path: root/drivers/bcma/scan.c
2014-07-31bcma: use NS prefix for names of Northstar specific coresRafał Miłecki
It's cleaner and we don't have quite identical names like BCMA_CORE_PCIEG2 and BCMA_CORE_PCIE2. Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-09-09bcma: fix error code handling on 64 Bit systemsHauke Mehrtens
On most 64 Bit systems unsigned long is 64 bit long and then -MAX_ERRNO is out of the range of a u32 used to store the error code in. This patch casts the -MAX_ERRNO to a u32 instead. This fixes a regression introduced in: commit fd4edf197544bae1c77d84bad354aa7ce1d08ce1 Author: Hauke Mehrtens <hauke@hauke-m.de> Date: Mon Jul 15 13:15:08 2013 +0200 bcma: fix handling of big addrl Reported-by: Arend van Spriel <arend@broadcom.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Tested-by: Arend van Spriel <arend@broadcom.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-07-22bcma: fix handling of big addrlHauke Mehrtens
The return value of bcma_erom_get_addr_desc() is a unsigned value and it could wrap around in the two complement writing. This happens for one core in the BCM4708 SoC. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-07-22bcma: add some more core namesHauke Mehrtens
These cores were found on a BCM4708 (chipid 53010), this is a ARM SoC with two Cortex A9 cores. bcma: bus0: Found chip with id 0xCF12, rev 0x00 and package 0x02 bcma: bus0: Core 0 found: ChipCommon (manuf 0x4BF, id 0x800, rev 0x2A, class 0x0) bcma: bus0: Core 1 found: DMA (manuf 0x4BF, id 0x502, rev 0x01, class 0x0) bcma: bus0: Core 2 found: GBit MAC (manuf 0x4BF, id 0x82D, rev 0x04, class 0x0) bcma: bus0: Core 3 found: GBit MAC (manuf 0x4BF, id 0x82D, rev 0x04, class 0x0) bcma: bus0: Core 4 found: GBit MAC (manuf 0x4BF, id 0x82D, rev 0x04, class 0x0) bcma: bus0: Core 5 found: GBit MAC (manuf 0x4BF, id 0x82D, rev 0x04, class 0x0) bcma: bus0: Core 6 found: PCIe Gen 2 (manuf 0x4BF, id 0x501, rev 0x01, class 0x0) bcma: bus0: Core 7 found: PCIe Gen 2 (manuf 0x4BF, id 0x501, rev 0x01, class 0x0) bcma: bus0: Core 8 found: ARM Cortex A9 core (ihost) (manuf 0x4BF, id 0x510, rev 0x01, class 0x0) bcma: bus0: Core 9 found: USB 2.0 (manuf 0x4BF, id 0x504, rev 0x01, class 0x0) bcma: bus0: Core 10 found: USB 3.0 (manuf 0x4BF, id 0x505, rev 0x01, class 0x0) bcma: bus0: Core 11 found: SDIO3 (manuf 0x4BF, id 0x503, rev 0x01, class 0x0) bcma: bus0: Core 12 found: ARM Cortex A9 JTAG (manuf 0x4BF, id 0x506, rev 0x01, class 0x0) bcma: bus0: Core 13 found: Denali DDR2/DDR3 memory controller (manuf 0x4BF, id 0x507, rev 0x01, class 0x0) bcma: bus0: Core 14 found: ROM (manuf 0x4BF, id 0x508, rev 0x01, class 0x0) bcma: bus0: Core 15 found: NAND flash controller (manuf 0x4BF, id 0x509, rev 0x01, class 0x0) bcma: bus0: Core 16 found: SPI flash controller (manuf 0x4BF, id 0x50A, rev 0x01, class 0x0) Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-05-17bcma: add more core IDsRafał Miłecki
PCIe and ARM CR4 cores were found on 14e4:43b1 AKA BCM4352. Reported-by: Gabriel Thörnblad <gabriel@thornblad.com> Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-03-27bcma: mark eromptr as __iomemHauke Mehrtens
This fixes some sparse warnings. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-07-26bcma: add missing iounmap on error pathHauke Mehrtens
This should fix the problem reported by Fengguang: The coccinelle static checker emits these warnings: drivers/bcma/scan.c:466:3-9: ERROR: missing iounmap; ioremap on line 451 and execution via conditional on line 465 drivers/bcma/scan.c:540:3-9: ERROR: missing iounmap; ioremap on line 515 and execution via conditional on line 539 Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-07-12bcma: add new cores at the end of listRafał Miłecki
This makes order in list more natural and fixes core->core_unit for more than 2 cores. Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-07-12bcma: add trivial GBIT MAC COMMON driverRafał Miłecki
GMAC COMMON core is present on BCM4706 and is used for example to access board PHYs (PHYs can not be accessed directly using GBIT MAC core). Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Acked-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-07-09bcma: use custom printing functionsRafał Miłecki
Having bus number printed makes it much easier to anaylze logs on systems with more buses. For example Netgear WNDR4500 has 3 AMBA buses in total, which makes standard log really messy. Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-06-27bcma: define some additional cores IDsRafał Miłecki
Some of them are BCM4706 specific AFAWK. Most of them was confirmed on Netgear WNDR450. Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-05-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull more networking updates from David Miller: "Ok, everything from here on out will be bug fixes." 1) One final sync of wireless and bluetooth stuff from John Linville. These changes have all been in his tree for more than a week, and therefore have had the necessary -next exposure. John was just away on a trip and didn't have a change to send the pull request until a day or two ago. 2) Put back some defines in user exposed header file areas that were removed during the tokenring purge. From Stephen Hemminger and Paul Gortmaker. 3) A bug fix for UDP hash table allocation got lost in the pile due to one of those "you got it.. no I've got it.." situations. :-) From Tim Bird. 4) SKB coalescing in TCP needs to have stricter checks, otherwise we'll try to coalesce overlapping frags and crash. Fix from Eric Dumazet. 5) RCU routing table lookups can race with free_fib_info(), causing crashes when we deref the device pointers in the route. Fix by releasing the net device in the RCU callback. From Yanmin Zhang. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (293 commits) tcp: take care of overlaps in tcp_try_coalesce() ipv4: fix the rcu race between free_fib_info and ip_route_output_slow mm: add a low limit to alloc_large_system_hash ipx: restore token ring define to include/linux/ipx.h if: restore token ring ARP type to header xen: do not disable netfront in dom0 phy/micrel: Fix ID of KSZ9021 mISDN: Add X-Tensions USB ISDN TA XC-525 gianfar:don't add FCB length to hard_header_len Bluetooth: Report proper error number in disconnection Bluetooth: Create flags for bt_sk() Bluetooth: report the right security level in getsockopt Bluetooth: Lock the L2CAP channel when sending Bluetooth: Restore locking semantics when looking up L2CAP channels Bluetooth: Fix a redundant and problematic incoming MTU check Bluetooth: Add support for Foxconn/Hon Hai AR5BBU22 0489:E03C Bluetooth: Fix EIR data generation for mgmt_device_found Bluetooth: Fix Inquiry with RSSI event mask Bluetooth: improve readability of l2cap_seq_list code Bluetooth: Fix skb length calculation ...
2012-05-16bcma: Find names of non BCM coresNathan Hintz
bcma_device_name only provides names for Broadcom cores. Modify logic to provide names for MIPS and ARM cores as well. Signed-off-by: Nathan Hintz <nlhintz@hotmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-04-18bcma: scan for extra address spaceHauke Mehrtens
Some cores like the USB core have two address spaces. In the USB host controller one address space is used for the OHCI and the other for the EHCI controller interface. The USB controller is the only core I found with two address spaces. This code is based on the AI scan function ai_scan() in shared/aiutils.c in the Broadcom SDK. CC: Rafał Miłecki <zajec5@gmail.com> CC: linux-wireless@vger.kernel.org Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-15Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless Conflicts: net/mac80211/debugfs_sta.c net/mac80211/sta_info.h
2012-02-06bcma: log the id, rev and pkg of the chip foundHauke Mehrtens
This makes us see what type of hardware someone uses by the dmesg output. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-02-06bcma: add the core unit numberHauke Mehrtens
Some SoCs have two pcie or gmac cores and we need to know the number of the specific core on the bus. This is the case for the BCM4706. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-02-01bcma: Fix mem leak in bcma_bus_scan()Jesper Juhl
bcma_bus_scan() leaks 'struct bcma_device' bytes if bcma_get_next_core() returns error. Restructure the code so we always kfree() the memory we allocate to the variable 'core' before it goes out of scope. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-24bcma: signedness bug in bcma_get_next_core()Dan Carpenter
The u32 would never be less than zero so the error handling would break. I changed it to s32 to match how bcma_erom_get_mst_port() is declared. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-08bcma: add SOC busHauke Mehrtens
This patch adds support for using bcma on a Broadcom SoC as the system bus. An SoC like the bcm4716 could register this bus and use it to searches for the bcma cores and register the devices on this bus. BCMA_HOSTTYPE_NONE was intended for SoCs at first but BCMA_HOSTTYPE_SOC is a better name. Acked-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-08bcma: add functions to scan cores needed on SoCsHauke Mehrtens
The chip common and mips core have to be setup early in the boot process to get the cpu clock. bcma_bus_early_register() gets pointers to some space to store the core data and searches for the chip common and mips core and initializes chip common. After that was done and the kernel is out of early boot we just have to run bcma_bus_register() and it will search for the other cores, initialize and register them. The cores are getting the same numbers as before. Acked-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-08bcma: move initializing of struct bcma_bus to own function.Hauke Mehrtens
This makes it possible to use this code in some other method. Acked-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-08bcma: move parsing of EEPROM into own function.Hauke Mehrtens
Move the parsing of the EEPROM data in scan function for one core into an own function. Now we are able to use it in some other scan function as well. Acked-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-10bcma: add Broadcom specific AMBA bus driverRafał Miłecki
Broadcom has released cards based on a new AMBA-based bus type. From a programming point of view, this new bus type differs from AMBA and does not use AMBA common registers. It also differs enough from SSB. We decided that a new bus driver is needed to keep the code clean. In its current form, the driver detects devices present on the bus and registers them in the system. It allows registering BCMA drivers for specified bus devices and provides them basic operations. The bus driver itself includes two important bus managing drivers: ChipCommon core driver and PCI(c) core driver. They are early used to allow correct initialization. Currently code is limited to supporting buses on PCI(e) devices, however the driver is designed to be used also on other hosts. The host abstraction layer is implemented and already used for PCI(e). Support for PCI(e) hosts is working and seems to be stable (access to 80211 core was tested successfully on a few devices). We can still optimize it by using some fixed windows, but this can be done later without affecting any external code. Windows are just ranges in MMIO used for accessing cores on the bus. Cc: Greg KH <greg@kroah.com> Cc: Michael Büsch <mb@bu3sch.de> Cc: Larry Finger <Larry.Finger@lwfinger.net> Cc: George Kashperko <george@znau.edu.ua> Cc: Arend van Spriel <arend@broadcom.com> Cc: linux-arm-kernel@lists.infradead.org Cc: Russell King <rmk@arm.linux.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Andy Botting <andy@andybotting.com> Cc: linuxdriverproject <devel@linuxdriverproject.org> Cc: linux-kernel@vger.kernel.org <linux-kernel@vger.kernel.org> Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
