None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
Cc: linux-ide@vger.kernel.org
Use the wrapper function for getting the driver data using pci_dev
instead of using dev_get_drvdata() with &pdev->dev, so we can directly
pass a struct pci_dev. This is a purely cosmetic change.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
This patch converts the drivers in drivers/ata/* to use module_pci_driver()
macro which makes the code smaller and a bit simpler.
Cc: Alan Cox <alan@linux.intel.com>
Cc: Jeff Garzik <jgarzik@pobox.com>
Cc: Mikael Pettersson <mikpe@it.uu.se>
Cc: Mark Lord <kernel@teksavvy.com>
Cc: Jeremy Higdon <jeremy@sgi.com>
Remove a lot of ' ' (double spaces) as well as ensuring use of tabs vs.
spaces is appropriate and consistent.
Signed-off-by: Dan McGee <dpmcgee@gmail.com>
This pushes timing and other values into preinitialized read-only data
sections rather than being inlined into the code. None of these
functions are called more than a handful of times, so reducing code size
makes sense.
This ports the timing values over from the old IDE driver into the new
PATA-based one. The comment was lying when it stated the old driver was
not MWDMA capable.
Boot tested on actual hardware using 'libata.force=mwdma2'.
This mirrors a very old commit (3160d5416f39da9d9, "sis5513: add
->udma_filter method for chipset_family >= ATA_133") to the old sis5513
IDE driver that prevents certain setups from working.
UDMA6 (ATA/133) is not supported on some chipsets and we need to ensure
this mode is not chosen even if a connected drive supports it. Port this
old patch forward to the new PATA driver to ensure UDMA5 is the highest
mode used if that is what is supported.
Kernel bugzilla #41582.
Reviewed-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
This is similar to the existing sis_old_port_base() method. We do this
same calculation and logic in multiple places (with one more to come in
a future patch), so extracting it into a method makes sense.
Use a single mechanism to show driver version.
Reduces text a tiny bit too.
Remove uses of static int printed_version
Add and use ata_print_version(const struct device *, const char *ver)
and ata_print_version_once.
$ size drivers/ata/built-in.*
544969 73893 116584 735446 b38d6 drivers/ata/built-in.allyesconfig.ata.o
543870 73893 116592 734355 b34ad drivers/ata/built-in.allyesconfig.print_once.o
141328 14689 4220 160237 271ed drivers/ata/built-in.defconfig.ata.o
141212 14689 4220 160121 27179 drivers/ata/built-in.defconfig.print_once.o
Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
These flags are marked as obsolete and the checks for them have been removed
by commit 294440887b32c58d220fb54b73b7a58079b78f20 (libata-sff: kill unused
ata_bus_reset()), so I think it's time to finally get rid of them...
Separate out ata_pci_bmdma_prepare_host() and ata_pci_bmdma_init_one()
from their SFF counterparts. SFF ones no longer try to initialize
BMDMA or set PCI master.
This allows parallel scan and the like to be set without having to stop
using the existing full helper functions. This patch merely adds the argument
and fixes up the callers. It doesn't undo the special cases already in the
tree or add any new parallel callers.
Signed-off-by: Alan Cox <alan@linux.intel.com>
This reverts commit f20941f334d8fdb6b598658979709b4e94cd034b.
Sergei Shtylyov notes "You call min() on uncomparables [in
mwdma_clip_to_pio()], i.e. mwdma_to_pio[] contains XFER_PIO_* and
adev->pio_mode - XFER_PIO_0 yields you a mode number. Thus the second
argument will always "win" as a minimal one"
Bartlomiej Zolnierkiewicz adds "There are more issues with the patch related
to mwdma_clip_to_pio(). The function can return values between 0 and
4 which obviously won't work well for the new code below for values
>2 (i.e. resulting in out-of-bounds array access for the common-case
of dev->pio_mode == XFER_PIO_4)."
Bartlomiej Zolnierkiewicz also notes the patch is incomplete, failing to
update MWDMA mode masks.
Call sis_fixup() on resume.
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Bartlomiej pointed out that while this got fixed in the old driver whoever
did it didn't port it across.
No functional changes in this patch.
Signed-off-by: Erik Inge Bolsø <knan-lkml@anduin.net>
Signed-off-by: Qinghuang Feng <qhfeng.kernel@gmail.com>
Some systems report SIS 5513 as both vendor/id and subvendor/id
string. In that case we can't distinguish the system by the id
svid/sdid and in fact the entry here breaks some boxes. At some
point we need to find another way to detect the Targa Visionary 1000,
until then this trades a hang for some users with lower performance
for others.
Closes: #12092
Signed-off-by: Alan Cox <alan@redhat.com>
This enables short 40-wire detection for my laptop thus
enabling UDMA/100.
SFF functions have confusing names. Some have sff prefix, some have
bmdma, some std, some pci and some none. Unify the naming by...
* SFF functions which are common to both BMDMA and non-BMDMA are
prefixed with ata_sff_.
* SFF functions which are specific to BMDMA are prefixed with
ata_bmdma_.
* SFF functions which are specific to PCI but apply to both BMDMA and
non-BMDMA are prefixed with ata_pci_sff_.
* SFF functions which are specific to PCI and BMDMA are prefixed with
ata_pci_bmdma_.
* Drop generic prefixes from LLD specific routines. For example,
bfin_std_dev_select -> bfin_dev_select.
The following renames are noteworthy.
ata_qc_issue_prot() -> ata_sff_qc_issue()
ata_pci_default_filter() -> ata_bmdma_mode_filter()
ata_dev_try_classify() -> ata_sff_dev_classify()
This rename is in preparation of separating SFF support out of libata
core layer. This patch strictly renames functions and doesn't
introduce any behavior difference.
Signed-off-by: Tejun Heo <htejun@gmail.com>
Currently reset methods are not specified directly in the
ata_port_operations table. If a LLD wants to use custom reset
methods, it should construct and use a error_handler which uses those
reset methods. It's done this way for two reasons.
First, the ops table already contained too many methods and adding
four more of them would noticeably increase the amount of necessary
boilerplate code all over low level drivers.
Second, as ->error_handler uses those reset methods, it can get
confusing. ie. By overriding ->error_handler, those reset ops can be
made useless making layering a bit hazy.
Now that ops table uses inheritance, the first problem doesn't exist
anymore. The second isn't completely solved but is relieved by
providing default values - most drivers can just override what it has
implemented and don't have to concern itself about higher level
callbacks. In fact, there currently is no driver which actually
modifies error handling behavior. Drivers which override
->error_handler just wraps the standard error handler only to prepare
the controller for EH. I don't think making ops layering strict has
any noticeable benefit.
This patch makes ->prereset, ->softreset, ->hardreset, ->postreset and
their PMP counterparts propoer ops. Default ops are provided in the
base ops tables and drivers are converted to override individual reset
methods instead of creating custom error_handler.
* ata_std_error_handler() doesn't use sata_std_hardreset() if SCRs
aren't accessible. sata_promise doesn't need to use separate
error_handlers for PATA and SATA anymore.
* softreset is broken for sata_inic162x and sata_sx4. As libata now
always prefers hardreset, this doesn't really matter but the ops are
forced to NULL using ATA_OP_NULL for documentation purpose.
* pata_hpt374 needs to use different prereset for the first and second
PCI functions. This used to be done by branching from
hpt374_error_handler(). The proper way to do this is to use
separate ops and port_info tables for each function. Converted.
port_info->private_data is currently used for two purposes - to record
private data about the port_info or to specify host->private_data to
use when allocating ata_host.
This overloading is confusing and counter-intuitive in that
port_info->private_data becomes host->private_data instead of
port->private_data. In addition, port_info and host don't correspond
to each other 1-to-1. Currently, the first non-NULL
port_info->private_data is used.
This patch makes port_info->private_data just be what it is -
private_data for the port_info where LLD can jot down extra info.
libata no longer sets host->private_data to the first non-NULL
port_info->private_data, @host_priv argument is added to
ata_pci_init_one() instead. LLDs which use ata_pci_init_one() can use
this argument to pass in pointer to host private data. LLDs which
don't should use init-register model anyway and can initialize
host->private_data directly.
Adding @host_priv instead of using init-register model for LLDs which
use ata_pci_init_one() is suggested by Alan Cox.
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
ata_pci_init_one() is the only function which uses ops->irq_handler
and pi->sht. Other initialization functions take the same information
as arguments. This causes confusion and duplicate unused entries in
structures.
Make ata_pci_init_one() take sht as an argument and use ata_interrupt
implicitly. All current users use ata_interrupt and if different irq
handler is necessary open coding ata_pci_init_one() using
ata_prepare_sff_host() and ata_activate_sff_host can be done under ten
lines including error handling and driver which requires custom
interrupt handler is likely to require custom initialization anyway.
As ata_pci_init_one() was the last user of ops->irq_handler, this
patch also kills the field.
libata lets low level drivers build ata_port_operations table and
register it with libata core layer. This allows low level drivers
high level of flexibility but also burdens them with lots of
boilerplate entries.
This becomes worse for drivers which support related similar
controllers which differ slightly. They share most of the operations
except for a few. However, the driver still needs to list all
operations for each variant. This results in large number of
duplicate entries, which is not only inefficient but also error-prone
as it becomes very difficult to tell what the actual differences are.
This duplicate boilerplates all over the low level drivers also make
updating the core layer exteremely difficult and error-prone. When
compounded with multi-branched development model, it ends up
accumulating inconsistencies over time. Some of those inconsistencies
cause immediate problems and fixed. Others just remain there dormant
making maintenance increasingly difficult.
To rectify the problem, this patch implements ata_port_operations
inheritance. To allow LLDs to easily re-use their own ops tables
overriding only specific methods, this patch implements poor man's
class inheritance. An ops table has ->inherits field which can be set
to any ops table as long as it doesn't create a loop. When the host
is started, the inheritance chain is followed and any operation which
isn't specified is taken from the nearest ancestor which has it
specified. This operation is called finalization and done only once
per an ops table and the LLD doesn't have to do anything special about
it other than making the ops table non-const such that libata can
update it.
libata provides four base ops tables lower drivers can inherit from -
base, sata, pmp, sff and bmdma. To avoid overriding these ops
accidentaly, these ops are declared const and LLDs should always
inherit these instead of using them directly.
After finalization, all the ops table are identical before and after
the patch except for setting .irq_handler to ata_interrupt in drivers
which didn't use to. The .irq_handler doesn't have any actual effect
and the field will soon be removed by later patch.
* sata_sx4 is still using old style EH and currently doesn't take
advantage of ops inheritance.
libata lets low level drivers build scsi_host_template and register it
to the SCSI layer. This allows low level drivers high level of
flexibility but also burdens them with lots of boilerplate entries.
This patch implements SHT initializers which can be used to initialize
all the boilerplate entries in a sht. Three variants of them are
implemented - BASE, BMDMA and NCQ - for different types of drivers.
Note that entries can be overriden by putting individual initializers
after the helper macro.
All sht tables are identical before and after this patch.
PCI device should be powered up or powered up before its PCI regsiters
are accessed. Although PCI configuration register access is allowed
in D3hot, PCI device is free to reset its status when transiting from
D3hot to D0 causing configuration data to change.
Many libata SFF drivers which use ata_pci_init_one() read and update
configuration registers before calling ata_pci_init_one() which
enables the PCI device. Also, in resume paths, some drivers access
registers without resuming the PCI device.
This patch adds a call to pcim_enable_device() in init path if
register is accessed before calling ata_pci_init_one() and make resume
paths first resume PCI devices, access PCI configuration regiters then
resume ATA host.
While at it...
* cmd640 was strange in that it set ->resume even when CONFIG_PM is
not. This is by-product of minimal build fix. Updated.
* In cs5530, Don't BUG() on reinit failure. Just whine and fail
resume.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
With newer kernels HDD in my old laptop is limited to UDMA 33.
With this patch I get UDMA 100 again.
Signed-off-by: Gabriel Craciunescu <nix.or.die@googlemail.com>
This avoids allocating DMA buffers if not needed but at the moment is
mostly just a neatness item.
Signed-off-by: Jeff Garzik <jeff@garzik.org>
It was always set to ata_port_disable(). Removed the hook, and replaced
the very few ap->ops->port_disable() callsites with direct calls to
ata_port_disable().
* ->irq_ack() is redundant to what the irq handler already
performs... chk-status + irq-clear. Furthermore, it is only
called in one place, when screaming-irq-debugging is enabled,
so we don't want to bother with a hook just for that.
* ata_dummy_irq_on() is only ever used in drivers that have
no callpath reaching ->irq_on(). Remove .irq_on hook from
those drivers, and the now-unused ata_dummy_irq_on()
Make reset methods and related functions deal with ata_link instead of
ata_port.
* ata_do_reset()
* ata_eh_reset()
* all prereset/reset/postreset methods and related functions
This patch introduces no behavior change.
Introduce ata_link. It abstracts PHY and sits between ata_port and
ata_device. This new level of abstraction is necessary to support
SATA Port Multiplier, which basically adds a bunch of links (PHYs) to
a ATA host port. Fields related to command execution, spd_limit and
EH are per-link and thus moved to ata_link.
This patch only defines the host link. Multiple link handling will be
added later. Also, a lot of ap->link derefences are added but many of
them will be removed as each part is converted to deal directly with
ata_link instead of ata_port.
Cc: James Bottomley <James.Bottomley@SteelEye.com>
sis_66_set_dmamode() also handles early UDMA100 (SIS630 ET) but is
missing udma timing value for UDMA100. According to sis5513, this
should be 0x8000. This caused UDMA100 device to fail on pata_sis till
it downgrades to UDMA66 while it works fine on sis5513 at UDMA100.
Reported by Adam Blech.
Cc: Adam Blech <desaster.area@addcom.de>
More short cables
* Fix MWDMA timings setup in sis_old_set_dmamode() and sis_66_set_dmamode().
The old timings were overclocked (even worse behavior than sis5513 IDE driver
which depends on BIOS to program correct timings), the new timings are taken
from the datasheet (they match timings from ATA spec).
* Fix UDMA timings setup in sis_old_set_dmamode().
Misplaced pci_write_config_word() call resulted in UDMA timings never
being set.
* Fix comments for sis_133_early_set_dmamode() and sis_133_set_dmamode():
- only the former function handles early SiS 961 bridges
- both functions lack MWDMA timings setup
* Fix typos in sis_100_set_piomode() and sis_133_set_piomode() comments.
* Bump driver version.
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6: (34 commits)
PCI: Only build PCI syscalls on architectures that want them
PCI: limit pci_get_bus_and_slot to domain 0
PCI: hotplug: acpiphp: avoid acpiphp "cannot get bridge info" PCI hotplug failure
PCI: hotplug: acpiphp: remove hot plug parameter write to PCI host bridge
PCI: hotplug: acpiphp: fix slot poweroff problem on systems without _PS3
PCI: hotplug: pciehp: wait for 1 second after power off slot
PCI: pci_set_power_state(): check for PM capabilities earlier
PCI: cpci_hotplug: Convert to use the kthread API
PCI: add pci_try_set_mwi
PCI: pcie: remove SPIN_LOCK_UNLOCKED
PCI: ROUND_UP macro cleanup in drivers/pci
PCI: remove pci_dac_dma_... APIs
PCI: pci-x-pci-express-read-control-interfaces cleanups
PCI: Fix typo in include/linux/pci.h
PCI: pci_ids, remove double or more empty lines
PCI: pci_ids, add atheros and 3com_2 vendors
PCI: pci_ids, reorder some entries
PCI: i386: traps, change VENDOR to DEVICE
PCI: ATM: lanai, change VENDOR to DEVICE
PCI: Change all drivers to use pci_device->revision
Instead of all drivers reading pci config space to get the revision
ID, they can now use the pci_device->revision member.
This exposes some issues where drivers where reading a word or a dword
for the revision number, and adding useless error-handling around the
read. Some drivers even just read it for no purpose of all.
In devices where the revision ID is being copied over and used in what
appears to be the equivalent of hotpath, I have left the copy code
and the cached copy as not to influence the driver's performance.
Compile tested with make all{yes,mod}config on x86_64 and i386.
Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com>
Acked-by: Dave Jones <davej@redhat.com>
If you are using a SiS controller and the BIOS didn't set it up then the
FIFO may be left active when we try and set up the CD. Not convinced this
matters but I'd prefer to be safe
This flag only has meaning in old-EH drivers, and these drivers have
already been converted to the new EH. Remove.
Changed PATA handler for PATA-ports used by sata_sis.
This patch was originally submitted by Jeff Garzik.
Added PCI-ID 1180 for SiS966 Controller in pata_sis.
The 1180 mode is fully compatible to other SiS PATA-controller.
The PCI-ID 1183 is SATA in PATA-emulation, but not fully compatible
to SiS5513/5518. sata_sis.c is forwarding this ID to pata_sis.
1183 is not working if simply added to pata_sis.
This handling fixes issues with SiS968.
Signed-off-by: Uwe Koziolek <uwe.koziolek@gmx.net>
- Rename sis_port_base to sis_old_port_base() so nobody uses it for new
generation controllers in error.
- Use byte size operations where it is cleaner for mode setup
- Fix a couple of masking errors on certai chip revs when setting speeds
The intention of using port_mask in SFF init helpers was to eventually
support exoctic configurations such as combination of legacy and
native port on the same controller. This never became actually
necessary and the related code always has been subtly broken one way
or the other. Now that new init model is in place, there is no reason
to make common helpers capable of handling all corner cases. Exotic
cases can simply dealt within LLDs as necessary.
This patch removes port_mask handling in SFF init helpers. SFF init
helpers don't take n_ports argument and interpret it into port_mask
anymore. All information is carried via port_info. n_ports argument
is dropped and always two ports are allocated. LLD can tell SFF to
skip certain port by marking it dummy. Note that SFF code has been
treating unuvailable ports this way for a long time until recent
breakage fix from Linus and is consistent with how other drivers
handle with unavailable ports.
This fixes 1-port legacy host handling still broken after the recent
native mode fix and simplifies SFF init logic. The following changes
are made...
* ata_pci_init_native_host() and ata_init_legacy_host() both now try
to initialized whatever they can and mark failed ports dummy. They
return 0 if any port is successfully initialized.
* ata_pci_prepare_native_host() and ata_pci_init_one() now doesn't
take n_ports argument. All info should be specified via port_info
array. Always two ports are allocated.
* ata_pci_init_bmdma() exported to be used by LLDs in exotic cases.
* port_info handling in all LLDs are standardized - all port_info
arrays are const stack variable named ppi. Unless the second port
is different from the first, its port_info is specified as NULL
(tells libata that it's identical to the last non-NULL port_info).
* pata_hpt37x/hpt3x2n: don't modify static variable directly. Make an
on-stack copy instead as ata_piix does.
* pata_uli: It has 4 ports instead of 2. Don't use
ata_pci_prepare_native_host(). Allocate the host explicitly and use
init helpers. It's simple enough.
Reimplement suspend/resume support using sdev->manage_start_stop.
* Device suspend/resume is now SCSI layer's responsibility and the
code is simplified a lot.
* DPM is dropped. This also simplifies code a lot. Suspend/resume
status is port-wide now.
* ata_scsi_device_suspend/resume() and ata_dev_ready() removed.
* Resume now has to wait for disk to spin up before proceeding. I
couldn't find easy way out as libata is in EH waiting for the
disk to be ready and sd is waiting for EH to complete to issue
START_STOP.
* sdev->manage_start_stop is set to 1 in ata_scsi_slave_config().
This fixes spindown on shutdown and suspend-to-disk.
Add @deadline to prereset and reset methods and make them honor it.
ata_wait_ready() which directly takes @deadline is implemented to be
used as the wait function. This patch is in preparation for EH timing
improvements.
* ata_wait_ready() never does busy sleep. It's only used from EH and
no wait in EH is that urgent. This function also prints 'be
patient' message automatically after 5 secs of waiting if more than
3 secs is remaining till deadline.
* ata_bus_post_reset() now fails with error code if any of its wait
fails. This is important because earlier reset tries will have
shorter timeout than the spec requires. If a device fails to
respond before the short timeout, reset should be retried with
longer timeout rather than silently ignoring the device.
There are three behavior differences.
1. Timeout is applied to both devices at once, not separately. This
is more consistent with what the spec says.
2. When a device passes devchk but fails to become ready before
deadline. Previouly, post_reset would just succeed and let
device classification remove the device. New code fails the
reset thus causing reset retry. After a few times, EH will give
up disabling the port.
3. When slave device passes devchk but fails to become accessible
(TF-wise) after reset. Original code disables dev1 after 30s
timeout and continues as if the device doesn't exist, while the
patched code fails reset. When this happens, new code fails
reset on whole port rather than proceeding with only the primary
device.
If the failing device is suffering transient problems, new code
retries reset which is a better behavior. If the failing device is
actually broken, the net effect is identical to it, but not to the
other device sharing the channel. In the previous code, reset would
have succeeded after 30s thus detecting the working one. In the new
code, reset fails and whole port gets disabled. IMO, it's a
pathological case anyway (broken device sharing bus with working
one) and doesn't really matter.
* ata_bus_softreset() is changed to return error code from
ata_bus_post_reset(). It used to return 0 unconditionally.
* Spin up waiting is to be removed and not converted to honor
deadline.
* To be on the safe side, deadline is set to 40s for the time being.
This changeset revolves around the fact that all the SiS controllers have
the same enable bits, but differing cable detection methods. Previously
that meant each type had its own error_handler methods. Instead we can
now implement different ->cable_detect methods and share a single
error_handler which does the filtering by enable bits.
In addition we had some auto const arrays that should be static const. I'm
not sure if gcc already treats them intelligently but adding the static
will make sure.
A small number of SiS setups require special handling (not many judging
by how long this dumb bug survived). A couple of Fedora 7 devel testers
hit an Oops on pata_sis loading which is caused by terminal confusion
between chipset as 'the chipset we have found' and chipset as 'array
iterator'
