Removed a couple of extraneous ACPI_ERROR messages that
appeared during normal execution. These became apparent
after the conversion from ACPI_DEBUG_PRINT.
Fixed a problem where the CreateField operator could hang
if the BitIndex or NumBits parameter referred to a named
object. From Valery Podrezov.
http://bugzilla.kernel.org/show_bug.cgi?id=5359
Fixed a problem where a DeRefOf operation on a buffer
object incorrectly failed with an exception. This also
fixes a couple of related RefOf and DeRefOf issues.
http://bugzilla.kernel.org/show_bug.cgi?id=5360
http://bugzilla.kernel.org/show_bug.cgi?id=5387
http://bugzilla.kernel.org/show_bug.cgi?id=5392
Fixed a problem where the AE_BUFFER_LIMIT exception was
returned instead of AE_STRING_LIMIT on an out-of-bounds
Index() operation. From Valery Podrezov.
http://bugzilla.kernel.org/show_bug.cgi?id=5480
Implemented a memory cleanup at the end of the execution
of each iteration of an AML While() loop, preventing the
accumulation of outstanding objects. From Valery Podrezov.
http://bugzilla.kernel.org/show_bug.cgi?id=5427
Eliminated a chunk of duplicate code in the object
resolution code. From Valery Podrezov.
http://bugzilla.kernel.org/show_bug.cgi?id=5336
Fixed several warnings during the 64-bit code generation.
Signed-off-by: Bob Moore <robert.moore@intel.com>
Signed-off-by: Len Brown <len.brown@intel.com>
Implemented support in the Resource Manager to allow
unresolved namestring references within resource package
objects for the _PRT method. This support is in addition
to the previously implemented unresolved reference
support within the AML parser. If the interpreter slack
mode is enabled (true on Linux unless acpi=strict),
these unresolved references will be passed through
to the caller as a NULL package entry.
http://bugzilla.kernel.org/show_bug.cgi?id=5741
Implemented and deployed new macros and functions for
error and warning messages across the subsystem. These
macros are simpler and generate less code than their
predecessors. The new macros ACPI_ERROR, ACPI_EXCEPTION,
ACPI_WARNING, and ACPI_INFO replace the ACPI_REPORT_*
macros.
Implemented the acpi_cpu_flags type to simplify host OS
integration of the Acquire/Release Lock OSL interfaces.
Suggested by Steven Rostedt and Andrew Morton.
Fixed a problem where Alias ASL operators are sometimes
not correctly resolved. causing AE_AML_INTERNAL
http://bugzilla.kernel.org/show_bug.cgi?id=5189
http://bugzilla.kernel.org/show_bug.cgi?id=5674
Fixed several problems with the implementation of the
ConcatenateResTemplate ASL operator. As per the ACPI
specification, zero length buffers are now treated as a
single EndTag. One-length buffers always cause a fatal
exception. Non-zero length buffers that do not end with
a full 2-byte EndTag cause a fatal exception.
Fixed a possible structure overwrite in the
AcpiGetObjectInfo external interface. (With assistance
from Thomas Renninger)
Added 2006 copyright.
At SuSE's suggestion, enabled all error messages
without enabling function tracing, ie with CONFIG_ACPI_DEBUG=n
Replaced all instances of the ACPI_DEBUG_PRINT macro invoked at
the ACPI_DB_ERROR and ACPI_DB_WARN debug levels with
the ACPI_REPORT_ERROR and ACPI_REPORT_WARNING macros,
respectively. This preserves all error and warning messages
in the non-debug version of the ACPICA code (this has been
referred to as the "debug lite" option.) Over 200 cases
were converted to create a total of over 380 error/warning
messages across the ACPICA code. This increases the code
and data size of the default non-debug version by about 13K.
Added ACPI_NO_ERROR_MESSAGES flag to enable deleting all messages.
The size of the debug version remains about the same.
Implemented support for the EM64T and other x86_64
processors. This essentially entails recognizing
that these processors support non-aligned memory
transfers. Previously, all 64-bit processors were assumed
to lack hardware support for non-aligned transfers.
Completed conversion of the Resource Manager to nearly
full table-driven operation. Specifically, the resource
conversion code (convert AML to internal format and the
reverse) and the debug code to dump internal resource
descriptors are fully table-driven, reducing code and data
size and improving maintainability.
The OSL interfaces for Acquire and Release Lock now use a
64-bit flag word on 64-bit processors instead of a fixed
32-bit word. (Alexey Starikovskiy)
Implemented support within the resource conversion code
for the Type-Specific byte within the various ACPI 3.0
*WordSpace macros.
Fixed some issues within the resource conversion code for
the type-specific flags for both Memory and I/O address
resource descriptors. For Memory, implemented support
for the MTP and TTP flags. For I/O, split the TRS and TTP
flags into two separate fields.
ACPICA 20050617:
Moved the object cache operations into the OS interface
layer (OSL) to allow the host OS to handle these operations
if desired (for example, the Linux OSL will invoke the
slab allocator). This support is optional; the compile
time define ACPI_USE_LOCAL_CACHE may be used to utilize
the original cache code in the ACPI CA core. The new OSL
interfaces are shown below. See utalloc.c for an example
implementation, and acpiosxf.h for the exact interface
definitions. Thanks to Alexey Starikovskiy.
acpi_os_create_cache
acpi_os_delete_cache
acpi_os_purge_cache
acpi_os_acquire_object
acpi_os_release_object
Modified the interfaces to acpi_os_acquire_lock and
acpi_os_release_lock to return and restore a flags
parameter. This fits better with many OS lock models.
Note: the current execution state (interrupt handler
or not) is no longer passed to these interfaces. If
necessary, the OSL must determine this state by itself, a
simple and fast operation. Thanks to Alexey Starikovskiy.
Fixed a problem in the ACPI table handling where a valid
XSDT was assumed present if the revision of the RSDP
was 2 or greater. According to the ACPI specification,
the XSDT is optional in all cases, and the table manager
therefore now checks for both an RSDP >=2 and a valid
XSDT pointer. Otherwise, the RSDT pointer is used.
Some ACPI 2.0 compliant BIOSs contain only the RSDT.
Fixed an interpreter problem with the Mid() operator in the
case of an input string where the resulting output string
is of zero length. It now correctly returns a valid,
null terminated string object instead of a string object
with a null pointer.
Fixed a problem with the control method argument handling
to allow a store to an Arg object that already contains an
object of type Device. The Device object is now correctly
overwritten. Previously, an error was returned.
ACPICA 20050624:
Modified the new OSL cache interfaces to use ACPI_CACHE_T
as the type for the host-defined cache object. This allows
the OSL implementation to define and type this object in
any manner desired, simplifying the OSL implementation.
For example, ACPI_CACHE_T is defined as kmem_cache_t for
Linux, and should be defined in the OS-specific header
file for other operating systems as required.
Changed the interface to AcpiOsAcquireObject to directly
return the requested object as the function return (instead
of ACPI_STATUS.) This change was made for performance
reasons, since this is the purpose of the interface in the
first place. acpi_os_acquire_object is now similar to the
acpi_os_allocate interface. Thanks to Alexey Starikovskiy.
Modified the initialization sequence in
acpi_initialize_subsystem to call the OSL interface
acpi_osl_initialize first, before any local initialization.
This change was required because the global initialization
now calls OSL interfaces.
Restructured the code base to split some files because
of size and/or because the code logically belonged in a
separate file. New files are listed below.
utilities/utcache.c /* Local cache interfaces */
utilities/utmutex.c /* Local mutex support */
utilities/utstate.c /* State object support */
parser/psloop.c /* Main AML parse loop */
Fixed three cases in the interpreter where an "index"
argument to an ASL function was still (internally) 32
bits instead of the required 64 bits. This was the Index
argument to the Index, Mid, and Match operators.
The "strupr" function is now permanently local
(acpi_ut_strupr), since this is not a POSIX-defined
function and not present in most kernel-level C
libraries. References to the C library strupr function
have been removed from the headers.
Completed the deployment of static
functions/prototypes. All prototypes with the static
attribute have been moved from the headers to the owning
C file.
ACPICA 20050329 from Bob Moore
An error is now generated if an attempt is made to create
a Buffer Field of length zero (A CreateField with a length
operand of zero.)
The interpreter now issues a warning whenever executable
code at the module level is detected during ACPI table
load. This will give some idea of the prevalence of this
type of code.
Implemented support for references to named objects (other
than control methods) within package objects.
Enhanced package object output for the debug
object. Package objects are now completely dumped, showing
all elements.
Enhanced miscellaneous object output for the debug
object. Any object can now be written to the debug object
(for example, a device object can be written, and the type
of the object will be displayed.)
The "static" qualifier has been added to all local
functions across the core subsystem.
The number of "long" lines (> 80 chars) within the source
has been significantly reduced, by about 1/3.
Cleaned up all header files to ensure that all CA/iASL
functions are prototyped (even static functions) and the
formatting is consistent.
Two new header files have been added, acopcode.h and
acnames.h.
Removed several obsolete functions that were no longer
used.
infrastructure for it.
Let it rip!
