path: root/drivers/acpi/sleep.c
2012-01-21ACPI / PM: Add Sony Vaio VPCCW29FX to nonvs blacklist.Lan Tianyu
Sony Vaio VPCCW29FX does not resume correctly without acpi_sleep=nonvs, so add it to the ACPI sleep blacklist. https://bugzilla.kernel.org/show_bug.cgi?id=34722 Signed-off-by: Lan Tianyu <tianyu.lan@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-12-06ACPI / PM: Do not save/restore NVS on Asus K54C/K54HRKeng-Yu Lin
The models do not resume correctly without acpi_sleep=nonvs. Signed-off-by: Keng-Yu Lin <kengyu@canonical.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-11-04ACPI / PM: Add Sony VPCEB17FX to nonvs blacklistDave Jones
Another entry for the nonvs blacklist, as noted by a user in https://bugzilla.redhat.com/show_bug.cgi?id=641789#c12 Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-10-22ACPI / PM: Add Sony VGN-FW21E to nonvs blacklist.Dave Jones
As noted by a user in https://bugzilla.redhat.com/show_bug.cgi?id=641789 The Sony VGN-FW21E also needs the nonvs by default workaround added. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-10-16PM / ACPI: Blacklist Vaio VGN-FW520F machine known to require acpi_sleep=nonvsBogdan Radulescu
Sony Vaio VGN-FW520F does not resume correctly without acpi_sleep=nonvs, so add it to the ACPI sleep blacklist. References: https://bugzilla.kernel.org/show_bug.cgi?id=16396#c86 Signed-off-by: Bogdan Radulescu <bogdan@nimblex.net> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-10-16PM / ACPI: Blacklist Sony Vaio known to require acpi_sleep=nonvsRafael J. Wysocki
Apparently, Sony Vaio VGN-SR26GN_P does not resume correctly without acpi_sleep=nonvs, so add it to the ACPI sleep blacklist. References: https://bugzilla.kernel.org/show_bug.cgi?id=16396#c91 Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-07-30ACPI: DMI workaround for Asus A8N-SLI Premium and Asus A8N-SLI DELUXZhang Rui
DMI workaround for A8N-SLI Premium and A8N-SLI DELUXE to enable the s3 suspend old ordering. http://bugzilla.kernel.org/show_bug.cgi?id=9528 Tested-by: Heiko Ettelbrück <hbruckynews@gmx.de> Tested-by: Brian Beardall <brian@rapsure.net> Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-03-23Merge branch 'linus' into releaseLen Brown
Conflicts: arch/x86/kernel/acpi/sleep.c Signed-off-by: Len Brown <len.brown@intel.com>
2011-03-16Merge branch 'x86-trampoline-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-trampoline-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: Fix binutils-2.21 symbol related build failures x86-64, trampoline: Remove unused variable x86, reboot: Fix the use of passed arguments in 32-bit BIOS reboot x86, reboot: Move the real-mode reboot code to an assembly file x86: Make the GDT_ENTRY() macro in <asm/segment.h> safe for assembly x86, trampoline: Use the unified trampoline setup for ACPI wakeup x86, trampoline: Common infrastructure for low memory trampolines Fix up trivial conflicts in arch/x86/kernel/Makefile
2011-03-15PM: Remove CONFIG_PM_OPSRafael J. Wysocki
After redefining CONFIG_PM to depend on (CONFIG_PM_SLEEP || CONFIG_PM_RUNTIME) the CONFIG_PM_OPS option is redundant and can be replaced with CONFIG_PM. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-02-24ACPI / PM: acpi_hibernation_enter() need not switch interrupts offRafael J. Wysocki
The function acpi_hibernation_enter() is always called with interrupts off, so it doesn't need to switch them off and on. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-02-24ACPI / PM: Merge do_suspend_lowlevel() into acpi_save_state_mem()Rafael J. Wysocki
The function do_suspend_lowlevel() is specific to x86 and defined in assembly code, so it should be called from the x86 low-level suspend code rather than from acpi_suspend_enter(). Merge do_suspend_lowlevel() into the x86's acpi_save_state_mem() and change the name of the latter to acpi_suspend_lowlevel(), so that the function's purpose is better reflected by its name. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-02-24ACPI / PM: Call acpi_save_state_mem() right before low-level suspendRafael J. Wysocki
Since acpi_save_state_mem() is only called by acpi_suspend_enter() if the target sleep state is S3, it's better to call it under the switch (acpi_state), right before do_suspend_lowlevel(). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-02-24ACPI / PM: Modify the "low-level resume finished" messageRafael J. Wysocki
Move the low-level resume completion message to the point where control goes back to acpi_suspend_enter() during resume and change it so that it's more informative. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-02-24ACPI / PM: acpi_suspend_enter() need not switch interrupts offRafael J. Wysocki
The function acpi_suspend_enter() is always called with interrupts off, so it doesn't need to switch them off and on. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-02-24ACPI / PM: Drop acpi_restore_state_mem()Rafael J. Wysocki
The function acpi_restore_state_mem() has never been and most likely never will be used, so remove it. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-02-17x86, trampoline: Use the unified trampoline setup for ACPI wakeupH. Peter Anvin
Use the unified trampoline allocation setup to allocate and install the ACPI wakeup code in low memory. Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> LKML-Reference: <4D5DFBE4.7090104@intel.com> Cc: Rafael J. Wysocki <rjw@sisk.pl> Cc: Matthieu Castet <castet.matthieu@free.fr> Cc: Stephen Rothwell <sfr@canb.auug.org.au>
2011-01-20ACPI / PM: Call suspend_nvs_free() earlier during resumeRafael J. Wysocki
It turns out that some device drivers map pages from the ACPI NVS region during resume using ioremap(), which conflicts with ioremap_cache() used for mapping those pages by the NVS save/restore code in nvs.c. Make the NVS pages mapped by the code in nvs.c be unmapped before device drivers' resume routines run. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (59 commits) ACPI / PM: Fix build problems for !CONFIG_ACPI related to NVS rework ACPI: fix resource check message ACPI / Battery: Update information on info notification and resume ACPI: Drop device flag wake_capable ACPI: Always check if _PRW is present before trying to evaluate it ACPI / PM: Check status of power resources under mutexes ACPI / PM: Rename acpi_power_off_device() ACPI / PM: Drop acpi_power_nocheck ACPI / PM: Drop acpi_bus_get_power() Platform / x86: Make fujitsu_laptop use acpi_bus_update_power() ACPI / Fan: Rework the handling of power resources ACPI / PM: Register power resource devices as soon as they are needed ACPI / PM: Register acpi_power_driver early ACPI / PM: Add function for updating device power state consistently ACPI / PM: Add function for device power state initialization ACPI / PM: Introduce __acpi_bus_get_power() ACPI / PM: Introduce function for refcounting device power resources ACPI / PM: Add functions for manipulating lists of power resources ACPI / PM: Prevent acpi_power_get_inferred_state() from making changes ACPICA: Update version to 20101209 ...
2011-01-12Merge branch 'suspend-ioremap-cache' into releaseLen Brown
2011-01-07ACPI / PM: Blacklist Averatec machine known to require acpi_sleep=nonvsRafael J. Wysocki
Apparently, Averatec AV1020-ED2 does not resume correctly without acpi_sleep=nonvs, so add it to the ACPI sleep blacklist. References: https://bugzilla.kernel.org/show_bug.cgi?id=16396#c86 Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2011-01-07PM: Fix oops in suspend/hibernate code related to failing ioremap()Jiri Slaby
When ioremap() fails (which might happen for some reason), we nicely oops in suspend_nvs_save() due to NULL dereference by memcpy() in there. Fail gracefully instead. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2010-12-22Merge branch 'master' into for-nextJiri Kosina
Conflicts: MAINTAINERS arch/arm/mach-omap2/pm24xx.c drivers/scsi/bfa/bfa_fcpim.c Needed to update to apply fixes for which the old branch was too outdated.
2010-12-13Merge branch 'bugzilla-23002' into releaseLen Brown
2010-12-13ACPI / PM: Do not save/restore NVS on Sony Vaio VGN-NW130DRafael J. Wysocki
The saving of the NVS memory area during suspend and restoring it during resume causes problems to appear on Sony Vaio VGN-NW130D, so blacklist that machine to avoid those problems. Addresses https://bugzilla.kernel.org/show_bug.cgi?id=23002 Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reported-and-tested-by: Adriano <adriano.vilela@yahoo.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-12-11ACPI: eliminate unused variable warning for !ACPI_SLEEPJan Beulich
Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-11-16suspend: constify platform_suspend_opsLionel Debroux
While at it, fix two checkpatch errors. Several non-const struct instances constified by this patch were added after the introduction of platform_suspend_ops in checkpatch.pl's list of "should be const" structs (79404849e90a41ea2109bd0e2f7c7164b0c4ce73). Patch against mainline. Inspired by hunks of the grsecurity patch, updated for newer kernels. Signed-off-by: Lionel Debroux <lionel_debroux@yahoo.fr> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-11-16hibernation: constify platform_hibernation_opsLionel Debroux
Patch against mainline. Changes since v1: added one hunk; no longer adding "const" qualifier to pointers in platform_hibernation_ops after seeing b4144e4f6e3b448d322095ca08af393682a69e33. Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-26Merge branch 'misc' into releaseLen Brown
2010-10-25ACPI / PM: Blacklist another machine that needs acpi_sleep=nonvsRafael J. Wysocki
Sony Vaio VPCEB1Z1E is reported to require acpi_sleep=nonvs for suspend/resume to work on it correctly, so blacklist it. Reported-by: Emanuele Bigiarini <pulmro@gmail.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2010-10-19ACPI: static sleep_states[] and acpi_gts_bfs_checkStephen Hemminger
Only used in one file so should be static. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-10-15ACPI / PM: Fix problems with acpi_pm_device_sleep_state()Rafael J. Wysocki
There is a number of problems with acpi_pm_device_sleep_state() now. First, if _S0W is not defined, it prevents devices from being put into D3 by PCI runtime PM, which shouldn't happen. Second, it shouldn't use adev->wakeup.state.enabled, because if it's set, it only means that either the device is permanently enabled to wake up the system, or that it has been enabled to do that through /proc/acpi/wakeup. Finally, it should be compiled if CONFIG_PM_SLEEP is not set, so that PCI runtime PM works correctly in that case. Fix these problems. Reported-by: Matthew Garrett <mjg59@srcf.ucam.org> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2010-09-24PM / ACPI: Blacklist systems known to require acpi_sleep=nonvsRafael J. Wysocki
Commit 2a6b69765ad794389f2fc3e14a0afa1a995221c2 (ACPI: Store NVS state even when entering suspend to RAM) changed the ACPI suspend to RAM code so that the NVS memory area is always unconditionally saved during suspend and restored during resume, since some systems evidently need that for the suspend-resume to work on them. However, it turned out that this change broke suspend-resume on a few systems, so commit 72ad5d77fb981963edae15eee8196c80238f5ed0 (ACPI / Sleep: Allow the NVS saving to be skipped during suspend to RAM) introduced the acpi_sleep=nonvs command line switch to allow their users to work around this issue. To keep track of the systems that require this workaround and to make the life of their users slightly easier blacklist them in acpisleep_dmi_table[]. https://bugzilla.kernel.org/show_bug.cgi?id=16396 Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2010-08-15Merge branch 'acpica-gpe' into releaseLen Brown
2010-08-14Merge branch 'nvs' into releaseLen Brown
2010-07-24ACPI / Sleep: Allow the NVS saving to be skipped during suspend to RAMRafael J. Wysocki
Commit 2a6b69765ad794389f2fc3e14a0afa1a995221c2 (ACPI: Store NVS state even when entering suspend to RAM) caused the ACPI suspend code save the NVS area during suspend and restore it during resume unconditionally, although it is known that some systems need to use acpi_sleep=s4_nonvs for hibernation to work. To allow the affected systems to avoid saving and restoring the NVS area during suspend to RAM and resume, introduce kernel command line option acpi_sleep=nonvs and make acpi_sleep=s4_nonvs work as its alias temporarily (add acpi_sleep=s4_nonvs to the feature removal file). Addresses https://bugzilla.kernel.org/show_bug.cgi?id=16396 . Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reported-and-tested-by: tomas m <tmezzadra@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-07-06ACPICA: Introduce acpi_gpe_wakeup()Rafael J. Wysocki
ACPICA uses reference counters to avoid disabling GPEs too early in case they have been enabled for many times. This is done separately for runtime and for wakeup, but the wakeup GPE reference counter is not really necessary, because GPEs are only enabled to wake up the system at the hardware level by acpi_enter_sleep_state(). Thus it only is necessary to set the corresponding bits in the wakeup enable masks of these GPEs' registers right before the system enters a sleep state. Moreover, the GPE wakeup enable bits can only be set when the target sleep state of the system is known and they need to be cleared immediately after wakeup regardless of how many wakeup devices are associated with a given GPE. On the basis of the above observations, introduce function acpi_gpe_wakeup() to be used for setting or clearing the enable bit corresponding to a given GPE in its enable register's enable_for_wake mask. Modify the ACPI suspend and wakeup code the use acpi_gpe_wakeup() instead of acpi_{enable|disable}_gpe() to set and clear GPE enable bits in their registers' enable_for_wake masks during system transitions to a sleep state and back to the working state, respectively. [This will allow us to drop the third argument of acpi_{enable|disable}_gpe() and simplify the GPE handling code.] Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-07-06ACPI / Sleep: Drop acpi_suspend_finish()Rafael J. Wysocki
The function acpi_suspend_finish() is not necessary any more, because acpi_pm_finish() can be used instead of it just fine. Remove it. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2010-07-06ACPI / Sleep: Consolidate suspend and hibernation routinesRafael J. Wysocki
Some hibernation and suspend routines can be merged, which reduces the complexity of code a bit. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2010-07-06ACPI / Wakeup: Simplify enabling of wakeup devicesRafael J. Wysocki
To simplify the enabling of wakeup devices during system suspend and hibernation, merge acpi_enable_wakeup_device_prep() with acpi_disable_wakeup_device() and remove unnecessary (and no longer valid) comments from the latter. Rename acpi_enable_wakeup_device() to acpi_enable_wakeup_devices() and acpi_disable_wakeup_device() to acpi_disable_wakeup_devices(), because these functions usually operate on multiple device objects. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2010-07-06ACPI / Sleep: Rework enabling wakeup devicesRafael J. Wysocki
There is no reason why acpi_enable_wakeup_device() should be called with interrupts disabled, because it doesn't access hardware. Thus it is possible to move it next to acpi_enable_wakeup_device_prep() and make the ACPI suspend, hibernate and poweroff code more straightforward. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2010-07-06ACPI / Sleep: Free NVS copy if suspending of devices failsRafael J. Wysocki
If suspending of devices fails or system suspend is tested in the "devices" mode, the memory allocated for storing a copy of the ACPI NVS area will not be freed, because acpi_pm_finish() is not called in that case. Fix this by moving the suspend_nvs_free() call to acpi_pm_end(). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2010-06-12Merge branch 'bugzilla-13931-sleep-nvs' into releaseLen Brown
Conflicts: drivers/acpi/sleep.c Signed-off-by: Len Brown <len.brown@intel.com>
2010-06-10ACPI: Store NVS state even when entering suspend to RAMMatthew Garrett
https://bugzilla.kernel.org/show_bug.cgi?id=13931 describes a bug where a system fails to successfully resume after the second suspend. Maxim Levitsky discovered that this could be rectified by forcibly saving and restoring the ACPI non-volatile state. The spec indicates that this is only required for S4, but testing the behaviour of Windows by adding an ACPI NVS region to qemu's e820 map and registering a custom memory read/write handler reveals that it's saved and restored even over suspend to RAM. We should mimic that behaviour to avoid other broken platforms. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-06-10suspend: Move NVS save/restore code to generic suspend functionalityMatthew Garrett
Saving platform non-volatile state may be required for suspend to RAM as well as hibernation. Move it to more generic code. Signed-off-by: Matthew Garrett <mjg@redhat.com> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Tested-by: Maxim Levitsky <maximlevitsky@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-06-01Merge branches 'bugzilla-14668' and 'misc-2.6.35' into releaseLen Brown
2010-05-28ACPI / EC / PM: Fix names of functions that block/unblock EC transactionsRafael J. Wysocki
The names of the functions used for blocking/unblocking EC transactions during suspend/hibernation suggest that the transactions are suspended and resumed by them, while in fact they are disabled and enabled. Rename the functions (and the flag used by them) to better reflect what they really do. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2010-05-28ACPI / EC / PM: Fix race between EC transactions and system suspendRafael J. Wysocki
There still is a race that may result in suspending the system in the middle of an EC transaction in progress, which leads to problems (like the kernel thinking that the ACPI global lock is held during resume while in fact it's not). To remove the race condition, modify the ACPI platform suspend and hibernate callbacks so that EC transactions are blocked right after executing the _PTS global control method and are allowed to happen again right after the low-level wakeup. Introduce acpi_pm_freeze() that will disable GPEs, wait until the event queues are empty and block EC transactions. Use it wherever GPEs are disabled in preparation for switching local interrupts off. Introduce acpi_pm_thaw() that will allow EC transactions to happen again and enable runtime GPEs. Use it to balance acpi_pm_freeze() wherever necessary. In addition to that use acpi_ec_resume_transactions_early() to unblock EC transactions as early as reasonably possible during resume. Also unblock EC transactions in acpi_hibernation_finish() and in the analogous suspend routine to make sure that the EC transactions are enabled in all error paths. Fixes https://bugzilla.kernel.org/show_bug.cgi?id=14668 Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reported-and-tested-by: Maxim Levitsky <maximlevitsky@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-05-12ACPI: Unconditionally set SCI_EN on resumeMatthew Garrett
The ACPI spec tells us that the firmware will reenable SCI_EN on resume. Reality disagrees in some cases. The ACPI spec tells us that the only way to set SCI_EN is via an SMM call. https://bugzilla.kernel.org/show_bug.cgi?id=13745 shows us that doing so may break machines. Tracing the ACPI calls made by Windows shows that it unconditionally sets SCI_EN on resume with a direct register write, and therefore the overwhelming probability is that everything is fine with this behaviour. Signed-off-by: Matthew Garrett <mjg@redhat.com> Tested-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2010-05-11ACPI: sleep: eliminate duplicate entries in acpisleep_dmi_table[]Alex Chiang
Duplicate entries ended up acpisleep_dmi_table[] by accident. They don't hurt functionality, but they are ugly, so let's get rid of them. Cc: stable@kernel.org Signed-off-by: Alex Chiang <achiang@canonical.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
