This patch converts the drivers in drivers/ata/* to use module_pci_driver()
macro which makes the code smaller and a bit simpler.
Cc: Alan Cox <alan@linux.intel.com>
Cc: Jeff Garzik <jgarzik@pobox.com>
Cc: Mikael Pettersson <mikpe@it.uu.se>
Cc: Mark Lord <kernel@teksavvy.com>
Cc: Jeremy Higdon <jeremy@sgi.com>
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
This is similar change as commit 60c3be3 ("ata_piix: parallel scanning
on PATA needs an extra locking") for ata_piix host driver.
Use a single mechanism to show driver version.
Reduces text a tiny bit too.
Remove uses of static int printed_version
Add and use ata_print_version(const struct device *, const char *ver)
and ata_print_version_once.
$ size drivers/ata/built-in.*
544969 73893 116584 735446 b38d6 drivers/ata/built-in.allyesconfig.ata.o
543870 73893 116592 734355 b34ad drivers/ata/built-in.allyesconfig.print_once.o
141328 14689 4220 160237 271ed drivers/ata/built-in.defconfig.ata.o
141212 14689 4220 160121 27179 drivers/ata/built-in.defconfig.print_once.o
Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
Separate out ata_pci_bmdma_prepare_host() and ata_pci_bmdma_init_one()
from their SFF counterparts. SFF ones no longer try to initialize
BMDMA or set PCI master.
Separate out BMDMA irq handler from SFF irq handler. The misnamed
host_intr() functions are renamed to ata_sff_port_intr() and
ata_bmdma_port_intr(). Common parts are factored into
__ata_sff_port_intr() and __ata_sff_interrupt() and used by sff and
bmdma interrupt routines.
All BMDMA drivers now use ata_bmdma_interrupt() or
ata_bmdma_port_intr() while all non-BMDMA SFF ones use
ata_sff_interrupt() or ata_sff_port_intr().
For now, ata_pci_sff_init_one() uses ata_bmdma_interrupt() as it's
used by both SFF and BMDMA drivers.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
MWDMA0 timings cannot be met with the PIIX based controller
programming interface.
Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com>
Signed-off-by: Alan Cox <alan@linux.intel.com>
