ACPICA commit 767ee53354e0c4b7e8e7c57c6dd7bf569f0d52bb
There are issues related to the namespace/interpreter locks, which causes
several ACPI functionalities not specification compliant. The lock issues
were detectec when we were trying to fix the functionalities (please see
Link # [1] for the details).
What's the lock issues? Let's first look into the namespace/interpreter
lock usages inside of the object evaluation and the table loading which are
the key AML interpretion code paths:
Table loading:
acpi_ns_load_table
L(Namespace)
acpi_ns_parse_table
acpi_ns_one_complete_parse(LOAD_PASS1/LOAD_PASS2)
acpi_ds_load1_begion_op
acpi_ds_load1_end_op
acpi_ds_load2_begion_op
acpi_ds_load2_end_op
U(Namespace)
Object evaluation:
acpi_ns_evaluate
L(Interpreter)
acpi_ps_execute_method
acpi_ds_exec_begin_op
acpi_ds_exec_end_op
U(Interpreter)
acpi_ns_load_table
L(Namespace)
U(Namespace)
acpi_ev_initialize_region
L(Namespace)
U(Namespace)
address_space.Setup
address_space.Handler
acpi_os_wait_semaphore
acpi_os_acquire_mutex
acpi_os_sleep
L(Interpreter)
U(Interpreter)
L(Interpreter)
acpi_ex_resolve_node_to_value
U(Interpreter)
acpi_ns_check_return_value
Where:
1. L(Interpreter) means acquire(MTX_INTERPRETER);
2. U(Interpreter) means release(MTX_INTERPRETER);
3. L(Namespace) means acquire(MTX_NAMESPACE);
4. U(Namespace) means release(MTX_NAMESPACE);
We can see that acpi_ns_exec_module_code() (which invokes acpi_ns_evaluate) is
implemented in a deferred way just in order to avoid to reacquire the
namespace lock. This is in fact the root cause of many other ACPICA issues:
1. We now know for sure that the module code should be executed right in
place by the Windows AML interpreter. So in the current design, if
the region initializations/accesses or the table loadings (where the
namespace surely should be locked again) happening during the table
loading period, dead lock could happen because ACPICA never unlocks the
namespace during the AML interpretion.
2. ACPICA interpreter just ensures that all static namespace nodes (named
objects created during the acpi_load_tables()) are created
(acpi_ns_lookup()) with the correct lock held, but doesn't ensure that
the named objects created by the control method are created with the
same correct lock held. It requires the control methods to be executed
in a serial way after "loading a table", that's why ACPICA requires
method auto serialization.
This patch fixes these software design issues by extending interpreter
enter/exit APIs to hold both interpreter/namespace locks to ensure the lock
order correctness, so that we can get these code paths:
Table loading:
acpi_ns_load_table
E(Interpreter)
acpi_ns_parse_table
acpi_ns_execute_table
X(Interpreter)
acpi_ns_load_table
address_space.Setup
acpi_os_sleep
E(Interpreter)
X(Interpreter)
Object evaluation:
acpi_ns_evaluate
E(Interpreter)
X(Interpreter)
acpi_ns_load_table
address_space.Setup
acpi_os_sleep
E(Interpreter)
X(Interpreter)
Where:
1. E(Interpreter) means acquire(MTX_INTERPRETER, MTX_NAMESPACE);
2. X(Interpreter) means release(MTX_NAMESPACE, MTX_INTERPRETER);
After this change, we can see:
1. All namespace nodes creations are locked by the namespace lock.
2. All namespace nodes referencing are locked with the same lock.
3. But we also can notice a defact that, all namespace nodes deletions
could be affected by this change. As a consequence,
acpi_ns_delete_namespace_subtree() may delete a static namespace node that
is still referenced by the interpreter (for example, the parser scopes).
Currently, we needn't worry about the last defact because in ACPICA, table
unloading is not fully functioning, its design strictly relies on the fact
that when the namespace deletion happens, either the AML table or the OSPMs
should have been notified and thus either the AML table or the OSPMs
shouldn't reference deletion-related namespace nodes during the namespace
deletion. And this change still works with the above restrictions applied.
While making this a-step-forward helps us to correct the wrong grammar to
pull many things back to the correct rail. And pulling things back to the
correct rail in return makes it possible for us to support fully
functioning table unloading after doing many cleanups.
While this patch is generated, all namespace locks are examined to ensure
that they can meet either of the following pattens:
1. L(Namespace)
U(Namespace)
2. E(Interpreter)
X(Interpreter)
3. E(Interpreter)
X(Interpreter)
L(Namespace)
U(Namespace)
E(Interpreter)
X(Interpreter)
We ensure this by adding X(Interpreter)/E(Interpreter) or removing
U(Namespace)/L(Namespace) for those currently are executed in the following
order:
E(Interpreter)
L(Namespace)
U(Namespace)
X(Interpreter)
And adding E(Interpreter)/X(Interpreter) for those currently are executed
in the following order:
X(Interpreter)
E(Interpreter)
Originally, the interpreter lock is held for the execution AML opcodes, the
namespace lock is held for the named object creation AML opcodes. Since
they are actually same in MS interpreter (can all be executed during the
table loading), we can combine the 2 locks and tune the locking code better
in this way. Lv Zheng.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=153541 # [1]
Link: https://bugzilla.kernel.org/show_bug.cgi?id=121701 # [1]
Link: https://bugs.acpica.org/show_bug.cgi?id=1323
Link: https://github.com/acpica/acpica/commit/767ee533
Reported-and-tested-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Reported-and-tested-by: Greg White <gwhite@kupulau.com>
Reported-and-tested-by: Dutch Guy <lucht_piloot@gmx.net>
Signed-off-by: Lv Zheng <lv.zheng@intel.com>
Signed-off-by: Bob Moore <robert.moore@intel.com>
ACPICA commit e2e72a351201fd58e4694418859ae2c247dafca0
Consolidate multiple versions of strtoul64 to one common version.
limit possible bases to either 10 or 16.
Handles both implicit and explicit conversions.
Added a 2-character ascii-to-hex function for GPEs and buffers.
Adds a new file, utstrtoul64.c
Link: https://github.com/acpica/acpica/commit/e2e72a35
All tool/utility signons.
Dual-license module header.
ACPICA commit 5923a9be36b8cb1b62afa89fe217783c04c92ad3
To improve readability. Rename all *_TYPE_* defines related to
ObjectType to *_OBJECT_TYPE_*
Link: https://github.com/acpica/acpica/commit/5923a9be
ACPICA commit dfa394471f6c01b2ee9433dbc143ec70cb9bca72
Mostly indentation inconsistencies across the code. Split
some long lines, etc.
Link: https://github.com/acpica/acpica/commit/dfa39447
ACPICA commit 8990e73ab2aa15d6a0068b860ab54feff25bee36
Link: https://github.com/acpica/acpica/commit/8990e73a
Signed-off-by: David E. Box <david.e.box@linux.intel.com>
Update ACPICA copyrights to 2014. Includes all source headers and
signons for the various tools.
It is reported by kernel build test systems that all ACPICA source
files in the kernel tree have incorrect label indentation. This
patch changes default indent option used in the release process to
fix this bug. Lv Zheng.
Disallow the dereference of a reference (via index) to an uninitialized
package element. Provides compatibility with other ACPI
implementations. ACPICA BZ 1003.
References: https://bugs.acpica.org/show_bug.cgi?id=431
refs.
Previously, references to these objects were resolved only to the actual
FieldUnit or BufferField object. The correct behavior is to resolve these
references to an actual value.
The problem is that DerefOf did not resolve these objects to actual
values. An "Integer" object is simple, return the value. But a field in
an operation region will require a read operation. For a BufferField, the
appropriate data must be extracted from the parent buffer.
NOTE: It appears that this issues is present in Windows7 but not
Windows8.
After many years, different formatting for switch() has crept in.
This change makes every switch block identical. Chao Guan.
ACPICA bugzilla 997.
References: https://bugs.acpica.org/show_bug.cgi?id=997
Signed-off-by: Chao Guan <chao.guan@intel.com>
Includes all source headers and signons for the various tools.
This is a cosmetic patch only. Comparison of the resulting binary showed
only line number differences.
This patch does not affect the generation of the Linux binary.
This patch decreases 210 lines of 20121018 divergence.diff.
The ACPICA source codes uses a totally different indentation style from the
Linux to be compatible with other users (operating systems or BIOS).
Indentation differences are critical to the release automation. There are
two causes related to the "indentation" that are affecting the release
automation:
1. The ACPICA -> Linux release process is:
ACPICA source -- acpisrc - hierarchy - indent ->
linuxized ACPICA source -- diff ->
linuxized ACPICA patch (x) -- human intervention ->
linuxized ACPICA patch (o)
Where
'x' means "cannot be directly applied to the Linux"
'o' means "can be directly applied to the Linux"
Different "indent" version or "indent" options used in the "indent"
step will lead to different divergences.
The version of "indent" used for the current release process is:
GNU indent 2.2.11
The options of "indent" used for the current release process is:
-npro -kr -i8 -ts8 -sob -l80 -ss -ncs
2. Manual indentation prettifying work in the Linux side will also harm the
automatically generated linuxized ACPICA patches, making them impossible
to apply directly.
This patch fixes source code differences caused by the two causes so that
the "human intervention" can be reduced in the future.
This makes all comments consistent.
Maintenance for source code consistency.
Update all copyrights to 2012.
Signed-off-by: Lin Ming <ming.m.lin@intel.com>
Signed-off-by: Len Brown <len.brown@intel.com>
Suspend has other meanings in ACPI context, name was misleading.
Always use 0x prefix for hex output, use %u for integer output
(all integers are unsigned.)
This type was introduced as the code was migrated from ACPI 1.0
(with 32-bit AML integers) to ACPI 2.0 (with 64-bit integers). It
is now obsolete and this change removes it from the ACPICA code
base, replaced by u64. The original typedef has been retained
for now for compatibility with existing device driver code.
Add 2010 copyright to all module headers and signons, including
the Linux header. This affects virtually every file in the ACPICA
core subsystem, iASL compiler, and all utilities.
Simplifies creation of simple integer objects.
ACPICA BZ 823.
http://www.acpica.org/bugzilla/show_bug.cgi?id=823
Remove all instances of this obsolete macro, since it is now a
simple reference to ->common.type. There were about 150 invocations
of the macro across 41 files. ACPICA BZ 755.
http://www.acpica.org/bugzilla/show_bug.cgi?id=755
also, delete sleep/ and delete ACPI_CFLAGS from Makefile
