path: root/drivers/acpi/video.c
2013-11-15ACPI / video: clean up DMI table for initial black screen problemAaron Lu
With commit 2c62333a408f "ACPI / video: Quirk initial backlight level 0" we do not need to have the following systems in DMI table, so remove them. HP Pavilion m4, HP 1000 Notebook PC, HP Pavilion g6 Notebook PC, HP Pavilion dm4, Fujitsu E753, HP Folio 13-2000. With this change, the use_bios_initial_backlight module parameter is no longer needed and thus removed. Signed-off-by: Aaron Lu <aaron.lu@intel.com> Tested-by: Alex Hung <alex.hung@canonical.com> # for HP 1000 Notebook PC Tested-by: Gustavo Maciel Dias Vieira <gustavo@sagui.org> # for HP Pavilion dm4 Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-11-07Revert "ACPI / video: Ignore BIOS initial backlight value for HP 250 G1"Aaron Lu
This reverts commit e37f14a5fb85522f3bbf88ece6134c4e610ed598. It turned out other systems also share the same problem with bug 63111 so I made a patch to catch initial brightness level 0 problem. With that patch applied, we do not need to place HP 250 G1 in DMI table. References: https://bugzilla.kernel.org/show_bug.cgi?id=63111 Signed-off-by: Aaron Lu <aaron.lu@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-11-07ACPI / video: Quirk initial backlight level 0Aaron Lu
Some firmware doesn't initialize initial backlight level to a proper value and _BQC will return 0 on first time evaluation. We used to be able to detect such incorrect value with our code logic, as value 0 normally isn't a valid value in _BCL. But with the introduction of Win8, firmware begins to fill _BCL with values from 0 to 100, now 0 becomes a valid value but that value will make user's screen black. This patch test initial _BQC for value 0, if such a value is returned, do not use it. References: https://bugzilla.kernel.org/show_bug.cgi?id=64031 References: https://bugzilla.kernel.org/show_bug.cgi?id=61231 References: https://bugzilla.kernel.org/show_bug.cgi?id=63111 Reported-by: Qingshuai Tian <qingshuai.tian@intel.com> Tested-by: Aaron Lu <aaron.lu@intel.com> # on "Idealpad u330p" Reported-and-tested-by: <erno@iki.fi> # on "Acer Aspire V5-573G" Reported-and-tested-by: Kirill Tkhai <tkhai@yandex.ru> # on "HP 250 G1" Signed-off-by: Aaron Lu <aaron.lu@intel.com> Cc: All applicable <stable@vger.kernel.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-11-07ACPI / video: Fix initial level validity testAaron Lu
When testing if the firmware's initial value is valid, we should use the corrected level value instead of the raw value returned from firmware. Signed-off-by: Aaron Lu <aaron.lu@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-10-25ACPI / video: Ignore BIOS initial backlight value for HP 250 G1Kirill Tkhai
On HP 250 G1 laptops, BIOS reports minimum backlight on boot and causes backlight to dim completely. This ignores the initial backlight values and set to max brightness. References: https://bugzilla.kernel.org/show_bug.cgi?id=63111 Signed-off-by: Kirill Tkhai <tkhai@yandex.ru> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-10-16ACPI / video: Do not register backlight if win8 and native interface existsAaron Lu
According to Matthew Garrett, "Windows 8 leaves backlight control up to individual graphics drivers rather than making ACPI calls itself. There's plenty of evidence to suggest that the Intel driver for Windows [8] doesn't use the ACPI interface, including the fact that it's broken on a bunch of machines when the OS claims to support Windows 8. The simplest thing to do appears to be to disable the ACPI backlight interface on these systems". So for Win8 systems, if there is native backlight control interface registered by GPU driver, ACPI video does not need to register its own. Since there are systems that don't work well with this approach, a parameter for video module named use_native_backlight is introduced and has the value of false by default. For users who have a broken ACPI video backlight interface, video.use_native_backlight=1 is needed in kernel cmdline. Signed-off-by: Aaron Lu <aaron.lu@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-10-16ACPI / video: seperate backlight control and event interfaceAaron Lu
The backlight control and event delivery functionality provided by ACPI video module is mixed together and registered all during video device enumeration time. As a result, the two functionality are also removed together on module unload time or by the acpi_video_unregister function. The two functionalities are actually independent and one may be useful while the other one may be broken, so it is desirable to seperate the two functionalities such that it is clear and easy to disable one functionality without affecting the other one. APIs to selectively remove backlight control interface and/or event delivery functionality can be easily added once needed. Signed-off-by: Aaron Lu <aaron.lu@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-08-27Merge branch 'acpi-video'Rafael J. Wysocki
* acpi-video: ACPI: blacklist win8 OSI for buggy laptops ACPI: blacklist win8 OSI for ASUS Zenbook Prime UX31A ACPI / video: drop unused fields from struct acpi_video_brightness_flags ACPI / video: remove unnecessary type casting ACPI / video: trivial style cleanups ACPI / video: trivial costmetic cleanups Conflicts: drivers/acpi/video.c
2013-08-27Merge branch 'acpi-assorted'Rafael J. Wysocki
* acpi-assorted: ACPI / osl: Kill macro INVALID_TABLE(). earlycpio.c: Fix the confusing comment of find_cpio_data(). ACPI / x86: Print Hot-Pluggable Field in SRAT. ACPI / thermal: Use THERMAL_TRIPS_NONE macro to replace number ACPI / thermal: Remove unused macros in the driver/acpi/thermal.c ACPI / thermal: Remove the unused lock of struct acpi_thermal ACPI / osl: Fix osi_setup_entries[] __initdata attribute location ACPI / numa: Fix __init attribute location in slit_valid() ACPI / dock: Fix __init attribute location in find_dock_and_bay() ACPI / Sleep: Fix incorrect placement of __initdata ACPI / processor: Fix incorrect placement of __initdata ACPI / EC: Fix incorrect placement of __initdata ACPI / scan: Drop unnecessary label from acpi_create_platform_device() ACPI: Move acpi_bus_get_device() from bus.c to scan.c ACPI / scan: Allow platform device creation without any IO resources ACPI: Cleanup sparse warning on acpi_os_initialize1() platform / thinkpad: Remove deprecated hotkey_report_mode parameter ACPI: Remove the old /proc/acpi/event interface
2013-08-27Merge branch 'acpi-cleanup'Rafael J. Wysocki
* acpi-cleanup: (21 commits) ACPI / dock: fix error return code in dock_add() ACPI / dock: Drop unnecessary local variable from dock_add() ACPI / dock / PCI: Drop ACPI dock notifier chain ACPI / dock: Do not check CONFIG_ACPI_DOCK_MODULE ACPI / dock: Do not leak memory on falilures to add a dock station ACPI: Drop ACPI bus notifier call chain ACPI / dock: Rework the handling of notifications ACPI / dock: Simplify dock_init_hotplug() and dock_release_hotplug() ACPI / dock: Walk list in reverse order during removal of devices ACPI / dock: Rework and simplify find_dock_devices() ACPI / dock: Drop the hp_lock mutex from struct dock_station ACPI: simplify acpiphp driver with new helper functions ACPI: simplify dock driver with new helper functions ACPI: Export acpi_(bay)|(dock)_match() from scan.c ACPI: introduce two helper functions for _EJ0 and _LCK ACPI: introduce helper function acpi_execute_simple_method() ACPI: introduce helper function acpi_has_method() ACPI / dock: simplify dock_create_acpi_device() ACPI / dock: mark initialization functions with __init ACPI / dock: drop redundant spin lock in dock station object ...
2013-08-22Revert "ACPI / video: Always call acpi_video_init_brightness() on init"Rafael J. Wysocki
Revert commit c04c697 (ACPI / video: Always call acpi_video_init_brightness() on init), because it breaks eDP backlight at 1920x1080 on Acer Aspire S3 for Trevor Bortins. References: https://bugs.freedesktop.org/show_bug.cgi?id=68355 Reported-and-bisected-by: Trevor Bortins <enabfluw@gmail.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-08-14Merge back earlier 'acpi-assorted' materialRafael J. Wysocki
2013-08-04ACPI / video: improve quirk check in acpi_video_bqc_quirk()Felipe Contreras
If the _BCL package ordering is descending, the first level (br->levels[2]) is likely to be 0, and if the number of levels matches the number of steps, we might confuse a returned level to mean the index. For example: current_level = max_level = 100 test_level = 0 returned level = 100 In this case 100 means the level, not the index, and _BCM failed. Still, if the _BCL package ordering is descending, the index of level 0 is also 100, so we assume _BQC is indexed, when it's not. This causes all _BQC calls to return bogus values causing weird behavior from the user's perspective. For example: xbacklight -set 10; xbacklight -set 20; would flash to 90% and then slowly down to the desired level (20). The solution is simple; test anything other than the first level (e.g. 1). [rjw: Changelog] Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-08-03ACPI / video: drop unused fields from struct acpi_video_brightness_flagsFelipe Contreras
The _BCM_use_index and _BCL_use_index fields in struct acpi_video_brightness_flags are not used, so drop them. [rjw: Changelog] Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-08-03ACPI / video: remove unnecessary type castingFelipe Contreras
Remove type casting from assignments involving void pointers in two places in drivers/acpi/video.c. [rjw: Changelog] Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com> Reviewed-by: Aaron Lu <aaron.lu@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-08-03ACPI / video: trivial style cleanupsFelipe Contreras
Fix several coding style defects in drivers/acpi/video.c: - Initialization of static variables. - Whitespace in expressions, variable definitions, function headers, etc. - Positioning of labels. - Braces around single statements. [rjw: Changelog] Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-08-03ACPI / video: trivial costmetic cleanupsFelipe Contreras
Fix whitespace and comments in several places in drivers/acpi/video.c. [rjw: Changelog] Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-07-26Revert "ACPI / video / i915: No ACPI backlight if firmware expects Windows 8"Rafael J. Wysocki
We attempted to address a regression introduced by commit a57f7f9 (ACPICA: Add Windows8/Server2012 string for _OSI method.) after which ACPI video backlight support doesn't work on a number of systems, because the relevant AML methods in the ACPI tables in their BIOSes become useless after the BIOS has been told that the OS is compatible with Windows 8. That problem is tracked by the bug entry at: https://bugzilla.kernel.org/show_bug.cgi?id=51231 Commit 8c5bd7a (ACPI / video / i915: No ACPI backlight if firmware expects Windows 8) introduced for this purpose essentially prevented the ACPI backlight support from being used if the BIOS had been told that the OS was compatible with Windows 8 and the i915 driver was loaded, in which case the backlight would always be handled by i915. Unfortunately, however, that turned out to cause problems with backlight to appear on multiple systems with symptoms indicating that i915 was unable to control the backlight on those systems as expected. For this reason, revert commit 8c5bd7a, but leave the function acpi_video_backlight_quirks() introduced by it, because another commit on top of it uses that function. References: https://lkml.org/lkml/2013/7/21/119 References: https://lkml.org/lkml/2013/7/22/261 References: https://lkml.org/lkml/2013/7/23/429 References: https://lkml.org/lkml/2013/7/23/459 References: https://lkml.org/lkml/2013/7/23/81 References: https://lkml.org/lkml/2013/7/24/27 Reported-and-tested-by: James Hogan <james@albanarts.com> Reported-and-tested-by: Kamal Mostafa <kamal@canonical.com> Reported-and-tested-by: Jörg Otte <jrg.otte@gmail.com> Reported-and-tested-by: Steven Newbury <steve@snewbury.org.uk> Reported-by: Martin Steigerwald <Martin@lichtvoll.de> Reported-by: Kalle Valo <kvalo@adurom.com> Tested-by: Joerg Platte <jplatte@naasa.net> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-07-21Merge tag 'acpi-video-3.11' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI video support fixes from Rafael Wysocki: "I'm sending a separate pull request for this as it may be somewhat controversial. The breakage addressed here is not really new and the fixes may not satisfy all users of the affected systems, but we've had so much back and forth dance in this area over the last several weeks that I think it's time to actually make some progress. The source of the problem is that about a year ago we started to tell BIOSes that we're compatible with Windows 8, which we really need to do, because some systems shipping with Windows 8 are tested with it and nothing else, so if we tell their BIOSes that we aren't compatible with Windows 8, we expose our users to untested BIOS/AML code paths. However, as it turns out, some Windows 8-specific AML code paths are not tested either, because Windows 8 actually doesn't use the ACPI methods containing them, so if we declare Windows 8 compatibility and attempt to use those ACPI methods, things break. That occurs mostly in the backlight support area where in particular the _BCM and _BQC methods are plain unusable on some systems if the OS declares Windows 8 compatibility. [ The additional twist is that they actually become usable if the OS says it is not compatible with Windows 8, but that may cause problems to show up elsewhere ] Investigation carried out by Matthew Garrett indicates that what Windows 8 does about backlight is to leave backlight control up to individual graphics drivers. At least there's evidence that it does that if the Intel graphics driver is used, so we've decided to follow Windows 8 in that respect and allow i915 to control backlight (Daniel likes that part). The first commit from Aaron Lu makes ACPICA export the variable from which we can infer whether or not the BIOS believes that we are compatible with Windows 8. The second commit from Matthew Garrett prepares the ACPI video driver by making it initialize the ACPI backlight even if it is not going to be used afterward (that is needed for backlight control to work on Thinkpads). The third commit implements the actual workaround making i915 take over backlight control if the firmware thinks it's dealing with Windows 8 and is based on the work of multiple developers, including Matthew Garrett, Chun-Yi Lee, Seth Forshee, and Aaron Lu. The final commit from Aaron Lu makes us follow Windows 8 by informing the firmware through the _DOS method that it should not carry out automatic brightness changes, so that brightness can be controlled by GUI. Hopefully, this approach will allow us to avoid using blacklists of systems that should not declare Windows 8 compatibility just to avoid backlight control problems in the future. - Change from Aaron Lu makes ACPICA export a variable which can be used by driver code to determine whether or not the BIOS believes that we are compatible with Windows 8. - Change from Matthew Garrett makes the ACPI video driver initialize the ACPI backlight even if it is not going to be used afterward (that is needed for backlight control to work on Thinkpads). - Fix from Rafael J Wysocki implements Windows 8 backlight support workaround making i915 take over bakclight control if the firmware thinks it's dealing with Windows 8. Based on the work of multiple developers including Matthew Garrett, Chun-Yi Lee, Seth Forshee, and Aaron Lu. - Fix from Aaron Lu makes the kernel follow Windows 8 by informing the firmware through the _DOS method that it should not carry out automatic brightness changes, so that brightness can be controlled by GUI" * tag 'acpi-video-3.11' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: ACPI / video: no automatic brightness changes by win8-compatible firmware ACPI / video / i915: No ACPI backlight if firmware expects Windows 8 ACPI / video: Always call acpi_video_init_brightness() on init ACPICA: expose OSI version
2013-07-18ACPI / video: ignore BIOS initial backlight value for Fujitsu E753Lan Tianyu
The BIOS of FUjitsu E753 reports an incorrect initial backlight value for WIN8 compatible OS, causing backlight to be dark during startup. This change causes the incorrect initial value from BIOS to be ignored. References: https://bugzilla.kernel.org/show_bug.cgi?id=60161 Reported-and-tested-by: Jan Hinnerk Stosch <janhinnerk.stosch@gmail.com> Signed-off-by: Lan Tianyu <tianyu.lan@intel.com> Cc: 3.7+ <stable@vger.kernel.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-07-18ACPI / video: no automatic brightness changes by win8-compatible firmwareAaron Lu
Starting from win8, MS backlight control driver will set bit 2 of the parameter of control method _DOS, to inform firmware it should not perform any automatic brightness changes. This mostly affects hotkey notification deliver - if we do not set this bit, on hotkey press, firmware may choose to adjust brightness level instead of sending out notification and doing nothing. So this patch sets bit 2 when calling _DOS so that GUIs can show the notification window on hotkey press. This behavior change is only necessary for win8 systems. The MS document on win8 backlight control is here: http://msdn.microsoft.com/en-US/library/windows/hardware/jj159305 References: https://bugzilla.kernel.org/show_bug.cgi?id=52951 References: https://bugzilla.kernel.org/show_bug.cgi?id=56711 Reported-by: Micael Dias <kam1kaz3@gmail.com> Reported-by: Dan Garton <dan.garton@gmail.com> Reported-by: Bob Ziuchkovski <bob.ziuchkovski@gmail.com> Signed-off-by: Aaron Lu <aaron.lu@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-07-18ACPI / video / i915: No ACPI backlight if firmware expects Windows 8Rafael J. Wysocki
According to Matthew Garrett, "Windows 8 leaves backlight control up to individual graphics drivers rather than making ACPI calls itself. There's plenty of evidence to suggest that the Intel driver for Windows [8] doesn't use the ACPI interface, including the fact that it's broken on a bunch of machines when the OS claims to support Windows 8. The simplest thing to do appears to be to disable the ACPI backlight interface on these systems". There's a problem with that approach, however, because simply avoiding to register the ACPI backlight interface if the firmware calls _OSI for Windows 8 may not work in the following situations: (1) The ACPI backlight interface actually works on the given system and the i915 driver is not loaded (e.g. another graphics driver is used). (2) The ACPI backlight interface doesn't work on the given system, but there is a vendor platform driver that will register its own, equally broken, backlight interface if not prevented from doing so by the ACPI subsystem. Therefore we need to allow the ACPI backlight interface to be registered until the i915 driver is loaded which then will unregister it if the firmware has called _OSI for Windows 8 (or will register the ACPI video driver without backlight support if not already present). For this reason, introduce an alternative function for registering ACPI video, acpi_video_register_with_quirks(), that will check whether or not the ACPI video driver has already been registered and whether or not the backlight Windows 8 quirk has to be applied. If the quirk has to be applied, it will block the ACPI backlight support and either unregister the backlight interface if the ACPI video driver has already been registered, or register the ACPI video driver without the backlight interface otherwise. Make the i915 driver use acpi_video_register_with_quirks() instead of acpi_video_register() in i915_driver_load(). This change is based on earlier patches from Matthew Garrett, Chun-Yi Lee and Seth Forshee and includes a fix from Aaron Lu's. References: https://bugzilla.kernel.org/show_bug.cgi?id=51231 Tested-by: Aaron Lu <aaron.lu@intel.com> Tested-by: Igor Gnatenko <i.gnatenko.brain@gmail.com> Tested-by: Yves-Alexis Perez <corsac@debian.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Reviewed-by: Aaron Lu <aaron.lu@intel.com> Acked-by: Matthew Garrett <matthew.garrett@nebula.com>
2013-07-18ACPI / video: Always call acpi_video_init_brightness() on initMatthew Garrett
We have to call acpi_video_init_brightness() even if we're not going to initialise the backlight - Thinkpads seem to use this as the trigger for enabling ACPI notifications rather than handling it in firmware. [rjw: Drop the brightness object created by acpi_video_init_brightness() if we are not going to use it.] Signed-off-by: Matthew Garrett <matthew.garrett@nebula.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-07-15ACPI: Remove the old /proc/acpi/event interfaceThomas Renninger
It is quite some time that this one has been deprecated. Get rid of it. Should some really important user be overseen, it may be reverted and the userspace program worked on first, but it is time to do something to get rid of this old stuff... Signed-off-by: Thomas Renninger <trenn@suse.de> Acked-by: Matthew Garrett <matthew.garrett@nebula.com> Acked-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-07-15ACPI: introduce helper function acpi_execute_simple_method()Jiang Liu
Introduce helper function acpi_execute_simple_method() and use it in a number of places to simplify code. [rjw: Changelog] Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-07-15ACPI: introduce helper function acpi_has_method()Jiang Liu
Introduce helper function acpi_has_method() and use it in a number of places to simplify code. [rjw: Changelog] Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-06-20ACPI / scan: Do not bind ACPI drivers to objects with scan handlersRafael J. Wysocki
ACPI drivers must not be bound to device objects having scan handlers attatched to them, so make acpi_device_probe() fail with -EINVAL if the device object being probed has an ACPI scan handler. After this change the analogous check introduced into the ACPI video driver by commit 8c9b7a7 (ACPI / video: Do not bind to device objects with a scan handler) is not necessary any more and may be dropped, so drop it. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Tested-by: Tony Luck <tony.luck@gmail.com> Acked-by: Toshi Kani <toshi.kani@hp.com>
2013-06-10ACPI / video: Do not bind to device objects with a scan handlerRafael J. Wysocki
With the introduction of ACPI scan handlers, ACPI device objects with an ACPI scan handler attached to them must not be bound to by ACPI drivers any more. Unfortunately, however, the ACPI video driver attempts to do just that if there is a _ROM ACPI control method defined under a device object with an ACPI scan handler. Prevent that from happening by making the video driver's "add" routine check if the device object already has an ACPI scan handler attached to it and return an error code in that case. That is not sufficient, though, because acpi_bus_driver_init() would then clear the device object's driver_data that may be set by its scan handler, so for the fix to work acpi_bus_driver_init() has to be modified to leave driver_data as is on errors. References: https://bugzilla.kernel.org/show_bug.cgi?id=58091 Bisected-and-tested-by: Dmitry S. Demin <dmitryy.demin@gmail.com> Reported-and-tested-by: Jason Cassell <bluesloth600@gmail.com> Tracked-down-by: Aaron Lu <aaron.lu@intel.com> Cc: 3.9+ <stable@kernel.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Reviewed-by: Aaron Lu <aaron.lu@intel.com>
2013-06-01ACPI / video: ignore BIOS initial backlight value for HP Pavilion g6Ash Willis
This patch addresses kernel bug 56661. BIOS reports an incorrect backlight value, causing the driver to switch off the backlight completely during startup. This patch ignores the incorrect value from BIOS. References: https://bugzilla.kernel.org/show_bug.cgi?id=56661 Signed-off-by: Ash Willis <ashwillis@programmer.net> Cc: All <stable@vger.kernel.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-06-01ACPI / video: ignore BIOS initial backlight value for HP m4Alex Hung
On HP m4 lapops, BIOS reports minimum backlight on boot and causes backlight to dim completely. This ignores the initial backlight values and set to max brightness. References: https://bugs.launchpad.net/bugs/1184501 Cc: All <stable@vger.kernel.org> Signed-off-by: Alex Hung <alex.hung@canonical.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-05-12ACPI video: ignore BIOS initial backlight value for HP 1000Alex Hung
On HP 1000 lapops, BIOS reports minimum backlight on boot and causes backlight to dim completely. This ignores the initial backlight values and set to max brightness. References:: https://bugs.launchpad.net/bugs/1167760 Signed-off-by: Alex Hung <alex.hung@canonical.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-04-25ACPI: video: correct acpi_video_bus_add error processingAaron Lu
acpi_video_bus_get_devices() may fail due to some video output device doesn't have the _ADR method, and in this case, the error processing is to simply free the video structure in acpi_video_bus_add(), while leaving those already registered video output devices in the wild, which means for some video output device, we have already registered a backlight interface and installed a notification handler for it. So it can happen when user is using this system, on hotkey pressing, the notification handler will send a keycode through a non-existing input device, causing kernel freeze. To solve this problem, free all those already registered video output devices once something goes wrong in acpi_video_bus_get_devices(), so that no wild backlight interfaces and notification handlers exist. References: https://bugzilla.kernel.org/show_bug.cgi?id=51731 Reported-and-tested-by: <i-tek@web.de> Signed-off-by: Aaron Lu <aaron.lu@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-04-22acpi: video: enhance the quirk detect logic of _BQCAaron Lu
Currently we decide if the _BQC is using index by first setting the level to maximum, and then check if _BQC returned maximum; if not, we say it is using index. This is not true for some buggy systems, where the _BQC method will always return a constant value(e.g. 0 or 100 for the two broken system) and thus break the current logic. So this patch tries to enhance the quirk detect logic for _BQC: we do this by picking a test_level, it can be the maximum level or the mininum one based on some condition. And we don't make the assumption that if _BQC returned a value that is not what we just set, it must be using an index. Instead, we will compare the value returned from _BQC and if it doesn't match, see if the returned value is an index. And if still no, clear the capability of _BQC. References: https://bugzilla.kernel.org/show_bug.cgi?id=42861 References: https://bugzilla.kernel.org/show_bug.cgi?id=56011 Reported-and-tested-by: Artem Savkov <artem.savkov@gmail.com> Reported-by: Luis Medinas <lmedinas@gmail.com> Reported-by: Cheppes <cheppes@mailinator.com> Signed-off-by: Aaron Lu <aaron.lu@intel.com> Acked-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-03-25ACPI / video: Fix applying indexed initial brightness value.Danny Baumann
The value initially read via _BQC also needs to be offset by 2 to compensate for the first 2 special items in _BCL. Introduce a helper function that does the BQC-value-to-level conversion in order to not needlessly duplicate code. Signed-off-by: Danny Baumann <dannybaumann@web.de> Reviewed-by: Aaron Lu <aaron.lu@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-03-25ACPI / video: Make logic a little easier to understand.Danny Baumann
Make code paths a little easier to follow, and don't needlessly continue list iteration. Signed-off-by: Danny Baumann <dannybaumann@web.de> Reviewed-by: Aaron Lu <aaron.lu@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-03-25ACPI / video: Fix brightness control initialization for some laptops.Danny Baumann
In particular, this fixes brightness control initialization for all devices that return index values from _BQC and don't happen to have the initial index set by the BIOS in their _BCL table. One example for that is the Dell Inspiron 15R SE (model number 7520). What happened for those devices is that acpi_init_brightness queried the initial brightness by calling acpi_video_device_lcd_get_level_current. This called _BQC, which returned e.g. 13. As _BQC_use_index isn't determined at this point (and thus has its initial value of 0), the index isn't converted into the actual level. As '13' isn't present in the _BCL list, *level is later overwritten with brightness->curr, which was initialized to max_level (100) before. Later in acpi_init_brightness, level_old (with the value 100) is used as an index into the _BCL table, which causes a value outside of the actual table to be used as input into acpi_video_device_lcd_set_level(). Depending on the (undefined) value of that location, this call will fail, causing the brightness control for the device in question not to be enabled. Fix that by returning the raw value returned by the _BQC call in the initialization case. Signed-off-by: Danny Baumann <dannybaumann@web.de> Reviewed-by: Aaron Lu <aaron.lu@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-03-24ACPI video: ignore BIOS backlight value for HP dm4Gustavo Maciel Dias Vieira
On a HP Pavilion dm4 laptop the BIOS sets minimum backlight on boot, completely dimming the screen. Ignore this initial value for this machine. Signed-off-by: Gustavo Maciel Dias Vieira <gustavo@sagui.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-02-15Merge branch 'acpi-assorted'Rafael J. Wysocki
* acpi-assorted: ACPI: Add DMI entry for Sony VGN-FW41E_H ACPI: fix obsolete comment in custom_method.c ACPI / thermal: Use mode to enable/disable kernel thermal processing ACPI thermal: remove unnecessary newline from exception message ACPI sysfs: remove unnecessary newline from exception ACPI video: remove unnecessary newline from error messages ACPI: SRAT: report non-volatile memory in debug ACPI: Rework acpi_get_child() to be more efficient
2013-01-26ACPI: Remove useless type argument of driver .remove() operationRafael J. Wysocki
The second argument of ACPI driver .remove() operation is only used by the ACPI processor driver and the value passed to that driver through it is always available from the given struct acpi_device object's removal_type field. For this reason, the second ACPI driver .remove() argument is in fact useless, so drop it. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Reviewed-by: Jiang Liu <jiang.liu@huawei.com> Acked-by: Toshi Kani <toshi.kani@hp.com> Acked-by: Yinghai Lu <yinghai@kernel.org>
2013-01-26ACPI video: remove unnecessary newline from error messagesColin Ian King
ACPI_ERROR() already appends a newline, so there is no need for the error messages to include one too. Signed-off-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-12-04ACPI / video: ignore BIOS initial backlight value for HP Folio 13-2000Zhang Rui
Or else the laptop will boot with a dimmed screen. References: https://bugzilla.kernel.org/show_bug.cgi?id=51141 Tested-by: Stefan Nagy <public@stefan-nagy.at> Signed-off-by: Zhang Rui <rui.zhang@intel.com> Cc: <stable@vger.kernel.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-11-03ACPI video: Ignore errors after _DOD evaluation.Igor Murzov
There are systems where video module known to work fine regardless of broken _DOD and ignoring returned value here doesn't cause any issues later. This should fix brightness controls on some laptops. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=47861 Signed-off-by: Igor Murzov <e-mail@date.by> Reviewed-by: Sergey V <sftp.mtuci@gmail.com> Signed-off-by: Zhang Rui <rui.zhang@intel.com>
2012-09-20ACPI video: allow events handlers to veto the keypressLuca Tettamanti
The standard video events may be overloaded for device specific purposes. For example AMD ACPI interface overloads ACPI_VIDEO_NOTIFY_PROBE (0x81) to signal AMD-specific events. In such cases we don't want to send the keypress (KEY_SWITCHVIDEOMODE) to the userspace because the user did not press the mode switch key (the spurious keypress confuses the DE which usually changes the display configuration and messes up a dual-screen setup). This patch gives the handlers the chance to examine the event and block the keypress if the event is device specific. v2: refactor as suggested by Zhang Rui <rui.zhang@intel.com> Signed-off-by: Luca Tettamanti <kronos.it@gmail.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2012-06-30Merge branches 'acpi_pad-bugzilla-42981', 'apei-bugzilla-43282', ↵Len Brown
'video-bugzilla-43168', 'bugzilla-40002' and 'bugfix-misc' into release bug fixes
2012-06-30ACPI video: Still use ACPI backlight control if _DOS doesn't existZhang Rui
This fixes a regression in 3.4-rc1 caused by commit ea9f8856bd6d4ed45885b06a338f7362cd6c60e5 (ACPI video: Harden video bus adding.) Some platforms don't have _DOS control method, but the ACPI backlight still works. We should not invoke _DOS for these platforms. https://bugzilla.kernel.org/show_bug.cgi?id=43168 Cc: Igor Murzov <intergalactic.anonymous@gmail.com> Cc: stable@vger.kernel.org Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-06-01ACPI video: use after input_unregister_device()Dan Carpenter
We can't use "input" anymore after calling input_unregister_device(). The call to input_free_device() is a double free. The normal way to deal with this is to make input_register_device() the last function called in the function. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Len Brown <len.brown@intel.com>
2012-06-01acpi_video: Intel video is not always i915Alan Cox
Stop it poking at random registers on the i740 cards that may be out there still. As per Matthew's feedback remove the conditional checks and never enable the opregion handling unless an appropriate driver has been loaded. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-06-01acpi_video: fix leaking PCI referencesAlan Cox
Signed-off-by: Alan Cox <alan@linux.intel.com> Acked-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-03-30ACPI video: Don't start video device until its associated input device has ↵Igor Murzov
been allocated Quoth Dmitry Torokhov: In addition to bus notifier we do install device notifier explicitly so it might fire up early. The easiest fox would be to move acpi_video_bus_start_devices() after input_allocate_device() but before input_register_device() - unregistered input devices can handle input_event() calls just fine. May fix crashes reported in: https://bugzilla.kernel.org/show_bug.cgi?id=40672 Signed-off-by: Igor Murzov <e-mail@date.by> Signed-off-by: Len Brown <len.brown@intel.com>
2012-03-30ACPI video: Harden video bus adding.Igor Murzov
It is always better to check return values, so add some new checks and correct existing ones. v2: Be consistent and don't mix errors from -E* and AE_* namespaces. Signed-off-by: Igor Murzov <e-mail@date.by> Signed-off-by: Len Brown <len.brown@intel.com>
