path: root/drivers/ata
2015-06-26Merge tag 'armsoc-cleanup' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Kevin Hilman: "A relatively small setup of cleanups this time around, and similar to last time the bulk of it is removal of legacy board support: - OMAP: removal of legacy (non-DT) booting for several platforms - i.MX: remove some legacy board files" * tag 'armsoc-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (36 commits) ARM: fix EFM32 build breakage caused by cpu_resume_arm ARM: 8389/1: Add cpu_resume_arm() for firmwares that resume in ARM state ARM: v7 setup function should invalidate L1 cache mach-omap2: Remove use of deprecated marco, PTR_RET in devices.c ARM: OMAP2+: Remove calls to deprecacted marco,PTR_RET in the files,fb.c and pmu.c ARM: OMAP2+: Constify irq_domain_ops ARM: OMAP2+: use symbolic defines for console loglevels instead of numbers ARM: at91: remove useless Makefile.boot ARM: at91: remove at91rm9200_sdramc.h ARM: at91: remove mach/at91_ramc.h and mach/at91rm9200_mc.h ARM: at91/pm: use the atmel-mc syscon defines pcmcia: at91_cf: Use syscon to configure the MC/smc ARM: at91: declare the at91rm9200 memory controller as a syscon mfd: syscon: Add Atmel MC (Memory Controller) registers definition ARM: at91: drop sam9_smc.c ata: at91: use syscon to configure the smc ARM: ux500: delete static resource defines ARM: ux500: rename ux500_map_io ARM: ux500: look up PRCMU resource from DT ARM: ux500: kill off L2CC static map ...
2015-06-25Merge branch 'for-4.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata Pull libata updates from Tejun Heo: - a number of libata core changes to better support NCQ TRIM. - ahci now supports MSI-X in single IRQ mode to support a new controller which doesn't implement MSI or INTX. - ahci now supports edge-triggered IRQ mode to support a new controller which for some odd reason did edge-triggered IRQ. - the usual controller support additions and changes. * 'for-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: (27 commits) libata: Do not blacklist Micron M500DC ata: ahci_mvebu: add suspend/resume support ahci, msix: Fix build error for !PCI_MSI ahci: Add support for Cavium's ThunderX host controller ahci: Add generic MSI-X support for single interrupts to SATA PCI driver libata: finally use __initconst in ata_parse_force_one() drivers: ata: add support for Ceva sata host controller devicetree:bindings: add devicetree bindings for ceva ahci ahci: added support for Freescale AHCI sata ahci: Store irq number in struct ahci_host_priv ahci: Move interrupt enablement code to a separate function Doc: libata: Fix spelling typo found in libata.xml ata:sata_nv - Change 1 to true for bool type variable. ata: add Broadcom AHCI SATA3 driver for STB chips Documentation: devicetree: add Broadcom SATA binding libata: Fix regression when the NCQ Send and Receive log page is absent ata: hpt366: fix constant cast warning ata: ahci_xgene: potential NULL dereference in probe ata: ahci_xgene: Add AHCI Support for 2nd HW version of APM X-Gene SoC AHCI SATA Host controller. libahci: Add support to handle HOST_IRQ_STAT as edge trigger latch. ...
2015-06-18libata: Do not blacklist Micron M500DCMartin K. Petersen
Queued TRIM got disabled on Micron M500DC drives thanks to the "Micron_M500*" pattern we had in place to accommodate the previous generation of this drive family. Tweak the blacklist entry slightly so we only disable queued TRIM for the non-DC variants of M500 drives. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Cc: stable@vger.kernel.org Signed-off-by: Tejun Heo <tj@kernel.org>
2015-06-17ata: ahci_mvebu: add suspend/resume supportThomas Petazzoni
This commit adds suspend/resume support to the ahci_mvebu driver. The suspend hook doesn't do anything special despite calling the generic ahci_platform_suspend_host() function. However, the resume hook has to restore the MBus windows configuration, as well as the regret option. Tested on Marvell Armada 388 GP. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-06-17ahci, msix: Fix build error for !PCI_MSIRobert Richter
It turned out the irq vector of the msix can be obtained from struct msix_entry. This makes the lookup function for msi_desc obsolete. This fixes a build error if PCI_MSI is unset: drivers/ata/ahci.c: In function ‘msix_get_desc’: drivers/ata/ahci.c:1210:2: error: ‘struct pci_dev’ has no member named ‘msi_list’ Catched by Fengguang's build bot. Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Robert Richter <rrichter@cavium.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-06-16ahci: Add support for Cavium's ThunderX host controllerRobert Richter
This patch adds support for Cavium's ThunderX host controller. The controller resides on the SoC and is a AHCI compatible SATA controller with one port, compliant with Serial ATA 3.1 and AHCI Revision 1.31. There can exists multiple SATA controllers on the SoC. The controller depends on MSI-X support since the PCI ECAM controller on the SoC does not implement MSI nor lagacy intx interrupt support. Thus, during device initialization, if MSI fails MSI-X will be used to enable the device's interrupts. The controller uses non-standard BAR0 for its register range. The already existing device lookup (vendor and device id) that is already implemented for other host controllers is used to change the PCI BAR. Signed-off-by: Robert Richter <rrichter@cavium.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-06-16ahci: Add generic MSI-X support for single interrupts to SATA PCI driverRobert Richter
This patch adds generic MSI-X support for single interrupts to the SATA PCI driver. MSI-X support is needed for host controller that only have MSI-X support implemented, but no MSI or intx. This patch only adds support for single interrupts, multiple per-port MSI-X interrupts are not yet implemented. The new implementation still initializes MSIs first. Only if that fails, the code tries to enable MSI-X. If that fails too, setup is continued with intx interrupts. To not break other chips by this generic code change, there are the following precautions: * Interrupt ranges are not enabled at all. * Only single interrupt mode is enabled for msix cap devices. Thus, only one interrupt will be setup. * During the discussion with Tejun we agreed to change the init sequence from msix-msi-intx to msi-msix-intx. Thus, if a device offers msi and init does not fail, the msix init code will not be executed. This is equivalent to current code. With this, the code only setups single mode msix as a last resort if msi fails. No interrupt range is enabled at all. Only one interrupt will be enabled. tj: comment edits. Changes of the patch series: v5: * updated patch subject that the patch only implements single IRQ * moved Cavium specific code to a separate patch * detect Cavium ThunderX device with PCI_CLASS_STORAGE_SATA_AHCI instead of vendor/dev id * added more comments to the code * enable single msix support for all kind of devices (removing strict check) * rebased onto update libata/for-4.2 with patch 1, 2 applied v4: * removed implementation of ahci_init_intx() * improved patch descriptions * rebased onto libata/for-4.2 v3: * store irq number in struct ahci_host_priv * change initialization order from msix-msi-intx to msi-msix-intx * improve comments in ahci_init_msix() * improve error message in ahci_init_msix() * do not enable MSI-X if MSI is actively disabled for the device v2: * determine irq vector from pci_dev->msi_list Based on a patch from Sunil Goutham <sgoutham@cavium.com>. Signed-off-by: Robert Richter <rrichter@cavium.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-06-10libata: finally use __initconst in ata_parse_force_one()Rasmus Villemoes
Just six days after this FIXME was added seven years ago, Sam Ravnborg added the missing feature (37c514e3dfc8 "Add missing init section definitions"), though it ended up being called __initconst. Let's use it; better late than never. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-06-10drivers: ata: add support for Ceva sata host controllerSuneel Garapati
Adds support for Ceva sata host controller on Xilinx Zynq UltraScale+ MPSoC. Signed-off-by: Suneel Garapati <suneel.garapati@xilinx.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-06-09ahci: added support for Freescale AHCI sataTang Yuantian
Freescale introduced QorIQ series SOCs, like ls1021 ls2085, with AHCI sata support. It complies with the serial ATA 3.0 specification and the AHCI 1.3 specification. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Yuantian Tang <Yuantian.Tang@freescale.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-06-08Merge branch 'for-4.1-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata Pull libata fixes from Tejun Heo: "Two driver fixes. One is for an ahci_mvebu controller config bug and the other fixes pata_octeon_cf build issue" * 'for-4.1-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: pata_octeon_cf: fix broken build ata: ahci_mvebu: Fix wrongly set base address for the MBus window setting
2015-06-08pata_octeon_cf: fix broken buildAaro Koskinen
MODULE_DEVICE_TABLE is referring to wrong driver's table and breaks the build. Fix that. Cc: stable@vger.kernel.org Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-06-03ahci: Store irq number in struct ahci_host_privRobert Richter
Currently, ahci supports only msi and intx. To also support msix the handling of the irq number need to be changed. The irq number for msix devices is taken from msi_list instead of pci_dev. Thus, the irq number of a device needs to be stored in struct ahci_host_priv now. This allows the host controller to be activated in a generic way. This change is only intended for ahci drivers. For that reason the irq number is stored in struct ahci_host_priv used only by ahci drivers. Thus, the ABI changes only for ahci_host_activate(), but existing ata drivers (about 50) are unaffected and keep unchanged. All users of ahci_host_activate() have been updated. While touching drivers/ata/libahci.c, doing a small code cleanup in ahci_port_start(). Signed-off-by: Robert Richter <rrichter@cavium.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-06-03ahci: Move interrupt enablement code to a separate functionRobert Richter
This patch refactors ahci_init_interrupts() and moves msi code to a separate function. Need the split since we add msix initialization in a later patch. The initialization for msix will be done after msi but before intx. Signed-off-by: Robert Richter <rrichter@cavium.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-05-29Doc: libata: Fix spelling typo found in libata.xmlMasanari Iida
This patch fix a spelling typo found in libata.xml. It is because libata.xml is generated from comments in source, I have to fix it in libata-core.c Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-05-26ata: ahci_mvebu: Fix wrongly set base address for the MBus window settingNadav Haklai
According to the Armada 38x datasheet, the window base address registers value is set in bits [31:4] of the register and corresponds to the transaction address bits [47:20]. Therefore, the 32bit base address value should be shifted right by 20bits and left by 4bits, resulting in 16 bit shift right. The bug as not been noticed yet because if the memory available on the platform is less than 2GB, then the base address is zero. [gregory.clement@free-electrons.com: add extra-explanation] Fixes: a3464ed2f14 (ata: ahci_mvebu: new driver for Marvell Armada 380 AHCI interfaces) Signed-off-by: Nadav Haklai <nadavh@marvell.com> Reviewed-by: Omri Itach <omrii@marvell.com> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Cc: <stable@vger.kernel.org> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-05-25ata:sata_nv - Change 1 to true for bool type variable.Shailendra Verma
The variable swncq_enabled is bool type. Hence initialize it with true instead of 1. Signed-off-by: Shailendra Verma <shailendra.capricorn@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-05-24ata: add Broadcom AHCI SATA3 driver for STB chipsBrian Norris
Pretty straightforward driver, using the nice library-ization of the generic ahci_platform driver. Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-05-21libata: Fix regression when the NCQ Send and Receive log page is absentMartin K. Petersen
Commit 5d3abf8ff67f ("libata: Fall back to unqueued READ LOG EXT if the DMA variant fails") allowed us to fall back to the unqueued READ LOG variant if the queued version failed. However, if the device did not support the page at all we would end up looping due to a merge snafu. Ensure we only take the fallback path once. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Reported-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Tested-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-05-21ata: hpt366: fix constant cast warningArnd Bergmann
gcc-5.x warns about a preexisting problem in the hpt36x pata driver: drivers/ata/pata_hpt366.c: In function 'hpt36x_init_one': drivers/ata/pata_hpt366.c:376:9: warning: assignment discards 'const' qualifier from pointer target type [-Wdiscarded-array-qualifiers] Other ata drivers have the same problem, as ata_pci_bmdma_init_one takes a non-const pointer, and they solve it by using a cast to turn that pointer into a normal non-const pointer. I also tried to change the ata core code to make host->private_data a const pointer, but that quickly got out of hand, as some other drivers expect it to be writable, so I ended up using the same hack as the others here. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-05-20ata: at91: use syscon to configure the smcAlexandre Belloni
Use syscon/regmap to configure the smc. This allows to avoid using at91sam9_smc.h and to compile the driver in a multiplatform configuration. The driver will still not probe until the proper DT bindings are added. That binding will include an atmel,smc property that is a phandle to the SMC the CF controller is connected to. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2015-05-18ata: ahci_xgene: potential NULL dereference in probeDan Carpenter
Smatch complains about this potential NULL dereference of "acpi_id". Fixes: c9802a4be661 ('ata: ahci_xgene: Add AHCI Support for 2nd HW version of APM X-Gene SoC AHCI SATA Host controller.') Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-05-11Merge branch 'for-4.1-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata Pull libata fixes from Tejun Heo: "Rather big for fixes pull. - SCC controllers never lived to see the light of the day. Both libata and ide drivers removed. - In some configurations, link power management policy changes sometimes cause delayed spurious PHY events which can develop into noticeable failures. This has been reported several times over the years. Gabriele's patches suppress PHY events for a while after LPM policy changes which should help most of these failures without causing too much problem for hotplug use cases. - A few controller specific fixes" [ Hmm. I don't think removing SSC support is really a "fix", but hey, it removes a lot of lines of code. Which I like. So ... good riddance ] * 'for-4.1-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: ahci: avoton port-disable reset-quirk ata: select DW_DMAC in case of SATA_DWC libata: Blacklist queued TRIM on all Samsung 800-series libata: Ignore spurious PHY event on LPM policy change libata: Add helper to determine when PHY events should be ignored ata: ahci_st: fixup layering violations / drvdata errors Remove celleb-only SCC PATA drivers
2015-05-11ata: ahci_xgene: Add AHCI Support for 2nd HW version of APM X-Gene SoC AHCI ↵Suman Tripathi
SATA Host controller. This patch enables full AHCI feature support for APM X-Gene SoC SATA host controller. The following errata's are removed: 1. 2a0bdff6b95 ("ahci-xgene: fix the dma state machine lockup for the IDENTIFY DEVICE PIO mode command") 2. 09c32aaa368 ("ahci_xgene: Fix the dma state machine lockup for the ATA_CMD_SMART PIO mode command") 3. 1540035da71 ("ahci_xgene: Implement the xgene_ahci_poll_reg_val to support PMP") 4. a3a84bc7c88 ("ahci_xgene: Implement the workaround to support PMP enumeration and discovery") 5. 1102407bb71 ("ahci_xgene: Fix the DMA state machine lockup for the ATA_CMD_PACKET PIO mode command") 6. 72f79f9e35b ("ahci_xgene: Removing NCQ support from the APM X-Gene SoC AHCI SATA Host Controller driver") In addition, enable PMP support for APM X-Gene SoC and enable FBS support for second generation APM X-Gene SoC. Signed-off-by: Suman Tripathi <stripathi@apm.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-05-10libahci: Add support to handle HOST_IRQ_STAT as edge trigger latch.Suman Tripathi
This patch adds the support to handle HOST_IRQ_STAT as edge trigger latch. Signed-off-by: Suman Tripathi <stripathi@apm.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-05-10libahci: Refactoring of ahci_single_irq_intr function.Suman Tripathi
This patch refactors the ahci_single_irq_intr function and also rename it to ahci_single_level_irq_intr as it handles a level triggered latch. Signed-off-by: Suman tripathi <stripathi@apm.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-05-10ahci: avoton port-disable reset-quirkDan Williams
Avoton AHCI occasionally sees drive probe timeouts at driver load time. When this happens SCR_STATUS indicates device detected, but no D2H FIS reception. Reset the internal link state machines by bouncing port-enable in the PCS register when this occurs. Cc: <stable@vger.kernel.org> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-05-05ata: select DW_DMAC in case of SATA_DWCAndy Shevchenko
Since sata_dwc_460ex.c was moved to generic DMA driver we have to ensure that user can still compile it. Fixes: 8b3444852a2b (sata_dwc_460ex: move to generic DMA driver) Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-05-05libata: Fall back to unqueued READ LOG EXT if the DMA variant failsMartin K. Petersen
Some devices advertise support for the READ/WRITE LOG DMA EXT commands but fail when we try to issue them. This can lead to queued TRIM being unintentionally disabled since the relevant feature flag is located in a general purpose log page. Fall back to unqueued READ LOG EXT if the DMA variant fails while reading a log page. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-05-05libata: Expose TRIM capability in sysfsMartin K. Petersen
Create a sysfs "trim" attribute for each ata_device that displays whether DSM TRIM is "unsupported", "unqueued", "forced_unqueued" (blacklisted) or "queued". Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-05-05libata: Allow NCQ TRIM to be enabled or disabled with a module parameterMartin K. Petersen
We have started seeing SSD firmware updates introduce support for queued TRIM. Sadly, in most cases this support is completely untested and can lead to either errors or data corruption. Add two libata force flags that can be used to either enable or disable queued TRIM support. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-05-04libata: Blacklist queued TRIM on all Samsung 800-seriesMartin K. Petersen
The queued TRIM problems appear to be generic to Samsung's firmware and not tied to a particular model. A recent update to the 840 EVO firmware introduced the same issue as we saw on 850 Pro. Blacklist queued TRIM on all 800-series drives while we work this issue with Samsung. Reported-by: Günter Waller <g.wal@web.de> Reported-by: Sven Köhler <sven.koehler@gmail.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Cc: stable@vger.kernel.org Signed-off-by: Tejun Heo <tj@kernel.org>
2015-05-02libata: samsung_cf: Constify platform_device_idKrzysztof Kozlowski
The platform_device_id is not modified by the driver and core uses it as const. Signed-off-by: Krzysztof Kozlowski <k.kozlowski.k@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-04-25libata: Ignore spurious PHY event on LPM policy changeGabriele Mazzotta
When the LPM policy is set to ATA_LPM_MAX_POWER, the device might generate a spurious PHY event that cuases errors on the link. Ignore this event if it occured within 10s after the policy change. The timeout was chosen observing that on a Dell XPS13 9333 these spurious events can occur up to roughly 6s after the policy change. Link: http://lkml.kernel.org/g/3352987.ugV1Ipy7Z5@xps13 Signed-off-by: Gabriele Mazzotta <gabriele.mzt@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: stable@vger.kernel.org
2015-04-25libata: Add helper to determine when PHY events should be ignoredGabriele Mazzotta
This is a preparation commit that will allow to add other criteria according to which PHY events should be dropped. Signed-off-by: Gabriele Mazzotta <gabriele.mzt@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: stable@vger.kernel.org
2015-04-20ata: ahci_st: fixup layering violations / drvdata errorsPeter Griffin
Brian noticed while working on another SATA driver that uses libahci_platform, an error in this driver; it tries to the the driver data for its device, while libata also thinks it can set the driver data. See: ahci_platform_init_host() -> ata_host_alloc_pinfo() -> ata_host_alloc() -> dev_set_drvdata() So instead of sticking the IP-specific platform data into drvdata, let's use the plat_data variable that is reserved for this use. Addtionally plat_data isn't set until ahci_platform_init_host() has been called further down in probe(). So re-work the st_ahci_probe_resets and st_ahci_deassert_resets functions to take ahci_host_priv *hpriv as a parameter. Signed-off-by: Peter Griffin <peter.griffin@linaro.org> Suggested-by: Brian Norris <computersforpeace@gmail.com> Cc: Srinivas Kandagatla <srinivas.kandagatla@gmail.com> Cc: Maxime Coquelin <maxime.coquelin@st.com> Cc: Patrice Chotard <patrice.chotard@st.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-04-16Merge tag 'powerpc-4.1-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux Pull powerpc updates from Michael Ellerman: - Numerous minor fixes, cleanups etc. - More EEH work from Gavin to remove its dependency on device_nodes. - Memory hotplug implemented entirely in the kernel from Nathan Fontenot. - Removal of redundant CONFIG_PPC_OF by Kevin Hao. - Rewrite of VPHN parsing logic & tests from Greg Kurz. - A fix from Nish Aravamudan to reduce memory usage by clamping nodes_possible_map. - Support for pstore on powernv from Hari Bathini. - Removal of old powerpc specific byte swap routines by David Gibson. - Fix from Vasant Hegde to prevent the flash driver telling you it was flashing your firmware when it wasn't. - Patch from Ben Herrenschmidt to add an OPAL heartbeat driver. - Fix for an oops causing get/put_cpu_var() imbalance in perf by Jan Stancek. - Some fixes for migration from Tyrel Datwyler. - A new syscall to switch the cpu endian by Michael Ellerman. - Large series from Wei Yang to implement SRIOV, reviewed and acked by Bjorn. - A fix for the OPAL sensor driver from Cédric Le Goater. - Fixes to get STRICT_MM_TYPECHECKS building again by Michael Ellerman. - Large series from Daniel Axtens to make our PCI hooks per PHB rather than per machine. - Small patch from Sam Bobroff to explicitly abort non-suspended transactions on syscalls, plus a test to exercise it. - Numerous reworks and fixes for the 24x7 PMU from Sukadev Bhattiprolu. - Small patch to enable the hard lockup detector from Anton Blanchard. - Fix from Dave Olson for missing L2 cache information on some CPUs. - Some fixes from Michael Ellerman to get Cell machines booting again. - Freescale updates from Scott: Highlights include BMan device tree nodes, an MSI erratum workaround, a couple minor performance improvements, config updates, and misc fixes/cleanup. * tag 'powerpc-4.1-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux: (196 commits) powerpc/powermac: Fix build error seen with powermac smp builds powerpc/pseries: Fix compile of memory hotplug without CONFIG_MEMORY_HOTREMOVE powerpc: Remove PPC32 code from pseries specific find_and_init_phbs() powerpc/cell: Fix iommu breakage caused by controller_ops change powerpc/eeh: Fix crash in eeh_add_device_early() on Cell powerpc/perf: Cap 64bit userspace backtraces to PERF_MAX_STACK_DEPTH powerpc/perf/hv-24x7: Fail 24x7 initcall if create_events_from_catalog() fails powerpc/pseries: Correct memory hotplug locking powerpc: Fix missing L2 cache size in /sys/devices/system/cpu powerpc: Add ppc64 hard lockup detector support oprofile: Disable oprofile NMI timer on ppc64 powerpc/perf/hv-24x7: Add missing put_cpu_var() powerpc/perf/hv-24x7: Break up single_24x7_request powerpc/perf/hv-24x7: Define update_event_count() powerpc/perf/hv-24x7: Whitespace cleanup powerpc/perf/hv-24x7: Define add_event_to_24x7_request() powerpc/perf/hv-24x7: Rename hv_24x7_event_update powerpc/perf/hv-24x7: Move debug prints to separate function powerpc/perf/hv-24x7: Drop event_24x7_request() powerpc/perf/hv-24x7: Use pr_devel() to log message ... Conflicts: tools/testing/selftests/powerpc/Makefile tools/testing/selftests/powerpc/tm/Makefile
2015-04-14Merge tag 'pm+acpi-4.1-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management and ACPI updates from Rafael Wysocki: "These are mostly fixes and cleanups all over, although there are a few items that sort of fall into the new feature category. First off, we have new callbacks for PM domains that should help us to handle some issues related to device initialization in a better way. There also is some consolidation in the unified device properties API area allowing us to use that inferface for accessing data coming from platform initialization code in addition to firmware-provided data. We have some new device/CPU IDs in a few drivers, support for new chips and a new cpufreq driver too. Specifics: - Generic PM domains support update including new PM domain callbacks to handle device initialization better (Russell King, Rafael J Wysocki, Kevin Hilman) - Unified device properties API update including a new mechanism for accessing data provided by platform initialization code (Rafael J Wysocki, Adrian Hunter) - ARM cpuidle update including ARM32/ARM64 handling consolidation (Daniel Lezcano) - intel_idle update including support for the Silvermont Core in the Baytrail SOC and for the Airmont Core in the Cherrytrail and Braswell SOCs (Len Brown, Mathias Krause) - New cpufreq driver for Hisilicon ACPU (Leo Yan) - intel_pstate update including support for the Knights Landing chip (Dasaratharaman Chandramouli, Kristen Carlson Accardi) - QorIQ cpufreq driver update (Tang Yuantian, Arnd Bergmann) - powernv cpufreq driver update (Shilpasri G Bhat) - devfreq update including Tegra support changes (Tomeu Vizoso, MyungJoo Ham, Chanwoo Choi) - powercap RAPL (Running-Average Power Limit) driver update including support for Intel Broadwell server chips (Jacob Pan, Mathias Krause) - ACPI device enumeration update related to the handling of the special PRP0001 device ID allowing DT-style 'compatible' property to be used for ACPI device identification (Rafael J Wysocki) - ACPI EC driver update including limited _DEP support (Lan Tianyu, Lv Zheng) - ACPI backlight driver update including a new mechanism to allow native backlight handling to be forced on non-Windows 8 systems and a new quirk for Lenovo Ideapad Z570 (Aaron Lu, Hans de Goede) - New Windows Vista compatibility quirk for Sony VGN-SR19XN (Chen Yu) - Assorted ACPI fixes and cleanups (Aaron Lu, Martin Kepplinger, Masanari Iida, Mika Westerberg, Nan Li, Rafael J Wysocki) - Fixes related to suspend-to-idle for the iTCO watchdog driver and the ACPI core system suspend/resume code (Rafael J Wysocki, Chen Yu) - PM tracing support for the suspend phase of system suspend/resume transitions (Zhonghui Fu) - Configurable delay for the system suspend/resume testing facility (Brian Norris) - PNP subsystem cleanups (Peter Huewe, Rafael J Wysocki)" * tag 'pm+acpi-4.1-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (74 commits) ACPI / scan: Fix NULL pointer dereference in acpi_companion_match() ACPI / scan: Rework modalias creation when "compatible" is present intel_idle: mark cpu id array as __initconst powercap / RAPL: mark rapl_ids array as __initconst powercap / RAPL: add ID for Broadwell server intel_pstate: Knights Landing support intel_pstate: remove MSR test cpufreq: fix qoriq uniprocessor build ACPI / scan: Take the PRP0001 position in the list of IDs into account ACPI / scan: Simplify acpi_match_device() ACPI / scan: Generalize of_compatible matching device property: Introduce firmware node type for platform data device property: Make it possible to use secondary firmware nodes PM / watchdog: iTCO: stop watchdog during system suspend cpufreq: hisilicon: add acpu driver ACPI / EC: Call acpi_walk_dep_device_list() after installing EC opregion handler cpufreq: powernv: Report cpu frequency throttling intel_idle: Add support for the Airmont Core in the Cherrytrail and Braswell SOCs intel_idle: Update support for Silvermont Core in Baytrail SOC PM / devfreq: tegra: Register governor on module init ...
2015-04-14Remove celleb-only SCC PATA driversDaniel Axtens
The SCC PATA interface is only used by celleb. celleb has been dropped [1], so drop the drivers. [1] http://patchwork.ozlabs.org/patch/451730/ CC: "David S. Miller" <davem@davemloft.net> CC: linux-ide@vger.kernel.org CC: Valentin Rothberg <valentinrothberg@gmail.com> CC: mpe@ellerman.id.au CC: linuxppc-dev@lists.ozlab.org Acked-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Daniel Axtens <dja@axtens.net> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-04-13Merge branch 'for-4.1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata Pull libata updates from Tejun Heo: - Hannes's patchset implements support for better error reporting introduced by the new ATA command spec. - the deperecated pci_ dma API usages have been replaced by dma_ ones. - a bunch of hardware specific updates and some cleanups. * 'for-4.1' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: ata: remove deprecated use of pci api ahci: st: st_configure_oob must be called after IP is clocked. ahci: st: Update the ahci_st DT documentation ahci: st: Update the DT example for how to obtain the PHY. sata_dwc_460ex: indent an if statement libata: Add tracepoints libata-eh: Set 'information' field for autosense libata: Implement support for sense data reporting libata: Implement NCQ autosense libata: use status bit definitions in ata_dump_status() ide,ata: Rename ATA_IDX to ATA_SENSE libata: whitespace fixes in ata_to_sense_error() libata: whitespace cleanup in ata_get_cmd_descript() libata: use READ_LOG_DMA_EXT libata: remove ATA_FLAG_LOWTAG sata_dwc_460ex: re-use hsdev->dev instead of dwc_dev sata_dwc_460ex: move to generic DMA driver sata_dwc_460ex: join messages back sata: xgene: add ACPI support for APM X-Gene SATA ports ata: sata_mv: add proper definitions for LP_PHY_CTL register values
2015-04-13Merge branch 'pnp'Rafael J. Wysocki
* pnp: PNP: Avoid leaving unregistered device objects in lists PNP: Convert pnp_lock into a mutex PNP: tty/serial/8250/8250_fintek: Use module_pnp_driver to register driver PNP: platform/x86/apple-gmux: Use module_pnp_driver to register driver PNP: net/sb1000: Use module_pnp_driver to register driver PNP: media/rc: Use module_pnp_driver to register driver PNP: ide/ide-pnp: Use module_pnp_driver to register driver PNP: ata/pata_isapnp: Use module_pnp_driver to register driver PNP: tpm/tpm_infineon: Use module_pnp_driver to register driver PNP: Add helper macro for pnp_register_driver boilerplate PNP / ACPI: Use ACPI_COMPANION_SET() during initialization
2015-04-08ata: remove deprecated use of pci apiQuentin Lambert
Replace occurences of the pci api by appropriate call to the dma api. A simplified version of the semantic patch that finds this problem is as follows: (http://coccinelle.lip6.fr) @deprecated@ idexpression id; position p; @@ ( pci_dma_supported@p ( id, ...) | pci_alloc_consistent@p ( id, ...) ) @bad1@ idexpression id; position deprecated.p; @@ ...when != &id->dev when != pci_get_drvdata ( id ) when != pci_enable_device ( id ) ( pci_dma_supported@p ( id, ...) | pci_alloc_consistent@p ( id, ...) ) @depends on !bad1@ idexpression id; expression direction; position deprecated.p; @@ ( - pci_dma_supported@p ( id, + dma_supported ( &id->dev, ... + , GFP_ATOMIC ) | - pci_alloc_consistent@p ( id, + dma_alloc_coherent ( &id->dev, ... + , GFP_ATOMIC ) ) Signed-off-by: Quentin Lambert <lambert.quentin@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-04-07Merge branch 'next-remove-ldst' of ↵Michael Ellerman
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc into next
2015-04-01ahci: st: st_configure_oob must be called after IP is clocked.Peter Griffin
Currently the ahci_st driver will hang the system on probe, as the st_configure_oob function does some register writes before the IP is clocked. This patch moves the function call to after ahci_platform_enable_resources (which enables the IP clock), and resolves the hang. Addtionally st_ahci_configure_oob should be called in the st_ahci_resume function, so we also rectify that ensuring it is also called after the IP clock has been enabled. Signed-off-by: Peter Griffin <peter.griffin@linaro.org> Acked-by: Lee Jones <lee.jones@linaro.org> Acked-by: Maxime Coquelin <maxime.coquelin@st.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-03-30sata_dwc_460ex: indent an if statementDan Carpenter
We shuffled some code around in 8b3444852a2b ('sata_dwc_460ex: move to generic DMA driver') an accidentally deleted a tab character here. It causes a Smatch warning "if statement not indented". Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-03-27libata: Blacklist queued TRIM on Samsung SSD 850 ProMartin K. Petersen
Blacklist queued TRIM on this drive for now. Reported-by: Stefan Keller <linux-list@zahlenfresser.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> CC: stable@vger.kernel.org Signed-off-by: Tejun Heo <tj@kernel.org>
2015-03-27libata: Update Crucial/Micron blacklistMartin K. Petersen
Micron has released an updated firmware (MU02) for M510/M550/MX100 drives to fix the issues with queued TRIM. Queued TRIM remains broken on M500 but is working fine on later drives such as M600 and MX200. Tweak our blacklist to reflect the above. Link: https://bugzilla.kernel.org/show_bug.cgi?id=71371 Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Cc: stable@vger.kernel.org Signed-off-by: Tejun Heo <tj@kernel.org>
2015-03-27libata: Add tracepointsHannes Reinecke
Add some tracepoints for ata_qc_issue, ata_qc_complete, and ata_eh_link_autopsy. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-03-27libata-eh: Set 'information' field for autosenseHannes Reinecke
If NCQ autosense or the sense data reporting feature is enabled the LBA of the offending command should be stored in the sense data 'information' field. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-03-27libata: Implement support for sense data reportingHannes Reinecke
ACS-4 defines a sense data reporting feature set. This patch implements support for it. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Tejun Heo <tj@kernel.org>
