path: root/drivers/base
2012-10-26Merge tag 'pm+acpi-for-3.7-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management and ACPI fixes from Rafael J Wysocki: - Fix for a memory leak in acpi_bind_one() from Jesper Juhl. - Fix for an error code path memory leak in pm_genpd_attach_cpuidle() from Jonghwan Choi. - Fix for smp_processor_id() usage in preemptible code in powernow-k8 from Andreas Herrmann. - Fix for a suspend-related memory leak in cpufreq stats from Xiaobing Tu. - Freezer fix for failure to clear PF_NOFREEZE along with PF_KTHREAD in flush_old_exec() from Oleg Nesterov. - acpi_processor_notify() fix from Alan Cox. * tag 'pm+acpi-for-3.7-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: ACPI: missing break freezer: exec should clear PF_NOFREEZE along with PF_KTHREAD Fix memory leak in cpufreq stats. cpufreq / powernow-k8: Remove usage of smp_processor_id() in preemptible code PM / Domains: Fix memory leak on error path in pm_genpd_attach_cpuidle ACPI: Fix memory leak in acpi_bind_one()
2012-10-26Merge tag 'driver-core-3.7-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core fixes from Greg Kroah-Hartman: "Here are a number of firmware core fixes for 3.7, and some other minor fixes. And some documentation updates thrown in for good measure. All have been in the linux-next tree for a while. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" * tag 'driver-core-3.7-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: Documentation:Chinese translation of Documentation/arm64/memory.txt Documentation:Chinese translation of Documentation/arm64/booting.txt Documentation:Chinese translation of Documentation/IRQ.txt firmware loader: document kernel direct loading sysfs: sysfs_pathname/sysfs_add_one: Use strlcat() instead of strcat() dynamic_debug: Remove unnecessary __used firmware loader: sync firmware cache by async_synchronize_full_domain firmware loader: let direct loading back on 'firmware_buf' firmware loader: fix one reqeust_firmware race firmware loader: cancel uncache work before caching firmware
2012-10-25Merge branch 'fixes_for_linus' of ↵Linus Torvalds
git://git.linaro.org/people/mszyprowski/linux-dma-mapping Pull CMA and DMA-mapping fixes from Marek Szyprowski: "This consists mainly of a set of one-liner fixes and cleanups for a few minor issues identified in both Contiguous Memory Allocator code and ARM DMA-mapping subsystem." * 'fixes_for_linus' of git://git.linaro.org/people/mszyprowski/linux-dma-mapping: ARM: mm: Remove unused arm_vmregion priv field ARM: dma-mapping: fix build warning in __dma_alloc() ARM: dma-mapping: support debug_dma_mapping_error mm: cma: alloc_contig_range: return early for err path drivers: cma: Fix wrong CMA selected region size default value drivers: dma-coherent: Fix typo in dma_mmap_from_coherent documentation drivers: dma-contiguous: Don't redefine SZ_1M
2012-10-23drivers: cma: Fix wrong CMA selected region size default valueLaurent Pinchart
Kconfig lists CMA_SIZE_SEL_ABSOLUTE as the default value fo the CMA selected region size, but that option isn't available in the defined choices. Set the default to CMA_SIZE_SEL_MBYTES instead. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com>
2012-10-23drivers: dma-coherent: Fix typo in dma_mmap_from_coherent documentationLaurent Pinchart
The function documentation incorrectly references dma_release_coherent. Fix it. Don't mention a specific function name as dma_mmap_from_coherent as multiple callers. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com>
2012-10-23drivers: dma-contiguous: Don't redefine SZ_1MLaurent Pinchart
Use the definition from linux/sizes.h instead. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com>
2012-10-23PM / Domains: Fix memory leak on error path in pm_genpd_attach_cpuidlejhbird.choi@samsung.com
If pm_genpd_attach_cpudidle failed we leak memory stored in 'cpu_data'. Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-10-22firmware loader: sync firmware cache by async_synchronize_full_domainMing Lei
async.c has provided synchronization mechanism on async_schedule_*, so use async_synchronize_full_domain to sync caching firmware instead of reinventing the wheel. Signed-off-by: Ming Lei <ming.lei@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-22firmware loader: let direct loading back on 'firmware_buf'Ming Lei
Firstly 'firmware_buf' is introduced to make all loading requests to share one firmware kernel buffer, so firmware_buf should be used in direct loading for saving memory and speedup firmware loading. Secondly, the commit below abb139e75c2cdbb955e840d6331cb5863e409d0e(firmware:teach the kernel to load firmware files directly from the filesystem) introduces direct loading for fixing udev regression, but it bypasses the firmware cache meachnism, so this patch enables caching firmware for direct loading case since it is still needed to solve drivers' dependency during system resume. Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ming Lei <ming.lei@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-22firmware loader: fix one reqeust_firmware raceMing Lei
Several loading requests may be pending on one same firmware buf, and this patch moves fw_map_pages_buf() before complete_all(&fw_buf->completion) and let all requests see the mapped 'buf->data' once the loading is completed. Signed-off-by: Ming Lei <ming.lei@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-22firmware loader: cancel uncache work before caching firmwareMing Lei
Under 'Opportunistic sleep' situation, system sleep might be triggered very frequently, so the uncahce work may not be completed before caching firmware during next suspend. This patch cancels the uncache work before caching firmware to fix the problem above. Also this patch optimizes the cacheing firmware mechanism a bit by only storing one firmware cache entry for one firmware image. So if the firmware is still cached during suspend, it doesn't need to be loaded from user space any more. Signed-off-by: Ming Lei <ming.lei@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-17regmap: select REGMAP if REGMAP_MMIO and REGMAP_IRQ enabledDong Aisheng
The regmap_mmio and regmap_irq depend on regmap core, if not select, we may not compile regmap core and meet compiling errors as follows if REGMAP_MMIO is selected by client drivers: drivers/mfd/syscon.c:94:15: error: variable 'syscon_regmap_config' has initializer but incomplete type drivers/mfd/syscon.c:95:2: error: unknown field 'reg_bits' specified in initializer drivers/mfd/syscon.c:95:2: warning: excess elements in struct initializer [enabled by default] drivers/mfd/syscon.c:95:2: warning: (near initialization for 'syscon_regmap_config') [enabled by default] drivers/mfd/syscon.c:96:2: error: unknown field 'val_bits' specified in initializer drivers/mfd/syscon.c:96:2: warning: excess elements in struct initializer [enabled by default] drivers/mfd/syscon.c:96:2: warning: (near initialization for 'syscon_regmap_config') [enabled by default] drivers/mfd/syscon.c:97:2: error: unknown field 'reg_stride' specified in initializer drivers/mfd/syscon.c:97:2: warning: excess elements in struct initializer [enabled by default] drivers/mfd/syscon.c:97:2: warning: (near initialization for 'syscon_regmap_config') [enabled by default] drivers/mfd/syscon.c: In function 'syscon_probe': drivers/mfd/syscon.c:124:2: error: invalid use of undefined type 'struct regmap_config' drivers/mfd/syscon.c:125:2: error: implicit declaration of function 'devm_regmap_init_mmio' [-Werror=implicit-function-declaration] drivers/mfd/syscon.c:125:17: warning: assignment makes pointer from integer without a cast [enabled by default] cc1: some warnings being treated as errors drivers/mfd/Kconfig: config MFD_SYSCON bool "System Controller Register R/W Based on Regmap" depends on OF select REGMAP_MMIO help Select this option to enable accessing system control registers via regmap. Signed-off-by: Dong Aisheng <dong.aisheng@linaro.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-10-09memory-hotplug: update memory block's state and notify userspaceWen Congyang
remove_memory() will be called when hot removing a memory device. But even if offlining memory, we cannot notice it. So the patch updates the memory block's state and sends notification to userspace. Additionally, the memory device may contain more than one memory block. If the memory block has been offlined, __offline_pages() will fail. So we should try to offline one memory block at a time. Thus remove_memory() also check each memory block's state. So there is no need to check the memory block's state before calling remove_memory(). Signed-off-by: Wen Congyang <wency@cn.fujitsu.com> Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: Jiang Liu <liuj97@gmail.com> Cc: Len Brown <len.brown@intel.com> Cc: Christoph Lameter <cl@linux.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09memory-hotplug: preparation to notify memory block's state at memory hot removeWen Congyang
remove_memory() is called in two cases: 1. echo offline >/sys/devices/system/memory/memoryXX/state 2. hot remove a memory device In the 1st case, the memory block's state is changed and the notification that memory block's state changed is sent to userland after calling remove_memory(). So user can notice memory block is changed. But in the 2nd case, the memory block's state is not changed and the notification is not also sent to userspcae even if calling remove_memory(). So user cannot notice memory block is changed. For adding the notification at memory hot remove, the patch just prepare as follows: 1st case uses offline_pages() for offlining memory. 2nd case uses remove_memory() for offlining memory and changing memory block's state and notifing the information. The patch does not implement notification to remove_memory(). Signed-off-by: Wen Congyang <wency@cn.fujitsu.com> Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: Jiang Liu <liuj97@gmail.com> Cc: Len Brown <len.brown@intel.com> Cc: Christoph Lameter <cl@linux.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-04firmware: use 'kernel_read()' to read firmware into kernel bufferLinus Torvalds
Fengguang correctly points out that the firmware reading should not use vfs_read(), since the buffer is in kernel space. The vfs_read() just happened to work for kernel threads, but sparse warns about the incorrect address spaces, and it's definitely incorrect and could fail for other users of the firmware loading. Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-03firmware: teach the kernel to load firmware files directly from the filesystemLinus Torvalds
This is a first step in allowing people to by-pass udev for loading device firmware. Current versions of udev will deadlock (causing us to block for the 30 second timeout) under some circumstances if the firmware is loaded as part of the module initialization path, and this is causing problems for media drivers in particular. The current patch hardcodes the firmware path that udev uses by default, and will fall back to the legacy udev mode if the firmware cannot be found there. We'd like to add support for both configuring the paths and the fallback behaviour, but in the meantime this hopefully fixes the immediate problem, while also giving us a way forward. [ v2: Some VFS layer interface cleanups suggested by Al Viro ] [ v3: use the default udev paths suggested by Kay Sievers ] Suggested-by: Ivan Kalvachev <ikalvachev@gmail.com> Acked-by: Greg KH <gregkh@linuxfoundation.org> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: Kay Sievers <kay@redhat.com> Cc: Ming Lei <ming.lei@canonical.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs update from Al Viro: - big one - consolidation of descriptor-related logics; almost all of that is moved to fs/file.c (BTW, I'm seriously tempted to rename the result to fd.c. As it is, we have a situation when file_table.c is about handling of struct file and file.c is about handling of descriptor tables; the reasons are historical - file_table.c used to be about a static array of struct file we used to have way back). A lot of stray ends got cleaned up and converted to saner primitives, disgusting mess in android/binder.c is still disgusting, but at least doesn't poke so much in descriptor table guts anymore. A bunch of relatively minor races got fixed in process, plus an ext4 struct file leak. - related thing - fget_light() partially unuglified; see fdget() in there (and yes, it generates the code as good as we used to have). - also related - bits of Cyrill's procfs stuff that got entangled into that work; _not_ all of it, just the initial move to fs/proc/fd.c and switch of fdinfo to seq_file. - Alex's fs/coredump.c spiltoff - the same story, had been easier to take that commit than mess with conflicts. The rest is a separate pile, this was just a mechanical code movement. - a few misc patches all over the place. Not all for this cycle, there'll be more (and quite a few currently sit in akpm's tree)." Fix up trivial conflicts in the android binder driver, and some fairly simple conflicts due to two different changes to the sock_alloc_file() interface ("take descriptor handling from sock_alloc_file() to callers" vs "net: Providing protocol type via system.sockprotoname xattr of /proc/PID/fd entries" adding a dentry name to the socket) * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (72 commits) MAX_LFS_FILESIZE should be a loff_t compat: fs: Generic compat_sys_sendfile implementation fs: push rcu_barrier() from deactivate_locked_super() to filesystems btrfs: reada_extent doesn't need kref for refcount coredump: move core dump functionality into its own file coredump: prevent double-free on an error path in core dumper usb/gadget: fix misannotations fcntl: fix misannotations ceph: don't abuse d_delete() on failure exits hypfs: ->d_parent is never NULL or negative vfs: delete surplus inode NULL check switch simple cases of fget_light to fdget new helpers: fdget()/fdput() switch o2hb_region_dev_write() to fget_light() proc_map_files_readdir(): don't bother with grabbing files make get_file() return its argument vhost_set_vring(): turn pollstart/pollstop into bool switch prctl_set_mm_exe_file() to fget_light() switch xfs_find_handle() to fget_light() switch xfs_swapext() to fget_light() ...
2012-10-02Merge branch 'for-v3.7' of ↵Linus Torvalds
git://git.linaro.org/people/mszyprowski/linux-dma-mapping Pull CMA and DMA-mapping updates from Marek Szyprowski: "This time the pull request is rather small, because the further redesign patches were not ready on time. This pull request consists of the patches which extend ARM DMA-mapping subsystem with support for CPU coherent (ACP) DMA busses. The first client of the new version is HighBank SATA driver. The second part of the pull request includes various cleanup for both CMA common code and ARM DMA-mapping subsystem." Fix up trivial add-add conflict due to the "dma-coherent" DT property being added next to the "calxeda,port-phys" property for the Calxeda AHCI controller. * 'for-v3.7' of git://git.linaro.org/people/mszyprowski/linux-dma-mapping: ARM: dma-mapping: Remove unsed var at arm_coherent_iommu_unmap_page ARM: highbank: add coherent DMA setup ARM: kill off arch_is_coherent ARM: add coherent iommu dma ops ARM: add coherent dma ops ARM: dma-mapping: Refrain noisy console message ARM: dma-mapping: Small logical clean up drivers: dma-contiguous: refactor dma_alloc_from_contiguous()
2012-10-02Merge tag 'pm-for-3.7-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management updates from Rafael J Wysocki: - Improved system suspend/resume and runtime PM handling for the SH TMU, CMT and MTU2 clock event devices (also used by ARM/shmobile). - Generic PM domains framework extensions related to cpuidle support and domain objects lookup using names. - ARM/shmobile power management updates including improved support for the SH7372's A4S power domain containing the CPU core. - cpufreq changes related to AMD CPUs support from Matthew Garrett, Andre Przywara and Borislav Petkov. - cpu0 cpufreq driver from Shawn Guo. - cpufreq governor fixes related to the relaxing of limit from Michal Pecio. - OMAP cpufreq updates from Axel Lin and Richard Zhao. - cpuidle ladder governor fixes related to the disabling of states from Carsten Emde and me. - Runtime PM core updates related to the interactions with the system suspend core from Alan Stern and Kevin Hilman. - Wakeup sources modification allowing more helper functions to be called from interrupt context from John Stultz and additional diagnostic code from Todd Poynor. - System suspend error code path fix from Feng Hong. Fixed up conflicts in cpufreq/powernow-k8 that stemmed from the workqueue fixes conflicting fairly badly with the removal of support for hardware P-state chips. The changes were independent but somewhat intertwined. * tag 'pm-for-3.7-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (76 commits) Revert "PM QoS: Use spinlock in the per-device PM QoS constraints code" PM / Runtime: let rpm_resume() succeed if RPM_ACTIVE, even when disabled, v2 cpuidle: rename function name "__cpuidle_register_driver", v2 cpufreq: OMAP: Check IS_ERR() instead of NULL for omap_device_get_by_hwmod_name cpuidle: remove some empty lines PM: Prevent runtime suspend during system resume PM QoS: Use spinlock in the per-device PM QoS constraints code PM / Sleep: use resume event when call dpm_resume_early cpuidle / ACPI : move cpuidle_device field out of the acpi_processor_power structure ACPI / processor: remove pointless variable initialization ACPI / processor: remove unused function parameter cpufreq: OMAP: remove loops_per_jiffy recalculate for smp sections: fix section conflicts in drivers/cpufreq cpufreq: conservative: update frequency when limits are relaxed cpufreq / ondemand: update frequency when limits are relaxed properly __init-annotate pm_sysrq_init() cpufreq: Add a generic cpufreq-cpu0 driver PM / OPP: Initialize OPP table from device tree ARM: add cpufreq transiton notifier to adjust loops_per_jiffy for smp cpufreq: Remove support for hardware P-state chips from powernow-k8 ...
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace changes from Eric Biederman: "This is a mostly modest set of changes to enable basic user namespace support. This allows the code to code to compile with user namespaces enabled and removes the assumption there is only the initial user namespace. Everything is converted except for the most complex of the filesystems: autofs4, 9p, afs, ceph, cifs, coda, fuse, gfs2, ncpfs, nfs, ocfs2 and xfs as those patches need a bit more review. The strategy is to push kuid_t and kgid_t values are far down into subsystems and filesystems as reasonable. Leaving the make_kuid and from_kuid operations to happen at the edge of userspace, as the values come off the disk, and as the values come in from the network. Letting compile type incompatible compile errors (present when user namespaces are enabled) guide me to find the issues. The most tricky areas have been the places where we had an implicit union of uid and gid values and were storing them in an unsigned int. Those places were converted into explicit unions. I made certain to handle those places with simple trivial patches. Out of that work I discovered we have generic interfaces for storing quota by projid. I had never heard of the project identifiers before. Adding full user namespace support for project identifiers accounts for most of the code size growth in my git tree. Ultimately there will be work to relax privlige checks from "capable(FOO)" to "ns_capable(user_ns, FOO)" where it is safe allowing root in a user names to do those things that today we only forbid to non-root users because it will confuse suid root applications. While I was pushing kuid_t and kgid_t changes deep into the audit code I made a few other cleanups. I capitalized on the fact we process netlink messages in the context of the message sender. I removed usage of NETLINK_CRED, and started directly using current->tty. Some of these patches have also made it into maintainer trees, with no problems from identical code from different trees showing up in linux-next. After reading through all of this code I feel like I might be able to win a game of kernel trivial pursuit." Fix up some fairly trivial conflicts in netfilter uid/git logging code. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (107 commits) userns: Convert the ufs filesystem to use kuid/kgid where appropriate userns: Convert the udf filesystem to use kuid/kgid where appropriate userns: Convert ubifs to use kuid/kgid userns: Convert squashfs to use kuid/kgid where appropriate userns: Convert reiserfs to use kuid and kgid where appropriate userns: Convert jfs to use kuid/kgid where appropriate userns: Convert jffs2 to use kuid and kgid where appropriate userns: Convert hpfs to use kuid and kgid where appropriate userns: Convert btrfs to use kuid/kgid where appropriate userns: Convert bfs to use kuid/kgid where appropriate userns: Convert affs to use kuid/kgid wherwe appropriate userns: On alpha modify linux_to_osf_stat to use convert from kuids and kgids userns: On ia64 deal with current_uid and current_gid being kuid and kgid userns: On ppc convert current_uid from a kuid before printing. userns: Convert s390 getting uid and gid system calls to use kuid and kgid userns: Convert s390 hypfs to use kuid and kgid where appropriate userns: Convert binder ipc to use kuids userns: Teach security_path_chown to take kuids and kgids userns: Add user namespace support to IMA userns: Convert EVM to deal with kuids and kgids in it's hmac computation ...
2012-10-02drivers: dma-contiguous: refactor dma_alloc_from_contiguous()Michal Nazarewicz
The dma_alloc_from_contiguous() function returns either a valid pointer to a page structure or NULL, the error code set when pageno >= cma->count is not used at all and can be safely removed. This commit also changes the function to avoid goto and have only one exit path and one place where mutex is unlocked. Signed-off-by: Michal Nazarewicz <mina86@mina86.com> [fixed compilation break caused by missing semicolon] Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com>
2012-10-01Merge tag 'driver-core-3.6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core merge from Greg Kroah-Hartman: "Here is the big driver core update for 3.7-rc1. A number of firmware_class.c updates (as you saw a month or so ago), and some hyper-v updates and some printk fixes as well. All patches that are outside of the drivers/base area have been acked by the respective maintainers, and have all been in the linux-next tree for a while. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" * tag 'driver-core-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (95 commits) memory: tegra{20,30}-mc: Fix reading incorrect register in mc_readl() device.h: Add missing inline to #ifndef CONFIG_PRINTK dev_vprintk_emit memory: emif: Add ifdef CONFIG_DEBUG_FS guard for emif_debugfs_[init|exit] Documentation: Fixes some translation error in Documentation/zh_CN/gpio.txt Documentation: Remove 3 byte redundant code at the head of the Documentation/zh_CN/arm/booting Documentation: Chinese translation of Documentation/video4linux/omap3isp.txt device and dynamic_debug: Use dev_vprintk_emit and dev_printk_emit dev: Add dev_vprintk_emit and dev_printk_emit netdev_printk/netif_printk: Remove a superfluous logging colon netdev_printk/dynamic_netdev_dbg: Directly call printk_emit dev_dbg/dynamic_debug: Update to use printk_emit, optimize stack driver-core: Shut up dev_dbg_reatelimited() without DEBUG tools/hv: Parse /etc/os-release tools/hv: Check for read/write errors tools/hv: Fix exit() error code tools/hv: Fix file handle leak Tools: hv: Implement the KVP verb - KVP_OP_GET_IP_INFO Tools: hv: Rename the function kvp_get_ip_address() Tools: hv: Implement the KVP verb - KVP_OP_SET_IP_INFO Tools: hv: Add an example script to configure an interface ...
2012-09-26make get_file() return its argumentAl Viro
simplifies a bunch of callers... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-09-24Merge branch 'pm-qos'Rafael J. Wysocki
* pm-qos: Revert "PM QoS: Use spinlock in the per-device PM QoS constraints code"
2012-09-24Revert "PM QoS: Use spinlock in the per-device PM QoS constraints code"Rafael J. Wysocki
This reverts commit fc2fb3a075c206927d3fbad251dae82ba82ccf2d. The problem with the above commit is that it makes the device PM QoS core code hold a spinlock around blocking_notifier_call_chain() invocations. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2012-09-24Merge branch 'pm-sleep'Rafael J. Wysocki
* pm-sleep: PM: Prevent runtime suspend during system resume PM / Sleep: use resume event when call dpm_resume_early Conflicts: drivers/base/power/main.c (trivial)
2012-09-24Merge branch 'pm-runtime'Rafael J. Wysocki
* pm-runtime: PM / Runtime: let rpm_resume() succeed if RPM_ACTIVE, even when disabled, v2
* pm-qos: PM QoS: Use spinlock in the per-device PM QoS constraints code
2012-09-22PM / Runtime: let rpm_resume() succeed if RPM_ACTIVE, even when disabled, v2Kevin Hilman
There are several drivers where the return value of pm_runtime_get_sync() is used to decide whether or not it is safe to access hardware and that don't provide .suspend() callbacks for system suspend (but may use late/noirq callbacks.) If such a driver happens to call pm_runtime_get_sync() during system suspend, after the core has disabled runtime PM, it will get the error code and will decide that the hardware should not be accessed, although this may be a wrong conclusion, depending on the state of the device when runtime PM was disabled. Drivers might work around this problem by using a test like: ret = pm_runtime_get_sync(dev); if (!ret || (ret == -EACCES && driver_private_data(dev)->suspended)) { /* access hardware */ } where driver_private_data(dev)->suspended is a flag set by the driver's .suspend() method (that would have to be added for this purpose). However, that potentially would need to be done by multiple drivers which means quite a lot of duplicated code and bloat. To avoid that we can use the observation that the core sets dev->power.is_suspended before disabling runtime PM and use that instead of the driver's private flag. Still, potentially many drivers would need to repeat that same check in quite a few places, so it's better to let the core do it. Then we can be a bit smarter and check whether or not runtime PM was disabled by the core only (disable_depth == 1) or by someone else in addition to the core (disable_depth > 1). In the former case rpm_resume() can return 1 if the runtime PM status is RPM_ACTIVE, because it means the device was active when the core disabled runtime PM. In the latter case it should still return -EACCES, because it isn't clear why runtime PM has been disabled. Tested on AM3730/Beagle-xM where a wakeup IRQ firing during the late suspend phase triggers runtime PM activity in the I2C driver since the wakeup IRQ is on an I2C-connected PMIC. [rjw: Modified whitespace to follow the file's convention.] Signed-off-by: Kevin Hilman <khilman@ti.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2012-09-22Merge remote-tracking branches 'regmap/topic/cache' and 'regmap/topic/irq' ↵Mark Brown
into regmap-next
2012-09-21userns: Convert devtmpfs to use GLOBAL_ROOT_UID and GLOBAL_ROOT_GIDEric W. Biederman
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-09-19PM: Prevent runtime suspend during system resumeAlan Stern
This patch (as1591) moves the pm_runtime_get_noresume() and pm_runtime_put_sync() calls from __device_suspend() and device_resume() to device_prepare() and device_complete() in the PM core. The reason for doing this is to make sure that parent devices remain at full power (i.e., don't go into runtime suspend) while their children are being resumed from a system sleep. The PCI core already contained equivalent code to serve the same purpose. The patch removes the duplicated code, since it is no longer needed. One of the comments from the PCI core gets moved into the PM core, and a second comment is added to explain whe the _get_noresume and _put_sync calls are present. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2012-09-19PM QoS: Use spinlock in the per-device PM QoS constraints codeJean Pihet
The per-device PM QoS locking requires a spinlock to be used. The reasons are: - an alignement with the PM QoS core code, which is used by the per-device PM QoS code for the constraints lists management. The PM QoS core code uses spinlocks to protect the constraints lists, - some drivers need to use the per-device PM QoS functionality from interrupt context or spinlock protected context. An example of such a driver is the OMAP HSI (high-speed synchronous serial interface) driver which needs to control the IP block idle state depending on the FIFO empty state, from interrupt context. Reported-by: Djamil Elaidi <d-elaidi@ti.com> Signed-off-by: Jean Pihet <j-pihet@ti.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2012-09-19PM / Sleep: use resume event when call dpm_resume_earlyFeng Hong
When dpm_suspend_noirq fail, state is PMSG_SUSPEND, should change to PMSG_RESUME when dpm_resume_early is called Signed-off-by: Feng Hong <hongfeng@marvell.com> Signed-off-by: Raul Xiong <xjian@marvell.com> Signed-off-by: Neil Zhang <zhangwm@marvell.com> Cc: stable@vger.kernel.org Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2012-09-17Merge branch 'pm-cpufreq'Rafael J. Wysocki
* pm-cpufreq: cpufreq: OMAP: remove loops_per_jiffy recalculate for smp sections: fix section conflicts in drivers/cpufreq cpufreq: conservative: update frequency when limits are relaxed cpufreq / ondemand: update frequency when limits are relaxed cpufreq: Add a generic cpufreq-cpu0 driver PM / OPP: Initialize OPP table from device tree ARM: add cpufreq transiton notifier to adjust loops_per_jiffy for smp cpufreq: Remove support for hardware P-state chips from powernow-k8 acpi-cpufreq: Add compatibility for legacy AMD cpb sysfs knob acpi-cpufreq: Add support for disabling dynamic overclocking ACPI: Add fixups for AMD P-state figures powernow-k8: delay info messages until initialization has succeeded cpufreq: Add warning message to powernow-k8 acpi-cpufreq: Add quirk to disable _PSD usage on all AMD CPUs acpi-cpufreq: Add support for modern AMD CPUs cpufreq / powernow-k8: Fixup missing _PSS objects message PM / cpufreq: Initialise the cpu field during conservative governor start
2012-09-17Merge branch 'pm-sleep'Rafael J. Wysocki
* pm-sleep: properly __init-annotate pm_sysrq_init() PM / wakeup: Use irqsave/irqrestore for events_lock PM / Freezer: Fix small typo "regrigerator" PM / Sleep: Print name of wakeup source that aborts suspend
2012-09-17Merge branch 'pm-domains'Rafael J. Wysocki
* pm-domains: PM / Domains: Fix compilation warning related to genpd_start_dev_no_timing() PM / Domains: Operations related to cpuidle using domain names PM / Domains: Document cpuidle-related functions and change their names PM / Domains: Add power-on function using names to identify domains PM / Domains: Make it possible to use names when adding subdomains PM / Domains: Make it possible to use domain names when adding devices
2012-09-17Merge branch 'pm-timers'Rafael J. Wysocki
* pm-timers: PM: Do not use the syscore flag for runtime PM sh: MTU2: Basic runtime PM support sh: CMT: Basic runtime PM support sh: TMU: Basic runtime PM support PM / Domains: Do not measure start time for "irq safe" devices PM / Domains: Move syscore flag from subsys data to struct device PM / Domains: Rename the always_on device flag to syscore PM / Runtime: Allow helpers to be called by early platform drivers PM: Reorganize device PM initialization sh: MTU2: Introduce clock events suspend/resume routines sh: CMT: Introduce clocksource/clock events suspend/resume routines sh: TMU: Introduce clocksource/clock events suspend/resume routines timekeeping: Add suspend and resume of clock event devices PM / Domains: Add power off/on function for system core suspend stage PM / Domains: Introduce simplified power on routine for system resume
2012-09-17device and dynamic_debug: Use dev_vprintk_emit and dev_printk_emitJoe Perches
Convert direct calls of vprintk_emit and printk_emit to the dev_ equivalents. Make create_syslog_header static. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: David S. Miller <davem@davemloft.net> Tested-by: Jim Cromie <jim.cromie@gmail.com> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-17dev: Add dev_vprintk_emit and dev_printk_emitJoe Perches
Add utility functions to consolidate the use of create_syslog_header and vprintk_emit. This allows conversion of logging functions that call create_syslog_header and then call vprintk_emit or printk_emit to the dev_ equivalents. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: David S. Miller <davem@davemloft.net> Tested-by: Jim Cromie <jim.cromie@gmail.com> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-17dev_dbg/dynamic_debug: Update to use printk_emit, optimize stackJoe Perches
commit c4e00daaa9 ("driver-core: extend dev_printk() to pass structured data") changed __dev_printk and broke dynamic-debug's ability to control the dynamic prefix of dev_dbg(dev,..). commit af7f2158fd ("drivers-core: make structured logging play nice with dynamic-debug") made a minimal correction. The current dynamic debug code uses up to 3 recursion levels via %pV. This can consume quite a bit of stack. Directly call printk_emit to reduce the recursion depth. These changes include: dev_dbg: o Create and use function create_syslog_header to format the syslog header for printk_emit uses. o Call create_syslog_header and neaten __dev_printk o Make __dev_printk static not global o Remove include header declaration of __dev_printk o Remove now unused EXPORT_SYMBOL() of __dev_printk o Whitespace neatening dynamic_dev_dbg: o Remove KERN_DEBUG from dynamic_emit_prefix o Call create_syslog_header and printk_emit o Whitespace neatening Signed-off-by: Joe Perches <joe@perches.com> Acked-by: David S. Miller <davem@davemloft.net> Tested-by: Jim Cromie <jim.cromie@gmail.com> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-16Merge 3.6-rc7 into driver-core-nextGreg Kroah-Hartman
This pulls in the fixes in that branch that are needed here as well. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-10firmware loader: fix compile warning when CONFIG_PM=nMing Lei
This patch replaces the previous macro of CONFIG_PM with CONFIG_PM_SLEEP becasue firmware cache is only used in system sleep situations. Also this patch fixes the below compile warning when CONFIG_PM=n: drivers/base/firmware_class.c:1147: warning: 'device_cache_fw_images' defined but not used drivers/base/firmware_class.c:1212: warning: 'device_uncache_fw_images_delay' defined but not used Reported-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ming Lei <ming.lei@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-09PM / OPP: Initialize OPP table from device treeShawn Guo
With a lot of devices booting from device tree nowadays, it requires that OPP table can be initialized from device tree. The patch adds a helper function of_init_opp_table together with a binding doc for that purpose. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2012-09-09regmap: no need primary handler for nested irqYunfan Zhang
The primary handler will NOT be called if the interrupt nests into another interrupt thread. Remove it to avoid confusing. Signed-off-by: Yunfan Zhang <yfzhang@marvell.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-09-06firmware loader: let caching firmware piggyback on loading firmwareMing Lei
After starting caching firmware, there is still some time left before devices are suspended, during the period, request_firmware or its nowait version may still be triggered by the below situations to load firmware images which can't be cached during suspend/resume cycle. - new devices added - driver bind - or device open kind of things This patch utilizes the piggyback trick to cache firmware for this kind of situation: just increase the firmware buf's reference count and add the fw name entry into cache entry list after starting caching firmware and before syscore_suspend() is called. Signed-off-by: Ming Lei <ming.lei@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-06firmware loader: fix firmware -ENOENT situationsMing Lei
If the requested firmware image doesn't exist, firmware->priv should be set for the later concurrent requests, otherwise warning and oops will be triggered inside firmware_free_data(). Signed-off-by: Ming Lei <ming.lei@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-06PM / wakeup: Use irqsave/irqrestore for events_lockJohn Stultz
Jon Medhurst (Tixy) recently noticed a problem with the events_lock usage. One of the Android patches that uses wakeup_sources calls wakeup_source_add() with irqs disabled. However, the event_lock usage in wakeup_source_add() uses spin_lock_irq()/spin_unlock_irq(), which reenables interrupts. This results in lockdep warnings. The fix is to use spin_lock_irqsave()/spin_lock_irqrestore() instead for the events_lock. References: https://bugs.launchpad.net/linaro-landing-team-arm/+bug/1037565 Reported-and-debugged-by: Jon Medhurst (Tixy) <tixy@linaro.org> Signed-off-by: John Stultz <john.stultz@linaro.org> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2012-09-06PM / Domains: Fix compilation warning related to genpd_start_dev_no_timing()Sachin Kamat
Function genpd_start_dev_no_timing was accessed inside CONFIG_PM_RUNTIME macro but defined outside it. When the above macro was not defined the compiler gave the following warning: drivers/base/power/domain.c:96:12: warning: ‘genpd_start_dev_no_timing’ defined but not used [-Wunused-function] Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2012-09-06driver core: Check if r->name is valid in platform_get_resource_byname()Peter Ujfalusi
Safety check for the validity of the resource name before calling strcmp(). If the resource name is NULL do not compare it, just skip it. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
