commit eea915bb0d1358755f151eaefb8208a2d5f3e10c upstream.
This oops was reported recently:
firmware_loading_store+0xf9/0x17b
dev_attr_store+0x20/0x22
sysfs_write_file+0x101/0x134
vfs_write+0xac/0xf3
sys_write+0x4a/0x6e
system_call_fastpath+0x16/0x1b
The complete backtrace was unfortunately not captured, but details can be found
here:
https://bugzilla.redhat.com/show_bug.cgi?id=769920
The cause is fairly clear.
Its caused by the fact that firmware_loading_store has a case 0 in its
switch statement that reads and writes the fw_priv->fw poniter without the
protection of the fw_lock mutex. since there is a window between the time that
_request_firmware sets fw_priv->fw to NULL and the time the corresponding sysfs
file is unregistered, its possible for a user space application to race in, and
write a zero to the loading file, causing a NULL dereference in
firmware_loading_store. Fix it by extending the protection of the fw_lock mutex
to cover all of the firware_loading_store function.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Disabling all runtime PM during system shutdown turns out not to be a
good idea, because some devices may need to be woken up from a
low-power state at that time.
The whole point of disabling runtime PM for system shutdown was to
prevent untimely runtime-suspend method calls. This patch (as1504)
accomplishes the same result by incrementing the usage count for each
device and waiting for ongoing runtime-PM callbacks to finish. This
is what we already do during system suspend and hibernation, which
makes sense since the shutdown method is pretty much a legacy analog
of the pm->poweroff method.
This fixes a recent regression on some OMAP systems introduced by
commit af8db1508f2c9f3b6e633e2d2d906c6557c617f9 (PM / driver core:
disable device's runtime PM during shutdown).
Reported-and-tested-by: NeilBrown <neilb@suse.de>
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
* 'driver-core-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core:
drivers/base/node.c: fix compilation error with older versions of gcc
uio: documentation fixups
device.h: Fix struct member documentation
Patch to fix the error message "directives may not be used inside a macro
argument" which appears when the kernel is compiled for the cris architecture.
Signed-off-by: Claudio Scordino <claudio@evidence.eu.com>
Acked-by: David Rientjes <rientjes@google.com>
Cc: stable <stable@vger.kernel.org>
Commit 4ca46ff3e0d8c234cb40ebb6457653b59584426c (PM / Sleep: Mark
devices involved in wakeup signaling during suspend) introduced
the power.wakeup_path field in struct dev_pm_info to mark devices
whose children are enabled to wake up the system from sleep states,
so that power domains containing the parents that provide their
children with wakeup power and/or relay their wakeup signals are not
turned off. Unfortunately, that introduced a PM regression on SH7372
whose power consumption in the system "memory sleep" state increased
as a result of it, because it prevented the power domain containing
the I2C controller from being turned off when some children of that
controller were enabled to wake up the system, although the
controller was not necessary for them to signal wakeup.
To fix this issue use the observation that devices whose
power.ignore_children flag is set for runtime PM should be treated
analogously during system suspend. Namely, they shouldn't be
included in wakeup paths going through their children. Since the
SH7372 I2C controller's power.ignore_children flag is set, doing so
will restore the previous behavior of that SOC.
There may be an issue when the user issue "reboot/shutdown" command, then
the device has shut down its hardware, after that, this runtime-pm featured
device's driver will probably be scheduled to do its suspend routine,
and at its suspend routine, it may access hardware, but the device has
already shutdown physically, then the system hang may be occurred.
I ran out this issue using an auto-suspend supported USB devices, like
3G modem, keyboard. The usb runtime suspend routine may be scheduled
after the usb controller has been shut down, and the usb runtime suspend
routine will try to suspend its roothub(controller), it will access
register, then the system hang occurs as the controller is shutdown.
Signed-off-by: Peter Chen <peter.chen@freescale.com>
Acked-by: Ming Lei <tom.leiming@gmail.com>
Cc: stable@kernel.org
Make dev_pm_qos_add_request() use WARN() in a better way and do not hardcode
the function's name into the message (use __func__ instead).
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Refrain from running clk_disable() on clocks that
have not been enabled. A typical case when this can
happen is during Suspend-to-RAM for devices that have
no driver associated with them. In such case the clock
may be in default ACQUIRED state.
Without this patch the sh7372 Mackerel board crashes
in __clk_disable() during Suspend-to-RAM with:
"Trying to disable clock 0xdeadbeef with 0 usecount"
This happens for the CEU device which is added during
boot. The test case has no CEU driver included in the
kernel configuration. Needed for v3.2-rc1.
Signed-off-by: Magnus Damm <damm@opensource.se>
Use ERR_CAST inlined function instead of ERR_PTR(PTR_ERR(...))
[The semantic patch that makes this change is available
in scripts/coccinelle/api/err_cast.cocci.
More information about semantic patching is available at
http://coccinelle.lip6.fr/]
Signed-off-by: Thomas Meyer <thomas@m3y3r.de>
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
* 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits)
Revert "tracing: Include module.h in define_trace.h"
irq: don't put module.h into irq.h for tracking irqgen modules.
bluetooth: macroize two small inlines to avoid module.h
ip_vs.h: fix implicit use of module_get/module_put from module.h
nf_conntrack.h: fix up fallout from implicit moduleparam.h presence
include: replace linux/module.h with "struct module" wherever possible
include: convert various register fcns to macros to avoid include chaining
crypto.h: remove unused crypto_tfm_alg_modname() inline
uwb.h: fix implicit use of asm/page.h for PAGE_SIZE
pm_runtime.h: explicitly requires notifier.h
linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h
miscdevice.h: fix up implicit use of lists and types
stop_machine.h: fix implicit use of smp.h for smp_processor_id
of: fix implicit use of errno.h in include/linux/of.h
of_platform.h: delete needless include <linux/module.h>
acpi: remove module.h include from platform/aclinux.h
miscdevice.h: delete unnecessary inclusion of module.h
device_cgroup.h: delete needless include <linux/module.h>
net: sch_generic remove redundant use of <linux/module.h>
net: inet_timewait_sock doesnt need <linux/module.h>
Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in
- drivers/media/dvb/frontends/dibx000_common.c
- drivers/media/video/{mt9m111.c,ov6650.c}
- drivers/mfd/ab3550-core.c
- include/linux/dmaengine.h
Originally, the runtime PM core would send an idle notification
whenever a suspend attempt failed. The idle callback routine could
then schedule a delayed suspend for some time later.
However this behavior was changed by commit
f71648d73c1650b8b4aceb3856bebbde6daa3b86 (PM / Runtime: Remove idle
notification after failing suspend). No notifications were sent, and
there was no clear mechanism to retry failed suspends.
This caused problems for the usbhid driver, because it fails
autosuspend attempts as long as a key is being held down. Therefore
this patch (as1492) adds a mechanism for retrying failed
autosuspends. If the callback routine updates the last_busy field so
that the next autosuspend expiration time is in the future, the
autosuspend will automatically be rescheduled.
Tested-by: Henrik Rydberg <rydberg@euromail.se>
Cc: <stable@kernel.org>
With delta type being int, its value is made zero
for all values of now > 0x80000000.
Hence fixing it.
Signed-off-by: venu byravarasu <vbyravarasu@nvidia.com>
This file isn't using full modular functionality, and hence
can be "downgraded" to just using export.h
This file is currently relying on <linux/module.h> sneaking it in
through the implicit include paths from device.h. Once that
is cleaned up, this will happen:
In file included from drivers/base/init.c:12:
drivers/base/base.h:34: error: field ‘bus_notifier’ has incomplete type
make[3]: *** [drivers/base/init.o] Error 1
Fix it up in advance, so the cleanup can continue.
It was implicitly getting it before, but it will break compiles
once we fix that.
Most of these files were implicitly getting EXPORT_SYMBOL via
device.h which was including module.h, but that path will be broken
soon.
[ with input from Stephen Rothwell <sfr@canb.auug.org.au> ]
This file was getting <linux/module.h> via an implicit include
path, but we want to crush those out of existence since they cost
time during compiles of processing thousands of lines of headers
for no reason. Give it the lightweight header that just contains
the EXPORT_SYMBOL infrastructure.
* 'pm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (63 commits)
PM / Clocks: Remove redundant NULL checks before kfree()
PM / Documentation: Update docs about suspend and CPU hotplug
ACPI / PM: Add Sony VGN-FW21E to nonvs blacklist.
ARM: mach-shmobile: sh7372 A4R support (v4)
ARM: mach-shmobile: sh7372 A3SP support (v4)
PM / Sleep: Mark devices involved in wakeup signaling during suspend
PM / Hibernate: Improve performance of LZO/plain hibernation, checksum image
PM / Hibernate: Do not initialize static and extern variables to 0
PM / Freezer: Make fake_signal_wake_up() wake TASK_KILLABLE tasks too
PM / Hibernate: Add resumedelay kernel param in addition to resumewait
MAINTAINERS: Update linux-pm list address
PM / ACPI: Blacklist Vaio VGN-FW520F machine known to require acpi_sleep=nonvs
PM / ACPI: Blacklist Sony Vaio known to require acpi_sleep=nonvs
PM / Hibernate: Add resumewait param to support MMC-like devices as resume file
PM / Hibernate: Fix typo in a kerneldoc comment
PM / Hibernate: Freeze kernel threads after preallocating memory
PM: Update the policy on default wakeup settings
PM / VT: Cleanup #if defined uglyness and fix compile error
PM / Suspend: Off by one in pm_suspend()
PM / Hibernate: Include storage keys in hibernation image on s390
* 'for-linus' of git://opensource.wolfsonmicro.com/regmap: (62 commits)
mfd: Enable rbtree cache for wm831x devices
regmap: Support some block operations on cached devices
regmap: Allow caches for devices with no defaults
regmap: Ensure rbtree syncs registers set to zero properly
regmap: Allow rbtree to cache zero default values
regmap: Warn on raw I/O as well as bulk reads that bypass cache
regmap: Return a sensible error code if we fail to read the cache
regmap: Use bsearch() to search the register defaults
regmap: Fix doc comment
regmap: Optimize the lookup path to use binary search
regmap: Ensure we scream if we enable cache bypass/only at the same time
regmap: Implement regcache_cache_bypass helper function
regmap: Save/restore the bypass state upon syncing
regmap: Lock the sync path, ensure we use the lockless _regmap_write()
regmap: Fix apostrophe usage
regmap: Make _regmap_write() global
regmap: Fix lock used for regcache_cache_only()
regmap: Grab the lock in regcache_cache_only()
regmap: Modify map->cache_bypass directly
regmap: Fix regcache_sync generic implementation
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1745 commits)
dp83640: free packet queues on remove
dp83640: use proper function to free transmit time stamping packets
ipv6: Do not use routes from locally generated RAs
|PATCH net-next] tg3: add tx_dropped counter
be2net: don't create multiple RX/TX rings in multi channel mode
be2net: don't create multiple TXQs in BE2
be2net: refactor VF setup/teardown code into be_vf_setup/clear()
be2net: add vlan/rx-mode/flow-control config to be_setup()
net_sched: cls_flow: use skb_header_pointer()
ipv4: avoid useless call of the function check_peer_pmtu
TCP: remove TCP_DEBUG
net: Fix driver name for mdio-gpio.c
ipv4: tcp: fix TOS value in ACK messages sent from TIME_WAIT
rtnetlink: Add missing manual netlink notification in dev_change_net_namespaces
ipv4: fix ipsec forward performance regression
jme: fix irq storm after suspend/resume
route: fix ICMP redirect validation
net: hold sock reference while processing tx timestamps
tcp: md5: add more const attributes
Add ethtool -g support to virtio_net
Fix up conflicts in:
- drivers/net/Kconfig:
The split-up generated a trivial conflict with removal of a
stale reference to Documentation/networking/net-modules.txt.
Remove it from the new location instead.
- fs/sysfs/dir.c:
Fairly nasty conflicts with the sysfs rb-tree usage, conflicting
with Eric Biederman's changes for tagged directories.
* 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (38 commits)
mm: memory hotplug: Check if pages are correctly reserved on a per-section basis
Revert "memory hotplug: Correct page reservation checking"
Update email address for stable patch submission
dynamic_debug: fix undefined reference to `__netdev_printk'
dynamic_debug: use a single printk() to emit messages
dynamic_debug: remove num_enabled accounting
dynamic_debug: consolidate repetitive struct _ddebug descriptor definitions
uio: Support physical addresses >32 bits on 32-bit systems
sysfs: add unsigned long cast to prevent compile warning
drivers: base: print rejected matches with DEBUG_DRIVER
memory hotplug: Refuse to add unaligned memory regions
remove the messy code file Documentation/zh_CN/SubmitChecklist
ARM: mxc: convert device creation to use platform_device_register_full
new helper to create platform devices with dma mask
docs/driver-model: Update device class docs
docs/driver-model: Document device.groups
kobj_uevent: Ignore if some listeners cannot handle message
dynamic_debug: make netif_dbg() call __netdev_printk()
dynamic_debug: make netdev_dbg() call __netdev_printk()
Since kfree() checks it its argument is not NULL, it is not necessary
to duplicate this check in __pm_clk_remove().
[rjw: Added the changelog.]
Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com>
* pm-domains:
The generic PM domains code in drivers/base/power/domain.c has
to avoid powering off domains that provide power to wakeup devices
during system suspend. Currently, however, this only works for
wakeup devices directly belonging to the given domain and not for
their children (or the children of their children and so on).
Thus, if there's a wakeup device whose parent belongs to a power
domain handled by the generic PM domains code, the domain will be
powered off during system suspend preventing the device from
signaling wakeup.
To address this problem introduce a device flag, power.wakeup_path,
that will be set during system suspend for all wakeup devices,
their parents, the parents of their parents and so on. This way,
all wakeup paths in the device hierarchy will be marked and the
generic PM domains code will only need to avoid powering off
domains containing devices whose power.wakeup_path is set.
(Resending as I am not seeing it in -next so maybe it got lost)
It is expected that memory being brought online is PageReserved
similar to what happens when the page allocator is being brought up.
Memory is onlined in "memory blocks" which consist of one or more
sections. Unfortunately, the code that verifies PageReserved is
currently assuming that the memmap backing all these pages is virtually
contiguous which is only the case when CONFIG_SPARSEMEM_VMEMMAP is set.
As a result, memory hot-add is failing on those configurations with
the message;
kernel: section number XXX page number 256 not reserved, was it already online?
This patch updates the PageReserved check to lookup struct page once
per section to guarantee the correct struct page is being checked.
[Check pages within sections properly: rientjes@google.com]
[original patch by: nfont@linux.vnet.ibm.com]
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Tested-by: Nathan Fontenot <nfont@linux.vnet.ibm.com>
This reverts commit 54f23eb7ba7619de85d8edca6e5336bc33072dbd.
Turns out this patch is wrong, another correct one will follow it.
This patch (as1485) documents a change to the kernel's default wakeup
policy. Devices that forward wakeup requests between buses should be
enabled for wakeup by default.
Record S3 failure time about each reason and the latest two failed
devices' names in S3 progress.
We can check it through 'suspend_stats' entry in debugfs.
The motivation of the patch:
We are enabling power features on Medfield. Comparing with PC/notebook,
a mobile enters/exits suspend-2-ram (we call it s3 on Medfield) far
more frequently. If it can't enter suspend-2-ram in time, the power
might be used up soon.
We often find sometimes, a device suspend fails. Then, system retries
s3 over and over again. As display is off, testers and developers
don't know what happens.
Some testers and developers complain they don't know if system
tries suspend-2-ram, and what device fails to suspend. They need
such info for a quick check. The patch adds suspend_stats under
debugfs for users to check suspend to RAM statistics quickly.
If not using this patch, we have other methods to get info about
what device fails. One is to turn on CONFIG_PM_DEBUG, but users
would get too much info and testers need recompile the system.
In addition, dynamic debug is another good tool to dump debug info.
But it still doesn't match our utilization scenario closely.
1) user need write a user space parser to process the syslog output;
2) Our testing scenario is we leave the mobile for at least hours.
Then, check its status. No serial console available during the
testing. One is because console would be suspended, and the other
is serial console connecting with spi or HSU devices would consume
power. These devices are powered off at suspend-2-ram.
Signed-off-by: ShuoX Liu <shuox.liu@intel.com>
* pm-runtime:
PM / Runtime: Handle .runtime_suspend() failure correctly
PM / Runtime: Fix kerneldoc comment for rpm_suspend()
PM / Runtime: Update document about callbacks
If .runtime_suspend() returns -EAGAIN or -EBUSY, the device should
still be in ACTIVE state, so it is not necessary to send an idle
notification to its parent. If .runtime_suspend() returns other
fatal failure, it doesn't make sense to send idle notification to
its parent.
Skip parent idle notification when failure is returned from
.runtime_suspend() and update comments in rpm_suspend() to reflect
that change.
[rjw: Modified the subject and changelog slightly.]
Signed-off-by: Ming Lei <ming.lei@canonical.com>
This patch fix kerneldoc comments for rpm_suspend():
- 'Cancel a pending idle notification' should be put before, also
should be changed to 'Cancel a pending idle notification,
autosuspend or suspend'.
- idle notification for the device after succeeding suspend has
been removed, so update the comment accordingly.
Support raw reads if all the registers being read are volatile, the cache
will have no impact for tem.
Support bulk reads either directly (if all the registers are volatile) or
by falling back to iterating over single register reads otherwise.
We only really need the defaults in order to cut down the number of
registers we sync and to satisfy reads while the device is powered off
but not all devices are going to need to do that (always on devices like
PMICs being the prime example) so don't require those devices to supply
a default. Instead only try to fall back to hardware defaults if the
driver told us to.
Devices using LZO won't be able to instantiate with this, that will require
some updates in the LZO code to handle this case.
Acked-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com>
Simplify the check for registers set at their default value by avoiding
picking a default value in the case where we don't have one. Instead we
only compare the current value to the current value when we looked one
up. This fixes the case where we don't have a default stored but the value
was set to zero when that isn't the chip default.
Ensure that when we start up in cache only mode we can store defaults of
zero, otherwise if the hardware is unavailable we won't be able to read.
As with the bulk reads we really should be able to make these play
nicely with the cache but warn for now.
If a register isn't cached then let callers know that so they can fall
back or error handle appropriately.
Rather than open coding a binary search use the standard bsearch() using
the comparison function we're already using for sort() on insert. This
fixes a lockup I was observing due to iterating on min <= max rather
than min < max when we fail to look up.
* pm-devfreq:
PM / devfreq: Add basic governors
PM / devfreq: Add common sysfs interfaces
PM: Introduce devfreq: generic DVFS framework with device-specific OPPs
PM / OPP: Add OPP availability change notifier.
* pm-qos:
PM / QoS: Update Documentation for the pm_qos and dev_pm_qos frameworks
PM / QoS: Add function dev_pm_qos_read_value() (v3)
PM QoS: Add global notification mechanism for device constraints
PM QoS: Implement per-device PM QoS constraints
PM QoS: Generalize and export constraints management code
PM QoS: Reorganize data structs
PM QoS: Code reorganization
PM QoS: Minor clean-ups
PM QoS: Move and rename the implementation files
* pm-domains:
PM / Domains: Split device PM domain data into base and need_restore
ARM: mach-shmobile: sh7372 sleep warning fixes
ARM: mach-shmobile: sh7372 A3SM support
ARM: mach-shmobile: sh7372 generic suspend/resume support
PM / Domains: Preliminary support for devices with power.irq_safe set
PM: Move clock-related definitions and headers to separate file
PM / Domains: Use power.sybsys_data to reduce overhead
PM: Reference counting of power.subsys_data
PM: Introduce struct pm_subsys_data
ARM / shmobile: Make A3RV be a subdomain of A4LC on SH7372
PM / Domains: Rename argument of pm_genpd_add_subdomain()
PM / Domains: Rename GPD_STATE_WAIT_PARENT to GPD_STATE_WAIT_MASTER
PM / Domains: Allow generic PM domains to have multiple masters
PM / Domains: Add "wait for parent" status for generic PM domains
PM / Domains: Make pm_genpd_poweron() always survive parent removal
PM / Domains: Do not take parent locks to modify subdomain counters
PM / Domains: Implement subdomain counters as atomic fields
* pm-runtime:
PM / Tracing: build rpm-traces.c only if CONFIG_PM_RUNTIME is set
PM / Runtime: Replace dev_dbg() with trace_rpm_*()
PM / Runtime: Introduce trace points for tracing rpm_* functions
PM / Runtime: Don't run callbacks under lock for power.irq_safe set
USB: Add wakeup info to debugging messages
PM / Runtime: pm_runtime_idle() can be called in atomic context
PM / Runtime: Add macro to test for runtime PM events
PM / Runtime: Add might_sleep() to runtime PM functions
To read the current PM QoS value for a given device we need to
make sure that the device's power.constraints object won't be
removed while we're doing that. For this reason, put the
operation under dev->power.lock and acquire the lock
around the initialization and removal of power.constraints.
Moreover, since we're using the value of power.constraints to
determine whether or not the object is present, the
power.constraints_state field isn't necessary any more and may be
removed. However, dev_pm_qos_add_request() needs to check if the
device is being removed from the system before allocating a new
PM QoS constraints object for it, so make it use the
power.power_state field of struct device for this purpose.
Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com>
Since there are more lookups than insertions in a typical
scenario, optimize the linear search into a binary search. For
this to work, we need to keep reg_defaults sorted upon
insertions, for now be lazy and use sort().
The patch enables to register notifier_block for an OPP-device in order
to get notified for any changes in the availability of OPPs of the
device. For example, if a new OPP is inserted or enable/disable status
of an OPP is changed, the notifier is executed.
This enables the usage of opp_add, opp_enable, and opp_disable to
directly take effect with any connected entities such as cpufreq or
devfreq.
Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com>
Reviewed-by: Mike Turquette <mturquette@ti.com>
Reviewed-by: Kevin Hilman <khilman@ti.com>
Ensure we've got a function so users can enable/disable the
cache bypass option.
