL [ 5259.349940] ------------[ cut here ]------------ [ 5259.349958] kernel BUG at /usr/src/linux-2.6/drivers/block/aoe/aoeblk.c:177! [ 5259.349990] invalid opcode: 0000 [#1] The bio in question is a barrier. Jens Axboe suggested that such bios need to be recognized and ended with -EOPNOTSUPP by any driver that provides its own ->make_request_fn handler and does not handle barriers. In testing the changes below eliminate the BUG. (Better would be real barrier support, something that Ed says he'll add for later in the .32 cycle. For now, this at least gets rid of a bug with crashing on an empty barrier. Jens) Signed-off-by: Ed L. Cashin <ecashin@coraid.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-11writeback: add name to backing_dev_infoJens Axboe
This enables us to track who does what and print info. Its main use is catching dirty inodes on the default_backing_dev_info, so we can fix that up. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-09aoe: allocate unused request_queue for sysfsEd Cashin
Andy Whitcroft reported an oops in aoe triggered by use of an incorrectly initialised request_queue object: [ 2645.959090] kobject '<NULL>' (ffff880059ca22c0): tried to add an uninitialized object, something is seriously wrong. [ 2645.959104] Pid: 6, comm: events/0 Not tainted 2.6.31-5-generic #24-Ubuntu [ 2645.959107] Call Trace: [ 2645.959139] [<ffffffff8126ca2f>] kobject_add+0x5f/0x70 [ 2645.959151] [<ffffffff8125b4ab>] blk_register_queue+0x8b/0xf0 [ 2645.959155] [<ffffffff8126043f>] add_disk+0x8f/0x160 [ 2645.959161] [<ffffffffa01673c4>] aoeblk_gdalloc+0x164/0x1c0 [aoe] The request queue of an aoe device is not used but can be allocated in code that does not sleep. Bruno bisected this regression down to cd43e26f071524647e660706b784ebcbefbd2e44 block: Expose stacked device queues in sysfs "This seems to generate /sys/block/$device/queue and its contents for everyone who is using queues, not just for those queues that have a non-NULL queue->request_fn." Addresses http://bugs.launchpad.net/bugs/410198 Addresses http://bugzilla.kernel.org/show_bug.cgi?id=13942 Note that embedding a queue inside another object has always been an illegal construct, since the queues are reference counted and must persist until the last reference is dropped. So aoe was always buggy in this respect (Jens). Signed-off-by: Ed Cashin <ecashin@coraid.com> Cc: Andy Whitcroft <apw@canonical.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Bruno Premont <bonbons@linux-vserver.org> Cc: Martin K. Petersen <martin.petersen@oracle.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-11-25aoe: remove private mac address format functionHarvey Harrison
Add %pm to omit the colons when printing a mac address. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-21[PATCH] switch aoeblkAl Viro
2008-10-21[PATCH] beginning of methods conversionAl Viro
To keep the size of changesets sane we split the switch by drivers; to keep the damn thing bisectable we do the following: 1) rename the affected methods, add ones with correct prototypes, make (few) callers handle both. That's this changeset. 2) for each driver convert to new methods. *ALL* drivers are converted in this series. 3) kill the old (renamed) methods. Note that it _is_ a flagday; all in-tree drivers are converted and by the end of this series no trace of old methods remain. The only reason why we do that this way is to keep the damn thing bisectable and allow per-driver debugging if anything goes wrong. New methods: open(bdev, mode) release(disk, mode) ioctl(bdev, mode, cmd, arg) /* Called without BKL */ compat_ioctl(bdev, mode, cmd, arg) locked_ioctl(bdev, mode, cmd, arg) /* Called with BKL, legacy */ Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-20x86: sysfs: kill owner field from attributeParag Warudkar
Tejun's commit 7b595756ec1f49e0049a9e01a1298d53a7faaa15 made sysfs attribute->owner unnecessary. But the field was left in the structure to ease the merge. It's been over a year since that change and it is now time to start killing attribute->owner along with its users - one arch at a time! This patch is attempt #1 to get rid of attribute->owner only for CONFIG_X86_64 or CONFIG_X86_32 . We will deal with other arches later on as and when possible - avr32 will be the next since that is something I can test. Compile (make allyesconfig / make allmodconfig / custom config) and boot tested. akpm: the idea is that we put the declaration of sttribute.owner inside `#ifndef CONFIG_X86'. But that proved to be too ambitious for now because new usages kept on turning up in subsystem trees. [akpm: remove the ifdef for now] Signed-off-by: Parag Warudkar <parag.lkml@gmail.com> Cc: Greg KH <greg@kroah.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Tejun Heo <htejun@gmail.com> Cc: Len Brown <lenb@kernel.org> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Jean Delvare <khali@linux-fr.org> Cc: Roland Dreier <rolandd@cisco.com> Cc: David Brownell <david-b@pacbell.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1075 commits) myri10ge: update driver version number to 1.4.3-1.369 r8169: add shutdown handler r8169: preliminary 8168d support r8169: support additional 8168cp chipset r8169: change default behavior for mildly identified 8168c chipsets r8169: add a new 8168cp flavor r8169: add a new 8168c flavor (bis) r8169: add a new 8168c flavor r8169: sync existing 8168 device hardware start sequences with vendor driver r8169: 8168b Tx performance tweak r8169: make room for more specific 8168 hardware start procedure r8169: shuffle some registers handling around (8168 operation only) r8169: new phy init parameters for the 8168b r8169: update phy init parameters r8169: wake up the PHY of the 8168 af_key: fix SADB_X_SPDDELETE response ath9k: Fix return code when ath9k_hw_setpower() fails on reset ath9k: remove nasty FAIL macro from ath9k_hw_reset() gre: minor cleanups in netlink interface gre: fix copy and paste error ...
2008-10-09block: move capacity from disk to part0Tejun Heo
Move disk->capacity to part0->nr_sects and convert all users who directly accessed the field to use {get|set}_capacity(). This is done early to allow the __dev field to be moved. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: implement and use {disk|part}_to_dev()Tejun Heo
Implement {disk|part}_to_dev() and use them to access generic device instead of directly dereferencing {disk|part}->dev. To make sure no user is left behind, rename generic devices fields to __dev. This is in preparation of unifying partition 0 handling with other partitions. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-09-21aoe: Use SKB interfaces for list management instead of home-grown stuff.David S. Miller
2008-02-08aoe: update copyright dateEd L. Cashin
Update the year in the copyright notices. Signed-off-by: Ed L. Cashin <ecashin@coraid.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08aoe: the aoeminor doesn't need a long formatEd L. Cashin
The aoedev aoeminor member doesn't need a long format. Signed-off-by: Ed L. Cashin <ecashin@coraid.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08aoe: mac_addr: avoid 64-bit arch compiler warningsEd L. Cashin
By returning unsigned long long, mac_addr does not generate compiler warnings on 64-bit architectures. Signed-off-by: Ed L. Cashin <ecashin@coraid.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08aoe: handle multiple network paths to AoE deviceEd L. Cashin
A remote AoE device is something can process ATA commands and is identified by an AoE shelf number and an AoE slot number. Such a device might have more than one network interface, and it might be reachable by more than one local network interface. This patch tracks the available network paths available to each AoE device, allowing them to be used more efficiently. Andrew Morton asked about the call to msleep_interruptible in the revalidate function. Yes, if a signal is pending, then msleep_interruptible will not return 0. That means we will not loop but will call aoenet_xmit with a NULL skb, which is a noop. If the system is too low on memory or the aoe driver is too low on frames, then the user can hit control-C to interrupt the attempt to do a revalidate. I have added a comment to the code summarizing that. Andrew Morton asked whether the allocation performed inside addtgt could use a more relaxed allocation like GFP_KERNEL, but addtgt is called when the aoedev lock has been locked with spin_lock_irqsave. It would be nice to allocate the memory under fewer restrictions, but targets are only added when the device is being discovered, and if the target can't be added right now, we can try again in a minute when then next AoE config query broadcast goes out. Andrew Morton pointed out that the "too many targets" message could be printed for failing GFP_ATOMIC allocations. The last patch in this series makes the messages more specific. Signed-off-by: Ed L. Cashin <ecashin@coraid.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-24Driver core: convert block from raw kobjects to core devicesKay Sievers
This moves the block devices to /sys/class/block. It will create a flat list of all block devices, with the disks and partitions in one directory. For compatibility /sys/block is created and contains symlinks to the disks. /sys/class/block |-- sda -> ../../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda |-- sda1 -> ../../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda/sda1 |-- sda10 -> ../../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda/sda10 |-- sda5 -> ../../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda/sda5 |-- sda6 -> ../../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda/sda6 |-- sda7 -> ../../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda/sda7 |-- sda8 -> ../../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda/sda8 |-- sda9 -> ../../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda/sda9 `-- sr0 -> ../../devices/pci0000:00/0000:00:1f.2/host1/target1:0:0/1:0:0:0/block/sr0 /sys/block/ |-- sda -> ../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda `-- sr0 -> ../devices/pci0000:00/0000:00:1f.2/host1/target1:0:0/1:0:0:0/block/sr0 Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-12-10aoe: properly initialise the request_queue's backing_dev_infoAndrew Morton
AOE forgot to initialise its queue's backing_dev_info, so kernels crash. (http://bugzilla.kernel.org/show_bug.cgi?id=9482) Fix that and consoldate aoeblk_gdalloc()'s error handling. Thanks be to Jon for reporting and testing. Cc: "Ed L. Cashin" <ecashin@coraid.com> Cc: <stable@kernel.org> Cc: "Jon Nelson" <jnelson@jamponi.net> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-10Drop 'size' argument from bio_endio and bi_end_ioNeilBrown
As bi_end_io is only called once when the reqeust is complete, the 'size' argument is now redundant. Remove it. Now there is no need for bio_endio to subtract the size completed from bi_size. So don't do that either. While we are at it, change bi_end_io to return void. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-24[BLOCK] Get rid of request_queue_t typedefJens Axboe
Some of the code has been gradually transitioned to using the proper struct request_queue, but there's lots left. So do a full sweet of the kernel and get rid of this typedef and replace its uses with the proper type. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-11-16aoe: Add forgotten NULL at end of attribute list in aoeblk.cDennis Stosberg
This caused the system to stall when the aoe module was loaded. The error was introduced in commit 4ca5224f3ea4779054d96e885ca9b3980801ce13 Signed-off-by: Dennis Stosberg <dennis@stosberg.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-18aoe: fix sysfs_create_file warningsGreg Kroah-Hartman
Moved the attributes into a group, making the compiler be quiet about ignoring the return value of the file create calls. This also also fixed a bug when removing the files, which were not symlinks. Cc: "Ed L. Cashin" <ecashin@coraid.com> Cc: Alan Cox <alan@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-18aoe: revert printk macrosEd L. Cashin
This patch addresses the concern that the aoe driver should not introduce unecessary conventions that must be learned by the reader. It reverts patch 6. Signed-off-by: "Ed L. Cashin" <ecashin@coraid.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-18aoe: remove sysfs commentEd L. Cashin
Remove unecessary comment. Signed-off-by: "Ed L. Cashin" <ecashin@coraid.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-18aoe: use bio->bi_idxEd L. Cashin
Instead of starting with bio->bi_io_vec, use the offset in bio->bi_idx. Signed-off-by: "Ed L. Cashin" <ecashin@coraid.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-18aoe: clean up printks via macrosEd L. Cashin
Use simple macros to clean up the printks. (This patch is reverted by the 14th patch to follow.) Signed-off-by: "Ed L. Cashin" <ecashin@coraid.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-18aoe: update copyright dateEd L. Cashin
Update the copyright year to 2006. Signed-off-by: "Ed L. Cashin" <ecashin@coraid.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-26[PATCH] mempool: use mempool_create_slab_pool()Matthew Dobson
Modify well over a dozen mempool users to call mempool_create_slab_pool() rather than calling mempool_create() with extra arguments, saving about 30 lines of code and increasing readability. Signed-off-by: Matthew Dobson <colpatch@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] aoe [6/8]: update device information on last closeEd L. Cashin
Instead of making the user wait or do it manually, refresh device information on its last close by issuing a config query to the device. Signed-off-by: "Ed L. Cashin" <ecashin@coraid.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-23[PATCH] aoe [2/8]: support dynamic resizing of AoE devicesEd L. Cashin
Allow the driver to recognize AoE devices that have changed size. Devices not in use are updated automatically, and devices that are in use are updated at user request. Signed-off-by: "Ed L. Cashin" <ecashin@coraid.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-08[PATCH] Add block_device_operations.getgeo block device methodChristoph Hellwig
HDIO_GETGEO is implemented in most block drivers, and all of them have to duplicate the code to copy the structure to userspace, as well as getting the start sector. This patch moves that to common code [1] and adds a ->getgeo method to fill out the raw kernel hd_geometry structure. For many drivers this means ->ioctl can go away now. [1] the s390 block drivers are odd in this respect. xpram sets ->start to 4 always which seems more than odd, and the dasd driver shifts the start offset around, probably because of it's non-standard sector size. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Jens Axboe <axboe@suse.de> Cc: <mike.miller@hp.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo Giarrusso <blaisorblade@yahoo.it> Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-03[PATCH] aoe: add firmware version to info in sysfsEd L Cashin
add firmware version to info in sysfs Signed-off-by: Ed L. Cashin <ecashin@coraid.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-04-18[PATCH] aoe 12/12: send outgoing packets in orderecashin@coraid.com
I can't use list.h, since sk_buff doesn't have a list_head but instead has two struct sk_buff pointers, and I want to avoid any extra memory allocation. send outgoing packets in order Signed-off-by: Ed L. Cashin <ecashin@coraid.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-04-18[PATCH] aoe 11/12: add support for disk statisticsecashin@coraid.com
add support for disk statistics Signed-off-by: Ed L. Cashin <ecashin@coraid.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
