path: root/drivers/base
2008-07-28more sysdev API change fallout - drivers/base/memory.cStephen Rothwell
Noticed because of this warning: drivers/base/memory.c:279: warning: initialization from incompatible pointer type Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26Use WARN() in drivers/base/Arjan van de Ven
Use WARN() instead of a printk+WARN_ON() pair; this way the message becomes part of the warning section for better reporting/collection. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Greg KH <greg@kroah.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26isa: set 24-bit dma_mask for ISA devicesRene Herman
dma_alloc_coherent() on x86 currently takes a passed in NULL device pointer to mean that it should allocate an ISA compatible (24-bit) buffer which is a bit of a hack. The ALSA ISA drivers are the main consumers of this but have a struct device in fact readily available. For the legacy drivers, this sets the device dma_mask in preparation for using the actual device with the DMA API so as to eventually not need the NULL hack in dma_alloc_coherent(). This does not fix a current bug -- 2.6.26-rc1 stumbled over the NULL hack in dma_alloc_coherent() but this has already been fixed in commit 4a367f3a9dbf2e7ffcee4702203479809236ee6e by Takashi Iwai. Signed-off-by: Rene Herman <rene.herman@gmail.com> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-by: Takashi Iwai <tiwai@suse.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25firmware: use memory_read_from_buffer()Akinobu Mita
Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Markus Rechberger <markus.rechberger@amd.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24memory-hotplug: add sysfs removable attribute for hotplug memory removeBadari Pulavarty
Memory may be hot-removed on a per-memory-block basis, particularly on POWER where the SPARSEMEM section size often matches the memory-block size. A user-level agent must be able to identify which sections of memory are likely to be removable before attempting the potentially expensive operation. This patch adds a file called "removable" to the memory directory in sysfs to help such an agent. In this patch, a memory block is considered removable if; o It contains only MOVABLE pageblocks o It contains only pageblocks with free pages regardless of pageblock type On the other hand, a memory block starting with a PageReserved() page will never be considered removable. Without this patch, the user-agent is forced to choose a memory block to remove randomly. Sample output of the sysfs files: ./memory/memory0/removable: 0 ./memory/memory1/removable: 0 ./memory/memory2/removable: 0 ./memory/memory3/removable: 0 ./memory/memory4/removable: 0 ./memory/memory5/removable: 0 ./memory/memory6/removable: 0 ./memory/memory7/removable: 1 ./memory/memory8/removable: 0 ./memory/memory9/removable: 0 ./memory/memory10/removable: 0 ./memory/memory11/removable: 0 ./memory/memory12/removable: 0 ./memory/memory13/removable: 0 ./memory/memory14/removable: 0 ./memory/memory15/removable: 0 ./memory/memory16/removable: 0 ./memory/memory17/removable: 1 ./memory/memory18/removable: 1 ./memory/memory19/removable: 1 ./memory/memory20/removable: 1 ./memory/memory21/removable: 1 ./memory/memory22/removable: 1 Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-23Merge branch 'cpus4096-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'cpus4096-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (31 commits) NR_CPUS: Replace NR_CPUS in speedstep-centrino.c cpumask: Provide a generic set of CPUMASK_ALLOC macros, FIXUP NR_CPUS: Replace NR_CPUS in cpufreq userspace routines NR_CPUS: Replace per_cpu(..., smp_processor_id()) with __get_cpu_var NR_CPUS: Replace NR_CPUS in arch/x86/kernel/genapic_flat_64.c NR_CPUS: Replace NR_CPUS in arch/x86/kernel/genx2apic_uv_x.c NR_CPUS: Replace NR_CPUS in arch/x86/kernel/cpu/proc.c NR_CPUS: Replace NR_CPUS in arch/x86/kernel/cpu/mcheck/mce_64.c cpumask: Optimize cpumask_of_cpu in lib/smp_processor_id.c, fix cpumask: Use optimized CPUMASK_ALLOC macros in the centrino_target cpumask: Provide a generic set of CPUMASK_ALLOC macros cpumask: Optimize cpumask_of_cpu in lib/smp_processor_id.c cpumask: Optimize cpumask_of_cpu in kernel/time/tick-common.c cpumask: Optimize cpumask_of_cpu in drivers/misc/sgi-xp/xpc_main.c cpumask: Optimize cpumask_of_cpu in arch/x86/kernel/ldt.c cpumask: Optimize cpumask_of_cpu in arch/x86/kernel/io_apic_64.c cpumask: Replace cpumask_of_cpu with cpumask_of_cpu_ptr Revert "cpumask: introduce new APIs" cpumask: make for_each_cpu_mask a bit smaller net: Pass reference to cpumask variable in net/sunrpc/svc.c ... Fix up trivial conflicts in drivers/cpufreq/cpufreq.c manually
2008-07-21sysdev: Add utility functions for simple int/ulong variable sysdev attributesAndi Kleen
This adds a new sysdev_ext_attribute that stores a pointer to the variable it manages and some utility functions/macro to easily use them. Previously all users wrote custom macros to generate show/store functions for each variable, with this it is possible to avoid that in many cases. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21sysdev: Pass the attribute to the low level sysdev show/store functionAndi Kleen
This allow to dynamically generate attributes and share show/store functions between attributes. Right now most attributes are generated by special macros and lots of duplicated code. With the attribute passed it's instead possible to attach some data to the attribute and then use that in shared low level functions to do different things. I need this for the dynamically generated bank attributes in the x86 machine check code, but it'll allow some further cleanups. I converted all users in tree to the new show/store prototype. It's a single huge patch to avoid unbisectable sections. Runtime tested: x86-32, x86-64 Compiled only: ia64, powerpc Not compile tested/only grep converted: sh, arm, avr32 Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21driver core: Suppress sysfs warnings for device_rename().Cornelia Huck
driver core: Suppress sysfs warnings for device_rename(). Renaming network devices to an already existing name is not something we want sysfs to print a scary warning for, since the callers can deal with this correctly. So let's introduce sysfs_create_link_nowarn() which gets rid of the common warning. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21always enable FW_LOADER unless EMBEDDED=yAdrian Bunk
James Bottomley recently discovered that we have {request,release}_firmware() dummies for the case of the actual functions not being available and has a fix for the bug that was actually causing build errors for built-in users with CONFIG_FW_LOADER=m. But now missing selects on FW_LOADER are no longer visible at compile-time at all and can become runtime problems. FW_LOADER is infrastructure with relatively small codesize we can safely enable for everyone, and only for people who really need small kernels (and can be expected to know what they are doing) it matters being able to disable it. This patch therefore always sets FW_LOADER=y and allows users only to disable it with EMBEDDED=y. As a bonus, we can then get rid of all "select FW_LOADER" plus the due to it required "depends on HOTPLUG" which removes some complexity from our Kconfig files. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21sysdev: fix debugging statements in registration code.Ben Dooks
The systdev_class_register() and sysdev_register() functions have pr_debug() statements which are enabled when the user selects the driver core debug. Both of these routines do not produce the correct output, as they make assumptions about data which has not been initialised. In sysdev_class_register() the code uses the kobject_name(&cls->kset.kobj) at the start of the function, but this is not setup until later in the same call. Change this to use cls->name which is passed in from the caller. The sysdev_register() function tries to get the name of the sysdev by kobject_name(&sysdev->kobj), but that isn't setup until later in the same function so change this message to use the name of the sysdev's class and add another message once the name is initialised. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21driver core: fix a lot of printk usages of bus_idGreg Kroah-Hartman
We have the dev_printk() variants for this kind of thing, use them instead of directly trying to access the bus_id field of struct device. This is done in order to remove bus_id entirely. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21class: change internal semaphore to a mutexDave Young
Now that the lockdep infrastructure in the class core is in place, we should be able to properly change the internal class semaphore to be a mutex. David wrote the original patch, and Greg fixed it up to apply properly due to all of the recent changes in this area. From: Dave Young <hidave.darkstar@gmail.com> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21class: add lockdep infrastructureMatthew Wilcox
This adds the infrastructure to properly handle lockdep issues when the internal class semaphore is changed to a mutex. Matthew wrote the original patch, and Greg fixed it up to work properly with the class_create() function. From: Matthew Wilcox <matthew@wil.cx> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Dave Young <hidave.darkstar@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21class: fix docbook comments for class_private structureGreg Kroah-Hartman
Removes a field that has been deleted, and adds a description fo the class_dirs field which was previously undocumented. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21class: rename "sem" to "class_sem" in internal class structureGreg Kroah-Hartman
This renames the struct class "sem" field to be "class_sem" to make things easier when struct bus_type and struct class merge in the future. It also makes grepping for fields easier as well. Based on an idea from Kay. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21class: rename "subsys" to "class_subsys" in internal class structureGreg Kroah-Hartman
This renames the struct class "subsys" field to be "class_subsys" to make things easier when struct bus_type and struct class merge in the future. It also makes grepping for fields easier as well. Based on an idea from Kay. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21class: rename "interfaces" to "class_interfaces" in internal class structureGreg Kroah-Hartman
This renames the struct class "interfaces" field to be "class_interfaces" to make things easier when struct bus_type and struct class merge in the future. It also makes grepping for fields easier as well. Based on an idea from Kay. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21class: rename "devices" to "class_devices" in internal class structureGreg Kroah-Hartman
This renames the struct class "devices" field to be "class_devices" to make things easier when struct bus_type and struct class merge in the future. It also makes grepping for fields easier as well. Based on an idea from Kay. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21class: move driver core specific parts to a private structureGreg Kroah-Hartman
This moves the portions of struct class that are dynamic (kobject and lock and lists) out of the main structure and into a dynamic, private, structure. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21Driver Core: add ability for class_find_device to start in middle of listGreg Kroah-Hartman
This mirrors the functionality that driver_find_device has as well. We add a start variable, and all callers of the function are fixed up at the same time. The block layer will be using this new functionality in a follow-on patch. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21Driver Core: add ability for class_for_each_device to start in middle of listGreg Kroah-Hartman
This mirrors the functionality that driver_for_each_device has as well. We add a start variable, and all callers of the function are fixed up at the same time. The block layer will be using this new functionality in a follow-on patch. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21device create: convert device_create_drvdata to device_createGreg Kroah-Hartman
Now that device_create() has been audited, rename things back to the original call to be sane. Keep the device_create_drvdata macro around to make merges easier. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21driver core: remove device_create()Greg Kroah-Hartman
There are no more users of this, and it is racy. Use device_create_drvdata() or device_create_vargs() instead. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21sysfs: add /sys/dev/{char,block} to lookup sysfs path by major:minorDan Williams
Why?: There are occasions where userspace would like to access sysfs attributes for a device but it may not know how sysfs has named the device or the path. For example what is the sysfs path for /dev/disk/by-id/ata-ST3160827AS_5MT004CK? With this change a call to stat(2) returns the major:minor then userspace can see that /sys/dev/block/8:32 links to /sys/block/sdc. What are the alternatives?: 1/ Add an ioctl to return the path: Doable, but sysfs is meant to reduce the need to proliferate ioctl interfaces into the kernel, so this seems counter productive. 2/ Use udev to create these symlinks: Also doable, but it adds a udev dependency to utilities that might be running in a limited environment like an initramfs. 3/ Do a full-tree search of sysfs. [kay.sievers@vrfy.org: fix duplicate registrations] [kay.sievers@vrfy.org: cleanup suggestions] Cc: Neil Brown <neilb@suse.de> Cc: Tejun Heo <htejun@gmail.com> Acked-by: Kay Sievers <kay.sievers@vrfy.org> Reviewed-by: SL Baur <steve@xemacs.org> Acked-by: Kay Sievers <kay.sievers@vrfy.org> Acked-by: Mark Lord <lkml@rtr.ca> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-18Merge branch 'linus' into cpus4096Ingo Molnar
Conflicts: drivers/acpi/processor_throttling.c Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-16Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (72 commits) Revert "x86/PCI: ACPI based PCI gap calculation" PCI: remove unnecessary volatile in PCIe hotplug struct controller x86/PCI: ACPI based PCI gap calculation PCI: include linux/pm_wakeup.h for device_set_wakeup_capable PCI PM: Fix pci_prepare_to_sleep x86/PCI: Fix PCI config space for domains > 0 Fix acpi_pm_device_sleep_wake() by providing a stub for CONFIG_PM_SLEEP=n PCI: Simplify PCI device PM code PCI PM: Introduce pci_prepare_to_sleep and pci_back_from_sleep PCI ACPI: Rework PCI handling of wake-up ACPI: Introduce new device wakeup flag 'prepared' ACPI: Introduce acpi_device_sleep_wake function PCI: rework pci_set_power_state function to call platform first PCI: Introduce platform_pci_power_manageable function ACPI: Introduce acpi_bus_power_manageable function PCI: make pci_name use dev_name PCI: handle pci_name() being const PCI: add stub for pci_set_consistent_dma_mask() PCI: remove unused arch pcibios_update_resource() functions PCI: fix pci_setup_device()'s sprinting into a const buffer ... Fixed up conflicts in various files (arch/x86/kernel/setup_64.c, arch/x86/pci/irq.c, arch/x86/pci/pci.h, drivers/acpi/sleep/main.c, drivers/pci/pci.c, drivers/pci/pci.h, include/acpi/acpi_bus.h) from x86 and ACPI updates manually.
2008-07-16Merge branch 'linus' into cpus4096Ingo Molnar
Conflicts: arch/x86/xen/smp.c kernel/sched_rt.c net/iucv/iucv.c Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-15Merge branch 'core/topology' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core/topology' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: cputopology: always define CPU topology information, clean up cpu topology: always define CPU topology information
2008-07-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6.gitDavid Woodhouse
Conflicts: sound/pci/Kconfig
2008-07-10firmware: Add CONFIG_FIRMWARE_IN_KERNEL option.David Woodhouse
This will control whether we build firmware into the kernel image for _every_ driver which we convert to request_firmware(), to avoid a proliferation of 'CONFIG_XXX_FIRMWARE' options for each one. Default to 'y' for now, which is the wrong thing to do but people seem to be insisting on it and refusing to even review patches until it's done. And it does preserve the existing behaviour for built-in drivers. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-07-10firmware: Add CONFIG_EXTRA_FIRMWARE optionDavid Woodhouse
This allows arbitrary firmware files to be included in the static kernel where the firmware loader can find them without requiring userspace to be alive. (Updated and CONFIG_EXTRA_FIRMWARE_DIR added with lots of help from Johannes Berg). Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
2008-07-10firmware: allow firmware files to be built into kernel imageDavid Woodhouse
Some drivers have their own hacks to bypass the kernel's firmware loader and build their firmware into the kernel; this renders those unnecessary. Other drivers don't use the firmware loader at all, because they always want the firmware to be available. This allows them to start using the firmware loader. A third set of drivers already use the firmware loader, but can't be used without help from userspace, which sometimes requires an initrd. This allows them to work in a static kernel. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-07-10firmware: make fw->data constDavid Woodhouse
In preparation for supporting firmware files linked into the static kernel, make fw->data const to ensure that users aren't modifying it (so that we can pass a pointer to the original in-kernel copy, rather than having to copy it). Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-07-08Merge branch 'x86/numa' into x86/develIngo Molnar
Conflicts: arch/x86/Kconfig arch/x86/kernel/e820.c arch/x86/kernel/efi_64.c arch/x86/kernel/mpparse.c arch/x86/kernel/setup.c arch/x86/kernel/setup_32.c arch/x86/mm/init_64.c include/asm-x86/proto.h Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08x86: cleanup early per cpu variables/accesses v4Mike Travis
* Introduce a new PER_CPU macro called "EARLY_PER_CPU". This is used by some per_cpu variables that are initialized and accessed before there are per_cpu areas allocated. ["Early" in respect to per_cpu variables is "earlier than the per_cpu areas have been setup".] This patchset adds these new macros: DEFINE_EARLY_PER_CPU(_type, _name, _initvalue) EXPORT_EARLY_PER_CPU_SYMBOL(_name) DECLARE_EARLY_PER_CPU(_type, _name) early_per_cpu_ptr(_name) early_per_cpu_map(_name, _idx) early_per_cpu(_name, _cpu) The DEFINE macro defines the per_cpu variable as well as the early map and pointer. It also initializes the per_cpu variable and map elements to "_initvalue". The early_* macros provide access to the initial map (usually setup during system init) and the early pointer. This pointer is initialized to point to the early map but is then NULL'ed when the actual per_cpu areas are setup. After that the per_cpu variable is the correct access to the variable. The early_per_cpu() macro is not very efficient but does show how to access the variable if you have a function that can be called both "early" and "late". It tests the early ptr to be NULL, and if not then it's still valid. Otherwise, the per_cpu variable is used instead: #define early_per_cpu(_name, _cpu) \ (early_per_cpu_ptr(_name) ? \ early_per_cpu_ptr(_name)[_cpu] : \ per_cpu(_name, _cpu)) A better method is to actually check the pointer manually. In the case below, numa_set_node can be called both "early" and "late": void __cpuinit numa_set_node(int cpu, int node) { int *cpu_to_node_map = early_per_cpu_ptr(x86_cpu_to_node_map); if (cpu_to_node_map) cpu_to_node_map[cpu] = node; else per_cpu(x86_cpu_to_node_map, cpu) = node; } * Add a flag "arch_provides_topology_pointers" that indicates pointers to topology cpumask_t maps are available. Otherwise, use the function returning the cpumask_t value. This is useful if cpumask_t set size is very large to avoid copying data on to/off of the stack. * The coverage of CONFIG_DEBUG_PER_CPU_MAPS has been increased while the non-debug case has been optimized a bit. * Remove an unreferenced compiler warning in drivers/base/topology.c * Clean up #ifdef in setup.c For inclusion into sched-devel/latest tree. Based on: git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6.git + sched-devel/latest .../mingo/linux-2.6-sched-devel.git Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-07-08Merge branches 'x86/numa-fixes', 'x86/apic', 'x86/apm', 'x86/bitops', ↵Ingo Molnar
'x86/build', 'x86/cleanups', 'x86/cpa', 'x86/cpu', 'x86/defconfig', 'x86/gart', 'x86/i8259', 'x86/intel', 'x86/irqstats', 'x86/kconfig', 'x86/ldt', 'x86/mce', 'x86/memtest', 'x86/pat', 'x86/ptemask', 'x86/resumetrace', 'x86/threadinfo', 'x86/timers', 'x86/vdso' and 'x86/xen' into x86/devel
2008-07-07PCI ACPI: Rework PCI handling of wake-upRafael J. Wysocki
* Introduce function acpi_pm_device_sleep_wake() for enabling and disabling the system wake-up capability of devices that are power manageable by ACPI. * Introduce function acpi_bus_can_wakeup() allowing other (dependent) subsystems to check if ACPI is able to enable the system wake-up capability of given device. * Introduce callback .sleep_wake() in struct pci_platform_pm_ops and for the ACPI PCI 'driver' make it use acpi_pm_device_sleep_wake(). * Introduce callback .can_wakeup() in struct pci_platform_pm_ops and for the ACPI 'driver' make it use acpi_bus_can_wakeup(). * Move the PME# handlig code out of pci_enable_wake() and split it into two functions, pci_pme_capable() and pci_pme_active(), allowing the caller to check if given device is capable of generating PME# from given power state and to enable/disable the device's PME# functionality, respectively. * Modify pci_enable_wake() to use the new ACPI callbacks and the new PME#-related functions. * Drop the generic .platform_enable_wakeup() callback that is not used any more. * Introduce device_set_wakeup_capable() that will set the power.can_wakeup flag of given device. * Rework PCI device PM initialization so that, if given device is capable of generating wake-up events, either natively through the PME# mechanism, or with the help of the platform, its power.can_wakeup flag is set and its power.should_wakeup flag is unset as appropriate. * Make ACPI set the power.can_wakeup flag for devices found to be wake-up capable by it. * Make the ACPI wake-up code enable/disable GPEs for devices that have the wakeup.flags.prepared flag set (which means that their wake-up power has been enabled). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-07-06Merge commit 'v2.6.26-rc9' into cpus4096Ingo Molnar
2008-07-04mm: switch node meminfo Active & Inactive pages to KbytesJohn Blackwood
There is a bug in the output of /sys/devices/system/node/node[n]/meminfo where the Active and Inactive values are in pages instead of Kbytes. Looks like this occurred back in 2.6.20 when the code was changed over to use node_page_state(). Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-13cputopology: always define CPU topology information, clean upBen Hutchings
simplify drivers/base/topology.c a bit. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-13cpu topology: always define CPU topology informationBen Hutchings
This can result in an empty topology directory in sysfs, and requires in-kernel users to protect all uses with #ifdef - see <http://marc.info/?l=linux-netdev&m=120639033904472&w=2>. The documentation of CPU topology specifies what the defaults should be if only partial information is available from the hardware. So we can provide these defaults as a fallback. This patch: - Adds default definitions of the 4 topology macros to <linux/topology.h> - Changes drivers/base/topology.c to use the topology macros unconditionally and to cope with definitions that aren't lvalues - Updates documentation accordingly [ From: Andrew Morton <akpm@linux-foundation.org> - fold now-duplicated code - fix layout ] Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Cc: Vegard Nossum <vegard.nossum@gmail.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Chandra Seetharaman <sekharan@us.ibm.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Mike Travis <travis@sgi.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: John Hawkes <hawkes@sgi.com> Cc: Zhang, Yanmin <yanmin.zhang@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-12Suspend-related patches for 2.6.27Rafael J. Wysocki
ACPI PM: Add possibility to change suspend sequence There are some systems out there that don't work correctly with our current suspend/hibernation code ordering. Provide a workaround for these systems allowing them to pass 'acpi_sleep=old_ordering' in the kernel command line so that it will use the pre-ACPI 2.0 ("old") suspend code ordering. Unfortunately, this requires us to add a platform hook to the resuming of devices for recovering the platform in case one of the device drivers' .suspend() routines returns error code. Namely, ACPI 1.0 specifies that _PTS should be called before suspending devices, but _WAK still should be called before resuming them in order to undo the changes made by _PTS. However, if there is an error during suspending devices, they are automatically resumed without returning control to the PM core, so the _WAK has to be called from within device_resume() in that cases. The patch also reorders and refactors the ACPI suspend/hibernation code to avoid duplication as far as reasonably possible. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-06-11dev_set_name: fix missing kernel-docRandy Dunlap
Fix kernel-doc for new dev_set_name() function: Warning(lin2626-rc5//drivers/base/core.c:767): No description found for parameter 'fmt' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-06-10Implement new suspend and hibernation callbacks for platform bussesRafael J. Wysocki
Implement new suspend and hibernation callbacks for the platform bus type. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Greg KH <greg@kroah.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-06-10Introduce new top level suspend and hibernation callbacksRafael J. Wysocki
Introduce 'struct pm_ops' and 'struct pm_ext_ops' ('ext' meaning 'extended') representing suspend and hibernation operations for bus types, device classes, device types and device drivers. Modify the PM core to use 'struct pm_ops' and 'struct pm_ext_ops' objects, if defined, instead of the ->suspend(), ->resume(), ->suspend_late(), and ->resume_early() callbacks (the old callbacks will be considered as legacy and gradually phased out). The main purpose of doing this is to separate suspend (aka S2RAM and standby) callbacks from hibernation callbacks in such a way that the new callbacks won't take arguments and the semantics of each of them will be clearly specified. This has been requested for multiple times by many people, including Linus himself, and the reason is that within the current scheme if ->resume() is called, for example, it's difficult to say why it's been called (ie. is it a resume from RAM or from hibernation or a suspend/hibernation failure etc.?). The second purpose is to make the suspend/hibernation callbacks more flexible so that device drivers can handle more than they can within the current scheme. For example, some drivers may need to prevent new children of the device from being registered before their ->suspend() callbacks are executed or they may want to carry out some operations requiring the availability of some other devices, not directly bound via the parent-child relationship, in order to prepare for the execution of ->suspend(), etc. Ultimately, we'd like to stop using the freezing of tasks for suspend and therefore the drivers' suspend/hibernation code will have to take care of the handling of the user space during suspend/hibernation. That, in turn, would be difficult within the current scheme, without the new ->prepare() and ->complete() callbacks. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-05-29driver-core: prepare for 2.6.27 api change by adding dev_set_nameStephen Rothwell
Create the dev_set_name function now so that various subsystems can start changing over to it before other changes in 2.6.27 will make it compulsory. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-25x86: move tracedata to RODATAJan Beulich
.. allowing it to be write-protected just as other read-only data under CONFIG_DEBUG_RODATA. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-23cpu: change some globals to statics in drivers/base/cpu.c v2Mike Travis
This patch makes the following needlessly global code static: - attr_online_map - attr_possible_map - attr_present_map - cpu_state_attr [v2] Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (27 commits) pktgen: make sure that pktgen_thread_worker has been executed [VLAN]: Propagate selected feature bits to VLAN devices drivers/atm/: remove CVS keywords vlan: Correctly handle device notifications for layered VLAN devices net: Fix call to ->change_rx_flags(dev, IFF_MULTICAST) in dev_change_flags() net_sched: cls_api: fix return value for non-existant classifiers ipsec: Use the correct ip_local_out function ipv6 addrconf: Allow infinite prefix lifetime. ipv6 route: Fix lifetime in netlink. ipv6 addrconf: Fix route lifetime setting in corner case. ndisc: Add missing strategies for per-device retrans timer/reachable time settings. ipv6: Move <linux/in6.h> from header-y to unifdef-y. l2tp: avoid skb truesize bug if headroom is increased wireless: Create 'device' symlink in sysfs wireless, airo: waitbusy() won't delay libertas: fix command timeout after firmware failure mac80211: Add RTNL version of ieee80211_iterate_active_interfaces mac80211 : Association with 11n hidden ssid ap. hostap: fix "registers" registration in procfs isdn/capi: Return proper errnos on module init. ...
