* acpi-hotplug:
ACPI / scan: ACPI device object sysfs attribute for _STA evaluation
ACPI / hotplug / driver core: Handle containers in a special way
ACPI / hotplug: Add demand_offline hotplug profile flag
ACPI / bind: Move acpi_get_child() to drivers/ide/ide-acpi.c
ACPI / bind: Pass struct acpi_device pointer to acpi_bind_one()
ACPI / bind: Rework struct acpi_bus_type
ACPI / bind: Redefine acpi_preset_companion()
ACPI / bind: Redefine acpi_get_child()
PCI / ACPI: Use acpi_find_child_device() for child devices lookup
ACPI / bind: Simplify child device lookups
ACPI / scan: Use direct recurrence for device hierarchy walks
ACPI: Introduce acpi_set_device_status()
ACPI / hotplug: Drop unfinished global notification handling routines
ACPI / hotplug: Rework generic code to handle suprise removals
ACPI / hotplug: Move container-specific code out of the core
ACPI / hotplug: Make ACPI PCI root hotplug use common hotplug code
ACPI / hotplug: Introduce common hotplug function acpi_device_hotplug()
ACPI / hotplug: Do not fail bus and device checks for disabled hotplug
ACPI / scan: Add acpi_device objects for all device nodes in the namespace
ACPI / scan: Define non-empty device removal handler
Adds the prototype declarations of functions acpi_ec_add_query_handler()
and acpi_ec_remove_query_handler() in header file internal.h and removes
unused functions ec_burst_enable() and ec_burst_disable() in ec.c.
This eliminates the following warnings in ec.c:
drivers/acpi/ec.c:393:5: warning: no previous prototype for ‘ec_burst_enable’ [-Wmissing-prototypes]
drivers/acpi/ec.c:402:5: warning: no previous prototype for ‘ec_burst_disable’ [-Wmissing-prototypes]
drivers/acpi/ec.c:531:5: warning: no previous prototype for ‘acpi_ec_add_query_handler’ [-Wmissing-prototypes]
drivers/acpi/ec.c:552:6: warning: no previous prototype for ‘acpi_ec_remove_query_handler’ [-Wmissing-prototypes]
Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
ACPI container devices require special hotplug handling, at least
on some systems, since generally user space needs to carry out
system-specific cleanup before it makes sense to offline devices in
the container. However, the current ACPI hotplug code for containers
first attempts to offline devices in the container and only then it
notifies user space of the container offline.
Moreover, after commit 202317a573b2 (ACPI / scan: Add acpi_device
objects for all device nodes in the namespace), ACPI device objects
representing containers are present as long as the ACPI namespace
nodes corresponding to them are present, which may be forever, even
if the container devices are physically detached from the system (the
return values of the corresponding _STA methods change in those
cases, but generally the namespace nodes themselves are still there).
Thus it is useful to introduce entities representing containers that
will go away during container hot-unplug.
The goal of this change is to address both the above issues.
The idea is to create a "companion" container system device for each
of the ACPI container device objects during the initial namespace
scan or on a hotplug event making the container present. That system
device will be unregistered on container removal. A new bus type
for container devices is added for this purpose, because device
offline and online operations need to be defined for them. The
online operation is a trivial function that is always successful
and the offline uses a callback pointed to by the container device's
offline member.
For ACPI containers that callback simply walks the list of ACPI
device objects right below the container object (its children) and
checks if all of their physical companion devices are offline. If
that's not the case, it returns -EBUSY and the container system
devivce cannot be put offline. Consequently, to put the container
system device offline, it is necessary to put all of the physical
devices depending on its ACPI companion object offline beforehand.
Container system devices created for ACPI container objects are
initially online. They are created by the container ACPI scan
handler whose hotplug.demand_offline flag is set. That causes
acpi_scan_hot_remove() to check if the companion container system
device is offline before attempting to remove an ACPI container or
any devices below it. If the check fails, a KOBJ_CHANGE uevent is
emitted for the container system device in question and user space
is expected to offline all devices below the container and the
container itself in response to it. Then, user space can finalize
the removal of the container with the help of its ACPI device
object's eject attribute in sysfs.
Tested-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
There is no reason to pass an ACPI handle to acpi_bind_one() instead
of a struct acpi_device pointer to the target device object, so
modify that function to take a struct acpi_device pointer as its
second argument and update all code depending on it accordingly.
Tested-by: Lan Tianyu <tianyu.lan@intel.com> # for USB/ACPI
Rework the common ACPI device hotplug code so that it is suitable
for PCI host bridge hotplug and switch the PCI host bridge scan
handler to using the common hotplug code.
This allows quite a few lines of code that are not necessary any more
to be dropped from the PCI host bridge scan handler and removes
arbitrary differences in behavior between PCI host bridge hotplug
and ACPI-based hotplug of other components, like CPUs and memory.
Also acpi_device_hotplug() can be static now.
Tested-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Modify the common ACPI device hotplug code to always queue up the
same function, acpi_device_hotplug(), using acpi_hotplug_execute()
and make the PCI host bridge hotplug code use that function too for
device hot removal.
This allows some code duplication to be reduced and a race condition
where the relevant ACPI handle may become invalid between the
notification handler and the function queued up by it via
acpi_hotplug_execute() to be avoided.
Modify the ACPI namespace scanning code to register a struct
acpi_device object for every namespace node representing a device,
processor and so on, even if the device represented by that namespace
node is reported to be not present and not functional by _STA.
There are multiple reasons to do that. First of all, it avoids
quite a lot of overhead when struct acpi_device objects are
deleted every time acpi_bus_trim() is run and then added again
by a subsequent acpi_bus_scan() for the same scope, although the
namespace objects they correspond to stay in memory all the time
(which always is the case on a vast majority of systems).
Second, it will allow user space to see that there are namespace
nodes representing devices that are not present at the moment and may
be added to the system. It will also allow user space to evaluate
_SUN for those nodes to check what physical slots the "missing"
devices may be put into and it will make sense to add a sysfs
attribute for _STA evaluation after this change (that will be
useful for thermal management on some systems).
Next, it will help to consolidate the ACPI hotplug handling among
subsystems by making it possible to store hotplug-related information
in struct acpi_device objects in a standard common way.
Finally, it will help to avoid a race condition related to the
deletion of ACPI namespace nodes. Namely, namespace nodes may be
deleted as a result of a table unload triggered by _EJ0 or _DCK.
If a hotplug notification for one of those nodes is triggered
right before the deletion and it executes a hotplug callback
via acpi_hotplug_execute(), the ACPI handle passed to that
callback may be stale when the callback actually runs. One way
to work around that is to always pass struct acpi_device pointers
to hotplug callbacks after doing a get_device() on the objects in
question which eliminates the use-after-free possibility (the ACPI
handles in those objects are invalidated by acpi_scan_drop_device(),
so they will trigger ACPICA errors on attempts to use them).
If an ACPI namespace node is removed (usually, as a result of a
table unload), and there is a data object attached to that node,
acpi_ns_delete_node() executes the removal handler submitted to
acpi_attach_data() for that object. That handler is currently empty
for struct acpi_device objects, so it is necessary to detach those
objects from the corresponding ACPI namespace nodes in advance every
time a table unload may happen. That is cumbersome and inefficient
and leads to some design constraints that turn out to be quite
inconvenient (in particular, struct acpi_device objects cannot be
registered for namespace nodes representing devices that are not
reported as present or functional by _STA).
For this reason, introduce a non-empty removal handler for ACPI
device objects that will unregister them when their ACPI namespace
nodes go away.
This code modification alone should not change functionality except
for the ordering of the ACPI hotplug workqueue which should not
matter (without subsequent code changes).
* acpi-hotplug:
ACPI / hotplug: Consolidate deferred execution of ACPI hotplug routines
ACPI / hotplug: Do not execute "insert in progress" _OST
ACPI / hotplug: Carry out PCI root eject directly
ACPI / hotplug: Merge device hot-removal routines
ACPI / hotplug: Make acpi_bus_hot_remove_device() internal
ACPI / hotplug: Simplify device ejection routines
ACPI / hotplug: Fix handle_root_bridge_removal()
ACPI / hotplug: Refuse to hot-remove all objects with disabled hotplug
ACPI / scan: Start matching drivers after trying scan handlers
ACPI: Remove acpi_pci_slot_init() headers from internal.h
include/acpi/acpiosxf.h (with the 'acpica' branch)
There are two different interfaces for queuing up work items on the
ACPI hotplug workqueue, alloc_acpi_hp_work() used by PCI and PCI host
bridge hotplug code and acpi_os_hotplug_execute() used by the common
ACPI hotplug code and docking stations. They both are somewhat
cumbersome to use and work slightly differently.
The users of alloc_acpi_hp_work() have to submit a work function that
will extract the necessary data items from a struct acpi_hp_work
object allocated by alloc_acpi_hp_work() and then will free that
object, while it would be more straightforward to simply use a work
function with one more argument and let the interface take care of
the execution details.
The users of acpi_os_hotplug_execute() also have to deal with the
fact that it takes only one argument in addition to the work function
pointer, although acpi_os_execute_deferred() actually takes care of
the allocation and freeing of memory, so it would have been able to
pass more arguments to the work function if it hadn't been
constrained by the connection with acpi_os_execute().
Moreover, while alloc_acpi_hp_work() makes GFP_KERNEL memory
allocations, which is correct, because hotplug work items are
always queued up from process context, acpi_os_hotplug_execute()
uses GFP_ATOMIC, as that is needed by acpi_os_execute(). Also,
acpi_os_execute_deferred() queued up by it waits for the ACPI event
workqueues to flush before executing the work function, whereas
alloc_acpi_hp_work() can't do anything similar. That leads to
somewhat arbitrary differences in behavior between various ACPI
hotplug code paths and has to be straightened up.
For this reason, replace both alloc_acpi_hp_work() and
acpi_os_hotplug_execute() with a single interface,
acpi_hotplug_execute(), combining their behavior and being more
friendly to its users than any of the two.
Since _handle_hotplug_event_root() is run from the ACPI hotplug
workqueue, it doesn't need to queue up a work item to eject a PCI
host bridge on the same workqueue. Instead, it can just carry out
the eject by calling acpi_bus_device_eject() directly, so make that
happen.
Notice that handle_root_bridge_removal() is the only user of
acpi_bus_hot_remove_device(), so it doesn't have to be exported
any more and can be made internal to the ACPI core.
Acked-by: Toshi Kani <toshi.kani@hp.com>
Since acpi_pci_slot_init() is now called from acpi_pci_init()
and pci-acpi.h contains its header, remove that header (and the
empty definition of that function for CONFIG_ACPI_PCI_SLOT unset)
from internal.h as it doesn't have to be there any more. That also
avoids a build warning about duplicate function definitions for
CONFIG_ACPI_PCI_SLOT unset.
According to Matthew Garrett, "Windows 8 leaves backlight control up
to individual graphics drivers rather than making ACPI calls itself.
There's plenty of evidence to suggest that the Intel driver for
Windows [8] doesn't use the ACPI interface, including the fact that
it's broken on a bunch of machines when the OS claims to support
Windows 8. The simplest thing to do appears to be to disable the
ACPI backlight interface on these systems".
So for Win8 systems, if there is native backlight control interface
registered by GPU driver, ACPI video does not need to register its own.
Since there are systems that don't work well with this approach, a
parameter for video module named use_native_backlight is introduced and
has the value of false by default. For users who have a broken ACPI
video backlight interface, video.use_native_backlight=1 is needed in
kernel cmdline.
Signed-off-by: Aaron Lu <aaron.lu@intel.com>
We attempted to address a regression introduced by commit a57f7f9
(ACPICA: Add Windows8/Server2012 string for _OSI method.) after which
ACPI video backlight support doesn't work on a number of systems,
because the relevant AML methods in the ACPI tables in their BIOSes
become useless after the BIOS has been told that the OS is compatible
with Windows 8. That problem is tracked by the bug entry at:
https://bugzilla.kernel.org/show_bug.cgi?id=51231
Commit 8c5bd7a (ACPI / video / i915: No ACPI backlight if firmware
expects Windows 8) introduced for this purpose essentially prevented
the ACPI backlight support from being used if the BIOS had been told
that the OS was compatible with Windows 8 and the i915 driver was
loaded, in which case the backlight would always be handled by i915.
Unfortunately, however, that turned out to cause problems with
backlight to appear on multiple systems with symptoms indicating that
i915 was unable to control the backlight on those systems as
expected.
For this reason, revert commit 8c5bd7a, but leave the function
acpi_video_backlight_quirks() introduced by it, because another
commit on top of it uses that function.
References: https://lkml.org/lkml/2013/7/21/119
References: https://lkml.org/lkml/2013/7/22/261
References: https://lkml.org/lkml/2013/7/23/429
References: https://lkml.org/lkml/2013/7/23/459
References: https://lkml.org/lkml/2013/7/23/81
References: https://lkml.org/lkml/2013/7/24/27
Reported-and-tested-by: James Hogan <james@albanarts.com>
Reported-and-tested-by: Kamal Mostafa <kamal@canonical.com>
Reported-and-tested-by: Jörg Otte <jrg.otte@gmail.com>
Reported-and-tested-by: Steven Newbury <steve@snewbury.org.uk>
Reported-by: Martin Steigerwald <Martin@lichtvoll.de>
Reported-by: Kalle Valo <kvalo@adurom.com>
Tested-by: Joerg Platte <jplatte@naasa.net>
This patch cleans up the following sparse warning:
# make C=2 drivers/acpi/osl.o
drivers/acpi/osl.c:1775:20: warning: symbol 'acpi_os_initialize1' was not declared. Should it be static?
CC drivers/acpi/osl.o
Signed-off-by: Lv Zheng <lv.zheng@intel.com>
There's a problem with that approach, however, because simply
avoiding to register the ACPI backlight interface if the firmware
calls _OSI for Windows 8 may not work in the following situations:
(1) The ACPI backlight interface actually works on the given system
and the i915 driver is not loaded (e.g. another graphics driver
is used).
(2) The ACPI backlight interface doesn't work on the given system,
but there is a vendor platform driver that will register its
own, equally broken, backlight interface if not prevented from
doing so by the ACPI subsystem.
Therefore we need to allow the ACPI backlight interface to be
registered until the i915 driver is loaded which then will unregister
it if the firmware has called _OSI for Windows 8 (or will register
the ACPI video driver without backlight support if not already
present).
For this reason, introduce an alternative function for registering
ACPI video, acpi_video_register_with_quirks(), that will check
whether or not the ACPI video driver has already been registered
and whether or not the backlight Windows 8 quirk has to be applied.
If the quirk has to be applied, it will block the ACPI backlight
support and either unregister the backlight interface if the ACPI
video driver has already been registered, or register the ACPI
video driver without the backlight interface otherwise. Make
the i915 driver use acpi_video_register_with_quirks() instead of
acpi_video_register() in i915_driver_load().
This change is based on earlier patches from Matthew Garrett,
Chun-Yi Lee and Seth Forshee and includes a fix from Aaron Lu's.
References: https://bugzilla.kernel.org/show_bug.cgi?id=51231
Tested-by: Aaron Lu <aaron.lu@intel.com>
Tested-by: Igor Gnatenko <i.gnatenko.brain@gmail.com>
Tested-by: Yves-Alexis Perez <corsac@debian.org>
Reviewed-by: Aaron Lu <aaron.lu@intel.com>
Acked-by: Matthew Garrett <matthew.garrett@nebula.com>
* acpi-assorted:
ACPI / EC: Add HP Folio 13 to ec_dmi_table in order to skip DSDT scan
ACPI: Add CMOS RTC Operation Region handler support
ACPI: Remove unused flags in acpi_device_flags
ACPI: Remove useless initializers
ACPI / battery: Make sure all spaces are in correct places
ACPI: add _STA evaluation at do_acpi_find_child()
ACPI / EC: access user space with get_user()/put_user()
* acpi-hotplug:
ACPI: Do not use CONFIG_ACPI_HOTPLUG_MEMORY_MODULE
ACPI / cpufreq: Add ACPI processor device IDs to acpi-cpufreq
Memory hotplug: Move alternative function definitions to header
ACPI / processor: Fix potential NULL pointer dereference in acpi_processor_add()
Memory hotplug / ACPI: Simplify memory removal
ACPI / scan: Add second pass of companion offlining to hot-remove code
Driver core / MM: Drop offline_memory_block()
ACPI / processor: Pass processor object handle to acpi_bind_one()
ACPI: Drop removal_type field from struct acpi_device
Driver core / memory: Simplify __memory_block_change_state()
ACPI / processor: Initialize per_cpu(processors, pr->id) properly
CPU: Fix sysfs cpu/online of offlined CPUs
Driver core: Introduce offline/online callbacks for memory blocks
ACPI / memhotplug: Bind removable memory blocks to ACPI device nodes
ACPI / processor: Use common hotplug infrastructure
ACPI / hotplug: Use device offline/online for graceful hot-removal
Driver core: Use generic offline/online for CPU offline/online
Driver core: Add offline/online device operations
On HP Folio 13-2000, the BIOS defines a CMOS RTC Operation Region and
the EC's _REG methord accesses that region. Thus an appropriate
address space handler must be registered for that region before the
EC driver is loaded.
Introduce a mechanism for adding CMOS RTC address space handlers.
Register an ACPI scan handler for CMOS RTC devices such that, when
a device of that kind is detected during an ACPI namespace scan, a
common CMOS RTC operation region address space handler will be
installed for it.
References: https://bugzilla.kernel.org/show_bug.cgi?id=54621
Reported-and-tested-by: Stefan Nagy <public@stefan-nagy.at>
Signed-off-by: Lan Tianyu <tianyu.lan@intel.com>
Cc: 3.9+ <stable@vger.kernel.org>
Commit 3b63aaa70e1 (PCI: acpiphp: Do not use ACPI PCI subdriver
mechanism) introduced an ACPI dock support regression, because it
changed the relative initialization order of the ACPI dock subsystem
and the ACPI-based PCI hotplug (acpiphp).
Namely, the ACPI dock subsystem has to be initialized before
acpiphp_enumerate_slots() is first run, which after commit
3b63aaa70e1 happens during the initial enumeration of the PCI
hierarchy triggered by the initial ACPI namespace scan in
acpi_scan_init(). For this reason, the dock subsystem has to be
initialized before the initial ACPI namespace scan in
acpi_scan_init().
To make that happen, modify the ACPI dock subsystem to be
non-modular and add the invocation of its initialization routine,
acpi_dock_init(), to acpi_scan_init() directly before the initial
namespace scan.
[rjw: Changelog, removal of dock_exit().]
References: https://bugzilla.kernel.org/show_bug.cgi?id=59501
Reported-and-tested-by: Alexander E. Patrakov <patrakov@gmail.com>
Tested-by: Illya Klymov <xanf@xanf.me>
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
Acked-by: Yinghai Lu <yinghai@kernel.org>
Since we have CSRT only to get additional DMA controller resources, let's get
rid of drivers/acpi/csrt.c and move its logic inside ACPI DMA helpers code.
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
Split the ACPI processor driver into two parts, one that is
non-modular, resides in the ACPI core and handles the enumeration
and hotplug of processors and one that implements the rest of the
existing processor driver functionality.
The non-modular part uses an ACPI scan handler object to enumerate
processors on the basis of information provided by the ACPI namespace
and to hook up with the common ACPI hotplug infrastructure. It also
populates the ACPI handle of each processor device having a
corresponding object in the ACPI namespace, which allows the driver
proper to bind to those devices, and makes the driver bind to them
if it is readily available (i.e. loaded) when the scan handler's
.attach() routine is running.
There are a few reasons to make this change.
First, switching the ACPI processor driver to using the common ACPI
hotplug infrastructure reduces code duplication and size considerably,
even though a new file is created along with a header comment etc.
Second, since the common hotplug code attempts to offline devices
before starting the (non-reversible) removal procedure, it will abort
(and possibly roll back) hot-remove operations involving processors
if cpu_down() returns an error code for one of them instead of
continuing them blindly (if /sys/firmware/acpi/hotplug/force_remove
is unset). That is a more desirable behavior than what the current
code does.
Finally, the separation of the scan/hotplug part from the driver
proper makes it possible to simplify the driver's .remove() routine,
because it doesn't need to worry about the possible cleanup related
to processor removal any more (the scan/hotplug part is responsible
for that now) and can handle device removal and driver removal
symmetricaly (i.e. as appropriate).
Some user-visible changes in sysfs are made (for example, the
'sysdev' link from the ACPI device node to the processor device's
directory is gone and a 'physical_node' link is present instead
and a corresponding 'firmware_node' is present in the processor
device's directory, the processor driver is now visible under
/sys/bus/cpu/drivers/ and bound to the processor device), but
that shouldn't affect the functionality that users care about
(frequency scaling, C-states and thermal management).
Tested on my venerable Toshiba Portege R500.
Reviewed-by: Toshi Kani <toshi.kani@hp.com>
Modify the generic ACPI hotplug code to be able to check if devices
scheduled for hot-removal may be gracefully removed from the system
using the device offline/online mechanism introduced previously.
Namely, make acpi_scan_hot_remove() handling device hot-removal call
device_offline() for all physical companions of the ACPI device nodes
involved in the operation and check the results. If any of the
device_offline() calls fails, the function will not progress to the
removal phase (which cannot be aborted), unless its (new) force
argument is set (in case of a failing offline it will put the devices
offlined by it back online).
In support of 'forced' device hot-removal, add a new sysfs attribute
'force_remove' that will reside under /sys/firmware/acpi/hotplug/.
* acpi-lpss:
ACPI / LPSS: make code less confusing for reader
ACPI / LPSS: Add support for exposing LTR registers to user space
ACPI / scan: Add special handler for Intel Lynxpoint LPSS devices
This patch introduces acpi_set_pnp_ids() and acpi_free_pnp_ids(),
which are updated from acpi_device_set_id() and acpi_free_ids(),
to setup and free acpi_device_pnp for a given acpi_handle. They
can be called without acpi_device.
Signed-off-by: Toshi Kani <toshi.kani@hp.com>
Devices on the Intel Lynxpoint Low Power Subsystem (LPSS) have some
common features that aren't shared with any other platform devices,
including the clock and LTR (Latency Tolerance Reporting) registers.
It is better to handle those features in common code than to bother
device drivers with doing that (I/O functionality-wise the LPSS
devices are generally compatible with other devices that don't
have those special registers and may be handled by the same drivers).
The clock registers of the LPSS devices are now taken care of by
the special clk-x86-lpss driver, but the MMIO mappings used for
accessing those registers can also be used for accessing the LTR
registers on those devices (LTR support for the Lynxpoint LPSS is
going to be added by a subsequent patch). Thus it is convenient
to add a special ACPI scan handler for the Lynxpoint LPSS devices
that will create the MMIO mappings for accessing the clock (and
LTR in the future) registers and will register the LPSS devices'
clocks, so the clk-x86-lpss driver will only need to take care of
the main Lynxpoint LPSS clock.
Introduce a special ACPI scan handler for Intel Lynxpoint LPSS
devices as described above. This also reduces overhead related to
browsing the ACPI namespace in search of the LPSS devices before the
registration of their clocks, removes some LPSS-specific (and
somewhat ugly) code from acpi_platform.c and shrinks the overall code
size slightly.
Acked-by: Mike Turquette <mturquette@linaro.org>
Make the ACPI memory hotplug driver use struct acpi_scan_handler
for representing the object used to set up ACPI memory hotplug
functionality and to remove hotplug memory ranges and data
structures used by the driver before unregistering ACPI device
nodes representing memory. Register the new struct acpi_scan_handler
object with the help of acpi_scan_add_handler_with_hotplug() to allow
user space to manipulate the attributes of the memory hotplug
profile.
This results in a significant reduction of the drvier's code size
and removes some ACPI hotplug code duplication.
Tested-by: Toshi Kani <toshi.kani@hp.com>
Introduce user space interface for manipulating hotplug profiles
associated with ACPI scan handlers.
The interface consists of sysfs directories under
/sys/firmware/acpi/hotplug/, one for each hotplug profile, containing
an attribute allowing user space to manipulate the enabled field of
the corresponding profile. Namely, switching the enabled attribute
from '0' to '1' will cause the common hotplug notify handler to be
installed for all ACPI namespace objects representing devices matching
the scan handler associated with the given hotplug profile (and
analogously for the converse switch).
Drivers willing to use the new user space interface should add their
ACPI scan handlers with the help of new funtion
acpi_scan_add_handler_with_hotplug().
Pull ACPI and power management fixes from Rafael Wysocki:
- Fixes for blackfin and microblaze build problems introduced by the
removal of global pm_idle. From Lars-Peter Clausen.
- OPP core build fix from Shawn Guo.
- Error condition check fix for the new imx6q-cpufreq driver from Wei
Yongjun.
- Fix for an AER driver crash related to the lack of APEI
initialization for acpi=off. From Rafael J Wysocki.
- Fix for a USB breakage on Thinkpad T430 related to ACPI power
resources and PCI wakeup from Rafael J. Wysocki.
* tag 'pm+acpi-fixes-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
ACPI / PM: Take unusual configurations of power resources into account
imx6q-cpufreq: fix return value check in imx6q_cpufreq_probe()
PM / OPP: fix condition for empty of_init_opp_table()
ACPI / APEI: Fix crash in apei_hest_parse() for acpi=off
microblaze idle: Fix compile error
blackfin idle: Fix compile error
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI changes from Bjorn Helgaas:
"Host bridge hotplug
- Major overhaul of ACPI host bridge add/start (Rafael Wysocki, Yinghai Lu)
- Major overhaul of PCI/ACPI binding (Rafael Wysocki, Yinghai Lu)
- Split out ACPI host bridge and ACPI PCI device hotplug (Yinghai Lu)
- Stop caching _PRT and make independent of bus numbers (Yinghai Lu)
PCI device hotplug
- Clean up cpqphp dead code (Sasha Levin)
- Disable ARI unless device and upstream bridge support it (Yijing Wang)
- Initialize all hot-added devices (not functions 0-7) (Yijing Wang)
Power management
- Don't touch ASPM if disabled (Joe Lawrence)
- Fix ASPM link state management (Myron Stowe)
Miscellaneous
- Fix PCI_EXP_FLAGS accessor (Alex Williamson)
- Disable Bus Master in pci_device_shutdown (Konstantin Khlebnikov)
- Document hotplug resource and MPS parameters (Yijing Wang)
- Add accessor for PCIe capabilities (Myron Stowe)
- Drop pciehp suspend/resume messages (Paul Bolle)
- Make pci_slot built-in only (not a module) (Jiang Liu)
- Remove unused PCI/ACPI bind ops (Jiang Liu)
- Removed used pci_root_bus (Bjorn Helgaas)"
* tag 'pci-v3.9-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (51 commits)
PCI/ACPI: Don't cache _PRT, and don't associate them with bus numbers
PCI: Fix PCI Express Capability accessors for PCI_EXP_FLAGS
ACPI / PCI: Make pci_slot built-in only, not a module
PCI/PM: Clear state_saved during suspend
PCI: Use atomic_inc_return() rather than atomic_add_return()
PCI: Catch attempts to disable already-disabled devices
PCI: Disable Bus Master unconditionally in pci_device_shutdown()
PCI: acpiphp: Remove dead code for PCI host bridge hotplug
PCI: acpiphp: Create companion ACPI devices before creating PCI devices
PCI: Remove unused "rc" in virtfn_add_bus()
PCI: pciehp: Drop suspend/resume ENTRY messages
PCI/ASPM: Don't touch ASPM if forcibly disabled
PCI/ASPM: Deallocate upstream link state even if device is not PCIe
PCI: Document MPS parameters pci=pcie_bus_safe, pci=pcie_bus_perf, etc
PCI: Document hpiosize= and hpmemsize= resource reservation parameters
PCI: Use PCI Express Capability accessor
PCI: Introduce accessor to retrieve PCIe Capabilities Register
PCI: Put pci_dev in device tree as early as possible
PCI: Skip attaching driver in device_add()
PCI: acpiphp: Keep driver loaded even if no slots found
* acpi-pm:
Commit d2e5f0c (ACPI / PCI: Rework the setup and cleanup of device
wakeup) moved the initial disabling of system wakeup for PCI devices
into a place where it can actually work and that exposed a hidden old
issue with crap^Wunusual system designs where the same power
resources are used for both wakeup power and device power control at
run time.
Namely, say there is one power resource such that the ACPI power
state D0 of a PCI device depends on that power resource (i.e. the
device is in D0 when that power resource is "on") and it is used
as a wakeup power resource for the same device. Then, calling
acpi_pci_sleep_wake(pci_dev, false) for the device in question will
cause the reference counter of that power resource to drop to 0,
which in turn will cause it to be turned off. As a result, the
device will go into D3cold at that point, although it should have
stayed in D0.
As it turns out, that happens to USB controllers on some laptops
and USB becomes unusable on those machines as a result, which is
a major regression from v3.8.
To fix this problem, (1) increment the reference counters of wakup
power resources during their initialization if they are "on"
initially, (2) prevent acpi_disable_wakeup_device_power() from
decrementing the reference counters of wakeup power resources that
were not enabled for wakeup power previously, and (3) prevent
acpi_enable_wakeup_device_power() from incrementing the reference
counters of wakeup power resources that already are enabled for
wakeup power.
In addition to that, if it is impossible to determine the initial
states of wakeup power resources, avoid enabling wakeup for devices
whose wakeup power depends on those power resources.
Reported-by: Dave Jones <davej@redhat.com>
Reported-by: Fabio Baltieri <fabio.baltieri@linaro.org>
Tested-by: Fabio Baltieri <fabio.baltieri@linaro.org>
* pci/jiang-pci_slot-kconfig:
As discussed in thread at https://patchwork.kernel.org/patch/1946851/,
there's no value in supporting CONFIG_ACPI_PCI_SLOT=m any more.
So change Kconfig and code to only support building pci_slot as
built-in driver.
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Make the ACPI container driver use struct acpi_scan_handler for
representing the object used to initialize ACPI containers and remove
the ACPI driver structure used previously and the data structures
created by it, since in fact they were not used for any purpose.
This simplifies the code and reduces the kernel's memory footprint by
avoiding the registration of a struct device_driver object with the
driver core and creation of its sysfs directory which is unnecessary.
In addition to that, make the namespace walk callback used for
installing the notify handlers for ACPI containers more
straightforward.
This change includes fixes from Toshi Kani.
Acked-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Currently, the ACPI namespace scanning code creates platform device
objects for ACPI device nodes whose IDs match the contents of the
acpi_platform_device_ids[] table. However, this adds a superfluous
special case into acpi_bus_device_attach() and makes it more
difficult to follow than it has to be. It also will make it more
difficult to implement removal code for those platform device objects
in the future.
For the above reasons, introduce a struct acpi_scan_handler object
for creating platform devices and move the code related to that from
acpi_bus_device_attach() to the .attach() callback of that object.
Also move the acpi_platform_device_ids[] table to acpi_platform.c.
Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Make the ACPI PCI IRQ link driver use struct acpi_scan_handler
for representing the object used to set up ACPI interrupt links and
to remove data structures used for this purpose before unregistering
the corresponding ACPI device nodes.
This simplifies the code slightly and reduces the kernel's memory
footprint by avoiding the registration of a struct device_driver
object with the driver core and creation of its sysfs directory
Make the ACPI PCI root bridge driver use struct acpi_scan_handler
for representing the object used to enumerate the PCI busses under
PCI host bridges found in the ACPI namespace (and to tear down data
structures representing the bus and devices on it before
unregistering the host bridges' ACPI device nodes).
The following commits depend on the 'acpi-lpss' material.
The acpiphp driver is confusing because it contains partial support for PCI
host bridge hotplug as well as support for hotplug of PCI devices.
This patch moves the host bridge hot-add support to pci_root.c and adds
hot-remove support in pci_root.c.
How to test it: if sci_emu patch is applied, find out root bus number to
ACPI root name mapping from dmesg or /sys. To remove root bus:
echo "\_SB.PCIB 3" > /sys/kernel/debug/acpi/sci_notify
To add back root bus:
echo "\_SB.PCIB 1" > /sys/kernel/debug/acpi/sci_notify
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
ACPI core adds sysfs device files after the given devices have been
registered with device_register(), which is not appropriate, because
it may lead to race conditions with user space tools using those
files.
Fix the problem by delaying the KOBJ_ADD uevent for ACPI devices
until after all of the devices' sysfs files have been created.
This also fixes a use-after-free in acpi_device_unregister().
Intel Lynxpoint LPSS peripheral drivers depend on LPSS clock tree being
created in order to function properly. The clock tree is exposed as a
platform driver that binds to a device named 'clk-lpt'.
To support this we modify the acpi_create_platform_device() to take one
additional parameter called flags. This is passed from
acpi_platform_device_ids[] array when acpi_create_platform_device() is
called.
We then introduce a new flag ACPI_PLATFORM_CLK which is used to tell
acpi_create_platform_device() to create the platform clocks as well.
Finally we set the ACPI_PLATFORM_CLK flags for all the Lynxpoint LPSS
devices and make sure that when this flag is set we create the
corresponding clock tree platform device.
Core System Resources Table (CSRT) is a proprietary ACPI table that
contains resources for certain devices that are not found in the DSDT
table. Typically a shared DMA controller might be found here.
This patch adds support for this table. We go through all entries in the
table and make platform devices of them. The resources from the table are
passed with the platform device.
There is one special resource in the table and it is the DMA request line
base and number of request lines. This information might be needed by the
DMA controller driver as it needs to map the ACPI DMA request line number
to the actual request line understood by the hardware. This range is passed
as IORESOURCE_DMA resource.
Move ACPI device power management functions from drivers/acpi/bus.c
to drivers/acpi/device_pm.c.
The system level attribute of ACPI power resources is the lowest
system sleep level (S0, S2 etc.) in which the given resource can be
"on" (ACPI 5.0, Section 7.1). On the other hand, wakeup power
resources have to be "on" for devices depending on them to be able to
signal wakeup. Therefore devices cannot wake up the system from
sleep states higher than the minimum of the system level attributes
of their wakeup power resources.
Use the wakeup power resources' system level values to get the
deepest system sleep state (highest system sleep level) the given
device can wake up the system from.
Some ACPI power resource initialization errors, like memory
allocation errors, are not taken into account appropriately in some
cases, which may lead to a device having an incomplete list of power
resources that one of its power states depends on, for one example.
Rework the power resource initialization and namespace scanning code
so that power resource initialization errors are treated more
seriously.
The lists of ACPI power resources are currently extracted in two
different ways, one for wakeup power resources and one for power
resources that device power states depend on. There is no reason
why it should be done differently in those two cases, so introduce
a common routine for extracting power resources lists from data
returned by AML, acpi_extract_power_resources(), and make the
namespace scanning code use it for both wakeup and device power
states power resources.
ACPI power resources have an order attribute that should be taken
into account when turning them on and off, but it is not used now.
Modify the power resources management code to preserve the
spec-compliant ordering of power resources that power states of
devices depend on (analogous changes will be done separately for
power resources used for wakeup).
