path: root/drivers/ata
2013-07-03Merge branch 'for-3.11' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata Pull libata updates from Tejun Heo: "Overview of changes: - The rest of maintainer email address updates. - Some core updates - more robust default behavior for port multipliers, better error reporting for SG_IO commands, and a way to better work around now ancient and probably pretty rare PATA -> SATA bridges with ATAPI devices. - sata_rcar stabilization. - Some hardware PCI ID additions and one-off low level driver updates." * 'for-3.11' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: (22 commits) AHCI: use ATA_BUSY libata-zpodd: must use ata_tf_init() ahci: AHCI-mode SATA patch for Intel Coleto Creek DeviceIDs ata_piix: IDE-mode SATA patch for Intel Coleto Creek DeviceIDs libata: cleanup SAT error translation ahci: sata: add support for exynos5440 sata libata: skip SRST for all SIMG [34]7x port-multipliers ahci: remove pmp link online check in FBS EH sata highbank: add bit-banged SGPIO driver support ahci: make ahci_transmit_led_message into a function pointer sata_rcar: fix compilation warning in sata_rcar_thaw() sata_highbank: increase retry count but shorten duration for Calxeda controller ata: use pci_get_drvdata() ipr: qc_fill_rtf() method should not store alternate status register sata_rcar: add 'base' local variable to some functions sata_rcar: correct 'sata_rcar_sht' sata_rcar: kill superfluous code in sata_rcar_bmdma_fill_sg() libata: do not limit R-Car SATA driver to shmobile ata: use platform_{get,set}_drvdata() AHCI: Make distinct names for ports in /proc/interrupts ...
2013-07-03Merge tag 'pci-v3.11-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI changes from Bjorn Helgaas: "PCI device hotplug - Add pci_alloc_dev() interface (Gu Zheng) - Add pci_bus_get()/put() for reference counting (Jiang Liu) - Fix SR-IOV reference count issues (Jiang Liu) - Remove unused acpi_pci_roots list (Jiang Liu) MSI - Conserve interrupt resources on x86 (Alexander Gordeev) AER - Force fatal severity when component has been reset (Betty Dall) - Reset link below Root Port as well as Downstream Port (Betty Dall) - Fix "Firmware first" flag setting (Bjorn Helgaas) - Don't parse HEST for non-PCIe devices (Bjorn Helgaas) ASPM - Warn when we can't disable ASPM as driver requests (Bjorn Helgaas) Miscellaneous - Add CircuitCo PCI IDs (Darren Hart) - Add AMD CZ SATA and SMBus PCI IDs (Shane Huang) - Work around Ivytown NTB BAR size issue (Jon Mason) - Detect invalid initial BAR values (Kevin Hao) - Add pcibios_release_device() (Sebastian Ott) - Fix powerpc & sparc PCI_UNKNOWN power state usage (Bjorn Helgaas)" * tag 'pci-v3.11-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (51 commits) MAINTAINERS: Add ACPI folks for ACPI-related things under drivers/pci PCI: Add CircuitCo vendor ID and subsystem ID PCI: Use pdev->pm_cap instead of pci_find_capability(..,PCI_CAP_ID_PM) PCI: Return early on allocation failures to unindent mainline code PCI: Simplify IOV implementation and fix reference count races PCI: Drop redundant setting of bus->is_added in virtfn_add_bus() unicore32/PCI: Remove redundant call of pci_bus_add_devices() m68k/PCI: Remove redundant call of pci_bus_add_devices() PCI / ACPI / PM: Use correct power state strings in messages PCI: Fix comment typo for pcie_pme_remove() PCI: Rename pci_release_bus_bridge_dev() to pci_release_host_bridge_dev() PCI: Fix refcount issue in pci_create_root_bus() error recovery path ia64/PCI: Clean up pci_scan_root_bus() usage PCI/AER: Reset link for devices below Root Port or Downstream Port ACPI / APEI: Force fatal AER severity when component has been reset PCI/AER: Remove "extern" from function declarations PCI/AER: Move AER severity defines to aer.h PCI/AER: Set dev->__aer_firmware_first only for matching devices PCI/AER: Factor out HEST device type matching PCI/AER: Don't parse HEST table for non-PCIe devices ...
2013-07-02Merge branch 'libata/for-3.10-fixes' into libata/for-3.11Tejun Heo
libata/for-3.10-fixes never got submitted during v3.10 cycle. Merge it into for-3.11 so that it can be routed together with other changes scheduled for v3.11. Three trivial conflicts in drivers/ata/sata_rcar.c. All are caused by 1b20f6a9ad ("sata_rcar: add 'base' local variable to some functions") conflicting with logic updates in for-3.10-fixes. The offending commit simply adds local variable @base on functions which dereferences sata_rcar_priv->base multiple times. The resolutions are trivial - applying s/priv->base/base/ in the conflicting logic updates. Signed-off-by: Tejun Heo <tj@kernel.org>
2013-06-28Merge branch 'pm-assorted'Rafael J. Wysocki
* pm-assorted: PM / QoS: Add pm_qos and dev_pm_qos to events-power.txt PM / QoS: Add dev_pm_qos_request tracepoints PM / QoS: Add pm_qos_request tracepoints PM / QoS: Add pm_qos_update_target/flags tracepoints PM / QoS: Update Documentation/power/pm_qos_interface.txt PM / Sleep: Print last wakeup source on failed wakeup_count write PM / QoS: correct the valid range of pm_qos_class PM / wakeup: Adjust messaging for wake events during suspend PM / Runtime: Update .runtime_idle() callback documentation PM / Runtime: Rework the "runtime idle" helper routine PM / Hibernate: print physical addresses consistently with other parts of kernel
2013-06-24AHCI: use ATA_BUSYSergei Shtylyov
ahci_hardreset() and ahci_p5wdh_hardreset() use bare numbers for the BSY bit of the ATA status register, despite it's #define'd in <linux/ata.h>. Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-06-25libata-acpi: add back ACPI based hotplug functionalityAaron Lu
Commit 30dcf76acc69 "libata: migrate ACPI code over to new bindings" mistakenly dropped the code to register hotplug notificaion handler for ATA port/devices, causing regression for people using ATA bay, as kernel bug #59871 shows. Fix this by adding back the hotplug notification handler registration code. Since this code has to be run once and notification needs to be installed on every ATA port/devices handle no matter if there is actual device attached, we can't do this in binding time for ATA device ACPI handle, as the binding only occurs when a SCSI device is created, i.e. there is device attached. So introduce the ata_acpi_hotplug_init() function to loop scan all ATA ACPI handles and if it is available, install the notificaion handler for it during ATA init time. With the ATA ACPI handle binding to SCSI device tree, it is possible now that when the SCSI hotplug work removes the SCSI device, the ACPI unbind function will find that the corresponding ACPI device has already been deleted by dock driver, causing a scaring message like: [ 128.263966] scsi 4:0:0:0: Oops, 'acpi_handle' corrupt Fix this by waiting for SCSI hotplug task finish in our notificaion handler, so that the removal of ACPI device done in ACPI unbind function triggered by the removal of SCSI device is run earlier when ACPI device is still available. [rjw: Rebased] References: https://bugzilla.kernel.org/show_bug.cgi?id=59871 Reported-bisected-and-tested-by: Dirk Griesbach <spamthis@freenet.de> Signed-off-by: Aaron Lu <aaron.lu@intel.com> Acked-by: Tejun Heo <tj@kernel.org> Cc: 3.6+ <stable@vger.kernel.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-06-24libata-zpodd: must use ata_tf_init()Sergei Shtylyov
There are some SATA controllers which have both devices 0 and 1 but this module just zeroes out taskfile and sets then ATA_TFLAG_DEVICE (not sure that's needed) which could lead to a wrong device being selected just before issuing command. Thus we should call ata_tf_init() which sets up the device register value properly, like all other users of ata_exec_internal() do... Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: stable@vger.kernel.org
2013-06-21ahci: AHCI-mode SATA patch for Intel Coleto Creek DeviceIDsSeth Heasley
This patch adds the AHCI-mode SATA DeviceIDs for the Intel Coleto Creek PCH. Signed-off-by: Seth Heasley <seth.heasley@intel.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: stable@vger.kernel.org
2013-06-21ata_piix: IDE-mode SATA patch for Intel Coleto Creek DeviceIDsSeth Heasley
This patch adds the IDE-mode SATA DeviceIDs for the Intel Coleto Creek PCH. Signed-off-by: Seth Heasley <seth.heasley@intel.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: stable@vger.kernel.org
2013-06-18libata: cleanup SAT error translationGwendal Grignou
- Remove duplicate Medium Error Entry. - Fix translations to match SAT2 translation table. - Remove warning messages when translation is not found when decoding error or status register. - Goes through status register decoding when only ABRT bit is set in error register. Tested: When a disk fails, it sets Status = 0x71 [DRDY DF ERR] , Error = 0x4 [ABRT] This patch will make the sense key HARDWARE_ERROR instead. When there is a simple command syntax error: Status = 0x51 [DRDY ERR] , Error = 0x4 [ABRT] The sense key remains ABORTED_COMMAND. tj: Some updates to the description and comments. Signed-off-by: Gwendal Grignou <gwendal@google.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-06-17ahci: sata: add support for exynos5440 sataGirish K S
This patch adds the compatible string of the exynos5440 sata controller compliant with the ahci 1.3 and sata 3.0 specification. changes in v2: changed the compatible string by adding the actual IP owners name instead of the SoC vendor name. Signed-off-by: Girish K S <ks.giri@samsung.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-06-11libata: skip SRST for all SIMG [34]7x port-multipliersTejun Heo
For some reason, a lot of port-multipliers have issues with softreset. SIMG [34]7x series port-multipliers have been quite erratic in this regard. I recall that it was better with some firmware revisions and the current list of quirks worked fine for a while. I think it got worse with later firmwares or maybe my test coverage wasn't good enough. Anyways, HPA is reporting that his 3726 setup suffers SRST failures and then the PMP gets confused and fails to probe the last port. The hope was that we try to stick to the standard as much as possible and soonish the PMPs and their firmwares will improve in quality, so the quirk list was kept to minimum. Well, it seems like that's never gonna happen. Let's set NO_SRST for all [34]7x PMPs so that whatever remaining userbase of the device suffer the least. Maybe we should do the same for 57xx's but unfortunately I don't have any device left to test and I'm not even sure 57xx's have ever been made widely available, so let's leave those alone for now. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: "H. Peter Anvin" <hpa@zytor.com> Cc: stable@vger.kernel.org
2013-06-09ahci: remove pmp link online check in FBS EHShane Huang
ata_link_online() check in ahci_error_intr() is unnecessary, it should be removed otherwise may lead to lockup with FBS enabled PMP. http://marc.info/?l=linux-ide&m=137050421603272&w=2 Reported-by: Yu Liu <liuyu.ac@gmail.com> Signed-off-by: Shane Huang <shane.huang@amd.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: stable@vger.kernel.org
2013-06-06sata highbank: add bit-banged SGPIO driver supportMark Langsdorf
Highbank supports SGPIO by bit-banging out the SGPIO signals over three GPIO pins defined in the DTB. Add support for this SGPIO functionality. Signed-off-by: Mark Langsdorf <mark.langsdorf@calxeda.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-06-06ahci: make ahci_transmit_led_message into a function pointerMark Langsdorf
Create a new ata_port_operations function pointer called transmit_led_message and give it the default value of ahci_transmit_led_message. This allows AHCI controllers with non-standard LED interfaces to use the existing em_ interface. Signed-off-by: Mark Langsdorf <mark.langsdorf@calxeda.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-06-03sata_rcar: fix compilation warning in sata_rcar_thaw()Sergei Shtylyov
When compiling the driver with gcc 4.8, it gives the following warning: drivers/ata/sata_rcar.c: In function `sata_rcar_thaw': drivers/ata/sata_rcar.c:183:2: warning: large integer implicitly truncated to unsigned type [-Woverflow] Fix the warning by explicit cast of the 'unsigned long' value to 'u32'. Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-06-03sata_highbank: increase retry count but shorten duration for Calxeda controllerMark Langsdorf
Increase the retry count for the hard reset function to 100 but shorten the time out period to 500 ms. See the comment for ahci_highbank_hardreset for the reasons why those vaulues were chosen. Signed-off-by: Mark Langsdorf <mark.langsdorf@calxeda.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: stable@vger.kernel.org
2013-06-03PM / Runtime: Rework the "runtime idle" helper routineRafael J. Wysocki
The "runtime idle" helper routine, rpm_idle(), currently ignores return values from .runtime_idle() callbacks executed by it. However, it turns out that many subsystems use pm_generic_runtime_idle() which checks the return value of the driver's callback and executes pm_runtime_suspend() for the device unless that value is not 0. If that logic is moved to rpm_idle() instead, pm_generic_runtime_idle() can be dropped and its users will not need any .runtime_idle() callbacks any more. Moreover, the PCI, SCSI, and SATA subsystems' .runtime_idle() routines, pci_pm_runtime_idle(), scsi_runtime_idle(), and ata_port_runtime_idle(), respectively, as well as a few drivers' ones may be simplified if rpm_idle() calls rpm_suspend() after 0 has been returned by the .runtime_idle() callback executed by it. To reduce overall code bloat, make the changes described above. Tested-by: Mika Westerberg <mika.westerberg@linux.intel.com> Tested-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Kevin Hilman <khilman@linaro.org> Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org> Acked-by: Alan Stern <stern@rowland.harvard.edu>
2013-06-03ahci: Add AMD CZ SATA device IDShane Huang
To add AMD CZ SATA controller device ID of IDE mode. [bhelgaas: drop pci_ids.h update] Signed-off-by: Shane Huang <shane.huang@amd.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Reviewed-by: Tejun Heo <tj@kernel.org> Cc: stable@vger.kernel.org
2013-06-03Merge branch 'for-3.10-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata Pull libata changes from Tejun Heo: "Nothing too interesting. PCI ID additions, some sata_rcar fixes and a fringe bug fix for DMADIR handling which shouldn't affect any device remotely modern." * 'for-3.10-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: sata_rcar: fix interrupt handling ahci: add an observed PCI ID for Marvell 88se9172 SATA controller sata_rcar: clear STOP bit in bmdma_start() method libata: make ata_exec_internal_sg honor DMADIR ata_piix: add PCI IDs for Intel BayTail libata: update "Maintained by:" tags
2013-06-02ata: use pci_get_drvdata()Jingoo Han
Use the wrapper function for getting the driver data using pci_dev instead of using dev_get_drvdata() with &pdev->dev, so we can directly pass a struct pci_dev. This is a purely cosmetic change. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-06-02sata_rcar: fix interrupt handlingSergei Shtylyov
The driver's interrupt handling code is too picky in deciding whether it should handle an interrupt or not which causes completely unneeded spurious interrupts. Thus make sata_rcar_{ata|serr}_interrupt() *void*; add ATA status register read to sata_rcar_ata_interrupt() to clear an unexpected ATA interrupt -- it doesn't get cleared by writing to the SATAINTSTAT register in the interrupt mode we use. Also, in sata_rcar_ata_interrupt() we should check SATAINTSTAT register only for enabled interrupts and we should clear only those interrupts that we have read as active first time around, because else we have a race and risk clearing an interrupt that can occur between read and write of the SATAINTSTAT register and never registering it... Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: stable@vger.kernel.org
2013-05-29ahci: add an observed PCI ID for Marvell 88se9172 SATA controllerGeorge Spelvin
A third possible PCI ID, as personally observed, and found in the pci.ids list. Signed-off-by: George Spelvin <linux@horizon.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-05-28sata_rcar: add 'base' local variable to some functionsSergei Shtylyov
The 'base' field of 'struct sata_rcar_priv' is used very often throughout the driver, so it seems worth loading it into a local variable if it's used more than once in a function. While at it, put some unitialized variables after intialized ones for aesthetic reasons. :-) Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-05-28sata_rcar: correct 'sata_rcar_sht'Sergei Shtylyov
Using ATA_BMDMA_SHT() to intialize 'sata_rcar_sht' was suboptimal as the R-Car descriptor table transfer counter is 28 bits wide (bit 1 to bit 28), so that the 'dma_boundary' field of 0xFFFF is just too small, as well as the 'sg_tablesize' field of 128. Use ATA_BASE_SHT() to initialize 'sata_rcar_sht' instead and give proper values to the 'dma_boundary' and 'sg_tablesize' fields explicitly. Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-05-28sata_rcar: kill superfluous code in sata_rcar_bmdma_fill_sg()Sergei Shtylyov
I've modified sata_rcar_bmdma_fill_sg() to take care of splitting long scatter/ gather segments due to the descriptor table transfer counter being only 28 bits wide (bit 1 to bit 28) but that was in vain as even if 'sata_rcar_sht' specified a correct 'dma_boundary' field, the DMA and block layers would have split the S/G segments on the necassary boundaries. Since the driver uses ATA_BMDMA_SHT() to initilaize 'sata_rcar_sht', the boundary is much smaller, only 0xFFFF, so the code I've added is even more useless, and it's better to just remove it. Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-05-24libata: do not limit R-Car SATA driver to shmobileSimon Horman
The motivation for this is to allow the driver to be used with the r8a7790 SoC. I believe that rather than adding another SoC to the list of allowed SoCs it is better to simply remove the dependency of the driver on shmobile all together. Signed-off-by: Simon Horman <horms+renesas@verge.net.au> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-05-24ata: use platform_{get,set}_drvdata()Jingoo Han
Use the wrapper functions for getting and setting the driver data using platform_device instead of using dev_{get,set}_drvdata() with &pdev->dev, so we can directly pass a struct platform_device. Also, unnecessary dev_set_drvdata() is removed, because the driver core clears the driver data to NULL after device_release or on probe failure. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-05-22AHCI: Make distinct names for ports in /proc/interruptsAlexander Gordeev
Currently all interrupts assigned to AHCI ports show up in '/proc/interrupts' as 'ahci'. This fix adds port numbers as suffixes and hence makes the descriptions distinct. Reported-by: Jan Beulich <JBeulich@suse.com> Signed-off-by: Alexander Gordeev <agordeev@redhat.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-05-22sata_rcar: clear STOP bit in bmdma_start() methodSergei Shtylyov
Iff bmdma_setup() has to stop a DMA transfer before starting a new one, then the STOP bit in the ATAPI_CONTROL1 register will remain set (it's only cleared when setting the START bit to 1) and then bmdma_start() method will set both START and STOP bits simultaneously which should abort the transfer being just started. Avoid that by explicitly clearing the STOP bit in bmdma_start() method (in this case it will be ignored on write). Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: stable@vger.kernel.org
2013-05-22libata: Add atapi_dmadir force flagVincent Pelletier
Some device require DMADIR to be enabled, but are not detected as such by atapi_id_dmadir. One such example is "Asus Serillel 2" SATA-host-to-PATA-device bridge: the bridge itself requires DMADIR, even if the bridged device does not. As atapi_dmadir module parameter can cause problems with some devices (as per Tejun Heo's memory), enabling it globally may not be possible depending on the hardware. This patch adds atapi_dmadir in the form of a "force" horkage value, allowing global, per-bus and per-device control. Signed-off-by: Vincent Pelletier <plr.vincent@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-05-22libata: make ata_exec_internal_sg honor DMADIRVincent Pelletier
libata honors DMADIR for regular commands, but not for internal commands used (among other) during device initialisation. This makes SATA-host-to-PATA-device bridges based on Silicon Image SiL3611 (such as "Abit Serillel 2") end up disabled when used with an ATAPI device after a few tries. Log output of the bridge being hot-plugged with an ATAPI drive: [ 9631.212901] ata1: exception Emask 0x10 SAct 0x0 SErr 0x40c0000 action 0xe frozen [ 9631.212913] ata1: irq_stat 0x00000040, connection status changed [ 9631.212923] ata1: SError: { CommWake 10B8B DevExch } [ 9631.212939] ata1: hard resetting link [ 9632.104962] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300) [ 9632.106393] ata1.00: ATAPI: PIONEER DVD-RW DVR-115, 1.06, max UDMA/33 [ 9632.106407] ata1.00: applying bridge limits [ 9632.108151] ata1.00: configured for UDMA/33 [ 9637.105303] ata1.00: qc timeout (cmd 0xa0) [ 9637.105324] ata1.00: failed to clear UNIT ATTENTION (err_mask=0x5) [ 9637.105335] ata1: hard resetting link [ 9638.044599] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300) [ 9638.047878] ata1.00: configured for UDMA/33 [ 9643.044933] ata1.00: qc timeout (cmd 0xa0) [ 9643.044953] ata1.00: failed to clear UNIT ATTENTION (err_mask=0x5) [ 9643.044963] ata1: limiting SATA link speed to 1.5 Gbps [ 9643.044971] ata1.00: limiting speed to UDMA/33:PIO3 [ 9643.044979] ata1: hard resetting link [ 9643.984225] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310) [ 9643.987471] ata1.00: configured for UDMA/33 [ 9648.984591] ata1.00: qc timeout (cmd 0xa0) [ 9648.984612] ata1.00: failed to clear UNIT ATTENTION (err_mask=0x5) [ 9648.984619] ata1.00: disabled [ 9649.000593] ata1: hard resetting link [ 9649.939902] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310) [ 9649.955864] ata1: EH complete With this patch, the drive enumerates correctly when libata is loaded with atapi_dmadir=1: [ 9891.810863] ata1: exception Emask 0x10 SAct 0x0 SErr 0x40c0000 action 0xe frozen [ 9891.810874] ata1: irq_stat 0x00000040, connection status changed [ 9891.810884] ata1: SError: { CommWake 10B8B DevExch } [ 9891.810900] ata1: hard resetting link [ 9892.762105] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300) [ 9892.763544] ata1.00: ATAPI: PIONEER DVD-RW DVR-115, 1.06, max UDMA/33, DMADIR [ 9892.763558] ata1.00: applying bridge limits [ 9892.765393] ata1.00: configured for UDMA/33 [ 9892.786063] ata1: EH complete [ 9892.792062] scsi 0:0:0:0: CD-ROM PIONEER DVD-RW DVR-115 1.06 PQ: 0 ANSI: 5 [ 9892.798455] sr2: scsi3-mmc drive: 12x/12x writer dvd-ram cd/rw xa/form2 cdda tray [ 9892.798837] sr 0:0:0:0: Attached scsi CD-ROM sr2 [ 9892.799109] sr 0:0:0:0: Attached scsi generic sg6 type 5 Based on a patch by Csaba Halász <csaba.halasz@gmail.com> on linux-ide: http://marc.info/?l=linux-ide&m=136121147832295&w=2 tj: minor formatting changes. Signed-off-by: Vincent Pelletier <plr.vincent@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: stable@vger.kernel.org
2013-05-16ata_piix: add PCI IDs for Intel BayTailChew, Chiau Ee
Adds IDE-mode SATA Device IDs for the Intel BayTrail platform. Signed-off-by: Chew, Chiau Ee <chiau.ee.chew@intel.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: stable@vger.kernel.org
2013-05-14libata: export ata_port port_no attribute via /sysDavid Milburn
While registering host controller track port number based upon number of ports available on the controller, export port_no attribute through /sys. This patch is needed by udev for composing persistent links in /dev/disk/by-path. /sys/devices/pci0000:00/0000:00:1f.2/ata8/ata_port/ata8 total 0 lrwxrwxrwx. 1 root root 0 Mar 6 12:43 device -> ../../../ata8 -r--r--r--. 1 root root 4096 Mar 6 12:43 idle_irq -r--r--r--. 1 root root 4096 Mar 6 12:43 nr_pmp_links -r--r--r--. 1 root root 4096 Mar 6 12:43 port_no drwxr-xr-x. 2 root root 0 Mar 6 12:42 power lrwxrwxrwx. 1 root root 0 Mar 6 12:41 subsystem -> ../../../../../../class/ata_port -rw-r--r--. 1 root root 4096 Mar 6 12:40 uevent 1 Signed-off-by: David Milburn <dmilburn@redhat.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-05-14libata: update "Maintained by:" tagsTejun Heo
Jeff moved on to a greener pasture. s/Maintained by: Jeff Garzik/Maintained by: Tejun Heo/g Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jeff Garzik <jgarzik@pobox.com>
2013-05-12drivers/ata: don't check resource with devm_ioremap_resourceWolfram Sang
devm_ioremap_resource does sanity checks on the given resource. No need to duplicate this in the driver. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2013-05-07Merge tag 'cleanup-for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC late cleanups from Arnd Bergmann: "These are cleanups and smaller changes that either depend on earlier feature branches or came in late during the development cycle. We normally try to get all cleanups early, so these are the exceptions: - A follow-up on the clocksource reworks, hopefully the last time we need to merge clocksource subsystem changes through arm-soc. A first set of patches was part of the original 3.10 arm-soc cleanup series because of interdependencies with timer drivers now moved out of arch/arm. - Migrating the SPEAr13xx platform away from using auxdata for DMA channel descriptions towards using information in device tree, based on the earlier SPEAr multiplatform series - A few follow-ups on the Atmel SAMA5 support and other changes for Atmel at91 based on the larger at91 reworks. - Moving the armada irqchip implementation to drivers/irqchip - Several OMAP cleanups following up on the larger series already merged in 3.10." * tag 'cleanup-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (50 commits) ARM: OMAP4: change the device names in usb_bind_phy ARM: OMAP2+: Fix mismerge for timer.c between ff931c82 and da4a686a ARM: SPEAr: conditionalize SMP code ARM: arch_timer: Silence debug preempt warnings ARM: OMAP: remove unused variable serial: amba-pl011: fix !CONFIG_DMA_ENGINE case ata: arasan: remove the need for platform_data ARM: at91/sama5d34ek.dts: remove not needed compatibility string ARM: at91: dts: add MCI DMA support ARM: at91: dts: add i2c dma support ARM: at91: dts: set #dma-cells to the correct value ARM: at91: suspend both memory controllers on at91sam9263 irqchip: armada-370-xp: slightly cleanup irq controller driver irqchip: armada-370-xp: move IRQ handler to avoid forward declaration irqchip: move IRQ driver for Armada 370/XP ARM: mvebu: move L2 cache initialization in init_early() devtree: add binding documentation for sp804 ARM: integrator-cp: convert use CLKSRC_OF for timer init ARM: versatile: use OF init for sp804 timer ARM: versatile: add versatile dtbs to dtbs target ...
2013-05-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS updates from Al Viro, Misc cleanups all over the place, mainly wrt /proc interfaces (switch create_proc_entry to proc_create(), get rid of the deprecated create_proc_read_entry() in favor of using proc_create_data() and seq_file etc). 7kloc removed. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits) don't bother with deferred freeing of fdtables proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h proc: Make the PROC_I() and PDE() macros internal to procfs proc: Supply a function to remove a proc entry by PDE take cgroup_open() and cpuset_open() to fs/proc/base.c ppc: Clean up scanlog ppc: Clean up rtas_flash driver somewhat hostap: proc: Use remove_proc_subtree() drm: proc: Use remove_proc_subtree() drm: proc: Use minor->index to label things, not PDE->name drm: Constify drm_proc_list[] zoran: Don't print proc_dir_entry data in debug reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show() proc: Supply an accessor for getting the data from a PDE's parent airo: Use remove_proc_subtree() rtl8192u: Don't need to save device proc dir PDE rtl8187se: Use a dir under /proc/net/r8180/ proc: Add proc_mkdir_data() proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h} proc: Move PDE_NET() to fs/proc/proc_net.c ...
2013-04-30Merge tag 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev Pull libata update from Jeff Garzik: - More ACPI fixes, cleanups - Minor cleanups for sata_highbank, pata_at32, pata_octeon_cf, sata_rcar - pata_legacy: small bug found in opti chipset code (untested fix, due to ancient h/w) - sata_fsl: RX water mark config knob, some h/w needs it - pata_imx: cleanups, DeviceTree support - SCSI<->ATA translator: properly export translator version, not device firmware version * tag 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: sata_highbank: Rename proc_name to the module name ACPI/libata: Restore libata.noacpi support [libata] acpi: make ata_ap_acpi_handle not block [libata] SCSI: really use SATL version in VPD pata_imx: add devicetree support pata_imx: use void __iomem * for regs pata_imx: cleanup error path pata_imx: Use devm_clk_get sata_rcar: Convert to devm_ioremap_resource() fsl/sata: create a sysfs entry for rx water mark libata-acpi: remove redundent code for power resource handling sata_highbank: make ahci_highbank_pm_ops static pata_octeon_cf: Use resource_size function pata_legacy: bogus clock in opti82c46x_set_piomode() pata_at32: use module_platform_driver_probe()
2013-04-30sata_highbank: Rename proc_name to the module nameRobert Richter
mkinitrd looks at /sys/class/scsi_host/host$hostnum/proc_name to find the module name of a disk driver. Current name is "highbank-ahci" but the module is "sata_highbank". Rename it to match the module name. Cc: Rob Herring <rob.herring@calxeda.com> Cc: Alexander Graf <agraf@suse.de> Cc: <stable@vger.kernel.org> v3.7.. Signed-off-by: Robert Richter <robert.richter@calxeda.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2013-04-30ACPI/libata: Restore libata.noacpi supportLv Zheng
This patch restores libata.noacpi support to libata-acpi.c. There are broken optional control methods for ATA controller devices in the real world. The libata.noacpi has been used for a long time as a workaround to deal with issues caused by the broken ASL codes. 1. The "noacpi" option is introduced by the following commit: commit 11ef697b37e3c85ce1ac21f7711babf1f5b12784 Date: Thu, 28 Sep 2006 11:29:01 -0700 Subject: libata: ACPI and _GTF support 2. The "noacpi" option is renamed to "libata_noacpi" by the following commit: commit d7d0dad62a641c156386288a747c1a2f6bb2e42d Date: Wed, 28 Mar 2007 01:57:37 -0400 Subject: [libata] Disable ACPI by default; fix namespace problems 3. Some of its logics are changed over time - becomes relying on the "acpi_handle" bound to the ATA devices since this commit: commit fafbae87db88a73b166d3bc3294d209207f27056 Date: Tue, 15 May 2007 03:28:16 +0900 Subject: libata-acpi: implement ata_acpi_associate() 4. The option is deleted by the following commit: commit 30dcf76acc695cbd2fa919e294670fe9552e16e7 Date: Mon, 25 Jun 2012 16:13:04 +0800 Subject: libata: migrate ACPI code over to new bindings But the libata.noacpi setup is still left in the kernel without codes to implement it. So the deletion introduces a regression to the Linux. This patch disables ATA_ACPI support at runtime by stopping acpi binding on the ATA devices to fix this regression. This patch is tested by booting a SATA x86-64 kernel or a PATA x86 kernel with or without "libata.noacpi=1" kernel command line argument. Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Aaron Lu <aaron.lu@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2013-04-30[libata] acpi: make ata_ap_acpi_handle not blockAaron Lu
Since commit 30dcf76acc, ata_ap_acpi_handle will always do a namespace walk, which requires acquiring an acpi namespace mutex. This made it impossible to be used when calling path has held a spinlock. For example, it can occur in the following code path for pata_acpi: ata_scsi_queuecmd (ap->lock is acquired) __ata_scsi_queuecmd ata_scsi_translate ata_qc_issue pacpi_qc_issue ata_acpi_stm ata_ap_acpi_handle acpi_get_child acpi_walk_namespace acpi_ut_acquire_mutex (acquire mutex while holding lock) This caused scheduling while atomic bug, as reported in bug #56781. Actually, ata_ap_acpi_handle doesn't have to walk the namespace every time it is called, it can simply return the bound acpi handle on the corresponding SCSI host. The reason previously it is not done this way is, ata_ap_acpi_handle is used in the binding function ata_acpi_bind_host by ata_acpi_gtm when the handle is not bound to the SCSI host yet. Since we already have the ATA port's handle in its binding function, we can simply use it instead of calling ata_ap_acpi_handle there. So introduce a new function __ata_acpi_gtm, where it will receive an acpi handle param in addition to the ATA port which is solely used for debug statement. With this change, we can make ata_ap_acpi_handle simply return the bound handle for SCSI host instead of walking the acpi namespace now. Buglink: https://bugzilla.kernel.org/show_bug.cgi?id=56781 Reported-and-tested-by: <kenzopl@o2.pl> Cc: <stable@vger.kernel.org> Signed-off-by: Aaron Lu <aaron.lu@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2013-04-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina: "Usual stuff, mostly comment fixes, typo fixes, printk fixes and small code cleanups" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (45 commits) mm: Convert print_symbol to %pSR gfs2: Convert print_symbol to %pSR m32r: Convert print_symbol to %pSR iostats.txt: add easy-to-find description for field 6 x86 cmpxchg.h: fix wrong comment treewide: Fix typo in printk and comments doc: devicetree: Fix various typos docbook: fix 8250 naming in device-drivers pata_pdc2027x: Fix compiler warning treewide: Fix typo in printks mei: Fix comments in drivers/misc/mei treewide: Fix typos in kernel messages pm44xx: Fix comment for "CONFIG_CPU_IDLE" doc: Fix typo "CONFIG_CGROUP_CGROUP_MEMCG_SWAP" mmzone: correct "pags" to "pages" in comment. kernel-parameters: remove outdated 'noresidual' parameter Remove spurious _H suffixes from ifdef comments sound: Remove stray pluses from Kconfig file radio-shark: Fix printk "CONFIG_LED_CLASS" doc: put proper reference to CONFIG_MODULE_SIG_ENFORCE ...
2013-04-29Merge tag 'char-misc-3.10-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver update from Greg Kroah-Hartman: "Here's the big char / misc driver update for 3.10-rc1 A number of various driver updates, the majority being new functionality in the MEI driver subsystem (it's now a subsystem, it started out just a single driver), extcon updates, memory updates, hyper-v updates, and a bunch of other small stuff that doesn't fit in any other tree. All of these have been in linux-next for a while" * tag 'char-misc-3.10-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (148 commits) Tools: hv: Fix a checkpatch warning tools: hv: skip iso9660 mounts in hv_vss_daemon tools: hv: use FIFREEZE/FITHAW in hv_vss_daemon tools: hv: use getmntent in hv_vss_daemon Tools: hv: Fix a checkpatch warning tools: hv: fix checks for origin of netlink message in hv_vss_daemon Tools: hv: fix warnings in hv_vss_daemon misc: mark spear13xx-pcie-gadget as broken mei: fix krealloc() misuse in in mei_cl_irq_read_msg() mei: reduce flow control only for completed messages mei: reseting -> resetting mei: fix reading large reposnes mei: revamp mei_irq_read_client_message function mei: revamp mei_amthif_irq_read_message mei: revamp hbm state machine Revert "drivers/scsi: use module_pcmcia_driver() in pcmcia drivers" Revert "scsi: pcmcia: nsp_cs: remove module init/exit function prototypes" scsi: pcmcia: nsp_cs: remove module init/exit function prototypes mei: wd: fix line over 80 characters misc: tsl2550: Use dev_pm_ops ...
2013-04-29Merge tag 'pci-v3.10-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI updates from Bjorn Helgaas: "PCI changes for the v3.10 merge window: PCI device hotplug - Remove ACPI PCI subdrivers (Jiang Liu, Myron Stowe) - Make acpiphp builtin only, not modular (Jiang Liu) - Add acpiphp mutual exclusion (Jiang Liu) Power management - Skip "PME enabled/disabled" messages when not supported (Rafael Wysocki) - Fix fallback to PCI_D0 (Rafael Wysocki) Miscellaneous - Factor quirk_io_region (Yinghai Lu) - Cache MSI capability offsets & cleanup (Gavin Shan, Bjorn Helgaas) - Clean up EISA resource initialization and logging (Bjorn Helgaas) - Fix prototype warnings (Andy Shevchenko, Bjorn Helgaas) - MIPS: Initialize of_node before scanning bus (Gabor Juhos) - Fix pcibios_get_phb_of_node() declaration "weak" annotation (Gabor Juhos) - Add MSI INTX_DISABLE quirks for AR8161/AR8162/etc (Xiong Huang) - Fix aer_inject return values (Prarit Bhargava) - Remove PME/ACPI dependency (Andrew Murray) - Use shared PCI_BUS_NUM() and PCI_DEVID() (Shuah Khan)" * tag 'pci-v3.10-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (63 commits) vfio-pci: Use cached MSI/MSI-X capabilities vfio-pci: Use PCI_MSIX_TABLE_BIR, not PCI_MSIX_FLAGS_BIRMASK PCI: Remove "extern" from function declarations PCI: Use PCI_MSIX_TABLE_BIR, not PCI_MSIX_FLAGS_BIRMASK PCI: Drop msi_mask_reg() and remove drivers/pci/msi.h PCI: Use msix_table_size() directly, drop multi_msix_capable() PCI: Drop msix_table_offset_reg() and msix_pba_offset_reg() macros PCI: Drop is_64bit_address() and is_mask_bit_support() macros PCI: Drop msi_data_reg() macro PCI: Drop msi_lower_address_reg() and msi_upper_address_reg() macros PCI: Drop msi_control_reg() macro and use PCI_MSI_FLAGS directly PCI: Use cached MSI/MSI-X offsets from dev, not from msi_desc PCI: Clean up MSI/MSI-X capability #defines PCI: Use cached MSI-X cap while enabling MSI-X PCI: Use cached MSI cap while enabling MSI interrupts PCI: Remove MSI/MSI-X cap check in pci_msi_check_device() PCI: Cache MSI/MSI-X capability offsets in struct pci_dev PCI: Use u8, not int, for PM capability offset [SCSI] megaraid_sas: Use correct #define for MSI-X capability PCI: Remove "extern" from function declarations ...
2013-04-19Merge branch 'spear/dwdma' into late/cleanupArnd Bergmann
This is a series originally prepared for inclusion in 3.9, which did not work out because of dependencies on the dmaengine driver. All the changes for the dmaengine code are merged in 3.9 now, so we can finally do the switchover and remove the now unnecessary dma definitions for spear13xx from the platform code. The dma platform_data actually made up the majority of the spear13xx platform code overall, so moving that into device tree files makes the code substantially smaller. * spear/dwdma: ata: arasan: remove the need for platform_data ARM: SPEAr13xx: Pass generic DW DMAC platform data from DT serial: pl011: use generic DMA slave configuration if possible spi: pl022: use generic DMA slave configuration if possible Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2013-04-19ata: arasan: remove the need for platform_dataArnd Bergmann
This adds a complete DT binding for the arasan device driver. There is currently only one user, which is the spear13xx platform, so we don't actually have to parse all the properties until another user comes in, but this does use the generic DMA binding to find the DMA channel. The patch is untested so far and is part of a series to convert the spear platform over to use the generic DMA binding, so it should stay with the rest of the series. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Viresh Kumar <viresh.linux@linaro.org> Cc: Vinod Koul <vinod.koul@intel.com> Cc: Jeff Garzik <jgarzik@redhat.com> Cc: devicetree-discuss@lists.ozlabs.org
2013-04-15ahci: Use PCI_VENDOR_ID_MARVELL_EXT for 0x1b4bMyron Stowe
With the 0x1b4b vendor ID #define in place, convert hard-coded ID values. Signed-off-by: Myron Stowe <myron.stowe@redhat.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Jeff Garzik <jgarzik@pobox.com>
2013-04-14Merge 3.9-rc7 into char-misc-nextGreg Kroah-Hartman
We want the fixes in there. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-12pata_pdc2027x: Fix compiler warningWang YanQing
Fix the follwing warnings: linux/drivers/ata/pata_pdc2027x.c:66: warning: 'pdc2027x_reinit_one' declared 'static' but never defined pdc2027x_reinit_one are defined only when CONFIG_PM is defined, thus making it conditional. Signed-off-by: Wang YanQing <udknight@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
