path: root/drivers/acpi
2010-01-06ACPI: Use the return result of ACPI lid notifier chain correctlyZhao Yakui
commit 13c199c0d0cf78b27592991129fb8cbcfc5164de upstream. On some laptops it will return NOTIFY_OK(non-zero) when calling the ACPI LID notifier. Then it is used as the result of ACPI LID resume function, which will complain the following warning message in course of suspend/resume: >PM: Device PNP0C0D:00 failed to resume: error 1 This patch is to eliminate the above warning message. http://bugzilla.kernel.org/show_bug.cgi?id=14782 Signed-off-by: Zhao Yakui <yakui.zhao@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-06ACPI: EC: Fix MSI DMI detectionAlexey Starikovskiy
commit 55b313f249e11b815fd0be51869f166aaf368f44 upstream. MSI strings should be ORed, not ANDed. Reference: http://bugzilla.kernel.org/show_bug.cgi?id=14446 Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-11-25Merge branch 'thinkpad-2.6.32' into releaseLen Brown
2009-11-25Merge branch 'bugzilla-14379' into releaseLen Brown
2009-11-24ACPI: Add Thinkpad T400, T500 to OSI(Linux) white-listJerone Young
acpi_osi=Linux helps the mute button work properly by sending Linux a mute key press. http://bugzilla.kernel.org/show_bug.cgi?id=13934 Signed-off-by: Jerone Young <jerone.young@canonical.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-11-24ACPICA: Silence the warning about _BIF returning the bufferAlexey Starikovskiy
_BIF was returning buffer instead of a string since day 1 of ACPI. Adding a warning for that is noble, but people don't like when someone cries wolf in a production system. Reference: http://bugzilla.kernel.org/show_bug.cgi?id=14379 Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2009-11-23ACPI: DMI init_set_sci_en_on_resume for HP-Compaq C700Len Brown
...else ACPI thermal controls fail after resume. http://bugzilla.kernel.org/show_bug.cgi?id=13745 Signed-off-by: Len Brown <len.brown@intel.com>
2009-11-06Merge branch 'bugzilla-13449' into releaseLen Brown
2009-11-05ACPI: sleep: another HP/Compaq DMI entries for init_set_sci_en_on_resumeVaibhav Verma
2009-11-05ACPI: add DMI entry for SCI_EN resume quirk on HP dv4Gustavo Maciel Dias Vieira
Fixes the missing battery on sleep problem for yet another HP laptop ("HP Pavilion dv4"). Fixes: http://bugzilla.kernel.org/show_bug.cgi?id=13449 Signed-off-by: Gustavo Maciel Dias Vieira <gustavo@sagui.org> Signed-off-by: Len Brown <len.brown@intel.com>
2009-11-05Merge branches 'misc', 'eeepc-laptop' and 'bugzilla-14445' into releaseLen Brown
2009-11-05ACPI: Move dereference after NULL testJulia Lawall
If the NULL test on pr is needed, then the dereference should be after the NULL test. A simplified version of the semantic match that detects this problem is as follows (http://coccinelle.lip6.fr/): // <smpl> @match exists@ expression x, E; identifier fld; @@ * x->fld ... when != \(x = E\|&x\) * x == NULL // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2009-11-05ACPICA: avoid "Info: mapping multiple BARs. Your kernel is fine."Bob Moore
Ensure that memory mappings created for operation regions do not cross page boundaries. Crossing a page boundary while mapping regions can cause warnings if the pages have different attributes. Such regions are probably BIOS bugs, and this is the workaround. http://bugzilla.kernel.org/show_bug.cgi?id=14445 [Kernel summit hacking hour] Signed-off-by: Bob Moore <robert.moore@intel.com> Acked-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-11-05ACPI: add __cpuinit to acpi_processor_add()Rakib Mullick
Annote acpi_processor_add with cpuinit since it calls a cpuinit function acpi_processor_power_init and fixes a section mismatch warning. We were warned by the following warning: LD drivers/acpi/processor.o WARNING: drivers/acpi/processor.o(.text+0x1829): Section mismatch in reference from the function acpi_processor_add() to the function .cpuinit.text:acpi_processor_power_init() The function acpi_processor_add() references the function __cpuinit acpi_processor_power_init(). This is often because acpi_processor_add lacks a __cpuinit annotation or the annotation of acpi_processor_power_init is wrong. Signed-off-by: Rakib Mullick <rakib.mullick@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2009-11-05acpi-power-meter: Don't leak ACPI error codes to userspaceDarrick J. Wong
If the ACPI methods return an error code, we must return -EINVAL to userspace to flag the error. Right now we pass the (positive) number right through, which causes echo to keep writing bogus values. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2009-10-28ACPI: clean up video.c boundary checks and typesArjan van de Ven
proc.c and video.c are a bit sloppy around types and style, confusing gcc for a new feature that'll be in 2.6.33 and will cause a warning on the current code. This patch changes if (foo + 1 > sizeof bar) into if (foo >= sizeof(bar)) which is more kernel-style. it also changes a variable in proc.c to unsigned; it gets assigned a value from an unsigned type, and is then only compared for > not for negative, so using unsigned is just outright the right type Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-10-15Merge branch 'misc' into releaseLen Brown
2009-10-15Merge branch 'launchpad-333386' into releaseLen Brown
2009-10-13ACPI button: don't try to use a non-existent lid deviceJesse Barnes
If a call comes in to check the lid state but there's no lid device present, we should return -ENODEV. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Len Brown <len.brown@intel.com>
2009-10-13ACPI: video: Loosen strictness of video bus detection codeStefan Bader
BugLink: http://bugs.launchpad.net/bugs/333386 Currently a video bus device must (beside other criteria) define _DOD and _DOS methods to be considered a video device. Some broken BIOSes prevented working backlight control by only defining both for one (non-existing bus) and only _DOD for the rest. With this patch in place the other bus definitions were considered too and backlight control started to work again. Signed-off-by: Stefan Bader <stefan.bader@canonical.com> Acked-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-10-13ACPI / PCI: Fix NULL pointer dereference in acpi_get_pci_dev() (rev. 2)Rafael J. Wysocki
acpi_get_pci_dev() may be called for a non-PCI device, in which case it should return NULL. However, it assumes that every handle it finds in the ACPI CA name space, between given device handle and the PCI root bridge handle, corresponds to a PCI-to-PCI bridge with an existing secondary bus. For this reason, when it finds a struct pci_dev object corresponding to one of them, it doesn't check if its 'subordinate' field is a valid pointer. This obviously leads to a NULL pointer dereference if acpi_get_pci_dev() is called for a non-PCI device with a PCI parent which is not a bridge. To fix this issue make acpi_get_pci_dev() check if pdev->subordinate is not NULL for every device it finds on the path between the root bridge and the device it's supposed to get to and return NULL if the "target" device cannot be found. http://bugzilla.kernel.org/show_bug.cgi?id=14129 (worked in 2.6.30, regression in 2.6.31) Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reported-by: Danny Feng <dfeng@redhat.com> Reviewed-by: Alex Chiang <achiang@hp.com> Tested-by: chepioq <chepioq@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-10-09ACPI: Kconfig, fix proc aggregator textJiri Slaby
Fix two typos in the Kconfig text about ACPI_PROCESSOR_AGGREGATOR. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-10-06ACPI: add AC/DC notifierMark Langsdorf
Add an ACPI event notifier for AC/DC connect/disconnect events. Signed-off-by: Mark Langsdorf <mark.langsdorf@amd.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-10-04Merge branch 'acpi-pad' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'acpi-pad' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: acpi_pad: build only on X86 ACPI: create Processor Aggregator Device driver Fixup trivial conflicts in MAINTAINERS file.
2009-10-03Merge branch 'misc' into releaseLen Brown
2009-10-03Merge branch 'bugzilla-14081' into releaseLen Brown
2009-10-03ACPI: EC: Don't parse DSDT for EC early init on CompalAlexey Starikovskiy
Compal DSDT breaks if scanned early, while we need early scan for almost all ASUS machines. Safest workaround seems to be to continue do an early scan for all machines, but this Compal model. http://bugzilla.kernel.org/show_bug.cgi?id=14086 Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2009-10-03ACPI: EC: Rewrite DMI checksAlexey Starikovskiy
Use dmi_check_system() for DMI matching. Don't use string "Notebook" for matching MSI hardware. http://bugzilla.kernel.org/show_bug.cgi?id=14081 Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2009-10-03ACPI: dock: fix "sibiling" typoAlex Chiang
Crossword clues as haikus: Snakes from the same brood fighting Jackson on a plane? sibilant siblings I guess Will Shortz's job is still secure. Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-10-03ACPI: kill overly verbose "throttling states" log messagesRoland Dreier
I was recently lucky enough to get a 64-CPU system. The processors actually have T-states, so my kernel log ends up with 64 lines like: ACPI: Processor [CPU0] (supports xx throttling states) This is pretty useless clutter because - this info is already available after boot from /proc/acpi/processor/CPUnn/throttling - there's also an ACPI_DEBUG_PRINT() in processor_throttling.c that gives the same info on boot for anyone who *really* cares. So just delete the code that prints the throttling states in processor_core.c. Signed-off-by: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2009-10-03ACPI: Fix bound checks for copy_from_user in the acpi /proc codeArjan van de Ven
The ACPI /proc write() code takes an unsigned length argument like any write() function, but then assigned it to a *signed* integer called "len". Only after this is a sanity check for len done to make it not larger than 4. Due to the type change a len < 0 is in principle also possible; this patch adds a check for this. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-10-02Merge branches 'sony-laptop', 'bugzilla-14247' and 'bugzilla-14271' into releaseLen Brown
2009-10-02ACPI: fix bus scanning memory leaksBjorn Helgaas
Free an acpi_get_object_info() buffer when we're finished. Skip the acpi_get_name() altogether -- it was only used for a printk that was really just for debug anyway. http://bugzilla.kernel.org/show_bug.cgi?id=14271 Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Reported-and-tested-by: Zdenek Kabelac <zdenek.kabelac@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-10-02ACPI: EC: Restart command even if no interrupts from ECAlexey Starikovskiy
EC may forget a command without sending any "reset" interrupt, thus we need to lessen the requirement for transaction restart. Reference: http://bugzilla.kernel.org/show_bug.cgi?id=14247 Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2009-10-01const: constify remaining file_operationsAlexey Dobriyan
[akpm@linux-foundation.org: fix KVM] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-27ACPI: kill "unused variable ‘i’" warningLinus Torvalds
Commit 3d5b6fb47a8e68fa311ca2c3447e7f8a7c3a9cf3 ("ACPI: Kill overly verbose "power state" log messages") removed the actual use of this variable, but didn't remove the variable itself, resulting in build warnings like drivers/acpi/processor_idle.c: In function ‘acpi_processor_power_init’: drivers/acpi/processor_idle.c:1169: warning: unused variable ‘i’ Just get rid of the now unused variable. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-27ACPI: Kill overly verbose "power state" log messagesRoland Dreier
I was recently lucky enough to get a 64-CPU system, so my kernel log ends up with 64 lines like: ACPI: CPU0 (power states: C1[C1] C2[C3]) This is pretty useless clutter because this info is already available after boot from both /sys/devices/system/cpu/cpu*/cpuidle/state?/ as well as /proc/acpi/processor/CPU*/power. So just delete the code that prints the C-states in processor_idle.c. Signed-off-by: Roland Dreier <rolandd@cisco.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-27ACPI: Clarify resource conflict messageJean Delvare
The message "ACPI: Device needs an ACPI driver" is misleading. The device _may_ need an ACPI driver, if the BIOS implemented a custom API for the device in question (which, AFAIK, can't be checked.) If not, then either a generic ACPI driver may be used (for example "thermal"), or nothing can be done (other than a white list). I propose to reword the message to: ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver which I think is more correct. Comments and suggestions welcome. I also added a message warning about possible problems and system instability when users pass acpi_enforce_resources=lax, as suggested by Len. Signed-off-by: Jean Delvare <jdelvare@suse.de> Cc: Thomas Renninger <trenn@suse.de> Cc: Alan Jenkins <sourcejedi.lkml@googlemail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-27acpi_pad: build only on X86Len Brown
X86_FEATURE_MWAIT doesn't exist on ia64... Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-26Merge branch 'for-linus' of git://git.o-hand.com/linux-rpurdie-backlightLinus Torvalds
* 'for-linus' of git://git.o-hand.com/linux-rpurdie-backlight: backlight: new driver for ADP5520/ADP5501 MFD PMICs backlight: extend event support to also support poll() backlight/eeepc-laptop: Update the backlight state when we change brightness backlight/acpi: Update the backlight state when we change brightness backlight: Allow drivers to update the core, and generate events on changes backlight: switch to da903x driver to dev_pm_ops backlight: Add support for the Avionic Design Xanthos backlight device. backlight: spi driver for LMS283GF05 LCD backlight: move hp680-bl's probe function to .devinit.text backlight: Add support for new Apple machines. backlight: mbp_nvidia_bl: add support for MacBookAir 1,1 backlight: Add WM831x backlight driver Trivial conflicts due to '#ifdef CONFIG_PM' differences in drivers/video/backlight/da903x_bl.c
2009-09-25ACPI: simplify building device HID/CID listBjorn Helgaas
Minor code cleanup, no functional change. Instead of remembering what HIDs & CIDs to add later, just add them immediately. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-25ACPI: remove acpi_device_uid() and related stuffBjorn Helgaas
Nobody uses acpi_device_uid(), so this patch removes it. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-25ACPI: remove acpi_device.flags.hardware_idBjorn Helgaas
Every acpi_device has at least one ID (if there's no _HID or _CID, we give it a synthetic or default ID). So there's no longer a need to check whether an ID exists; we can just use it. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-25ACPI: remove acpi_device.flags.compatible_idsBjorn Helgaas
We now keep a single list of IDs that includes both the _HID and any _CIDs. We no longer need to keep track of whether the device has a _CID. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-25ACPI: maintain a single list of _HID and _CID IDsBjorn Helgaas
There's no need to treat _HID and _CID differently. Keeping them in a single list makes code that uses the IDs a little simpler because it can just traverse the list rather than checking "do we have a HID?", "do we have any CIDs?" Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Reviewed-by: Alex Chiang <achiang@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-25ACPI: make sure every acpi_device has an IDBjorn Helgaas
This makes sure every acpi_device has at least one ID. If we build an acpi_device for a namespace node with no _HID or _CID, we sometimes synthesize an ID like "LNXCPU" or "LNXVIDEO". If we don't even have that, give it a default "device" ID. Note that this means things like: /sys/devices/LNXSYSTM:00/LNXSYBUS:00/HWP0001:00/HWP0002:04/device:00 (a PCI slot SxFy device) will have "hid" and "modprobe" entries, where they didn't before. These aren't very useful (a HID of "device" doesn't tell you what *kind* of device it is, so it doesn't help find a driver), but I don't think they're harmful. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-25ACPI: use acpi_device_hid() when possibleBjorn Helgaas
Use acpi_device_hid() rather than accessing acpi_device.pnp.hardware_id directly. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-25ACPI: fix synthetic HID for \_SB_Bjorn Helgaas
This makes \_SB_ show up as /sys/devices/LNXSYSTM:00/LNXSYBUS:00 rather than "device:00". This has been broken for a loooong time (at least since 2.6.13) because device->parent is an acpi_device pointer, not a handle. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-25ACPI: handle re-enumeration, when acpi_devices might already existBjorn Helgaas
acpi_bus_scan() traverses the namespace to enumerate devices and uses acpi_add_single_object() to create acpi_devices. When the platform notifies us of a hot-plug event, we need to traverse part of the namespace again to figure out what appeared or disappeared. (We don't yet call acpi_bus_scan() during hot-plug, but I plan to do that in the future.) This patch makes acpi_add_single_object() notice when we already have an acpi_device, so we don't need to make a new one. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-25ACPI: factor out device type and status checkingBjorn Helgaas
This patch adds acpi_bus_type_and_status(), which determines the type of the object and whether we want to build an acpi_device for it. If it is acpi_device-worthy, it returns the type and the device's current status. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
