Enable support of IOAPIC hotplug by:
1) reintroducing ACPI based IOAPIC driver
2) enhance pci_root driver to hook hotplug events
The ACPI IOAPIC driver is always enabled if all of ACPI, PCI and IOAPIC
are enabled.
Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Joerg Roedel <joro@8bytes.org>
Cc: Rafael J. Wysocki <rjw@rjwysocki.net>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Randy Dunlap <rdunlap@infradead.org>
Cc: Yinghai Lu <yinghai@kernel.org>
Cc: Len Brown <lenb@kernel.org>
Link: http://lkml.kernel.org/r/1414387308-27148-19-git-send-email-jiang.liu@linux.intel.com
structures.
struct acpi_resource_address and struct acpi_resource_extended_address64 share substracts
just at different offsets. To unify the parsing functions, OSPMs like Linux
need a new ACPI_ADDRESS64_ATTRIBUTE as their substructs, so they can
extract the shared data.
This patch also synchronizes the structure changes to the Linux kernel.
The usages are searched by matching the following keywords:
1. acpi_resource_address
2. acpi_resource_extended_address
3. ACPI_RESOURCE_TYPE_ADDRESS
4. ACPI_RESOURCE_TYPE_EXTENDED_ADDRESS
And we found and fixed the usages in the following files:
arch/ia64/kernel/acpi-ext.c
arch/ia64/pci/pci.c
arch/x86/pci/acpi.c
arch/x86/pci/mmconfig-shared.c
drivers/xen/xen-acpi-memhotplug.c
drivers/acpi/acpi_memhotplug.c
drivers/acpi/pci_root.c
drivers/acpi/resource.c
drivers/char/hpet.c
drivers/pnp/pnpacpi/rsparser.c
drivers/hv/vmbus_drv.c
Build tests are passed with defconfig/allnoconfig/allyesconfig and
defconfig+CONFIG_ACPI=n.
Original-by: Thomas Gleixner <tglx@linutronix.de>
Original-by: Jiang Liu <jiang.liu@linux.intel.com>
Signed-off-by: Lv Zheng <lv.zheng@intel.com>
Finally enhance pci_root driver to support DMAR device hotplug when
hot-plugging PCI host bridges.
Reviewed-by: Yijing Wang <wangyijing@huawei.com>
Acked-by: Bjorn Helgaas <bhelgaas@google.com>
Signed-off-by: Joerg Roedel <jroedel@suse.de>
Apple hardware queries _OSI("Darwin") in order to determine whether the
system is running OS X, and changes firmware behaviour based on the
answer. The most obvious difference in behaviour is that Thunderbolt
hardware is forcibly powered down unless the system is running OS X. The
obvious solution would be to simply add Darwin to the list of supported
_OSI strings, but this causes problems.
Recent Apple hardware includes two separate methods for checking _OSI
strings. The first will check whether Darwin is supported, and if so
will exit. The second will check whether Darwin is supported, but will
then continue to check for further operating systems. If a further
operating system is found then later firmware code will assume that the
OS is not OS X. This results in the unfortunate situation where the
Thunderbolt controller is available at boot time but remains powered
down after suspend.
The easiest way to handle this is to special-case it in the
Linux-specific OSI handling code. If we see Darwin, we should answer
true and then disable all other _OSI vendor strings.
The next problem is that the Apple PCI _OSC method has the following
code:
if (LEqual (0x01, OSDW ()))
if (LAnd (LEqual (Arg0, GUID), NEXP)
(do stuff)
else
(fail)
NEXP is a value in high memory and is presumably under the control of
the firmware. No methods sets it. The methods that are called in the "do
stuff" path are dummies. Unless there's some additional firmware call in
early boot, there's no way for this call to succeed - and even if it
does, it doesn't do anything.
The easiest way to handle this is simply to ignore it. We know which
flags would be set, so just set them by hand if the platform is running
in Darwin mode.
Signed-off-by: Matthew Garrett <matthew.garrett@nebula.com>
[andreas.noever@gmail.com: merged two patches, do not touch ACPICA]
Signed-off-by: Andreas Noever <andreas.noever@gmail.com>
Since ACPI wakeup GPEs are going to be enabled during system suspend
as well as for runtime wakeup by a subsequent patch and the same
notify handlers will be used in both cases, rework the ACPI device
wakeup notification framework so that the part specific to physical
devices is always run asynchronously from the PM workqueue. This
prevents runtime resume callbacks for those devices from being
run during system suspend and resume which may not be appropriate,
among other things.
Also make ACPI device wakeup notification handling a bit more robust
agaist subsequent removal of ACPI device objects, whould that ever
happen, and create a wakeup source object for each ACPI device
configured for wakeup so that wakeup notifications for those
devices can wake up the system from the "freeze" sleep state.
'acpi-button'
* acpi-cleanup:
ACPI: Remove duplicate definitions of PREFIX
ACPI / tables: Replace printk with pr_*
* acpi-thermal:
ACPI / thermal: make acpi_thermal_check asynchronous on resume
* acpi-pci:
ACPI / PCI: Do not call ISA-specific code if ISA is not supported
* acpi-lpss:
ACPI / LPSS: Add Intel BayTrail ACPI mode PWM
* acpi-button:
ACPI / button: Add ACPI Button event via netlink routine
We already have a macro for PREFIX of "ACPI: " in
drivers/acpi/internal.h, so remove the duplicate ones
in ACPI drivers when internal.h is included.
Signed-off-by: Hanjun Guo <hanjun.guo@linaro.org>
Since the only existing caller of acpiphp_check_host_bridge(),
which is acpi_pci_root_scan_dependent(), already has a struct
acpi_device pointer needed to obtain the ACPIPHP context, it
doesn't make sense to execute acpi_bus_get_device() on its
handle in acpiphp_handle_to_bridge() just in order to get that
pointer back.
For this reason, modify acpiphp_check_host_bridge() to take
a struct acpi_device pointer as its argument and rearrange the
code accordingly.
Tested-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Pull ACPI and power management updates from Rafael Wysocki:
"As far as the number of commits goes, the top spot belongs to ACPI
this time with cpufreq in the second position and a handful of PM
core, PNP and cpuidle updates. They are fixes and cleanups mostly, as
usual, with a couple of new features in the mix.
The most visible change is probably that we will create struct
acpi_device objects (visible in sysfs) for all devices represented in
the ACPI tables regardless of their status and there will be a new
sysfs attribute under those objects allowing user space to check that
status via _STA.
Consequently, ACPI device eject or generally hot-removal will not
delete those objects, unless the table containing the corresponding
namespace nodes is unloaded, which is extremely rare. Also ACPI
container hotplug will be handled quite a bit differently and cpufreq
will support CPU boost ("turbo") generically and not only in the
acpi-cpufreq driver.
Specifics:
- ACPI core changes to make it create a struct acpi_device object for
every device represented in the ACPI tables during all namespace
scans regardless of the current status of that device. In
accordance with this, ACPI hotplug operations will not delete those
objects, unless the underlying ACPI tables go away.
- On top of the above, new sysfs attribute for ACPI device objects
allowing user space to check device status by triggering the
execution of _STA for its ACPI object. From Srinivas Pandruvada.
- ACPI core hotplug changes reducing code duplication, integrating
the PCI root hotplug with the core and reworking container hotplug.
- ACPI core simplifications making it use ACPI_COMPANION() in the
code "glueing" ACPI device objects to "physical" devices.
- ACPICA update to upstream version 20131218. This adds support for
the DBG2 and PCCT tables to ACPICA, fixes some bugs and improves
debug facilities. From Bob Moore, Lv Zheng and Betty Dall.
- Init code change to carry out the early ACPI initialization
earlier. That should allow us to use ACPI during the timekeeping
initialization and possibly to simplify the EFI initialization too.
From Chun-Yi Lee.
- Clenups of the inclusions of ACPI headers in many places all over
from Lv Zheng and Rashika Kheria (work in progress).
- New helper for ACPI _DSM execution and rework of the code in
drivers that uses _DSM to execute it via the new helper. From
Jiang Liu.
- New Win8 OSI blacklist entries from Takashi Iwai.
- Assorted ACPI fixes and cleanups from Al Stone, Emil Goode, Hanjun
Guo, Lan Tianyu, Masanari Iida, Oliver Neukum, Prarit Bhargava,
Rashika Kheria, Tang Chen, Zhang Rui.
- intel_pstate driver updates, including proper Baytrail support,
from Dirk Brandewie and intel_pstate documentation from Ramkumar
Ramachandra.
- Generic CPU boost ("turbo") support for cpufreq from Lukasz
Majewski.
- powernow-k6 cpufreq driver fixes from Mikulas Patocka.
- cpufreq core fixes and cleanups from Viresh Kumar, Jane Li, Mark
Brown.
- Assorted cpufreq drivers fixes and cleanups from Anson Huang, John
Tobias, Paul Bolle, Paul Walmsley, Sachin Kamat, Shawn Guo, Viresh
Kumar.
- cpuidle cleanups from Bartlomiej Zolnierkiewicz.
- Support for hibernation APM events from Bin Shi.
- Hibernation fix to avoid bringing up nonboot CPUs with ACPI EC
disabled during thaw transitions from Bjørn Mork.
- PM core fixes and cleanups from Ben Dooks, Leonardo Potenza, Ulf
Hansson.
- PNP subsystem fixes and cleanups from Dmitry Torokhov, Levente
Kurusa, Rashika Kheria.
- New tool for profiling system suspend from Todd E Brandt and a
cpupower tool cleanup from One Thousand Gnomes"
* tag 'pm+acpi-3.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (153 commits)
thermal: exynos: boost: Automatic enable/disable of BOOST feature (at Exynos4412)
cpufreq: exynos4x12: Change L0 driver data to CPUFREQ_BOOST_FREQ
Documentation: cpufreq / boost: Update BOOST documentation
cpufreq: exynos: Extend Exynos cpufreq driver to support boost
cpufreq / boost: Kconfig: Support for software-managed BOOST
acpi-cpufreq: Adjust the code to use the common boost attribute
cpufreq: Add boost frequency support in core
intel_pstate: Add trace point to report internal state.
cpufreq: introduce cpufreq_generic_get() routine
ARM: SA1100: Create dummy clk_get_rate() to avoid build failures
cpufreq: stats: create sysfs entries when cpufreq_stats is a module
cpufreq: stats: free table and remove sysfs entry in a single routine
cpufreq: stats: remove hotplug notifiers
cpufreq: stats: handle cpufreq_unregister_driver() and suspend/resume properly
cpufreq: speedstep: remove unused speedstep_get_state
platform: introduce OF style 'modalias' support for platform bus
PM / tools: new tool for suspend/resume performance optimization
ACPI: fix module autoloading for ACPI enumerated devices
ACPI: add module autoloading support for ACPI enumerated devices
ACPI: fix create_modalias() return value handling
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
"PCI changes for the v3.14 merge window:
Resource management
- Change pci_bus_region addresses to dma_addr_t (Bjorn Helgaas)
- Support 64-bit AGP BARs (Bjorn Helgaas, Yinghai Lu)
- Add pci_bus_address() to get bus address of a BAR (Bjorn Helgaas)
- Use pci_resource_start() for CPU address of AGP BARs (Bjorn Helgaas)
- Enforce bus address limits in resource allocation (Yinghai Lu)
- Allocate 64-bit BARs above 4G when possible (Yinghai Lu)
- Convert pcibios_resource_to_bus() to take pci_bus, not pci_dev (Yinghai Lu)
PCI device hotplug
- Major rescan/remove locking update (Rafael J. Wysocki)
- Make ioapic builtin only (not modular) (Yinghai Lu)
- Fix release/free issues (Yinghai Lu)
- Clean up pciehp (Bjorn Helgaas)
- Announce pciehp slot info during enumeration (Bjorn Helgaas)
MSI
- Add pci_msi_vec_count(), pci_msix_vec_count() (Alexander Gordeev)
- Add pci_enable_msi_range(), pci_enable_msix_range() (Alexander Gordeev)
- Deprecate "tri-state" interfaces: fail/success/fail+info (Alexander Gordeev)
- Export MSI mode using attributes, not kobjects (Greg Kroah-Hartman)
- Drop "irq" param from *_restore_msi_irqs() (DuanZhenzhong)
SR-IOV
- Clear NumVFs when disabling SR-IOV in sriov_init() (ethan.zhao)
Virtualization
- Add support for save/restore of extended capabilities (Alex Williamson)
- Add Virtual Channel to save/restore support (Alex Williamson)
- Never treat a VF as a multifunction device (Alex Williamson)
- Add pci_try_reset_function(), et al (Alex Williamson)
AER
- Ignore non-PCIe error sources (Betty Dall)
- Support ACPI HEST error sources for domains other than 0 (Betty Dall)
- Consolidate HEST error source parsers (Bjorn Helgaas)
- Add a TLP header print helper (Borislav Petkov)
Freescale i.MX6
- Remove unnecessary code (Fabio Estevam)
- Make reset-gpio optional (Marek Vasut)
- Report "link up" only after link training completes (Marek Vasut)
- Start link in Gen1 before negotiating for Gen2 mode (Marek Vasut)
- Fix PCIe startup code (Richard Zhu)
Marvell MVEBU
- Remove duplicate of_clk_get_by_name() call (Andrew Lunn)
- Drop writes to bridge Secondary Status register (Jason Gunthorpe)
- Obey bridge PCI_COMMAND_MEM and PCI_COMMAND_IO bits (Jason Gunthorpe)
- Support a bridge with no IO port window (Jason Gunthorpe)
- Use max_t() instead of max(resource_size_t,) (Jingoo Han)
- Remove redundant of_match_ptr (Sachin Kamat)
- Call pci_ioremap_io() at startup instead of dynamically (Thomas Petazzoni)
NVIDIA Tegra
- Disable Gen2 for Tegra20 and Tegra30 (Eric Brower)
Renesas R-Car
- Add runtime PM support (Valentine Barshak)
- Fix rcar_pci_probe() return value check (Wei Yongjun)
Synopsys DesignWare
- Fix crash in dw_msi_teardown_irq() (Bjørn Erik Nilsen)
- Remove redundant call to pci_write_config_word() (Bjørn Erik Nilsen)
- Fix missing MSI IRQs (Harro Haan)
- Add dw_pcie prefix before cfg_read/write (Pratyush Anand)
- Fix I/O transfers by using CPU (not realio) address (Pratyush Anand)
- Whitespace cleanup (Jingoo Han)
EISA
- Call put_device() if device_register() fails (Levente Kurusa)
- Revert EISA initialization breakage ((Bjorn Helgaas)
Miscellaneous
- Remove unused code, including PCIe 3.0 interfaces (Stephen Hemminger)
- Prevent bus conflicts while checking for bridge apertures (Bjorn Helgaas)
- Stop clearing bridge Secondary Status when setting up I/O aperture (Bjorn Helgaas)
- Use dev_is_pci() to identify PCI devices (Yijing Wang)
- Deprecate DEFINE_PCI_DEVICE_TABLE (Joe Perches)
- Update documentation 00-INDEX (Erik Ekman)"
* tag 'pci-v3.14-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (119 commits)
Revert "EISA: Initialize device before its resources"
Revert "EISA: Log device resources in dmesg"
vfio-pci: Use pci "try" reset interface
PCI: Check parent kobject in pci_destroy_dev()
xen/pcifront: Use global PCI rescan-remove locking
powerpc/eeh: Use global PCI rescan-remove locking
PCI: Fix pci_check_and_unmask_intx() comment typos
PCI: Add pci_try_reset_function(), pci_try_reset_slot(), pci_try_reset_bus()
MPT / PCI: Use pci_stop_and_remove_bus_device_locked()
platform / x86: Use global PCI rescan-remove locking
PCI: hotplug: Use global PCI rescan-remove locking
pcmcia: Use global PCI rescan-remove locking
ACPI / hotplug / PCI: Use global PCI rescan-remove locking
ACPI / PCI: Use global PCI rescan-remove locking in PCI root hotplug
PCI: Add global pci_lock_rescan_remove()
PCI: Cleanup pci.h whitespace
PCI: Reorder so actual code comes before stubs
PCI/AER: Support ACPI HEST AER error sources for PCI domains other than 0
ACPICA: Add helper macros to extract bus/segment numbers from HEST table.
PCI: Make local functions static
Multiple race conditions are possible between the addition and removal of
PCI devices during ACPI PCI host bridge hotplug and the generic PCI bus
rescan and device removal that can be triggered via sysfs.
To avoid those race conditions make the ACPI PCI host bridge addition and
removal code use global PCI rescan-remove locking.
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
drivers/acpi/scan.c
Replace direct inclusions of <acpi/acpi.h>, <acpi/acpi_bus.h> and
<acpi/acpi_drivers.h>, which are incorrect, with <linux/acpi.h>
inclusions and remove some inclusions of those files that aren't
necessary.
First of all, <acpi/acpi.h>, <acpi/acpi_bus.h> and <acpi/acpi_drivers.h>
should not be included directly from any files that are built for
CONFIG_ACPI unset, because that generally leads to build warnings about
undefined symbols in !CONFIG_ACPI builds. For CONFIG_ACPI set,
<linux/acpi.h> includes those files and for CONFIG_ACPI unset it
provides stub ACPI symbols to be used in that case.
Second, there are ordering dependencies between those files that always
have to be met. Namely, it is required that <acpi/acpi_bus.h> be included
prior to <acpi/acpi_drivers.h> so that the acpi_pci_root declarations the
latter depends on are always there. And <acpi/acpi.h> which provides
basic ACPICA type declarations should always be included prior to any other
ACPI headers in CONFIG_ACPI builds. That also is taken care of including
<linux/acpi.h> as appropriate.
Cc: Matthew Garrett <mjg59@srcf.ucam.org>
Acked-by: Bjorn Helgaas <bhelgaas@google.com> (drivers/pci stuff)
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> (Xen stuff)
* acpi-hotplug:
ACPI / hotplug: Fix conflicted PCI bridge notify handlers
* acpi-sysfs:
ACPI / sysfs: Fix incorrect ACPI tables walk in acpi_tables_sysfs_init()
ACPI / sysfs: Set file size for each exposed ACPI table
* acpi-sleep:
ACPI / sleep: clean up compiler warning about uninitialized field
Rework the common ACPI device hotplug code so that it is suitable
for PCI host bridge hotplug and switch the PCI host bridge scan
handler to using the common hotplug code.
This allows quite a few lines of code that are not necessary any more
to be dropped from the PCI host bridge scan handler and removes
arbitrary differences in behavior between PCI host bridge hotplug
and ACPI-based hotplug of other components, like CPUs and memory.
Also acpi_device_hotplug() can be static now.
Modify the common ACPI device hotplug code to always queue up the
same function, acpi_device_hotplug(), using acpi_hotplug_execute()
and make the PCI host bridge hotplug code use that function too for
device hot removal.
This allows some code duplication to be reduced and a race condition
where the relevant ACPI handle may become invalid between the
notification handler and the function queued up by it via
acpi_hotplug_execute() to be avoided.
Modify the ACPI namespace scanning code to register a struct
acpi_device object for every namespace node representing a device,
processor and so on, even if the device represented by that namespace
node is reported to be not present and not functional by _STA.
There are multiple reasons to do that. First of all, it avoids
quite a lot of overhead when struct acpi_device objects are
deleted every time acpi_bus_trim() is run and then added again
by a subsequent acpi_bus_scan() for the same scope, although the
namespace objects they correspond to stay in memory all the time
(which always is the case on a vast majority of systems).
Second, it will allow user space to see that there are namespace
nodes representing devices that are not present at the moment and may
be added to the system. It will also allow user space to evaluate
_SUN for those nodes to check what physical slots the "missing"
devices may be put into and it will make sense to add a sysfs
attribute for _STA evaluation after this change (that will be
useful for thermal management on some systems).
Next, it will help to consolidate the ACPI hotplug handling among
subsystems by making it possible to store hotplug-related information
in struct acpi_device objects in a standard common way.
Finally, it will help to avoid a race condition related to the
deletion of ACPI namespace nodes. Namely, namespace nodes may be
deleted as a result of a table unload triggered by _EJ0 or _DCK.
If a hotplug notification for one of those nodes is triggered
right before the deletion and it executes a hotplug callback
via acpi_hotplug_execute(), the ACPI handle passed to that
callback may be stale when the callback actually runs. One way
to work around that is to always pass struct acpi_device pointers
to hotplug callbacks after doing a get_device() on the objects in
question which eliminates the use-after-free possibility (the ACPI
handles in those objects are invalidated by acpi_scan_drop_device(),
so they will trigger ACPICA errors on attempts to use them).
The PCI host bridge scan handler installs its own notify handler,
handle_hotplug_event_root(), by itself. Nevertheless, the ACPI
hotplug framework also installs the common notify handler,
acpi_hotplug_notify_cb(), for PCI root bridges. This causes
acpi_hotplug_notify_cb() to call _OST method with unsupported
error as hotplug.enabled is not set.
To address this issue, introduce hotplug.ignore flag, which
indicates that the scan handler installs its own notify handler by
itself. The ACPI hotplug framework does not install the common
notify handler when this flag is set.
Signed-off-by: Toshi Kani <toshi.kani@hp.com>
[rjw: Changed the name of the new flag]
Cc: 3.9+ <stable@vger.kernel.org> # 3.9+
* acpi-hotplug:
ACPI / scan: Set flags.match_driver in acpi_bus_scan_fixed()
ACPI / PCI root: Clear driver_data before failing enumeration
ACPI / hotplug: Fix PCI host bridge hot removal
ACPI / hotplug: Fix acpi_bus_get_device() return value check
If a PCI host bridge cannot be enumerated due to an error in
pci_acpi_scan_root(), its ACPI device object's driver_data field
has to be cleared by acpi_pci_root_add() before freeing the
object pointed to by that field, or some later acpi_pci_find_root()
checks that should fail may succeed and cause quite a bit of
confusion to ensue.
Fix acpi_pci_root_add() to clear device->driver_data before
returning an error code as appropriate.
Acked-by: Toshi Kani <toshi.kani@hp.com>
Pull PCI changes from Bjorn Helgaas:
"Resource management
- Fix host bridge window coalescing (Alexey Neyman)
- Pass type, width, and prefetchability for window alignment (Wei Yang)
PCI device hotplug
- Convert acpiphp, acpiphp_ibm to dynamic debug (Lan Tianyu)
Power management
- Remove pci_pm_complete() (Liu Chuansheng)
MSI
- Fail initialization if device is not in PCI_D0 (Yijing Wang)
MPS (Max Payload Size)
- Use pcie_get_mps() and pcie_set_mps() to simplify code (Yijing Wang)
- Use pcie_set_readrq() to simplify code (Yijing Wang)
- Use cached pci_dev->pcie_mpss to simplify code (Yijing Wang)
SR-IOV
- Enable upstream bridges even for VFs on virtual buses (Bjorn Helgaas)
- Use pci_is_root_bus() to avoid catching virtual buses (Wei Yang)
Virtualization
- Add x86 MSI masking ops (Konrad Rzeszutek Wilk)
Freescale i.MX6
- Support i.MX6 PCIe controller (Sean Cross)
- Increase link startup timeout (Marek Vasut)
- Probe PCIe in fs_initcall() (Marek Vasut)
- Fix imprecise abort handler (Tim Harvey)
Renesas R-Car
- Support Gen2 internal PCIe controller (Valentine Barshak)
Samsung Exynos
- Add MSI support (Jingoo Han)
- Turn off power when link fails (Jingoo Han)
- Add Jingoo Han as maintainer (Jingoo Han)
- Add clk_disable_unprepare() on error path (Wei Yongjun)
Synopsys DesignWare
- Add irq_create_mapping() (Pratyush Anand)
- Add header guards (Seungwon Jeon)
Miscellaneous
- Enable native PCIe services by default on non-ACPI (Andrew Murray)
- Cleanup _OSC usage and messages (Bjorn Helgaas)
- Remove pcibios_last_bus boot option on non-x86 (Bjorn Helgaas)
- Convert bus code to use bus_, drv_, and dev_groups (Greg Kroah-Hartman)
- Remove unused pci_mem_start (Myron Stowe)
- Make sysfs functions static (Sachin Kamat)
- Warn on invalid return from driver probe (Stephen M. Cameron)
- Remove Intel Haswell D3 delays (Todd E Brandt)
- Call pci_set_master() in core if driver doesn't do it (Yinghai Lu)
- Use pci_is_pcie() to simplify code (Yijing Wang)
- Use PCIe capability accessors to simplify code (Yijing Wang)
- Use cached pci_dev->pcie_cap to simplify code (Yijing Wang)
- Removed unused "is_pcie" from struct pci_dev (Yijing Wang)
- Simplify sysfs CPU affinity implementation (Yijing Wang)"
* tag 'pci-v3.13-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (79 commits)
PCI: Enable upstream bridges even for VFs on virtual buses
PCI: Add pci_upstream_bridge()
PCI: Add x86_msi.msi_mask_irq() and msix_mask_irq()
PCI: Warn on driver probe return value greater than zero
PCI: Drop warning about drivers that don't use pci_set_master()
PCI: Workaround missing pci_set_master in pci drivers
powerpc/pci: Use pci_is_pcie() to simplify code [fix]
PCI: Update pcie_ports 'auto' behavior for non-ACPI platforms
PCI: imx6: Probe the PCIe in fs_initcall()
PCI: Add R-Car Gen2 internal PCI support
PCI: imx6: Remove redundant of_match_ptr
PCI: Report pci_pme_active() kmalloc failure
mn10300/PCI: Remove useless pcibios_last_bus
frv/PCI: Remove pcibios_last_bus
PCI: imx6: Increase link startup timeout
PCI: exynos: Remove redundant of_match_ptr
PCI: imx6: Fix imprecise abort handler
PCI: Fail MSI/MSI-X initialization if device is not in PCI_D0
PCI: imx6: Remove redundant dev_err() in imx6_pcie_probe()
x86/PCI: Coalesce multiple overlapping host bridge windows
There are two different interfaces for queuing up work items on the
ACPI hotplug workqueue, alloc_acpi_hp_work() used by PCI and PCI host
bridge hotplug code and acpi_os_hotplug_execute() used by the common
ACPI hotplug code and docking stations. They both are somewhat
cumbersome to use and work slightly differently.
The users of alloc_acpi_hp_work() have to submit a work function that
will extract the necessary data items from a struct acpi_hp_work
object allocated by alloc_acpi_hp_work() and then will free that
object, while it would be more straightforward to simply use a work
function with one more argument and let the interface take care of
the execution details.
The users of acpi_os_hotplug_execute() also have to deal with the
fact that it takes only one argument in addition to the work function
pointer, although acpi_os_execute_deferred() actually takes care of
the allocation and freeing of memory, so it would have been able to
pass more arguments to the work function if it hadn't been
constrained by the connection with acpi_os_execute().
Moreover, while alloc_acpi_hp_work() makes GFP_KERNEL memory
allocations, which is correct, because hotplug work items are
always queued up from process context, acpi_os_hotplug_execute()
uses GFP_ATOMIC, as that is needed by acpi_os_execute(). Also,
acpi_os_execute_deferred() queued up by it waits for the ACPI event
workqueues to flush before executing the work function, whereas
alloc_acpi_hp_work() can't do anything similar. That leads to
somewhat arbitrary differences in behavior between various ACPI
hotplug code paths and has to be straightened up.
For this reason, replace both alloc_acpi_hp_work() and
acpi_os_hotplug_execute() with a single interface,
acpi_hotplug_execute(), combining their behavior and being more
friendly to its users than any of the two.
Since _handle_hotplug_event_root() is run from the ACPI hotplug
workqueue, it doesn't need to queue up a work item to eject a PCI
host bridge on the same workqueue. Instead, it can just carry out
the eject by calling acpi_bus_device_eject() directly, so make that
happen.
Notice that handle_root_bridge_removal() is the only user of
acpi_bus_hot_remove_device(), so it doesn't have to be exported
any more and can be made internal to the ACPI core.
Simplify handle_root_bridge_removal() and acpi_eject_store() by
getting rid of struct acpi_eject_event and passing device objects
directly to async routines executed via acpi_os_hotplug_execute().
It is required to do get_device() on the struct acpi_device in
question before passing it to acpi_bus_hot_remove_device() through
acpi_os_hotplug_execute(), because acpi_bus_hot_remove_device()
calls acpi_scan_hot_remove() that does put_device() on that
object.
The ACPI PCI root removal routine, handle_root_bridge_removal(),
doesn't do that, which may lead to premature freeing of the
device object or to executing put_device() on an object that
has been freed already.
Fix this problem by making handle_root_bridge_removal() use
get_device() as appropriate.
Cc: All applicable <stable@vger.kernel.org>
This updates _OSC-related messages to be more human-readable. We now always
show the features we declare support for (this was previously invisible) as
well as the features we are granted control of.
Typical changes:
-acpi PNP0A08:00: Requesting ACPI _OSC control (0x1d)
-acpi PNP0A08:00: ACPI _OSC control (0x1d) granted
+acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
+acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Test the services we support (extended config space, ASPM, MSI) separately
so we can give a better message. Previously we said "Unable to request
_OSC control..."; now we'll say "we support %#02x but %#02x are required".
Test "pcie_ports_disabled" separately so we can give a better message.
Previously we said "Unable to request _OSC control..."; now we'll
say "PCIe port services disabled; not requesting _OSC control".
"pcie_ports_disabled" is true when CONFIG_PCIEPORTBUS=n or we boot
with "pcie_ports=compat".
If the _OSC support notification fails, we will never request control
(because "support == OSC_PCI_SEGMENT_GROUPS_SUPPORT", which doesn't include
all the features in ACPI_PCIE_REQ_SUPPORT), so we can return early to
simplify the code.
Previously, we ran _OSC once to tell the platform that we support
PCI Segment Groups, then we ran it again if we supported any additional
features (ASPM, MSI, or extended config space). I don't think it's
necessary to run it twice, since we can easily build the complete
mask of features we support before running _OSC the first time.
We run _OSC again later when requesting control of PCIe features;
that's unaffected by this change.
Previously we used "flags" for both:
- the bitmask of features we support (segments, ASPM, MSI, etc.), and
- the bitmask of features we want to control (native hotplug, AER, etc.)
To reduce confusion, this patch splits this into two variables:
"support" is the bitmask of features we support, and "control" is the
bitmask of features we want to control. No functional change.
This doesn't change any of the _OSC code; it just moves it out into
a new function so it doesn't clutter acpi_pci_root_add() so much. This
also enables future simplifications.
There's no need to check whether _OSC exists here; we eventually
call acpi_evaluate_object(..., "_OSC", ...), and that will fail
gracefully if _OSC doesn't exist.
Make PCI Host Bridge _OSC #defines more consistent. No functional change.
OSC_QUERY_TYPE isn't a "type"; it's an index into the _OSC Capabilities
Buffer of DWORDs. Rename OSC_QUERY_TYPE, OSC_SUPPORT_TYPE, and
OSC_CONTROL_TYPE to OSC_QUERY_DWORD, etc., to make this clear.
* pci/misc:
PCI/ACPI: Fix _OSC ordering to allow PCIe hotplug use when available
PCI: exynos: Add I/O access wrappers
PCI: designware: Drop "addr" arg from dw_pcie_readl_rc()/dw_pcie_writel_rc()
This fixes the problem of acpiphp claiming slots that should be managed
by pciehp, which may keep ExpressCard slots from working.
The acpiphp driver claims PCIe slots unless the BIOS has granted us
control of PCIe native hotplug via _OSC. Prior to v3.10, the acpiphp
.add method (add_bridge()) was always called *after* we had requested
native hotplug control with _OSC.
But after 3b63aaa70e ("PCI: acpiphp: Do not use ACPI PCI subdriver
mechanism"), which appeared in v3.10, acpiphp initialization is done
during the bus scan via the pcibios_add_bus() hook, and this happens
*before* we request native hotplug control.
Therefore, acpiphp doesn't know yet whether the BIOS will grant control,
and it claims slots that we should be handling with native hotplug.
This patch requests native hotplug control earlier, so we know whether
the BIOS granted it to us before we initialize acpiphp.
To avoid reintroducing the ASPM issue fixed by b8178f130e ('Revert
"PCI/ACPI: Request _OSC control before scanning PCI root bus"'), we run
_OSC earlier but defer the actual ASPM calls until after the bus scan is
complete.
Tested successfully by myself.
[bhelgaas: changelog, mark for stable]
Reference: https://bugzilla.kernel.org/show_bug.cgi?id=60736
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Acked-by: Yinghai Lu <yinghai@kernel.org>
CC: stable@vger.kernel.org # v3.10+
CC: Len Brown <lenb@kernel.org>
CC: "Rafael J. Wysocki" <rjw@sisk.pl>
When hot-adding an ACPI host bridge, use
pci_assign_unassigned_root_bus_resources() instead of
pci_assign_unassigned_bus_resources().
The former is more aggressive and will release and reassign existing
resources if necessary. This is safe at hot-add time because no drivers
are bound to devices below the new host bridge yet.
[bhelgaas: changelog, split __init changes out for reviewability]
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
We currently enable PCI bridges after scanning a bus and assigning
resources. This is often done in arch code.
This patch changes this so we don't enable a bridge until necessary, i.e.,
until we enable a PCI device behind the bridge. We do this in the generic
pci_enable_device() path, so this also removes the arch-specific code to
enable bridges.
[bhelgaas: changelog]
"PCI device hotplug
- Add pci_alloc_dev() interface (Gu Zheng)
- Add pci_bus_get()/put() for reference counting (Jiang Liu)
- Fix SR-IOV reference count issues (Jiang Liu)
- Remove unused acpi_pci_roots list (Jiang Liu)
MSI
- Conserve interrupt resources on x86 (Alexander Gordeev)
AER
- Force fatal severity when component has been reset (Betty Dall)
- Reset link below Root Port as well as Downstream Port (Betty Dall)
- Fix "Firmware first" flag setting (Bjorn Helgaas)
- Don't parse HEST for non-PCIe devices (Bjorn Helgaas)
ASPM
- Warn when we can't disable ASPM as driver requests (Bjorn Helgaas)
Miscellaneous
- Add CircuitCo PCI IDs (Darren Hart)
- Add AMD CZ SATA and SMBus PCI IDs (Shane Huang)
- Work around Ivytown NTB BAR size issue (Jon Mason)
- Detect invalid initial BAR values (Kevin Hao)
- Add pcibios_release_device() (Sebastian Ott)
- Fix powerpc & sparc PCI_UNKNOWN power state usage (Bjorn Helgaas)"
* tag 'pci-v3.11-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (51 commits)
MAINTAINERS: Add ACPI folks for ACPI-related things under drivers/pci
PCI: Add CircuitCo vendor ID and subsystem ID
PCI: Use pdev->pm_cap instead of pci_find_capability(..,PCI_CAP_ID_PM)
PCI: Return early on allocation failures to unindent mainline code
PCI: Simplify IOV implementation and fix reference count races
PCI: Drop redundant setting of bus->is_added in virtfn_add_bus()
unicore32/PCI: Remove redundant call of pci_bus_add_devices()
m68k/PCI: Remove redundant call of pci_bus_add_devices()
PCI / ACPI / PM: Use correct power state strings in messages
PCI: Fix comment typo for pcie_pme_remove()
PCI: Rename pci_release_bus_bridge_dev() to pci_release_host_bridge_dev()
PCI: Fix refcount issue in pci_create_root_bus() error recovery path
ia64/PCI: Clean up pci_scan_root_bus() usage
PCI/AER: Reset link for devices below Root Port or Downstream Port
ACPI / APEI: Force fatal AER severity when component has been reset
PCI/AER: Remove "extern" from function declarations
PCI/AER: Move AER severity defines to aer.h
PCI/AER: Set dev->__aer_firmware_first only for matching devices
PCI/AER: Factor out HEST device type matching
PCI/AER: Don't parse HEST table for non-PCIe devices
* pci/jiang-remove-global-list:
PCI/ACPI: Use dev_printk(), acpi_handle_print(), pr_xxx() when possible
PCI/ACPI: Remove unused global list acpi_pci_roots
PCI/ACPI: Introduce "handle" local for economy of expression
PCI/ACPI: Combine duplicate adjacent "if" tests
Use dev_printk(), acpi_handle_print(), and pr_xxx() to print messages
in pci_root.c.
[bhelgaas: fold in dev_printk() changes, use dev_printk() in
handle_root_bridge_insertion()]
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
Now the global list acpi_pci_roots pci_root.c is useless, remove it.
[bhelgaas: split out from acpi_handle_printk() changes]
[bhelgaas: split out from acpi_pci_roots removal]
When a PCI host bridge device receives a Bus Check notification, we
must re-enumerate starting with the bridge to discover changes (devices
that have been added or removed).
Prior to 668192b678 ("PCI: acpiphp: Move host bridge hotplug to
pci_root.c"), this happened in _handle_hotplug_event_bridge(). After that
commit, _handle_hotplug_event_bridge() is not installed for host bridges,
and the host bridge notify handler, _handle_hotplug_event_root() did not
re-enumerate.
This patch adds re-enumeration to _handle_hotplug_event_root().
This fixes cases where we don't notice the addition or removal of
PCI devices, e.g., the PCI-to-USB ExpressCard in the bugzilla below.
[bhelgaas: changelog, references]
Reference: https://lkml.kernel.org/r/CAAh6nkmbKR3HTqm5ommevsBwhL_u0N8Rk7Wsms_LfP=nBgKNew@mail.gmail.com
Reference: https://bugzilla.kernel.org/show_bug.cgi?id=57961
Reported-by: Gavin Guo <tuffkidtt@gmail.com>
Tested-by: Gavin Guo <tuffkidtt@gmail.com>
Reviewed-by: Jiang Liu <jiang.liu@huawei.com>
CC: stable@vger.kernel.org # v3.9+
We should check the acpi_resource_to_address64() return value, which
also removes the need to validate the resource type beforehand.
Found by Coverity (CID 113815).
Pull power management and ACPI updates from Rafael J Wysocki:
- ARM big.LITTLE cpufreq driver from Viresh Kumar.
- exynos5440 cpufreq driver from Amit Daniel Kachhap.
- cpufreq core cleanup and code consolidation from Viresh Kumar and
Stratos Karafotis.
- cpufreq scalability improvement from Nathan Zimmer.
- AMD "frequency sensitivity feedback" powersave bias for the ondemand
cpufreq governor from Jacob Shin.
- cpuidle code consolidation and cleanups from Daniel Lezcano.
- ARM OMAP cpuidle fixes from Santosh Shilimkar and Daniel Lezcano.
- ACPICA fixes and other improvements from Bob Moore, Jung-uk Kim, Lv
Zheng, Yinghai Lu, Tang Chen, Colin Ian King, and Linn Crosetto.
- ACPI core updates related to hotplug from Toshi Kani, Paul Bolle,
Yasuaki Ishimatsu, and Rafael J Wysocki.
- Intel Lynxpoint LPSS (Low-Power Subsystem) support improvements from
Rafael J Wysocki and Andy Shevchenko.
* tag 'pm+acpi-3.10-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (192 commits)
cpufreq: Revert incorrect commit 5800043
cpufreq: MAINTAINERS: Add co-maintainer
cpuidle: add maintainer entry
ACPI / thermal: do not always return THERMAL_TREND_RAISING for active trip points
ARM: s3c64xx: cpuidle: use init/exit common routine
cpufreq: pxa2xx: initialize variables
ACPI: video: correct acpi_video_bus_add error processing
SH: cpuidle: use init/exit common routine
ARM: S5pv210: compiling issue, ARM_S5PV210_CPUFREQ needs CONFIG_CPU_FREQ_TABLE=y
ACPI: Fix wrong parameter passed to memblock_reserve
cpuidle: fix comment format
pnp: use %*phC to dump small buffers
isapnp: remove debug leftovers
ARM: imx: cpuidle: use init/exit common routine
ARM: davinci: cpuidle: use init/exit common routine
ARM: kirkwood: cpuidle: use init/exit common routine
ARM: calxeda: cpuidle: use init/exit common routine
ARM: tegra: cpuidle: use init/exit common routine for tegra3
ARM: tegra: cpuidle: use init/exit common routine for tegra2
ARM: OMAP4: cpuidle: use init/exit common routine
