path: root/drivers/ata/pata_hpt366.c
2015-05-21ata: hpt366: fix constant cast warningArnd Bergmann
gcc-5.x warns about a preexisting problem in the hpt36x pata driver: drivers/ata/pata_hpt366.c: In function 'hpt36x_init_one': drivers/ata/pata_hpt366.c:376:9: warning: assignment discards 'const' qualifier from pointer target type [-Wdiscarded-array-qualifiers] Other ata drivers have the same problem, as ata_pci_bmdma_init_one takes a non-const pointer, and they solve it by using a cast to turn that pointer into a normal non-const pointer. I also tried to change the ata core code to make host->private_data a const pointer, but that quickly got out of hand, as some other drivers expect it to be writable, so I ended up using the same hack as the others here. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-05-09ata: use CONFIG_PM_SLEEP instead of CONFIG_PM where applicable in host driversBartlomiej Zolnierkiewicz
This patch fixes host drivers to use CONFIG_PM_SLEEP instead of CONFIG_PM where applicable. Benefits of this change: * unused code is not being compiled in for CONFIG_PM=y, CONFIG_PM_SLEEP=n and CONFIG_PM_RUNTIME=y configurations * easier transition to use struct dev_pm_ops and SIMPLE_DEV_PM_OPS() in the future * more consistent code (there are host drivers which are using the correct CONFIG_PM_SLEEP checks already) The patch leaves the core libata code and ->port_[suspend,resume] support in sata_[inic162x,nv,sil24].c alone for now. Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-02-13ata: delete non-required instances of include <linux/init.h>Paul Gortmaker
None of these files are actually using any __init type directives and hence don't need to include <linux/init.h>. Most are just a left over from __devinit and __cpuinit removal, or simply due to code getting copied from one driver to the next. Cc: linux-ide@vger.kernel.org Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-06-02ata: use pci_get_drvdata()Jingoo Han
Use the wrapper function for getting the driver data using pci_dev instead of using dev_get_drvdata() with &pdev->dev, so we can directly pass a struct pci_dev. This is a purely cosmetic change. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2012-07-25ata: use module_pci_driverAxel Lin
This patch converts the drivers in drivers/ata/* to use module_pci_driver() macro which makes the code smaller and a bit simpler. Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: Alan Cox <alan@linux.intel.com> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Mikael Pettersson <mikpe@it.uu.se> Cc: Mark Lord <kernel@teksavvy.com> Cc: Jeremy Higdon <jeremy@sgi.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2011-10-14pata_hpt366: add hpt36x_find_mode() helperBartlomiej Zolnierkiewicz
Factor out code for finding the register programming information from hpt366_set_mode() to hpt36x_find_mode(). This makes pata_hpt366 driver more similar to pata_{37x,3x2n} ones. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2011-03-14ata: pata: Convert pr_*(DRV_NAME ...) to pr_fmt/pr_<level>Joe Perches
Commit 40d69ba029c8d5de51aaeb5358999266c482d00a ("pata_hpt{37x|3x2n}: use pr_*(DRV_NAME ...) instead of printk(KERN_* ...)") used pr_<level>. Add #define pr_fmt and remove DRV_NAME. Increment driver version numbers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-01-28pata_hpt{366|37x}: use pr_warning(...) instead of printk(KERN_WARNING ...)Sergei Shtylyov
... in hpt_dma_blacklisted(). Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2011-01-07pata_hpt366: coding style cleanupSergei Shtylyov
Fix 2 errors and 11 warnings given by checkpatch.pl: - *switch* and *case* not on the same indentation level; - no space between *switch* and open parenthesis; - drive blacklist arrays not being *const*; - spaces before tabs; - lines over 80 characters. In addition to these changes, also add new line after variable definition in hpt36x_init_chipset()... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-25libata-sff: separate out BMDMA initTejun Heo
Separate out ata_pci_bmdma_prepare_host() and ata_pci_bmdma_init_one() from their SFF counterparts. SFF ones no longer try to initialize BMDMA or set PCI master. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-19libata-sff: clean up BMDMA initializationTejun Heo
When BMDMA initialization failed or BMDMA was not available for whatever reason, bmdma_addr was left at zero and used as an indication that BMDMA shouldn't be used. This leads to the following problems. p1. For BMDMA drivers which don't use traditional BMDMA register, ata_bmdma_mode_filter() incorrectly inhibits DMA modes. Those drivers either have to inherit from ata_sff_port_ops or clear ->mode_filter explicitly. p2. non-BMDMA drivers call into BMDMA PRD table allocation. It doesn't actually allocate PRD table if bmdma_addr is not initialized but is still confusing. p3. For BMDMA drivers which don't use traditional BMDMA register, some methods might not be invoked as expected (e.g. bmdma_stop from ata_sff_post_internal_cmd()). p4. SFF drivers w/ custom DMA interface implement noop BMDMA ops worrying libata core might call into one of them. These problems are caused by the muddy line between SFF and BMDMA and the assumption that all BMDMA controllers initialize bmdma_addr. This patch fixes p1 and p2 by removing the bmdma_addr assumption and moving prd allocation to BMDMA port start. Later patches will fix the remaining issues. This patch improves BMDMA initialization such that * When BMDMA register initialization fails, falls back to PIO instead of failing. ata_pci_bmdma_init() never fails now. * When ata_pci_bmdma_init() falls back to PIO, it clears ap->mwdma_mask and udma_mask instead of depending on ata_bmdma_mode_filter(). This makes ata_bmdma_mode_filter() unnecessary thus resolving p1. * ata_port_start() which actually is BMDMA specific is moved to ata_bmdma_port_start(). ata_port_start() and ata_sff_port_start() are killed. * ata_sff_port_start32() is moved and renamed to ata_bmdma_port_start32(). Drivers which no longer call into PRD table allocation are... pdc_adma, sata_inic162x, sata_qstor, sata_sx4, pata_cmd640 and all drivers which inherit from ata_sff_port_ops. pata_icside sets ->port_start to ATA_OP_NULL as it doesn't need PRD but is a BMDMA controller and doesn't have custom port_start like other such controllers. Note that with the previous patch which makes all and only BMDMA drivers inherit from ata_bmdma_port_ops, this change doesn't break drivers which need PRD table. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-03-01libata: Pass host flags into the pci helperAlan Cox
This allows parallel scan and the like to be set without having to stop using the existing full helper functions. This patch merely adds the argument and fixes up the callers. It doesn't undo the special cases already in the tree or add any new parallel callers. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-03-01pata_hpt366: remove irrelevant TODOSergei Shtylyov
HPT36x chips just don't have DPLL. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-03-01pata_hpt366: remove redundant codeSergei Shtylyov
There's no need to clear the fast interrupt bit in hpt366_set_mode() since we're doing it in hpt366_init_chipset() already. While at it, rename 'addr1' local variable to 'addr' and exclude 'ap->port_no' from its calculation as HPT36x are single-channel-per-function chips. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-12-03ata: use pci_dev->revisionSergei Shtylyov
Some places were using PCI_CLASS_REVISION instead of PCI_REVISION_ID, so they weren't converted by commit 44c10138fd4bbc4b6d6bff0873c24902f2a9da65 (PCI: Change all drivers to use pci_device->revision). Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-12-03pata_hpt366: fix timing register documentationSergei Shtylyov
The comment in the driver actually describes HPT37x's timing register layout, which is different from HPT36x. Fix it and reformat the comment, while at it. Bump the driver version, accounting for several patches that forgot to do it. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-03-24[libata] convert drivers to use ata.h mode mask definesErik Inge Bolsø
No functional changes in this patch. Signed-off-by: Erik Inge Bolsø <knan-lkml@anduin.net> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-08pata_hpt366: reimplement mode programmingTejun Heo
Reimplement mode programming logic of pata_hpt366 such that it's identical to that of IDE hpt366 driver. The differences were... * pata_hpt366 used 0xCFFF8FFFF to mask pio modes and 0x3FFFFFFF dma modes. IDE hpt366 uses 0xC1F8FFFF for PIO, 0x303800FF for MWDMA and 0x30070000 for UDMA. * pata_hpt366 doesn't set 0x08000000 for PIO unless it's already set and always turns it on for MWDMA/UDMA. IDE hpt366 doesn't bother with the bit. It always uses what was there. * IDE hpt366 always clears 0xC0000000. pata_hpt366 doesn't. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-12-16pata_hpt366: no ATAPI DMATejun Heo
IDE hpt366 driver doesn't allow DMA for ATAPI devices and MWDMA2 on ATAPI device locks up pata_hpt366. Follow the suit. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-12-16pata_hpt366: fix cable detection,Tejun Heo
pata_hpt366 is strange in that its two channels occupy two PCI functions and both are primary channels and bit1 of PCI configuration register 0x5A indicates cable for both channels. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-12-09pata_hpt366: fix clock detectionTejun Heo
pata_hpt366 had its clock detection wrong and detected 25Mhz as 40Mhz and vice-versa. Fix it. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-17libata: rename SFF functionsTejun Heo
SFF functions have confusing names. Some have sff prefix, some have bmdma, some std, some pci and some none. Unify the naming by... * SFF functions which are common to both BMDMA and non-BMDMA are prefixed with ata_sff_. * SFF functions which are specific to BMDMA are prefixed with ata_bmdma_. * SFF functions which are specific to PCI but apply to both BMDMA and non-BMDMA are prefixed with ata_pci_sff_. * SFF functions which are specific to PCI and BMDMA are prefixed with ata_pci_bmdma_. * Drop generic prefixes from LLD specific routines. For example, bfin_std_dev_select -> bfin_dev_select. The following renames are noteworthy. ata_qc_issue_prot() -> ata_sff_qc_issue() ata_pci_default_filter() -> ata_bmdma_mode_filter() ata_dev_try_classify() -> ata_sff_dev_classify() This rename is in preparation of separating SFF support out of libata core layer. This patch strictly renames functions and doesn't introduce any behavior difference. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: stop overloading port_info->private_dataTejun Heo
port_info->private_data is currently used for two purposes - to record private data about the port_info or to specify host->private_data to use when allocating ata_host. This overloading is confusing and counter-intuitive in that port_info->private_data becomes host->private_data instead of port->private_data. In addition, port_info and host don't correspond to each other 1-to-1. Currently, the first non-NULL port_info->private_data is used. This patch makes port_info->private_data just be what it is - private_data for the port_info where LLD can jot down extra info. libata no longer sets host->private_data to the first non-NULL port_info->private_data, @host_priv argument is added to ata_pci_init_one() instead. LLDs which use ata_pci_init_one() can use this argument to pass in pointer to host private data. LLDs which don't should use init-register model anyway and can initialize host->private_data directly. Adding @host_priv instead of using init-register model for LLDs which use ata_pci_init_one() is suggested by Alan Cox. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
2008-04-17libata: make ata_pci_init_one() not use ops->irq_handler and pi->shtTejun Heo
ata_pci_init_one() is the only function which uses ops->irq_handler and pi->sht. Other initialization functions take the same information as arguments. This causes confusion and duplicate unused entries in structures. Make ata_pci_init_one() take sht as an argument and use ata_interrupt implicitly. All current users use ata_interrupt and if different irq handler is necessary open coding ata_pci_init_one() using ata_prepare_sff_host() and ata_activate_sff_host can be done under ten lines including error handling and driver which requires custom interrupt handler is likely to require custom initialization anyway. As ata_pci_init_one() was the last user of ops->irq_handler, this patch also kills the field. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: implement and use ops inheritanceTejun Heo
libata lets low level drivers build ata_port_operations table and register it with libata core layer. This allows low level drivers high level of flexibility but also burdens them with lots of boilerplate entries. This becomes worse for drivers which support related similar controllers which differ slightly. They share most of the operations except for a few. However, the driver still needs to list all operations for each variant. This results in large number of duplicate entries, which is not only inefficient but also error-prone as it becomes very difficult to tell what the actual differences are. This duplicate boilerplates all over the low level drivers also make updating the core layer exteremely difficult and error-prone. When compounded with multi-branched development model, it ends up accumulating inconsistencies over time. Some of those inconsistencies cause immediate problems and fixed. Others just remain there dormant making maintenance increasingly difficult. To rectify the problem, this patch implements ata_port_operations inheritance. To allow LLDs to easily re-use their own ops tables overriding only specific methods, this patch implements poor man's class inheritance. An ops table has ->inherits field which can be set to any ops table as long as it doesn't create a loop. When the host is started, the inheritance chain is followed and any operation which isn't specified is taken from the nearest ancestor which has it specified. This operation is called finalization and done only once per an ops table and the LLD doesn't have to do anything special about it other than making the ops table non-const such that libata can update it. libata provides four base ops tables lower drivers can inherit from - base, sata, pmp, sff and bmdma. To avoid overriding these ops accidentaly, these ops are declared const and LLDs should always inherit these instead of using them directly. After finalization, all the ops table are identical before and after the patch except for setting .irq_handler to ata_interrupt in drivers which didn't use to. The .irq_handler doesn't have any actual effect and the field will soon be removed by later patch. * sata_sx4 is still using old style EH and currently doesn't take advantage of ops inheritance. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: implement and use SHT initializersTejun Heo
libata lets low level drivers build scsi_host_template and register it to the SCSI layer. This allows low level drivers high level of flexibility but also burdens them with lots of boilerplate entries. This patch implements SHT initializers which can be used to initialize all the boilerplate entries in a sht. Three variants of them are implemented - BASE, BMDMA and NCQ - for different types of drivers. Note that entries can be overriden by putting individual initializers after the helper macro. All sht tables are identical before and after this patch. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: PCI device should be powered up before being accessedTejun Heo
PCI device should be powered up or powered up before its PCI regsiters are accessed. Although PCI configuration register access is allowed in D3hot, PCI device is free to reset its status when transiting from D3hot to D0 causing configuration data to change. Many libata SFF drivers which use ata_pci_init_one() read and update configuration registers before calling ata_pci_init_one() which enables the PCI device. Also, in resume paths, some drivers access registers without resuming the PCI device. This patch adds a call to pcim_enable_device() in init path if register is accessed before calling ata_pci_init_one() and make resume paths first resume PCI devices, access PCI configuration regiters then resume ATA host. While at it... * cmd640 was strange in that it set ->resume even when CONFIG_PM is not. This is by-product of minimal build fix. Updated. * In cs5530, Don't BUG() on reinit failure. Just whine and fail resume. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-03-05pata_hpt*, pata_serverworks: fix UDMA maskingAlan Cox
When masking, mask out the modes that are unsupported not the ones that are supported. This makes life happier. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata: Switch most of the remaining SFF drivers to ata_sff_port_startAlan Cox
This avoids allocating DMA buffers if not needed but at the moment is mostly just a neatness item. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12[libata] Remove ->port_disable() hookJeff Garzik
It was always set to ata_port_disable(). Removed the hook, and replaced the very few ap->ops->port_disable() callsites with direct calls to ata_port_disable(). Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12[libata] Remove ->irq_ack() hook, and ata_dummy_irq_on()Jeff Garzik
* ->irq_ack() is redundant to what the irq handler already performs... chk-status + irq-clear. Furthermore, it is only called in one place, when screaming-irq-debugging is enabled, so we don't want to bother with a hook just for that. * ata_dummy_irq_on() is only ever used in drivers that have no callpath reaching ->irq_on(). Remove .irq_on hook from those drivers, and the now-unused ata_dummy_irq_on() Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-09[libata] Use ATA_UDMAx standard masks when filling driver's udma_mask infoJeff Garzik
The ATA_UDMAx masks are self-documenting, and far better than manually writing in the hex mask. Note that pata_it8213 mask differed from the comment. Added a FIXME there. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-09[libata] PATA drivers: remove ATA_FLAG_SRSTJeff Garzik
This flag only has meaning in old-EH drivers, and these drivers have already been converted to the new EH. Remove. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-21pata_hpt366: Enable bits are unreliable so don't use themAlan Cox
Various people had problems with both old and new IDE when hpt366 enable bits started getting honoured. It turns out they are not reliable so don't rely on them Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-11libata: clean up SFF init messTejun Heo
The intention of using port_mask in SFF init helpers was to eventually support exoctic configurations such as combination of legacy and native port on the same controller. This never became actually necessary and the related code always has been subtly broken one way or the other. Now that new init model is in place, there is no reason to make common helpers capable of handling all corner cases. Exotic cases can simply dealt within LLDs as necessary. This patch removes port_mask handling in SFF init helpers. SFF init helpers don't take n_ports argument and interpret it into port_mask anymore. All information is carried via port_info. n_ports argument is dropped and always two ports are allocated. LLD can tell SFF to skip certain port by marking it dummy. Note that SFF code has been treating unuvailable ports this way for a long time until recent breakage fix from Linus and is consistent with how other drivers handle with unavailable ports. This fixes 1-port legacy host handling still broken after the recent native mode fix and simplifies SFF init logic. The following changes are made... * ata_pci_init_native_host() and ata_init_legacy_host() both now try to initialized whatever they can and mark failed ports dummy. They return 0 if any port is successfully initialized. * ata_pci_prepare_native_host() and ata_pci_init_one() now doesn't take n_ports argument. All info should be specified via port_info array. Always two ports are allocated. * ata_pci_init_bmdma() exported to be used by LLDs in exotic cases. * port_info handling in all LLDs are standardized - all port_info arrays are const stack variable named ppi. Unless the second port is different from the first, its port_info is specified as NULL (tells libata that it's identical to the last non-NULL port_info). * pata_hpt37x/hpt3x2n: don't modify static variable directly. Make an on-stack copy instead as ata_piix does. * pata_uli: It has 4 ports instead of 2. Don't use ata_pci_prepare_native_host(). Allocate the host explicitly and use init helpers. It's simple enough. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-11libata: reimplement suspend/resume support using sdev->manage_start_stopTejun Heo
Reimplement suspend/resume support using sdev->manage_start_stop. * Device suspend/resume is now SCSI layer's responsibility and the code is simplified a lot. * DPM is dropped. This also simplifies code a lot. Suspend/resume status is port-wide now. * ata_scsi_device_suspend/resume() and ata_dev_ready() removed. * Resume now has to wait for disk to spin up before proceeding. I couldn't find easy way out as libata is in EH waiting for the disk to be ready and sd is waiting for EH to complete to issue START_STOP. * sdev->manage_start_stop is set to 1 in ata_scsi_slave_config(). This fixes spindown on shutdown and suspend-to-disk. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-01libata: add deadline support to prereset and reset methodsTejun Heo
Add @deadline to prereset and reset methods and make them honor it. ata_wait_ready() which directly takes @deadline is implemented to be used as the wait function. This patch is in preparation for EH timing improvements. * ata_wait_ready() never does busy sleep. It's only used from EH and no wait in EH is that urgent. This function also prints 'be patient' message automatically after 5 secs of waiting if more than 3 secs is remaining till deadline. * ata_bus_post_reset() now fails with error code if any of its wait fails. This is important because earlier reset tries will have shorter timeout than the spec requires. If a device fails to respond before the short timeout, reset should be retried with longer timeout rather than silently ignoring the device. There are three behavior differences. 1. Timeout is applied to both devices at once, not separately. This is more consistent with what the spec says. 2. When a device passes devchk but fails to become ready before deadline. Previouly, post_reset would just succeed and let device classification remove the device. New code fails the reset thus causing reset retry. After a few times, EH will give up disabling the port. 3. When slave device passes devchk but fails to become accessible (TF-wise) after reset. Original code disables dev1 after 30s timeout and continues as if the device doesn't exist, while the patched code fails reset. When this happens, new code fails reset on whole port rather than proceeding with only the primary device. If the failing device is suffering transient problems, new code retries reset which is a better behavior. If the failing device is actually broken, the net effect is identical to it, but not to the other device sharing the channel. In the previous code, reset would have succeeded after 30s thus detecting the working one. In the new code, reset fails and whole port gets disabled. IMO, it's a pathological case anyway (broken device sharing bus with working one) and doesn't really matter. * ata_bus_softreset() is changed to return error code from ata_bus_post_reset(). It used to return 0 unconditionally. * Spin up waiting is to be removed and not converted to honor deadline. * To be on the safe side, deadline is set to 40s for the time being. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28pata: cable methodsAlan Cox
Versus upstream as requested Last of the trivial switches to cable_detect methods. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28libata: Change prototype of mode_filter to remove ata_port*Alan Cox
With Tejun having added adev->ap some time ago we can get rid of the almost unused port being passed to mode filters. And while we are doing filters, lets turn on the !IORDY filter as well. Signed-off-by: Alan Cox <alan@redhat.com> With some hand massaging from Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28pata_hpt366: support ->cable_detectAlan Cox
2007-03-02libata: add missing CONFIG_PM in LLDsTejun Heo
Add missing #ifdef CONFIG_PM conditionals around all PM related parts in libata LLDs. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-26[libata] bump versionsJeff Garzik
Bump versions based on changes submitted during 2.6.21 merge window. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09libata: add another IRQ calls (libata drivers)Akira Iguchi
This patch is against each libata driver. Two IRQ calls are added in ata_port_operations. - irq_on() is used to enable interrupts. - irq_ack() is used to acknowledge a device interrupt. In most drivers, ata_irq_on() and ata_irq_ack() are used for irq_on and irq_ack respectively. In some drivers (ex: ahci, sata_sil24) which cannot use them as is, ata_dummy_irq_on() and ata_dummy_irq_ack() are used. Signed-off-by: Kou Ishizaki <kou.ishizaki@toshiba.co.jp> Signed-off-by: Akira Iguchi <akira2.iguchi@toshiba.co.jp> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09libata: convert to iomapTejun Heo
Convert libata core layer and LLDs to use iomap. * managed iomap is used. Pointer to pcim_iomap_table() is cached at host->iomap and used through out LLDs. This basically replaces host->mmio_base. * if possible, pcim_iomap_regions() is used Most iomap operation conversions are taken from Jeff Garzik <jgarzik@pobox.com>'s iomap branch. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09libata: update libata LLDs to use devresTejun Heo
Update libata LLDs to use devres. Core layer is already converted to support managed LLDs. This patch simplifies initialization and fixes many resource related bugs in init failure and detach path. For example, all converted drivers now handle ata_device_add() failure gracefully without excessive resource rollback code. As most resources are released automatically on driver detach, many drivers don't need or can do with much simpler ->{port|host}_stop(). In general, stop callbacks are need iff port or host needs to be given commands to shut it down. Note that freezing is enough in many cases and ports are automatically frozen before being detached. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09libata: use ata_id_c_string()Tejun Heo
There were several places where ATA ID strings are manually terminated and in some places possibly unterminated strings were passed to string functions which don't limit length like strstr(). This patch converts all of them over to ata_id_c_string(). Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09libata: straighten out ATA_ID_* constantsTejun Heo
* Kill _OFS suffixes in ATA_ID_{SERNO|FW_REV|PROD}_OFS for consistency with other ATA_ID_* constants. * Kill ATA_SERNO_LEN * Add and use ATA_ID_SERNO_LEN, ATA_ID_FW_REV_LEN and ATA_ID_PROD_LEN. This change also makes ata_device_blacklisted() use proper length for fwrev. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09[libata] trim trailing whitespaceJeff Garzik
Most of these contributed by that mysterious figger known as A.C. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-03[PATCH] libata: kill unnecessary sht->max_sectors initializationsTejun Heo
sht->max_sectors is overrided unconditionally in ->slave_configure. There's no reason to set it to any value. Signed-off-by: Tejun Heo <htejun@gmail.com>
2006-12-01[PATCH] hpt36x: Suspend/resume supportAlan
Another chipset which needs some reconfiguration after a resume. All the chip setup is moved to a new function called in both setup and resume. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
