path: root/drivers/ata
2009-01-27Merge branch 'hibern_fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'hibern_fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: SATA PIIX: Blacklist system that spins off disks during ACPI power off SATA Sil: Blacklist system that spins off disks during ACPI power off SATA AHCI: Blacklist system that spins off disks during ACPI power off SATA: Blacklisting of systems that spin off disks during ACPI power off DMI: Introduce dmi_first_match to make the interface more flexible Hibernation: Introduce system_entering_hibernation
2009-01-27SATA PIIX: Blacklist system that spins off disks during ACPI power offRafael J. Wysocki
Some notebooks from HP have the problem that their BIOSes attempt to spin down hard drives before entering ACPI system states S4 and S5. This leads to a yo-yo effect during system power-off shutdown and the last phase of hibernation when the disk is first spun down by the kernel and then almost immediately turned on and off by the BIOS. This, in turn, may result in shortening the disk's life times. To prevent this from happening we can blacklist the affected systems using DMI information. Blacklist HP 2510p that uses the ata_piix driver. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-27SATA Sil: Blacklist system that spins off disks during ACPI power offRafael J. Wysocki
Some notebooks from HP have the problem that their BIOSes attempt to spin down hard drives before entering ACPI system states S4 and S5. This leads to a yo-yo effect during system power-off shutdown and the last phase of hibernation when the disk is first spun down by the kernel and then almost immediately turned on and off by the BIOS. This, in turn, may result in shortening the disk's life times. To prevent this from happening we can blacklist the affected systems using DMI information. Blacklist HP nx6325 that uses the sata_sil driver. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-27SATA AHCI: Blacklist system that spins off disks during ACPI power offRafael J. Wysocki
Some notebooks from HP have the problem that their BIOSes attempt to spin down hard drives before entering ACPI system states S4 and S5. This leads to a yo-yo effect during system power-off shutdown and the last phase of hibernation when the disk is first spun down by the kernel and then almost immediately turned on and off by the BIOS. This, in turn, may result in shortening the disk's life times. To prevent this from happening we can blacklist the affected systems using DMI information. Blacklist HP nx6310 that uses the AHCI driver. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-27SATA: Blacklisting of systems that spin off disks during ACPI power offRafael J. Wysocki
Introduce new libata flags ATA_FLAG_NO_POWEROFF_SPINDOWN and ATA_FLAG_NO_HIBERNATE_SPINDOWN that, if set, will prevent disks from being spun off during system power off and hibernation, respectively (to handle the hibernation case we need the new system state SYSTEM_HIBERNATE_ENTER that can be checked against by libata, in analogy with SYSTEM_POWER_OFF). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-27pata-rb532-cf: remove set_irq_type from finish_ioPhil Sutter
The driver has been tested without the call to set_irq_type at this point and occurs to work fine, so it should be safe to remove it. Signed-off-by: Phil Sutter <n0-1@freewrt.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-26[libata] pata_via: support VX855, future chips whose IDE controller use 0x0571JosephChan@via.com.tw
It supports VX855 and future chips whose IDE controller uses PCI ID 0x0571. Signed-off-by: Joseph Chan <josephchan@via.com.tw> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-26sata_mv: no longer experimental (v2)Mark Lord
Update Kconfig for sata_mv with full list of chips supported, and (finally!) remove the "EXPERIMENTAL" designations. Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-26sata_mv: msi masking fix (v2)Mark Lord
Enable reliable use of Message-Signaled Interrupts (MSI) in sata_mv by masking further chip interrupts within the main interrupt handler. Based upon a suggestion by Grant Grundler. MSI is working reliably in all of my test systems here now. Signed-off-by: Mark Lord <mlord@pobox.com> Reviewed-by: Grant Grundler <grundler@google.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-26sata_mv: Properly initialize main irq maskThomas Reitmayr
I noticed that during initialization sata_mv.c assumes that the main interrupt mask has its default value of 0. The function mv_platform_probe(..) initializes a shadow irq mask with 0 assuming that's the value of the controller's register. Now mv_set_main_irq_mask(..) only writes the controller's register if the new value differs from the "shadowed" value. This is fatal when trying to disable all interrupts in mv_init_host(..), i.e. the following function call does not write anything to the main irq mask register: mv_set_main_irq_mask(host, ~0, 0); The effect I see on my machine (QNAP TS-109 II) with booting via kexec (with Linux as a 2nd-stage boot loader) is that if the sata_mv module was still loaded when performing kexec, then the new kernel's sata_mv module starts up with interrupts enabled. This results in an unhandled IRQ and breaks the boot process. The unhandled interrupt itself might also be fixed by Lennert's patch proposed at http://markmail.org/message/kwvzxstnlsa3s26w which I did not try yet. However I still propose to additionally initialize the shadow variable with the current contents of the main irq mask register to get both in sync and allow proper disabling the main irq mask. This fixes the unhandled irq on my machine. Signed-off-by: Thomas Reitmayr <treitmayr@devbase.at> Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-26sata_mv: remove bogus nsect restrictionMark Lord
Remove unneeded nsect restriction from GenII NCQ path, and improve comments to explain why this is not a problem. Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-26sata_mv: don't read hc_irq_causeMark Lord
Remove silly read-modify-write sequences when clearing interrupts in hc_irq_cause. This gets rid of unneeded MMIO reads, resulting in a slight performance boost when switching between EDMA and non-EDMA modes (eg. for cache flushes). Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-26sata_mv: fix 8-port timeouts on 508x/6081 chipsMark Lord
Fix a longstanding bug for the 8-port Marvell Sata controllers (508x/6081), where accesses to the upper 4 ports would cause lost-interrupts / timeouts for the lower 4-ports. With this patch, the 6081 boards should finally be reliable enough for mainstream use with Linux. Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-26sata_nv: fix MCP5x resetTejun Heo
MCP5x family of controllers seem to share much more with nf2's as far as reset protocol is concerned. It requires heardreset to get the PHY going and classfication code report after hardreset is unreliable. Create a new board type MCP5x and use noclassify hardreset. SWNCQ is modified to inherit from this new type. This fixes hotplug regression reported in kernel bz#12351. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-26sata_nv: rename nv_nf2_hardreset()Tejun Heo
nv_nf2_hardreset() will be used by other flavors too. Rename it to nv_noclassify_hardreset(). Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-26libata: set NODEV_HINT for 0x7f statusTejun Heo
Asus Pundit-R with atiixp controller has the second port missing and, very unusually, its status is stuck at 0x7f and all others at 0. This meanst that it fails TF access test but gets detected as a disk due to classification code check and then evades polling IDENTIFY presence detection thanks to the missing BSY in the status value causing excessive delays during boot. This patch makes libata-sff HSM set NODEV_HINT if the status is 0x7f to make polling IDENTIFY presence detection work for these machines. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-26libata-sff: fix incorrect EH messageTejun Heo
The EH message for NODEV_HINT path was describing the opposite condition. Fix it. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-16sata_fsl: Return non-zero on error in probe()Michal Sojka
while I was looking over kernel sources I've found this small bug. Formerly, zero was returned even if an error happened. Signed-off-by: Michal Sojka <sojkam1@fel.cvut.cz> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-16drivers/ata/pata_ali.c: s/isa_bridge/ali_isa_bridge/ to fix alpha buildAndrew Morton
drivers/ata/pata_ali.c:44: error: static declaration of 'isa_bridge' follows non-static declaration arch/alpha/include/asm/pci.h:274: error: previous declaration of 'isa_bridge' was here Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-16libata: New driver for OCTEON SOC Compact Flash interface (v7).David Daney
Cavium OCTEON processor support was recently merged, so now we have this CF driver for your consideration. Most OCTEON variants have *no* DMA or interrupt support on the CF interface so for these, only PIO is supported. Although if DMA is available, we do take advantage of it. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-16libata: Add another column to the ata_timing table.David Daney
The forthcoming OCTEON SOC Compact Flash driver needs an additional timing value that was not available in the ata_timing table. I add a new column for dmack_hold time. The values were obtained from the Compact Flash specification Rev 4.1. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-16sata_via: Add VT8261 supportJosephChan@via.com.tw
Signed-off-by: Joseph Chan <josephchan@via.com.tw> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-16pata_atiixp: update port enabledness test handlingTejun Heo
Port enabledness test fits much better into init_one() instead of pre_reset(). The reason why these tests are in pre_reset() is purely historical at this point. Move it to init_one(). This will help further changes. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-16[libata] get-identity ioctl: Fix use of invalid memory pointerJeff Garzik
for SAS drivers. Caught by Ke Wei (and team?) at Marvell. Also, move the ata_scsi_ioctl export to libata-scsi.c, as that seems to be the general trend. Acked-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-13pata_it821x: Update RDC UDMA handlingAlan Cox
The UDMA affliction is apparently specific to revision 0x11. Keeps us in sync with drivers/ide current. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-13ata: fix wrong WARN_ON_ONCEChristian Borntraeger
This patch fixes a wrong WARN_ON that was triggered by 32bit PIO support: WARNING: at drivers/ata/libata-sff.c:1017 ata_sff_hsm_move+0x45e/0x750() __atapi_pio_bytes simply doesnt know enough to decide if there is a bug. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-10libata: only ports >= 0 need to synchronizeArjan van de Ven
In a discussio with Jeff Garzik, he mentioned that the serialization for the libata port probes only needs to be within the domain of a host. This means that for the first port of each host (with ID 0), we don't need to wait, so we can relax our serialization a little. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-10libata: Add a per-host flag to opt-in into parallel port probesArjan van de Ven
This patch adds a per host flag that allows drivers to opt in into having its busses scanned in parallel. Drivers that do not set this flag get their ports scanned in the "original" sequence. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-09Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (94 commits) ACPICA: hide private headers ACPICA: create acpica/ directory ACPI: fix build warning ACPI : Use RSDT instead of XSDT by adding boot option of "acpi=rsdt" ACPI: Avoid array address overflow when _CST MWAIT hint bits are set fujitsu-laptop: Simplify SBLL/SBL2 backlight handling fujitsu-laptop: Add BL power, LED control and radio state information ACPICA: delete utcache.c ACPICA: delete acdisasm.h ACPICA: Update version to 20081204. ACPICA: FADT: Update error msgs for consistency ACPICA: FADT: set acpi_gbl_use_default_register_widths to TRUE by default ACPICA: FADT parsing changes and fixes ACPICA: Add ACPI_MUTEX_TYPE configuration option ACPICA: Fixes for various ACPI data tables ACPICA: Restructure includes into public/private ACPI: remove private acpica headers from driver files ACPI: reboot.c: use new acpi_reset interface ACPICA: New: acpi_reset interface - write to reset register ACPICA: Move all public H/W interfaces to new hwxface ...
2009-01-09libata: use WARN_ON_ONCE on hot pathsTejun Heo
Convert WARN_ON() on command issue/completion paths to WARN_ON_ONCE() so that libata doesn't spam the machine even when one of those conditions triggers repeatedly. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-09Merge branch 'linus' into releaseLen Brown
2009-01-08libata: clean up the SFF code for coding styleAlan Cox
2009-01-08libata: Add 32bit PIO supportAlan Cox
This matters for some controllers and in one or two cases almost doubles PIO performance. Add a bmdma32 operations set we can inherit and activate it for some controllers Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-08[libata] ahci: Withdraw IGN_SERR_INTERNAL for SB800 SATAShane Huang
There is an issue in ATI SB600/SB700 SATA that PxSERR.E should not be set on some conditions, which will lead to many SATA ODD error messages. commit 55a61604cd1354e1783364e1c901034f2f474b7d is the workaround. Since SB800 fixed this HW issue, IGN_SERR_INTERNAL should be withdrawn for SB800. Signed-off-by: Shane Huang <shane.huang@amd.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-08pata_hpt366: reimplement mode programmingTejun Heo
Reimplement mode programming logic of pata_hpt366 such that it's identical to that of IDE hpt366 driver. The differences were... * pata_hpt366 used 0xCFFF8FFFF to mask pio modes and 0x3FFFFFFF dma modes. IDE hpt366 uses 0xC1F8FFFF for PIO, 0x303800FF for MWDMA and 0x30070000 for UDMA. * pata_hpt366 doesn't set 0x08000000 for PIO unless it's already set and always turns it on for MWDMA/UDMA. IDE hpt366 doesn't bother with the bit. It always uses what was there. * IDE hpt366 always clears 0xC0000000. pata_hpt366 doesn't. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-08[libata] pata_hpt3x3: correct _freeze() function declarationJeff Garzik
2009-01-08libata: Add special ata_pio_need_iordy() handling for Compact Flash.David Daney
According to the Compact Flash specification r4.1, PIO modes 5 and 6 do not use iordy. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-08pata_platform: __pata_platform_remove() shouldn't be in discard sectionSonic Zhang
-- UPD include/linux/compile.h `___pata_platform_remove' referenced in section `__ksymtab_gpl' of drivers/built-in.o: defined in discarded section `.devexit.text' of drivers/built-in.o make: *** [.tmp_vmlinux1] Error 1 -- __pata_platform_remove() should not be in discarded section __pata_platform_remove(struct device *dev) is invoked in both pata_platform.c and pata_of_platform.c by reomve function defined in discarded section ".devexit.text". An exported function should not be put into discarded section. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-08sata_sil24: remove unused sil24_port_multiplierGrant Grundler
AFAICT, struct sil24_port_multiplier isn't used anywhere. Remove it. Signed-off-by: Grant Grundler <grundler@google.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-08[libata] ahci: Add SATA GEN3 related messagesShane Huang
The present AHCI driver seems to support SATA GEN 3 speed, but the related messages should be modified. Signed-off-by: Shane Huang <shane.huang@amd.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-08ata_piix: save, use saved and restore IOCFGTejun Heo
Certain ACPI implementations mess up IOCFG on _STM making libata detect cable type incorrectly after a suspend/resume cycle. This patch makes ata_piix save IOCFG on attach, use the saved value for things which aren't dynamic and restore it on detach so that the next driver also gets the BIOS initialized value. This patch contains the following changes. * makes ich_pata_cable_detect() use saved_iocfg. * make piix_iocfg_bit18_quirk() take @host and use saved_iocfg. * hpriv allocation moved upwards to save iocfg before doing anything else. This fixes bz#11879. Andreas Mohr reported and diagnosed the problem. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Andreas Mohr <andi@lisas.de> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-08pata_ali: Fix and workaround for FIFO DMA bugAlan Cox
In very obscure cases this can cause problems. We need to help the hardware out a bit to avoid DMA problems on a reset. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-08pata_ali: force initialise a few bitsAlan Cox
We can't assume some of the setup here on non x86 boxes. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-08pata_hpt3x3: Workarounds for chipsetAlan Cox
Correct the DMA bit flags (UDMA and MWDMA were swapped) Add workarounds so that we clear ERR and INTR bits before issuing a DMA Add workarounds so that we stop a live DMA before touching the CTL register Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-07fastboot: Make libata initialization even more asyncArjan van de Ven
As suggested by Linus: Don't do the libata init in 2 separate steps with a global sync inbetween, but do it as one async step, with a local sync before registering the device. This cuts the boottime on my machine with 2 sata controllers down significantly, and it seems to work. Would be nice if the libata folks take a good look at this patch though.. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
2009-01-07fastboot: make the libata port scan asynchronousArjan van de Ven
This patch makes the libata port scanning asynchronous (per device). There is a synchronization point before doing the actual disk scan so that device ordering is not affected. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
2009-01-06libata: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Cc: Jeff Garzik <jgarzik@redhat.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-12-31ACPI: remove private acpica headers from driver filesLin Ming
External driver files should not include any private acpica headers. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-12-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (104 commits) [SCSI] fcoe: fix configuration problems [SCSI] cxgb3i: fix select/depend problem [SCSI] fcoe: fix incorrect use of struct module [SCSI] cxgb3i: remove use of skb->sp [SCSI] cxgb3i: Add cxgb3i iSCSI driver. [SCSI] zfcp: Remove unnecessary warning message [SCSI] zfcp: Add support for unchained FSF requests [SCSI] zfcp: Remove busid macro [SCSI] zfcp: remove DID_DID flag [SCSI] zfcp: Simplify mask lookups for incoming RSCNs [SCSI] zfcp: Remove initial device data from zfcp_data [SCSI] zfcp: fix compile warning [SCSI] zfcp: Remove adapter list [SCSI] zfcp: Simplify SBAL allocation to fix sparse warnings [SCSI] zfcp: register with SCSI layer on ccw registration [SCSI] zfcp: Fix message line break [SCSI] qla2xxx: changes in multiq code [SCSI] eata: fix the data buffer accessors conversion regression [SCSI] ibmvfc: Improve async event handling [SCSI] lpfc : correct printk types on PPC compiles ...
2008-12-29[SCSI] add residual argument to scsi_execute and scsi_execute_reqFUJITA Tomonori
scsi_execute() and scsi_execute_req() discard the residual length information. Some callers need it. This adds residual argument (optional) to scsi_execute and scsi_execute_req. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
