path: root/drivers/base/platform.c
2009-06-15driver core: fix gcc 4.3.3 warnings about string literalsGreg Kroah-Hartman
This removes the warning: format not a string literal and no format arguments warnings in the driver core that gcc 4.3.3 complains about. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15driver core: Const-correct platform getbyname functionsLinus Walleij
This converts resource and IRQ getbyname functions for the platform bus to use const char *, I ran into compiler moanings when I tried using a const char * for looking up a certain resource. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-12Driver Core: Rework platform suspend/resume, print warningMagnus Damm
This patch reworks the platform driver code for legacy suspend and resume to avoid installing callbacks in struct device_driver. A warning is also added telling users to update the platform driver to use dev_pm_ops. The functions platform_legacy_suspend()/resume() directly call suspend and resume callbacks in struct platform_driver instead of wrapping things in platform_drv_suspend()/resume(). Signed-off-by: Magnus Damm <damm@igel.co.jp> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2009-05-08Revert driver core: move platform_data into platform_deviceGreg Kroah-Hartman
This reverts commit 006f4571a15fae3a0575f2a0f9e9b63b3d1012f8: This patch moves platform_data from struct device into struct platform_device, based on the two ideas: 1. Now all platform_driver is registered by platform_driver_register, which makes probe()/release()/... of platform_driver passed parameter of platform_device *, so platform driver can get platform_data from platform_device; 2. Other kind of devices do not need to use platform_data, we can decrease size of device if moving it to platform_device. Taking into consideration of thousands of files to be fixed and they can't be finished in one night(maybe it will take a long time), so we keep platform_data in device to allow two kind of cases coexist until all platform devices pass its platfrom data from platform_device->platform_data. All patches to do this kind of conversion are welcome. As we don't really want to do it, it was a bad idea. Cc: David Brownell <david-b@pacbell.net> Cc: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-05-08Revert driver core: fix passing platform_dataMing Lei
This reverts commit ce21c7bcd796fc4f45d48781b7e85f493cc55ee5: We will remove platform_data field from struct device until all platform devices pass its specific data from platfom_device and all platform drivers use platform specific data passed by platform_device->platform_data. This kind of conversion will need a long time, for thousands of files is affected. To make the conversion easily, we allow platform specific data passed by struct device or struct platform_device and platform driver may use it from struct device or struct platform_device. As we really don't want to do this at all. Cc: David Brownell <david-b@pacbell.net> Cc: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-05-08Driver core: platform: fix kernel-doc warningsRandy Dunlap
Fix function parameter notation in platform.c; fixes kernel-doc warnings. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-04-16Driver Core: early platform driverMagnus Damm
V3 of the early platform driver implementation. Platform drivers are great for embedded platforms because we can separate driver configuration from the actual driver. So base addresses, interrupts and other configuration can be kept with the processor or board code, and the platform driver can be reused by many different platforms. For early devices we have nothing today. For instance, to configure early timers and early serial ports we cannot use platform devices. This because the setup order during boot. Timers are needed before the platform driver core code is available. The same goes for early printk support. Early in this case means before initcalls. These early drivers today have their configuration either hard coded or they receive it using some special configuration method. This is working quite well, but if we want to support both regular kernel modules and early devices then we need to have two ways of configuring the same driver. A single way would be better. The early platform driver patch is basically a set of functions that allow drivers to register themselves and architecture code to locate them and probe. Registration happens through early_param(). The time for the probe is decided by the architecture code. See Documentation/driver-model/platform.txt for more details. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Magnus Damm <damm@igel.co.jp> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: David Brownell <david-b@pacbell.net> Cc: Tejun Heo <htejun@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24driver core: fix passing platform_dataMing Lei
We will remove platform_data field from struct device until all platform devices pass its specific data from platfom_device and all platform drivers use platform specific data passed by platform_device->platform_data. This kind of conversion will need a long time, for thousands of files is affected. To make the conversion easily, we allow platform specific data passed by struct device or struct platform_device and platform driver may use it from struct device or struct platform_device. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24driver core: move platform_data into platform_deviceMing Lei
This patch moves platform_data from struct device into struct platform_device, based on the two ideas: 1. Now all platform_driver is registered by platform_driver_register, which makes probe()/release()/... of platform_driver passed parameter of platform_device *, so platform driver can get platform_data from platform_device; 2. Other kind of devices do not need to use platform_data, we can decrease size of device if moving it to platform_device. Taking into consideration of thousands of files to be fixed and they can't be finished in one night(maybe it will take a long time), so we keep platform_data in device to allow two kind of cases coexist until all platform devices pass its platfrom data from platform_device->platform_data. All patches to do this kind of conversion are welcome. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24platform: introduce module id table for platform devicesEric Miao
Now platform_device is being widely used on SoC processors where the peripherals are attached to the system bus, which is simple enough. However, silicon IPs for these SoCs are usually shared heavily across a family of processors, even products from different companies. This makes the original simple driver name based matching insufficient, or simply not straight-forward. Introduce a module id table for platform devices, and makes it clear that a platform driver is able to support some shared IP and handle slight differences across different platforms (by 'driver_data'). Module alias is handled automatically when a MODULE_DEVICE_TABLE() is defined. To not disturb the current platform drivers too much, the matched id entry is recorded and can be retrieved by platform_get_device_id(). Signed-off-by: Eric Miao <eric.miao@marvell.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24platform: make better use of to_platform_{device,driver}() macrosEric Miao
This helps the code look more consistent and cleaner. Signed-off-by: Eric Miao <eric.miao@marvell.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-06driver core: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-06PM: Simplify the new suspend/hibernation framework for devicesRafael J. Wysocki
PM: Simplify the new suspend/hibernation framework for devices Following the discussion at the Kernel Summit, simplify the new device PM framework by merging 'struct pm_ops' and 'struct pm_ext_ops' and removing pointers to 'struct pm_ext_ops' from 'struct platform_driver' and 'struct pci_driver'. After this change, the suspend/hibernation callbacks will only reside in 'struct device_driver' as well as at the bus type/ device class/device type level. Accordingly, PCI and platform device drivers are now expected to put their suspend/hibernation callbacks into the 'struct device_driver' embedded in 'struct pci_driver' or 'struct platform_driver', respectively. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@suse.cz> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (46 commits) UIO: Fix mapping of logical and virtual memory UIO: add automata sercos3 pci card support UIO: Change driver name of uio_pdrv UIO: Add alignment warnings for uio-mem Driver core: add bus_sort_breadthfirst() function NET: convert the phy_device file to use bus_find_device_by_name kobject: Cleanup kobject_rename and !CONFIG_SYSFS kobject: Fix kobject_rename and !CONFIG_SYSFS sysfs: Make dir and name args to sysfs_notify() const platform: add new device registration helper sysfs: use ilookup5() instead of ilookup5_nowait() PNP: create device attributes via default device attributes Driver core: make bus_find_device_by_name() more robust usb: turn dev_warn+WARN_ON combos into dev_WARN debug: use dev_WARN() rather than WARN_ON() in device_pm_add() debug: Introduce a dev_WARN() function sysfs: fix deadlock device model: Do a quickcheck for driver binding before doing an expensive check Driver core: Fix cleanup in device_create_vargs(). Driver core: Clarify device cleanup. ...
2008-10-16resource: add resource_type() and IORESOURCE_TYPE_BITSMagnus Damm
Add resource_type() and IORESOURCE_TYPE_BITS. They make it easier to add more resource types without having to rewrite tons of code. Signed-off-by: Magnus Damm <damm@igel.co.jp> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Jean Delvare <khali@linux-fr.org> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16platform: add new device registration helperDmitry Baryshkov
Add a helper that registers simple platform_device w/o resources but with parent and device data. This is usefull to cleanup platform code from code that registers such simple devices as leds-gpio, generic-bl, etc. Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-16driver core: make struct platform_pm_ops staticAdrian Bunk
This patch makes the needlessly global struct platform_pm_ops static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-06-10Implement new suspend and hibernation callbacks for platform bussesRafael J. Wysocki
Implement new suspend and hibernation callbacks for the platform bus type. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Greg KH <greg@kroah.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-03-10drivers: fix dma_get_required_maskJames Bottomley
There's a bug in the current implementation of dma_get_required_mask() where it ands the returned mask with the current device mask. This rather defeats the purpose if you're using the call to determine what your mask should be (since you will at that time have the default DMA_32BIT_MASK). This bug results in any driver that uses this function *always* getting a 32 bit mask, which is wrong. Fix by removing the and with dev->dma_mask. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24Driver core: coding style fixesGreg Kroah-Hartman
Fix up a number of coding style issues in the drivers/base/ directory that have annoyed me over the years. checkpatch.pl is now very happy. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24Driver Core: constify the name passed to platform_device_register_simpleStephen Rothwell
This name is just passed to platform_device_alloc which has its parameter declared const. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24Driver core: move the static kobject out of struct driverGreg Kroah-Hartman
This patch removes the kobject, and a few other driver-core-only fields out of struct driver and into the driver core only. Now drivers can be safely create on the stack or statically (like they currently are.) Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24driver core: remove fields from struct bus_typeGreg Kroah-Hartman
struct bus_type is static everywhere in the kernel. This moves the kobject in the structure out of it, and a bunch of other private only to the driver core fields are now moved to a private structure. This lets us dynamically create the backing kobject properly and gives us the chance to be able to document to users exactly how to use the struct bus_type as there are no fields they can improperly access. Thanks to Kay for the build fixes on this patch. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12Driver core: Make platform_device.id an intJean Delvare
While platform_device.id is a u32, platform_device_add() handles "-1" as a special id value. This has potential for confusion and bugs. Making it an int instead should prevent problems from happening in the future. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12Driver core: change add_uevent_var to use a structKay Sievers
This changes the uevent buffer functions to use a struct instead of a long list of parameters. It does no longer require the caller to do the proper buffer termination and size accounting, which is currently wrong in some places. It fixes a known bug where parts of the uevent environment are overwritten because of wrong index calculations. Many thanks to Mathieu Desnoyers for finding bugs and improving the error handling. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12platform: prefix MODALIAS with "platform:"Kay Sievers
Prefix platform modalias strings with "platform:", which modprobe config to blacklist alias resolving if userspace configures it. Send uevents for all platform devices. Add MODULE_ALIAS's to: pxa2xx_pcmcia, ds1742 and pcspkr to trigger module autoloading by userspace. $ modinfo pcspkr alias: platform:pcspkr license: GPL description: PC Speaker beeper driver ... $ modprobe -n -v platform:pcspkr insmod /lib/modules/2.6.23-rc3-g28e8351a-dirty/kernel/drivers/input/misc/pcspkr.ko Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: David Brownell <david-b@pacbell.net> Cc: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-09drivers/base/platform.c: fix small typo in docMárton Németh
Typo: iwithout -> without. Signed-off-by: Márton Németh <nm127@freemail.hu> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-08fix hotplug for legacy platform driversDavid Brownell
We've had various reports of some legacy "probe the hardware" style platform drivers having nasty problems with hotplug support. The core issue is that those legacy drivers don't fully conform to the driver model. They assume a role that should be the responsibility of infrastructure code: creating device nodes. The "modprobe" step in hotplugging relies on drivers to have split those roles into different modules. The lack of this split causes the problems. When a driver creates nodes for devices that don't exist (sending a hotplug event), then exits (aborting one modprobe) before the "modprobe $MODALIAS" step completes (by failing, since it's in the middle of a modprobe), the result can be an endless loop of modprobe invocations ... badness. This fix uses the newish per-device flag controlling issuance of "add" events. (A previous version of this patch used a per-device "driver can hotplug" flag, which only scrubbed $MODALIAS from the environment rather than suppressing the entire hotplug event.) It also shrinks that flag to one bit, saving a word in "struct device". So the net of this patch is removing some nasty failures with legacy drivers, while retaining hotplug capability for the majority of platform drivers. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Greg KH <gregkh@suse.de> Cc: Andres Salomon <dilinger@debian.org> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-02platform: reorder platform_device_delJean Delvare
In platform_device_del(), we currently delete the device resources first, then we delete the device itself. This causes a (minor) bug to occur when one unregisters a platform device before unregistering its platform driver, and the driver is requesting (in .probe()) and releasing (in .remove()) a resource of the device. The device resources are already gone by the time the driver gets the chance to release the resources it had been requesting, causing an error like: Trying to free nonexistent resource <0000000000000295-0000000000000296> If the platform driver is unregistered first, the problem doesn't occur, as the driver will have the opportunity to release the resources it had requested before the device resources themselves are released. It's a bit odd that unregistering the driver first or the device first doesn't lead to the same result. So I believe that we should delete the device first in platform_device_del(). I've searched the git history and found that it used to be the case before 2.6.8, but was changed here: http://www.kernel.org/git/?p=linux/kernel/git/torvalds/old-2.6-bkcvs.git;a=commitdiff;h=96ef7b3689936ee1e64b711511342026a8ce459c > 2004/07/14 16:09:44-07:00 dtor_core > [PATCH] Driver core: Fix OOPS in device_platform_unregister > > Driver core: platform_device_unregister should release resources first > and only then call device_unregister, otherwise if there > are no more references to the device it will be freed and > the fucntion will try to access freed memory. However we now have an explicit call to put_device() at the end of platform_device_unregister() so I guess the original problem no longer exists and it is safe to revert that change. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07driver core fixes: device_register() retval check in platform.cCornelia Huck
Check the return value of device_register() in platform_bus_init(). Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-13Driver core: Make platform_device_add_data accept a const pointerScott Wood
platform_device_add_data() makes a copy of the data that is given to it, and thus the parameter can be const. This removes a warning when data from get_property() on powerpc is handed to platform_device_add_data(), as get_property() returns a const pointer. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-13Driver core: "platform_driver_probe() can save codespace": save codespaceAndrew Morton
This function can be __init Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-01Driver core: platform_driver_probe(), can save codespaceDavid Brownell
This defines a new platform_driver_probe() method allowing the driver's probe() method, and its support code+data, to safely live in __init sections for typical system configurations. Many system-on-chip processors could benefit from this API, to the tune of recovering hundreds to thousands of bytes per driver. That's memory which is currently wasted holding code which can never be called after system startup, yet can not be removed. It can't be removed because of the linkage requirement that pointers to init section code (like, ideally, probe support) must not live in other sections (like driver method tables) after those pointers would be invalid. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-25PM: platform_bus and late_suspend/early_resumeDavid Brownell
Teach platform_bus about the new suspend_late/resume_early PM calls, issued with IRQs off. Do we really need sysdev and friends any more, or can janitors start switching its users over to platform_device so we can do a minor code-ectomy? Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] Driver Core: Fix platform_device_add to use device_addRussell King
platform_device_add() should be using device_add() rather than device_register() - any platform device passed to platform_device_add() should have already been initialised, either by platform_device_alloc() or platform_device_register(). Signed-off-by: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] platform_bus learns about modaliasDavid Brownell
This patch adds modalias support to platform devices, for simpler hotplug/coldplug driven driver setup. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-22Fix "frist", "fisrt", typosUwe Zeisberger
Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-03-20[PATCH] driver core: platform_get_irq*(): return -ENXIO on errorDavid Vrabel
platform_get_irq*() cannot return 0 on error as 0 is a valid IRQ on some platforms, return -ENXIO instead. Signed-off-by: David Vrabel <dvrabel@arcom.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-13[PATCH] platform-device-del typo fixJean Delvare
Please fold this typo fix into platform-device-del.patch, as was discussed earlier on LKML: http://lkml.org/lkml/2005/12/10/76 Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] Driver Core: Rearrange exports in platform.cDmitry Torokhov
Driver core: rearrange exports in platform.c The new way is to specify export right after symbol definition. Rearrange exports to follow new style to avoid mixing two styles in one file. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] Driver Core: Add platform_device_del()Dmitry Torokhov
Driver core: add platform_device_del function Having platform_device_del90 allows more straightforward error handling code in drivers registering platform devices. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] Allow overlapping resources for platform devicesKumar Gala
There are cases in which a device's memory mapped registers overlap with another device's memory mapped registers. On several PowerPC devices this occurs for the MDIO bus, whose registers tended to overlap with one of the ethernet controllers. By switching from request_resource to insert_resource we can register the MDIO bus as a proper platform device and not hack around how we handle its memory mapped registers. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-09[DRIVER MODEL] Add platform_driverRussell King
Introduce struct platform_driver. This allows the platform device driver methods to be passed a platform_device structure instead of instead of a plain device structure, and therefore requiring casting in every platform driver. We introduce this in such a way that any existing platform drivers registered directly via driver_register continue to work as before, thereby allowing a gradual conversion to the new platform_driver methods. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-05[DRIVER MODEL] Improved dynamically allocated platform_device interfaceRussell King
Re-jig the simple platform device support to allow private data to be attached to a platform device, as well as allowing the parent device to be set. Example usage: pdev = platform_device_alloc("mydev", id); if (pdev) { err = platform_device_add_resources(pdev, &resources, ARRAY_SIZE(resources)); if (err == 0) err = platform_device_add_data(pdev, &platform_data, sizeof(platform_data)); if (err == 0) err = platform_device_add(pdev); } else { err = -ENOMEM; } if (err) platform_device_put(pdev); Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-31Merge master.kernel.org:/home/rmk/linux-2.6-drvmodelLinus Torvalds
Manual #include fixups for clashes - there may be some unnecessary
2005-10-30[PATCH] fix missing includesTim Schmielau
I recently picked up my older work to remove unnecessary #includes of sched.h, starting from a patch by Dave Jones to not include sched.h from module.h. This reduces the number of indirect includes of sched.h by ~300. Another ~400 pointless direct includes can be removed after this disentangling (patch to follow later). However, quite a few indirect includes need to be fixed up for this. In order to feed the patches through -mm with as little disturbance as possible, I've split out the fixes I accumulated up to now (complete for i386 and x86_64, more archs to follow later) and post them before the real patch. This way this large part of the patch is kept simple with only adding #includes, and all hunks are independent of each other. So if any hunk rejects or gets in the way of other patches, just drop it. My scripts will pick it up again in the next round. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] DRIVER MODEL: Get rid of the obsolete tri-level suspend/resume callbacksRussell King
In PM v1, all devices were called at SUSPEND_DISABLE level. Then all devices were called at SUSPEND_SAVE_STATE level, and finally SUSPEND_POWER_DOWN level. However, with PM v2, to maintain compatibility for platform devices, I arranged for the PM v2 suspend/resume callbacks to call the old PM v1 suspend/resume callbacks three times with each level in order so that existing drivers continued to work. Since this is obsolete infrastructure which is no longer necessary, we can remove it. Here's an (untested) patch to do exactly that. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] drivers/base - fix sparse warningsBen Dooks
There are a number of sparse warnings from the latest sparse snapshot being generated from the drivers/base build. The main culprits are due to the initialisation functions not being declared in a header file. Also, the firmware.c file should include <linux/device.h> to get the prototype of firmware_register() and firmware_unregister(). This patch moves the init function declerations from the init.c file to the base.h, and ensures it is included in all the relevant c sources. It also adds <linux/device.h> to the included headers for firmware.c. The patch does not solve all the sparse errors generated, but reduces the count significantly. drivers/base/core.c:161:1: warning: symbol 'devices_subsys' was not declared. Should it be static? drivers/base/core.c:417:12: warning: symbol 'devices_init' was not declared. Should it be static? drivers/base/sys.c:253:6: warning: symbol 'sysdev_shutdown' was not declared. Should it be static? drivers/base/sys.c:326:5: warning: symbol 'sysdev_suspend' was not declared. Should it be static? drivers/base/sys.c:428:5: warning: symbol 'sysdev_resume' was not declared. Should it be static? drivers/base/sys.c:450:12: warning: symbol 'system_bus_init' was not declared. Should it be static? drivers/base/bus.c:133:1: warning: symbol 'bus_subsys' was not declared. Should it be static? drivers/base/bus.c:667:12: warning: symbol 'buses_init' was not declared. Should it be static? drivers/base/class.c:759:12: warning: symbol 'classes_init' was not declared. Should it be static? drivers/base/platform.c:313:12: warning: symbol 'platform_bus_init' was not declared. Should it be static? drivers/base/cpu.c:110:12: warning: symbol 'cpu_dev_init' was not declared. Should it be static? drivers/base/firmware.c:17:5: warning: symbol 'firmware_register' was not declared. Should it be static? drivers/base/firmware.c:23:6: warning: symbol 'firmware_unregister' was not declared. Should it be static? drivers/base/firmware.c:28:12: warning: symbol 'firmware_init' was not declared. Should it be static? drivers/base/init.c:28:13: warning: symbol 'driver_init' was not declared. Should it be static? drivers/base/dmapool.c:174:10: warning: implicit cast from nocast type drivers/base/attribute_container.c:439:1: warning: symbol 'attribute_container_init' was not declared. Should it be static? drivers/base/power/runtime.c:76:6: warning: symbol 'dpm_set_power_state' was not declared. Should it be static? Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-13[PATCH] drivers/base/*: use kzalloc instead of kmalloc+memsetJiri Slaby
Fixes a bunch of memset bugs too. Signed-off-by: Lion Vollnhals <webmaster@schiggl.de> Signed-off-by: Jiri Slaby <xslaby@fi.muni.cz> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
