path: root/drivers/acpi/apei
2013-03-27ACPI / APEI: fix error status check condition for CPERChen Gong
In Table 18-289, ACPI5.0 SPEC, the error data length in CPER Generic Error Data Entry can be 0, which means this generic error data entry can have only one header. So fix the check conditon for it. Signed-off-by: Chen Gong <gong.chen@linux.intel.com> Reviewed-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-02-28Merge branch 'linux_next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-edac Pull EDAC fixes and ghes-edac from Mauro Carvalho Chehab: "For: - Some fixes at edac drivers (i7core_edac, sb_edac, i3200_edac); - error injection support for i5100, when EDAC debug is enabled; - fix edac when it is loaded builtin (early init for the subsystem); - a "Firmware First" EDAC driver, allowing ghes to report errors via EDAC (ghes-edac). With regards to ghes-edac, this fixes a longstanding BZ at Red Hat that happens with Nehalem and Sandy Bridge CPUs: when both GHES and i7core_edac or sb_edac are running, the error reports are unpredictable, as both BIOS and OS race to access the registers. With ghes-edac, the EDAC core will refuse to register any other concurrent memory error driver. This patchset moves the ghes struct definitions to a separate header file (include/acpi/ghes.h) and adds 3 hooks at apei/ghes.c to register/unregister and to report errors via ghes-edac. Those changes were acked by ghes driver maintainer (Huang)." * 'linux_next' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-edac: (30 commits) i5100_edac: convert to use simple_open() ghes_edac: fix to use list_for_each_entry_safe() when delete list items ghes_edac: Fix RAS tracing ghes_edac: Make it compliant with UEFI spec 2.3.1 ghes_edac: Improve driver's printk messages ghes_edac: Don't credit the same memory dimm twice ghes_edac: do a better job of filling EDAC DIMM info ghes_edac: add support for reporting errors via EDAC ghes_edac: Register at EDAC core the BIOS report ghes: add the needed hooks for EDAC error report ghes: move structures/enum to a header file edac: add support for error type "Info" edac: add support for raw error reports edac: reduce stack pressure by using a pre-allocated buffer edac: lock module owner to avoid error report conflicts edac: remove proc_name from mci structure edac: add a new memory layer type edac: initialize the core earlier edac: better report error conditions in debug mode i5100_edac: Remove two checkpatch warnings ...
2013-02-25ghes: add the needed hooks for EDAC error reportMauro Carvalho Chehab
In order to allow reporting errors via EDAC, add hooks for: 1) register an EDAC driver; 2) unregister an EDAC driver; 3) report errors via EDAC. As the EDAC driver will need to access the ghes structure, adds it as one of the parameters for ghes_do_proc. Acked-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-02-23Merge branch 'acpi-cleanup' into fixesRafael J. Wysocki
* acpi-cleanup: ACPI / APEI: Fix crash in apei_hest_parse() for acpi=off
2013-02-23ACPI / APEI: Fix crash in apei_hest_parse() for acpi=offRafael J. Wysocki
After commit 92ef2a2 (ACPI: Change the ordering of PCI root bridge driver registrarion), acpi_hest_init() is never called for acpi=off (acpi_disabled), so hest_disable is not set, but hest_tab is NULL, which causes apei_hest_parse() to crash when it is called from aer_acpi_firmware_first(). Fix that by making apei_hest_parse() check if hest_tab is not NULL in addition to checking hest_disable. Also remove the now useless acpi_disabled check from apei_hest_parse(). Reported-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-02-21ghes: move structures/enum to a header fileMauro Carvalho Chehab
As a ghes_edac driver will need to access ghes structures, in order to properly handle the errors, move those structures to a separate header file. No functional changes. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-02-19Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf changes from Ingo Molnar: "There are lots of improvements, the biggest changes are: Main kernel side changes: - Improve uprobes performance by adding 'pre-filtering' support, by Oleg Nesterov. - Make some POWER7 events available in sysfs, equivalent to what was done on x86, from Sukadev Bhattiprolu. - tracing updates by Steve Rostedt - mostly misc fixes and smaller improvements. - Use perf/event tracing to report PCI Express advanced errors, by Tony Luck. - Enable northbridge performance counters on AMD family 15h, by Jacob Shin. - This tracing commit: tracing: Remove the extra 4 bytes of padding in events changes the ABI. All involved parties (PowerTop in particular) seem to agree that it's safe to do now with the introduction of libtraceevent, but the devil is in the details ... Main tooling side changes: - Add 'event group view', from Namyung Kim: To use it, 'perf record' should group events when recording. And then perf report parses the saved group relation from file header and prints them together if --group option is provided. You can use the 'perf evlist' command to see event group information: $ perf record -e '{ref-cycles,cycles}' noploop 1 [ perf record: Woken up 2 times to write data ] [ perf record: Captured and wrote 0.385 MB perf.data (~16807 samples) ] $ perf evlist --group {ref-cycles,cycles} With this example, default perf report will show you each event separately. You can use --group option to enable event group view: $ perf report --group ... # group: {ref-cycles,cycles} # ======== # Samples: 7K of event 'anon group { ref-cycles, cycles }' # Event count (approx.): 6876107743 # # Overhead Command Shared Object Symbol # ................ ....... ................. .......................... 99.84% 99.76% noploop noploop [.] main 0.07% 0.00% noploop ld-2.15.so [.] strcmp 0.03% 0.00% noploop [kernel.kallsyms] [k] timerqueue_del 0.03% 0.03% noploop [kernel.kallsyms] [k] sched_clock_cpu 0.02% 0.00% noploop [kernel.kallsyms] [k] account_user_time 0.01% 0.00% noploop [kernel.kallsyms] [k] __alloc_pages_nodemask 0.00% 0.00% noploop [kernel.kallsyms] [k] native_write_msr_safe 0.00% 0.11% noploop [kernel.kallsyms] [k] _raw_spin_lock 0.00% 0.06% noploop [kernel.kallsyms] [k] find_get_page 0.00% 0.02% noploop [kernel.kallsyms] [k] rcu_check_callbacks 0.00% 0.02% noploop [kernel.kallsyms] [k] __current_kernel_time As you can see the Overhead column now contains both of ref-cycles and cycles and header line shows group information also - 'anon group { ref-cycles, cycles }'. The output is sorted by period of group leader first. - Initial GTK+ annotate browser, from Namhyung Kim. - Add option for runtime switching perf data file in perf report, just press 's' and a menu with the valid files found in the current directory will be presented, from Feng Tang. - Add support to display whole group data for raw columns, from Jiri Olsa. - Add per processor socket count aggregation in perf stat, from Stephane Eranian. - Add interval printing in 'perf stat', from Stephane Eranian. - 'perf test' improvements - Add support for wildcards in tracepoint system name, from Jiri Olsa. - Add anonymous huge page recognition, from Joshua Zhu. - perf build-id cache now can show DSOs present in a perf.data file that are not in the cache, to integrate with build-id servers being put in place by organizations such as Fedora. - perf top now shares more of the evsel config/creation routines with 'record', paving the way for further integration like 'top' snapshots, etc. - perf top now supports DWARF callchains. - Fix mmap limitations on 32-bit, fix from David Miller. - 'perf bench numa mem' NUMA performance measurement suite - ... and lots of fixes, performance improvements, cleanups and other improvements I failed to list - see the shortlog and git log for details." * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (270 commits) perf/x86/amd: Enable northbridge performance counters on AMD family 15h perf/hwbp: Fix cleanup in case of kzalloc failure perf tools: Fix build with bison 2.3 and older. perf tools: Limit unwind support to x86 archs perf annotate: Make it to be able to skip unannotatable symbols perf gtk/annotate: Fail early if it can't annotate perf gtk/annotate: Show source lines with gray color perf gtk/annotate: Support multiple event annotation perf ui/gtk: Implement basic GTK2 annotation browser perf annotate: Fix warning message on a missing vmlinux perf buildid-cache: Add --update option uprobes/perf: Avoid uprobe_apply() whenever possible uprobes/perf: Teach trace_uprobe/perf code to use UPROBE_HANDLER_REMOVE uprobes/perf: Teach trace_uprobe/perf code to pre-filter uprobes/perf: Teach trace_uprobe/perf code to track the active perf_event's uprobes: Introduce uprobe_apply() perf: Introduce hw_perf_event->tp_target and ->tp_list uprobes/perf: Always increment trace_uprobe->nhit uprobes/tracing: Kill uprobe_trace_consumer, embed uprobe_consumer into trace_uprobe uprobes/tracing: Introduce is_trace_uprobe_enabled() ...
2013-01-24Merge tag 'please-pull-aer-trace' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/ras/ras into perf/core Use perf/event tracing to report PCI Express advanced errors, by Tony Luck. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-01-19ACPI, APEI: Fixup incorrect 64-bit access width firmware bugLans Zhang
The bit width check was introduced by 15afae60 (ACPI, APEI: Fix incorrect APEI register bit width check and usage), and a fixup for incorrect 32-bit width memory address was given by f712c71 (ACPI, APEI: Fixup common access width firmware bug). Now there is a similar symptom: [Firmware Bug]: APEI: Invalid bit width + offset in GAR [0x12345000/64/0/3/0] Another bogus BIOS reports an incorrect 64-bit width in trigger table. Thus, apply to a similar workaround for 64-bit width memory address. Signed-off-by: Lans Zhang <jia.zhang@windriver.com> Acked-by: Gary Hade <garyhade@us.ibm.com> Acked-by: Myron Stowe <myron.stowe@redhat.com> Acked-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-01-03aerdrv: Enhanced AER loggingLance Ortiz
This patch will provide a more reliable and easy way for user-space applications to have access to AER logs rather than reading them from the message buffer. It also provides a way to notify user-space when an AER event occurs. The aer driver is updated to generate a trace event of function 'aer_event' when a PCIe error is reported over the AER interface. The trace event was added to both the interrupt based aer path and the firmware first path. Signed-off-by: Lance Ortiz <lance.ortiz@hp.com> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Boris Petkov <bp@alien8.de> Signed-off-by: Tony Luck <tony.luck@intel.com>
2013-01-03ACPI / APEI: Fix the returned value in erst_dbg_readAdrian Huang
If the persistent store is empty initially, the function 'erst_dbg_read' returns a nonzero value. The better way is to return a zero indicating the read operation reaches EOF. Tested on two different servers. Signed-off-by: Adrian Huang <adrian.huang@hp.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-12-12Merge tag 'please-pull-einj-fix-for-acpi5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ras/ras Pull ACPI5 error injection fix from Tony Luck: "Trivial fix for error injection code using ACPI5 version of EINJ" * tag 'please-pull-einj-fix-for-acpi5' of git://git.kernel.org/pub/scm/linux/kernel/git/ras/ras: ACPI, APEI, EINJ: Add missed ACPI5 support for error trigger table
2012-12-12Merge tag 'please-pull-pstore_mevent' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux Pull pstore fixes from Tony Luck: "Patch series to allow EFI variable backend to pstore to hold multiple records." * tag 'please-pull-pstore_mevent' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux: efi_pstore: Add a format check for an existing variable name at erasing time efi_pstore: Add a format check for an existing variable name at reading time efi_pstore: Add a sequence counter to a variable name efi_pstore: Add ctime to argument of erase callback efi_pstore: Remove a logic erasing entries from a write callback to hold multiple logs efi_pstore: Add a logic erasing entries to an erase callback efi_pstore: Check remaining space with QueryVariableInfo() before writing data
2012-12-11Merge tag 'driver-core-3.8-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core updates from Greg Kroah-Hartman: "Here's the large driver core updates for 3.8-rc1. The biggest thing here is the various __dev* marking removals. This is going to be a pain for the merge with different subsystem trees, I know, but all of the patches included here have been ACKed by their various subsystem maintainers, as they wanted them to go through here. If this is too much of a pain, I can pull all of them out of this tree and just send you one with the other fixes/updates and then, after 3.8-rc1 is out, do the rest of the removals to ensure we catch them all, it's up to you. The merges should all be trivial, and Stephen has been doing them all in linux-next for a few weeks now quite easily. Other than the __dev* marking removals, there's nothing major here, some firmware loading updates and other minor things in the driver core. All of these have (much to Stephen's annoyance), been in linux-next for a while. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" Fixed up trivial conflicts in drivers/gpio/gpio-{em,stmpe}.c due to gpio update. * tag 'driver-core-3.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (93 commits) modpost.c: Stop checking __dev* section mismatches init.h: Remove __dev* sections from the kernel acpi: remove use of __devinit PCI: Remove __dev* markings PCI: Always build setup-bus when PCI is enabled PCI: Move pci_uevent into pci-driver.c PCI: Remove CONFIG_HOTPLUG ifdefs unicore32/PCI: Remove CONFIG_HOTPLUG ifdefs sh/PCI: Remove CONFIG_HOTPLUG ifdefs powerpc/PCI: Remove CONFIG_HOTPLUG ifdefs mips/PCI: Remove CONFIG_HOTPLUG ifdefs microblaze/PCI: Remove CONFIG_HOTPLUG ifdefs dma: remove use of __devinit dma: remove use of __devexit_p firewire: remove use of __devinitdata firewire: remove use of __devinit leds: remove use of __devexit leds: remove use of __devinit leds: remove use of __devexit_p mmc: remove use of __devexit ...
2012-12-07ACPI, APEI, EINJ: Add missed ACPI5 support for error trigger tableChen Gong
To handle error trigger table correctly, memory region must be removed from request region. We had a series of patches to do this culminating in: commit b4e008dc5 ACPI, APEI, EINJ, Refine the fix of resource conflict but when ACPI5 support was added, we missed updating this area. So when using EINJ table on an ACPI5 enabled machine, we get following error: APEI: Can not request [mem 0x526b80000-0x526b80007] for APEI EINJ Trigger registers Fix this by checking for the acpi5 case and using the same code that was added earlier. Signed-off-by: Chen Gong <gong.chen@linux.intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2012-11-28acpi: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-26efi_pstore: Add a sequence counter to a variable nameSeiji Aguchi
[Issue] Currently, a variable name, which identifies each entry, consists of type, id and ctime. But if multiple events happens in a short time, a second/third event may fail to log because efi_pstore can't distinguish each event with current variable name. [Solution] A reasonable way to identify all events precisely is introducing a sequence counter to the variable name. The sequence counter has already supported in a pstore layer with "oopscount". So, this patch adds it to a variable name. Also, it is passed to read/erase callbacks of platform drivers in accordance with the modification of the variable name. <before applying this patch> a variable name of first event: dump-type0-1-12345678 a variable name of second event: dump-type0-1-12345678 type:0 id:1 ctime:12345678 If multiple events happen in a short time, efi_pstore can't distinguish them because variable names are same among them. <after applying this patch> it can be distinguishable by adding a sequence counter as follows. a variable name of first event: dump-type0-1-1-12345678 a variable name of Second event: dump-type0-1-2-12345678 type:0 id:1 sequence counter: 1(first event), 2(second event) ctime:12345678 In case of a write callback executed in pstore_console_write(), "0" is added to an argument of the write callback because it just logs all kernel messages and doesn't need to care about multiple events. Signed-off-by: Seiji Aguchi <seiji.aguchi@hds.com> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Mike Waychison <mikew@google.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2012-11-26efi_pstore: Add ctime to argument of erase callbackSeiji Aguchi
[Issue] Currently, a variable name, which is used to identify each log entry, consists of type, id and ctime. But an erase callback does not use ctime. If efi_pstore supported just one log, type and id were enough. However, in case of supporting multiple logs, it doesn't work because it can't distinguish each entry without ctime at erasing time. <Example> As you can see below, efi_pstore can't differentiate first event from second one without ctime. a variable name of first event: dump-type0-1-12345678 a variable name of second event: dump-type0-1-23456789 type:0 id:1 ctime:12345678, 23456789 [Solution] This patch adds ctime to an argument of an erase callback. It works across reboots because ctime of pstore means the date that the record was originally stored. To do this, efi_pstore saves the ctime to variable name at writing time and passes it to pstore at reading time. Signed-off-by: Seiji Aguchi <seiji.aguchi@hds.com> Acked-by: Mike Waychison <mikew@google.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2012-11-21ACPI: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-07-14ACPI, APEI: Fixup common access width firmware bugJean Delvare
Many firmwares have a common register definition bug where 8-bit access width is specified for a 32-bit register. Ideally this should be fixed in the BIOS, but earlier versions of the kernel did not complain, so fix that up silently. This closes kernel bug #43282: https://bugzilla.kernel.org/show_bug.cgi?id=43282 Signed-off-by: Jean Delvare <jdelvare@suse.de> Acked-by: Huang Ying <ying.huang@intel.com> Acked-by: Gary Hade <garyhade@us.ibm.com> Cc: stable@vger.kernel.org [3.4+] Signed-off-by: Len Brown <len.brown@intel.com>
2012-06-12ACPI, APEI, Avoid too much error reporting in runtimeHuang Ying
This patch fixed the following bug. https://bugzilla.kernel.org/show_bug.cgi?id=43282 This is caused by a firmware bug checking (checking generic address register provided by firmware) in runtime. The checking should be done in address mapping time instead of runtime to avoid too much error reporting in runtime. Reported-by: Pawel Sikora <pluto@agmk.net> Signed-off-by: Huang Ying <ying.huang@intel.com> Tested-by: Jean Delvare <khali@linux-fr.org> Cc: stable@vger.kernel.org Signed-off-by: Len Brown <len.brown@intel.com>
2012-03-30Merge branch 'apei' into releaseLen Brown
Conflicts: drivers/acpi/apei/apei-base.c This was a conflict between 15afae604651d4e17652d2ffb56f5e36f991cfef (CPI, APEI: Fix incorrect APEI register bit width check and usage) and 653f4b538f66d37db560e0f56af08117136d29b7 (ACPICA: Expand OSL memory read/write interfaces to 64 bits) The former changed a parameter in the call to acpi_os_read_memory64() and the later replaced all calls to acpi_os_read_memory64() with calls to acpi_os_read_memory(). Signed-off-by: Len Brown <len.brown@intel.com>
2012-03-30CPER failed to handle generic error records with multiple sectionsJiang Liu
The function apei_estatus_print() and apei_estatus_check() forget to move ahead the gdata pointer when dealing with multiple generic error data sections. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-03-30ACPI, APEI: Fix incorrect APEI register bit width check and usageGary Hade
The current code incorrectly assumes that (1) the APEI register bit width is always 8, 16, 32, or 64 and (2) the APEI register bit width is always equal to the APEI register access width. ERST serialization instructions entries such as: [030h 0048 1] Action : 00 [Begin Write Operation] [031h 0049 1] Instruction : 03 [Write Register Value] [032h 0050 1] Flags (decoded below) : 01 Preserve Register Bits : 1 [033h 0051 1] Reserved : 00 [034h 0052 12] Register Region : [Generic Address Structure] [034h 0052 1] Space ID : 00 [SystemMemory] [035h 0053 1] Bit Width : 03 [036h 0054 1] Bit Offset : 00 [037h 0055 1] Encoded Access Width : 03 [DWord Access:32] [038h 0056 8] Address : 000000007F2D7038 [040h 0064 8] Value : 0000000000000001 [048h 0072 8] Mask : 0000000000000007 break this assumption by yielding: [Firmware Bug]: APEI: Invalid bit width in GAR [0x7f2d7038/3/0] I have found no ACPI specification requirements corresponding with the above assumptions. There is even a good example in the Serialization Instruction Entries section (ACPI 4.0 section 17.4,1.2, ACPI 4.0a section 2.5.1.2, ACPI 5.0 section 18.5.1.2) that mentions a serialization instruction with a bit range of [6:2] which is 5 bits wide, _not_ 8, 16, 32, or 64 bits wide. Compile and boot tested with 3.3.0-rc7 on a IBM HX5. Signed-off-by: Gary Hade <garyhade@us.ibm.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-03-30ACPI, APEI, EINJ, new parameter to control trigger actionChen Gong
Some APEI firmware implementation will access injected address specified in param1 to trigger the error when injecting memory error, which means if one SRAR error is injected, the crash always happens because it is executed in kernel context. This new parameter can disable trigger action and control is taken over by the user. In this way, an SRAR error can happen in user context instead of crashing the system. This function is highly depended on BIOS implementation so please ensure you know the BIOS trigger procedure before you enable this switch. v2: notrigger should be created together with param1/param2 Tested-by: Tony Luck <tony.luck@lintel.com> Signed-off-by: Chen Gong <gong.chen@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-03-30ACPI, APEI, EINJ, limit the range of einj_paramChen Gong
On the platforms with ACPI4.x support, parameter extension is not always doable, which means only parameter extension is enabled, einj_param can take effect. v2->v1: stopping early in einj_get_parameter_address for einj_param Signed-off-by: Chen Gong <gong.chen@linux.intel.com> Acked-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-03-30ACPI, APEI, Fix ERST header length checkJiang Liu
This fixes a trivial copy & paste error in ERST header length check. It's just for future safety because sizeof(struct acpi_table_einj) equals to sizeof(struct acpi_table_erst) with current ACPI5.0 specification. It applies to v3.3-rc6. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Acked-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-03-22ACPICA: Expand OSL memory read/write interfaces to 64 bitsBob Moore
This change expands acpi_os_read_memory and acpi_os_write_memory to a full 64 bits. This allows 64 bit transfers via the acpi_read and acpi_write interfaces. Note: The internal acpi_hw_read and acpi_hw_write interfaces remain at 32 bits, because 64 bits is not needed to access the standard ACPI registers. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-23Use acpi_os_map_memory() instead of ioremap() in einj driverLuck, Tony
ioremap() has become more picky and is now spitting out console messages like: ioremap error for 0xbddbd000-0xbddbe000, requested 0x10, got 0x0 when loading the einj driver. What we are trying to so here is map a couple of data structures that the EINJ table points to. Perhaps acpi_os_map_memory() is a better tool for this? Most importantly it works, but as a side benefit it maps the structures into kernel virtual space so we can access them with normal C memory dereferences, so instead of using: writel(param1, &v5param->apicid); we can use the more natural: v5param->apicid = param1; Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-23ACPI, APEI, EINJ, cleanup 0 vs NULL confusionDan Carpenter
This function is returning pointers. Sparse complains here: drivers/acpi/apei/einj.c:262:32: warning: Using plain integer as NULL pointer Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-23ACPI, APEI, EINJ Allow empty Trigger Error Action TableNiklas Söderlund
According to the ACPI spec [1] section 18.6.4 the TRIGGER_ERROR action table can consists of zero elements. [1] Advanced Configuration and Power Interface Specification Revision 5.0, December 6, 2011 http://www.acpi.info/DOWNLOADS/ACPIspec50.pdf Signed-off-by: Niklas Söderlund <niklas.soderlund@ericsson.com> Acked-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-21ACPI, APEI: Add 64-bit read/write support for APEI on i386Myron Stowe
Base ACPI (CA) currently does not support atomic 64-bit reads and writes (acpi_read() and acpi_write() split 64-bit loads/stores into two 32-bit transfers) yet APEI expects 64-bit transfer capability, even when running on 32-bit systems. This patch implements 64-bit read and write routines for APEI usage. This patch re-factors similar functionality introduced in commit 04c25997c97, bringing it into the ACPI subsystem in preparation for removing ./drivers/acpi/atomicio.[ch]. In the implementation I have replicated acpi_os_read_memory() and acpi_os_write_memory(), creating 64-bit versions for APEI to utilize, as opposed to something more elegant. My thinking is that we should attempt to see if we can get ACPI's CA/OSL changed so that the existing acpi_read() and acpi_write() interfaces are natively 64-bit capable and then subsequently remove the replication. Signed-off-by: Myron Stowe <myron.stowe@redhat.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-18Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux This includes initial support for the recently published ACPI 5.0 spec. In particular, support for the "hardware-reduced" bit that eliminates the dependency on legacy hardware. APEI has patches resulting from testing on real hardware. Plus other random fixes. * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: (52 commits) acpi/apei/einj: Add extensions to EINJ from rev 5.0 of acpi spec intel_idle: Split up and provide per CPU initialization func ACPI processor: Remove unneeded variable passed by acpi_processor_hotadd_init V2 ACPI processor: Remove unneeded cpuidle_unregister_driver call intel idle: Make idle driver more robust intel_idle: Fix a cast to pointer from integer of different size warning in intel_idle ACPI: kernel-parameters.txt : Add intel_idle.max_cstate intel_idle: remove redundant local_irq_disable() call ACPI processor: Fix error path, also remove sysdev link ACPI: processor: fix acpi_get_cpuid for UP processor intel_idle: fix API misuse ACPI APEI: Convert atomicio routines ACPI: Export interfaces for ioremapping/iounmapping ACPI registers ACPI: Fix possible alignment issues with GAS 'address' references ACPI, ia64: Use SRAT table rev to use 8bit or 16/32bit PXM fields (ia64) ACPI, x86: Use SRAT table rev to use 8bit or 32bit PXM fields (x86/x86-64) ACPI: Store SRAT table revision ACPI, APEI, Resolve false conflict between ACPI NVS and APEI ACPI, Record ACPI NVS regions ACPI, APEI, EINJ, Refine the fix of resource conflict ...
2012-01-18Merge branches 'einj', 'intel_idle', 'misc', 'srat' and 'turbostat-ivb' into ↵Len Brown
release
2012-01-18acpi/apei/einj: Add extensions to EINJ from rev 5.0 of acpi specTony Luck
ACPI 5.0 provides extensions to the EINJ mechanism to specify the target for the error injection - by APICID for cpu related errors, by address for memory related errors, and by segment/bus/device/function for PCIe related errors. Also extensions for vendor specific error injections. Tested-by: Chen Gong <gong.chen@linux.intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-17ACPI APEI: Convert atomicio routinesMyron Stowe
APEI needs memory access in interrupt context. The obvious choice is acpi_read(), but originally it couldn't be used in interrupt context because it makes temporary mappings with ioremap(). Therefore, we added drivers/acpi/atomicio.c, which provides: acpi_pre_map_gar() -- ioremap in process context acpi_atomic_read() -- memory access in interrupt context acpi_post_unmap_gar() -- iounmap Later we added acpi_os_map_generic_address() (2971852) and enhanced acpi_read() so it works in interrupt context as long as the address has been previously mapped (620242a). Now this sequence: acpi_os_map_generic_address() -- ioremap in process context acpi_read()/apei_read() -- now OK in interrupt context acpi_os_unmap_generic_address() is equivalent to what atomicio.c provides. This patch introduces apei_read() and apei_write(), which currently are functional equivalents of acpi_read() and acpi_write(). This is mainly proactive, to prevent APEI breakages if acpi_read() and acpi_write() are ever augmented to support the 'bit_offset' field of GAS, as APEI's __apei_exec_write_register() precludes splitting up functionality related to 'bit_offset' and APEI's 'mask' (see its APEI_EXEC_PRESERVE_REGISTER block). With apei_read() and apei_write() in place, usages of atomicio routines are converted to apei_read()/apei_write() and existing calls within osl.c and the CA, based on the re-factoring that was done in an earlier patch series - http://marc.info/?l=linux-acpi&m=128769263327206&w=2: acpi_pre_map_gar() --> acpi_os_map_generic_address() acpi_post_unmap_gar() --> acpi_os_unmap_generic_address() acpi_atomic_read() --> apei_read() acpi_atomic_write() --> apei_write() Note that acpi_read() and acpi_write() currently use 'bit_width' for accessing GARs which seems incorrect. 'bit_width' is the size of the register, while 'access_width' is the size of the access the processor must generate on the bus. The 'access_width' may be larger, for example, if the hardware only supports 32-bit or 64-bit reads. I wanted to minimize any possible impacts with this patch series so I did *not* change this behavior. Signed-off-by: Myron Stowe <myron.stowe@redhat.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-17ACPI, APEI, Resolve false conflict between ACPI NVS and APEIHuang Ying
Some firmware will access memory in ACPI NVS region via APEI. That is, instructions in APEI ERST/EINJ table will read/write ACPI NVS region. The original resource conflict checking in APEI code will check memory/ioport accessed by APEI via general resource management mech. But ACPI NVS region is marked as busy already, so that the false resource conflict will prevent APEI ERST/EINJ to work. To fix this, this patch excludes ACPI NVS regions when APEI components request resources. So that they will not conflict with ACPI NVS regions. Reported-and-tested-by: Pavel Ivanov <paivanof@gmail.com> Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-17ACPI, APEI, EINJ, Refine the fix of resource conflictXiao, Hui
Current fix for resource conflict is to remove the address region <param1 & param2, ~param2+1> from trigger resource, which is highly relies on valid user input. This patch is trying to avoid such potential issues by fetching the exact address region from trigger action table entry. Signed-off-by: Xiao, Hui <hui.xiao@linux.intel.com> Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-17ACPI, APEI, EINJ, Fix resource conflict on some machineHuang Ying
Some APEI firmware implementation will access injected address specified in param1 to trigger the error when injecting memory error. This will cause resource conflict with RAM. On one of our testing machine, if injecting at memory address 0x10000000, the following error will be reported in dmesg: APEI: Can not request iomem region <0000000010000000-0000000010000008> for GARs. This patch removes the injecting memory address range from trigger table resources to avoid conflict. Signed-off-by: Huang Ying <ying.huang@intel.com> Tested-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-17ACPI, APEI, Printk queued error record before panicHuang Ying
Because printk is not safe inside NMI handler, the recoverable error records received in NMI handler will be queued to be printked in a delayed IRQ context via irq_work. If a fatal error occurs after the recoverable error and before the irq_work processed, we lost a error report. To solve the issue, the queued error records are printked in NMI handler if system will go panic. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-17ACPI, APEI, GHES, Distinguish interleaved error report in kernel logHuang Ying
In most cases, printk only guarantees messages from different printk calling will not be interleaved between each other. But, one APEI GHES hardware error report will involve multiple printk calling, normally each for one line. So it is possible that the hardware error report comes from different generic hardware error source will be interleaved. In this patch, a sequence number is prefixed to each line of error report. So that, even if they are interleaved, they still can be distinguished by the prefixed sequence number. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-17ACPI, APEI, Remove table not found messageHuang Ying
Because APEI tables are optional, these message may confuse users, for example, https://bugs.launchpad.net/ubuntu/+source/linux/+bug/599715 Reported-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-17ACPI, APEI, Print resource errors in conventional formatBjorn Helgaas
Use the normal %pR-like format for MMIO and I/O port ranges. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-17ACPI, APEI, GHES: Add PCIe AER recovery supportHuang Ying
aer_recover_queue() is called when recoverable PCIe AER errors are notified by firmware to do the recovery work. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-13module_param: make bool parameters really bool (drivers & misc)Rusty Russell
module_param(bool) used to counter-intuitively take an int. In fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy trick. It's time to remove the int/unsigned int option. For this version it'll simply give a warning, but it'll break next kernel version. Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-11-17pstore: pass reason to backend write callbackKees Cook
This allows a backend to filter on the dmesg reason as well as the pstore reason. When ramoops is switched to pstore, this is needed since it has no interest in storing non-crash dmesg details. Drop pstore_write() as it has no users, and handling the "reason" here has no obviously correct value. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-11-17pstore: pass allocated memory region back to callerKees Cook
The buf_lock cannot be held while populating the inodes, so make the backend pass forward an allocated and filled buffer instead. This solves the following backtrace. The effect is that "buf" is only ever used to notify the backends that something was written to it, and shouldn't be used in the read path. To replace the buf_lock during the read path, isolate the open/read/close loop with a separate mutex to maintain serialized access to the backend. Note that is is up to the pstore backend to cope if the (*write)() path is called in the middle of the read path. [ 59.691019] BUG: sleeping function called from invalid context at .../mm/slub.c:847 [ 59.691019] in_atomic(): 0, irqs_disabled(): 1, pid: 1819, name: mount [ 59.691019] Pid: 1819, comm: mount Not tainted 3.0.8 #1 [ 59.691019] Call Trace: [ 59.691019] [<810252d5>] __might_sleep+0xc3/0xca [ 59.691019] [<810a26e6>] kmem_cache_alloc+0x32/0xf3 [ 59.691019] [<810b53ac>] ? __d_lookup_rcu+0x6f/0xf4 [ 59.691019] [<810b68b1>] alloc_inode+0x2a/0x64 [ 59.691019] [<810b6903>] new_inode+0x18/0x43 [ 59.691019] [<81142447>] pstore_get_inode.isra.1+0x11/0x98 [ 59.691019] [<81142623>] pstore_mkfile+0xae/0x26f [ 59.691019] [<810a2a66>] ? kmem_cache_free+0x19/0xb1 [ 59.691019] [<8116c821>] ? ida_get_new_above+0x140/0x158 [ 59.691019] [<811708ea>] ? __init_rwsem+0x1e/0x2c [ 59.691019] [<810b67e8>] ? inode_init_always+0x111/0x1b0 [ 59.691019] [<8102127e>] ? should_resched+0xd/0x27 [ 59.691019] [<8137977f>] ? _cond_resched+0xd/0x21 [ 59.691019] [<81142abf>] pstore_get_records+0x52/0xa7 [ 59.691019] [<8114254b>] pstore_fill_super+0x7d/0x91 [ 59.691019] [<810a7ff5>] mount_single+0x46/0x82 [ 59.691019] [<8114231a>] pstore_mount+0x15/0x17 [ 59.691019] [<811424ce>] ? pstore_get_inode.isra.1+0x98/0x98 [ 59.691019] [<810a8199>] mount_fs+0x5a/0x12d [ 59.691019] [<810b9174>] ? alloc_vfsmnt+0xa4/0x14a [ 59.691019] [<810b9474>] vfs_kern_mount+0x4f/0x7d [ 59.691019] [<810b9d7e>] do_kern_mount+0x34/0xb2 [ 59.691019] [<810bb15f>] do_mount+0x5fc/0x64a [ 59.691019] [<810912fb>] ? strndup_user+0x2e/0x3f [ 59.691019] [<810bb3cb>] sys_mount+0x66/0x99 [ 59.691019] [<8137b537>] sysenter_do_call+0x12/0x26 Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-11-01Merge branch 'pstore' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux * 'pstore' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux: pstore: make pstore write function return normal success/fail value pstore: change mutex locking to spin_locks pstore: defer inserting OOPS entries into pstore
2011-10-26Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (46 commits) llist: Add back llist_add_batch() and llist_del_first() prototypes sched: Don't use tasklist_lock for debug prints sched: Warn on rt throttling sched: Unify the ->cpus_allowed mask copy sched: Wrap scheduler p->cpus_allowed access sched: Request for idle balance during nohz idle load balance sched: Use resched IPI to kick off the nohz idle balance sched: Fix idle_cpu() llist: Remove cpu_relax() usage in cmpxchg loops sched: Convert to struct llist llist: Add llist_next() irq_work: Use llist in the struct irq_work logic llist: Return whether list is empty before adding in llist_add() llist: Move cpu_relax() to after the cmpxchg() llist: Remove the platform-dependent NMI checks llist: Make some llist functions inline sched, tracing: Show PREEMPT_ACTIVE state in trace_sched_switch sched: Remove redundant test in check_preempt_tick() sched: Add documentation for bandwidth control sched: Return unused runtime on group dequeue ...
2011-10-12pstore: make pstore write function return normal success/fail valueChen Gong
Currently pstore write interface employs record id as return value, but it is not enough because it can't tell caller if the write operation is successful. Pass the record id back via an argument pointer and return zero for success, non-zero for failure. Signed-off-by: Chen Gong <gong.chen@linux.intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
