Remove own implementation of hex_to_bin().
Signed-off-by: Andy Shevchenko <ext-andriy.shevchenko@nokia.com>
Cc: Len Brown <lenb@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'acpica' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (22 commits)
ACPI: fix early DSDT dmi check warnings on ia64
ACPICA: Update version to 20100428.
ACPICA: Update/clarify some parameter names associated with acpi_handle
ACPICA: Rename acpi_ex_system_do_suspend->acpi_ex_system_do_sleep
ACPICA: Prevent possible allocation overrun during object copy
ACPICA: Split large file, evgpeblk
ACPICA: Add GPE support for dynamically loaded ACPI tables
ACPICA: Clarify/rename some root table descriptor fields
ACPICA: Update version to 20100331.
ACPICA: Minimize the differences between linux GPE code and ACPICA code base
ACPI: add boot option acpi=copy_dsdt to fix corrupt DSDT
ACPICA: Update DSDT copy/detection.
ACPICA: Add subsystem option to force copy of DSDT to local memory
ACPICA: Add detection of corrupted/replaced DSDT
ACPICA: Add write support for DataTable operation regions
ACPICA: Fix for acpi_reallocate_root_table for incorrect root table copy
ACPICA: Update comments/headers, no functional change
ACPICA: Update version to 20100304
ACPICA: Fix for possible fault in acpi_ex_release_mutex
ACPICA: Standardize integer output for ACPICA warnings/errors
WARNING: at drivers/firmware/dmi_scan.c:423 dmi_matches+0x70/0x160()
dmi check: not initialized yet.
This is caused by commit aa2110c
(ACPI: add boot option acpi=copy_dsdt to fix corrupt DSDT).
DMI is not initialized yet in acpi_early_init on ia64.
The DSDT DMI check table is x86 specific, so make it empty on other archs.
And this fixes the warnings on ia64.
Reported-and-tested-by: Tony Luck <tony.luck@intel.com>
Signed-off-by: Lin Ming <ming.m.lin@intel.com>
Signed-off-by: Len Brown <len.brown@intel.com>
This addresses: https://bugzilla.kernel.org/show_bug.cgi?id=14998
We copy some strings into "event" but we leave the space after the NULL
terminators uninitialized. Later in acpi_bus_receive_event() we copy
the whole struct to another buffer with memcpy(). If the new buffer is
stored on the stack, kmemcheck prints a warning about the unitialized
space after the NULL terminators.
It's true that the space is uninitialized, but it's harmless. The
buffer is only used in acpi_system_read_event() and we don't read past
This patch changes the kmalloc() to kzalloc() so that we initialize the
memory and silence the kmemcheck warning.
Reported-by: Christian Casteyde <casteyde.christian@free.fr>
Some BIOS on Toshiba machines corrupt the DSDT, so add a new
boot option acpi=copy_dsdt to workaround it.
Add warning message to ask users to use this option if corrupt DSDT detected.
Also build a DMI blacklist to check it and automatically copy DSDT.
https://bugzilla.kernel.org/show_bug.cgi?id=14679
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
'bugzilla-531916-power-state', 'ht-warn-2.6.34', 'pnp', 'processor-rename', 'sony-2.6.34', 'suse-bugzilla-531547', 'tz-check', 'video' and 'misc-2.6.34' into release
If the BIOS pokes the system-wide OSC bits to see if Linux
supports evaluating _OST after a _PPC change notification,
answer yes.
Also, fix an oversight where we neglected to set the OSC
bit advertising processor aggregator device support
when acpi-pad is compiled as a module.
Signed-off-by: Zhao Yakui <yakui.zhao@intel.com>
If the ACPI power state can be got both directly and indirectly,
we prefer to get it indirectly.
https://bugzilla.redhat.com/show_bug.cgi?id=531916 describes a
system with a _PSC method for the fan that always returns "on".
There's no benefit in us always requesting the state of the fan
when performing transitions - we want to do everything we can
to ensure that the fan turns on when it should do, not risk
hardware damage by believing the hardware when it tells us the
fan is already on. Given that the Leading Other OS(tm) works fine
on this machine, it seems likely that it behaves in much this way.
inspired-by: Matthew Garrett <mjg@redhat.com>
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
release
Executing _OSC returns a buffer, which has an acpi object in it.
Don't directly returns the buffer, instead, we return the acpi object's
buffer. This fixes a regression since caller of acpi_run_osc expects
an acpi object's buffer returned.
Tested-by: Yinghai Lu <yinghai@kernel.org>
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
We discovered that at least one machine (HP Envy), methods in the DSDT
attempt to call external methods defined in a dynamically loaded SSDT.
Unfortunately, the DSDT methods we are trying to call are part of the
EC initialization, which happens very early, and the the dynamic SSDT
is only loaded when a processor _PDC method runs much later.
This results in namespace lookup errors for the (as of yet) undefined
methods.
Since Windows doesn't have any issues with this machine, we take it
as a hint that they must be evaluating _PDC much earlier than we are.
Thus, the proper thing for Linux to do should be to match the Windows
implementation more closely.
Provide a mechanism to call _PDC before we enable the EC. Doing so loads
the dynamic tables, and allows the EC to be enabled correctly.
The ACPI processor driver will still evaluate _PDC in its .add() method
to cover the hotplug case.
Resolves: http://bugzilla.kernel.org/show_bug.cgi?id=14824
Cc: ming.m.lin@intel.com
Signed-off-by: Alex Chiang <achiang@hp.com>
v2->v1:
.improve debug info as suggedted by Bjorn,Kenji
.API is using uuid string as suggested by Alexey
Add an API to execute _OSC. A lot of devices can have this method, so add a
generic API.
Add acpi_bus_get_status_handle() so we can get the status of a namespace
object before building a struct acpi_device.
This removes a use of "device->flags.dynamic_status", a cached indicator of
whether _STA exists. It seems simpler and more reliable to just evaluate
_STA and catch AE_NOT_FOUND errors.
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
drivers/pci/dmar.c
users of acpi.h that need dmi.h should include it directly.
Handler was never invoked. Now invoked if/when host node is deleted.
Data object was not automatically deleted when host node was deleted.
Interface to handler had an unused parameter, removed it.
ACPICA BZ 778.
http://acpica.org/bugzilla/show_bug.cgi?id=778
Signed-off-by: Bob Moore <robert.moore@intel.com>
This patch changes the global system notification path so it uses the
acpi_handle, not the acpi_device.
System notifications often deal with device presence and status change.
In these cases, we may not have an acpi_device. For example, we may
get a Device Check notification on an object that previously was not
present. Since the object was not present, we would not have had an
acpi_device for it.
Remove return values from acpi_bus_check_device() and acpi_bus_check_scope()
since nobody looks at them.
Remove "status_changed" return from acpi_bus_check_device(). Nobody
does anything useful based on its value.
This replaces several messages that depend on the acpi_device struct
with a single message that uses just the acpi_handle. We should be
able to deal with notifications to objects that do not yet have an
acpi_device struct.
System notify events (0x00-0x7f) are common across all device types
and should be handled in Linux/ACPI, not in drivers. However, some
BIOSes use system notify events in device-specific ways that require
the driver to be involved.
This patch adds a ACPI_DRIVER_ALL_NOTIFY_EVENTS driver flag. When a
driver sets this flag and supplies a .notify method, Linux/ACPI calls
the .notify method for ALL notify events on the device, not just the
device-specific (0x80-0xff) events.
"Transitioning device [%s] to D%d" is not correct.
We print this line when we attempted to transition
the device, and it failed.
So instead, print
"Device [%s] failed to transition to D%d\n"
This can happen under two conditions:
1. acpi_power_transition() fails when trying to handle the
_ON/_OFF for associated power resource.
2. acpi_evaluate_object() on the explicit _PS0/_PS3
for that actual device could fail.
this change clarifies, but doesn't fix
http://bugzilla.kernel.org/show_bug.cgi?id=13243
This patch makes acpi_init() call acpi_wakeup_device_init() directly.
Previously, acpi_wakeup_device_init() was a late_initcall (sequence 7).
acpi_wakeup_device_init() depends on acpi_wakeup_device_list, which
is populated when ACPI devices are enumerated by acpi_init() ->
acpi_scan_init(). Using late_initcall is certainly enough to make
sure acpi_wakeup_device_list is populated, but it is more than
necessary. We can just as easily call acpi_wakeup_device_init()
directly from acpi_init(), which avoids the initcall magic.
CC: Li Shaohua <shaohua.li@intel.com>
This patch makes acpi_init() call acpi_sleep_proc_init() directly.
Previously, acpi_sleep_proc_init() was a late_initcall (sequence 7),
apparently to make sure that the /proc hierarchy already exists:
2003/02/13 12:38:03-06:00 mochel
acpi sleep: demote sleep proc file creation.
- Make acpi_sleep_proc_init() a late_initcall(), and not called from
acpi_sleep_init(). This guarantees that the acpi proc hierarchy is at
least there when we create the dang file.
This should no longer be an issue because acpi_bus_init() (called early
in acpi_init()) creates acpi_root_dir (/proc/acpi).
This patch makes acpi_init() call init_acpi_device_notify() directly.
Previously, init_acpi_device_notify() was an arch_initcall (sequence 3),
so it was called before acpi_init() (a subsys_initcall at sequence 4).
init_acpi_device_notify() sets the platform_notify and
platform_notify_remove function pointers. These pointers
are not used until acpi_init() enumerates ACPI devices in
this path:
acpi_init()
acpi_scan_init()
acpi_bus_scan()
acpi_add_single_object()
acpi_device_register()
device_add()
<use platform_notify>
So it is sufficient to have acpi_init() call init_acpi_device_notify()
directly before it enumerates devices.
This patch makes acpi_init() call acpi_debug_init() directly.
Previously, both were subsys_initcalls. acpi_debug_init()
must happen after acpi_init(), and it's better to call it
explicitly rather than rely on link ordering.
This patch makes acpi_init() call acpi_system_init() directly.
Previously, both were subsys_initcalls. acpi_system_init()
This patch makes acpi_init() call acpi_power_init() directly.
Previously, both were subsys_initcalls. acpi_power_init()
CC: Zhao Yakui <yakui.zhao@intel.com>
This patch makes acpi_init() call acpi_ec_init() directly.
Previously, both were subsys_initcalls. acpi_ec_init()
CC: Alexey Starikovskiy <astarikovskiy@suse.de>
This patch makes acpi_init() call acpi_scan_init() directly.
Previously, both acpi_init() and acpi_scan_init() were subsys_initcalls,
and acpi_init() was called first based on the link order from the
makefile (bus.o before scan.o).
acpi_scan_init() registers the ACPI bus type, creates the root device,
and enumerates fixed-feature and namespace devices. All of this must
be done after acpi_init(), and it's better to call acpi_scan_init()
explicitly rather than rely on the link ordering.
This patch makes acpi_init() exit early when ACPI is disabled.
This skips a DMI check that affects ACPI power management. The
DMI check prints a notice that is misleading when ACPI is disabled.
A number of things that shouldn't be exposed outside the ACPI core
were declared in include/acpi/acpi_drivers.h, where anybody can
see them. This patch moves those declarations to a new "internal.h"
inside drivers/acpi.
There was a misplaced status test (two consequent tests without a
statement in between) in acpi_bus_init for ages. Remove it, since the
function which should be checked (acpi_os_initialize1) has BUG_ONs on
failure paths.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
acpi_early_init() was changed to over-write the cmdline param,
making it really inconvenient to set debug flags at boot-time.
Also,
This sets the default level to "info", which is what all the ACPI
drivers use. So to enable messages from drivers, you only have to
supply the "layer" (a.k.a. "component"). For non-"info" ACPI core
and ACPI interpreter messages, you have to supply both level and
layer masks, as before.
When CONFIG_ACPI_DEBUG=y, the default acpi_dbg_layer and acpi_dbg_level
values built into the ACPI CA have some debug output enabled. We'd
rather be quiet unless the user actually specified the acpi.debug_level
argument.
This enables distros to ship with CONFIG_ACPI_DEBUG=y without
inundating users with debug output.
Remove CONFIG_ACPI_EC. It was always set the same as CONFIG_ACPI,
and it had no menu label, so there was no way to set it to anything
other than "y".
Per section 6.5.4 of the ACPI 3.0b specification,
OSPM must make Embedded Controller operation regions, accessed
via the Embedded Controllers described in ECDT, available before
executing any control method.
The ECDT table is optional, but if it is present, the above text
means that the EC it describes is a required part of the ACPI
subsystem, so CONFIG_ACPI_EC=n wouldn't make sense.
Acked-by: Alexey Starikovskiy <astarikovskiy@suse.de>
drivers/acpi/bay.c
drivers/acpi/dock.c
drivers/ata/libata-acpi.c
drivers/acpi/osl.c
According to ACPI spec when the status of some device is not present
but functional, the device is valid and the children of this device
should be enumerated. It means that the device should be added to
linux acpi device tree. But the device driver for this device should not
be loaded.
The detailed info can be found in the section 6.3.7 of ACPI 3.0b spec.
_STA may return bit 0 clear (not present) with bit 3 set (device is
functional). This case is used to indicate a valid device for which no
device driver should be loaded (for example, a bridge device.).
Children of this device may be present and valid. OS should continue
enumeration below a device whose _STA returns this bit combination
http://bugzilla.kernel.org/show_bug.cgi?id=3358
Signed-off-by: Li Shaohua <shaohua.li@intel.com>
Add the DMI check to disable power check in the course of device power
transistion.
http://bugzilla.kernel.org/show_bug.cgi?id=11000
transition
Maybe the incorrect power state is returned on the bogus bios, which
is different with the real power state. For example: the bios returns D0
state and the real power state is D3. OS expects to set the device to D0
state. In such case if OS uses the power state returned by the BIOS and
checks the device power state very strictly in power transition, the device
can't be transited to the correct power state.
So the boot option of "acpi.power_nocheck=1" is added to avoid checking
the device power in the course of device power transition.
http://bugzilla.kernel.org/show_bug.cgi?id=8049
As of version 2.0, ACPI can return 64-bit integers. The current
acpi_evaluate_integer only supports 64-bit integers on 64-bit platforms.
Change the argument to take a pointer to an acpi_integer so we support
64-bit integers on all platforms.
lenb: replaced use of "acpi_integer" with "unsigned long long"
lenb: fixed bug in acpi_thermal_trips_update()
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
when there is no ECDT table and no _INI object for EC device, it will be
enabled before scanning ACPI device. But it is too late after the following
the commit is merged.
>commit 7752d5cfe3d11ca0bb9c673ec38bd78ba6578f8e
> Author: Robert Hancock <hancockr@shaw.ca>
> Date: Fri Feb 15 01:27:20 2008 -0800
>x86: validate against acpi motherboard resources
After the above commit is merged, OS will check whether MCFG area is
reserved in ACPI motherboard resources by calling the function of
acpi_get_devices when there exists MCFG table. In the acpi_get_devices the _STA
object will be evaluated to check the status of the ACPI device. On some broken
BIOS the MYEC object of EC device is initialized as one, which indicates that
EC operation region is already accessible before enabling EC device.So on these
broken BIOS the EC operation region will be accessed in course of evaluating
the _STA object before enabling EC device, which causes that OS will print the
following warning messages:
>ACPI Error (evregion-0315): No handler for Region [EC__] (ffff88007f8145e8)
[EmbeddedControl] [20080609]
>ACPI Error (exfldio-0290): Region EmbeddedControl(3) has no handler [20080321]
>ACPI Error (psparse-0530): Method parse/execution failed [\_SB_.PCI0.SBRG.
EC__.BAT1._STA] (Node ffff81013fc17a00), AE_NOT_EXIST
>ACPI Error (uteval-0233): Method execution failed [\_SB_.PCI0.SBRG.EC__.BAT1.
Although the above warning message is harmless, it looks confusing.
So it is necessary to enable EC device as early as possible.Maybe it is
appropriate to enable it immediately after ACPI full initialization.
http://bugzilla.kernel.org/show_bug.cgi?id=11255
http://bugzilla.kernel.org/show_bug.cgi?id=11374
http://bugzilla.kernel.org/show_bug.cgi?id=11660
The battery driver already registers notification handler.
To avoid registering notification handler again,
introduce a notifier chain in global system notifier handler
and use it in dock driver.
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (72 commits)
Revert "x86/PCI: ACPI based PCI gap calculation"
PCI: remove unnecessary volatile in PCIe hotplug struct controller
PCI: include linux/pm_wakeup.h for device_set_wakeup_capable
PCI PM: Fix pci_prepare_to_sleep
x86/PCI: Fix PCI config space for domains > 0
Fix acpi_pm_device_sleep_wake() by providing a stub for CONFIG_PM_SLEEP=n
PCI: Simplify PCI device PM code
PCI PM: Introduce pci_prepare_to_sleep and pci_back_from_sleep
PCI ACPI: Rework PCI handling of wake-up
ACPI: Introduce new device wakeup flag 'prepared'
ACPI: Introduce acpi_device_sleep_wake function
PCI: rework pci_set_power_state function to call platform first
PCI: Introduce platform_pci_power_manageable function
ACPI: Introduce acpi_bus_power_manageable function
PCI: make pci_name use dev_name
PCI: handle pci_name() being const
PCI: add stub for pci_set_consistent_dma_mask()
PCI: remove unused arch pcibios_update_resource() functions
PCI: fix pci_setup_device()'s sprinting into a const buffer
Fixed up conflicts in various files (arch/x86/kernel/setup_64.c,
arch/x86/pci/irq.c, arch/x86/pci/pci.h, drivers/acpi/sleep/main.c,
drivers/pci/pci.c, drivers/pci/pci.h, include/acpi/acpi_bus.h) from x86
and ACPI updates manually.
No longer needed; replaced mostly with u32, but also acpi_size
where a type that changes 32/64 bit on 32/64-bit platforms is
required.
v2: Fix a cast of a 32-bit int to a pointer in ACPI to avoid a compiler warning.
from David Howells
