path: root/drivers/acpi
2009-04-01Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (88 commits) PCI: fix HT MSI mapping fix PCI: don't enable too much HT MSI mapping x86/PCI: make pci=lastbus=255 work when acpi is on PCI: save and restore PCIe 2.0 registers PCI: update fakephp for bus_id removal PCI: fix kernel oops on bridge removal PCI: fix conflict between SR-IOV and config space sizing powerpc/PCI: include pci.h in powerpc MSI implementation PCI Hotplug: schedule fakephp for feature removal PCI Hotplug: rename legacy_fakephp to fakephp PCI Hotplug: restore fakephp interface with complete reimplementation PCI: Introduce /sys/bus/pci/devices/.../rescan PCI: Introduce /sys/bus/pci/devices/.../remove PCI: Introduce /sys/bus/pci/rescan PCI: Introduce pci_rescan_bus() PCI: do not enable bridges more than once PCI: do not initialize bridges more than once PCI: always scan child buses PCI: pci_scan_slot() returns newly found devices PCI: don't scan existing devices ... Fix trivial append-only conflict in Documentation/feature-removal-schedule.txt
2009-03-31proc 2/2: remove struct proc_dir_entry::ownerAlexey Dobriyan
Setting ->owner as done currently (pde->owner = THIS_MODULE) is racy as correctly noted at bug #12454. Someone can lookup entry with NULL ->owner, thus not pinning enything, and release it later resulting in module refcount underflow. We can keep ->owner and supply it at registration time like ->proc_fops and ->data. But this leaves ->owner as easy-manipulative field (just one C assignment) and somebody will forget to unpin previous/pin current module when switching ->owner. ->proc_fops is declared as "const" which should give some thoughts. ->read_proc/->write_proc were just fixed to not require ->owner for protection. rmmod'ed directories will be empty and return "." and ".." -- no harm. And directories with tricky enough readdir and lookup shouldn't be modular. We definitely don't want such modular code. Removing ->owner will also make PDE smaller. So, let's nuke it. Kudos to Jeff Layton for reminding about this, let's say, oversight. http://bugzilla.kernel.org/show_bug.cgi?id=12454 Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-03-27Merge branch 'core/percpu' into percpu-cpumask-x86-for-linus-2Ingo Molnar
Conflicts: arch/parisc/kernel/irq.c arch/x86/include/asm/fixmap_64.h arch/x86/include/asm/setup.h kernel/irq/handle.c Semantic merge: arch/x86/include/asm/fixmap.h Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-26Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
Conflicts: drivers/net/wimax/i2400m/usb-notif.c
2009-03-24Driver core: implement uevent suppress in kobjectMing Lei
This patch implements uevent suppress in kobject and removes it from struct device, based on the following ideas: 1,Uevent sending should be one attribute of kobject, so suppressing it in kobject layer is more natural than in device layer. By this way, we can do it for other objects embedded with kobject. 2,It may save several bytes for each instance of struct device.(On my omap3(32bit ARM) based box, can save 8bytes per device object) This patch also introduces dev_set|get_uevent_suppress() helpers to set and query uevent_suppress attribute in case to help kobject as private part of struct device in future. [This version is against the latest driver-core patch set of Greg,please ignore the last version.] Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-19PCI/ACPI: rename pci_osc_control_set()Kenji Kaneshige
- Rename pci_osc_control_set() to acpi_pci_osc_control_set() according to the other API names in drivers/acpi/pci_root.c. - Move _OSC related definitions to include/linux/acpi.h because _OSC related API is implemented in drivers/acpi/pci_root.c now. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Reviewed-by: Andrew Patterson <andrew.patterson@hp.com> Tested-by: Andrew Patterson <andrew.patterson@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-19PCI/ACPI: move _OSC code to pci_root.cKenji Kaneshige
Move PCI _OSC management code from drivers/pci/pci-acpi.c to drivers/acpi/pci_root.c. The benefits are - We no longer need struct osc_data and its management code (contents are moved to struct acpi_pci_root). This simplify the code, and we no longer care about kmalloc() failure. - We can make pci_acpi_osc_support() be a static function, which is called only from drivers/acpi/pci_root.c. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Reviewed-by: Andrew Patterson <andrew.patterson@hp.com> Tested-by: Andrew Patterson <andrew.patterson@hp.com> Acked-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-16acpi: check for pxm_to_node_map overflowCyrill Gorcunov
It is hardly (if ever) possible but in case of broken _PXM entry we could reach out of pxm_to_node_map array bounds in acpi_map_pxm_to_node() call. Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2009-03-16ACPI: remove doubled status checkingJiri Slaby
There was a misplaced status test (two consequent tests without a statement in between) in acpi_bus_init for ages. Remove it, since the function which should be checked (acpi_os_initialize1) has BUG_ONs on failure paths. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2009-03-16ACPI suspend: Blacklist Toshiba Satellite L300 that requires to set SCI_EN ↵Zhang Rui
directly on resume This is a supplement of commit 65df78473ffbf3bff5e2034df1638acc4f3ddd50. http://bugzilla.kernel.org/show_bug.cgi?id=12798 Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-03-16Revert "ACPI: make some IO ports off-limits to AML"Len Brown
This reverts commit 5ec5d38a1c8af255ffc481c81eef13e9155524b3. because it caused spurious dmesg warmings. We'll implement the check for off-limit ports in a more clever way in the future. http://bugzilla.kernel.org/show_bug.cgi?id=12758 Signed-off-by: Len Brown <len.brown@intel.com>
2009-03-16suspend: switch the Asus Pundit P1-AH2 to old ACPI sleep orderingAndy Whitcroft
Switch the Asus Pundit P1-AH2 (M2N8L motherboard) to the old ACPI 1.0 sleep ordering by default. Without this it will not suspend/resume correctly. Signed-off-by: Andy Whitcroft <apw@canonical.com> Tested-by: Dustin Kirkland <kirkland@canonical.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-02-24Merge branch 'tj-percpu' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/tj/misc into core/percpu Conflicts: arch/x86/include/asm/pgtable.h
2009-02-24Merge branches 'x86/acpi', 'x86/apic', 'x86/asm', 'x86/cleanups', 'x86/mm', ↵Ingo Molnar
'x86/signal' and 'x86/urgent'; commit 'v2.6.29-rc6' into x86/core
2009-02-24Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
2009-02-23acpi: add some missing section markersJeremy Fitzhardinge
early_acpi_os_unmap_memory() is an __init function, and acpi_os_unmap_memory() is allowed to access an __init function until acpi_gbl_permanent_mmap is set up. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: Len Brown <len.brown@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-22Merge branch 'linus' into x86/apicIngo Molnar
Conflicts: arch/x86/mach-default/setup.c Semantic conflict resolution: arch/x86/kernel/setup.c Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-21Merge branches 'release', 'bugzilla-12011', 'bugzilla-12632', 'misc' and ↵Len Brown
'suspend' into release
2009-02-21ACPI: remove CONFIG_ACPI_SYSTEMBjorn Helgaas
Remove CONFIG_ACPI_SYSTEM. It was always set the same as CONFIG_ACPI, and it had no menu label, so there was no way to set it to anything other than "y". Some things under CONFIG_ACPI_SYSTEM (acpi_irq_handled, acpi_os_gpe_count(), event_is_open, register_acpi_notifier(), etc.) are used unconditionally by the CA, the OSPM, and drivers, so we depend on them always being present. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-02-21battery: don't assume we are fully charged when not charging or dischargingRichard Hughes
On hardware like the T61 it can take a couple of seconds for the battery to start charging after the power is connected, and we incorrectly tell userspace that we are fully charged, and then go back to charging. Only mark a battery as fully charged when the preset charge matches either the last full charge, or the design charge. http://bugzilla.kernel.org/show_bug.cgi?id=12632 Signed-off-by: Richard Hughes <hughsient@gmail.com> Acked-by: Alexey Starikovskiy <astarikovskiy@suse.de> Acked-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Len Brown <len.brown@intel.com>
2009-02-21ACPI: EC: Add delay for slow MSI controllerAlexey Starikovskiy
http://bugzilla.kernel.org/show_bug.cgi?id=12011 Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2009-02-20alloc_percpu: change percpu_ptr to per_cpu_ptrRusty Russell
Impact: cleanup There are two allocated per-cpu accessor macros with almost identical spelling. The original and far more popular is per_cpu_ptr (44 files), so change over the other 4 files. tj: kill percpu_ptr() and update UP too Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: mingo@redhat.com Cc: lenb@kernel.org Cc: cpufreq@vger.kernel.org Signed-off-by: Tejun Heo <tj@kernel.org>
2009-02-14Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
Conflicts: drivers/net/wireless/iwlwifi/iwl-agn.c drivers/net/wireless/iwlwifi/iwl3945-base.c
2009-02-09acpi/x86: introduce __apci_map_table, v4Yinghai Lu
to prevent wrongly overwriting fixmap that still want to use. ACPI used to rely on low mappings being all linearly mapped and grew a habit: it never really unmapped certain kinds of tables after use. This can cause problems - for example the hypothetical case when some spurious access still references it. v2: remove prev_map and prev_size in __apci_map_table v3: let acpi_os_unmap_memory() call early_iounmap too, so remove extral calling to early_acpi_os_unmap_memory v4: fix typo in one acpi_get_table_with_size calling Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Acked-by: Len Brown <len.brown@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-09acpi: remove final __acpi_map_table mapping before setting ↵Jeremy Fitzhardinge
acpi_gbl_permanent_mmap On x86, __acpi_map_table uses early_ioremap() to create the mapping, replacing the previous mapping with a new one. Once enough of the kernel is up an running it switches to using normal ioremap(). At that point, we need to clean up the final mapping to avoid a warning from the early_ioremap subsystem. This can be removed after all the instances in the ACPI code are fixed that rely on early-ioremap's implicit overmapping of previously mapped tables. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Acked-by: Len Brown <len.brown@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-07Merge branches 'release', 'asus', 'bugzilla-12450', 'cpuidle', 'debug', ↵Len Brown
'ec', 'misc', 'printk' and 'processor' into release
2009-02-07ACPI: Kconfig text - Fix the ACPI_CONTAINER module name according to the ↵Thierry Vignaud
real module name. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2009-02-07ACPICA: Fix table entry truncation calculationMyron Stowe
During early boot, ACPI RSDT/XSDT table entries are gathered into the 'initial_tables[]' array. This array is currently statically defined (see ./drivers/acpi/tables.c). When there are more table entries than can be held in the 'initial_tables[]' array, the message "Truncating N table entries!" is output. As currently implemented, this message will always erroneously calculate N as 0. This patch fixes the calculation that determines how many table entries will be missing (truncated). This modification may be used under either the GPL or the BSD-style license used for Intel ACPI CA code. Signed-off-by: Myron Stowe <myron.stowe@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2009-02-07ACPI: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2009-02-07ACPI: add missing KERN_* constants to printksFrank Seidel
According to kerneljanitors todo list all printk calls (beginning a new line) should have an according KERN_* constant. Those are the missing peaces here for the acpi subsystem. Signed-off-by: Frank Seidel <frank@f-seidel.de> Signed-off-by: Len Brown <len.brown@intel.com>
2009-02-06ACPI: dock: Don't eval _STA on every show_docked sysfs readHolger Macht
Some devices trigger a DEVICE_CHECK on every evalutation of _STA. This can also be seen in commit 8b59560a3baf2e7c24e0fb92ea5d09eca92805db (ACPI: dock: avoid check _STA method). If an undock is processed, the dock driver sends a uevent and userspace might read the show_docked property in sysfs. This causes an evaluation of _STA of the particular device which causes the dock driver to immediately dock again. In any case, evaluation of _STA (show_docked) does not necessarily mean that we are docked, so check with the internal device structure. http://bugzilla.kernel.org/show_bug.cgi?id=12360 Signed-off-by: Holger Macht <hmacht@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2009-02-06ACPI: disable ACPI cleanly when bad RSDP foundLen Brown
When ACPI is disabled in the BIOS of this VIA C3 box, it invalidates the RSDP, which Linux notices: ACPI Error (tbxfroot-0218): A valid RSDP was not found [20080926] Bug Linux neglected to disable ACPI at that stage, and later scribbled on smp_found_config: ACPI: No APIC-table, disabling MPS But this box doesn't run well in legacy PIC mode, it needed IOAPIC mode to perform correctly: http://lkml.org/lkml/2009/2/5/39 So exit ACPI mode cleanly when we first detect that it is hopeless. Signed-off-by: Len Brown <len.brown@intel.com>
2009-02-06ACPI: delete CPU_IDLE=n codeLen Brown
CPU_IDLE=y has been default for ACPI=y since Nov-2007, and has shipped in many distributions since then. Here we delete the CPU_IDLE=n ACPI idle code, since nobody should be using it, and we don't want to maintain two versions. Signed-off-by: Len Brown <len.brown@intel.com>
2009-02-05netlink: change return-value logic of netlink_broadcast()Pablo Neira Ayuso
Currently, netlink_broadcast() reports errors to the caller if no messages at all were delivered: 1) If, at least, one message has been delivered correctly, returns 0. 2) Otherwise, if no messages at all were delivered due to skb_clone() failure, return -ENOBUFS. 3) Otherwise, if there are no listeners, return -ESRCH. With this patch, the caller knows if the delivery of any of the messages to the listeners have failed: 1) If it fails to deliver any message (for whatever reason), return -ENOBUFS. 2) Otherwise, if all messages were delivered OK, returns 0. 3) Otherwise, if no listeners, return -ESRCH. In the current ctnetlink code and in Netfilter in general, we can add reliable logging and connection tracking event delivery by dropping the packets whose events were not successfully delivered over Netlink. Of course, this option would be settable via /proc as this approach reduces performance (in terms of filtered connections per seconds by a stateful firewall) but providing reliable logging and event delivery (for conntrackd) in return. This patch also changes some clients of netlink_broadcast() that may report ENOBUFS errors via printk. This error handling is not of any help. Instead, the userspace daemons that are listening to those netlink messages should resync themselves with the kernel-side if they hit ENOBUFS. BTW, netlink_broadcast() clients include those that call cn_netlink_send(), nlmsg_multicast() and genlmsg_multicast() since they internally call netlink_broadcast() and return its error value. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-04ACPI: cpufreq: Remove deprecated /proc/acpi/processor/../performance proc ↵Thomas Renninger
entries They were long enough set deprecated... Update Documentation/cpu-freq/users-guide.txt: The deprecated files listed there seen not to exist for some time anymore already. Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2009-02-03ACPI: make some IO ports off-limits to AMLLen Brown
ACPICA exports acpi_os_validate_address() so the OS can prevent BIOS AML from accessing specified addresses. Start using this interface to prevent AML from accessing some well known IO addresses that the OS "owns". Signed-off-by: Len Brown <len.brown@intel.com>
2009-02-03ACPICA: add debug dump of BIOS _OSI stringsLen Brown
on boot, print out the OSI strings the BIOS uses to query the OS. To see this output... build with CONFIG_ACPI_DEBUG boot with "acpi.debug_level=4" (ACPI_LV_INFO) (enabled by default) and "acpi.debug_level=1" (ACPI_UTILITIES) (default is 0) example output: ACPI: BIOS _OSI(Windows 2001) supported ACPI: BIOS _OSI(Windows 2001 SP1) supported ACPI: BIOS _OSI(Windows 2001 SP2) supported ACPI: BIOS _OSI(Windows 2006) supported ACPI: BIOS _OSI(Linux) not-supported ACPI: BIOS _OSI(FreeBSD) not-supported Signed-off-by: Len Brown <len.brown@intel.com>
2009-02-02ACPI: proc_dir_entry 'video/VGA' already registeredZhao Yakui
eliminate the duplicate the name of "VGA" http://bugzilla.kernel.org/show_bug.cgi?id=12514 Signed-off-by: Zhao Yakui <yakui.zhao@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-02-02ACPI: Skip the first two elements in the _BCL packageZhao Yakui
According to the Spec the first two elements in the _BCL package won't be regarded as the available brightness level. The first is the brightness when full power is connected to the box(It means that the AC adapter is plugged). The second is the brightness level when the box is on battery. If the first two elements are still used while finding the next brightness level, it will fall back to the lowest level when keeping on pressing hotkey. (On some boxes the brightness will be changed twice when hotkey is pressed once. One is in the ACPI video driver. The other is changed by sys I/F. In the ACPI video driver the first two elements will be used while changing the brightness. But the first two elements is skipped while using sys I/F. In such case there exists the inconsistency). So he first two elements had better be skipped while showing the available brightness or finding the next brightness level. http://bugzilla.kernel.org/show_bug.cgi?id=12450 Signed-off-by: Zhao Yakui <yakui.zhao@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-01-28ACPI: remove BM_RLD access from idle entry pathLen Brown
It is true that BM_RLD needs to be set to enable bus master activity to wake an older chipset (eg PIIX4) from C3. This is contrary to the erroneous wording the ACPI 2.0, 3.0 specifications that suggests that BM_RLD is an indicator rather than a control bit. ACPI 1.0's correct wording should be restored in ACPI 4.0: http://www.acpica.org/bugzilla/show_bug.cgi?id=689 But the kernel should not have to clear BM_RLD when entering a non C3-type state just to set it again when entering a C3-type C-state. We should be able to set BM_RLD at boot time and leave it alone -- removing the overhead of accessing this IO register from the idle entry path. Signed-off-by: Len Brown <len.brown@intel.com>
2009-01-28ACPI: remove locking from PM1x_STS register readsLen Brown
PM1a_STS and PM1b_STS are twins that get OR'd together on reads, and all writes are repeated to both. The fields in PM1x_STS are single bits only, there are no multi-bit fields. So it is not necessary to lock PM1x_STS reads against writes because it is impossible to read an intermediate value of a single bit. It will either be 0 or 1, even if a write is in progress during the read. Reads are asynchronous to writes no matter if a lock is used or not. Signed-off-by: Len Brown <len.brown@intel.com>
2009-01-17ACPI: Fix crash on ASUS laptopsTero Roponen
This patch fixes the crash I experienced in 2.6.29-rc2. Tested on ASUS M50vm. Signed-off-by: Tero Roponen <tero.roponen@gmail.com> Acked-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2009-01-16ACPI suspend: Fix compilation warnings in drivers/acpi/sleep.cRafael J. Wysocki
Fix two compilation warnings in drivers/acpi/sleep.c, one triggered by unsetting CONFIG_SUSPEND and the other triggered by unsetting CONFIG_HIBERNATION, by moving some code under the appropriate #ifdefs . Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2009-01-16Merge branch 'misc' into releaseLen Brown
2009-01-16Merge branches 'bugzilla-11884' and 'bugzilla-8544' into releaseLen Brown
2009-01-16ACPI: rename main.c to sleep.cLen Brown
2009-01-16thermal fixup for broken BIOS which has invalid trip points.Zhang Rui
ACPI thermal driver only re-evaluate VALID trip points. For the broken BIOS show in http://bugzilla.kernel.org/show_bug.cgi?id=8544 the active[0] is set to invalid at boot time and it will not be re-evaluated again. We can still get a single warning message at boot time. http://marc.info/?l=linux-kernel&m=120496222629983&w=2 http://bugzilla.kernel.org/show_bug.cgi?id=12203 Signed-off-by: Zhang Rui<rui.zhang@intel.com> Tested-by: Márton Németh <nm127@freemail.hu> Signed-off-by: Len Brown <len.brown@intel.com>
2009-01-16ACPI: EC: Don't trust ECDT tables from ASUSAlexey Starikovskiy
http://bugzilla.kernel.org/show_bug.cgi?id=9399 http://bugzilla.kernel.org/show_bug.cgi?id=11880 Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2009-01-16ACPI: EC: Limit workaround for ASUS notebooks even moreAlexey Starikovskiy
References: http://bugzilla.kernel.org/show_bug.cgi?id=11884 Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2009-01-09Merge branch 'drivers-platform' into releaseLen Brown
Conflicts: drivers/misc/Kconfig Signed-off-by: Len Brown <len.brown@intel.com>
