path: root/drivers/acpi/pci_root.c
2009-09-19Merge branch 'sfi-base' into releaseLen Brown
Conflicts: drivers/acpi/power.c Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-09ACPI: export acpi_pci_root and friendsAlex Chiang
We can simplify ACPI drivers if we can tell whether a handle is an ACPI PCI root or not. Reviewed-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-08-28ACPI: Move definition of PREFIX from acpi_bus.h to internal..hLen Brown
Linux/ACPI core files using internal.h all PREFIX "ACPI: ", however, not all ACPI drivers use/want it -- and they should not have to #undef PREFIX to define their own. Add GPL commment to internal.h while we are there. This does not change any actual console output, asside from a whitespace fix. Signed-off-by: Len Brown <len.brown@intel.com>
2009-06-26ACPI: video: prevent NULL deref in acpi_get_pci_dev()Troy Moure
ref: http://thread.gmane.org/gmane.linux.kernel/857228/focus=857468 When the ACPI video driver initializes, it does a namespace walk looking for for supported devices. When we find an appropriate handle, we walk up the ACPI tree looking for a PCI root bus, and then walk back down the PCI bus, assuming that every device inbetween is a P2P bridge. This assumption is not correct, and is reported broken on at least: Dell Latitude E6400 ThinkPad X61 Dell XPS M1330 Add a NULL deref check to prevent boot panics. Reported-by: Alessandro Suardi <alessandro.suardi@gmail.com> Signed-off-by: Troy Moure <twmoure@szypr.net> Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-06-24Merge branches 'acerhdf', 'acpi-pci-bind', 'bjorn-pci-root', ↵Len Brown
'bugzilla-12904', 'bugzilla-13121', 'bugzilla-13396', 'bugzilla-13533', 'bugzilla-13612', 'c3_lock', 'hid-cleanups', 'misc-2.6.31', 'pdc-leak-fix', 'pnpacpi', 'power_nocheck', 'thinkpad_acpi', 'video' and 'wmi' into release
2009-06-20ACPI: pci_root: remove unused dev/fn informationBjorn Helgaas
We never use the PCI device & function number, so remove it to make it clear that it's not needed. Many PCI host bridges don't even appear in config space, so it's meaningless to look at stuff from _ADR, which doesn't exist in that case. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Reviewed-by: Alex Chiang <achiang@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-06-20ACPI: pci_root: simplify list traversalsBjorn Helgaas
Using list_for_each_entry() makes traversing the root list easier. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Reviewed-by: Alex Chiang <achiang@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-06-20ACPI: pci_root: use driver data rather than list lookupBjorn Helgaas
There's no need to search the list to find the acpi_pci_root structure. We saved it as device->driver_data when we added the device. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-06-20ACPI: pci_root: simplify acpi_pci_root_add() control flowBjorn Helgaas
By looking up the segment & bus number earlier, we don't have to worry about cleaning up if it fails. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-06-20ACPI: pci_root: check _CRS, then _BBN for downstream bus numberBjorn Helgaas
To find a host bridge's downstream bus number, we currently look at _BBN first. If _BBN returns a bus number we've already seen, we conclude that _BBN was wrong and look for a bus number in _CRS. However, the spec[1] (figure 5-5 and the example in sec 9.12.1) and an ACPI FAQ[2] suggest that the OS should use _CRS to discover the bus number range, and that _BBN is really intended to bootstrap _CRS methods that reference PCI opregions. This patch makes us always look at _CRS first. If _CRS doesn't supply a bus number, we look at _BBN. If _BBN doesn't exist, we default to zero. This makes the behavior consistent regardless of device discovery order. Previously, if A and B had duplicate _BBNs and we found A first, we'd only look at B's _CRS, whereas if we found B first, we'd only look at A's _CRS. I'm told that Windows discovers host bridge bus numbers using _CRS, so it should be fairly safe to rely on this BIOS functionality. This patch also removes two misleading messages: we printed the "Wrong _BBN value, reboot and use option 'pci=noacpi'" message before looking at _CRS, so we would likely find the bus number in _CRS, the system would work fine, and the user would be confused. The "PCI _CRS %d overrides _BBN 0" message incorrectly assumes _BBN was zero, and it's useless anyway because we print the segment/bus number a few lines later. References: [1] http://www.acpi.info/DOWNLOADS/ACPIspec30b.pdf [2] http://www.acpi.info/acpi_faq.htm _BBN/_CRS discussion http://download.microsoft.com/download/9/8/f/98f3fe47-dfc3-4e74-92a3-088782200fe7/TWAR05005_WinHEC05.ppt (slide 17) http://bugzilla.kernel.org/show_bug.cgi?id=1662 ASUS PR-DLS http://bugzilla.kernel.org/show_bug.cgi?id=1127 ASUS PR-DLSW http://bugzilla.kernel.org/show_bug.cgi?id=1741 ASUS PR-DLS533 Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Reviewed-by: Alex Chiang <achiang@hp.com> CC: Shaohua Li <shaohua.li@intel.com> CC: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-06-17ACPI: simplify acpi_pci_irq_add_prt() APIAlexander Chiang
A PCI domain cannot change as you descend down subordinate buses, which makes the 'segment' argument to acpi_pci_irq_add_prt() useless. Change the interface to take a struct pci_bus *, from whence we can derive the bus number and segment. Reducing the number of arguments makes life simpler for callers. Signed-off-by: Alex Chiang <achiang@hp.com> Acked-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-06-17ACPI: eviscerate pci_bind.cAlexander Chiang
Now that we can dynamically convert an ACPI CA handle to a struct pci_dev at runtime, there's no need to statically bind them during boot. acpi_pci_bind/unbind are vastly simplified, and are only used to evaluate _PRT methods on P2P bridges and non-bridge children. This patch also changes the time-space tradeoff ever so slightly. Looking up the ACPI-PCI binding is never in the performance path, and by eliminating this caching, we save 24 bytes for each _ADR device in the ACPI namespace. This patch lays further groundwork to eventually eliminate the acpi_driver_ops.bind callback. Signed-off-by: Alex Chiang <achiang@hp.com> Acked-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-06-17ACPI: Introduce acpi_get_pci_dev()Alexander Chiang
Convert an ACPI CA handle to a struct pci_dev. Performing this lookup dynamically allows us to get rid of the ACPI-PCI binding code, which: - eliminates struct acpi_device vs struct pci_dev lifetime issues - lays more groundwork for eliminating .start from acpi_device_ops and thus simplifying ACPI drivers - whacks out a lot of code This change lays the groundwork for eliminating much of pci_bind.c. Although pci_root.c may not be the most logical place for this change, putting it here saves us from having to export acpi_pci_find_root. Signed-off-by: Alex Chiang <achiang@hp.com> Acked-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-06-17ACPI: Introduce acpi_is_root_bridge()Alexander Chiang
Returns whether an ACPI CA node is a PCI root bridge or not. This API is generically useful, and shouldn't just be a hotplug function. The implementation becomes much simpler as well. Signed-off-by: Alex Chiang <achiang@hp.com> Acked-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-06-17ACPI: make acpi_pci_bind() staticAlexander Chiang
acpi_pci_root_add() explicitly assigns device->ops.bind, and later calls acpi_pci_bind_root(), which also does the same thing. We don't need to repeat ourselves; removing the explicit assignment allows us to make acpi_pci_bind() static. Signed-off-by: Alex Chiang <achiang@hp.com> Acked-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-03-19PCI/ACPI: rename pci_osc_control_set()Kenji Kaneshige
- Rename pci_osc_control_set() to acpi_pci_osc_control_set() according to the other API names in drivers/acpi/pci_root.c. - Move _OSC related definitions to include/linux/acpi.h because _OSC related API is implemented in drivers/acpi/pci_root.c now. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Reviewed-by: Andrew Patterson <andrew.patterson@hp.com> Tested-by: Andrew Patterson <andrew.patterson@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-19PCI/ACPI: move _OSC code to pci_root.cKenji Kaneshige
Move PCI _OSC management code from drivers/pci/pci-acpi.c to drivers/acpi/pci_root.c. The benefits are - We no longer need struct osc_data and its management code (contents are moved to struct acpi_pci_root). This simplify the code, and we no longer care about kmalloc() failure. - We can make pci_acpi_osc_support() be a static function, which is called only from drivers/acpi/pci_root.c. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Reviewed-by: Andrew Patterson <andrew.patterson@hp.com> Tested-by: Andrew Patterson <andrew.patterson@hp.com> Acked-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07ACPI/PCI: PCI MSI _OSC support capabilities called when root bridge addedAndrew Patterson
The _OSC capability OSC_MSI_SUPPORT is set when the root bridge is added with pci_acpi_osc_support(), so we no longer need to do it in the PCI MSI driver. Also adds the function pci_msi_enabled, which returns true if pci=nomsi is not on the kernel command-line. Signed-off-by: Andrew Patterson <andrew.patterson@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07ACPI/PCI: PCIe ASPM _OSC support capabilities called when root bridge addedAndrew Patterson
The _OSC capabilities OSC_ACTIVE_STATE_PWR_SUPPORT and OSC_CLOCK_PWR_CAPABILITY_SUPPORT are set when the root bridge is added with pci_acpi_osc_support(), so we no longer need to do it in the ASPM driver. Also add the function pcie_aspm_enabled, which returns true if pcie_aspm=off is not on the kernel command-line. Signed-off-by: Andrew Patterson <andrew.patterson@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07ACPI/PCI: PCI extended config _OSC support called when root bridge addedAndrew Patterson
The _OSC capability OSC_EXT_PCI_CONFIG_SUPPORT is set when the root bridge is added with pci_acpi_osc_support() if we can access PCI extended config space. This adds the function pci_ext_cfg_avail which returns true if we can access PCI extended config space (offset greater than 0xff). It currently only returns false if arch=x86 and raw_pci_ext_ops is not set (which might happen if pci=nommcfg is set on the kernel command-line). Signed-off-by: Andrew Patterson <andrew.patterson@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07ACPI/PCI: call _OSC support during root bridge discoveryAndrew Patterson
Add pci_acpi_osc_support() and call it when a PCI bridge is added. This allows us to avoid having every individual PCI root bridge driver call _OSC support for every root bridge in their probe functions, a significant savings in boot time. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-11-06ACPI: remove comments about debug layer/level to useBjorn Helgaas
I don't think there's any point in cluttering the code with these. Better to improve the documentation so *anybody* can figure out what layer & level to use. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-22Merge branch 'ull' into testLen Brown
Conflicts: drivers/acpi/bay.c drivers/acpi/dock.c drivers/ata/libata-acpi.c Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-11ACPI: Change acpi_evaluate_integer to support 64-bit on 32-bit kernelsMatthew Wilcox
As of version 2.0, ACPI can return 64-bit integers. The current acpi_evaluate_integer only supports 64-bit integers on 64-bit platforms. Change the argument to take a pointer to an acpi_integer so we support 64-bit integers on all platforms. lenb: replaced use of "acpi_integer" with "unsigned long long" lenb: fixed bug in acpi_thermal_trips_update() Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-10ACPI: catch calls of acpi_driver_data on pointer of wrong typePavel Machek
Catch attempts to use of acpi_driver_data on pointers of wrong type. akpm: rewritten to use proper C typechecking and remove the "function"-used-as-lvalue thing. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-21ACPI: fix section mismatch in acpi_pci_root_addSam Ravnborg
Fix following warning: WARNING: vmlinux.o(.text+0x550e85): Section mismatch in reference from the function acpi_pci_root_add() to the function .devinit.text:pci_acpi_scan_root() acpi_pci_root_add uses a __devinit annotated function and it looks like annotating it __devinit too is the correct fix. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Len Brown <len.brown@intel.com>
2007-07-23ACPI: autoload modules - Create __mod_acpi_device_table symbol for all ACPI ↵Thomas Renninger
drivers modpost is going to use these to create e.g. acpi:ACPI0001 in modules.alias. Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-12ACPI: delete extra #defines in /drivers/acpi/ driversLen Brown
Cosmetic only. Except in a single case, #define ACPI_*_DRIVER_NAME were invoked 0 or 1 times. Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-12ACPI: fix acpi_driver.name usageLen Brown
It was erroneously used as a description rather than a name. ie. turn this: lenb@se7525gp2:/sys> ls bus/acpi/drivers ACPI AC Adapter Driver ACPI Embedded Controller Driver ACPI Power Resource Driver ACPI Battery Driver ACPI Fan Driver ACPI Processor Driver ACPI Button Driver ACPI PCI Interrupt Link Driver ACPI Thermal Zone Driver ACPI container driver ACPI PCI Root Bridge Driver hpet into this: lenb@se7525gp2:~> ls /sys/bus/acpi/drivers ac battery button container ec fan hpet pci_link pci_root power processor thermal Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-12ACPI: clean up ACPI_MODULE_NAME() useLen Brown
cosmetic only Make "module name" actually match the file name. Invoke with ';' as leaving it off confuses Lindent and gcc doesn't care. Fix indentation where Lindent did get confused. Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-03Pull sysfs into test branchLen Brown
Conflicts: Documentation/feature-removal-schedule.txt include/acpi/acpi_drivers.h Signed-off-by: Len Brown <len.brown@intel.com>
2007-01-16ACPI: Optimize acpi_get_pci_rootbridge_handle() to boot fasterJustin Chen
Move acpi_get_pci_rootbridge_handle() from glue.c to pci_root.c and get the root bridge ACPI handles by searching the &acpi_pci_roots list instead of walking through the ACPI name space. This significantly reduces boot time on large I/O systems. Signed-off-by: Justin Chen <justin.chen@hp.com> Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-12-21ACPI: fix Supermicro X7DB8+ Boot regressionRui Zhang
http://bugzilla.kernel.org/show_bug.cgi?id=7695 Originally we converted bind/unbind to use a new pci bridge driver. The driver will add/remove _PRT, so we can eventually remove .bind/.unbind methods. But we found that some of the _ADR-Based devices don't have _PRT, i.e. they are not managed by the new ACPI PCI bridge driver. So that .bind method is not called for some _ADR-Based devices, which leads to a failure. Now we make ACPI PCI Root Bridge Driver scan and binds all _ADR-Based devices once the driver is loaded, in the .add method of ACPI PCI Root Bridge driver. Extra code path for calling .bind/.unbind when _ADR-Based devices are hot added/removed is also added. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-12-20ACPI: replace kmalloc+memset with kzallocBurman Yan
Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2006-12-20Pull bugfix into test branchLen Brown
2006-12-20ACPI: fix single linked list manipulationAkinobu Mita
Fix single linked list manipulation for sub_driver. If the remving entry is not on the head of the sub_driver list, it goes into infinate loop. Though that infinite loop doesn't happen. Because the only user of acpi_pci_register_dirver() is acpiphp. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2006-12-15ACPI: Convert ACPI PCI .bind/.unbind to use PCI bridge driverLi Shaohua
acpi_device had a .bind/.unbind methods, but Linux driver model does not. Cut ACPI PCI code over to use the Linux driver model methods. Convert bind/unbind to use a new pci bridge driver. The driver will add/remove _PRT, so we can eventually remove .bind/.unbind methods. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-10-14ACPI: Remove unnecessary from/to-void* and to-void casts in drivers/acpiJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-30ACPI: pci_root: Remove unneeded acpi_handle from driver.Patrick Mochel
Signed-off-by: Patrick Mochel <mochel@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-30ACPI: pci_root: Use acpi_device's handle instead of driver'sPatrick Mochel
2006-06-30ACPI: pci root: add struct acpi_device to struct acpi_pci_root.Patrick Mochel
2006-06-27ACPI: delete tracing macros from drivers/acpi/*.cPatrick Mochel
2006-06-27ACPI: un-export ACPI_ERROR() -- use printk(KERN_ERR...)Len Brown
2006-06-26ACPI: Enable ACPI error messages w/o CONFIG_ACPI_DEBUGThomas Renninger
2005-12-10[ACPI] ACPICA 20050930Bob Moore
Completed a major overhaul of the Resource Manager code - specifically, optimizations in the area of the AML/internal resource conversion code. The code has been optimized to simplify and eliminate duplicated code, CPU stack use has been decreased by optimizing function parameters and local variables, and naming conventions across the manager have been standardized for clarity and ease of maintenance (this includes function, parameter, variable, and struct/typedef names.) All Resource Manager dispatch and information tables have been moved to a single location for clarity and ease of maintenance. One new file was created, named "rsinfo.c". The ACPI return macros (return_ACPI_STATUS, etc.) have been modified to guarantee that the argument is not evaluated twice, making them less prone to macro side-effects. However, since there exists the possibility of additional stack use if a particular compiler cannot optimize them (such as in the debug generation case), the original macros are optionally available. Note that some invocations of the return_VALUE macro may now cause size mismatch warnings; the return_UINT8 and return_UINT32 macros are provided to eliminate these. (From Randy Dunlap) Implemented a new mechanism to enable debug tracing for individual control methods. A new external interface, acpi_debug_trace(), is provided to enable this mechanism. The intent is to allow the host OS to easily enable and disable tracing for problematic control methods. This interface can be easily exposed to a user or debugger interface if desired. See the file psxface.c for details. acpi_ut_callocate() will now return a valid pointer if a length of zero is specified - a length of one is used and a warning is issued. This matches the behavior of acpi_ut_allocate(). Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-09-22[ACPI] handle ACPICA 20050916's acpi_resource.type renameLen Brown
2005-08-05[ACPI] Lindent all ACPI filesLen Brown
2005-06-27[PATCH] acpi bridge hotadd: ACPI based root bridge hot-addRajesh Shah
When you hot-plug a (root) bridge hierarchy, it may have p2p bridges and devices attached to it that have not been configured by firmware. In this case, we need to configure the devices before starting them. This patch separates device start from device scan so that we can introduce the configuration step in the middle. I kept the existing semantics for pci_scan_bus() since there are a huge number of callers to that function. Also, I have no way of testing the changes I made to the parisc files, so this needs review by those folks. Sorry for the massive cross-post, this touches files in many different places. Signed-off-by: Rajesh Shah <rajesh.shah@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
