* acpi-scan:
ACPI / bus: Move ACPI bus type registration
ACPI / scan: Move bus operations and notification routines to bus.c
ACPI / scan: Move device matching code to bus.c
ACPI / scan: Move sysfs-related device code to a separate file
* acpi-processor:
PCC: Disable compilation by default
ACPI: Decouple ACPI idle and ACPI processor drivers
ACPI: Split out ACPI PSS from ACPI Processor driver
PCC: Initialize PCC Mailbox earlier at boot
ACPI / processor: remove leftover __refdata annotations
* acpi-assorted:
ACPI: fix acpi_debugfs_init prototype
ACPI: Remove FSF mailing addresses
* pm-cpuidle:
suspend-to-idle: Prevent RCU from complaining about tick_freeze()
* pm-cpufreq:
cpufreq: Allow freq_table to be obtained for offline CPUs
cpufreq: Initialize the governor again while restoring policy
* acpi-resources:
ACPI / PCI: Fix regressions caused by resource_size_t overflow with 32-bit kernel
kernel
Zoltan Boszormenyi reported this regression:
"There's a Realtek RTL8111/8168/8411 (PCI ID 10ec:8168, Subsystem ID
1565:230e) network chip on the mainboard. After the r8169 driver loaded
the IRQs in the machine went berserk. Keyboard keypressed arrived with
considerable latency and duplicated, so no real work was possible.
The machine responded to the power button but didn't actually power
down. It just stuck at the powering down message. I had to press the
power button for 4 seconds to power it down.
The computer is a POS machine with a big battery inside. Because of this,
either ACPI or the Realtek chip kept the bad state and after rebooting,
the network chip didn't even show up in lspci. Not even the PXE ROM
announced itself during boot. I had to disconnect the battery to beat
some sense back to the computer.
The regression happens with 4.0.5, 4.1.0-rc8 and 4.1.0-final. 3.18.16 was
good."
The regression is caused by commit 593669c2ac0f (x86/PCI/ACPI: Use common
ACPI resource interfaces to simplify implementation). Since commit
593669c2ac0f, x86 PCI ACPI host bridge driver validates ACPI resources by
first converting an ACPI resource to a 'struct resource' structure and
then applying checks against the converted resource structure. The 'start'
and 'end' fields in 'struct resource' are defined to be type of
resource_size_t, which may be 32 bits or 64 bits depending on
CONFIG_PHYS_ADDR_T_64BIT.
This may cause incorrect resource validation results with 32-bit kernels
because 64-bit ACPI resource descriptors may get truncated when converting
to 32-bit 'start' and 'end' fields in 'struct resource'. It eventually
affects PCI resource allocation subsystem and makes some PCI devices and
the system behave abnormally due to incorrect resource assignment.
So enhance the ACPI resource parsing interfaces to ignore ACPI resource
descriptors with address/offset above 4G when running in 32-bit mode.
With the fix applied, the behavior of the machine was restored to how
3.18.16 worked, i.e. the memory range that is over 4GB is ignored again,
and lspci -vvxxx shows that everything is at the same memory window as
they were with 3.18.16.
Reported-and-tested-by: Boszormenyi Zoltan <zboszor@pr.hu>
Fixes: 593669c2ac0f (x86/PCI/ACPI: Use common ACPI resource interfaces to simplify implementation)
Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com>
Cc: 4.0+ <stable@vger.kernel.org> # 4.0+
There is no need to carry potentially outdated Free Software Foundation
mailing address in file headers since the COPYING file includes it.
Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
This effectively reverts the following three commits:
7bc10388ccdd ACPI / resources: free memory on error in add_region_before()
0f1b414d1907 ACPI / PNP: Avoid conflicting resource reservations
b9a5e5e18fbf ACPI / init: Fix the ordering of acpi_reserve_resources()
(commit b9a5e5e18fbf introduced regressions some of which, but not
all, were addressed by commit 0f1b414d1907 and commit 7bc10388ccdd
was a fixup on top of the latter) and causes ACPI fixed hardware
resources to be reserved at the fs_initcall_sync stage of system
initialization.
The story is as follows. First, a boot regression was reported due
to an apparent resource reservation ordering change after a commit
that shouldn't lead to such changes. Investigation led to the
conclusion that the problem happened because acpi_reserve_resources()
was executed at the device_initcall() stage of system initialization
which wasn't strictly ordered with respect to driver initialization
(and with respect to the initialization of the pcieport driver in
particular), so a random change causing the device initcalls to be
run in a different order might break things.
The response to that was to attempt to run acpi_reserve_resources()
as soon as we knew that ACPI would be in use (commit b9a5e5e18fbf).
However, that turned out to be too early, because it caused resource
reservations made by the PNP system driver to fail on at least one
system and that failure was addressed by commit 0f1b414d1907.
That fix still turned out to be insufficient, though, because
calling acpi_reserve_resources() before the fs_initcall stage of
system initialization caused a boot regression to happen on the
eCAFE EC-800-H20G/S netbook. That meant that we only could call
acpi_reserve_resources() at the fs_initcall initialization stage
or later, but then we might just as well call it after the PNP
initalization in which case commit 0f1b414d1907 wouldn't be
necessary any more.
For this reason, the changes made by commit 0f1b414d1907 are reverted
(along with a memory leak fixup on top of that commit), the changes
made by commit b9a5e5e18fbf that went too far are reverted too and
acpi_reserve_resources() is changed into fs_initcall_sync, which
will cause it to be executed after the PNP subsystem initialization
(which is an fs_initcall) and before device initcalls (including
the pcieport driver initialization) which should avoid the initial
issue.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=100581
Link: http://marc.info/?t=143092384600002&r=1&w=2
Link: https://bugzilla.kernel.org/show_bug.cgi?id=99831
Link: http://marc.info/?t=143389402600001&r=1&w=2
Fixes: b9a5e5e18fbf "ACPI / init: Fix the ordering of acpi_reserve_resources()"
Reported-by: Roland Dreier <roland@purestorage.com>
Cc: All applicable <stable@vger.kernel.org>
There is a small memory leak on error.
Fixes: 0f1b414d1907 (ACPI / PNP: Avoid conflicting resource reservations)
Commit b9a5e5e18fbf "ACPI / init: Fix the ordering of
acpi_reserve_resources()" overlooked the fact that the memory
and/or I/O regions reserved by acpi_reserve_resources() may
conflict with those reserved by the PNP "system" driver.
If that conflict actually takes place, it causes the reservations
made by the "system" driver to fail while before commit b9a5e5e18fbf
all reservations made by it and by acpi_reserve_resources() would be
successful. In turn, that allows the resources that haven't been
reserved by the "system" driver to be used by others (e.g. PCI) which
sometimes leads to functional problems (up to and including boot
failures).
To fix that issue, introduce a common resource reservation routine,
acpi_reserve_region(), to be used by both acpi_reserve_resources()
and the "system" driver, that will track all resources reserved by
it and avoid making conflicting requests.
An IO port or MMIO resource assigned to a PCI host bridge may be
consumed by the host bridge itself or available to its child
bus/devices. The ACPI specification defines a bit (Producer/Consumer)
to tell whether the resource is consumed by the host bridge itself,
but firmware hasn't used that bit consistently, so we can't rely on it.
Before commit 593669c2ac0f ("x86/PCI/ACPI: Use common ACPI resource
interfaces to simplify implementation"), arch/x86/pci/acpi.c ignored
all IO port resources defined by acpi_resource_io and
acpi_resource_fixed_io to filter out IO ports consumed by the host
bridge itself.
Commit 593669c2ac0f ("x86/PCI/ACPI: Use common ACPI resource interfaces
to simplify implementation") started accepting all IO port and MMIO
resources, which caused a regression that IO port resources consumed
by the host bridge itself became available to its child devices.
Then commit 63f1789ec716 ("x86/PCI/ACPI: Ignore resources consumed by
host bridge itself") ignored resources consumed by the host bridge
itself by checking the IORESOURCE_WINDOW flag, which accidently removed
MMIO resources defined by acpi_resource_memory24, acpi_resource_memory32
and acpi_resource_fixed_memory32.
On x86 and IA64 platforms, all IO port and MMIO resources are assumed
to be available to child bus/devices except one special case:
IO port [0xCF8-0xCFF] is consumed by the host bridge itself
to access PCI configuration space.
So explicitly filter out PCI CFG IO ports[0xCF8-0xCFF]. This solution
will also ease the way to consolidate ACPI PCI host bridge common code
from x86, ia64 and ARM64.
Related ACPI table are archived at:
https://bugzilla.kernel.org/show_bug.cgi?id=94221
Related discussions at:
http://patchwork.ozlabs.org/patch/461633/
https://lkml.org/lkml/2015/3/29/304
Fixes: 63f1789ec716 (Ignore resources consumed by host bridge itself)
Reported-by: Bernhard Thaler <bernhard.thaler@wvnet.at>
Reviewed-by: Bjorn Helgaas <bhelgaas@google.com>
Some BIOSes report incorrect length for ACPI address space descriptors,
so relax the checks to avoid regressions. This issue has appeared several
times as:
3162b6f0c5e1 ("PNPACPI: truncate _CRS windows with _LEN > _MAX - _MIN + 1")
d558b483d5a7 ("x86/PCI: truncate _CRS windows with _LEN > _MAX - _MIN + 1")
f238b414a74a ("PNPACPI: compute Address Space length rather than using _LEN")
48728e077480 ("x86/PCI: compute Address Space length rather than using _LEN")
Please refer to https://bugzilla.kernel.org/show_bug.cgi?id=94221
for more details and example malformed ACPI resource descriptors.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=94221
Fixes: 593669c2ac0f (x86/PCI/ACPI: Use common ACPI resource interfaces ...)
Tested-by: Dave Airlie <airlied@redhat.com>
Tested-by: Prakash Punnoor <prakash@punnoor.de>
Annoying and noisy ACPI debug messages are printed with pr_info()
after the recent ACPI resources handling rework. Replace the
pr_info() with pr_debug() to reduce to noise level.
Reported-by: Borislav Petkov <bp@alien8.de>
Currently ACPI, PCI and pnp all implement the same resource list
management with different data structure. We need to transfer from
one data structure into another when passing resources from one
subsystem into another subsystem. So move struct resource_list_entry
from ACPI into resource core and rename it as resource_entry,
then it could be reused by different subystems and avoid the data
structure conversion.
Introduce dedicated header file resource_ext.h instead of embedding
it into ioport.h to avoid header file inclusion order issues.
Acked-by: Vinod Koul <vinod.koul@intel.com>
Introduce helper function acpi_dev_filter_resource_type(), which may
be used by acpi_dev_get_resources() to filer out resource based on
resource type.
Add field offset to struct resource_list_entry to host address space
translation offset so it could be used to represent bridge resources.
Add translation_offset into the result address for bridge window
resources to form the master side address.
Currently acpi_dev_resource_{ext_}address_space() are only used for
devices instead of bridges, so it won't break current users. Later
it will be used to support PCI host bridge drivers.
Change function acpi_dev_resource_address_space() and
acpi_dev_resource_ext_address_space() to return address space
translation offset.
It's based on a patch from Yinghai Lu <yinghai@kernel.org>.
Enforce stricter checks for address space descriptors according to
ACPI spec.
Also set flag IORESOURCE_UNSET for unassigned resource in addition to
IORESOURCE_DISABLED to mark resource as unassigned.
Normalize return value of resource parse functions as:
1) return "true" if resource is assigned.
2) return "false" and IORESOURCE_DISABLED setting in res->flags if
resource is unassigned.
3) return "false" and zeroing res->flags if it's not an valid or
expected resource.
According to ACPI spec 5, section 6.4.3.1 "24-Bit Memory Range Descriptor",
minimum, maximum and address_length field in struct acpi_resource_memory24
is in granularity of 256-bytes. So shift 8-bit left to get correct address.
Add support of PREFETCH attributre to ACPI address space and extended
address space parser.
Normal memory and io resources have window always set to false. Move
the flag logic to the unified address space parser.
With the unions in place which let us identify the substructs we can
use a single parser for address_space and ext_address_space.
If the parser disables a resource during parsing, let it return false,
so the calling code does not need to implement further checks.
Also apply length check to IO resources.
[Jiang] Remove enforcement that resource starting address must be
non-zero.
Check whether the resulting length is the same as the given
length. Check for start <= end as well.
We need to hand in the resource for this, so we can apply the flags
directly.
non-zero.
The ACPI type is checked in acpi_resource_to_address64() anyway.
structures.
struct acpi_resource_address and struct acpi_resource_extended_address64 share substracts
just at different offsets. To unify the parsing functions, OSPMs like Linux
need a new ACPI_ADDRESS64_ATTRIBUTE as their substructs, so they can
extract the shared data.
This patch also synchronizes the structure changes to the Linux kernel.
The usages are searched by matching the following keywords:
1. acpi_resource_address
2. acpi_resource_extended_address
3. ACPI_RESOURCE_TYPE_ADDRESS
4. ACPI_RESOURCE_TYPE_EXTENDED_ADDRESS
And we found and fixed the usages in the following files:
arch/ia64/kernel/acpi-ext.c
arch/ia64/pci/pci.c
arch/x86/pci/acpi.c
arch/x86/pci/mmconfig-shared.c
drivers/xen/xen-acpi-memhotplug.c
drivers/acpi/acpi_memhotplug.c
drivers/acpi/pci_root.c
drivers/acpi/resource.c
drivers/char/hpet.c
drivers/pnp/pnpacpi/rsparser.c
drivers/hv/vmbus_drv.c
Build tests are passed with defconfig/allnoconfig/allyesconfig and
defconfig+CONFIG_ACPI=n.
Original-by: Thomas Gleixner <tglx@linutronix.de>
Original-by: Jiang Liu <jiang.liu@linux.intel.com>
Signed-off-by: Lv Zheng <lv.zheng@intel.com>
Change acpi_dev_resource_address_space() to return failure if the
acpi_resource structure can't be converted to an ACPI address64
structure, so caller could correctly detect failure.
Acked-by: Rafael J. Wysocki <rjw@rjwysocki.net>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Joerg Roedel <joro@8bytes.org>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Randy Dunlap <rdunlap@infradead.org>
Cc: Yinghai Lu <yinghai@kernel.org>
Cc: Len Brown <lenb@kernel.org>
Link: http://lkml.kernel.org/r/1414387308-27148-6-git-send-email-jiang.liu@linux.intel.com
The recently merged change (in v3.14-rc6) to ACPI resource detection
(below) causes all zero length ACPI resources to be elided from the
table:
commit b355cee88e3b1a193f0e9a81db810f6f83ad728b
Author: Zhang Rui <rui.zhang@intel.com>
Date: Thu Feb 27 11:37:15 2014 +0800
ACPI / resources: ignore invalid ACPI device resources
This change has caused a regression in (at least) serial port detection
for a number of machines (see LP#1313981 [1]). These seem to represent
their IO regions (presumably incorrectly) as a zero length region.
Reverting the above commit restores these serial devices.
Only elide zero length resources which lie at address 0.
Fixes: b355cee88e3b (ACPI / resources: ignore invalid ACPI device resources)
Signed-off-by: Andy Whitcroft <apw@canonical.com>
Acked-by: Zhang Rui <rui.zhang@intel.com>
Cc: 3.14+ <stable@vger.kernel.org> # 3.14+
ACPI table may export resource entry with 0 length.
But the current code interprets this kind of resource in a wrong way.
It will create a resource structure with
res->end = acpi_resource->start + acpi_resource->len - 1;
This patch fixes a problem on my machine that a platform device fails
to be created because one of its ACPI IO resource entry (start = 0,
end = 0, length = 0) is translated into a generic resource with
start = 0, end = 0xffffffff.
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
Introduce helper function acpi_has_method() and use it in a number
of places to simplify code.
[rjw: Changelog]
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
acpi_get_override_irq() was added because there was a problem with
buggy BIOSes passing wrong IRQ() resource for the RTC IRQ. The
commit that added the workaround was 61fd47e0c8476 (ACPI: fix two
IRQ8 issues in IOAPIC mode).
With ACPI 5 enumerated devices there are typically one or more
extended IRQ resources per device (and these IRQs can be shared).
However, the acpi_get_override_irq() workaround forces all IRQs in
range 0 - 15 (the legacy ISA IRQs) to be edge triggered, active high
as can be seen from the dmesg below:
ACPI: IRQ 6 override to edge, high
ACPI: IRQ 7 override to edge, high
ACPI: IRQ 13 override to edge, high
Also /proc/interrupts for the I2C controllers (INT33C2 and INT33C3) shows
the same thing:
7: 4 0 0 0 IO-APIC-edge INT33C2:00, INT33C3:00
The _CSR method for INT33C2 (and INT33C3) device returns following
resource:
Interrupt (ResourceConsumer, Level, ActiveLow, Shared,,, )
0x00000007,
which states that this is supposed to be level triggered, active low,
shared IRQ instead.
Fix this by making sure that acpi_get_override_irq() gets only called
when we are dealing with legacy IRQ() or IRQNoFlags() descriptors.
While we are there, correct pr_warning() to print the right triggering
value.
This change turns out to be necessary to make DMA work correctly on
systems based on the Intel Lynxpoint PCH (Platform Controller Hub).
[rjw: Changelog]
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Cc: 3.9+ <stable@vger.kernel.org>
There is no need to initialize the node before appending it to the list.
Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Currently acpi_dev_process_resource() returns AE_ABORT_METHOD
to terminate the acpi_walk_resources() it is called from if
the .preproc() routine provided by the caller of
acpi_dev_get_resources() initiating the resources walk returns
an error code. It is better to use AE_CTRL_TERMINATE for this
purpose, however, so do that.
Currently, whoever wants to use ACPI device resources has to call
acpi_walk_resources() to browse the buffer returned by the _CRS
method for the given device and create filters passed to that
routine to apply to the individual resource items. This generally
is cumbersome, time-consuming and inefficient. Moreover, it may
be problematic if resource conflicts need to be resolved, because
the different users of _CRS will need to do that in a consistent
way. However, if there are resource conflicts, the ACPI core
should be able to resolve them centrally instead of relying on
various users of acpi_walk_resources() to handle them correctly
together.
For this reason, introduce a new function, acpi_dev_get_resources(),
that can be used by subsystems to obtain a list of struct resource
objects corresponding to the ACPI device resources returned by
_CRS and, if necessary, to apply additional preprocessing routine
to the ACPI resources before converting them to the struct resource
format.
Make the ACPI code that creates platform device objects use
acpi_dev_get_resources() for resource processing instead of executing
acpi_walk_resources() twice by itself, which causes it to be much
more straightforward and easier to follow.
In the future, acpi_dev_get_resources() can be extended to meet
the needs of the ACPI PNP subsystem and other users of _CRS in
the kernel.
Tested-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Move some code used for parsing ACPI device resources from the PNP
subsystem to the ACPI core, so that other bus types (platform, SPI,
I2C) can use the same routines for parsing resources in a consistent
way, without duplicating code.
