path: root/drivers/ata/pata_mpc52xx.c
2007-03-02libata: add missing PM callbacksTejun Heo
Some LLDs were missing scsi device PM callbacks while having host/port suspend support. Add missing ones. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-13[POWERPC] Fixup mp5200 drivers to match device tree changesGrant Likely
Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-09libata: add another IRQ calls (libata drivers)Akira Iguchi
This patch is against each libata driver. Two IRQ calls are added in ata_port_operations. - irq_on() is used to enable interrupts. - irq_ack() is used to acknowledge a device interrupt. In most drivers, ata_irq_on() and ata_irq_ack() are used for irq_on and irq_ack respectively. In some drivers (ex: ahci, sata_sil24) which cannot use them as is, ata_dummy_irq_on() and ata_dummy_irq_ack() are used. Signed-off-by: Kou Ishizaki <kou.ishizaki@toshiba.co.jp> Signed-off-by: Akira Iguchi <akira2.iguchi@toshiba.co.jp> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09libata: convert to iomapTejun Heo
Convert libata core layer and LLDs to use iomap. * managed iomap is used. Pointer to pcim_iomap_table() is cached at host->iomap and used through out LLDs. This basically replaces host->mmio_base. * if possible, pcim_iomap_regions() is used Most iomap operation conversions are taken from Jeff Garzik <jgarzik@pobox.com>'s iomap branch. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09libata: update libata LLDs to use devresTejun Heo
Update libata LLDs to use devres. Core layer is already converted to support managed LLDs. This patch simplifies initialization and fixes many resource related bugs in init failure and detach path. For example, all converted drivers now handle ata_device_add() failure gracefully without excessive resource rollback code. As most resources are released automatically on driver detach, many drivers don't need or can do with much simpler ->{port|host}_stop(). In general, stop callbacks are need iff port or host needs to be given commands to shut it down. Note that freezing is enough in many cases and ports are automatically frozen before being detached. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09[PATCH] libata: Add support for the MPC52xx ATA controllerSylvain Munaut
This patch adds initial libata support for the Freescale MPC5200 integrated IDE controller. Signed-off-by: Sylvain Munaut <tnt@246tNt.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
