path: root/drivers/atm
2012-05-06skb: Add inline helper for getting the skb end offset from headAlexander Duyck
With the recent changes for how we compute the skb truesize it occurs to me we are probably going to have a lot of calls to skb_end_pointer - skb->head. Instead of running all over the place doing that it would make more sense to just make it a separate inline skb_end_offset(skb) that way we can return the correct value without having gcc having to do all the optimization to cancel out skb->head - skb->head. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2012-04-04Driver: Atm: Remove 'break' after 'return' statement.Santosh Nayak
'break' is unnecessary after 'return' statement. Remove all such 'break' as clean up. Signed-off-by: Santosh Nayak <santoshprasadnayak@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
2012-03-16eni: fix driver remove function and driver probe error path.françois romieu
- add eni_do_release() to balance eni_do_init - turn the zeroes DMA area into a per device data Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-11drivers/atm/eni.c: ensure arguments to request_irq and free_irq are compatibleJulia Lawall
Convert calls to free_irq so that the second argument is the same as the last argument of the corresponding call to request_irq. Without this property, free_irq does nothing. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/sfc/rx.c Overlapping changes in drivers/net/ethernet/sfc/rx.c, one to change the rx_buf->is_page boolean into a set of u16 flags, and another to adjust how ->ip_summed is initialized. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-19drivers/atm/solos-pci.c: exchange pci_iounmapsJulia Lawall
The calls to pci_iounmap are in the wrong order, as compared to the associated calls to pci_iomap. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression e,x; statement S,S1; int ret; @@ e = pci_iomap(x,...) ... when != pci_iounmap(x,e) if (<+...e...+>) S ... when any when != pci_iounmap(x,e) *if (...) { ... when != pci_iounmap(x,e) return ...; } ... when any pci_iounmap(x,e); // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-01atm: Fix typo in lanai.cMasanari Iida
Correct spelling "reseting" to resetting" in drivers/atm/lanai.c Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-13module_param: make bool parameters really bool (drivers & misc)Rusty Russell
module_param(bool) used to counter-intuitively take an int. In fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy trick. It's time to remove the int/unsigned int option. For this version it'll simply give a warning, but it'll break next kernel version. Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-11-26atm: eliminate atm_guess_pdu2truesize()chas williams - CONTRACTOR
Signed-off-by: Chas Williams - CONTRACTOR <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1745 commits) dp83640: free packet queues on remove dp83640: use proper function to free transmit time stamping packets ipv6: Do not use routes from locally generated RAs |PATCH net-next] tg3: add tx_dropped counter be2net: don't create multiple RX/TX rings in multi channel mode be2net: don't create multiple TXQs in BE2 be2net: refactor VF setup/teardown code into be_vf_setup/clear() be2net: add vlan/rx-mode/flow-control config to be_setup() net_sched: cls_flow: use skb_header_pointer() ipv4: avoid useless call of the function check_peer_pmtu TCP: remove TCP_DEBUG net: Fix driver name for mdio-gpio.c ipv4: tcp: fix TOS value in ACK messages sent from TIME_WAIT rtnetlink: Add missing manual netlink notification in dev_change_net_namespaces ipv4: fix ipsec forward performance regression jme: fix irq storm after suspend/resume route: fix ICMP redirect validation net: hold sock reference while processing tx timestamps tcp: md5: add more const attributes Add ethtool -g support to virtio_net ... Fix up conflicts in: - drivers/net/Kconfig: The split-up generated a trivial conflict with removal of a stale reference to Documentation/networking/net-modules.txt. Remove it from the new location instead. - fs/sysfs/dir.c: Fairly nasty conflicts with the sysfs rb-tree usage, conflicting with Eric Biederman's changes for tagged directories.
2011-10-19net: add skb frag size accessorsEric Dumazet
To ease skb->truesize sanitization, its better to be able to localize all references to skb frags size. Define accessors : skb_frag_size() to fetch frag size, and skb_frag_size_{set|add|sub}() to manipulate it. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-03atm/iphase : removal of PCI space dereferences.françois romieu
Mostly PHY access and a few (ugly) debug statements for DMA control. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-09-15Merge branch 'master' into for-nextJiri Kosina
Fast-forward merge with Linus to be able to merge patches based on more recent version of the tree.
2011-09-15atm: Convert vmalloc/memset to vzallocJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-08-26atm: convert to SKB paged frag API.Ian Campbell
Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Chas Williams <chas@cmf.nrl.navy.mil> Cc: linux-atm-general@lists.sourceforge.net Cc: netdev@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-12lanai: use pci_dev->subsystem_deviceSergei Shtylyov
The driver reads PCI subsystem IDs from the PCI configuration registers while it is already stored by the PCI subsystem in the 'subsystem_device' field of 'struct pci_dev'... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-08ATM: Delete no use FILL_RX_POOLS_IN_BH marcoWang Shaoyan
The macro FILL_RX_POOLS_IN_BH is never been used, in order to avoid the compiler reports error because of the usage of function INIT_WORK, we just delete the marco. Cc: Chas Williams <chas@cmf.nrl.navy.mil> Cc: linux-atm-general@lists.sourceforge.net Signed-off-by: Wang Shaoyan <wangshaoyan.pt@taobao.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-06net: remove interrupt.h inclusion from netdevice.hAlexey Dobriyan
* remove interrupt.g inclusion from netdevice.h -- not needed * fixup fallout, add interrupt.h and hardirq.h back where needed. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1446 commits) macvlan: fix panic if lowerdev in a bond tg3: Add braces around 5906 workaround. tg3: Fix NETIF_F_LOOPBACK error macvlan: remove one synchronize_rcu() call networking: NET_CLS_ROUTE4 depends on INET irda: Fix error propagation in ircomm_lmp_connect_response() irda: Kill set but unused variable 'bytes' in irlan_check_command_param() irda: Kill set but unused variable 'clen' in ircomm_connect_indication() rxrpc: Fix set but unused variable 'usage' in rxrpc_get_transport() be2net: Kill set but unused variable 'req' in lancer_fw_download() irda: Kill set but unused vars 'saddr' and 'daddr' in irlan_provider_connect_indication() atl1c: atl1c_resume() is only used when CONFIG_PM_SLEEP is defined. rxrpc: Fix set but unused variable 'usage' in rxrpc_get_peer(). rxrpc: Kill set but unused variable 'local' in rxrpc_UDP_error_handler() rxrpc: Kill set but unused variable 'sp' in rxrpc_process_connection() rxrpc: Kill set but unused variable 'sp' in rxrpc_rotate_tx_window() pkt_sched: Kill set but unused variable 'protocol' in tc_classify() isdn: capi: Use pr_debug() instead of ifdefs. tg3: Update version to 3.119 tg3: Apply rx_discards fix to 5719/5720 ... Fix up trivial conflicts in arch/x86/Kconfig and net/mac80211/agg-tx.c as per Davem.
2011-05-18drivercore: revert addition of of_match to struct deviceGrant Likely
Commit b826291c, "drivercore/dt: add a match table pointer to struct device" added an of_match pointer to struct device to cache the of_match_table entry discovered at driver match time. This was unsafe because matching is not an atomic operation with probing a driver. If two or more drivers are attempted to be matched to a driver at the same time, then the cached matching entry pointer could get overwritten. This patch reverts the of_match cache pointer and reworks all users to call of_match_device() directly instead. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-04-17atm: solos-pci: Fix set-but-unused variable.David S. Miller
This is just a readback to entire completion of a register write, keep the readback but kill the unused variable. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-17atm: idt77252: Fix set-but-unused variables.David S. Miller
Two cases here: 1) idt77252_rx_raw() really does not make any use of the extracted PTI field of the atm header. 2) idt77252_collect_stat() only uses the register values in code which has been compiled out by a "NOTDEF" cpp test for more than 10 years. Just kill this NOTDEF code entirely, but keep the register reads in case they have side effects. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-17atm: he: Fix undefined sequence points.David S. Miller
GCC complains in these queue index operations because we perform operations of the form: x = some_operation(++x); which is undefined. Replace with: x = some_operation(x + 1); which is well defined and provides the intended operation. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-17atm: eni: Kill set-but-unused variables.David S. Miller
The variable eni_dev is initialized but never subsequently used in these two functions. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-12atm: iphase: Fix set-but-not-used warnings.David S. Miller
The "iavcc" and "iadev" cases are obvious. The intr_status and frmr_intr cases are reading a register to clear the chip status. This driver is pretty old and creaky, and uses volatile pointer dereferences to do register I/O when it should be using readl() and friends. However that it outside of the scope of these changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-07Merge branch 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6Linus Torvalds
* 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6: Fix common misspellings
2011-03-30atm/solos-pci: Don't flap VCs when carrier state changesPhilip A. Prindeville
Don't flap VCs when carrier state changes; higher-level protocols can detect loss of connectivity and act accordingly. This is more consistent with how other network interfaces work. We no longer use release_vccs() so we can delete it. release_vccs() was duplicated from net/atm/common.c; make the corresponding function exported, since other code duplicates it and could leverage it if it were public. Signed-off-by: Philip A. Prindeville <philipp@redfish-solutions.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-30atm/solos-pci: Don't include frame pseudo-header on transmit hex-dumpPhilip A. Prindeville
Omit pkt_hdr preamble when dumping transmitted packet as hex-dump; we can pull this up because the frame has already been sent, and dumping it is the last thing we do with it before freeing it. Also include the size, vpi, and vci in the debug as is done on receive. Use "port" consistently instead of "device" intermittently. Signed-off-by: Philip Prindeville <philipp@redfish-solutions.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-30atm/solos-pci: Use VPI.VCI notation uniformly.Philip A. Prindeville
Use VPI.VCI notation consistently throughout the module. This is the one remaining place where the VCI is used before the VPI in any output. Signed-off-by: Philip Prindeville <philipp@redfish-solutions.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits) doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore Update cpuset info & webiste for cgroups dcdbas: force SMI to happen when expected arch/arm/Kconfig: remove one to many l's in the word. asm-generic/user.h: Fix spelling in comment drm: fix printk typo 'sracth' Remove one to many n's in a word Documentation/filesystems/romfs.txt: fixing link to genromfs drivers:scsi Change printk typo initate -> initiate serial, pch uart: Remove duplicate inclusion of linux/pci.h header fs/eventpoll.c: fix spelling mm: Fix out-of-date comments which refers non-existent functions drm: Fix printk typo 'failled' coh901318.c: Change initate to initiate. mbox-db5500.c Change initate to initiate. edac: correct i82975x error-info reported edac: correct i82975x mci initialisation edac: correct commented info fs: update comments to point correct document target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c ... Trivial conflict in fs/eventpoll.c (spelling vs addition)
2011-02-28dt: Eliminate of_platform_{,un}register_driverGrant Likely
Final step to eliminate of_platform_bus_type. They're all just platform drivers now. v2: fix type in pasemi_nand.c (thanks to Stephen Rothwell) Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-02-15Merge branch 'master' into for-nextJiri Kosina
2011-02-13ATM, Solos PCI ADSL2+: Don't deref NULL pointer if net_ratelimit() and ↵Jesper Juhl
alloc_skb() interact badly. If alloc_skb() fails to allocate memory and returns NULL then we want to return -ENOMEM from drivers/atm/solos-pci.c::popen() regardless of the value of net_ratelimit(). The way the code is today, we may not return if net_ratelimit() returns 0, then we'll proceed to pass a NULL pointer to skb_put() which will blow up in our face. This patch ensures that we always return -ENOMEM on alloc_skb() failure and only let the dev_warn() be controlled by the value of net_ratelimit(). Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-02fix typos 'comamnd' -> 'command' in commentsJustin P. Mattock
2011-01-24Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
2011-01-21atm: idt77105: fix fetch_stats() resultVasiliy Kulikov
copy_to_user() used PRIV(dev)->stats instead of local stats variable. Zero stats were returned to user in case of (zero != 0), also memcpy() was pointless. Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-13Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) Documentation/trace/events.txt: Remove obsolete sched_signal_send. writeback: fix global_dirty_limits comment runtime -> real-time ppc: fix comment typo singal -> signal drivers: fix comment typo diable -> disable. m68k: fix comment typo diable -> disable. wireless: comment typo fix diable -> disable. media: comment typo fix diable -> disable. remove doc for obsolete dynamic-printk kernel-parameter remove extraneous 'is' from Documentation/iostats.txt Fix spelling milisec -> ms in snd_ps3 module parameter description Fix spelling mistakes in comments Revert conflicting V4L changes i7core_edac: fix typos in comments mm/rmap.c: fix comment sound, ca0106: Fix assignment to 'channel'. hrtimer: fix a typo in comment init/Kconfig: fix typo anon_inodes: fix wrong function name in comment fix comment typos concerning "consistent" poll: fix a typo in comment ... Fix up trivial conflicts in: - drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c) - fs/ext4/ext4.h Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
2011-01-09Madge Ambassador ATM Adapter driver: Always release_firmware() in ↵Jesper Juhl
ucode_init() and don't leak memory. Failure to call release_firmware() will result in memory leak in drivers/atm/ambassador.c::ucode_init(). This patch makes sure we always call release_firmware() when needed, thus removing the leak(s). Yes, I know checkpatch complains about this patch, but it was either that or completely mess up the existing style, so I opted to use the existing style and live with the checkpatch related flak. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-04Merge branch 'master' of ↵David S. Miller
2010-12-31drivers/atm/atmtcp.c: add missing atm_dev_putJulia Lawall
The earlier call to atm_dev_lookup increases the reference count of dev, so decrease it on the way out. The semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression x, E; constant C; @@ x = atm_dev_lookup(...); ... when != false x != NULL when != true x == NULL when != \(E = x\|x = E\) when != atm_dev_put(dev); *return -C; // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-22Merge branch 'master' into for-nextJiri Kosina
Conflicts: MAINTAINERS arch/arm/mach-omap2/pm24xx.c drivers/scsi/bfa/bfa_fcpim.c Needed to update to apply fixes for which the old branch was too outdated.
2010-12-17Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/bnx2x/bnx2x.h drivers/net/wireless/iwlwifi/iwl-1000.c drivers/net/wireless/iwlwifi/iwl-6000.c drivers/net/wireless/iwlwifi/iwl-core.h drivers/vhost/vhost.c
2010-12-10atm: correct sysfs 'device' link creation and parent relationshipsDan Williams
The ATM subsystem was incorrectly creating the 'device' link for ATM nodes in sysfs. This led to incorrect device/parent relationships exposed by sysfs and udev. Instead of rolling the 'device' link by hand in the generic ATM code, pass each ATM driver's bus device down to the sysfs code and let sysfs do this stuff correctly. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-08atm: lanai: use kernel's '%pM' format option to print MACAndy Shevchenko
Signed-off-by: Andy Shevchenko <andy.shevchenko@gmail.com> Cc: Chas Williams <chas@cmf.nrl.navy.mil> Cc: linux-atm-general@lists.sourceforge.net Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-18atm: fore200e: Fix build warning.David S. Miller
GCC (rightfully) complains that: drivers/atm/fore200e.c:614:5: warning: operation on 'cmdq->head' may be undefined This is due to the FORE200E_NEXT_ENTRY macro, which essentially evaluates to: i = ++i % m Make it what's explicitly intended here which is: i = (i + 1) % m and the warning goes away. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-08solos: Refuse to upgrade firmware with older FPGA. It doesn't work.David Woodhouse
Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
