commit 35b464e32c8bccef435e415db955787ead4ab44c upstream.
The DISPLAY_CLEAR command on the NewHaven NHD-0220DZW-AG5 display
does NOT change the DDRAM address to 00h (home position) like the
standard Hitachi HD44780 controller. As a consequence, the starting
position of the initial string LCD_INIT_TEXT is not guaranteed to be
at 0,0 depending on where the cursor was before the DISPLAY_CLEAR
command.
Extract of DISPLAY_CLEAR command from datasheets of:
Hitachi HD44780:
... It then sets DDRAM address 0 into the address counter...
NewHaven NHD-0220DZW-AG5 datasheet:
... This instruction does not change the DDRAM Address
Move the cursor home after sending DISPLAY_CLEAR command to support
non-standard LCDs.
Signed-off-by: Hugo Villeneuve <hvilleneuve@dimonoff.com>
Reviewed-by: Geert Uytterhoeven <geert@linux-m68k.org>
Tested-by: David Reaver <me@davidreaver.com>
Link: https://lore.kernel.org/r/20230722180925.1408885-1-hugo@hugovil.com
Signed-off-by: Miguel Ojeda <ojeda@kernel.org>
[ Upstream commit ddf75a86aba2cfb7ec4497e8692b60c8c8fe0ee7 ]
hd44780_probe() allocates a memory chunk for hd with kzalloc() and
makes "lcd->drvdata->hd44780" point to it. When we call hd44780_remove(),
we should release all relevant memory and resource. But "lcd->drvdata
->hd44780" is not released, which will lead to a memory leak.
We should release the "lcd->drvdata->hd44780" in hd44780_remove() to fix
the memory leak bug.
Fixes: 718e05ed92ec ("auxdisplay: Introduce hd44780_common.[ch]")
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Reported-by: kernel test robot <lkp@intel.com>
Signed-off-by: Jianglei Nie <niejianglei2021@163.com>
The value returned by an i2c driver's remove function is mostly ignored.
(Only an error message is printed if the value is non-zero that the
error is ignored.)
So change the prototype of the remove function to return no value. This
way driver authors are not tempted to assume that passing an error to
the upper layer is a good idea. All drivers are adapted accordingly.
There is no intended change of behaviour, all callbacks were prepared to
return 0 before.
Reviewed-by: Peter Senna Tschudin <peter.senna@gmail.com>
Reviewed-by: Jeremy Kerr <jk@codeconstruct.com.au>
Reviewed-by: Benjamin Mugnier <benjamin.mugnier@foss.st.com>
Reviewed-by: Javier Martinez Canillas <javierm@redhat.com>
Reviewed-by: Crt Mori <cmo@melexis.com>
Reviewed-by: Heikki Krogerus <heikki.krogerus@linux.intel.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Marek Behún <kabel@kernel.org> # for leds-turris-omnia
Acked-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Reviewed-by: Petr Machata <petrm@nvidia.com> # for mlxsw
Reviewed-by: Maximilian Luz <luzmaximilian@gmail.com> # for surface3_power
Acked-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com> # for bmc150-accel-i2c + kxcjk-1013
Reviewed-by: Hans Verkuil <hverkuil-cisco@xs4all.nl> # for media/* + staging/media/*
Acked-by: Miguel Ojeda <ojeda@kernel.org> # for auxdisplay/ht16k33 + auxdisplay/lcd2s
Reviewed-by: Luca Ceresoli <luca.ceresoli@bootlin.com> # for versaclock5
Reviewed-by: Ajay Gupta <ajayg@nvidia.com> # for ucsi_ccg
Acked-by: Jonathan Cameron <Jonathan.Cameron@huawei.com> # for iio
Acked-by: Peter Rosin <peda@axentia.se> # for i2c-mux-*, max9860
Acked-by: Adrien Grassein <adrien.grassein@gmail.com> # for lontium-lt8912b
Reviewed-by: Jean Delvare <jdelvare@suse.de> # for hwmon, i2c-core and i2c/muxes
Acked-by: Corey Minyard <cminyard@mvista.com> # for IPMI
Reviewed-by: Vladimir Oltean <olteanv@gmail.com>
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Acked-by: Sebastian Reichel <sebastian.reichel@collabora.com> # for drivers/power
Acked-by: Krzysztof Hałasa <khalasa@piap.pl>
Signed-off-by: Wolfram Sang <wsa@kernel.org>
Currently the reading of the onstack array is confusing since two
out of three members are of different types. Let it be more clear
by explicitly set the array size, so everybody will understand that
parameters are cast to the type of the array.
While at it, add a missed space.
The deprecated i2c ->probe() functionality doesn't work with
OF compatible strings, as it only checks for the i2c device id.
While it's not a problem right now, it would still bring a
better code. Switch to the new way of probing.
Use the module_i2c_driver() macro to make the code smaller
and a bit simpler.
Make use of device property API in this driver so that both OF based
system and ACPI based system can use this driver.
Fix multi-line comment style:
- start sentences with Capital letter
- use non-networking style of the first line
While it might work, the current approach is fragile in a few ways:
- whenever members in the structure are shuffled, the pointer will be wrong
- the resource freeing may include more than covered by kfree()
Fix this by using charlcd_free() call instead of kfree().
Fixes: 8c9108d014c5 ("auxdisplay: add a driver for lcd2s character display")
Cc: Lars Poeschel <poeschel@lemonage.de>
Once allocated the struct lcd2s_data is never freed.
Fix the memory leak by switching to devm_kzalloc().
It seems that the lcd2s_redefine_char() has never been properly
tested. The buffer is filled by DEF_CUSTOM_CHAR command followed
by the character number (from 0 to 7), but immediately after that
these bytes are rewritten by the decoded hex stream.
Fix the index to fill the buffer after the command and number.
[fixed typo in commit message]
Check if the pointer lcd->ops->init_display exists before dereferencing it.
If a driver called charlcd_init() without defining the ops, this would
return segmentation fault, as happened to me when implementing a charlcd
driver. Checking the pointer before dereferencing protects from
segmentation fault.
Signed-off-by: Luiz Sampaio <sampaio.ime@gmail.com>
Removing 'int' from 'unsigned long int' declaration, which is unnecessary.
Resolves the checkpatch error.
Signed-off-by: Huiquan Deng <denghuiquan@cdjrlc.com>
[reworded and avoid moving the line]
ht16k33.c doesn't use any macro or function declared in
linux/slab.h. Thus, these files can be removed from ht16k33.c
safely without affecting the compilation.
Signed-off-by: Mianhan Liu <liumh1@shanghaitech.edu.cn>
Acked-by: Robin van der Gracht <robin@protonic.nl>
[reworded]
ks0108.c doesn't use any macro or function declared in
linux/fs.h, linux/io.h and linux/uaccess.h. Thus,
these files can be removed from ks0108.c safely without
[reworded]
cfag12864bfb.c doesn't use any macro or function declared in
linux/delay.h, linux/string.h and linux/uaccess.h. Thus,
these files can be removed from cfag12864bfb.c safely without
[reworded]
The device property API allows drivers to gather device resources from
different sources, such as ACPI, and lift the dependency on Device Tree.
Convert the driver to unleash the power of the device property API.
Suggested-by: Marek Behún <kabel@kernel.org>
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Instantiate a single LED based on the "led" subnode in DT.
This allows the user to control display brightness and blinking (backed
by hardware support) through the LED class API and triggers, and exposes
the display color. The LED will be named
"auxdisplay:<color>:<function>".
When running in dot-matrix mode and if no "led" subnode is found, the
driver falls back to the traditional backlight mode, to preserve
backwards compatibility.
Reviewed-by: Marek Behún <kabel@kernel.org>
Reviewed-by: Robin van der Gracht <robin@protonic.nl>
The Holtek HT16K33 LED controller is not only used for driving
dot-matrix displays, but also for driving segment displays.
Add support for 4-digit 7-segment and quad 14-segment alphanumeric
displays, like the Adafruit 7-segment and 14-segment display backpack
and FeatherWing expansion boards. Use the character line display core
support to display a message, which will be scrolled if it doesn't fit.
Extract all frame buffer (including backlight) probing into
ht16k33_fbdev_probe().
Call ht16k33_fbdev_probe() after ht16k33_keypad_probe(), as the latter
does not need any manual cleanup in the probe error path.
Extract brightness handling into a helper function, so it can be called
from multiple places.
Move delayed_work from ht16k33_fbdev to ht16k33_priv, as it is not
specific to dot-matrix displays, but common to all display types.
This driver has many users of "client->dev". Add shorthands to simplify
the code.
ht16k33_probe() does not use the passed i2c_device_id, so the driver can
be converted trivially to the new-style of i2c probing.
There is no need to check the return code of input_register_device(),
just propagate it to the caller.
Use the existing HT16K33_FB_SIZE definition instead of open-coding the
same calculation using an hardcoded value.
While at it, restore reverse Christmas tree variable declaration order.
As the ht16k33 frame buffer sub-driver does not register an
fb_ops.fb_blank() handler, blanking does not work:
$ echo 1 > /sys/class/graphics/fb0/blank
sh: write error: Invalid argument
Fix this by providing a handler that always returns zero, to make sure
blank events will be sent to the actual device handling the backlight.
Reported-by: Robin van der Gracht <robin@protonic.nl>
Suggested-by: Robin van der Gracht <robin@protonic.nl>
Fixes: 8992da44c6805d53 ("auxdisplay: ht16k33: Driver for LED controller")
Currently /sys/class/graphics/fb0/bl_curve is not accessible (-ENODEV),
as the driver does not connect the backlight to the frame buffer device.
Fix this moving backlight initialization up, and filling in
fb_info.bl_dev.
If the message to display is longer than the number of characters that
the display can show, the message will be scrolled. Currently the
scroll rate is fixed, moving every 500 ms.
Add support for changing the scroll rate through a "scroll_step_ms"
device attribute in sysfs.
Use the existing kmemdup_nul() helper instead of open-coding the same
operation.
Extract the character line display core support from the simple ASCII
LCD driver for the MIPS Boston, Malta & SEAD3 development boards into
its own subdriver, so it can be reused for other displays.
As this moves the "message" device attribute in sysfs in a "linedisp.N"
subdirectory, a symlink is added to preserve backwards compatibility.
Convert the "message" device attribute from sprintf() to sysfs_emit(),
as the latter is aware of the PAGE_SIZE buffer.
img_ascii_lcd_probe() has many users of "pdev->dev". Add a shorthand to
simplify the code.
While writing an empty string to a device attribute is a no-op, and thus
does not need explicit safeguards, the user can still write a single
newline to an attribute file:
echo > .../message
If that happens, img_ascii_lcd_display() trims the newline, yielding an
empty string, and causing an infinite loop in img_ascii_lcd_scroll().
Fix this by adding a check for empty strings. Clear the display in case
one is encountered.
Fixes: 0cad855fbd083ee5 ("auxdisplay: img-ascii-lcd: driver for simple ASCII LCD displays")
Resolves the checkpatch warning.
Signed-off-by: Jinchao Wang <wjc@cdjrlc.com>
[edited wording]
Switch to use module_parport_driver() to reduce boilerplate code.
For structure initializers the fields are 0 (or NULL) by default, so
there is no need to fill them explicitly. Besides that, much easier
to read when initializers use C99 style. Hence, convert to C99 style
as well.
Acked-by: Willy Tarreau <w@1wt.eu>
Cc: stable@vger.kernel.org
Link: https://lore.kernel.org/lkml/CAHp75VfKyqy+vM0XkP9Yb+znGOTVT4zYCRY3A3nQ7C3WNUVN0g@mail.gmail.com/
Reported-By: Andy Shevchenko <andy.shevchenko@gmail.com>
Signed-off-by: Lars Poeschel <poeschel@lemonage.de>
Tested-by: Andy Shevchenko <andy.shevchenko@gmail.com>
[added Link, Fixes, Cc stable tags, edited message]
The section "19) Editor modelines and other cruft" in
Documentation/process/coding-style.rst clearly says, "Do not include any
of these in source files."
I recently receive a patch to explicitly add a new one.
Let's do treewide cleanups, otherwise some people follow the existing code
and attempt to upstream their favoriate editor setups.
It is even nicer if scripts/checkpatch.pl can check it.
If we like to impose coding style in an editor-independent manner, I think
editorconfig (patch [1]) is a saner solution.
[1] https://lore.kernel.org/lkml/20200703073143.423557-1-danny@kdrag0n.dev/
Link: https://lkml.kernel.org/r/20210324054457.1477489-1-masahiroy@kernel.org
Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Reviewed-by: Miguel Ojeda <ojeda@kernel.org> [auxdisplay]
charlcd_write() is invoked as a VFS->write() callback and as such it is
always invoked from preemptible context and may sleep.
charlcd_puts() is invoked from register/unregister callback which is
preemptible. The reboot notifier callback is also invoked from
preemptible context.
Therefore there is no need to use in_interrupt() to figure out if it
is safe to sleep because it always is. in_interrupt() and related
context checks are being removed from non-core code.
Using schedule() to schedule (and be friendly to others) is
discouraged and cond_resched() should be used instead.
Remove in_interrupt() and use cond_resched() to schedule every 32
iterations if needed.
Link: https://lkml.kernel.org/r/20200914204209.256266093@linutronix.de
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
[mo: fixed a couple typos in comment and commit message]
Update contact info.
Link: https://lkml.kernel.org/r/20210206162524.GA11520@kernel.org
A second CHARLCD config symbol was added instead of moving the existing
one. Fix this by removing the old one.
Fixes: 718e05ed92ecac0d ("auxdisplay: Introduce hd44780_common.[ch]")
Drop the call to msecs_to_jiffies(), as "HZ / fbdev->refresh_rate" is
already the number of jiffies to wait.
Keyscan should be optional to support simple LED matrix displays (output
only).
Reported-by: Michael Kaplan <M.KAPLAN@evva.com>
Signed-off-by: Robin van der Gracht <robin@protonic.nl>
[geert: Rebased]
The three struct charlcd_ops contain the same data, so we only need one
of this structures. The other two are removed.
charlcd drivers need to provide some print function to charlcd. For
hd44780 based panel driver this function was missing. We provide the
generic hd44780_common_print function which should be suitable.
Fixes: b26deabb1d915fe87d395081bbd3058b938dee89 ("auxdisplay: hd44780_common_print")
Reported-by: kernel test robot <oliver.sang@intel.com>
drivers/auxdisplay/lcd2s.c:373:3-8: No need to set .owner here. The core will do it.
Remove .owner field if calls are used which set it automatically
Generated by: scripts/coccinelle/api/platform_no_drv_owner.cocci
CC: Lars Poeschel <poeschel@lemonage.de>
Signed-off-by: kernel test robot <lkp@intel.com>
The kfree() needs to be moved down a line to prevent a use after free.
When building the hd44780_common driver without a driver that actually
uses it like panel or hd44780 you get a build error, because
hd44780_common uses charlcd, but did not select it. Its users did
select it.
This is fixed now. hd4478_common now selects charlcd in Kconfig and
panel and hd44780 do not. They only select hd44780_common.
Reported-by: Randy Dunlap <rdunlap@infradead.org>
