path: root/drivers/acpi
2010-10-01Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: ACPI: invoke DSDT corruption workaround on all Toshiba Satellite ACPI, APEI, Fix ERST MOVE_DATA instruction implementation ACPI: fan: Fix more unbalanced code block ACPI: acpi_pad: simplify code to avoid false gcc build warning ACPI, APEI, Fix error path for memory allocation ACPI, APEI, HEST Fix the unsuitable usage of platform_data ACPI, APEI, Fix acpi_pre_map() return value ACPI, APEI, Fix APEI related table size checking ACPI: Disable Windows Vista compatibility for Toshiba P305D ACPI: Kconfig: fix typo. ACPI: add missing __percpu markup in arch/x86/kernel/acpi/cstate.c ACPI: Fix typos ACPI video: fix a poor warning message ACPI: fix build warnings resulting from merge window conflict ACPI: EC: add Vista incompatibility DMI entry for Toshiba Satellite L355 ACPI: expand Vista blacklist to include SP1 and SP2 ACPI: delete ZEPTO idle=nomwait DMI quirk ACPI: enable repeated PCIEXP wakeup by clearing PCIEXP_WAKE_STS on resume PM / ACPI: Blacklist systems known to require acpi_sleep=nonvs ACPI: Don't report current_now if battery reports in mWh
2010-09-29Merge branches 'apei', 'battery-mwh-fix', 'bugzilla-10807', ↵Len Brown
'bugzilla-14736', 'bugzilla-14679', 'bugzilla-16396', 'launchpad-613381' and 'misc' into release
2010-09-29ACPI: invoke DSDT corruption workaround on all Toshiba SatelliteLen Brown
Our list of Toshiba Satellite models that require this workaround is growing -- so invoke the workaround for the entire product line. https://bugzilla.kernel.org/show_bug.cgi?id=14679 Signed-off-by: Len Brown <len.brown@intel.com>
2010-09-29ACPI, APEI, Fix ERST MOVE_DATA instruction implementationHuang Ying
The src_base and dst_base fields in apei_exec_context are physical address, so they should be ioremaped before being used in ERST MOVE_DATA instruction. Reported-by: Javier Martinez Canillas <martinez.javier@gmail.com> Reported-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-09-29ACPI: fan: Fix more unbalanced code blockLuis Henriques
commit 934231de706d2579fae14f5857fcd8de991009ff fixes an unbalanced CONFIG_ACPI_PROCFS code block during module initialisation. This patch fixes similar issue but for the module exit. Signed-off-by: Luis Henriques <luis.henrix@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-09-29ACPI: acpi_pad: simplify code to avoid false gcc build warningLen Brown
acpi_pad.c:432: warning: ‘num_cpus’ may be used uninitialized in this function gcc 4.4.4 was unable to notice that num_cpus is always set. Re-arrange the code to un-confuse gcc, and also make it easier for humans to read.... Signed-off-by: Len Brown <len.browns@intel.com>
2010-09-29ACPI, APEI, Fix error path for memory allocationHuang Ying
In ERST debug/test support patch, a dynamic allocated buffer is used. The may-failed memory allocation should be tried firstly before free the previous buffer. APEI resource management memory allocation related error path is fixed too. v2: - Fix error messages for APEI resources management Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-09-29ACPI, APEI, HEST Fix the unsuitable usage of platform_dataJin Dongming
platform_data in hest_parse_ghes() is used for saving the address of entry information of erst_tab. When the device is failed to be added, platform_data will be freed by platform_device_put(). But the value saved in platform_data should not be freed here. If it is done, it will make system panic. So I think platform_data should save the address of allocated memory which saves entry information of erst_tab. This patch fixed it and I confirmed it on x86_64 next-tree. v2: Transport the pointer of hest_hdr to platform_data using platform_device_add_data() Signed-off-by: Jin Dongming <jin.dongming@np.css.fujitsu.com> Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-09-29ACPI, APEI, Fix acpi_pre_map() return valueJin Dongming
After we ioremap() a new region, we call __acpi_try_ioremap() to see whether another thread has already mapped the same region. This check clobbers "vaddr", so compute the return value of acpi_pre_map() using the ioremap() result "map->vaddr" instead. v2: Modified the unsuitable description of patch. v3: Removed unlikely() check and made description simpler. Signed-off-by: Jin Dongming <jin.dongming@np.css.fujitsu.com> Reviewed-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-09-29ACPI, APEI, Fix APEI related table size checkingHuang Ying
On Huang Ying's machine: erst_tab->header_length == sizeof(struct acpi_table_einj) but Yinghai reported that on his machine, erst_tab->header_length == sizeof(struct acpi_table_einj) - sizeof(struct acpi_table_header) To make erst table size checking code works on all systems, both testing are treated as PASS. Same situation applies to einj_tab->header_length, so corresponding table size checking is changed in similar way too. v2: - Treat both table size as valid Originally-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-09-28acpi_idle: add missing \n to printkLen Brown
otherwise, these two lines print as one: ACPI: acpi_idle yielding to intel_idle ACPI: SSDT 3f5d8741 00203 (v02 PmRef Cpu0Ist 00003000 INTL 20050624) Signed-off-by: Len Brown <len.brown@intel.com>
2010-09-28ACPI: Disable Windows Vista compatibility for Toshiba P305DZhang Rui
Disable the Windows Vista (SP1) compatibility for Toshiba P305D. http://bugzilla.kernel.org/show_bug.cgi?id=14736 Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-09-28ACPI: Kconfig: fix typo.Andrea Gelmini
"power of" -> "power off" Signed-off-by: Len Brown <len.brown@intel.com>
2010-09-28ACPI: Fix typosLucas De Marchi
2010-09-28ACPI video: fix a poor warning messageZhang Rui
Fix a vague warning message. https://bugzilla.kernel.org/show_bug.cgi?id=16599 Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-09-28ACPI: fix build warnings resulting from merge window conflictZhang Rui
drivers/acpi/sysfs.c:154: warning: passing argument 1 of '__check_old_set_param' from incompatible pointer type include/linux/moduleparam.h:165: note: expected 'int (*)(const char *, struct kernel_param *)' but argument is of type 'int (*)(const char *, const struct kernel_param *)' Introduced by commit 1c8fce27e275fd7c6b75bc6455745f02d3903ee6 ("ACPI: introduce drivers/acpi/sysfs.c") interacting with commit 9bbb9e5a33109b2832e2e63dcc7a132924ab374b ("param: use ops in struct kernel_param, rather than get and set fns directly"). Use module_param_cb instead of the obsoleted module_param_call to fix a build warning. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-09-28ACPI: EC: add Vista incompatibility DMI entry for Toshiba Satellite L355Len Brown
https://bugzilla.kernel.org/show_bug.cgi?id=12641 Signed-off-by: Len Brown <len.brown@intel.com>
2010-09-28ACPI: expand Vista blacklist to include SP1 and SP2Len Brown
When we claim incompatibility with Vista, include both Vista SP1 and SP2. https://bugzilla.kernel.org/show_bug.cgi?id=12641 Signed-off-by: Len Brown <len.brown@intel.com>
2010-09-28ACPI: delete ZEPTO idle=nomwait DMI quirkLen Brown
per comments in the bug report, this entry seems to hurt at much as it helps. https://bugzilla.kernel.org/show_bug.cgi?id=10807 Signed-off-by: Len Brown <len.brown@intel.com>
2010-09-28ACPI: enable repeated PCIEXP wakeup by clearing PCIEXP_WAKE_STS on resumeColin Ian King
Section 4.7.3.1.1 (PM1 Status Registers) of version 4.0 of the ACPI spec concerning PCIEXP_WAKE_STS points out in in the final note field in table 4-11 that if this bit is set to 1 and the system is put into a sleeping state then the system will not automatically wake. This bit gets set by hardware to indicate that the system woke up due to a PCI Express wakeup event, so clear it during acpi_hw_clear_acpi_status() calls to enable subsequent resumes to work. BugLink: http://bugs.launchpad.net/bugs/613381 Signed-off-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-09-24PM / ACPI: Blacklist systems known to require acpi_sleep=nonvsRafael J. Wysocki
Commit 2a6b69765ad794389f2fc3e14a0afa1a995221c2 (ACPI: Store NVS state even when entering suspend to RAM) changed the ACPI suspend to RAM code so that the NVS memory area is always unconditionally saved during suspend and restored during resume, since some systems evidently need that for the suspend-resume to work on them. However, it turned out that this change broke suspend-resume on a few systems, so commit 72ad5d77fb981963edae15eee8196c80238f5ed0 (ACPI / Sleep: Allow the NVS saving to be skipped during suspend to RAM) introduced the acpi_sleep=nonvs command line switch to allow their users to work around this issue. To keep track of the systems that require this workaround and to make the life of their users slightly easier blacklist them in acpisleep_dmi_table[]. https://bugzilla.kernel.org/show_bug.cgi?id=16396 Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2010-09-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI: bus speed strings should be const PCI hotplug: Fix build with CONFIG_ACPI unset PCI: PCIe: Remove the port driver module exit routine PCI: PCIe: Move PCIe PME code to the pcie directory PCI: PCIe: Disable PCIe port services during port initialization PCI: PCIe: Ask BIOS for control of all native services at once ACPI/PCI: Negotiate _OSC control bits before requesting them ACPI/PCI: Do not preserve _OSC control bits returned by a query ACPI/PCI: Make acpi_pci_query_osc() return control bits ACPI/PCI: Reorder checks in acpi_pci_osc_control_set() PCI: PCIe: Introduce commad line switch for disabling port services PCI: PCIe AER: Introduce pci_aer_available() x86/PCI: only define pci_domain_nr if PCI and PCI_DOMAINS are set PCI: provide stub pci_domain_nr function for !CONFIG_PCI configs
2010-08-31ACPI: Don't report current_now if battery reports in mWhMatthew Garrett
ACPI batteries can report in units of either current or energy. Right now we expose the current_now file even if the battery is reporting energy units, resulting in a file that should contain mA instead containing mW. Don't expose this value unless the battery is reporting current. Signed-off-by: Matthew Garrett <mjg@redhat.com> Cc: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-08-24PCI: PCIe: Ask BIOS for control of all native services at onceRafael J. Wysocki
After commit 852972acff8f10f3a15679be2059bb94916cba5d (ACPI: Disable ASPM if the platform won't provide _OSC control for PCIe) control of the PCIe Capability Structure is unconditionally requested by acpi_pci_root_add(), which in principle may cause problems to happen in two ways. First, the BIOS may refuse to give control of the PCIe Capability Structure if it is not asked for any of the _OSC features depending on it at the same time. Second, the BIOS may assume that control of the _OSC features depending on the PCIe Capability Structure will be requested in the future and may behave incorrectly if that doesn't happen. For this reason, control of the PCIe Capability Structure should always be requested along with control of any other _OSC features that may depend on it (ie. PCIe native PME, PCIe native hot-plug, PCIe AER). Rework the PCIe port driver so that (1) it checks which native PCIe port services can be enabled, according to the BIOS, and (2) it requests control of all these services simultaneously. In particular, this causes pcie_portdrv_probe() to fail if the BIOS refuses to grant control of the PCIe Capability Structure, which means that no native PCIe port services can be enabled for the PCIe Root Complex the given port belongs to. If that happens, ASPM is disabled to avoid problems with mishandling it by the part of the PCIe hierarchy for which control of the PCIe Capability Structure has not been received. Make it possible to override this behavior using 'pcie_ports=native' (use the PCIe native services regardless of the BIOS response to the control request), or 'pcie_ports=compat' (do not use the PCIe native services at all). Accordingly, rework the existing PCIe port service drivers so that they don't request control of the services directly. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-08-24ACPI/PCI: Negotiate _OSC control bits before requesting them Rafael J. Wysocki
It is possible that the BIOS will not grant control of all _OSC features requested via acpi_pci_osc_control_set(), so it is recommended to negotiate the final set of _OSC features with the query flag set before calling _OSC to request control of these features. To implement it, rework acpi_pci_osc_control_set() so that the caller can specify the mask of _OSC control bits to negotiate and the mask of _OSC control bits that are absolutely necessary to it. Then, acpi_pci_osc_control_set() will run _OSC queries in a loop until the mask of _OSC control bits returned by the BIOS is equal to the mask passed to it. Also, before running the _OSC request acpi_pci_osc_control_set() will check if the caller's required control bits are present in the final mask. Using this mechanism we will be able to avoid situations in which the BIOS doesn't grant control of certain _OSC features, because they depend on some other _OSC features that have not been requested. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-08-24ACPI/PCI: Do not preserve _OSC control bits returned by a query Rafael J. Wysocki
There is the assumption in acpi_pci_osc_control_set() that it is always sufficient to compare the mask of _OSC control bits to be requested with the result of an _OSC query where all of the known control bits have been checked. However, in general, that need not be the case. For example, if an _OSC feature A depends on an _OSC feature B and control of A, B plus another _OSC feature C is requested simultaneously, the BIOS may return A, B, C, while it would only return C if A and C were requested without B. That may result in passing a wrong mask of _OSC control bits to an _OSC control request, in which case the BIOS may only grant control of a subset of the requested features. Moreover, acpi_pci_run_osc() will return error code if that happens and the caller of acpi_pci_osc_control_set() will not know that it's been granted control of some _OSC features. Consequently, the system will generally not work as expected. Apart from this acpi_pci_osc_control_set() always uses the mask of _OSC control bits returned by the very first invocation of acpi_pci_query_osc(), but that is done with the second argument equal to OSC_PCI_SEGMENT_GROUPS_SUPPORT which generally happens to affect the returned _OSC control bits. For these reasons, make acpi_pci_osc_control_set() always check if control of the requested _OSC features will be granted before making the final control request. As a result, the osc_control_qry and osc_queried members of struct acpi_pci_root are not necessary any more, so drop them and remove the remaining code referring to them. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-08-24ACPI/PCI: Make acpi_pci_query_osc() return control bitsRafael J. Wysocki
Make acpi_pci_query_osc() use an additional pointer argument to return the mask of control bits obtained from the BIOS to the caller. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-08-24ACPI/PCI: Reorder checks in acpi_pci_osc_control_set()Rafael J. Wysocki
Make acpi_pci_osc_control_set() attempt to find the handle of the _OSC object under the given PCI root bridge object after verifying that its second argument is correct and that there is a struct acpi_pci_root object for the given root bridge handle, which is more logical than the old code. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reviewed-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-08-15Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: gcc-4.6: ACPI: fix unused but set variables in ACPI ACPI thermal: make procfs I/F depend on CONFIG_ACPI_PROCFS ACPI video: make procfs I/F depend on CONFIG_ACPI_PROCFS ACPI processor: remove deprecated ACPI procfs I/F ACPI power_resource: remove unused procfs I/F ACPI: remove deprecated ACPI procfs I/F ACPI: introduce drivers/acpi/sysfs.c ACPI: introduce module parameter acpi.aml_debug_output ACPI: introduce drivers/acpi/debugfs.c ACPI, APEI, ERST debug support ACPI, APEI, Manage GHES as platform devices ACPI, APEI, Rename CPER and GHES severity constants ACPI, APEI, Fix a typo of error path of apei_resources_request ACPI / ACPICA: Fix reference counting problems with GPE handlers ACPI: Add the check of ADR flag in course of finding ACPI handle for PCI device ACPI / Sleep: Drop acpi_suspend_finish() ACPI / Sleep: Consolidate suspend and hibernation routines ACPI / Wakeup: Simplify enabling of wakeup devices ACPI / Sleep: Rework enabling wakeup devices ACPI / Sleep: Free NVS copy if suspending of devices fails Fixed up totally buggered "ACPI: fix unused but set variables in ACPI" patch that doesn't even compile in the merge. Thanks to Sedat Dilek <sedat.dilek@googlemail.com> for noticing the breakage before I even pulled. And a big "Grrr.." at Len for not even bothering to compile the tree before asking me to pull.
2010-08-15Merge branch 'linus' into releaseLen Brown
Conflicts: drivers/acpi/debug.c Signed-off-by: Len Brown <len.brown@intel.com>
2010-08-15gcc-4.6: ACPI: fix unused but set variables in ACPIAndi Kleen
Some minor improvements in error handling, but overall it was mostly dead code. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2010-08-15ACPI thermal: make procfs I/F depend on CONFIG_ACPI_PROCFSZhang Rui
Mark the ACPI thermal procfs I/F deprecated, because /sys/class/thermal/ is already available and has been working for years w/o any problem. The ACPI thermal procfs I/F will be removed in 2.6.37. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-08-15ACPI video: make procfs I/F depend on CONFIG_ACPI_PROCFSZhang Rui
Mark ACPI video driver procfs I/F deprecated, including: /proc/acpi/video/*/info /proc/acpi/video/*/DOS /proc/acpi/video/*/ROM /proc/acpi/video/*/POST /proc/acpi/video/*/POST_info /proc/acpi/video/*/*/info /proc/acpi/video/*/*/state /proc/acpi/video/*/*/EDID and /proc/acpi/video/*/*/brightness, because 1. we already have the sysfs I/F /sysclass/backlight/ as the replacement of /proc/acpi/video/*/*/brightness. 2. the other procfs I/F is not useful for userspace. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-08-15ACPI processor: remove deprecated ACPI procfs I/FZhang Rui
Remove deprecated ACPI processor procfs I/F, including: /proc/acpi/processor/CPUX/power /proc/acpi/processor/CPUX/limit /proc/acpi/processor/CPUX/info /proc/acpi/processor/CPUX/throttling still exists, as we don't have sysfs I/F available for now. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-08-15ACPI power_resource: remove unused procfs I/FZhang Rui
Remove unused ACPI power procfs I/F. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-08-15ACPI: remove deprecated ACPI procfs I/FZhang Rui
Rmove deprecated ACPI procfs I/F, including /proc/acpi/debug_layer /proc/acpi/debug_level /proc/acpi/info /proc/acpi/dsdt /proc/acpi/fadt /proc/acpi/sleep because the sysfs I/F is already available and has been working well for years. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-08-15ACPI: introduce drivers/acpi/sysfs.cZhang Rui
Introduce drivers/acpi/sysfs.c. code for ACPI sysfs I/F, including #ifdef ACPI_DEBUG /sys/module/acpi/parameters/debug_layer /sys/module/acpi/parameters/debug_level /sys/module/acpi/parameters/trace_method_name /sys/module/acpi/parameters/trace_debug_layer /sys/module/acpi/parameters/trace_debug_level /sys/module/acpi/parameters/trace_state #endif /sys/module/acpi/parameters/acpica_version /sys/firmware/acpi/tables/ /sys/firmware/acpi/interrupts/ is moved to this file. No function change in this patch. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-08-15Merge branch 'acpica-gpe' into releaseLen Brown
2010-08-14Merge branch 'bugzilla-16422' into releaseLen Brown
2010-08-14Merge branch 'procfs-cleanup' into releaseLen Brown
2010-08-14Merge branch 'apei' into releaseLen Brown
2010-08-14Merge branch 'nvs' into releaseLen Brown
2010-08-14ACPI: introduce module parameter acpi.aml_debug_outputZhang Rui
Introduce module parameter acpi.aml_debug_output. With acpi.aml_debug_output set, we can get AML debug object output (Store (AAA, Debug)), even with CONFIG_ACPI_DEBUG cleared. Together with the runtime custom method mechanism, we can debug AML code problems without rebuilding the kernel. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-08-14ACPI: introduce drivers/acpi/debugfs.cZhang Rui
Introduce drivers/acpi/debugfs.c. Code for ACPI debugfs I/F, i.e. /sys/kernel/debug/acpi/custom_method, is moved to this file. And make ACPI debugfs always built in, even if CONFIG_ACPI_DEBUG is cleared. BTW:this adds about 400bytes code to ACPI, when CONFIG_ACPI_DEBUG is cleared. [uaccess.h build fix from Andrew Morton <akpm@linux-foundation.org>] Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-08-14ACPI, APEI, ERST debug supportHuang Ying
This patch adds debugging/testing support to ERST. A misc device is implemented to export raw ERST read/write/clear etc operations to user space. With this patch, we can add ERST testing support to linuxfirmwarekit ISO (linuxfirmwarekit.org) to verify the kernel support and the firmware implementation. Signed-off-by: Huang Ying <ying.huang@intel.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-08-12Merge branch 'params' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus * 'params' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: (22 commits) param: don't deref arg in __same_type() checks param: update drivers/acpi/debug.c to new scheme param: use module_param in drivers/message/fusion/mptbase.c ide: use module_param_named rather than module_param_call param: update drivers/char/ipmi/ipmi_watchdog.c to new scheme param: lock if_sdio's lbs_helper_name and lbs_fw_name against sysfs changes. param: lock myri10ge_fw_name against sysfs changes. param: simple locking for sysfs-writable charp parameters param: remove unnecessary writable charp param: add kerneldoc to moduleparam.h param: locking for kernel parameters param: make param sections const. param: use free hook for charp (fix leak of charp parameters) param: add a free hook to kernel_param_ops. param: silence .init.text references from param ops Add param ops struct for hvc_iucv driver. nfs: update for module_param_named API change AppArmor: update for module_param_named API change param: use ops in struct kernel_param, rather than get and set fns directly param: move the EXPORT_SYMBOL to after the definitions. ...
2010-08-12acpi: fix bogus preemption logicThomas Gleixner
The ACPI_PREEMPTION_POINT() logic was introduced in commit 8bd108d (ACPICA: add preemption point after each opcode parse). The follow up commits abe1dfab6, 138d15692, c084ca70 tried to fix the preemption logic back and forth, but nobody noticed that the usage of in_atomic_preempt_off() in that context is wrong. The check which guards the call of cond_resched() is: if (!in_atomic_preempt_off() && !irqs_disabled()) in_atomic_preempt_off() is not intended for general use as the comment above the macro definition clearly says: * Check whether we were atomic before we did preempt_disable(): * (used by the scheduler, *after* releasing the kernel lock) On a CONFIG_PREEMPT=n kernel the usage of in_atomic_preempt_off() works by accident, but with CONFIG_PREEMPT=y it's just broken. The whole purpose of the ACPI_PREEMPTION_POINT() is to reduce the latency on a CONFIG_PREEMPT=n kernel, so make ACPI_PREEMPTION_POINT() depend on CONFIG_PREEMPT=n and remove the in_atomic_preempt_off() check. Addresses https://bugzilla.kernel.org/show_bug.cgi?id=16210 [akpm@linux-foundation.org: fix build] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Len Brown <lenb@kernel.org> Cc: Francois Valenduc <francois.valenduc@tvcablenet.be> Cc: Lin Ming <ming.m.lin@intel.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11param: update drivers/acpi/debug.c to new schemeRusty Russell
The new module_param_cb() uses an ops struct, and the ops take a const struct kernel_param pointer (it's in .rodata). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-08-08ACPI, APEI, Manage GHES as platform devicesHuang Ying
Register GHES during HEST initialization as platform devices. And make GHES driver into platform device driver. So that the GHES driver module can be loaded automatically when there are GHES available. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-08-08ACPI, APEI, Rename CPER and GHES severity constantsHuang Ying
The abbreviation of severity should be SEV instead of SER, so the CPER severity constants are renamed accordingly. GHES severity constants are renamed in the same way too. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
