Pull ACPI and power management fixes from Rafael Wysocki:
- Fixes for blackfin and microblaze build problems introduced by the
removal of global pm_idle. From Lars-Peter Clausen.
- OPP core build fix from Shawn Guo.
- Error condition check fix for the new imx6q-cpufreq driver from Wei
Yongjun.
- Fix for an AER driver crash related to the lack of APEI
initialization for acpi=off. From Rafael J Wysocki.
- Fix for a USB breakage on Thinkpad T430 related to ACPI power
resources and PCI wakeup from Rafael J. Wysocki.
* tag 'pm+acpi-fixes-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
ACPI / PM: Take unusual configurations of power resources into account
imx6q-cpufreq: fix return value check in imx6q_cpufreq_probe()
PM / OPP: fix condition for empty of_init_opp_table()
ACPI / APEI: Fix crash in apei_hest_parse() for acpi=off
microblaze idle: Fix compile error
blackfin idle: Fix compile error
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI changes from Bjorn Helgaas:
"Host bridge hotplug
- Major overhaul of ACPI host bridge add/start (Rafael Wysocki, Yinghai Lu)
- Major overhaul of PCI/ACPI binding (Rafael Wysocki, Yinghai Lu)
- Split out ACPI host bridge and ACPI PCI device hotplug (Yinghai Lu)
- Stop caching _PRT and make independent of bus numbers (Yinghai Lu)
PCI device hotplug
- Clean up cpqphp dead code (Sasha Levin)
- Disable ARI unless device and upstream bridge support it (Yijing Wang)
- Initialize all hot-added devices (not functions 0-7) (Yijing Wang)
Power management
- Don't touch ASPM if disabled (Joe Lawrence)
- Fix ASPM link state management (Myron Stowe)
Miscellaneous
- Fix PCI_EXP_FLAGS accessor (Alex Williamson)
- Disable Bus Master in pci_device_shutdown (Konstantin Khlebnikov)
- Document hotplug resource and MPS parameters (Yijing Wang)
- Add accessor for PCIe capabilities (Myron Stowe)
- Drop pciehp suspend/resume messages (Paul Bolle)
- Make pci_slot built-in only (not a module) (Jiang Liu)
- Remove unused PCI/ACPI bind ops (Jiang Liu)
- Removed used pci_root_bus (Bjorn Helgaas)"
* tag 'pci-v3.9-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (51 commits)
PCI/ACPI: Don't cache _PRT, and don't associate them with bus numbers
PCI: Fix PCI Express Capability accessors for PCI_EXP_FLAGS
ACPI / PCI: Make pci_slot built-in only, not a module
PCI/PM: Clear state_saved during suspend
PCI: Use atomic_inc_return() rather than atomic_add_return()
PCI: Catch attempts to disable already-disabled devices
PCI: Disable Bus Master unconditionally in pci_device_shutdown()
PCI: acpiphp: Remove dead code for PCI host bridge hotplug
PCI: acpiphp: Create companion ACPI devices before creating PCI devices
PCI: Remove unused "rc" in virtfn_add_bus()
PCI: pciehp: Drop suspend/resume ENTRY messages
PCI/ASPM: Don't touch ASPM if forcibly disabled
PCI/ASPM: Deallocate upstream link state even if device is not PCIe
PCI: Document MPS parameters pci=pcie_bus_safe, pci=pcie_bus_perf, etc
PCI: Document hpiosize= and hpmemsize= resource reservation parameters
PCI: Use PCI Express Capability accessor
PCI: Introduce accessor to retrieve PCIe Capabilities Register
PCI: Put pci_dev in device tree as early as possible
PCI: Skip attaching driver in device_add()
PCI: acpiphp: Keep driver loaded even if no slots found
* acpi-pm:
Commit d2e5f0c (ACPI / PCI: Rework the setup and cleanup of device
wakeup) moved the initial disabling of system wakeup for PCI devices
into a place where it can actually work and that exposed a hidden old
issue with crap^Wunusual system designs where the same power
resources are used for both wakeup power and device power control at
run time.
Namely, say there is one power resource such that the ACPI power
state D0 of a PCI device depends on that power resource (i.e. the
device is in D0 when that power resource is "on") and it is used
as a wakeup power resource for the same device. Then, calling
acpi_pci_sleep_wake(pci_dev, false) for the device in question will
cause the reference counter of that power resource to drop to 0,
which in turn will cause it to be turned off. As a result, the
device will go into D3cold at that point, although it should have
stayed in D0.
As it turns out, that happens to USB controllers on some laptops
and USB becomes unusable on those machines as a result, which is
a major regression from v3.8.
To fix this problem, (1) increment the reference counters of wakup
power resources during their initialization if they are "on"
initially, (2) prevent acpi_disable_wakeup_device_power() from
decrementing the reference counters of wakeup power resources that
were not enabled for wakeup power previously, and (3) prevent
acpi_enable_wakeup_device_power() from incrementing the reference
counters of wakeup power resources that already are enabled for
wakeup power.
In addition to that, if it is impossible to determine the initial
states of wakeup power resources, avoid enabling wakeup for devices
whose wakeup power depends on those power resources.
Reported-by: Dave Jones <davej@redhat.com>
Reported-by: Fabio Baltieri <fabio.baltieri@linaro.org>
Tested-by: Fabio Baltieri <fabio.baltieri@linaro.org>
* pci/jiang-pci_slot-kconfig:
As discussed in thread at https://patchwork.kernel.org/patch/1946851/,
there's no value in supporting CONFIG_ACPI_PCI_SLOT=m any more.
So change Kconfig and code to only support building pci_slot as
built-in driver.
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
* acpi-cleanup: (21 commits)
ACPI / hotplug: Fix concurrency issues and memory leaks
ACPI: Remove the use of CONFIG_ACPI_CONTAINER_MODULE
ACPI / scan: Full transition to D3cold in acpi_device_unregister()
ACPI / scan: Make acpi_bus_hot_remove_device() acquire the scan lock
ACPI: Drop the container.h header file
ACPI / Documentation: refer to correct file for acpi_platform_device_ids[] table
ACPI / scan: Make container driver use struct acpi_scan_handler
ACPI / scan: Remove useless #ifndef from acpi_eject_store()
ACPI: Unbind ACPI drv when probe failed
ACPI: sysfs eject support for ACPI scan handlers
ACPI / scan: Follow priorities of IDs when matching scan handlers
ACPI / PCI: pci_slot: replace printk(KERN_xxx) with pr_xxx()
ACPI / dock: Fix acpi_bus_get_device() check in drivers/acpi/dock.c
ACPI / scan: Clean up acpi_bus_get_parent()
ACPI / platform: Use struct acpi_scan_handler for creating devices
ACPI / PCI: Make PCI IRQ link driver use struct acpi_scan_handler
ACPI / PCI: Make PCI root driver use struct acpi_scan_handler
ACPI / scan: Introduce struct acpi_scan_handler
ACPI / scan: Make scanning of fixed devices follow the general scheme
ACPI: Drop device start operation that is not used
This changeset is aimed at fixing a few different but related
problems in the ACPI hotplug infrastructure.
First of all, since notify handlers may be run in parallel with
acpi_bus_scan(), acpi_bus_trim() and acpi_bus_hot_remove_device()
and some of them are installed for ACPI handles that have no struct
acpi_device objects attached (i.e. before those objects are created),
those notify handlers have to take acpi_scan_lock to prevent races
from taking place (e.g. a struct acpi_device is found to be present
for the given ACPI handle, but right after that it is removed by
acpi_bus_trim() running in parallel to the given notify handler).
Moreover, since some of them call acpi_bus_scan() and
acpi_bus_trim(), this leads to the conclusion that acpi_scan_lock
should be acquired by the callers of these two funtions rather by
these functions themselves.
For these reasons, make all notify handlers that can handle device
addition and eject events take acpi_scan_lock and remove the
acpi_scan_lock locking from acpi_bus_scan() and acpi_bus_trim().
Accordingly, update all of their users to make sure that they
are always called under acpi_scan_lock.
Furthermore, since eject operations are carried out asynchronously
with respect to the notify events that trigger them, with the help
of acpi_bus_hot_remove_device(), even if notify handlers take the
ACPI scan lock, it still is possible that, for example,
acpi_bus_trim() will run between acpi_bus_hot_remove_device() and
the notify handler that scheduled its execution and that
acpi_bus_trim() will remove the device node passed to
acpi_bus_hot_remove_device() for ejection. In that case, the struct
acpi_device object obtained by acpi_bus_hot_remove_device() will be
invalid and not-so-funny things will ensue. To protect agaist that,
make the users of acpi_bus_hot_remove_device() run get_device() on
ACPI device node objects that are about to be passed to it and make
acpi_bus_hot_remove_device() run put_device() on them and check if
their ACPI handles are not NULL (make acpi_device_unregister() clear
the device nodes' ACPI handles for that check to work).
Finally, observe that acpi_os_hotplug_execute() actually can fail,
in which case its caller ought to free memory allocated for the
context object to prevent leaks from happening. It also needs to
run put_device() on the device node that it ran get_device() on
previously in that case. Modify the code accordingly.
Acked-by: Yinghai Lu <yinghai@kernel.org>
In order to drop reference counts of all power resources used by an
ACPI device node being removed, acpi_device_unregister() calls
acpi_power_transition(device, ACPI_STATE_D3_COLD), which effectively
transitions the device node into D3cold if it uses any power
resources. However, for some device nodes it may not be appropriate
to remove power from them entirely before putting them into D3hot
before. On the other hand, executing _PS3 for devices that don't
use power resources before removing them shouldn't really hurt.
In fact, that is done by acpi_bus_hot_remove_device(), but this is
not the right place to do it, because the bus trimming may have
caused power to be removed from the device node in question already
before.
For these reasons, make acpi_device_unregister() carry out full
power-off transition for all device nodes supporting that and remove
the direct evaluation of _PS3 from acpi_bus_hot_remove_device().
The ACPI scan lock has been introduced to prevent acpi_bus_scan()
and acpi_bus_trim() from running in parallel with each other for
overlapping ACPI namespace scopes. However, it is not sufficient
to do that, because if acpi_bus_scan() is run (for an overlapping
namespace scope) right after the acpi_bus_trim() in
acpi_bus_hot_remove_device(), the subsequent eject will remove
devices without removing the corresponding struct acpi_device
objects (and possibly companion "physical" device objects).
Therefore acpi_bus_hot_remove_device() has to acquire the scan
lock before carrying out the bus trimming and hold it through
the evaluation of _EJ0, so make that happen.
Acked-by: Toshi Kani <toshi.kani@hp.com>
Make the ACPI container driver use struct acpi_scan_handler for
representing the object used to initialize ACPI containers and remove
the ACPI driver structure used previously and the data structures
created by it, since in fact they were not used for any purpose.
This simplifies the code and reduces the kernel's memory footprint by
avoiding the registration of a struct device_driver object with the
driver core and creation of its sysfs directory which is unnecessary.
In addition to that, make the namespace walk callback used for
installing the notify handlers for ACPI containers more
straightforward.
This change includes fixes from Toshi Kani.
Acked-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Tested-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Reviewed-by: Toshi Kani <toshi.kani@hp.com>
Tested-by: Toshi Kani <toshi.kani@hp.com>
Since the FORCE_EJECT symbol is never defined, the
#ifndef FORCE_EJECT in acpi_eject_store() is always true, so drop it.
When acpi_device_install_notify_handler() failed in acpi_device_probe(),
it calls acpi_drv->ops.remove() and fails the probe. However, the ACPI
driver is left bound to the acpi_device. Fix it by clearing the driver
and driver_data fields.
Signed-off-by: Toshi Kani <toshi.kani@hp.com>
Changed sysfs eject, acpi_eject_store(), so that it doesn't return
error codes for devices nodes with ACPI scan handlers attached and
no ACPI drivers.
[rjw: Changelog]
The IDs of ACPI device nodes stored in their pnp.ids member arrays
are sorted by decreasing priority (i.e. the highest-priority ID is
the first entry). This means that when matching scan handlers to
device nodes, the namespace scanning code should walk the list of
scan handlers for each device node ID instead of walking the list
of device node IDs for each handler (the latter causes the first
handler matching any of the device node IDs to be chosen, although
there may be another handler matching an ID of a higher priority
which should be preferred). Make the code follow this observation.
This change has been suggested and justified by Toshi Kani.
* acpi-lpss:
ACPI / platform: create LPSS clocks if Lynxpoint devices are found during scan
clk: x86: add support for Lynxpoint LPSS clocks
x86: add support for Intel Low Power Subsystem
ACPI / platform: fix comment about the platform device name
ACPI: add support for CSRT table
* acpi-pm: (35 commits)
ACPI / PM: Handle missing _PSC in acpi_bus_update_power()
ACPI / PM: Do not power manage devices in unknown initial states
ACPI / PM: Fix acpi_bus_get_device() check in drivers/acpi/device_pm.c
ACPI / PM: Fix /proc/acpi/wakeup for devices w/o bus or parent
ACPI / PM: Fix consistency check for power resources during resume
ACPI / PM: Expose lists of device power resources to user space
sysfs: Functions for adding/removing symlinks to/from attribute groups
ACPI / PM: Expose current status of ACPI power resources
ACPI / PM: Expose power states of ACPI devices to user space
ACPI / scan: Prevent device add uevents from racing with user space
ACPI / PM: Fix device power state value after transitions to D3cold
ACPI / PM: Use string "D3cold" to represent ACPI_STATE_D3_COLD
ACPI / PM: Sanitize checks in acpi_power_on_resources()
ACPI / PM: Always evaluate _PSn after setting power resources
ACPI / PM: Introduce helper for executing _PSn methods
ACPI / PM: Make acpi_bus_init_power() more robust
ACPI / PM: Fix build for unusual combination of Kconfig options
ACPI / PM: remove leading whitespace from #ifdef
ACPI / PM: Consolidate suspend-specific and hibernate-specific code
ACPI / PM: Move device power management functions to device_pm.c
* acpi-scan: (30 commits)
ACPI / scan: Fix acpi_bus_get_device() check in acpi_match_device()
ACPI / scan: Make namespace scanning and trimming mutually exclusive
ACPI / scan: Make it clear that acpi_bus_trim() cannot fail
ACPI / scan: Drop acpi_bus_add() and use acpi_bus_scan() instead
ACPI: update ej_event interface to take acpi_device
ACPI / scan: Add second pass to acpi_bus_trim()
ACPI / scan: Change the implementation of acpi_bus_trim()
ACPI / scan: Drop the second argument of acpi_bus_trim()
ACPI / scan: Drop the second argument of acpi_device_unregister()
ACPI: Remove the ops field from struct acpi_device
ACPI: remove unused acpi_op_bind and acpi_op_unbind
ACPI / scan: Fix check of device_attach() return value.
ACPI / scan: Treat power resources in a special way
ACPI: Remove unused struct acpi_pci_root.id member
ACPI: Drop ACPI device .bind() and .unbind() callbacks
ACPI / PCI: Move the _PRT setup and cleanup code to pci-acpi.c
ACPI / PCI: Rework the setup and cleanup of device wakeup
ACPI: Add .setup() and .cleanup() callbacks to struct acpi_bus_type
ACPI: Make acpi_bus_scan() and acpi_bus_add() take only one argument
ACPI: Replace ACPI device add_type field with a match_driver flag
In general, for ACPI device power management to work, the initial
power states of devices must be known (otherwise, we wouldn't be able
to keep track of power resources, for example). Hence, if it is
impossible to determine the initial ACPI power states of some
devices, they can't be regarded as power-manageable using ACPI.
For this reason, modify acpi_bus_get_power_flags() to clear the
power_manageable flag if acpi_bus_init_power() fails and add some
extra fallback code to acpi_bus_init_power() to cover broken
BIOSes that provide _PS0/_PS3 without _PSC for some devices.
Verified to work on my HP nx6325 that has this problem.
Tested-by: Peter Wu <lekensteyn@gmail.com>
Make acpi_bus_get_parent() more straightforward and remove an
unnecessary local variable ret from it.
Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Since acpi_bus_get_device() returns int and not acpi_status, change
acpi_match_device() so that it doesn't apply ACPI_FAILURE() to the
return value of acpi_bus_get_device().
Currently, the ACPI namespace scanning code creates platform device
objects for ACPI device nodes whose IDs match the contents of the
acpi_platform_device_ids[] table. However, this adds a superfluous
special case into acpi_bus_device_attach() and makes it more
difficult to follow than it has to be. It also will make it more
difficult to implement removal code for those platform device objects
in the future.
For the above reasons, introduce a struct acpi_scan_handler object
for creating platform devices and move the code related to that from
acpi_bus_device_attach() to the .attach() callback of that object.
Also move the acpi_platform_device_ids[] table to acpi_platform.c.
Tested-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Make the ACPI PCI IRQ link driver use struct acpi_scan_handler
for representing the object used to set up ACPI interrupt links and
to remove data structures used for this purpose before unregistering
the corresponding ACPI device nodes.
This simplifies the code slightly and reduces the kernel's memory
footprint by avoiding the registration of a struct device_driver
object with the driver core and creation of its sysfs directory
Introduce struct acpi_scan_handler for representing objects that
will do configuration tasks depending on ACPI device nodes'
hardware IDs (HIDs).
Currently, those tasks are done either directly by the ACPI namespace
scanning code or by ACPI device drivers designed specifically for
this purpose. None of the above is desirable, however, because
doing that directly in the namespace scanning code makes that code
overly complicated and difficult to follow and doing that in
"special" device drivers leads to a great deal of confusion about
their role and to confusing interactions with the driver core (for
example, sysfs directories are created for those drivers, but they
are completely unnecessary and only increase the kernel's memory
footprint in vain).
The following commits depend on the 'acpi-lpss' material.
The following commits depend on the 'acpi-scan' material.
Make acpi_bus_scan_fixed() use device_attach() directly to attach
drivers, if any, to the fixed devices in analogy with how
acpi_bus_scan() works, which allows the last argument of
acpi_add_single_object() to be dropped and the manipulation of the
flags.match_driver bit to be moved to acpi_init_device_object()
and acpi_device_add_finalize().
After these changes all of the functions for the initialization
and registration of struct acpi_device objects work in the same
way for all of them.
The following commits depend on the 'acpi-pm' material.
There is no guarantee that acpi_bus_scan() and acpi_bus_trim() will
not be run in parallel for the same scope of the ACPI namespace,
which may lead to a great deal of confusion, so introduce a new mutex
to prevent that from happening.
The second argument of ACPI driver .remove() operation is only used
by the ACPI processor driver and the value passed to that driver
through it is always available from the given struct acpi_device
object's removal_type field. For this reason, the second ACPI driver
.remove() argument is in fact useless, so drop it.
Reviewed-by: Jiang Liu <jiang.liu@huawei.com>
Since acpi_bus_trim() cannot fail, change its definition to a void
function, so that its callers don't check the return value in vain
and update the callers.
The acpiphp driver is confusing because it contains partial support for PCI
host bridge hotplug as well as support for hotplug of PCI devices.
This patch moves the host bridge hot-add support to pci_root.c and adds
hot-remove support in pci_root.c.
How to test it: if sci_emu patch is applied, find out root bus number to
ACPI root name mapping from dmesg or /sys. To remove root bus:
echo "\_SB.PCIB 3" > /sys/kernel/debug/acpi/sci_notify
To add back root bus:
echo "\_SB.PCIB 1" > /sys/kernel/debug/acpi/sci_notify
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Since ACPI power resources are going to be used more extensively on
new hardware platforms, it becomes necessary for user space (powertop
in particular) to observe some properties of those resources for
diagnostics purposes.
For this reason, expose the current status of each ACPI power
resource to user space via sysfs by adding a new resource_in_use
attribute to the sysfs directory representing the given power
resource.
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Make it possible to retrieve the current power state of a device with
ACPI power management from user space via sysfs by adding two new
attributes, power_state and real_power_state, to the sysfs directory
associated with the struct acpi_device object representing the
device's ACPI node.
ACPI core adds sysfs device files after the given devices have been
registered with device_register(), which is not appropriate, because
it may lead to race conditions with user space tools using those
files.
Fix the problem by delaying the KOBJ_ADD uevent for ACPI devices
until after all of the devices' sysfs files have been created.
This also fixes a use-after-free in acpi_device_unregister().
Intel Lynxpoint LPSS peripheral drivers depend on LPSS clock tree being
created in order to function properly. The clock tree is exposed as a
platform driver that binds to a device named 'clk-lpt'.
To support this we modify the acpi_create_platform_device() to take one
additional parameter called flags. This is passed from
acpi_platform_device_ids[] array when acpi_create_platform_device() is
called.
We then introduce a new flag ACPI_PLATFORM_CLK which is used to tell
acpi_create_platform_device() to create the platform clocks as well.
Finally we set the ACPI_PLATFORM_CLK flags for all the Lynxpoint LPSS
devices and make sure that when this flag is set we create the
corresponding clock tree platform device.
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Core System Resources Table (CSRT) is a proprietary ACPI table that
contains resources for certain devices that are not found in the DSDT
table. Typically a shared DMA controller might be found here.
This patch adds support for this table. We go through all entries in the
table and make platform devices of them. The resources from the table are
passed with the platform device.
There is one special resource in the table and it is the DMA request line
base and number of request lines. This information might be needed by the
DMA controller driver as it needs to map the ACPI DMA request line number
to the actual request line understood by the hardware. This range is passed
as IORESOURCE_DMA resource.
The only difference between acpi_bus_scan() and acpi_bus_add() is the
invocation of acpi_update_all_gpes() in the latter which in fact is
unnecessary, because acpi_update_all_gpes() has already been called
by acpi_scan_init() and the way it is implemented guarantees the next
invocations of it to do nothing.
For this reason, drop acpi_bus_add() and make all its callers use
acpi_bus_scan() directly instead of it. Additionally, rearrange the
code in acpi_scan_init() slightly to improve the visibility of the
acpi_update_all_gpes() call in there.
The system level attribute of ACPI power resources is the lowest
system sleep level (S0, S2 etc.) in which the given resource can be
"on" (ACPI 5.0, Section 7.1). On the other hand, wakeup power
resources have to be "on" for devices depending on them to be able to
signal wakeup. Therefore devices cannot wake up the system from
sleep states higher than the minimum of the system level attributes
of their wakeup power resources.
Use the wakeup power resources' system level values to get the
deepest system sleep state (highest system sleep level) the given
device can wake up the system from.
Some ACPI power resource initialization errors, like memory
allocation errors, are not taken into account appropriately in some
cases, which may lead to a device having an incomplete list of power
resources that one of its power states depends on, for one example.
Rework the power resource initialization and namespace scanning code
so that power resource initialization errors are treated more
seriously.
The lists of ACPI power resources are currently extracted in two
different ways, one for wakeup power resources and one for power
resources that device power states depend on. There is no reason
why it should be done differently in those two cases, so introduce
a common routine for extracting power resources lists from data
returned by AML, acpi_extract_power_resources(), and make the
namespace scanning code use it for both wakeup and device power
states power resources.
The local variables in acpi_bus_get_power_flags() need not be
initialized upfront, so change the code accordingly.
To reduce indentation level and improve code readability, move the
initialization code related to device power states from
acpi_bus_get_power_flags() to a new routine,
acpi_bus_init_power_state().
ACPI power resources have an order attribute that should be taken
into account when turning them on and off, but it is not used now.
Modify the power resources management code to preserve the
spec-compliant ordering of wakeup power resources.
spec-compliant ordering of power resources that power states of
devices depend on (analogous changes will be done separately for
power resources used for wakeup).
The ACPI power resources driver is not very useful, because the only
thing it really does is to restore the state of the power resources
that were "on" before system suspend or hibernation, but that may be
achieved in a different way.
Drop the ACPI power resources driver entirely and add
acpi_resume_power_resources() that will walk the list of all
registered power resources during system resume and turn on the ones
that were "on" before the preceding system suspend or hibernation.
ACPI power resources need to be treated in a special way by the
namespace scanning code, because they need to be ready to use as
soon as they have been discovered (even before registering ACPI
device nodes using them for power management).
For this reason, it doesn't make sense to separate the preparation
of struct acpi_device objects representing them in the device
hierarchy from the creation of struct acpi_power_resource objects
actually used for power resource manipulation. Accordingly, it
doesn't make sense to define non-empty .add() and .remove() callbacks
in the power resources "driver" (in fact, it is questionable whether
or not it is useful to register such a "driver" at all).
Rearrange the code in scan.c and power.c so that power resources are
initialized entirely by one routine, acpi_add_power_resource(), that
also prepares their struct acpi_device objects and registers them
with the driver core, telling it to use a special release routine,
acpi_release_power_resource(), for removing objects that represent
power resources from memory. Make the ACPI namespace scanning code
in scan.c always use acpi_add_power_resource() for preparing and
registering objects that represent power resources.
Simplify the code preparing struct acpi_device objects for
registration by removing useless code, moving different pieces of
code into the functions they belong to and making a couple of int
functions always returning 0 void.
This also fixes a possible memory leak in ACPI device registration
error code path by making acpi_device_register() detach data from
device->handle if device_register() fails and prepares the scanning
code for special-casing ACPI power resources (next patch).
