path: root/drivers/ata/sata_mv.c
2008-02-20sata_mv: remove iounmap in mv_platform_remove and use devm_iomapSaeed Bishara
this will fix crash bug when doing rmmod to the driver, this is because the port_stop function get called later and it could access the device's registers. Signed-off-by: Saeed Bishara <saeed@marvell.com> Acked-by: Mark Lord <mlord@pobox.com> Acked-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-20sata_mv: use hpriv->base instead of the host->iomapSaeed Bishara
this fixes crash bug as the iomap table is not valid for integrated controllers. Signed-off-by: Saeed Bishara <saeed@marvell.com> Acked-by: Mark Lord <mlord@pobox.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-20sata_mv: Define module alias for platform deviceMartin Michlmayr
The sata_mv driver can be loaded as a platform device, as is done by various Orion (ARM) based devices. The driver needs to define a module alias for the platform driver so udev will load it automatically. Tested with Debian on a QNAP TS-209. Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Acked-by: Mark Lord <mlord@pobox.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-19libata: eliminate the home grown dma padding in favour ofJames Bottomley
that provided by the block layer ATA requires that all DMA transfers begin and end on word boundaries. Because of this, a large amount of machinery grew up in ide to adjust scatterlists on this basis. However, as of 2.5, the block layer has a dma_alignment variable which ensures both the beginning and length of a DMA transfer are aligned on the dma_alignment boundary. Although the block layer does adjust the beginning of the transfer to ensure this happens, it doesn't actually adjust the length, it merely makes sure that space is allocated for transfers beyond the declared length. The upshot of this is that scatterlists may be padded to any size between the actual length and the length adjusted to the dma_alignment safely knowing that memory is allocated in this region. Right at the moment, SCSI takes the default dma_aligment which is on a 512 byte boundary. Note that this aligment only applies to transfers coming in from user space. However, since all kernel allocations are automatically aligned on a minimum of 32 byte boundaries, it is safe to adjust them in this manner as well. tj: * Adjusting sg after padding is done in block layer. Make libata set queue alignment correctly for ATAPI devices and drop broken sg mangling from ata_sg_setup(). * Use request->raw_data_len for ATAPI transfer chunk size. * Killed qc->raw_nbytes. * Separated out killing qc->n_iter. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-15ata: fix sparse warnings in sata_mv.cHarvey Harrison
pp is never used again in this function, no need to declare a new one. drivers/ata/sata_mv.c:1545:24: warning: symbol 'pp' shadows an earlier one drivers/ata/sata_mv.c:1501:22: originally declared here drivers/ata/sata_mv.c:1553:24: warning: symbol 'pp' shadows an earlier one drivers/ata/sata_mv.c:1501:22: originally declared here Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-11sata_mv: platform driver allocs dma without createByron Bradley
When the sata_mv driver is used as a platform driver, mv_create_dma_pools() is never called so it fails when trying to alloc in mv_pool_start(). Signed-off-by: Byron Bradley <byron.bbradley@gmail.com> Acked-by: Mark Lord <mlord@pobox.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-11sata_mv: fix loop with last portYinghai Lu
commit f351b2d638c3cb0b95adde3549b7bfaf3f991dfa sata_mv: Support SoC controllers cause panic: scsi 4:0:0:0: Direct-Access ATA HITACHI HDS7225S V44O PQ: 0 ANSI: 5 sd 4:0:0:0: [sde] 488390625 512-byte hardware sectors (250056 MB) sd 4:0:0:0: [sde] Write Protect is off sd 4:0:0:0: [sde] Mode Sense: 00 3a 00 00 sd 4:0:0:0: [sde] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA sd 4:0:0:0: [sde] 488390625 512-byte hardware sectors (250056 MB) sd 4:0:0:0: [sde] Write Protect is off sd 4:0:0:0: [sde] Mode Sense: 00 3a 00 00 sd 4:0:0:0: [sde] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA sde:<1>BUG: unable to handle kernel NULL pointer dereference at 000000000000001a IP: [<ffffffff806262c7>] mv_interrupt+0x21c/0x4cc PGD 0 Oops: 0000 [1] SMP CPU 3 Modules linked in: Pid: 0, comm: swapper Not tainted 2.6.24-smp-08636-g0afc2ed-dirty #26 RIP: 0010:[<ffffffff806262c7>] [<ffffffff806262c7>] mv_interrupt+0x21c/0x4cc RSP: 0000:ffff8102050bbec8 EFLAGS: 00010297 RAX: 0000000000000008 RBX: 0000000000000000 RCX: 0000000000000003 RDX: 0000000000008000 RSI: 0000000000000286 RDI: ffff8102035180e0 RBP: 0000000000000001 R08: 0000000000000003 R09: ffff8102036613e0 R10: 0000000000000002 R11: ffffffff8061474c R12: ffff8102035bf828 R13: 0000000000000008 R14: ffff81020348ece8 R15: ffffc20002cb2000 FS: 0000000000000000(0000) GS:ffff810405025700(0000) knlGS:0000000000000000 CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b CR2: 000000000000001a CR3: 0000000000201000 CR4: 00000000000006e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process swapper (pid: 0, threadinfo ffff810405094000, task ffff8102050b28c0) Stack: 000000010000000c 0002040000220400 0000001100000002 ffff81020348eda8 0000000000000001 ffff8102035f2cc0 0000000000000000 0000000000000000 0000000000000018 0000000000000000 0000000000000000 ffffffff80269ee8 Call Trace: <IRQ> [<ffffffff80269ee8>] ? handle_IRQ_event+0x25/0x53 [<ffffffff8026b393>] ? handle_fasteoi_irq+0x90/0xc8 [<ffffffff802218e2>] ? do_IRQ+0xf1/0x15f [<ffffffff8021df24>] ? default_idle+0x0/0x55 [<ffffffff8021f361>] ? ret_from_intr+0x0/0xa <EOI> [<ffffffff8023010c>] ? lapic_next_event+0x0/0xa [<ffffffff8021df55>] ? default_idle+0x31/0x55 [<ffffffff8021df50>] ? default_idle+0x2c/0x55 [<ffffffff8021df24>] ? default_idle+0x0/0x55 [<ffffffff8021e00b>] ? cpu_idle+0x92/0xb8 Code: 41 14 85 c0 89 44 24 14 0f 84 9d 02 00 00 f7 d0 01 d6 41 89 d5 89 41 14 8b 41 14 89 34 24 e9 7e 02 00 00 49 63 c5 49 8b 5c c6 48 <f6> 43 1a 80 4c 8b a3 20 37 00 00 0f 85 62 02 00 00 31 c9 41 83 RIP [<ffffffff806262c7>] mv_interrupt+0x21c/0x4cc RSP <ffff8102050bbec8> CR2: 000000000000001a ---[ end trace 2583b5f7a5350584 ]--- Kernel panic - not syncing: Aiee, killing interrupt handler! last_port already include port0 base. this patch change use last_port directly, and move pp assignment later. Signed-off-by: Yinghai Lu <yinghai.lu@sun.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-06ata: drivers/ata/sata_mv.c needs dmapool.hAndrew Morton
mips: drivers/ata/sata_mv.c: In function `mv_port_free_dma_mem': drivers/ata/sata_mv.c:1080: error: implicit declaration of function `dma_pool_free' Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-06sata_mv: Support SoC controllersSaeed Bishara
Marvell's Orion SoC includes SATA controllers based on Marvell's PCI-to-SATA 88SX controllers. This patch extends the libATA sata_mv driver to support those controllers. [edited to use linux/ata_platform.h -jg] Signed-off-by: Saeed Bishara <saeed@marvell.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-02-01sata_mv: Remove PCI dependencySaeed Bishara
The integrated SATA controller is connected directly to the SoC's internal bus, not via PCI interface. this patch removes the dependency on the PCI interface. Signed-off-by: Saeed Bishara <saeed@marvell.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-01sata_mv ncq Comments and version bumpMark Lord
Remove some obsolete comments, and bump up the driver version number. Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-01sata_mv ncq Remove post internal cmd opMark Lord
This driver currently has no need for the .post_internal_cmd op. So get rid of it, to save unnecessary transitions between EDMA and non-EDMA modes. Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-01sata_mv ncq Enable NCQ operationMark Lord
Final changes to actually turn on NCQ in the driver for GEN_II/IIE hardware. Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-01sata_mv ncq Introduce per-tag SG tablesMark Lord
In preparation for supporting NCQ, we must allocate separate SG tables for each command tag, rather than just a single table per port as before. Gen-I hardware cannot do NCQ, though, so we still allocate just a single table for that, but populate it in all 32 slots to avoid special-cases elsewhere in hotter paths of the code. Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-01sata_mv ncq Use DMA memory pools for hardware memory tablesMark Lord
Create host-owned DMA memory pools, for use in allocating/freeing per-port command/response queues and SG tables. This gives us a way to guarantee we meet the hardware address alignment requirements, and also reduces memory that might otherwise be wasted on alignment gaps. Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-01sata_mv ncq Restrict max sectors to 8-bits on GenII NCQMark Lord
The GenII chips have only 8-bits for the sector_count field when performing NCQ. Add a dev_config method to restrict this when necessary, taking care not to override any other restriction already in place (likely none, but someday.. ?). Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-01sata_mv ncq Ignore response status LSB on NCQMark Lord
The lower 8 bits of response status are not valid for NCQ. Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-01sata_mv ncq Use hqtag instead of ioidMark Lord
Simplify tag handling by using the cid/hqtag field instead of ioid, as recommended by Marvell. Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-01sata_mv ncq Add want ncq parameter for EDMA configurationMark Lord
An extra EDMA config bit is required for NCQ operation. So set/clear it as needed, and cache current setting in port_priv. For now though, it will always be "off" (0). Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-01sata_mv ncq Fix EDMA configurationMark Lord
Simplify and fix EDMA configuration setup to match Marvell specificiations. The chip documentation gives a specific (re)init sequence, which we now follow. Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-01sata_mv ncq Rename base to port mmioMark Lord
Use naming consistent with elsewhere in this driver. This will keep things less confusing when we later add "hc_mmio" in this function. Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-01sata_mv ncq Mask transient IRQsMark Lord
The chips can handle many transient errors internally without a software IRQ. We now mask/ignore those interrupts here. This is necessary for NCQ, later on. Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-01sata_mv ncq EH fixesMark Lord
A hard reset is necessary after hotplug events. Only clear the error irq bits that were set on entry. Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-23libata: convert to chained sgTejun Heo
libata used private sg iterator to handle padding sg. Now that sg can be chained, padding can be handled using standard sg ops. Convert to chained sg. * s/qc->__sg/qc->sg/ * s/qc->pad_sgent/qc->extra_sg[]/. Because chaining consumes one sg entry. There need to be two extra sg entries. The renaming is also for future addition of other extra sg entries. * Padding setup is moved into ata_sg_setup_extra() which is organized in a way that future addition of other extra sg entries is easy. * qc->orig_n_elem is unused and removed. * qc->n_elem now contains the number of sg entries that LLDs should map. qc->mapped_n_elem is added to carry the original number of mapped sgs for unmapping. * The last sg of the original sg list is used to chain to extra sg list. The original last sg is pointed to by qc->last_sg and the content is stored in qc->saved_last_sg. It's restored during ata_sg_clean(). * All sg walking code has been updated. Unnecessary assertions and checks for conditions the core layer already guarantees are removed. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-17sata_mv: improve warnings about Highpoint RocketRAID 23xx cardsMark Lord
Improve the existing boot/load time warnings from sata_mv for Highpoint RocketRAID 23xx cards, based on new knowledge about where the BIOS likes to overwrite sectors with metadata. Harmless to us, but very useful for end users. Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-04sata_mv: Warn about HPT RocketRAID BIOS treatment of "Legacy" drivesMark Lord
The Highpoint RocketRAID boards using Marvell 7042 chips overwrite the 9th sector of attached drives at boot time, when those drives are configured as "Legacy" (the default) in the HighPoint BIOS. This kills GRUB, and probably other stuff. But it all happens *before* Linux is even loaded. So, for now we'll log a WARNING when such boards are detected, and advise users to configure BIOS "JBOD" volumes instead, which don't appear to suffer from this problem. Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-12-01sata_mv: Fix broken Marvell 7042 support.Mark Lord
sata_mv: Fix broken Marvell 7042 support. The Marvell 7042 chip is more or less the same as the 6042 internally, but sports a PCIe bus. Despite having identical SATA cores, the 7042 does differ from its PCI bus counterparts in placment and layout of certain bus related registers. This patch fixes sata_mv to distinguish between the PCI bus registers of earlier chips, and the PCIe bus registers of the 7042. Specifically, move the offsets and bit patterns for the PCI/PCIe interrupt cause/mask registers into the struct mv_host_priv, as these values differ between the 6xxx and 7xxx series chips. This fixes the driver to not access reserved PCI addresses, and prevents the lockups reported in linux-2.6.24 with 7042 boards. Also add a new PCI ID for the Highpoint 2300 7042-based board that I'm using for testing this stuff here. Tested with Marvell 6081 + 7042 chips, on x86 & x86_64. Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-01sata_mv: fix compilation error when enabling DEBUGSaeed Bishara
use sstatus instead status. Signed-off-by: Saeed Bishara <saeed@marvell.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-29[libata] Address some checkpatch-spotted issuesJeff Garzik
2007-10-23[libata] checkpatch-inspired cleanupsJeff Garzik
Tackle the relatively sane complaints of checkpatch --file. The vast majority is indentation and whitespace changes, the rest are * #include fixes * printk KERN_xxx prefix addition * BSS/initializer cleanups Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-10-18[libata] kill ata_sg_is_last()Jeff Garzik
Short term, this works around a bug introduced by early sg-chaining work. Long term, removing this function eliminates a branch from a hot path loop in each scatter/gather table build. Also, as this code demonstrates, we don't need to _track_ the end of the s/g list, as long as we mark it in some way. And doing so programatically is nice. So its a useful cleanup, regardless of its short term effects. Based conceptually on a quick patch by Jens Axboe. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-10-12libata: update ata_dev_try_classify() argumentsTejun Heo
Make ata_dev_try_classify() take a pointer to ata_device instead of ata_port/port_number combination for consistency and add @present argument. @present indicates whether the device seems present during reset. It's the result of TF access during softreset and link onlineness during hardreset. @present will be used to improve diagnostic failure handling. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata: implement and use ata_port_desc() to report port configurationTejun Heo
Currently, port configuration reporting has the following problems. * iomapped address is reported instead of raw address * report contains irrelevant fields or lacks necessary fields for non-SFF controllers. * host->irq/irq2 are there just for reporting and hacky. This patch implements and uses ata_port_desc() and ata_port_pbar_desc(). ata_port_desc() is almost identical to ata_ehi_push_desc() except that it takes @ap instead of @ehi, has no locking requirement, can only be used during host initialization and " " is used as separator instead of ", ". ata_port_pbar_desc() is a helper to ease reporting of a PCI BAR or an offsetted address into it. LLD pushes whatever description it wants using the above two functions. The accumulated description is printed on host registration after "[S/P]ATA max MAX_XFERMODE ". SFF init helpers and ata_host_activate() automatically add descriptions for addresses and irq respectively, so only LLDs which isn't standard SFF need to add custom descriptions. In many cases, such controllers need to report different things anyway. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12[libata] Remove ->port_disable() hookJeff Garzik
It was always set to ata_port_disable(). Removed the hook, and replaced the very few ap->ops->port_disable() callsites with direct calls to ata_port_disable(). Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12[libata] Remove ->irq_ack() hook, and ata_dummy_irq_on()Jeff Garzik
* ->irq_ack() is redundant to what the irq handler already performs... chk-status + irq-clear. Furthermore, it is only called in one place, when screaming-irq-debugging is enabled, so we don't want to bother with a hook just for that. * ata_dummy_irq_on() is only ever used in drivers that have no callpath reaching ->irq_on(). Remove .irq_on hook from those drivers, and the now-unused ata_dummy_irq_on() Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-link: linkify resetTejun Heo
Make reset methods and related functions deal with ata_link instead of ata_port. * ata_do_reset() * ata_eh_reset() * all prereset/reset/postreset methods and related functions This patch introduces no behavior change. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-link: linkify PHY-related functionsTejun Heo
Make the following PHY-related functions to deal with ata_link instead of ata_port. * sata_print_link_status() * sata_down_spd_limit() * ata_set_sata_spd_limit() and friends * sata_link_debounce/resume() * sata_scr_valid/read/write/write_flush() * ata_link_on/offline() This patch introduces no behavior change. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-link: introduce ata_linkTejun Heo
Introduce ata_link. It abstracts PHY and sits between ata_port and ata_device. This new level of abstraction is necessary to support SATA Port Multiplier, which basically adds a bunch of links (PHYs) to a ATA host port. Fields related to command execution, spd_limit and EH are per-link and thus moved to ata_link. This patch only defines the host link. Multiple link handling will be added later. Also, a lot of ap->link derefences are added but many of them will be removed as each part is converted to deal directly with ata_link instead of ata_port. This patch introduces no behavior change. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12[libata] sata_mv: more S/G fixesJeff Garzik
* corruption fix: we only want the lower 16 bits of length (0 == 64kb) * ditto: the upper layer sets max-phys-segments to LIBATA_MAX_PRD, so we must reset it to own hw-specific length. * delete unused mv_fill_sg() return value Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-10-09sata_mv: correct S/G table limitsJeff Garzik
The recent mv_fill_sg() rewrite, to fix a data corruption problem related to IOMMU virtual merging, forgot to account for the potentially-increased size of the scatter/gather table after its run. Additionally, the DMA boundary is reduced from 0xffffffff to 0xffff to more closely match the needs of mv_fill_sg(). Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-03libata: fix for sata_mv >64KB DMA segmentsOlof Johansson
Fix bug in sata_mv for cases where the IOMMU layer has merged SG entries to larger than 64KB. They need to be split up before being sent to the driver. Just for simplicity's sake, split up at 64K boundary instead of 64K size, since that's what the common code does anyway. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-08-31[libata] Bump driver versionsJeff Garzik
Bump the versions for drivers that were modified, but had not already had a version number bump. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-08-15sata_mv: PCI IDs for Hightpoint RocketRaid 1740/1742Alan Cox
Underneath all the HPT packaging, PCI identifiers, binary driver modules and stuff you find that ... Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-20libata: make ->scr_read/write callbacks return error codeTejun Heo
Convert ->scr_read/write callbacks to return error code to better indicate failure. This will help handling of SCR_NOTIFICATION. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-20libata: improve EH report formattingTejun Heo
Requiring LLDs to format multiple error description messages properly doesn't work too well. Help LLDs a bit by making ata_ehi_push_desc() insert ", " on each invocation. __ata_ehi_push_desc() is the raw version without the automatic separator. While at it, make ehi_desc interface proper functions instead of macros. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-20[libata] sata_mv: minor cleanupsJeff Garzik
* trim trailing whitespace * document some flags, registers, and register bits * fix locking around EDMA on/off and configuration * continue replacing "constant OP var" with "var OP constant" * use new pci_try_set_mwi() Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-20[libata] sata_mv: Micro-optimization and cleanupsJeff Garzik
* Micro-optimization in the EDMA interrupt handling code * s/EDMA_ERR_CRBQ_PAR/EDMA_ERR_CRQB_PAR/ * Document EDMA Error Interrupt Cause register bits Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-17[libata] sata_mv: use pci_try_set_mwi()Jeff Garzik
Because sometimes in life, it's ok to fail. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-12Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6: (34 commits) PCI: Only build PCI syscalls on architectures that want them PCI: limit pci_get_bus_and_slot to domain 0 PCI: hotplug: acpiphp: avoid acpiphp "cannot get bridge info" PCI hotplug failure PCI: hotplug: acpiphp: remove hot plug parameter write to PCI host bridge PCI: hotplug: acpiphp: fix slot poweroff problem on systems without _PS3 PCI: hotplug: pciehp: wait for 1 second after power off slot PCI: pci_set_power_state(): check for PM capabilities earlier PCI: cpci_hotplug: Convert to use the kthread API PCI: add pci_try_set_mwi PCI: pcie: remove SPIN_LOCK_UNLOCKED PCI: ROUND_UP macro cleanup in drivers/pci PCI: remove pci_dac_dma_... APIs PCI: pci-x-pci-express-read-control-interfaces cleanups PCI: Fix typo in include/linux/pci.h PCI: pci_ids, remove double or more empty lines PCI: pci_ids, add atheros and 3com_2 vendors PCI: pci_ids, reorder some entries PCI: i386: traps, change VENDOR to DEVICE PCI: ATM: lanai, change VENDOR to DEVICE PCI: Change all drivers to use pci_device->revision ...
2007-07-12[libata] sata_mv: Fix and clean up per-chip-generation testsJeff Garzik
Due to a mistake in test logic, Gen-IIE chips were being treated as Gen-II chips in some cases. Fix this, and in the process, clean up IS_50XX/IS_60XX tests to the more uniform IS_GEN_{I,II,IIE} tests. Signed-off-by: Jeff Garzik <jeff@garzik.org>
